  4. Problem mit Admin Update 7.7.2
    5.4k
29 Beiträge 4 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • S saeft_2003
    Alles klar mach ich morgen. Melde mich dann.
    @saeft_2003
    Mit deinem Proxmox scheint aber auch was zu klemmen, wenn ich mir die Meldungen so anschaue...
    2025-09-13 20:29:51.738  - error: proxmox.0 (1545511) Storage: local-SSD on  storage/pve/local-SSD not available
    2025-09-13 20:30:39.475  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:34:01.075  - error: proxmox.0 (1545511) Storage: PBS-Cloud on  storage/pve/PBS-Cloud not available
    2025-09-13 20:50:33.105  - error: proxmox.0 (1545511) Problem with getStorageStatus. undefined
    2025-09-13 20:50:33.105  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
    2025-09-13 20:50:36.116  - error: proxmox.0 (1545511) Problem with getStorageStatus. undefined
    2025-09-13 20:50:36.116  - error: proxmox.0 (1545511) Storage: PBS-Cloud on  storage/pve/PBS-Cloud not available
    2025-09-13 20:50:39.131  - error: proxmox.0 (1545511) Problem with getStorageStatus. undefined
    2025-09-13 20:50:39.131  - error: proxmox.0 (1545511) Storage: local-SSD on  storage/pve/local-SSD not available
    2025-09-13 20:51:36.950  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:52:52.058  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:54:02.843  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:54:49.730  - error: proxmox.0 (1545511) Storage: local-SSD on  storage/pve/local-SSD not available
    2025-09-13 20:56:23.234  - error: backitup.0 (2664074) Access token is expired. Please make an authorization again
    2025-09-13 20:57:16.318  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
    2025-09-13 20:59:34.473  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:59:44.475  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
    2025-09-13 21:00:41.119  - error: proxmox.0 (1545511) Storage: local-SSD on  storage/pve/local-SSD not available
    2025-09-13 21:03:18.064  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
    2025-09-13 21:05:42.952  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
      @saeft_2003
      saeft_2003
      Das sind Pseudofehler es läuft alles Fehlerfrei . Die kamen mit einem update vom proxmox Adapter.
      • S saeft_2003
        liv-in-skyL Offline
        liv-in-skyL Offline
        @saeft_2003
        ist bei mir auch so - aber nur im edge browser - in chrome funktioniert der admin
        • liv-in-skyL liv-in-sky
          @saeft_2003
          saeft_2003
          @liv-in-sky
          Ja wie? Dann wäre das doch ein Admin Problem. Ich nutze auf Mac und IPhone nur Safari. Jetzt im Moment funktioniert das ohne Probleme, dann sollte das nach dem update auf 7.7.2 auch noch.
            @saeft_2003
            Kiste erstmal updaten...
            iob stop
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
            Dann
            iob stop
            iob fix
            iob start
            Dann
            iob update
            iob upgrade all
            saeft_2003
            @thomas-braun sagte in Problem mit Admin Update 7.7.2:
            @saeft_2003
            iob stop
            sudo apt update
            sudo reboot
            Dann
            iob stop
            iob fix
            iob start
            Dann
            iob update
            iob upgrade all
            Hab alles gemacht. Geht nicht nach dem Admin update komme ich nicht mehr drauf obwohl der admin läuft.
            system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            Getestet mit drei Browser…
            • S saeft_2003
              @saeft_2003
              iob stop
              sudo apt update
              sudo reboot
              Dann
              iob stop
              iob fix
              iob start
              Dann
              iob update
              iob upgrade all
              @saeft_2003 sagte in Problem mit Admin Update 7.7.2:
              tut er nicht!
              dann müsste ein + davor sein
              • S saeft_2003
                @saeft_2003
                iob stop
                sudo apt update
                sudo reboot
                Dann
                iob stop
                iob fix
                iob start
                Dann
                iob update
                iob upgrade all
                @saeft_2003
                Dann zeig jetzt nochmal
                iob diag
                  saeft_2003
                  @homoran sagte in Problem mit Admin Update 7.7.2:
                  tut er nicht!
                  ah ok ich dachte enable heißt das er läuft.
                    @saeft_2003
                    iob diag
                    saeft_2003
                    @saeft_2003
                    iob diag
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                     Static hostname: iobroker
                           Icon name: computer-vm
                             Chassis: vm 🖴
                      Virtualization: kvm
                              Kernel: Linux 6.1.0-39-amd64
                        Architecture: x86-64
                     Hardware Vendor: QEMU
                      Hardware Model: Standard PC _i440FX + PIIX, 1996_
                    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                    OS is similar to:
                    model name      : Common KVM processor
                    Docker          : false
                    Virtualization  : kvm
                    Kernel          : x86_64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     10:02:23 up 43 min,  2 users,  load average: 1.00, 1.07, 0.91
                    CPU threads: 8
                    *** LIFE CYCLE STATUS ***
                    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                    *** TIME AND TIMEZONES ***
                                   Local time: Sun 2025-09-14 10:02:23 CEST
                               Universal time: Sun 2025-09-14 08:02:23 UTC
                                     RTC time: Sun 2025-09-14 08:02:23
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    patrick
                    HOME=/home/patrick
                    GROUPS=patrick adm dialout cdrom floppy sudo audio dip video plugdev users netdev iobroker
                    iobroker
                    HOME=/home/iobroker
                    GROUPS=iobroker tty dialout audio video plugdev
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         false
                    Unit display-manager.service could not be found.
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:             12G        4.8G        6.9G        548K        758M        7.4G
                    Swap:           1.0G          0B        1.0G
                    Total:           13G        4.8G        7.9G
                    Active iob-Instances:   51
                            11676 M total memory
                             4607 M used memory
                              235 M active memory
                             4552 M inactive memory
                             6601 M free memory
                               64 M buffer memory
                              659 M swap cache
                              974 M total swap
                                0 M used swap
                              974 M free swap
                    top - 10:02:24 up 43 min,  2 users,  load average: 1.00, 1.07, 0.91
                    Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :  11676.7 total,   6600.7 free,   4607.9 used,    724.1 buff/cache
                    MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7068.7 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    udev           devtmpfs  5.7G     0  5.7G   0% /dev
                    tmpfs          tmpfs     1.2G  536K  1.2G   1% /run
                    /dev/sda1      ext4       31G   14G   16G  48% /
                    tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
                    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
                    [Sun Sep 14 09:19:06 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                    [Sun Sep 14 09:19:06 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                    Show mounted filesystems:
                    TARGET SOURCE    FSTYPE OPTIONS
                    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                    /var:
                    3.5G    /var/
                    2.7G    /var/log/journal/27edfd6da47743cab5e987a6643f0827
                    2.7G    /var/log
                    600M    /var/cache
                    Archived and active journals take up 2.6G in the file system.
                    /opt/iobroker/backups:
                    1.1G    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    994M    /opt/iobroker/iobroker-data/
                    612M    /opt/iobroker/iobroker-data/files
                    236M    /opt/iobroker/iobroker-data/backup-objects
                    115M    /opt/iobroker/iobroker-data/files/vis.0
                    114M    /opt/iobroker/iobroker-data/files/vis-2.0
                    81M     /opt/iobroker/iobroker-data/objects.jsonl
                    61M     /opt/iobroker/iobroker-data/states.jsonl
                    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
                    *** ZigBee Settings ***
                    HINT:
                    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                    tcp
                    HINT:
                    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                    tcp
                    HINT:
                    Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                    tcp
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v20.19.5
                    /usr/bin/node           v20.19.5
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    /usr/bin/corepack       0.33.0
                    nodejs:
                      Installed: 20.19.5-1nodesource1
                      Candidate: 20.19.5-1nodesource1
                      Version table:
                     *** 20.19.5-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                         20.19.4-1nodesource1 1001
                         20.19.3-1nodesource1 1001
                         20.19.2-1nodesource1 1001
                         20.19.1-1nodesource1 1001
                         20.19.0-1nodesource1 1001
                         20.18.3-1nodesource1 1001
                         20.18.2-1nodesource1 1001
                         20.18.1-1nodesource1 1001
                         20.18.0-1nodesource1 1001
                         20.17.0-1nodesource1 1001
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         18.20.4+dfsg-1~deb12u1 500
                            500 http://deb.debian.org/debian bookworm/main amd64 Packages
                            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 2600)
                    Core adapters versions
                    js-controller:  7.0.7
                    admin:          7.6.17
                    javascript:     8.9.2
                    nodejs modules from github:     8
                    +-- iobroker.labcom@0.1.6 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#b03e1f4e04d4839b753872ba9c97b0a2a84255a8)
                    +-- iobroker.proxmox@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.proxmox.git#3998404a0bb41a2370f5804f4fc332dea916e8bc)
                    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                    +-- iobroker.vedirect@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.vedirect.git#043f003dc44aed8ee3d6f9a7b1f8617b95dd9cc1)
                    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                    +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.web-speedy.git#79889767b80052eb5093509d55a7751d966e80ed)
                    +-- iobroker.woso_mitsu_aircon_rac@1.0.1 (git+ssh://git@github.com/wolkeSoftware/ioBroker.woso_mitsu_aircon_rac.git#c96849c7b4249f3b1519014ccb298679a4ecc2e9)
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      system.adapter.backitup.1               : backitup              : iobroker                                 - disabled
                    + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                      system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                    + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
                    + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
                      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                      system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
                      system.adapter.history.0                : history               : iobroker                                 - disabled
                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      system.adapter.labcom.0                 : labcom                : iobroker                                 -  enabled
                    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                    + system.adapter.mhi-wfrac.0              : mhi-wfrac             : iobroker                                 -  enabled
                      system.adapter.mhi-wfrac.1              : mhi-wfrac             : iobroker                                 - disabled
                    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                      system.adapter.mqtt.2                   : mqtt                  : iobroker                                 - disabled, port: 1884, bind: 0.0.0.0
                      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 - disabled
                    + system.adapter.ph803w.0                 : ph803w                : iobroker                                 -  enabled
                    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                      system.adapter.ping.1                   : ping                  : iobroker                                 - disabled
                    + system.adapter.ping.2                   : ping                  : iobroker                                 -  enabled
                    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                      system.adapter.proxmox.1                : proxmox               : iobroker                                 - disabled, port: 8006
                    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
                      system.adapter.reolink.1                : reolink               : iobroker                                 - disabled
                      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                    + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
                      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    + system.adapter.simple-api.1             : simple-api            : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                    + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.statistics.0             : statistics            : iobroker                                 - disabled
                    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                      system.adapter.synology.1               : synology              : iobroker                                 - disabled, port: 5000
                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.telegram.3               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                      system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                      system.adapter.vedirect.0               : vedirect              : iobroker                                 - disabled
                      system.adapter.vedirect.1               : vedirect              : iobroker                                 - disabled
                      system.adapter.vedirect.2               : vedirect              : iobroker                                 - disabled
                      system.adapter.vedirect.3               : vedirect              : iobroker                                 - disabled
                      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                    + system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, port: 5000
                      system.adapter.wiobrowser.1             : wiobrowser            : iobroker                                 - disabled, port: 5000
                    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                      system.adapter.woso_mitsu_aircon_rac.0  : woso_mitsu_aircon_rac : iobroker                                 - disabled
                      system.adapter.woso_mitsu_aircon_rac.1  : woso_mitsu_aircon_rac : iobroker                                 - disabled
                    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                      system.adapter.yahka.1                  : yahka                 : iobroker                                 - disabled
                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.107:6638
                    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.108:6638
                    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.110:6638
                    + instance is alive
                    ioBroker-Repositories
                    │ (index) │ name               │ url                                                     │ auto upgrade │
                    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                    Upgrade policy: none
                    Installed ioBroker-Adapters
                    Adapter    "admin"        : 7.7.2    , installed 7.6.17 [Updatable]
                    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
                    Adapter    "countdown"    : 3.0.0    , installed 3.0.0
                    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                    Adapter    "ebus"         : 3.6.3    , installed 3.6.3
                    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
                    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
                    Adapter    "ical"         : 1.16.2   , installed 1.16.2
                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                    Adapter    "iot"          : 3.3.0    , installed 3.3.0
                    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                    Controller "js-controller": 7.0.7    , installed 7.0.7
                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                    Adapter    "mhi-wfrac"    : 2.1.7    , installed 2.1.7
                    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                    Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
                    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
                    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
                    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
                    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                    Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
                    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                    Adapter    "synology"     : 3.1.0    , installed 3.1.0
                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                    Adapter    "web"          : 7.0.8    , installed 7.0.8
                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                    Adapter    "wled"         : 0.7.2    , installed 0.7.3
                    Adapter    "worx"         : 3.2.7    , installed 3.2.7
                    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                    Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
                    Objects and States
                    Objects:        49806
                    States:         42339
                    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       20424      966/io.mqtt.0
                    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       20423      966/io.mqtt.0
                    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20449      981/io.mqtt.1
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18169      1202/io.sonoff.0
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18089      1148/io.shelly.0
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15540      491/sshd: /usr/sbin
                    tcp        0      0 192.168.178.90:42001    0.0.0.0:*               LISTEN      1001       17839      891/io.hm-rpc.1
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13972      1/init
                    tcp        0      0 192.168.178.90:42010    0.0.0.0:*               LISTEN      1001       16074      874/io.hm-rpc.0
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15559      470/iobroker.js-con
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15564      470/iobroker.js-con
                    tcp        0      0 127.0.0.1:37051         0.0.0.0:*               LISTEN      1001       23591      1338/io.yahka.0
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23852      1546/io.simple-api.
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22507      1642/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15359      514/io.admin.0
                    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       24637      1570/io.simple-api.
                    tcp6       0      0 :::39905                :::*                    LISTEN      1001       18384      1338/io.yahka.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15551      491/sshd: /usr/sbin
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          13179      1/init
                    udp        0      0 0.0.0.0:46888           0.0.0.0:*                           1001       20461      997/io.ph803w.0
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21026      1275/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21027      1275/io.tuya.0
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15450      397/dhclient
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14564      1/init
                    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17911      951/io.mihome-vacuu
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25056      1745/io.esphome.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23175      1679/io.wled.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18389      1338/io.yahka.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18388      1338/io.yahka.0
                    udp        0      0 192.168.178.90:5353     0.0.0.0:*                           1001       18235      1251/io.tr-064.0
                    udp6       0      0 :::111                  :::*                                0          13973      1/init
                    • S saeft_2003
                      @saeft_2003
                      iob diag
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                               Chassis: vm 🖴
                        Virtualization: kvm
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                      CPU threads: 8
                                    NTP service: active
                                RTC in local TZ: no
                      patrick
                      HOME=/home/patrick
                      iobroker
                      HOME=/home/iobroker
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Swap:           1.0G          0B        1.0G
                               4607 M used memory
                                235 M active memory
                               6601 M free memory
                                 64 M buffer memory
                                659 M swap cache
                                974 M total swap
                                  0 M used swap
                                974 M free swap
                      *** FILESYSTEM ***
                      /var:
                      3.5G    /var/
                      2.7G    /var/log
                      600M    /var/cache
                      USB-Devices by-id:
                      HINT:
                      tcp
                      HINT:
                      tcp
                      HINT:
                      tcp
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.6.17
                      javascript:     8.9.2
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        49806
                      States:         42339
                      Pending Updates: 0
                      Jetzt läuft der admin:
                      Adapter State
                      Bring jetzt nodejs auf Version 22:
                      iob nodejs-update
                      Und danach die Ausgabe von
                      iob update
                      iob upgrade
                      • S saeft_2003
                        tut er nicht!
                        nein!
                        enable heisst, dass du die Instanz aktiviert und nicht pausiert hast
                        Log File - Last 25 Lines
                        wären jetzt sehr interessant gewesen
                          Adapter State
                          iob nodejs-update
                          iob update
                          iob upgrade
                          saeft_2003
                          admin läuft jetzt nur weil ich ich wieder zurück bin auf 7.6.17. Trotzdem weiter machen mit dem node update?
                          • S saeft_2003
                            Kannst du dann bitte tun was wir sagen? Danke...
                              saeft_2003
                              ja klar mach ich, hab nur gedacht das wir evtl. gerade aneinander vorbei reden. Ich mache jetzt das node update dann melde ich mich.
                              @Homoran
                              Das log file hab ich leider nicht mehr...
                              • S saeft_2003
                                @Homoran
                                Das liegt in
                                /home/iobroker/iob_diag.log
                                  Das liegt in
                                  saeft_2003
                                  patrick@iobroker:~$ iob update
                                  patrick@iobroker:~$ iob upgrade
                                  This upgrade of "admin" will introduce the following changes:
                                  -> 7.7.2:
                                  Fixing change of the language in the admin
                                  -> 7.7.1:
                                  Fixing clearing of the filter on the object tab
                                  -> 7.7.0:
                                  Added the concept for single-side-on authentication (SSO)
                                  -> 7.6.20:
                                  Allowed using of * in the filter of objects
                                  Small GUI improvements
                                  -> 7.6.19:
                                  Improvements on JSONConfig component `state`
                                  Added `infoBox` JSONConfig component
                                  -> 7.6.18:
                                  Added OAuth2 authentication to JSONConfig components
                                  Would you like to upgrade admin from @7.6.17 to @7.7.2 now? [(y)es, (n)o]: y
                                  Update admin from @7.6.17 to @7.7.2
                                  host.iobroker Adapter "system.adapter.admin.0" is stopped.
                                  NPM version: 10.9.3
                                  Installing iobroker.admin@7.7.2... (System call)
                                  added 16 packages, and changed 9 packages in 6s
                                  251 packages are looking for funding
                                    run `npm fund` for details
                                  Updating objects from io-package.json for adapter "admin" with version "7.7.2"
                                  Update "system.adapter.admin.0"
                                  upload [171] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                  upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
                                  upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
                                  upload [90] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-C0FlO84Y.js custom/assets/index-C0FlO84Y.js application/javascript
                                  upload [80] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-CcDQHtwq.js custom/assets/index-CcDQHtwq.js application/javascript
                                  upload [70] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js custom/assets/index-DIVai5gZ.js application/javascript
                                  upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-G9F5mhbe.js custom/assets/index-G9F5mhbe.js application/javascript
                                  upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-eQxyhk2m.js custom/assets/index-eQxyhk2m.js application/javascript
                                  upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/jsx-runtime-DEOw6lrW.js custom/assets/jsx-runtime-DEOw6lrW.js application/javascript
                                  upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/virtualExposes-BufY-8i6.js custom/assets/virtualExposes-BufY-8i6.js application/javascript
                                  upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
                                  upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                                  upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                                  upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
                                  upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
                                  upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                                  upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                                  upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                  upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                  upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json
                                  upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json
                                  upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json
                                  upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json
                                  upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json
                                  upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json
                                  upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json
                                  upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json
                                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json
                                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json
                                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                  host.iobroker Adapter "system.adapter.admin.0" is started
                                    saeft_2003
                                    @Homoran @Thomas-Braun
                                    Nach dem node-js update komme ich wieder auf admin mit 7.7.2 👍
                                    Lag das jetzt an node-js? Die war doch mit 20.x jetzt noch nicht so alt...
                                    • S saeft_2003
                                      Aber nicht mehr die Empfehlung...
                                      Und 20 läuft auch in wenigen Monaten aus.
                                        saeft_2003
                                        Ok Hauptsache es läuft wieder. Vielen Dank für eure Hilfe 👍
                                        • S saeft_2003
                                          @saeft_2003
                                          Die Installation künftig regelmäßiger auf Stand halten und den Empfehlungen folgen.
