  4. js Controler auf 7.07 geht nicht Fehlermeldung iOb
    1.0k
    6.1k
52 Beiträge 6 Kommentatoren 4.9k Aufrufe 5 Beobachtet
  • marcel-drzalM Offline
    marcel-drzal
    schrieb am zuletzt editiert von marcel-drzal
    2025-08-22 15:13:55.721 - error: host.iobroker iobroker npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Required: {"node":"^18 || ^20"}npm error notsup Actual: {"npm":"10.9.3","node":"v22.18.0"}npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-22T13_13_53_260Z-debug-0.log
    2025-08-22 15:13:55.721 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.myuplink@0.8.4: 1
    2025-08-22 15:13:56.732 - info: host.iobroker iobroker exit 25
    2025-08-22 15:14:49.833 - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T14:14:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
    2025-08-22 15:14:50.069 - info: host.iobroker Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2025-08-22 15:14:58.547 - info: host.iobroker iobroker upgrade yahka@1.1.5 --debug
    2025-08-22 15:14:59.206 - info: host.iobroker iobroker Update yahka from @1.0.3 to @1.1.5
    2025-08-22 15:14:59.275 - info: host.iobroker iobroker NPM version: 10.9.3
    2025-08-22 15:14:59.275 - info: host.iobroker iobroker Installing iobroker.yahka@1.1.5... (System call)
    2025-08-22 15:15:05.132 - info: host.iobroker iobroker added 1 package, removed 1 package, and changed 19 packages in 6s408 packages are looking for funding run `npm fund` for details
    2025-08-22 15:15:06.399 - error: host.iobroker iobroker Cannot install "pam-devel": WARNING: apt does not have a stable CLI interface. Use with caution in scripts.E: Unable to locate package pam-devel
    2025-08-22 15:15:06.399 - error: host.iobroker iobroker The following apt packages could not be installed: pam-devel. Please install them manually.
    Myuplink adapter installieren geht nicht und
    hoffe ihr könnt mir helfen und bitte nachsichtig bin nicht so fitt hier,
    • Adaptername: ... myuplink
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: ...
    • js-controller Version: ...
    • Admin Version: ...
    • Hardwaresystem: NUC, Pi4 ...
    • Arbeitsspeicher: ...xGB
    • Festplattenart: SD-Karte, SSD, HDD, ...
    • Betriebssystem: ...
    • Nodejs-Version: ...v22.18.0
    • NPM-Version: ...10.9.3
    • Installationsart: Skript oder Manuell ?
    • Image, Docker genutzt: Ja - Nein
    • Ort, Name der Imagedatei: ...
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 11 (bullseye)
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
                Kernel: Linux 6.8.12-13-pve
          Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     14:54:39 up 59 min,  1 user,  load average: 0.81, 0.67, 0.45
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2025-08-22 14:54:39 CEST
               Universal time: Fri 2025-08-22 12:54:39 UTC
                     RTC time: n/a
                  NTP service: n/a
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    marcel
    HOME=/home/marcel
    GROUPS=marcel sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            6.1G        1.7G        3.3G        0.0K        1.1G        4.5G
    Swap:           512M          0B        512M
    Total:          6.7G        1.7G        3.8G
    Active iob-Instances:   22
             6144 M total memory
             1687 M used memory
             1552 M active memory
              963 M inactive memory
             3322 M free memory
                0 M buffer memory
             1134 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 14:54:39 up 59 min,  1 user,  load average: 0.81, 0.67, 0.45
    Tasks:  51 total,   2 running,  49 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 12.1 us,  6.1 sy,  0.0 ni, 81.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   6144.0 total,   3322.1 free,   1687.8 used,   1134.1 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   4456.0 avail Mem
    *** FAILED SERVICES ***
      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
    * influxdb.service              loaded failed failed InfluxDB is an open-source, distributed, time series database
    * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
    4 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--160--disk--0 ext4       30G   11G   17G  39% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  108K   13G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--160--disk--0 ext4   rw,relatime,stripe=16
    /var:
    1.7G    /var/
    709M    /var/cache
    704M    /var/cache/apt
    670M    /var/log
    665M    /var/log/journal/fe2dcc346dde445a9e95482e37c85663
    Archived and active journals take up 33.3M in the file system.
    /opt/iobroker/backups:
    2.2G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    664M    /opt/iobroker/iobroker-data/
    388M    /opt/iobroker/iobroker-data/files
    176M    /opt/iobroker/iobroker-data/backup-objects
    49M     /opt/iobroker/iobroker-data/files/vis.0
    48M     /opt/iobroker/iobroker-data/files/iot.admin
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.*
    Extended Pan ID:
    grep: /opt/iobroker/iobroker-data/zigbee_*/nvbackup.json: No such file or directory
    Pan ID:
    /home/iobroker/.diag.sh: line 713: printf: 0x: invalid hex number
    Channel:
    Network Key:
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.18.0
    /usr/bin/node           v22.18.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 22.18.0-1nodesource1
      Candidate: 22.18.0-1nodesource1
      Version table:
     *** 22.18.0-1nodesource1 600
         22.17.1-1nodesource1 600
         22.17.0-1nodesource1 600
         22.16.0-1nodesource1 600
         22.15.1-1nodesource1 600
         22.15.0-1nodesource1 600
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 136)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     1
    +-- iobroker.luxtronik2@0.3.0 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#e3a8b912a68cdb84c808a91c6a2250ae4f7ec1b9)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.denon.0                  : denon                 : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.judoisoft.0              : judoisoft             : iobroker                                 -  enabled
    + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 10.10.50.16
      system.adapter.luxtronik2.0             : luxtronik2            : iobroker                                 - disabled, port: 8214
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.16
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
    Adapter    "judoisoft"    : 1.1.2    , installed 1.1.2
    Adapter    "klf200"       : 1.3.5    , installed 1.3.5
    Adapter    "knx"          : 2.0.30   , installed 2.0.30
    Adapter    "lg-thinq"     : 1.1.0    , installed 1.1.0
    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "yahka"        : 1.1.5    , installed 1.0.3  [Updatable]
    Objects and States
    Objects:        8605
    States:         6325
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (3.224.76.162). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (54.164.204.90). - connect (111: Connection refused)
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://security.debian.org/debian-security trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Get:3 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
    Hit:4 http://deb.debian.org/debian trixie-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Err:3 https://repos.influxdata.com/debian buster InRelease
    Err:6 https://dl.yarnpkg.co m/debian InRelease
      Could not connect to dl.yarnpkg.co:443 (54.164.204.90). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (3.224.76.162). - connect (111: Connection refused)
    Fetched 12.9 kB in 0s (46.6 kB/s)
    Reading package lists...
    W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (54.164.204.90). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (3.224.76.162). - connect (111: Connection refused)
    Pending Updates: 125
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       55537724   24434/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       55537735   24434/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          55289997   168/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          55287579   325/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          55287088   1/init
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       55538522   24776/io.simple-api
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       55538613   24821/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       55534315   24457/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          55287580   325/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          55289999   168/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          55287090   1/init
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          55287203   76/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          55287089   1/init
    udp        0      0 10.10.50.16:123         0.0.0.0:*                           0          55287468   237/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          55287466   237/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          55287462   237/ntpd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       55539535   24856/io.wled.0
    udp        0      0 10.10.50.16:48468       0.0.0.0:*                           1000       55538332   24671/io.knx.0
    udp6       0      0 :::111                  :::*                                0          55287091   1/init
    udp6       0      0 fd48:3919:e463:2897:123 :::*                                109        55288262   237/ntpd
    udp6       0      0 fe80::7435:b2ff:fe7:123 :::*                                109        55290215   237/ntpd
    udp6       0      0 ::1:123                 :::*                                0          55287470   237/ntpd
    udp6       0      0 :::123                  :::*                                0          55287459   237/ntpd
    2025-08-22 14:53:37.880  - info: host.iobroker instance system.adapter.web.0 in version "7.0.8" started with pid 24821
    2025-08-22 14:53:38.575  - info: web.0 (24821) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.18.0, js-controller: 7.0.6
    2025-08-22 14:53:38.680  - info: web.0 (24821) socket.io server listening on port 8082
    2025-08-22 14:53:38.681  - info: web.0 (24821) http server listening on port 8082
    2025-08-22 14:53:41.873  - info: host.iobroker instance system.adapter.iot.0 in version "3.3.0" started with pid 24841
    2025-08-22 14:53:42.487  - info: iot.0 (24841) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v22.18.0, js-controller: 7.0.6
    2025-08-22 14:53:42.507  - info: iot.0 (24841) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2025-08-22 14:53:42.833  - info: iot.0 (24841) Connection changed: connect "marcel-drzal_arcor_de"
    2025-08-22 14:53:45.879  - info: host.iobroker instance system.adapter.wled.0 in version "0.7.2" started with pid 24856
    2025-08-22 14:53:46.446  - info: wled.0 (24856) starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.wled, node: v22.18.0, js-controller: 7.0.6
    2025-08-22 14:53:46.569  - info: wled.0 (24856) Try to contact 3 known devices
    2025-08-22 14:53:46.569  - info: wled.0 (24856) Try to contact : "WLEDJayson" on IP : 172.16.0.206
    2025-08-22 14:53:49.577  - info: wled.0 (24856) Try to contact : "WLED-SoundReactive" on IP : 172.16.0.205
    2025-08-22 14:53:49.868  - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T13:42:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
    2025-08-22 14:53:49.868  - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T13:53:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
    2025-08-22 14:53:49.876  - info: host.iobroker instance system.adapter.info.0 in version "2.0.0" started with pid 24871
    2025-08-22 14:53:50.608  - info: cloud.0 (24641) Trying to connect as system.user.admin to cloud
    2025-08-22 14:53:50.639  - info: info.0 (24871) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v22.18.0, js-controller: 7.0.6
    2025-08-22 14:53:50.688  - info: info.0 (24871) Reading/updating systemdata.
    2025-08-22 14:53:50.711  - info: cloud.0 (24641) Connection changed: connect
    2025-08-22 14:53:50.992  - info: info.0 (24871) cpu Temp res = {"main":60,"cores":[57,56,57,63,55,59],"max":63,"socket":[],"chipset":null}
    2025-08-22 14:53:52.578  - info: wled.0 (24856) Try to contact : "WLED-SoundReactive" on IP : 10.10.50.205
    2025-08-22 14:53:55.581  - info: wled.0 (24856) Bonjour service started, new  devices  will  be detected automatically
    2025-08-22 14:54:05.583  - info: wled.0 (24856) WLED initialisation finalized, ready to do my job have fun !
    2025-08-22 14:54:49.819  - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T13:54:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
    iob diag has finished.Bitte in der nachfolgenden Übersicht die mit ... bzw x gekennzeichneten Felder ausfüllen und im Anschluss an die Tabelle auf Linux Systemen den Output des Commands iob diag einfügen.
    Hinweis: Das Eröffnen eines Issues hier ersetzt NICHT das Anlegen eine Issues im Repository des Adapters. Fehlerbehebungen werden ausschließlich über Issues getrackt.
    DANKE
    Bitte ausfüllen:
    • Adaptername: ...
    • NPM-Version: ...
    Linux User bitte hier den Output von iob diag einfügen.Myuplink adapter installieren geht nicht und
    Script v.2025-08-09
    *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
    OS is similar to:
    Docker          : false
    Kernel          : x86_64
    Userland        : 64 bit
    CPU threads: 2
                     RTC time: n/a
                  NTP service: n/a
              RTC in local TZ: no
    marcel
    HOME=/home/marcel
    iobroker
    HOME=/home/iobroker
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Swap:           512M          0B        512M
             6144 M total memory
             1687 M used memory
             3322 M free memory
                0 M buffer memory
             1134 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    *** FILESYSTEM ***
    /var:
    1.7G    /var/
    709M    /var/cache
    704M    /var/cache/apt
    670M    /var/log
    USB-Devices by-id:
    zigbee.*
    Extended Pan ID:
    Pan ID:
    Channel:
    Network Key:
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    nodejs:
      Version table:
         20.19.2+dfsg-1 500
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    admin:          7.6.17
    javascript:     8.9.2
    Adapter State
    + instance is alive
    Objects and States
    Objects:        8605
    States:         6325
    • marcel-drzalM marcel-drzal
      Script v.2025-08-09
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      marcel
      HOME=/home/marcel
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           512M          0B        512M
               6144 M total memory
               1687 M used memory
               3322 M free memory
                  0 M buffer memory
               1134 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      1.7G    /var/
      709M    /var/cache
      704M    /var/cache/apt
      670M    /var/log
      USB-Devices by-id:
      zigbee.*
      Extended Pan ID:
      Pan ID:
      Channel:
      Network Key:
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8605
      States:         6325
      DANKE
      Bitte ausfüllen:
      • Adaptername: ...
      • NPM-Version: ...
      Script v.2025-08-09
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      marcel
      HOME=/home/marcel
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           512M          0B        512M
               6144 M total memory
               1687 M used memory
               3322 M free memory
                  0 M buffer memory
               1134 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      1.7G    /var/
      709M    /var/cache
      704M    /var/cache/apt
      670M    /var/log
      USB-Devices by-id:
      zigbee.*
      Extended Pan ID:
      Pan ID:
      Channel:
      Network Key:
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8605
      States:         6325
      @marcel-drzal
      Und dann sind da 125 Updates in der Pipeline...
      Und deine Paketquellen sind 'Kraut-und-Rüben'.
      Setz da einen frischen, konsistenten Container neu auf.
      marcel-drzalM 2 Antworten Letzte Antwort
        @marcel-drzal
        marcel-drzal
        @thomas-braun habe ich versucht aber nicht hin bekommen
        bleibt immer hängen
        login as: root
        root@10.10.50.16's password:
        Linux iobroker 6.8.12-13-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-13 (2025-07-22T10:00Z) x86_64
        permitted by applicable law.
        You have mail.
        Last login: Fri Aug 22 14:37:59 2025 from 10.10.10.166
        root@iobroker:~# sudo apt update
        Hit:1 http://deb.debian.org/debian trixie InRelease
        Hit:2 http://security.debian.org/debian-security trixie-security InRelease
        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
        Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
        Err:4 https://repos.influxdata.com/debian buster InRelease
        Fetched 12.9 kB in 0s (47.0 kB/s)
        Reading package lists... Done
        470 packages can be upgraded. Run 'apt list --upgradable' to see them.
        apt-listchanges: News
        openssh (1:10.0p1-1) unstable; urgency=medium
          OpenSSH 10.0p1 includes a number of changes that may affect existing
          configurations:
           * This release removes support for the weak DSA signature algorithm,
             completing the deprecation process that began in 2015 (when DSA was
             disabled by default) and repeatedly warned over the last 12 months.
           * scp(1), sftp(1): pass "ControlMaster no" to ssh when invoked by scp &
             sftp. This disables implicit session creation by these tools when
             ControlMaster was set to yes/auto by configuration, which some users
             found surprising. This change will not prevent scp/sftp from using an
             existing multiplexing session if one had already been created.
           * sshd(8): this release disables finite field (a.k.a modp) Diffie-Hellman
             key exchange in sshd by default. Specifically, this removes the
             "diffie-hellman-group*" and "diffie-hellman-group-exchange-*" methods
             from the default KEXAlgorithms list. The client is unchanged and
             continues to support these methods by default.
           * sshd(8): this release removes the implicit fallback to compiled-in
             groups for Diffie-Hellman Group Exchange KEX when the moduli file
             exists but does not contain moduli within the client-requested range.
             The fallback behaviour remains for the case where the moduli file does
             not exist at all. This allows administrators more explicit control over
             which DH groups will be selected, but can lead to connection failures
             if the moduli file is edited incorrectly.
         -- Colin Watson <cjwatson@debian.org>  Fri, 11 Apr 2025 11:16:19 +0100
        openssh (1:9.9p1-1) unstable; urgency=medium
          OpenSSH 9.9p1 includes a number of changes that may affect existing
          configurations:
           * ssh(1): remove support for pre-authentication compression.  OpenSSH has
        wie geht es hier weiter??
          bleibt immer hängen
          login as: root
          You have mail.
            configurations:
            configurations:
          @marcel-drzal
          Und wie immer: NIE, NIE, NIE als root herumkaspern.
          marcel-drzalM 1 Antwort Letzte Antwort
            @marcel-drzal
            marcel-drzal
            auch als user geht es nicht
              configurations:
            hängt an der Stelle, was muss ich hier machen?
                configurations:
              @marcel-drzal sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
              Mit q aus der Nachricht raus...
                marcel-drzal
                @thomas-braun said in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                470 upgraded, 165 newly installed, 34 to remove and 0 not upgraded.
                Need to get 0 B/341 MB of archives.
                After this operation, 743 MB of additional disk space will be used.
                Do you want to continue? [Y/n] Y
                Reading changelogs... Done
                apt-listchanges: Mailing root: apt-listchanges: news for iobroker
                Extracting templates from packages: 100%
                Preconfiguring packages ...
                (Reading database ... 43860 files and directories currently installed.)
                Preparing to unpack .../base-files_13.8_amd64.deb ...
                * The base-files package cannot be installed because
                * /bin is a directory, but should be a symbolic link.
                * Please install the usrmerge package to convert this system to merged-/usr.
                * For more information please read https://wiki.debian.org/UsrMerge.
                dpkg: error processing archive /var/cache/apt/archives/base-files_13.8_amd64.deb (--unpack):
                 new base-files package pre-installation script subprocess returned error exit status 1
                Errors were encountered while processing:
                E: Sub-process /usr/bin/dpkg returned an error code (1)
                marcel@iobroker:~$
                was ist das noch für ein error?
                Jetzt hat sich auch der js-controler auf 7.0.7 geändert Danke dir das hat schon mal geklappt 👏
                Installieren von Adapter myuplink gibt unten noch Fehlermeldungen, kannst du mir da helfen. Danke dir
                $ iobroker add myuplink auto --host iobroker --debug
                NPM version: 10.9.3
                Installing iobroker.myuplink@0.8.4... (System call)
                added 1 package in 4s
                host.iobroker install adapter myuplink
                upload [12] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [11] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [10] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [9] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [8] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [6] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [5] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [4] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [3] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [2] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [1] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/jsonConfig.json jsonConfig.json application/json
                upload [0] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/myuplink.png myuplink.png image/png
                host.iobroker object system.adapter.myuplink created/updatedUpdating objects from io-package.json for adapter "myuplink" with version "0.8.4"
                host.iobroker object system.adapter.myuplink.0.compactMode created
                host.iobroker object system.adapter.myuplink.0.cpu created
                host.iobroker object system.adapter.myuplink.0.cputime created
                host.iobroker object system.adapter.myuplink.0.memHeapUsed created
                host.iobroker object system.adapter.myuplink.0.memHeapTotal created
                host.iobroker object system.adapter.myuplink.0.memRss created
                host.iobroker object system.adapter.myuplink.0.uptime created
                host.iobroker object system.adapter.myuplink.0.inputCount created
                host.iobroker object system.adapter.myuplink.0.outputCount created
                host.iobroker object system.adapter.myuplink.0.eventLoopLag created
                host.iobroker object system.adapter.myuplink.0.sigKill created
                host.iobroker object system.adapter.myuplink.0.logLevel created
                host.iobroker object myuplink.0.info created
                host.iobroker object myuplink.0.info.connection created
                host.iobroker object myuplink.0.info.currentError created
                host.iobroker object myuplink.0.info.updateTime created
                host.iobroker object myuplink.0.info.lastError created
                host.iobroker Set default value of myuplink.0.info.currentError:
                host.iobroker Set default value of myuplink.0.info.updateTime:
                host.iobroker Set default value of myuplink.0.info.lastErrorTime:
                host.iobroker object system.adapter.myuplink.0 created
                Process exited with code 0
                haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                  marcel@iobroker:~$
                  NPM version: 10.9.3
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @marcel-drzal
                  Zeig nochmal bitte nen aktuelles
                  iob diag
                    marcel@iobroker:~$
                    NPM version: 10.9.3
                    ZUERST musst du die windschiefe Basis in Ordnung bringen. Auf das wackelige Fundament setzt man doch keinen Dienst drauf.
                    • mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @marcel-drzal
                      Die deinem Problem zugrunde liegende Fehlermeldung ist folgende:
                      Oder extrahiert:
                      Diese wird (oder wurde?) durch YAHKA in einer Version älter als 1.1.5 ausgelöst. Da du anscheinend zwischenzeitlich yahka auf 1.1.5 gebracht hast sollte sich das primäre Problem behoben haben.
                      Was sonst noch zu sanieren wäre hat die @Thomas-Braun schon geschieben,
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                        @marcel-drzal
                        marcel-drzal
                        @marcel-drzal
                        wie kann ich die Packetquellen sauber ziehen
                        Linux iobroker 6.8.12-13-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-13 (2025-07-22T10                                             :00Z) x86_64
                        Last login: Fri Aug 22 15:54:52 2025 from 10.10.10.166
                        marcel@iobroker:~$   iobroker repo show
                        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json                                             '        │ false        │
                        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-late                                             st.json' │ false        │
                        marcel@iobroker:~$
                        • haselchenH haselchen
                          @marcel-drzal
                          iob diag
                          marcel-drzal
                          @haselchen
                          ich hoffe ihr könnt mir helfen. Versuche es nun erst einmal Sauber zu ziehen und dann Updaten.
                          ```bash
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                                     Chassis: container
                              Virtualization: lxc
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           11:54:07 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
                          CPU threads: 2
                                         Local time: Sun 2025-08-24 11:54:07 CEST
                                     Universal time: Sun 2025-08-24 09:54:07 UTC
                                           RTC time: n/a
                                        NTP service: n/a
                                    RTC in local TZ: no
                          marcel
                          HOME=/home/marcel
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Mem:            6.1G        1.9G        3.6G        0.0K        633M        4.3G
                          Swap:           512M          0B        512M
                          Total:          6.7G        1.9G        4.1G
                          Active iob-Instances:   23
                                   6144 M total memory
                                   1892 M used memory
                                   1886 M active memory
                                    493 M inactive memory
                                   3618 M free memory
                                      0 M buffer memory
                                    633 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          top - 11:54:08 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
                          Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  6.2 us,  0.0 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   6144.0 total,   3617.9 free,   1892.3 used,    633.8 buff/cache
                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   4251.6 avail Mem
                          *** FILESYSTEM ***
                          /var:
                          1.7G    /var/
                          709M    /var/cache
                          704M    /var/cache/apt
                          669M    /var/log
                          670M    /opt/iobroker/iobroker-data/
                          377M    /opt/iobroker/iobroker-data/files
                          26M     /opt/iobroker/iobroker-data/objects.jsonl
                          19M     /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.3
                          /usr/bin/npx            10.9.3
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 58433)
                          js-controller:  7.0.7
                          admin:          7.6.17
                          javascript:     8.9.2
                          Adapter State
                          + system.adapter.myuplink.0               : myuplink              : iobroker                                 -  enabled
                          + instance is alive
                          Controller "js-controller": 7.0.7    , installed 7.0.7
                          Adapter    "myuplink"     : 0.8.4    , installed 0.8.4
                          Objects and States
                          Objects:        8765
                          States:         6459
                          W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused)
                            Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
                          Fetched 12.9 kB in 0s (46.8 kB/s)
                          W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       22058      140/iobroker.js-con
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       17359      140/iobroker.js-con
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11038      1/init
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21672      193/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          21795      320/master
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       32747      712/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22163      342/io.admin.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       27465      667/io.simple-api.0
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          21796      320/master
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          11040      1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          21674      193/sshd: /usr/sbin
                          udp        0      0 10.10.50.16:50137       0.0.0.0:*                           1000       435218     547/io.knx.0
                          udp        0      0 10.10.50.16:55244       0.0.0.0:*                           1000       1650387    547/io.knx.0
                          udp        0      0 10.10.50.16:57540       0.0.0.0:*                           1000       56405      547/io.knx.0
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16336      75/dhclient
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11039      1/init
                          udp        0      0 10.10.50.16:123         0.0.0.0:*                           0          21644      172/ntpd
                          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          21642      172/ntpd
                          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          21638      172/ntpd
                          udp        0      0 10.10.50.16:33034       0.0.0.0:*                           1000       766879     547/io.knx.0
                          udp        0      0 10.10.50.16:33292       0.0.0.0:*                           1000       42281      547/io.knx.0
                          udp        0      0 10.10.50.16:33516       0.0.0.0:*                           1000       796516     547/io.knx.0
                          udp        0      0 10.10.50.16:35890       0.0.0.0:*                           1000       2015188    547/io.knx.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       34914      742/io.wled.0
                          udp        0      0 10.10.50.16:38368       0.0.0.0:*                           1000       27253      547/io.knx.0
                          udp        0      0 10.10.50.16:42227       0.0.0.0:*                           1000       144075     547/io.knx.0
                          udp        0    960 10.10.50.16:43259       0.0.0.0:*                           1000       2062242    547/io.knx.0
                          udp        0      0 10.10.50.16:43538       0.0.0.0:*                           1000       2015226    547/io.knx.0
                          udp        0      0 10.10.50.16:47107       0.0.0.0:*                           1000       1431661    547/io.knx.0
                          udp6       0      0 :::111                  :::*                                0          11041      1/init
                          udp6       0      0 fe80::7435:b2ff:fe7:123 :::*                                109        22015      172/ntpd
                          udp6       0      0 fd48:3919:e463:2897:123 :::*                                109        22013      172/ntpd
                          udp6       0      0 ::1:123                 :::*                                0          21646      172/ntpd
                          udp6       0      0 :::123                  :::*                                0          21635      172/ntpd
                          2025-08-24 11:42:49.822  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:42:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:42:56.387  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
                          2025-08-24 11:42:56.430  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
                          2025-08-24 11:42:56.518  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
                          2025-08-24 11:43:49.845  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:43:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:44:49.836  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:44:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:45:10.007  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3952
                          2025-08-24 11:45:10.613  - info: dwd.0 (3952) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.18.0, js-controller: 7.0.7
                          2025-08-24 11:45:10.805  - info: dwd.0 (3952) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-08-24 11:45:11.314  - info: host.iobroker instance system.adapter.dwd.0 having pid 3952 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2025-08-24 11:45:49.834  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:45:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:46:49.854  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:46:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:47:49.843  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:47:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:47:56.999  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
                          2025-08-24 11:47:57.042  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
                          2025-08-24 11:47:57.134  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
                          2025-08-24 11:48:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:48:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:49:49.839  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:49:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:50:49.820  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:50:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:51:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:51:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:52:49.858  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:52:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          2025-08-24 11:52:57.648  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
                          2025-08-24 11:52:57.690  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
                          2025-08-24 11:52:57.782  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
                          2025-08-24 11:53:49.823  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:53:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                          • mcm1957M mcm1957
                            @marcel-drzal
                            Oder extrahiert:
                            marcel-drzal
                            @mcm1957
                            Danke für deine Hilfe.
                            Yahkara nutze ich nicht mehr. hatte ich eigendlich gelöscht
                              @mcm1957
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              @marcel-drzal
                              Zum Zeitpunkt der Fehlermeldung war yahka aber installiert.Bist du sicher, dass du den ADAPTER und nicht nur die INSTANZ gelöscht hast?
                              EDIT:
                              Lt iob diag in commentar https://forum.iobroker.net/topic/81995/js-controler-auf-7-07-geht-nicht-fehlermeldung-iob/12 hast du jetzt yahka 1.1.5 installiert - allerdings ohne aktive instanz.
                              Du hast also offensichtlich nur die Instanz gelöscht :-)
                              @Thomas-Braun
                              Anregung für iob diag: Warnung bei Adaptern die installiert sind aber keine Instanz besitzen wär zu überlegen.
                              marcel-drzalM Thomas BraunT 3 Antworten Letzte Antwort
                              • mcm1957M mcm1957
                                @marcel-drzal
                                EDIT:
                                @Thomas-Braun
                                marcel-drzal
                                @mcm1957
                                  @mcm1957
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  @marcel-drzal
                                  Yep ist installiert. Wenn du ihn nicht mehr benutzt solltest du ihn deinstallieren.
                                  • mcm1957M mcm1957
                                    @marcel-drzal
                                    EDIT:
                                    @Thomas-Braun
                                    @mcm1957 sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                                    Schwierig zu checken. Können ja auch Adapter ohne Instanz sein oder die Nummerierung ist instanz.3 oder so.
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      Also zu checken of die Instanz .0 oder .99 ist wär sicher trivial machbar.
                                      Hast du Beispiele für Adapter ohne Instanz? Da gibts sicher ein Kriterium dazu.
                                      • mcm1957M mcm1957
                                        @marcel-drzal
                                        EDIT:
                                        @Thomas-Braun
                                        marcel-drzal
                                        @mcm1957 Adapter habe ich gelöscht
                                        habe nun einen error:
                                        dpkg: error
                                         new base-files package pre-installation script subprocess returned error exit s              tatus 1
                                          dpkg: error
                                          @marcel-drzal
                                          dpkg ist aber das Paketmanagement auf OS-Ebene. Da ist also eine Etage tiefer schon was schief.
                                          sudo apt update
                                          sagt?
