  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    5.8k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • flandsteF flandste
    @stefank Auch ich habe Probleme (KIA Niro EV) - folgende Fehlermeldungen bei der Installation:
    $ iobroker upgrade bluelink@3.1.20 --debug
    Update bluelink from @3.1.3 to @3.1.20
    NPM version: 10.9.3
    Installing iobroker.bluelink@3.1.20... (System call)
    npm warn deprecated npmlog@4.1.2: This package is no longer supported.
    npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated gauge@2.7.4: This package is no longer supported.
    bluelinky@9.1.0 prepare> tsc
    usocket@0.3.0 install> node-gyp rebuild
    gyp info it worked if it ends with ok
    gyp info using node@22.19.0 | linux | arm64
    (node:122369) [DEP0060] DeprecationWarning: The util._extend API is deprecated. Please use Object.assign() instead.(Use node --trace-deprecation ... to show where the warning was created)
    gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
    gyp ERR! UNCAUGHT EXCEPTION
    gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.34+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usocket/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/usocketgyp ERR! node -v v22.19.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    changed 2 packages in 29s
    240 packages are looking for funding run npm fund for details
    Updating objects from io-package.json for adapter "bluelink" with version "3.1.20"
    Update "system.adapter.bluelink.0"
    upload [12] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink.png bluelink.png image/png
    upload [11] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [7] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [1] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/jsonConfig.json jsonConfig.json application/json
    Process exited with code 0
    Wer kann da weiterhelfen bzw. die Fehlermeldungen ausdeutschen?
    Meister MopperM Online
    Meister Mopper
    #2137
    @flandste
    Schau dir mal iob diag an, möglicherweise werden da Optimierungsmöglichkeiten angezeigt und zeige das Ergebnis in </>codetags hier.
    Es gibt hier einige sehr gute Berater.
    Proxmox und HA ...
    Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
      ManfredHi
      schrieb am zuletzt editiert von ManfredHi
      #2138
      ich bekomme beim Bluelink-Adapter wenn ich die Abfrage vom Server mache immer folgende Meldung:
      bluelink.0
      2025-09-06 09:35:19.309	info	Update for TMAHXXXXXXXX5166 successfull
      bluelink.0
      2025-09-06 09:35:19.308	error	TypeError: Cannot read properties of undefined (reading 'State') at Bluelink.setNewFullStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:731:106) at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:392:17) at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13) at async Pe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:298:21)
      bluelink.0
      2025-09-06 09:35:13.092	info	Read new update for TMAHXXXXXXXX5166  from the server
      bluelink.0
      2025-09-06 09:35:12.992	info	1 Vehicles found
      bluelink.0
      2025-09-06 09:35:10.763	info	Login to api
      bluelink.0
      2025-09-06 09:35:10.756	info	starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.4, js-controller: 7.0.7
      habe einen Hyundai i30 N-Line Bj. 2025.
      Bluelink-Adapter 3.1.3 ist installiert. Wenn ich den 3.1.20 nehme, dann kann ich mich nicht einloggen, da sagt mir der Adapter ständig, dass die Zugangsdaten nicht stimmen.
      Hab ich da irgendwas falsch eingestellt ?
      ilovegymI 1 Antwort Letzte Antwort
      • M ManfredHi
        bluelink.0
        bluelink.0
        bluelink.0
        bluelink.0
        bluelink.0
        bluelink.0
        ilovegymI Offline
        ilovegymI Offline
        ilovegym
        #2139
        @manfredhi
        ei, das ist ja auch ne Uralt Version 3.1.3 ...
        • ilovegymI ilovegym
          @manfredhi
          ManfredHi
          #2140
          @ilovegym sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
          Das ist doch die letzte im Stable, die mir angezeigt wird.
          Wenn ich über NPM die 3.1.20 installiere, dann klappt die Anmeldung nicht. Da bleibt der Adapter dann auf gelb, weil angeblich meine Zugangsdaten falsch wären.
          2025-09-05 20:46:54.486  - info: bluelink.0 (2253469) starting. Version 3.1.20 in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.4, js-controller: 7.0.7
          2025-09-05 20:46:54.493  - info: bluelink.0 (2253469) Login to api
          2025-09-05 20:46:55.913  - error: bluelink.0 (2253469) Error: @EuropeController.login: Could not manage to get token: {"retId":"dbddf418-5447-4547-9342-0f6f897aab25","retCode":4000,"retMsg":"Bad Request","retSubMsg":"\"clientSecret is wrong. requested clientId=6d477c38-3ca4-4cf3-9557-2a1929a94654 requested clientSecret=secret\"","retValue":null}
          2025-09-05 20:46:55.913  - error: bluelink.0 (2253469) Server is not available or login credentials are wrong
          2025-09-05 20:46:55.913  - error: bluelink.0 (2253469) next auto login attempt in 1 hour or restart adapter manual
          ilovegymI Pedder007P 2 Antworten Letzte Antwort
          • M ManfredHi
            ilovegymI Offline
            ilovegymI Offline
            ilovegym
            #2141
            @manfredhi
            ja, wie du hier im Thread lesen kannst, baut zur Zeit Hyundai-Kia an den Servern rum.. wenn du glueck hast, geht irgendeine Version ( evtl mal 3.1.6,? ) ... es gibt leider zu viele Typen ..
            • M ManfredHi
              Pedder007P Offline
              Pedder007P Offline
              Pedder007
              schrieb am zuletzt editiert von Pedder007
              #2142
              @manfredhi ich bin auf der 3.1.19 und bei mir geht's aktuell (seit ca. 1 - 1,5 Wochen) auch nicht.
              KIA/Hyundai erwirtschaftet sich da aktuell, aus meiner Sicht, keine gute Kundenreputation. Ich war vorher gut 6 Jahre in der 'me Connect' Umgebung von Mercedes, bzw. hatte hier auch den entsprechenden Adapter im Einsatz. Da gab es solche (gravierenden) Probleme nie.
              Und @arteck das geht in keinster weise in Deine Richtung. Du machst einen tollen Job!
              Die neue KIA-App finde ich auch grottig unübersichtlich und ich werde auch einen Teufel tun und die Kollegen mein Fahrverhalten überwachen lassen (das nimmt ja langsam Züge von Orwells 1984 an).
              Pedder
              All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
              Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
              Under construction: Smart-WoMo auf Raspi4
              • Pedder007P Pedder007
                arteckA Offline
                arteckA Offline
                arteck
                #2143
                @pedder007 ich vermute da eher die wollen nicht fremde System auf dem Server haben. ergo bauen die ein Riegel vor. mal schauen in welche Richtung das geht ..
                evcc geht auch nicht mehr und da sind di Jung mehr auf zack als ich
                Pedder007P 1 Antwort Letzte Antwort
                • arteckA arteck
                  Pedder007P Offline
                  Pedder007P Offline
                  Pedder007
                  #2144
                  @arteck klar wollen sie das eigentlich nicht, weil sie müssen dann natürlich 1. ggf. mehr CPU und Bandbreite zur Verfügung stellen, haben 2. keine Kontrolle darüber was mit den Daten passiert und verlieren 3. Nutzer aus ihren komischen Apps mit denen sie ja weitere Nutzerdaten generieren.
                  Leider haben da viele Firmen nicht verstanden, dass es mittlerweile ganz viele Nutzer gibt, die eben nicht für alles eine dedizierte App auf dem Handy haben wollen, bzw. eben die Daten auch anderweitig / sinnvoll, und vor allem plattform-übergreifend, weiter verwenden wollen.
                  Gerade was das gesamte (private) Energie-Management angeht (inkl. Fahrzeug), muss das einfach möglich sein. Dazu sollte die Kollegen in Brüssel mal ein Machtwort sprechen. Aber da halten dann wahrscheinlich genau die zugehörigen Lobbyisten den Deckel drauf.
                  Allerdings machen sich ja aktuell auch einige Energieversorger auf den Weg mit eigenen intelligenten Lösungen in die Haushalte zu gehen. Die werden dann ja auf die gleichen Probleme stoßen und evtl. gibt es dann ja von dort, mit mehr Druck, einen entsprechenden Impuls zu besseren Schnittstellen ;-)
                  Aktuell is es wirklich einfach nur traurig, dass da viele nur in ihrem closed Shop denken ... 😢
                  Und nochmal, danke das Du hier so dranbleibst @arteck, ich finde das ganz super 👍
                  PS. ... und nun höre ich auch damit auf hier noch weitere Arien zu singen 🤣
                  Pedder
                  • P Peguschwein
                    E-Niro und EV3 funktionieren wieder. Beim EV3 ist der Datenaufbau anders als vorher, Darum musste ich einige Datenpunkte im VIS und einige Scripte anpassen. Jetzt passt wieder alles
                    Peguschwein
                    #2145
                    unterdessen geht wieder nicht mehr. Muss mich wohl vom EV3 und Niro trennen
                    • P Peguschwein
                      ilovegymI Offline
                      ilovegymI Offline
                      ilovegym
                      #2146
                      @peguschwein was geht nicht mehr?
                        Peguschwein
                        #2147
                        @ilovegym
                        seit ein paar Tagen habe ich keinen Zugriff mehr. Instanz auch shon gelöscht und neu installiert.alles ohne Erfolg
                        Zuerst war eine Fehlermeldung Landescode nicht supported Hatte eigentlich nur den SOC und km Stand und die Reichweite ausgelesen. Vor en paar Tagen ist
                        dann nichts mehr gegangen. Login 100% korrekt
                        ManagedBluelinkyError: @EuropeController.login: [401] Unauthorized on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin - {"errId":"xxxxxxxxxxxxxxxxxxx","errCode":"4010","errMsg":"Require authentication"}
                        die x sind ein Platzhalter für eine Nummer habe sie mal vorsichtshalber rausgenommen
                        Gruss Rene
                        • P Peguschwein
                          @ilovegym
                          Gruss Rene
                          ilovegymI Offline
                          ilovegymI Offline
                          ilovegym
                          #2148
                          @peguschwein
                          na bei dem Fehler Landescode auf EN stellen, dann gehts. ( so hab ich s auch, aber mit Version 3.1.6 - Hyundai Ioniq 5N )
                          Keiner weiss, ausser Hyundai (und da bin ich mir auch nicht sicher), was die machen und vorhaben und ändern... zur Zeit gibts wohl die Migration von Bluelink zur MyHyundai-App, letztere funktioniert bei mir zumindest mit den Push, die werden auch angezeigt, wenn die App nicht aktiv ist, im Gegensatz zur Bluelink, da kommen erst Meldungen, wenn ich die App aufmache..
                          Pedder007P P 2 Antworten Letzte Antwort
                            @peguschwein
                            Pedder007P Offline
                            Pedder007P Offline
                            Pedder007
                            #2149
                            Nope, habe gerade für KIA Niro EV3 mal von 3.1.19 nach 3.1.6 down-ge-graded und auch den Landescode angepasst, aber das hilft leider auch nicht. Gleiche Fehlermeldung wie bei @Peguschwein
                            bluelink.0
                            2025-09-09 12:04:05.981	error	next auto login attempt in 1 hour or restart adapter manual
                            bluelink.0
                            2025-09-09 12:04:05.981	error	Server is not available or login credentials are wrong
                            bluelink.0
                            2025-09-09 12:04:05.981	error	ManagedBluelinkyError: @EuropeController.login: [401] Unauthorized on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/language - "{\"errId\":\"xxxxxxxxxxxxxxxxxxxxxx\",\"errCode\":\"4010\",\"errMsg\":\"Require authentication\"}\n"
                            Da hilft weiter nur warten und hoffen ;-)
                            Pedder
                              @peguschwein
                              Peguschwein
                              schrieb am zuletzt editiert von Peguschwein
                              #2150
                              @ilovegym
                              war das erste was ich gemacht habe, dann ist aber nur der Fehler vom Ländercode weg. Login funktioniert trotzdem nicht. Das gleiche beim E-Niro
                              • P Peguschwein
                                @ilovegym
                                ilovegymI Offline
                                ilovegymI Offline
                                ilovegym
                                #2151
                                @peguschwein @Pedder007
                                schade! 😞
                                  sansibar
                                  schrieb am zuletzt editiert von sansibar
                                  #2152
                                  Gleiche Fehlermeldung bei mir wie bei @Peguschwein
                                  Funktioniert seit 26.08. um 02:27 nicht mehr - bis dahin lief alles jahrelang wunderbar (demzufolge sind auch die Credentials sicher korrekt).
                                  Auch das Umstellen der Sprache auf EN (oder zurück auf DE) hat hier nichts gebracht.
                                  Hoffe, hier wird bald eine Lösung gefunden... 😬
                                    ManfredHi
                                    #2153
                                    Also bei mir läuft die 3.1.19 insoweit einwandfrei. Nur dieser eine Eintrag
                                    bluelink.0
                                    war auch mit dieser Version vorhanden. mit hilfe von chatgpt habe ich in der main.js etwas geändert. nun kommt dieser fehler nicht mehr. meine benötigten Daten wie Status ob zugesperrt oder nicht km-Stand, Füllstand Tank, Reichweite usw. kommen alle rein. Auch funktioniert das auf- und zusperren.
                                    • M ManfredHi
                                      bluelink.0
                                      ManfredHi
                                      #2154
                                      @manfredhi sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                      Copy to Clipboard 2025-09-06 09:35:19.308 error TypeError: Cannot read properties of undefined (reading 'State') at Bluelink.setNewFullStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:731:106) at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:392:17) at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13) at async Pe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:298:21) bluelink.0
                                      Allerdings nach einem Sperr- oder Aufsperrbefehl funktioniert kein weiterer Befehl mehr (das sperren oder zusperren wird ausgeführt, aber dann geht nichts mehr). Das war aber auch vor der änderung in der main.js schon so.
                                      Mache deshalb mit einem zusätzlichen Skript zeitverzögert nach so einem sperr und aufsperrbefehl ein neuerliches forceLogin und dann geht auch das.
                                      • M ManfredHi
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #2155
                                        @manfredhi das wird bei dir solange funktionieren bis der Token abgelaufen ist..
                                        • arteckA arteck
                                          ManfredHi
                                          #2156
                                          @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                          ok. und wann läuft dieser ab? durch einen neustart des adapters ?
