  4. Problem mit Admin Update 7.7.2
    5.4k
29 Beiträge 4 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • S saeft_2003
    ja klar mach ich, hab nur gedacht das wir evtl. gerade aneinander vorbei reden. Ich mache jetzt das node update dann melde ich mich.
    @Homoran
    Das log file hab ich leider nicht mehr...
    @saeft_2003 sagte in Problem mit Admin Update 7.7.2:
    Das liegt in
    /home/iobroker/iob_diag.log
      Das liegt in
      saeft_2003
      patrick@iobroker:~$ iob update
      Adapter    "admin"        : 7.7.2    , installed 7.6.17 [Updatable]
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
      Adapter    "countdown"    : 3.0.0    , installed 3.0.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "ebus"         : 3.6.3    , installed 3.6.3
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "homekit-controller": 0.5.11, installed 0.5.11
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.4.0    , installed 2.4.0
      Adapter    "mhi-wfrac"    : 2.1.7    , installed 2.1.7
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
      Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
      Adapter    "roborock"     : 0.6.18   , installed 0.6.18
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
      Adapter    "wled"         : 0.7.2    , installed 0.7.3
      Adapter    "worx"         : 3.2.7    , installed 3.2.7
      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
      Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
      patrick@iobroker:~$ iob upgrade
      This upgrade of "admin" will introduce the following changes:
      -> 7.7.2:
      Fixing change of the language in the admin
      -> 7.7.1:
      Fixing clearing of the filter on the object tab
      -> 7.7.0:
      Added the concept for single-side-on authentication (SSO)
      -> 7.6.20:
      Allowed using of * in the filter of objects
      Small GUI improvements
      -> 7.6.19:
      Improvements on JSONConfig component `state`
      Added `infoBox` JSONConfig component
      -> 7.6.18:
      Added OAuth2 authentication to JSONConfig components
      Would you like to upgrade admin from @7.6.17 to @7.7.2 now? [(y)es, (n)o]: y
      Update admin from @7.6.17 to @7.7.2
      host.iobroker Adapter "system.adapter.admin.0" is stopped.
      NPM version: 10.9.3
      Installing iobroker.admin@7.7.2... (System call)
      added 16 packages, and changed 9 packages in 6s
      251 packages are looking for funding
        run `npm fund` for details
      Updating objects from io-package.json for adapter "admin" with version "7.7.2"
      Update "system.adapter.admin.0"
      upload [171] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
      upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
      upload [90] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-C0FlO84Y.js custom/assets/index-C0FlO84Y.js application/javascript
      upload [80] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-CcDQHtwq.js custom/assets/index-CcDQHtwq.js application/javascript
      upload [70] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js custom/assets/index-DIVai5gZ.js application/javascript
      upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-G9F5mhbe.js custom/assets/index-G9F5mhbe.js application/javascript
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-eQxyhk2m.js custom/assets/index-eQxyhk2m.js application/javascript
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/jsx-runtime-DEOw6lrW.js custom/assets/jsx-runtime-DEOw6lrW.js application/javascript
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/virtualExposes-BufY-8i6.js custom/assets/virtualExposes-BufY-8i6.js application/javascript
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      host.iobroker Adapter "system.adapter.admin.0" is started
        saeft_2003
        @Homoran @Thomas-Braun
        Nach dem node-js update komme ich wieder auf admin mit 7.7.2 👍
        Lag das jetzt an node-js? Die war doch mit 20.x jetzt noch nicht so alt...
        • S saeft_2003
          Aber nicht mehr die Empfehlung...
          Und 20 läuft auch in wenigen Monaten aus.
            saeft_2003
            Ok Hauptsache es läuft wieder. Vielen Dank für eure Hilfe 👍
            • S saeft_2003
              @saeft_2003
              Die Installation künftig regelmäßiger auf Stand halten und den Empfehlungen folgen.
                @saeft_2003
                saeft_2003
                schrieb am zuletzt editiert von saeft_2003
                Da hast du natürlich recht, aber ich bin da eigentlich schon immer dran das System aktuell zu halten. Ich hatte mir auch schon den Thread von Apollon zu Node 22 durchgelesen gehabt vor ein paar Tagen.
                Die Empfehlung ist jetzt erstmal grad vier Wochen her und Apollon schreibt ja auch das keinen Grund zur Eile gibt da Node 20 stabil läuft. Deswegen wollte ich jetzt demnächst das Update machen, weil im Moment daheim grad viel los ist.
                Deswegen habe ich auch nicht gedacht, dass mein Problem mit dem admin zusammen hängen kann.
                • S saeft_2003
                  @saeft_2003
                  Dann die nächste Aufgabe für den Herbst:
                  *** LIFE CYCLE STATUS ***
                  Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                    @saeft_2003
                    saeft_2003
                    Ja hab ich schon auf dem Plan. Erstelle dann einfach eine neue VM und spiele das backup ein...
                      saeft_2003
                      So jetzt habe ich das Problem wieder. Nach dem update von admin 7.7.2 auf 7.7.19 komme ich nicht auf den admin. Es kommt einfach nichts...
                      Mit iob list instances sehe ich aber das der admin läuft. Mach ich ein downgrade 7.7.2 komme ich wieder drauf.
                      An was kann das liegen?
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                       Static hostname: iobroker
                             Icon name: computer-vm
                               Chassis: vm 🖴
                        Virtualization: kvm
                                Kernel: Linux 6.1.0-39-amd64
                          Architecture: x86-64
                       Hardware Vendor: QEMU
                        Hardware Model: Standard PC _i440FX + PIIX, 1996_
                      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                      OS is similar to:
                      model name      : Common KVM processor
                      Docker          : false
                      Virtualization  : kvm
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       19:03:58 up 52 days,  9:17,  4 users,  load average: 1.33, 0.77, 0.52
                      CPU threads: 8
                      *** TIME AND TIMEZONES ***
                                     Local time: Wed 2025-11-05 19:03:58 CET
                                 Universal time: Wed 2025-11-05 18:03:58 UTC
                                       RTC time: Wed 2025-11-05 18:03:58
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      patrick
                      HOME=/home/patrick
                      GROUPS=patrick adm dialout cdrom floppy sudo audio dip video plugdev users netdev iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server:         false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:             14G        6.7G        4.7G        2.0M        3.3G        7.6G
                      Swap:           1.0G          0B        1.0G
                      Total:           15G        6.7G        5.7G
                      Active iob-Instances:   51
                              13644 M total memory
                               6363 M used memory
                               1020 M active memory
                               7658 M inactive memory
                               4493 M free memory
                                 34 M buffer memory
                               3075 M swap cache
                                974 M total swap
                                  0 M used swap
                                974 M free swap
                      top - 19:03:58 up 52 days,  9:17,  4 users,  load average: 1.33, 0.77, 0.52
                      Tasks: 168 total,   1 running, 167 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :  13644.6 total,   4493.0 free,   6362.7 used,   3111.2 buff/cache
                      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7282.0 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      udev           devtmpfs  6.7G     0  6.7G   0% /dev
                      tmpfs          tmpfs     1.4G  1.9M  1.4G   1% /run
                      /dev/sda1      ext4       31G   15G   15G  51% /
                      tmpfs          tmpfs     6.7G     0  6.7G   0% /dev/shm
                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs          tmpfs     1.4G     0  1.4G   0% /run/user/1000
                      tmpfs          tmpfs     1.4G     0  1.4G   0% /run/user/0
                      [Sun Sep 14 10:46:19 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sun Sep 14 10:46:19 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                      Show mounted filesystems:
                      TARGET SOURCE    FSTYPE OPTIONS
                      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                      /var:
                      3.6G    /var/
                      2.8G    /var/log/journal/27edfd6da47743cab5e987a6643f0827
                      2.8G    /var/log
                      636M    /var/cache
                      Archived and active journals take up 2.7G in the file system.
                      /opt/iobroker/backups:
                      1.1G    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      989M    /opt/iobroker/iobroker-data/
                      597M    /opt/iobroker/iobroker-data/files
                      242M    /opt/iobroker/iobroker-data/backup-objects
                      115M    /opt/iobroker/iobroker-data/files/vis.0
                      114M    /opt/iobroker/iobroker-data/files/vis-2.0
                      75M     /opt/iobroker/iobroker-data/states.jsonl
                      71M     /opt/iobroker/iobroker-data/objects.jsonl
                      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                      19M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.b371dc6f.js.map
                      USB-Devices by-id:
                      /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
                      *** ZigBee Settings ***
                      HINT:
                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                      tcp
                      HINT:
                      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                      tcp
                      HINT:
                      Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                      tcp
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v22.21.0
                      /usr/bin/node           v22.21.0
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      /usr/bin/corepack       0.34.0
                      nodejs:
                        Installed: 22.21.0-1nodesource1
                        Candidate: 22.21.0-1nodesource1
                        Version table:
                       *** 22.21.0-1nodesource1 1001
                           22.20.0-1nodesource1 1001
                           22.19.0-1nodesource1 1001
                           22.18.0-1nodesource1 1001
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                           18.20.4+dfsg-1~deb12u1 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 357686)
                      Core adapters versions
                      js-controller:  7.0.7
                      admin:          7.7.2
                      javascript:     8.9.2
                      nodejs modules from github:     8
                      +-- iobroker.labcom@0.1.6 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#b03e1f4e04d4839b753872ba9c97b0a2a84255a8)
                      +-- iobroker.proxmox@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.proxmox.git#3998404a0bb41a2370f5804f4fc332dea916e8bc)
                      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                      +-- iobroker.vedirect@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.vedirect.git#043f003dc44aed8ee3d6f9a7b1f8617b95dd9cc1)
                      +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                      +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.web-speedy.git#79889767b80052eb5093509d55a7751d966e80ed)
                      +-- iobroker.woso_mitsu_aircon_rac@1.0.1 (git+ssh://git@github.com/wolkeSoftware/ioBroker.woso_mitsu_aircon_rac.git#c96849c7b4249f3b1519014ccb298679a4ecc2e9)
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        system.adapter.backitup.1               : backitup              : iobroker                                 - disabled
                      + system.adapter.cameras.0                : cameras               : iobroker                                 -  enabled, port: 8200, bind: 127.0.0.1
                      + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                        system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                      + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
                      + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
                        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                        system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
                        system.adapter.history.0                : history               : iobroker                                 - disabled
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        system.adapter.labcom.0                 : labcom                : iobroker                                 -  enabled
                      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                      + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                        system.adapter.mhi-wfrac.0              : mhi-wfrac             : iobroker                                 - disabled
                        system.adapter.mhi-wfrac.1              : mhi-wfrac             : iobroker                                 - disabled
                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                        system.adapter.mqtt.2                   : mqtt                  : iobroker                                 - disabled, port: 1884, bind: 0.0.0.0
                        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 - disabled
                      + system.adapter.ph803w.0                 : ph803w                : iobroker                                 -  enabled
                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                        system.adapter.ping.1                   : ping                  : iobroker                                 - disabled
                      + system.adapter.ping.2                   : ping                  : iobroker                                 -  enabled
                      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                        system.adapter.proxmox.1                : proxmox               : iobroker                                 - disabled, port: 8006
                      + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
                        system.adapter.reolink.1                : reolink               : iobroker                                 - disabled
                        system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                      + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
                        system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.simple-api.1             : simple-api            : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                      + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
                      + system.adapter.smoothed.0               : smoothed              : iobroker                                 -  enabled
                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.statistics.0             : statistics            : iobroker                                 - disabled
                      + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                        system.adapter.synology.1               : synology              : iobroker                                 - disabled, port: 5000
                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.3               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                        system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
                        system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
                      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                        system.adapter.vedirect.0               : vedirect              : iobroker                                 - disabled
                        system.adapter.vedirect.1               : vedirect              : iobroker                                 - disabled
                        system.adapter.vedirect.2               : vedirect              : iobroker                                 - disabled
                        system.adapter.vedirect.3               : vedirect              : iobroker                                 - disabled
                        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                      + system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, port: 5000
                        system.adapter.wiobrowser.1             : wiobrowser            : iobroker                                 - disabled, port: 5000
                      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                      + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                        system.adapter.woso_mitsu_aircon_rac.0  : woso_mitsu_aircon_rac : iobroker                                 - disabled
                        system.adapter.woso_mitsu_aircon_rac.1  : woso_mitsu_aircon_rac : iobroker                                 - disabled
                      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                        system.adapter.yahka.1                  : yahka                 : iobroker                                 - disabled
                      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.107:6638
                      + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.108:6638
                      + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.110:6638
                      + instance is alive
                      ioBroker-Repositories
                      │ (index) │ name               │ url                                                     │ auto upgrade │
                      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Adapter    "admin"        : 7.7.19   , installed 7.7.2  [Updatable]
                      Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                      Adapter    "cameras"      : 2.1.2    , installed 2.1.2
                      Adapter    "ebus"         : 3.6.7    , installed 3.6.7
                      Adapter    "ical"         : 1.17.0   , installed 1.17.0
                      Adapter    "iot"          : 5.0.7    , installed 4.2.2  [Updatable]
                      Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
                      Adapter    "shelly"       : 10.4.0   , installed 10.4.0
                      Adapter    "smoothed"     : 1.5.0    , installed 1.5.0
                      Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
                      Objects and States
                      Objects:        51337
                      States:         43324
                      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       108413666  2653938/io.mqtt.1
                      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       108608097  2666781/io.mqtt.0
                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       108608096  2666781/io.mqtt.0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       108417058  2654144/io.sonoff.0
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       117372337  3232268/io.shelly.0
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       108413083  2653524/iobroker.js
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       108412122  2653524/iobroker.js
                      tcp        0      0 127.0.0.1:45497         0.0.0.0:*               LISTEN      1001       117375598  2654256/io.yahka.0
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15552      1/init
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13658      492/sshd: /usr/sbin
                      tcp        0      0 192.168.178.90:42001    0.0.0.0:*               LISTEN      1001       108421762  2654909/io.hm-rpc.1
                      tcp        0      0 192.168.178.90:42010    0.0.0.0:*               LISTEN      1001       108445152  2656517/io.hm-rpc.0
                      tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1001       116241594  3159803/io.cameras.
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          274        1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          13660      492/sshd: /usr/sbin
                      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       108417717  2654486/io.simple-a
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       108418849  2654470/io.simple-a
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       117434475  3236788/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       116241525  3159779/io.web.0
                      tcp6       0      0 :::39077                :::*                    LISTEN      1001       108417283  2654256/io.yahka.0
                      udp        0      0 0.0.0.0:42133           0.0.0.0:*                           1001       108412672  2653953/io.ph803w.0
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       108413630  2653908/io.mihome-v
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       108421293  2654652/io.esphome.
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       108416933  2654604/io.wled.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       108417288  2654256/io.yahka.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       108417287  2654256/io.yahka.0
                      udp        0      0 192.168.178.90:5353     0.0.0.0:*                           1001       108415519  2654189/io.tr-064.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          539        391/dhclient
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13401      1/init
                      udp6       0      0 :::111                  :::*                                0          15553      1/init
                      2025-11-05 15:29:21.980  - error: modbus.0 (2654377) Client in error state.
                      2025-11-05 15:50:22.740  - error: modbus.0 (2654377) Request timed out.
                      2025-11-05 15:50:22.741  - error: modbus.0 (2654377) Client in error state.
                      2025-11-05 15:58:06.385  - error: proxmox.0 (2654061) Problem with getStorageStatus. undefined
                      2025-11-05 15:58:06.387  - error: proxmox.0 (2654061) Storage: local-SSD on  storage/pve/local-SSD not available
                      2025-11-05 15:58:09.396  - error: proxmox.0 (2654061) Problem with getStorageStatus. undefined
                      2025-11-05 15:58:09.397  - error: proxmox.0 (2654061) Storage: local-lvm on  storage/pve/local-lvm not available
                      • S saeft_2003
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                                 Chassis: vm 🖴
                          Virtualization: kvm
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 8
                                      NTP service: active
                                  RTC in local TZ: no
                        patrick
                        HOME=/home/patrick
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Swap:           1.0G          0B        1.0G
                                 6363 M used memory
                                 4493 M free memory
                                   34 M buffer memory
                                 3075 M swap cache
                                  974 M total swap
                                    0 M used swap
                                  974 M free swap
                        *** FILESYSTEM ***
                        /var:
                        3.6G    /var/
                        2.8G    /var/log
                        636M    /var/cache
                        USB-Devices by-id:
                        HINT:
                        tcp
                        HINT:
                        tcp
                        HINT:
                        tcp
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.4
                        /usr/bin/npx            10.9.4
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.7.2
                        javascript:     8.9.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        51337
                        States:         43324
                        Pending Updates: 0
                        Debian GNU/Linux 12 (bookworm)
                        Bring es auf Debian 13
                        Im Log steht mit Sicherheit was. Und wenn es nur der Start ist. Bring die anderen Adapter auch auf Stand.
                          saeft_2003
                          Ich hab jetzt rausgefunden an was es liegt, war nicht direkt ein iobroker Problem. Musste nachdem update in Safari den cache löschen, dann lief es wieder…
