  4. Problem mit Admin Update 7.7.2
    5.4k
29 Beiträge 4 Kommentatoren 2.7k Aufrufe 4 Beobachtet
    @saeft_2003
    Dann zeig jetzt nochmal
    iob diag
    saeft_2003
    @thomas-braun sagte in Problem mit Admin Update 7.7.2:
    @saeft_2003
    iob diag
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-39-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     10:02:23 up 43 min,  2 users,  load average: 1.00, 1.07, 0.91
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-09-14 10:02:23 CEST
               Universal time: Sun 2025-09-14 08:02:23 UTC
                     RTC time: Sun 2025-09-14 08:02:23
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    patrick
    HOME=/home/patrick
    GROUPS=patrick adm dialout cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             12G        4.8G        6.9G        548K        758M        7.4G
    Swap:           1.0G          0B        1.0G
    Total:           13G        4.8G        7.9G
    Active iob-Instances:   51
            11676 M total memory
             4607 M used memory
              235 M active memory
             4552 M inactive memory
             6601 M free memory
               64 M buffer memory
              659 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 10:02:24 up 43 min,  2 users,  load average: 1.00, 1.07, 0.91
    Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  11676.7 total,   6600.7 free,   4607.9 used,    724.1 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7068.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  5.7G     0  5.7G   0% /dev
    tmpfs          tmpfs     1.2G  536K  1.2G   1% /run
    /dev/sda1      ext4       31G   14G   16G  48% /
    tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
    [Sun Sep 14 09:19:06 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Sep 14 09:19:06 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    3.5G    /var/
    2.7G    /var/log/journal/27edfd6da47743cab5e987a6643f0827
    2.7G    /var/log
    600M    /var/cache
    Archived and active journals take up 2.6G in the file system.
    /opt/iobroker/backups:
    1.1G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    994M    /opt/iobroker/iobroker-data/
    612M    /opt/iobroker/iobroker-data/files
    236M    /opt/iobroker/iobroker-data/backup-objects
    115M    /opt/iobroker/iobroker-data/files/vis.0
    114M    /opt/iobroker/iobroker-data/files/vis-2.0
    81M     /opt/iobroker/iobroker-data/objects.jsonl
    61M     /opt/iobroker/iobroker-data/states.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.5
    /usr/bin/node           v20.19.5
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 20.19.5-1nodesource1
      Candidate: 20.19.5-1nodesource1
      Version table:
     *** 20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 2600)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     8
    +-- iobroker.labcom@0.1.6 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#b03e1f4e04d4839b753872ba9c97b0a2a84255a8)
    +-- iobroker.proxmox@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.proxmox.git#3998404a0bb41a2370f5804f4fc332dea916e8bc)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.vedirect@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.vedirect.git#043f003dc44aed8ee3d6f9a7b1f8617b95dd9cc1)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.web-speedy.git#79889767b80052eb5093509d55a7751d966e80ed)
    +-- iobroker.woso_mitsu_aircon_rac@1.0.1 (git+ssh://git@github.com/wolkeSoftware/ioBroker.woso_mitsu_aircon_rac.git#c96849c7b4249f3b1519014ccb298679a4ecc2e9)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.backitup.1               : backitup              : iobroker                                 - disabled
    + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
    + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
      system.adapter.history.0                : history               : iobroker                                 - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.labcom.0                 : labcom                : iobroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mhi-wfrac.0              : mhi-wfrac             : iobroker                                 -  enabled
      system.adapter.mhi-wfrac.1              : mhi-wfrac             : iobroker                                 - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.mqtt.2                   : mqtt                  : iobroker                                 - disabled, port: 1884, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 - disabled
    + system.adapter.ph803w.0                 : ph803w                : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      system.adapter.ping.1                   : ping                  : iobroker                                 - disabled
    + system.adapter.ping.2                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.proxmox.1                : proxmox               : iobroker                                 - disabled, port: 8006
    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
      system.adapter.reolink.1                : reolink               : iobroker                                 - disabled
      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
    + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.simple-api.1             : simple-api            : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.statistics.0             : statistics            : iobroker                                 - disabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
      system.adapter.synology.1               : synology              : iobroker                                 - disabled, port: 5000
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.3               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
      system.adapter.vedirect.0               : vedirect              : iobroker                                 - disabled
      system.adapter.vedirect.1               : vedirect              : iobroker                                 - disabled
      system.adapter.vedirect.2               : vedirect              : iobroker                                 - disabled
      system.adapter.vedirect.3               : vedirect              : iobroker                                 - disabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
    + system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, port: 5000
      system.adapter.wiobrowser.1             : wiobrowser            : iobroker                                 - disabled, port: 5000
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
      system.adapter.woso_mitsu_aircon_rac.0  : woso_mitsu_aircon_rac : iobroker                                 - disabled
      system.adapter.woso_mitsu_aircon_rac.1  : woso_mitsu_aircon_rac : iobroker                                 - disabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      system.adapter.yahka.1                  : yahka                 : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.107:6638
    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.108:6638
    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.110:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.2    , installed 7.6.17 [Updatable]
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
    Adapter    "countdown"    : 3.0.0    , installed 3.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "ebus"         : 3.6.3    , installed 3.6.3
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "mhi-wfrac"    : 2.1.7    , installed 2.1.7
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wled"         : 0.7.2    , installed 0.7.3
    Adapter    "worx"         : 3.2.7    , installed 3.2.7
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
    Objects and States
    Objects:        49806
    States:         42339
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       20424      966/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       20423      966/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20449      981/io.mqtt.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18169      1202/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18089      1148/io.shelly.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15540      491/sshd: /usr/sbin
    tcp        0      0 192.168.178.90:42001    0.0.0.0:*               LISTEN      1001       17839      891/io.hm-rpc.1
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13972      1/init
    tcp        0      0 192.168.178.90:42010    0.0.0.0:*               LISTEN      1001       16074      874/io.hm-rpc.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15559      470/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15564      470/iobroker.js-con
    tcp        0      0 127.0.0.1:37051         0.0.0.0:*               LISTEN      1001       23591      1338/io.yahka.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23852      1546/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22507      1642/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15359      514/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       24637      1570/io.simple-api.
    tcp6       0      0 :::39905                :::*                    LISTEN      1001       18384      1338/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15551      491/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13179      1/init
    udp        0      0 0.0.0.0:46888           0.0.0.0:*                           1001       20461      997/io.ph803w.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21026      1275/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21027      1275/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15450      397/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14564      1/init
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17911      951/io.mihome-vacuu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25056      1745/io.esphome.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23175      1679/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18389      1338/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18388      1338/io.yahka.0
    udp        0      0 192.168.178.90:5353     0.0.0.0:*                           1001       18235      1251/io.tr-064.0
    udp6       0      0 :::111                  :::*                                0          13973      1/init
    • S saeft_2003
      @saeft_2003
      iob diag
      Script v.2025-08-09
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      patrick
      HOME=/home/patrick
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
               4607 M used memory
                235 M active memory
               6601 M free memory
                 64 M buffer memory
                659 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      3.5G    /var/
      2.7G    /var/log
      600M    /var/cache
      USB-Devices by-id:
      HINT:
      tcp
      HINT:
      tcp
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        49806
      States:         42339
      Pending Updates: 0
      @saeft_2003 sagte in Problem mit Admin Update 7.7.2:
      Jetzt läuft der admin:
      Adapter State
      Bring jetzt nodejs auf Version 22:
      iob nodejs-update
      Und danach die Ausgabe von
      iob update
      iob upgrade
      • S saeft_2003
        @homoran sagte in Problem mit Admin Update 7.7.2:
        obwohl der admin läuft.
        tut er nicht!
        dann müsste ein + davor sein
        ah ok ich dachte enable heißt das er läuft.
        nein!
        enable heisst, dass du die Instanz aktiviert und nicht pausiert hast
        Log File - Last 25 Lines
        wären jetzt sehr interessant gewesen
          Adapter State
          iob nodejs-update
          iob update
          iob upgrade
          saeft_2003
          admin läuft jetzt nur weil ich ich wieder zurück bin auf 7.6.17. Trotzdem weiter machen mit dem node update?
          • S saeft_2003
            Kannst du dann bitte tun was wir sagen? Danke...
              saeft_2003
              ja klar mach ich, hab nur gedacht das wir evtl. gerade aneinander vorbei reden. Ich mache jetzt das node update dann melde ich mich.
              @Homoran
              Das log file hab ich leider nicht mehr...
              • S saeft_2003
                @Homoran
                Das liegt in
                /home/iobroker/iob_diag.log
                  Das liegt in
                  saeft_2003
                  patrick@iobroker:~$ iob update
                  patrick@iobroker:~$ iob upgrade
                  This upgrade of "admin" will introduce the following changes:
                  -> 7.7.2:
                  Fixing change of the language in the admin
                  -> 7.7.1:
                  Fixing clearing of the filter on the object tab
                  -> 7.7.0:
                  Added the concept for single-side-on authentication (SSO)
                  -> 7.6.20:
                  Allowed using of * in the filter of objects
                  Small GUI improvements
                  -> 7.6.19:
                  Improvements on JSONConfig component `state`
                  Added `infoBox` JSONConfig component
                  -> 7.6.18:
                  Added OAuth2 authentication to JSONConfig components
                  Would you like to upgrade admin from @7.6.17 to @7.7.2 now? [(y)es, (n)o]: y
                  Update admin from @7.6.17 to @7.7.2
                  host.iobroker Adapter "system.adapter.admin.0" is stopped.
                  NPM version: 10.9.3
                  Installing iobroker.admin@7.7.2... (System call)
                  added 16 packages, and changed 9 packages in 6s
                  251 packages are looking for funding
                    run `npm fund` for details
                  Updating objects from io-package.json for adapter "admin" with version "7.7.2"
                  Update "system.adapter.admin.0"
                  upload [171] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                  upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
                  upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
                  upload [90] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-C0FlO84Y.js custom/assets/index-C0FlO84Y.js application/javascript
                  upload [80] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-CcDQHtwq.js custom/assets/index-CcDQHtwq.js application/javascript
                  upload [70] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js custom/assets/index-DIVai5gZ.js application/javascript
                  upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-G9F5mhbe.js custom/assets/index-G9F5mhbe.js application/javascript
                  upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-eQxyhk2m.js custom/assets/index-eQxyhk2m.js application/javascript
                  upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/jsx-runtime-DEOw6lrW.js custom/assets/jsx-runtime-DEOw6lrW.js application/javascript
                  upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/virtualExposes-BufY-8i6.js custom/assets/virtualExposes-BufY-8i6.js application/javascript
                  upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
                  upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                  upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                  upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
                  upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
                  upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                  upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                  upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                  upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                  upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json
                  upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json
                  upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json
                  upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json
                  upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json
                  upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json
                  upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json
                  upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json
                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json
                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json
                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                  host.iobroker Adapter "system.adapter.admin.0" is started
                    saeft_2003
                    @Homoran @Thomas-Braun
                    Nach dem node-js update komme ich wieder auf admin mit 7.7.2 👍
                    Lag das jetzt an node-js? Die war doch mit 20.x jetzt noch nicht so alt...
                    • S saeft_2003
                      Aber nicht mehr die Empfehlung...
                      Und 20 läuft auch in wenigen Monaten aus.
                        saeft_2003
                        Ok Hauptsache es läuft wieder. Vielen Dank für eure Hilfe 👍
                        • S saeft_2003
                          @saeft_2003
                          Die Installation künftig regelmäßiger auf Stand halten und den Empfehlungen folgen.
                            @saeft_2003
                            saeft_2003
                            schrieb am zuletzt editiert von saeft_2003
                            Da hast du natürlich recht, aber ich bin da eigentlich schon immer dran das System aktuell zu halten. Ich hatte mir auch schon den Thread von Apollon zu Node 22 durchgelesen gehabt vor ein paar Tagen.
                            Die Empfehlung ist jetzt erstmal grad vier Wochen her und Apollon schreibt ja auch das keinen Grund zur Eile gibt da Node 20 stabil läuft. Deswegen wollte ich jetzt demnächst das Update machen, weil im Moment daheim grad viel los ist.
                            Deswegen habe ich auch nicht gedacht, dass mein Problem mit dem admin zusammen hängen kann.
                            • S saeft_2003
                              @saeft_2003
                              Dann die nächste Aufgabe für den Herbst:
                                @saeft_2003
                                saeft_2003
                                Ja hab ich schon auf dem Plan. Erstelle dann einfach eine neue VM und spiele das backup ein...
                                  saeft_2003
                                  So jetzt habe ich das Problem wieder. Nach dem update von admin 7.7.2 auf 7.7.19 komme ich nicht auf den admin. Es kommt einfach nichts...
                                  Mit iob list instances sehe ich aber das der admin läuft. Mach ich ein downgrade 7.7.2 komme ich wieder drauf.
                                  An was kann das liegen?
                                  Script v.2025-08-09
                                  *** BASE SYSTEM ***
                                           Chassis: vm 🖴
                                    Virtualization: kvm
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                   19:03:58 up 52 days,  9:17,  4 users,  load average: 1.33, 0.77, 0.52
                                  CPU threads: 8
                                                 Local time: Wed 2025-11-05 19:03:58 CET
                                             Universal time: Wed 2025-11-05 18:03:58 UTC
                                                   RTC time: Wed 2025-11-05 18:03:58
                                                NTP service: active
                                            RTC in local TZ: no
                                  patrick
                                  HOME=/home/patrick
                                  iobroker
                                  HOME=/home/iobroker
                                  Display-Manager:
                                  Desktop:
                                  Session:                tty
                                  *** MEMORY ***
                                  Mem:             14G        6.7G        4.7G        2.0M        3.3G        7.6G
                                  Swap:           1.0G          0B        1.0G
                                  Total:           15G        6.7G        5.7G
                                          13644 M total memory
                                           6363 M used memory
                                           1020 M active memory
                                           7658 M inactive memory
                                           4493 M free memory
                                             34 M buffer memory
                                           3075 M swap cache
                                            974 M total swap
                                              0 M used swap
                                            974 M free swap
                                  top - 19:03:58 up 52 days,  9:17,  4 users,  load average: 1.33, 0.77, 0.52
                                  Tasks: 168 total,   1 running, 167 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :  13644.6 total,   4493.0 free,   6362.7 used,   3111.2 buff/cache
                                  MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7282.0 avail Mem
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  6.7G     0  6.7G   0% /dev
                                  tmpfs          tmpfs     1.4G  1.9M  1.4G   1% /run
                                  /dev/sda1      ext4       31G   15G   15G  51% /
                                  tmpfs          tmpfs     6.7G     0  6.7G   0% /dev/shm
                                  tmpfs          tmpfs     1.4G     0  1.4G   0% /run/user/1000
                                  tmpfs          tmpfs     1.4G     0  1.4G   0% /run/user/0
                                  [Sun Sep 14 10:46:19 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Sun Sep 14 10:46:19 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                  /var:
                                  3.6G    /var/
                                  2.8G    /var/log/journal/27edfd6da47743cab5e987a6643f0827
                                  2.8G    /var/log
                                  636M    /var/cache
                                  Archived and active journals take up 2.7G in the file system.
                                  989M    /opt/iobroker/iobroker-data/
                                  597M    /opt/iobroker/iobroker-data/files
                                  242M    /opt/iobroker/iobroker-data/backup-objects
                                  75M     /opt/iobroker/iobroker-data/states.jsonl
                                  71M     /opt/iobroker/iobroker-data/objects.jsonl
                                  19M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.b371dc6f.js.map
                                  USB-Devices by-id:
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  /usr/bin/nodejs         v22.21.0
                                  /usr/bin/node           v22.21.0
                                  /usr/bin/npm            10.9.4
                                  /usr/bin/npx            10.9.4
                                  /usr/bin/corepack       0.34.0
                                  nodejs:
                                    Installed: 22.21.0-1nodesource1
                                    Candidate: 22.21.0-1nodesource1
                                    Version table:
                                   *** 22.21.0-1nodesource1 1001
                                       22.20.0-1nodesource1 1001
                                       22.19.0-1nodesource1 1001
                                       22.18.0-1nodesource1 1001
                                       22.17.1-1nodesource1 1001
                                       22.17.0-1nodesource1 1001
                                       22.16.0-1nodesource1 1001
                                       22.15.1-1nodesource1 1001
                                       22.15.0-1nodesource1 1001
                                       22.14.0-1nodesource1 1001
                                       22.13.1-1nodesource1 1001
                                       22.13.0-1nodesource1 1001
                                       22.12.0-1nodesource1 1001
                                       22.11.0-1nodesource1 1001
                                       22.10.0-1nodesource1 1001
                                       22.9.0-1nodesource1 1001
                                       22.8.0-1nodesource1 1001
                                       22.7.0-1nodesource1 1001
                                       22.6.0-1nodesource1 1001
                                       22.5.1-1nodesource1 1001
                                       22.5.0-1nodesource1 1001
                                       22.4.1-1nodesource1 1001
                                       22.4.0-1nodesource1 1001
                                       22.3.0-1nodesource1 1001
                                       22.2.0-1nodesource1 1001
                                       22.1.0-1nodesource1 1001
                                       22.0.0-1nodesource1 1001
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 357686)
                                  admin:          7.7.2
                                  javascript:     8.9.2
                                  Adapter State
                                  + system.adapter.cameras.0                : cameras               : iobroker                                 -  enabled, port: 8200, bind: 127.0.0.1
                                    system.adapter.mhi-wfrac.0              : mhi-wfrac             : iobroker                                 - disabled
                                  + system.adapter.smoothed.0               : smoothed              : iobroker                                 -  enabled
                                    system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
                                  + instance is alive
                                  Adapter    "admin"        : 7.7.19   , installed 7.7.2  [Updatable]
                                  Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                                  Adapter    "cameras"      : 2.1.2    , installed 2.1.2
                                  Adapter    "ebus"         : 3.6.7    , installed 3.6.7
                                  Adapter    "ical"         : 1.17.0   , installed 1.17.0
                                  Adapter    "iot"          : 5.0.7    , installed 4.2.2  [Updatable]
                                  Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
                                  Adapter    "shelly"       : 10.4.0   , installed 10.4.0
                                  Adapter    "smoothed"     : 1.5.0    , installed 1.5.0
                                  Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
                                  Objects and States
                                  Objects:        51337
                                  States:         43324
                                  Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                  Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       108413666  2653938/io.mqtt.1
                                  tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       108608097  2666781/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       108608096  2666781/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       108417058  2654144/io.sonoff.0
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       117372337  3232268/io.shelly.0
                                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       108413083  2653524/iobroker.js
                                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       108412122  2653524/iobroker.js
                                  tcp        0      0 127.0.0.1:45497         0.0.0.0:*               LISTEN      1001       117375598  2654256/io.yahka.0
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15552      1/init
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13658      492/sshd: /usr/sbin
                                  tcp        0      0 192.168.178.90:42001    0.0.0.0:*               LISTEN      1001       108421762  2654909/io.hm-rpc.1
                                  tcp        0      0 192.168.178.90:42010    0.0.0.0:*               LISTEN      1001       108445152  2656517/io.hm-rpc.0
                                  tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1001       116241594  3159803/io.cameras.
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          274        1/init
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13660      492/sshd: /usr/sbin
                                  tcp6       0      0 :::8088                 :::*                    LISTEN      1001       108417717  2654486/io.simple-a
                                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       108418849  2654470/io.simple-a
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       117434475  3236788/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       116241525  3159779/io.web.0
                                  tcp6       0      0 :::39077                :::*                    LISTEN      1001       108417283  2654256/io.yahka.0
                                  udp        0      0 0.0.0.0:42133           0.0.0.0:*                           1001       108412672  2653953/io.ph803w.0
                                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       108413630  2653908/io.mihome-v
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       108421293  2654652/io.esphome.
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       108416933  2654604/io.wled.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       108417288  2654256/io.yahka.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       108417287  2654256/io.yahka.0
                                  udp        0      0 192.168.178.90:5353     0.0.0.0:*                           1001       108415519  2654189/io.tr-064.0
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          539        391/dhclient
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13401      1/init
                                  udp6       0      0 :::111                  :::*                                0          15553      1/init
                                  2025-11-05 15:29:21.980  - error: modbus.0 (2654377) Client in error state.
                                  2025-11-05 15:50:22.740  - error: modbus.0 (2654377) Request timed out.
                                  2025-11-05 15:50:22.741  - error: modbus.0 (2654377) Client in error state.
                                  2025-11-05 15:58:06.385  - error: proxmox.0 (2654061) Problem with getStorageStatus. undefined
                                  2025-11-05 15:58:06.387  - error: proxmox.0 (2654061) Storage: local-SSD on  storage/pve/local-SSD not available
                                  2025-11-05 15:58:09.396  - error: proxmox.0 (2654061) Problem with getStorageStatus. undefined
                                  2025-11-05 15:58:09.397  - error: proxmox.0 (2654061) Storage: local-lvm on  storage/pve/local-lvm not available
                                  • S saeft_2003
                                    Script v.2025-08-09
                                    *** BASE SYSTEM ***
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    CPU threads: 8
                                                  NTP service: active
                                              RTC in local TZ: no
                                    patrick
                                    HOME=/home/patrick
                                    iobroker
                                    HOME=/home/iobroker
                                    Display-Manager:
                                    Desktop:
                                    Session:                tty
                                    *** MEMORY ***
                                    Swap:           1.0G          0B        1.0G
                                             6363 M used memory
                                             4493 M free memory
                                               34 M buffer memory
                                             3075 M swap cache
                                              974 M total swap
                                                0 M used swap
                                              974 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    3.6G    /var/
                                    2.8G    /var/log
                                    636M    /var/cache
                                    USB-Devices by-id:
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    HINT:
                                    tcp
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.9.4
                                    /usr/bin/npx            10.9.4
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.7.2
                                    javascript:     8.9.2
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        51337
                                    States:         43324
                                    Pending Updates: 0
                                    Debian GNU/Linux 12 (bookworm)
                                    Bring es auf Debian 13
                                    Im Log steht mit Sicherheit was. Und wenn es nur der Start ist. Bring die anderen Adapter auch auf Stand.
                                      saeft_2003
                                      Ich hab jetzt rausgefunden an was es liegt, war nicht direkt ein iobroker Problem. Musste nachdem update in Safari den cache löschen, dann lief es wieder…
