  4. ioBroker macht Probleme im Docker
    6.5k
33 Beiträge 10 Kommentatoren 2.1k Aufrufe 6 Beobachtet
    @mühlenbroker
    Und was steht sonst drin?
    Komplette Ausgabe des Skripts posten.
    Mühlenbroker
    ========= Start marking the full check here ===========
    Script v.2024-09-21
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.31+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     19:08:20 up  2:36,  2 users,  load average: 0.22, 0.20, 0.18
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-09-29 19:08:21 CEST
               Universal time: Mon 2025-09-29 17:08:21 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    thomas
    XDG_CONFIG_HOME=/home/thomas/.config
    HOME=/home/thomas
    GROUPS=thomas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi
    thomas
    HOME=/home/thomas
    GROUPS=thomas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Do you want to switch to 'multi-user.target'? (y/n)
    • M Mühlenbroker
      Script v.2024-09-21
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      thomas
      HOME=/home/thomas
      thomas
      HOME=/home/thomas
      Desktop: 	LXDE-pi
      Terminal: 	x11
      @mühlenbroker sagte in ioBroker macht Probleme im Docker:
      Docker : false
      Da läuft doch gar kein Docker. Dafür halt ein Display-Server:
      Unnötig.
      Und der Rest der Ausgabe fehlt.
        Docker : false
        Unnötig.
        Mühlenbroker
        nicht? Ich bin laie, wenn ich in die Portainer Oberfläche gehe, läuft er ja. Bringe ich irgendwas durcheinander?
        • M Mühlenbroker
          Offenbar. Und warum ein Laie gleich mit Dockern & Co. herummacht werde ich wohl auch nie verstehen. Da fehlen offenbar die absoluten Grundlagen, die man für den zusätzlichen Stack braucht.
            Mühlenbroker
            Ich habe mir das damals nach einer Anleitung so zusammengestellt und es war für mich Plausibel.
            • M Mühlenbroker
              T Nicht stören
              T Nicht stören
              ticaki
              @mühlenbroker
              Poste bitte die ganze ausgabe von iob diag - die ist unglaublich lang.
              Spenden
              • T ticaki
                @mühlenbroker
                Mühlenbroker
                @ticaki
                Script v.2024-09-21
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                thomas
                HOME=/home/thomas
                thomas
                HOME=/home/thomas
                Desktop: 	LXDE-pi
                Terminal: 	x11
                New boot target is multi-user now! The system needs to be restarted.
                Removed "/etc/systemd/system/default.target".
                Created symlink /etc/systemd/system/default.target -> /lib/systemd/system/multi-user.target.
                *** MEMORY ***
                Mem:            8.2G        2.0G        649M        225M        5.9G        6.2G
                Swap:           209M          0B        209M
                Total:          8.4G        2.0G        859M
                Active iob-Instances: 	0
                         7809 M total memory
                         1927 M used memory
                         6028 M active memory
                          702 M inactive memory
                          618 M free memory
                          173 M buffer memory
                         5426 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                top - 19:29:02 up  2:57,  2 users,  load average: 0.20, 0.14, 0.16
                Tasks: 252 total,   1 running, 251 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 22.2 us, 22.2 sy,  0.0 ni, 55.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   7809.0 total,    616.9 free,   1929.5 used,   5600.0 buff/cache
                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5879.5 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** DMESG CRITICAL ERRORS ***
                No critical errors detected
                *** FILESYSTEM ***
                udev           devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs          tmpfs     781M  1.8M  780M   1% /run
                /dev/sda2      ext4      917G   43G  828G   5% /
                tmpfs          tmpfs     3.9G  148K  3.9G   1% /dev/shm
                tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                /dev/sda1      vfat      510M   75M  436M  15% /boot/firmware
                tmpfs          tmpfs     781M   40K  781M   1% /run/user/1000
                [Mon Sep 29 16:32:02 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:06:B6:2B vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=550f0a9c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                [Mon Sep 29 16:32:07 2025] EXT4-fs (sda2): mounted filesystem 4aa56689-dcb4-4759-90e6-179beae559ac ro with ordered data mode. Quota mode: none.
                [Mon Sep 29 16:32:08 2025] EXT4-fs (sda2): re-mounted 4aa56689-dcb4-4759-90e6-179beae559ac r/w. Quota mode: none.
                Show mounted filesystems:
                TARGET                           SOURCE       FSTYPE           OPTIONS
                /                                /dev/sda2    ext4             rw,noatime
                |-/run/user/1000/doc             portal       fuse.portal      rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                |-/boot/firmware                 /dev/sda1    vfat             rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-r
                `-/home/thomas/thinclient_drives xrdp-chansrv fuse.xrdp-chansr rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                /var:
                40G	/var/
                37G	/var/lib/docker
                37G	/var/lib
                29G	/var/lib/docker/volumes
                27G	/var/lib/docker/volumes/influxdb/_data/engine/data/1697462a5e13427f/autogen
                Archived and active journals take up 1.9G in the file system.
                /opt/iobroker/backups:
                4.0K	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                91M	/opt/iobroker/iobroker-data/
                69M	/opt/iobroker/iobroker-data/files
                47M	/opt/iobroker/iobroker-data/files/admin.admin
                46M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                17M	/opt/iobroker/iobroker-data/objects.jsonl
                8.6M	/opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                3.9M	/opt/iobroker/iobroker-data/states.jsonl
                3.7M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-00V6sJFg.js
                3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
                USB-Devices by-id:
                No Devices found 'by-id'
                *** NodeJS-Installation ***
                nodejs: 		N/A
                node: 		N/A
                npm: 			N/A
                npx: 			N/A
                corepack: 	N/A
                *** nodejs is NOT correctly installed ***
                nodejs:
                  Installed: (none)
                  Candidate: 18.20.4+dfsg-1~deb12u1
                  Version table:
                     18.20.4+dfsg-1~deb12u1 500
                        500 http://deb.debian.org/debian bookworm/main arm64 Packages
                        500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                Temp directories causing deletion problem: 1
                Some problems detected, please run iob fix
                Errors in npm tree: 0
                No problems detected
                *** ioBroker-Installation ***
                ioBroker Status
                ./iob_diag.sh: line 893: iob: command not found
                Hosts:
                ./iob_diag.sh: line 895: iob: command not found
                Core adapters versions
                ./iob_diag.sh: line 901: iob: command not found
                js-controller:
                ./iob_diag.sh: line 902: iob: command not found
                admin:
                ./iob_diag.sh: line 903: iob: command not found
                javascript:
                nodejs modules from github: 	0
                Adapter State
                ioBroker-Repositories
                ./iob_diag.sh: line 915: iob: command not found
                Installed ioBroker-Instances
                ./iob_diag.sh: line 918: iob: command not found
                Objects and States
                Objects: 	0
                States: 	0
                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                Reading package lists... Done
                Pending Updates: 383
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8609       792/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:9090            0.0.0.0:*               LISTEN      0          9918       2174/docker-proxy
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12875      2765/cupsd
                tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          11762      2076/docker-proxy
                tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      0          10816      2102/docker-proxy
                tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN      0          11734      2027/docker-proxy
                tcp        0      0 0.0.0.0:8086            0.0.0.0:*               LISTEN      0          9893       2121/docker-proxy
                tcp        0      0 127.0.0.1:40743         0.0.0.0:*               LISTEN      0          6385       765/containerd
                tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          12421      2143/docker-proxy
                tcp6       0      0 ::1:3350                :::*                    LISTEN      0          7326       766/xrdp-sesman
                tcp6       0      0 :::22                   :::*                    LISTEN      0          8611       792/sshd: /usr/sbin
                tcp6       0      0 :::9090                 :::*                    LISTEN      0          11804      2188/docker-proxy
                tcp6       0      0 :::9443                 :::*                    LISTEN      0          12408      2084/docker-proxy
                tcp6       0      0 :::3000                 :::*                    LISTEN      0          10819      2109/docker-proxy
                tcp6       0      0 :::3389                 :::*                    LISTEN      112        9232       804/xrdp
                tcp6       0      0 :::8081                 :::*                    LISTEN      0          11739      2041/docker-proxy
                tcp6       0      0 :::8086                 :::*                    LISTEN      0          12418      2129/docker-proxy
                tcp6       0      0 :::8000                 :::*                    LISTEN      0          12424      2151/docker-proxy
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12874      2765/cupsd
                udp        0      0 0.0.0.0:32786           0.0.0.0:*                           104        5396       579/avahi-daemon: r
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12919      2767/cups-browsed
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5394       579/avahi-daemon: r
                udp6       0      0 :::49062                :::*                                104        5397       579/avahi-daemon: r
                udp6       0      0 fe80::fda2:67b9:1e9:546 :::*                                0          10649      616/NetworkManager
                udp6       0      0 fe80::e3a4:2db4:b49:546 :::*                                0          10428      616/NetworkManager
                udp6       0      0 :::5353                 :::*                                104        5395       579/avahi-daemon: r
                2025-09-29 19:14:11.394  - info: mqtt.0 (231) All states published
                2025-09-29 19:19:11.394  - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connection closed: timeout
                2025-09-29 19:19:11.396  - info: mqtt.0 (231) Disconnected from 127.0.0.1: undefined
                2025-09-29 19:19:21.397  - info: mqtt.0 (231) Reconnected to 127.0.0.1
                2025-09-29 19:19:21.402  - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connected with secret 1759166361401_1251
                2025-09-29 19:19:21.406  - info: mqtt.0 (231) Connected to 127.0.0.1
                2025-09-29 19:19:21.408  - info: mqtt.0 (231) Subscribe on "#"
                2025-09-29 19:19:21.409  - info: mqtt.0 (231) Publishing state mqtt.0.info.connection
                2025-09-29 19:19:21.411  - info: mqtt.0 (231) All states published
                2025-09-29 19:24:21.413  - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connection closed: timeout
                2025-09-29 19:24:21.415  - info: mqtt.0 (231) Disconnected from 127.0.0.1: undefined
                2025-09-29 19:24:31.415  - info: mqtt.0 (231) Reconnected to 127.0.0.1
                2025-09-29 19:24:31.419  - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connected with secret 1759166671417_8156
                2025-09-29 19:24:31.421  - info: mqtt.0 (231) Connected to 127.0.0.1
                2025-09-29 19:24:31.422  - info: mqtt.0 (231) Subscribe on "#"
                2025-09-29 19:24:31.423  - info: mqtt.0 (231) Publishing state mqtt.0.info.connection
                2025-09-29 19:24:31.424  - info: mqtt.0 (231) All states published
                2025-09-29 19:29:31.424  - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connection closed: timeout
                2025-09-29 19:29:31.427  - info: mqtt.0 (231) Disconnected from 127.0.0.1: undefined
                2025-09-29 19:29:41.428  - info: mqtt.0 (231) Reconnected to 127.0.0.1
                2025-09-29 19:29:41.433  - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connected with secret 1759166981431_5259
                2025-09-29 19:29:41.438  - info: mqtt.0 (231) Connected to 127.0.0.1
                2025-09-29 19:29:41.439  - info: mqtt.0 (231) Subscribe on "#"
                2025-09-29 19:29:41.439  - info: mqtt.0 (231) Publishing state mqtt.0.info.connection
                2025-09-29 19:29:41.441  - info: mqtt.0 (231) All states published
                iob diag has finished.
                • M Mühlenbroker
                  @ticaki
                  Script v.2024-09-21
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  thomas
                  HOME=/home/thomas
                  thomas
                  HOME=/home/thomas
                  Desktop: 	LXDE-pi
                  Terminal: 	x11
                  *** MEMORY ***
                  Swap:           209M          0B        209M
                           7809 M total memory
                           1927 M used memory
                            618 M free memory
                            173 M buffer memory
                           5426 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  *** FILESYSTEM ***
                  /var:
                  40G	/var/
                  37G	/var/lib/docker
                  37G	/var/lib
                  USB-Devices by-id:
                  nodejs: 		N/A
                  node: 		N/A
                  npm: 			N/A
                  npx: 			N/A
                  corepack: 	N/A
                  nodejs:
                    Installed: (none)
                    Version table:
                  ioBroker Status
                  Hosts:
                  js-controller:
                  admin:
                  javascript:
                  Adapter State
                  Objects and States
                  Objects: 	0
                  States: 	0
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @mühlenbroker
                  Mal von dem iob diag (und den katastrophalen Infos ) weg , nach welcher Anleitung hast Du installiert ?
                  • haselchenH haselchen
                    @mühlenbroker
                    Mühlenbroker
                    @haselchen
                    das ist eine gute Frage. Wenn ich die Anleitung nur noch hätte. Zwei Jahre sind vergangen...
                    • M Mühlenbroker
                      es stehen eben nur die Adapter von der Neuinstallation drin.
                      das sind aber nur wenige,
                      sonoff und mqtt gehören nicht dazu
                        Mühlenbroker
                        ja, jetzt sind es sehr wenige. Ich hab das halt vermasselt und es wird mir wohl viel Arbeit bevorstehen.
                        • M Mühlenbroker
                          hast du gelesen was ich schrieb??
                          hier nochmal:
                          laut log läuft bei dir sonoff und mqtt.
                          Die sind in keiner Neuinstallation dabei!
                          Also müssten die aus dem Backup kommen.
                          BTW
                          was ist aus
                          @homoran sagte in ioBroker macht Probleme im Docker:
                          @mühlenbroker entpack doch mal dein backup und zeig was drin steht
                          geworden?
                            hier nochmal:
                            BTW
                            was ist aus
                            geworden?
                            Mühlenbroker
                            ja, diese beiden habe ich versucht, nach der Neuinstallation zu Installieren. Das hat allerdings auch nicht so recht geklappt. Ich sitze ja nun schon zwei Tage dran und habe sicher eineiges in die falsche Richtung gemacht.Screenshot 1.jpg
                            Nach der Backup Datei schaue ich nochmal
                            HomoranH CodierknechtC 2 Antworten Letzte Antwort
                            • M Mühlenbroker
                              @mühlenbroker logs bitte immer als Text in code-tags posten
                              • M Mühlenbroker
                                CodierknechtC Offline
                                Codierknecht
                                Sowas gehört auf jeden Fall auf einen separaten Datenträger. Also ins NAS, auf 'nen Stick oder gleich in die Cloud.
                                Wenn Du ein aktuelles Backup gefunden hast, solltest Du vielleicht nochmal neu anfangen.
                                Also von Grund auf neu installieren. Und zwar ohne Desktop. Was nicht installiert ist, frisst keine Ressourcen und kann auch keine Probleme produzieren. Braucht man für ioBroker ja auch nicht.
                                Wie das geht, steht hier: https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                Als Anfänger und auf einem kleinen Pi macht Docker IMHO nicht wirklich Sinn. Auch wenn's technisch funktionieren sollte.
                                Das muss dann erstmal sauber laufen.
                                Wenn Du soweit bist, melde dich wieder hier.
                                HmIP|ZigBee|Tasmota|Unifi
                                Zabbix Certified Specialist
                                • CodierknechtC Codierknecht
                                  Mühlenbroker
                                  @codierknecht
                                  Ich habe alles neu aufgesetzt und es läuft wieder hervorragend. Als nächstes kümmere ich mich ums Backup.
