  4. Problem mit Admin Update 7.7.2
    5.4k
29 Beiträge 4 Kommentatoren 2.7k Aufrufe 4 Beobachtet
    saeft_2003
    • Adaptername: admin
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 7.6.17
    • js-controller Version: 7.0.7
    • Admin Version: 7.6.17
    • Hardwaresystem: NUC
    • Arbeitsspeicher: 12GB
    • Festplattenart: SSD
    • Betriebssystem: debian
    • Nodejs-Version: 20.18.3
    • NPM-Version: 10.8.2
    • Installationsart: Skript oder Manuell ?
    • Image, Docker genutzt: Ja - Nein
    • Ort, Name der Imagedatei: ...
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-31-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     21:04:57 up 172 days, 25 min,  3 users,  load average: 0.37, 0.39, 0.60
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-09-13 21:04:57 CEST
               Universal time: Sat 2025-09-13 19:04:57 UTC
                     RTC time: Sat 2025-09-13 19:04:57
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    patrick
    HOME=/home/patrick
    GROUPS=patrick adm dialout cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             12G        6.5G        1.6G        4.8M        4.5G        5.8G
    Swap:           1.0G        1.3M        1.0G
    Total:           13G        6.5G        2.6G
    Active iob-Instances:   51
            11676 M total memory
             6187 M used memory
             1273 M active memory
             8358 M inactive memory
             1497 M free memory
              183 M buffer memory
             4126 M swap cache
              974 M total swap
                1 M used swap
              973 M free swap
    top - 21:04:57 up 172 days, 25 min,  3 users,  load average: 0.37, 0.39, 0.60
    Tasks: 165 total,   1 running, 164 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  11676.7 total,   1496.9 free,   6187.9 used,   4309.4 buff/cache
    MiB Swap:    975.0 total,    973.7 free,      1.3 used.   5488.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  5.7G     0  5.7G   0% /dev
    tmpfs          tmpfs     1.2G  5.0M  1.2G   1% /run
    /dev/sda1      ext4       31G   14G   15G  49% /
    tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/0
    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
    [Tue Mar 25 19:39:16 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Mar 25 19:39:16 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    3.5G    /var/
    2.7G    /var/log/journal/27edfd6da47743cab5e987a6643f0827
    2.7G    /var/log
    600M    /var/cache
    Archived and active journals take up 2.6G in the file system.
    /opt/iobroker/backups:
    1.1G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    965M    /opt/iobroker/iobroker-data/
    612M    /opt/iobroker/iobroker-data/files
    236M    /opt/iobroker/iobroker-data/backup-objects
    115M    /opt/iobroker/iobroker-data/files/vis.0
    114M    /opt/iobroker/iobroker-data/files/vis-2.0
    69M     /opt/iobroker/iobroker-data/objects.jsonl
    43M     /opt/iobroker/iobroker-data/states.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.5
    /usr/bin/node           v20.19.5
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 20.19.5-1nodesource1
      Candidate: 20.19.5-1nodesource1
      Version table:
     *** 20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 694362)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     8
    +-- iobroker.labcom@0.1.6 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#b03e1f4e04d4839b753872ba9c97b0a2a84255a8)
    +-- iobroker.proxmox@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.proxmox.git#3998404a0bb41a2370f5804f4fc332dea916e8bc)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.vedirect@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.vedirect.git#043f003dc44aed8ee3d6f9a7b1f8617b95dd9cc1)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.web-speedy.git#79889767b80052eb5093509d55a7751d966e80ed)
    +-- iobroker.woso_mitsu_aircon_rac@1.0.1 (git+ssh://git@github.com/wolkeSoftware/ioBroker.woso_mitsu_aircon_rac.git#c96849c7b4249f3b1519014ccb298679a4ecc2e9)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.backitup.1               : backitup              : iobroker                                 - disabled
    + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
    + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
      system.adapter.history.0                : history               : iobroker                                 - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.labcom.0                 : labcom                : iobroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mhi-wfrac.0              : mhi-wfrac             : iobroker                                 -  enabled
      system.adapter.mhi-wfrac.1              : mhi-wfrac             : iobroker                                 - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.mqtt.2                   : mqtt                  : iobroker                                 - disabled, port: 1884, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 - disabled
    + system.adapter.ph803w.0                 : ph803w                : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      system.adapter.ping.1                   : ping                  : iobroker                                 - disabled
    + system.adapter.ping.2                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.proxmox.1                : proxmox               : iobroker                                 - disabled, port: 8006
    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
      system.adapter.reolink.1                : reolink               : iobroker                                 - disabled
      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
    + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.simple-api.1             : simple-api            : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.statistics.0             : statistics            : iobroker                                 - disabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
      system.adapter.synology.1               : synology              : iobroker                                 - disabled, port: 5000
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.3               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
      system.adapter.vedirect.0               : vedirect              : iobroker                                 - disabled
      system.adapter.vedirect.1               : vedirect              : iobroker                                 - disabled
      system.adapter.vedirect.2               : vedirect              : iobroker                                 - disabled
      system.adapter.vedirect.3               : vedirect              : iobroker                                 - disabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
    + system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, port: 5000
      system.adapter.wiobrowser.1             : wiobrowser            : iobroker                                 - disabled, port: 5000
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
      system.adapter.woso_mitsu_aircon_rac.0  : woso_mitsu_aircon_rac : iobroker                                 - disabled
      system.adapter.woso_mitsu_aircon_rac.1  : woso_mitsu_aircon_rac : iobroker                                 - disabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      system.adapter.yahka.1                  : yahka                 : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.107:6638
    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.108:6638
    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.110:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.2    , installed 7.6.17 [Updatable]
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
    Adapter    "countdown"    : 3.0.0    , installed 3.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "ebus"         : 3.6.3    , installed 3.6.3
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "mhi-wfrac"    : 2.1.7    , installed 2.1.7
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wled"         : 0.7.2    , installed 0.7.3
    Adapter    "worx"         : 3.2.7    , installed 3.2.7
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
    Objects and States
    Objects:        49766
    States:         42315
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 71
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       410818399  1881059/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       406176787  1545540/io.shelly.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       406173480  1545379/io.mqtt.1
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       422614465  2645891/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       422614464  2645891/io.mqtt.0
    tcp        0      0 127.0.0.1:33601         0.0.0.0:*               LISTEN      1001       410807282  1545741/io.yahka.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          406234400  1572448/sshd: /usr/
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13385      1/systemd
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       406172872  1544876/iobroker.js
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       406172148  1544876/iobroker.js
    tcp        0      0 192.168.178.90:42001    0.0.0.0:*               LISTEN      1001       406175816  1545289/io.hm-rpc.1
    tcp        0      0 192.168.178.90:42010    0.0.0.0:*               LISTEN      1001       406175797  1545266/io.hm-rpc.0
    tcp        0      0 127.0.0.1:40237         0.0.0.0:*               LISTEN      1001       424266084  1545741/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          406234402  1572448/sshd: /usr/
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13386      1/systemd
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       406180100  1546003/io.simple-a
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       406173772  1544895/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       406179365  1546073/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       406180080  1545975/io.simple-a
    tcp6       0      0 :::37273                :::*                    LISTEN      1001       406176652  1545741/io.yahka.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       406175315  1545349/io.mihome-v
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       406182091  1546210/io.esphome.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       406178719  1546112/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       406176658  1545741/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       406176657  1545741/io.yahka.0
    udp        0      0 192.168.178.90:5353     0.0.0.0:*                           1001       406176424  1545645/io.tr-064.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       406176442  1545673/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       406176443  1545673/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13700      358/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14875      1/systemd
    udp        0      0 0.0.0.0:58930           0.0.0.0:*                           1001       406175969  1545413/io.ph803w.0
    udp6       0      0 :::111                  :::*                                0          12136      1/systemd
    2025-09-13 20:29:51.738  - error: proxmox.0 (1545511) Storage: local-SSD on  storage/pve/local-SSD not available
    2025-09-13 20:30:39.475  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:34:01.075  - error: proxmox.0 (1545511) Storage: PBS-Cloud on  storage/pve/PBS-Cloud not available
    2025-09-13 20:50:33.105  - error: proxmox.0 (1545511) Problem with getStorageStatus. undefined
    2025-09-13 20:50:33.105  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
    2025-09-13 20:50:36.116  - error: proxmox.0 (1545511) Problem with getStorageStatus. undefined
    2025-09-13 20:50:36.116  - error: proxmox.0 (1545511) Storage: PBS-Cloud on  storage/pve/PBS-Cloud not available
    2025-09-13 20:50:39.131  - error: proxmox.0 (1545511) Problem with getStorageStatus. undefined
    2025-09-13 20:50:39.131  - error: proxmox.0 (1545511) Storage: local-SSD on  storage/pve/local-SSD not available
    2025-09-13 20:51:36.950  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:52:52.058  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:54:02.843  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:54:49.730  - error: proxmox.0 (1545511) Storage: local-SSD on  storage/pve/local-SSD not available
    2025-09-13 20:56:23.234  - error: backitup.0 (2664074) Access token is expired. Please make an authorization again
    2025-09-13 20:57:16.318  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
    2025-09-13 20:59:34.473  - error: proxmox.0 (1545511) Storage: local on  storage/pve/local not available
    2025-09-13 20:59:44.475  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
    2025-09-13 21:00:41.119  - error: proxmox.0 (1545511) Storage: local-SSD on  storage/pve/local-SSD not available
    2025-09-13 21:03:18.064  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
    2025-09-13 21:05:42.952  - error: proxmox.0 (1545511) Storage: DS716 on  storage/pve/DS716 not available
    Bei mir funktioniert das admin update auf 7.7.2 nicht. Wenn ich das update starte läuft erst alles ganz normal, es kommt auch noch die Meldung dass das update erfolgreich war. Wenn ich dann auf Seite neu laden klicke kommt nur noch eine weiße Seite (keine Fehlermeldung). Getestet auf verschiedenen Endgeräten.
    Mit list instance sehe ich das der admin läuft, auch ein reboot brachte keine Änderung. Ich bin dann mit einem snapshot zurück und läuft wieder... Wisst ihr wo das Problem liegen könnte?
    • S saeft_2003
      Script v.2025-08-09
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      patrick
      HOME=/home/patrick
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               6187 M used memory
               1497 M free memory
                183 M buffer memory
               4126 M swap cache
                974 M total swap
                  1 M used swap
                973 M free swap
      *** FILESYSTEM ***
      /var:
      3.5G    /var/
      2.7G    /var/log
      600M    /var/cache
      USB-Devices by-id:
      HINT:
      tcp
      HINT:
      tcp
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        49766
      States:         42315
      Pending Updates: 71
      @saeft_2003
      Kiste erstmal updaten...
      iob stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      Dann
      iob stop
      iob fix
      iob start
      Dann
      iob update
      iob upgrade all
      S 2 Antworten Letzte Antwort
        @saeft_2003
        iob stop
        sudo apt update
        sudo reboot
        Dann
        iob stop
        iob fix
        iob start
        Dann
        iob update
        iob upgrade all
        saeft_2003
        Alles klar mach ich morgen. Melde mich dann.
        • S saeft_2003
          @saeft_2003
          Mit deinem Proxmox scheint aber auch was zu klemmen, wenn ich mir die Meldungen so anschaue...
            @saeft_2003
            saeft_2003
            Das sind Pseudofehler es läuft alles Fehlerfrei . Die kamen mit einem update vom proxmox Adapter.
            • S saeft_2003
              liv-in-skyL Offline
              liv-in-skyL Offline
              @saeft_2003
              ist bei mir auch so - aber nur im edge browser - in chrome funktioniert der admin
              • liv-in-skyL liv-in-sky
                @saeft_2003
                saeft_2003
                @liv-in-sky
                Ja wie? Dann wäre das doch ein Admin Problem. Ich nutze auf Mac und IPhone nur Safari. Jetzt im Moment funktioniert das ohne Probleme, dann sollte das nach dem update auf 7.7.2 auch noch.
                  @saeft_2003
                  iob stop
                  sudo apt update
                  sudo reboot
                  Dann
                  iob stop
                  iob fix
                  iob start
                  Dann
                  iob update
                  iob upgrade all
                  saeft_2003
                  @thomas-braun sagte in Problem mit Admin Update 7.7.2:
                  @saeft_2003
                  iob stop
                  sudo apt update
                  sudo reboot
                  Dann
                  iob stop
                  iob fix
                  iob start
                  Dann
                  iob update
                  iob upgrade all
                  Hab alles gemacht. Geht nicht nach dem Admin update komme ich nicht mehr drauf obwohl der admin läuft.
                  Getestet mit drei Browser…
                  • S saeft_2003
                    @saeft_2003
                    iob stop
                    sudo apt update
                    sudo reboot
                    Dann
                    iob stop
                    iob fix
                    iob start
                    Dann
                    iob update
                    iob upgrade all
                    @saeft_2003 sagte in Problem mit Admin Update 7.7.2:
                    tut er nicht!
                    dann müsste ein + davor sein
                    • S saeft_2003
                      @saeft_2003
                      iob stop
                      sudo apt update
                      sudo reboot
                      Dann
                      iob stop
                      iob fix
                      iob start
                      Dann
                      iob update
                      iob upgrade all
                      @saeft_2003
                      Dann zeig jetzt nochmal
                      iob diag
                        saeft_2003
                        @homoran sagte in Problem mit Admin Update 7.7.2:
                        tut er nicht!
                        ah ok ich dachte enable heißt das er läuft.
                          @saeft_2003
                          iob diag
                          saeft_2003
                          @saeft_2003
                          iob diag
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                                   Chassis: vm 🖴
                            Virtualization: kvm
                                    Kernel: Linux 6.1.0-39-amd64
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           10:02:23 up 43 min,  2 users,  load average: 1.00, 1.07, 0.91
                          CPU threads: 8
                          Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                                         Local time: Sun 2025-09-14 10:02:23 CEST
                                     Universal time: Sun 2025-09-14 08:02:23 UTC
                                           RTC time: Sun 2025-09-14 08:02:23
                                        NTP service: active
                                    RTC in local TZ: no
                          patrick
                          HOME=/home/patrick
                          iobroker
                          HOME=/home/iobroker
                          GROUPS=iobroker tty dialout audio video plugdev
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Mem:             12G        4.8G        6.9G        548K        758M        7.4G
                          Swap:           1.0G          0B        1.0G
                          Total:           13G        4.8G        7.9G
                                   4607 M used memory
                                    235 M active memory
                                   4552 M inactive memory
                                   6601 M free memory
                                     64 M buffer memory
                                    659 M swap cache
                                    974 M total swap
                                      0 M used swap
                                    974 M free swap
                          top - 10:02:24 up 43 min,  2 users,  load average: 1.00, 1.07, 0.91
                          Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  11676.7 total,   6600.7 free,   4607.9 used,    724.1 buff/cache
                          MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7068.7 avail Mem
                          *** FILESYSTEM ***
                          tmpfs          tmpfs     1.2G  536K  1.2G   1% /run
                          /dev/sda1      ext4       31G   14G   16G  48% /
                          [Sun Sep 14 09:19:06 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sun Sep 14 09:19:06 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                          /var:
                          3.5G    /var/
                          2.7G    /var/log
                          600M    /var/cache
                          994M    /opt/iobroker/iobroker-data/
                          81M     /opt/iobroker/iobroker-data/objects.jsonl
                          61M     /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          HINT:
                          tcp
                          HINT:
                          tcp
                          HINT:
                          tcp
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 2600)
                          admin:          7.6.17
                          javascript:     8.9.2
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        49806
                          States:         42339
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       20424      966/io.mqtt.0
                          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       20423      966/io.mqtt.0
                          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20449      981/io.mqtt.1
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18169      1202/io.sonoff.0
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18089      1148/io.shelly.0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15540      491/sshd: /usr/sbin
                          tcp        0      0 192.168.178.90:42001    0.0.0.0:*               LISTEN      1001       17839      891/io.hm-rpc.1
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13972      1/init
                          tcp        0      0 192.168.178.90:42010    0.0.0.0:*               LISTEN      1001       16074      874/io.hm-rpc.0
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15559      470/iobroker.js-con
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15564      470/iobroker.js-con
                          tcp        0      0 127.0.0.1:37051         0.0.0.0:*               LISTEN      1001       23591      1338/io.yahka.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23852      1546/io.simple-api.
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22507      1642/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15359      514/io.admin.0
                          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       24637      1570/io.simple-api.
                          tcp6       0      0 :::39905                :::*                    LISTEN      1001       18384      1338/io.yahka.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          15551      491/sshd: /usr/sbin
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          13179      1/init
                          udp        0      0 0.0.0.0:46888           0.0.0.0:*                           1001       20461      997/io.ph803w.0
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21026      1275/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21027      1275/io.tuya.0
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15450      397/dhclient
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14564      1/init
                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17911      951/io.mihome-vacuu
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25056      1745/io.esphome.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23175      1679/io.wled.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18389      1338/io.yahka.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18388      1338/io.yahka.0
                          udp        0      0 192.168.178.90:5353     0.0.0.0:*                           1001       18235      1251/io.tr-064.0
                          udp6       0      0 :::111                  :::*                                0          13973      1/init
                          • S saeft_2003
                            @saeft_2003
                            iob diag
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 8
                                          NTP service: active
                                      RTC in local TZ: no
                            patrick
                            HOME=/home/patrick
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           1.0G          0B        1.0G
                                     4607 M used memory
                                      235 M active memory
                                     6601 M free memory
                                       64 M buffer memory
                                      659 M swap cache
                                      974 M total swap
                                        0 M used swap
                                      974 M free swap
                            *** FILESYSTEM ***
                            /var:
                            3.5G    /var/
                            2.7G    /var/log
                            600M    /var/cache
                            USB-Devices by-id:
                            HINT:
                            tcp
                            HINT:
                            tcp
                            HINT:
                            tcp
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.6.17
                            javascript:     8.9.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        49806
                            States:         42339
                            Pending Updates: 0
                            Jetzt läuft der admin:
                            Adapter State
                            Bring jetzt nodejs auf Version 22:
                            iob nodejs-update
                            Und danach die Ausgabe von
                            iob update
                            iob upgrade
                            • S saeft_2003
                              tut er nicht!
                              nein!
                              enable heisst, dass du die Instanz aktiviert und nicht pausiert hast
                              Log File - Last 25 Lines
                              wären jetzt sehr interessant gewesen
                                Adapter State
                                iob nodejs-update
                                iob update
                                iob upgrade
                                saeft_2003
                                admin läuft jetzt nur weil ich ich wieder zurück bin auf 7.6.17. Trotzdem weiter machen mit dem node update?
                                • S saeft_2003
                                  Kannst du dann bitte tun was wir sagen? Danke...
                                    saeft_2003
                                    ja klar mach ich, hab nur gedacht das wir evtl. gerade aneinander vorbei reden. Ich mache jetzt das node update dann melde ich mich.
                                    @Homoran
                                    Das log file hab ich leider nicht mehr...
                                    • S saeft_2003
                                      @Homoran
                                      Das liegt in
                                      /home/iobroker/iob_diag.log
                                        Das liegt in
                                        saeft_2003
                                        patrick@iobroker:~$ iob update
                                        patrick@iobroker:~$ iob upgrade
                                        This upgrade of "admin" will introduce the following changes:
                                        -> 7.7.2:
                                        Fixing change of the language in the admin
                                        -> 7.7.1:
                                        Fixing clearing of the filter on the object tab
                                        -> 7.7.0:
                                        Added the concept for single-side-on authentication (SSO)
                                        -> 7.6.20:
                                        Allowed using of * in the filter of objects
                                        Small GUI improvements
                                        -> 7.6.19:
                                        Improvements on JSONConfig component `state`
                                        Added `infoBox` JSONConfig component
                                        -> 7.6.18:
                                        Added OAuth2 authentication to JSONConfig components
                                        Would you like to upgrade admin from @7.6.17 to @7.7.2 now? [(y)es, (n)o]: y
                                        Update admin from @7.6.17 to @7.7.2
                                        host.iobroker Adapter "system.adapter.admin.0" is stopped.
                                        NPM version: 10.9.3
                                        Installing iobroker.admin@7.7.2... (System call)
                                        added 16 packages, and changed 9 packages in 6s
                                        251 packages are looking for funding
                                          run `npm fund` for details
                                        Updating objects from io-package.json for adapter "admin" with version "7.7.2"
                                        Update "system.adapter.admin.0"
                                        upload [171] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                        upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
                                        upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
                                        upload [90] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-C0FlO84Y.js custom/assets/index-C0FlO84Y.js application/javascript
                                        upload [80] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-CcDQHtwq.js custom/assets/index-CcDQHtwq.js application/javascript
                                        upload [70] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js custom/assets/index-DIVai5gZ.js application/javascript
                                        upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-G9F5mhbe.js custom/assets/index-G9F5mhbe.js application/javascript
                                        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-eQxyhk2m.js custom/assets/index-eQxyhk2m.js application/javascript
                                        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/jsx-runtime-DEOw6lrW.js custom/assets/jsx-runtime-DEOw6lrW.js application/javascript
                                        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/virtualExposes-BufY-8i6.js custom/assets/virtualExposes-BufY-8i6.js application/javascript
                                        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
                                        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                                        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                                        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
                                        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
                                        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                                        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                                        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json
                                        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json
                                        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json
                                        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json
                                        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json
                                        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json
                                        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json
                                        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json
                                        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json
                                        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json
                                        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                                        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                        host.iobroker Adapter "system.adapter.admin.0" is started
                                          saeft_2003
                                          @Homoran @Thomas-Braun
                                          Nach dem node-js update komme ich wieder auf admin mit 7.7.2 👍
                                          Lag das jetzt an node-js? Die war doch mit 20.x jetzt noch nicht so alt...
