  4. js Controler auf 7.07 geht nicht Fehlermeldung iOb
    1.0k
    6.1k
52 Beiträge 6 Kommentatoren 4.9k Aufrufe 5 Beobachtet
  • mcm1957M Online
    mcm1957M Online
    mcm1957
    @marcel-drzal
    Die deinem Problem zugrunde liegende Fehlermeldung ist folgende:
    error: host.iobroker iobroker npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Required: {"node":"^18 || ^20"}npm error notsup Actual: {"npm":"10.9.3","node":"v22.18.0"}npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-22T13_13_53_260Z-debug-0.log
    2025-08-22 15:13:55.721 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.myuplink@0.8.4: 1
    2025-08-22 15:13:56.732 - info: host.iobroker iobroker exit 25
    2025-08-22 15:14:49.833 - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T14:14:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
    2025-08-22 15:14:50.069 - info: host.iobroker Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2025-08-22 15:14:58.547 - info: host.iobroker iobroker upgrade yahka@1.1.5 --debug
    2025-08-22 15:14:59.206 - info: host.iobroker iobroker Update yahka from @1.0.3 to @1.1.5
    2025-08-22 15:14:59.275 - info: host.iobroker iobroker NPM version: 10.9.3
    2025-08-22 15:14:59.275 - info: host.iobroker iobroker Installing iobroker.yahka@1.1.5... (System call)
    2025-08-22 15:15:05.132 - info: host.iobroker iobroker added 1 package, removed 1 package, and changed 19 packages in 6s408 packages are looking for funding run `npm fund` for details
    2025-08-22 15:15:06.399 - error: host.iobroker iobroker Cannot install "pam-devel": WARNING: apt does not have a stable CLI interface. Use with caution in scripts.E: Unable to locate package pam-devel
    2025-08-22 15:15:06.399 - error: host.iobroker iobroker The following apt packages could not be installed: pam-devel. Please install them manually.
    Oder extrahiert:
    Diese wird (oder wurde?) durch YAHKA in einer Version älter als 1.1.5 ausgelöst. Da du anscheinend zwischenzeitlich yahka auf 1.1.5 gebracht hast sollte sich das primäre Problem behoben haben.
    Was sonst noch zu sanieren wäre hat die @Thomas-Braun schon geschieben,
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    marcel-drzalM 1 Antwort Letzte Antwort
      @marcel-drzal
      Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
      Und dann sind da 125 Updates in der Pipeline...
      Und deine Paketquellen sind 'Kraut-und-Rüben'.
      Setz da einen frischen, konsistenten Container neu auf.
      marcel-drzalM Offline
      marcel-drzal
      @thomas-braun said in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
      @marcel-drzal
      wie kann ich die Packetquellen sauber ziehen
      Linux iobroker 6.8.12-13-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-13 (2025-07-22T10                                             :00Z) x86_64
      permitted by applicable law.
      Last login: Fri Aug 22 15:54:52 2025 from 10.10.10.166
      marcel@iobroker:~$   iobroker repo show
      │ (index) │ name               │ url        │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json                                             '        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-late                                             st.json' │ false        │
      Upgrade policy: none
      marcel@iobroker:~$
      • haselchenH haselchen
        @marcel-drzal
        Zeig nochmal bitte nen aktuelles
        iob diag
        marcel-drzal
        schrieb am zuletzt editiert von marcel-drzal
        @haselchen
        ich hoffe ihr könnt mir helfen. Versuche es nun erst einmal Sauber zu ziehen und dann Updaten.
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
        Operating System: Debian GNU/Linux 11 (bullseye)
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container
            Virtualization: lxc
                    Kernel: Linux 6.8.12-13-pve
              Architecture: x86-64
        OS is similar to:
        model name      : Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         11:54:07 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2025-08-24 11:54:07 CEST
                   Universal time: Sun 2025-08-24 09:54:07 UTC
                         RTC time: n/a
                      NTP service: n/a
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        marcel
        HOME=/home/marcel
        GROUPS=marcel sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            6.1G        1.9G        3.6G        0.0K        633M        4.3G
        Swap:           512M          0B        512M
        Total:          6.7G        1.9G        4.1G
        Active iob-Instances:   23
                 6144 M total memory
                 1892 M used memory
                 1886 M active memory
                  493 M inactive memory
                 3618 M free memory
                    0 M buffer memory
                  633 M swap cache
                  512 M total swap
                    0 M used swap
                  512 M free swap
        top - 11:54:08 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
        Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  6.2 us,  0.0 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   6144.0 total,   3617.9 free,   1892.3 used,    633.8 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   4251.6 avail Mem
        *** FAILED SERVICES ***
          UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
        * influxdb.service              loaded failed failed InfluxDB is an open-source, distributed, time series database
        * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
        4 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--160--disk--0 ext4       30G   11G   17G  39% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs   32G     0   32G   0% /dev/tty
        tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
        tmpfs                            tmpfs      13G  108K   13G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--160--disk--0 ext4   rw,relatime,stripe=16
        /var:
        1.7G    /var/
        709M    /var/cache
        704M    /var/cache/apt
        669M    /var/log
        665M    /var/log/journal/fe2dcc346dde445a9e95482e37c85663
        Archived and active journals take up 33.3M in the file system.
        /opt/iobroker/backups:
        2.2G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        670M    /opt/iobroker/iobroker-data/
        377M    /opt/iobroker/iobroker-data/files
        176M    /opt/iobroker/iobroker-data/backup-objects
        49M     /opt/iobroker/iobroker-data/files/vis.0
        48M     /opt/iobroker/iobroker-data/files/iot.admin
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        26M     /opt/iobroker/iobroker-data/objects.jsonl
        20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
        19M     /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        No Devices found 'by-id'
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.18.0
        /usr/bin/node           v22.18.0
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        /usr/bin/corepack       0.33.0
        nodejs:
          Installed: 22.18.0-1nodesource1
          Candidate: 22.18.0-1nodesource1
          Version table:
         *** 22.18.0-1nodesource1 600
             22.17.1-1nodesource1 600
             22.17.0-1nodesource1 600
             22.16.0-1nodesource1 600
             22.15.1-1nodesource1 600
             22.15.0-1nodesource1 600
             22.14.0-1nodesource1 600
             22.13.1-1nodesource1 600
             22.13.0-1nodesource1 600
             22.12.0-1nodesource1 600
             22.11.0-1nodesource1 600
             22.10.0-1nodesource1 600
             22.9.0-1nodesource1 600
             22.8.0-1nodesource1 600
             22.7.0-1nodesource1 600
             22.6.0-1nodesource1 600
             22.5.1-1nodesource1 600
             22.5.0-1nodesource1 600
             22.4.1-1nodesource1 600
             22.4.0-1nodesource1 600
             22.3.0-1nodesource1 600
             22.2.0-1nodesource1 600
             22.1.0-1nodesource1 600
             22.0.0-1nodesource1 600
             20.19.2+dfsg-1 500
                500 http://deb.debian.org/debian trixie/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 58433)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.6.17
        javascript:     8.9.2
        nodejs modules from github:     1
        +-- iobroker.luxtronik2@0.3.0 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#e3a8b912a68cdb84c808a91c6a2250ae4f7ec1b9)
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          system.adapter.denon.0                  : denon                 : iobroker                                 - disabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.judoisoft.0              : judoisoft             : iobroker                                 -  enabled
        + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 10.10.50.16
          system.adapter.luxtronik2.0             : luxtronik2            : iobroker                                 - disabled, port: 8214
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.16
        + system.adapter.myuplink.0               : myuplink              : iobroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Installed ioBroker-Adapters
        Adapter    "admin"        : 7.6.17   , installed 7.6.17
        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
        Adapter    "denon"        : 1.15.12  , installed 1.15.12
        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
        Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
        Adapter    "homekit-controller": 0.5.11, installed 0.5.11
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "judoisoft"    : 1.1.2    , installed 1.1.2
        Adapter    "klf200"       : 1.3.5    , installed 1.3.5
        Adapter    "knx"          : 2.0.30   , installed 2.0.30
        Adapter    "lg-thinq"     : 1.1.0    , installed 1.1.0
        Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
        Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
        Adapter    "myuplink"     : 0.8.4    , installed 0.8.4
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "shelly"       : 10.1.0   , installed 10.1.0
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Objects and States
        Objects:        8765
        States:         6459
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused)
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Hit:1 http://security.debian.org/debian-security trixie-security InRelease
        Hit:2 http://deb.debian.org/debian trixie InRelease
        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
        Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
        Err:6 https://dl.yarnpkg.co m/debian InRelease
          Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
        Err:4 https://repos.influxdata.com/debian buster InRelease
        Fetched 12.9 kB in 0s (46.8 kB/s)
        Reading package lists...
        W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
        Pending Updates: 125
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       22058      140/iobroker.js-con
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       17359      140/iobroker.js-con
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11038      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21672      193/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          21795      320/master
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       32747      712/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22163      342/io.admin.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       27465      667/io.simple-api.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          21796      320/master
        tcp6       0      0 :::111                  :::*                    LISTEN      0          11040      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          21674      193/sshd: /usr/sbin
        udp        0      0 10.10.50.16:50137       0.0.0.0:*                           1000       435218     547/io.knx.0
        udp        0      0 10.10.50.16:55244       0.0.0.0:*                           1000       1650387    547/io.knx.0
        udp        0      0 10.10.50.16:57540       0.0.0.0:*                           1000       56405      547/io.knx.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16336      75/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11039      1/init
        udp        0      0 10.10.50.16:123         0.0.0.0:*                           0          21644      172/ntpd
        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          21642      172/ntpd
        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          21638      172/ntpd
        udp        0      0 10.10.50.16:33034       0.0.0.0:*                           1000       766879     547/io.knx.0
        udp        0      0 10.10.50.16:33292       0.0.0.0:*                           1000       42281      547/io.knx.0
        udp        0      0 10.10.50.16:33516       0.0.0.0:*                           1000       796516     547/io.knx.0
        udp        0      0 10.10.50.16:35890       0.0.0.0:*                           1000       2015188    547/io.knx.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       34914      742/io.wled.0
        udp        0      0 10.10.50.16:38368       0.0.0.0:*                           1000       27253      547/io.knx.0
        udp        0      0 10.10.50.16:42227       0.0.0.0:*                           1000       144075     547/io.knx.0
        udp        0    960 10.10.50.16:43259       0.0.0.0:*                           1000       2062242    547/io.knx.0
        udp        0      0 10.10.50.16:43538       0.0.0.0:*                           1000       2015226    547/io.knx.0
        udp        0      0 10.10.50.16:47107       0.0.0.0:*                           1000       1431661    547/io.knx.0
        udp6       0      0 :::111                  :::*                                0          11041      1/init
        udp6       0      0 fe80::7435:b2ff:fe7:123 :::*                                109        22015      172/ntpd
        udp6       0      0 fd48:3919:e463:2897:123 :::*                                109        22013      172/ntpd
        udp6       0      0 ::1:123                 :::*                                0          21646      172/ntpd
        udp6       0      0 :::123                  :::*                                0          21635      172/ntpd
        2025-08-24 11:42:49.822  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:42:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:42:56.387  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
        2025-08-24 11:42:56.430  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
        2025-08-24 11:42:56.518  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
        2025-08-24 11:43:49.845  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:43:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:44:49.836  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:44:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:45:10.007  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3952
        2025-08-24 11:45:10.613  - info: dwd.0 (3952) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.18.0, js-controller: 7.0.7
        2025-08-24 11:45:10.805  - info: dwd.0 (3952) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-08-24 11:45:11.314  - info: host.iobroker instance system.adapter.dwd.0 having pid 3952 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-08-24 11:45:49.834  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:45:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:46:49.854  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:46:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:47:49.843  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:47:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:47:56.999  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
        2025-08-24 11:47:57.042  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
        2025-08-24 11:47:57.134  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
        2025-08-24 11:48:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:48:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:49:49.839  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:49:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:50:49.820  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:50:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:51:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:51:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:52:49.858  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:52:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        2025-08-24 11:52:57.648  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
        2025-08-24 11:52:57.690  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
        2025-08-24 11:52:57.782  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
        2025-08-24 11:53:49.823  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:53:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
        iob diag has finished.
        • mcm1957M mcm1957
          @marcel-drzal
          Oder extrahiert:
          marcel-drzal
          @mcm1957
          Danke für deine Hilfe.
          Yahkara nutze ich nicht mehr. hatte ich eigendlich gelöscht
          • marcel-drzalM marcel-drzal
            @mcm1957
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @marcel-drzal
            Zum Zeitpunkt der Fehlermeldung war yahka aber installiert.Bist du sicher, dass du den ADAPTER und nicht nur die INSTANZ gelöscht hast?
            EDIT:
            Lt iob diag in commentar https://forum.iobroker.net/topic/81995/js-controler-auf-7-07-geht-nicht-fehlermeldung-iob/12 hast du jetzt yahka 1.1.5 installiert - allerdings ohne aktive instanz.
            Du hast also offensichtlich nur die Instanz gelöscht :-)
            @Thomas-Braun
            Anregung für iob diag: Warnung bei Adaptern die installiert sind aber keine Instanz besitzen wär zu überlegen.
            marcel-drzalM Thomas BraunT 3 Antworten Letzte Antwort
            • mcm1957M mcm1957
              @marcel-drzal
              EDIT:
              @Thomas-Braun
              marcel-drzal
              @mcm1957
                @mcm1957
                mcm1957M Online
                mcm1957M Online
                mcm1957
                @marcel-drzal
                Yep ist installiert. Wenn du ihn nicht mehr benutzt solltest du ihn deinstallieren.
                • mcm1957M mcm1957
                  @marcel-drzal
                  EDIT:
                  @Thomas-Braun
                  @mcm1957 sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                  Schwierig zu checken. Können ja auch Adapter ohne Instanz sein oder die Nummerierung ist instanz.3 oder so.
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    Also zu checken of die Instanz .0 oder .99 ist wär sicher trivial machbar.
                    Hast du Beispiele für Adapter ohne Instanz? Da gibts sicher ein Kriterium dazu.
                    • mcm1957M mcm1957
                      @marcel-drzal
                      EDIT:
                      @Thomas-Braun
                      marcel-drzal
                      @mcm1957 Adapter habe ich gelöscht
                      habe nun einen error:
                      dpkg: error
                      470 upgraded, 165 newly installed, 34 to remove and 0 not upgraded.
                      Need to get 0 B/341 MB of archives.
                      After this operation, 743 MB of additional disk space will be used.
                      Do you want to continue? [Y/n] Y
                      Reading changelogs... Done
                      Extracting templates from packages: 100%
                      Preconfiguring packages ...
                      (Reading database ... 43860 files and directories currently installed.)
                      Preparing to unpack .../base-files_13.8_amd64.deb ...
                      * The base-files package cannot be installed because
                      * /bin is a directory, but should be a symbolic link.
                      * Please install the usrmerge package to convert this system to merged-/usr.
                      * For more information please read https://wiki.debian.org/UsrMerge.
                      dpkg: error processing archive /var/cache/apt/archives/base-files_13.8_amd64.deb               (--unpack):
                       new base-files package pre-installation script subprocess returned error exit s              tatus 1
                      Errors were encountered while processing:
                      E: Sub-process /usr/bin/dpkg returned an error code (1)
                        dpkg: error
                        @marcel-drzal
                        dpkg ist aber das Paketmanagement auf OS-Ebene. Da ist also eine Etage tiefer schon was schief.
                        sudo apt update
                        sagt?
                          @marcel-drzal
                          sudo apt update
                          sagt?
                          marcel-drzal
                          direcktes uptadt aus iobroker:
                          marcel@10.10.50.16's password:
                          Linux iobroker 6.14.8-2-pve #1 SMP PREEMPT_DYNAMIC PMX 6.14.8-2 (2025-07-22T10:0                                                       4Z) x86_64
                          Last login: Tue Aug 26 18:40:15 2025 from 10.10.10.166
                          marcel@iobroker:~$ sudo apt update
                          [sudo] password for marcel:
                          Hit:1 http://deb.debian.org/debian trixie InRelease
                          Get:2 http://security.debian.org/debian-security trixie-security InRelease [43.4                                                        kB]
                          Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.1 kB]
                          Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
                          Get:6 http://security.debian.org/debian-security trixie-security/main amd64 Pack                                                       ages [33.1 kB]
                          Get:7 http://security.debian.org/debian-security trixie-security/main Translatio                                                       n-en [22.0 kB]
                            The following signatures couldn't be verified because the public key is not av                                                       ailable: NO_PUBKEY D8FF8E1F7DF8B07E
                          Get:8 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [7803 B]
                          Err:9 https://dl.yarnpkg.co m/debian InRelease
                            Could not connect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connec                                                       tion refused) Could not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect                                                        (111: Connection refused)
                          Fetched 178 kB in 1s (325 kB/s)
                          Reading package lists... Done
                          471 packages can be upgraded. Run 'apt list --upgradable' to see them.
                          W: An error occurred during the signature verification. The repository is not up                                                       dated and the previous index files will be used. GPG error: https://repos.influx                                                       data.com/debian buster InRelease: The following signatures couldn't be verified                                                        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                          W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  T                                                       he following signatures couldn't be verified because the public key is not avail                                                       able: NO_PUBKEY D8FF8E1F7DF8B07E
                          W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not con                                                       nect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connection refused) C                                                       ould not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect (111: Connecti                                                       on refused)
                          PlatformBetriebssystem:linux
                          Architektur:x64
                          CPUs:2
                          Geschwindigkeit:4043 MHz
                          Modell:unknown
                          RAM:6 GB
                          System-Betriebszeit:2 T. 00:15:05
                          Node.js:v22.18.0
                          Zeit:1756964837826
                          Zeitversatz:-120
                          NPM:10.9.3
                          Adapter-Anzahl:574
                          Datenträgergröße:29.4 GB
                          Freier Festplattenspeicher:18.5 GB
                          Aktive Instanzen:21
                          Pfad:/opt/iobroker/
                          Betriebszeit:2 T. 00:15:01
                          aktiv:true
                          _nodeCurrent:22.18.0
                          _nodeNewest:22.19.0
                          _nodeNewestNext:22.19.0
                          _npmCurrent:10.9.3
                          _npmNewest:10.9.3
                          _npmNewestNext:10.9.3
                            Architektur:x64
                            CPUs:2
                            Modell:unknown
                            RAM:6 GB
                            Node.js:v22.18.0
                            Zeit:1756964837826
                            Zeitversatz:-120
                            NPM:10.9.3
                            Adapter-Anzahl:574
                            Aktive Instanzen:21
                            Pfad:/opt/iobroker/
                            aktiv:true
                            _nodeNewest:22.19.0
                            _npmCurrent:10.9.3
                            _npmNewest:10.9.3
                            @marcel-drzal
                            Hau die 471 Updates rein, verdammt.
                            Die influxdb-Quelle ist veraltet. Leg die neu an.
                            Geht so:
                            https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                            Und dann schau, aus welcher Datei dieses yarn-Dingsi kommt.
                            cd /etc/apt/
                            grep -r yarn .
                            Die Zeile mit dem Eintrag zu yarn würde ich löschen.
                              @marcel-drzal
                              Geht so:
                              cd /etc/apt/
                              grep -r yarn .
                              marcel-drzal
                              habe ich bekomme hier die Meldung:
                              Fetched 38.5 MB in 3s (11.3 MB/s)
                               new base-files package pre-installation script subprocess returned error exit status 1
                              marcel@iobroker:~$
                                marcel@iobroker:~$
                                @marcel-drzal
                                Hast du das ganze Ding über Jahre von Release zu Release geschliffen?
                                Oder von Buster direkt auf Trixie gesprungen?
                                Da scheint mir einiges schiefgelaufen zu sein.
                                Installier es von Grund auf neu.
                                  @marcel-drzal
                                  marcel-drzal
                                  @thomas-braun nein denke habe es immer auf den neusten Stand gehalten.
                                  Neu? Gibt es einen anderen Weg. Wie kann ich da am besten vor gehen?
                                    @marcel-drzal sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                                    Von wo aus? Also doch über Generationen rübergetragen?
                                    Ich würde es neuinstallieren. Da fehlt mindestens der usrmerge auf der Kiste und wer weiß was sonst noch alles.
                                    Edit:
                                    Und dein Herumgehampel als root trägt auch nicht dazu bei da ein stabiles, sauberes System zu haben.
                                      Edit:
                                      marcel-drzal
                                      ok, ich mach alles neu.
                                      kannst du mir dabei helfen?
                                      würde erst mal ein neues sauberes System auf setzen in Proxmox.
                                      also es erst mal parallel laufen lassen und nach und nach alles rüber ziehen.
                                      oder geht das nich ?
                                      ich denke wenn ich ein Backup ziehe in iobroker habe ich die gelichen Probleme dann wieder oder?
                                      da_WoodyD Thomas BraunT 2 Antworten Letzte Antwort
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        @marcel-drzal bin jetzt auch kein profi, aber sauber aufsetzen (beschreibungen gibts genug), backup mit dem backitup adapter machen, dann sollten keine schweinereien mehr sein nach rückspielen.
                                          Nein, das darunterliegende System ist krumm und schief, der ioBroker dürfte da nicht direkt von betroffen sein.
                                          Zur Installation auf Proxmox:
                                          https://www.iobroker.net/#de/documentation/install/proxmox.md
