  4. Neuer Robonect HX Adapter
    6.1k
robonectgardenahusqvarnamährobotergarten
467 Beiträge 58 Kommentatoren 166.2k Aufrufe 42 Beobachtet
  • I ioBrokerMike
    Moin
    Ich bekomme immer wieder vom Robonect HX Modul 1.4.2 Fehlermeldungen die aber die Funktion nicht beeinträchtigen, nur der Reiter Protokolle im IOBroker füllt sich.
    robonect.0
    2025-07-11 10:19:02.681	debug	currentStatus: 2
    robonect.0
    2025-07-11 10:19:02.681	debug	isRestTime: false
    robonect.0
    2025-07-11 10:19:02.681	debug	pollType: Status
    robonect.0
    2025-07-11 10:19:02.680	warn	Error returned from Robonect device: {"message":"connect ETIMEDOUT 192.168.178.20:80","name":"Error","stack":"Error: connect ETIMEDOUT 192.168.178.20:80\n at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:92:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:620:25)\n at RedirectableRequest.emit (node:events:524:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)\n at ClientRequest.emit (node:events:536:35)\n at ClientRequest.emit (node:domain:489:12)\n at emitErrorEvent (node:_http_client:101:11)\n at Socket.socketErrorListener (node:_http_client:504:5)\n at Socket.emit (node:events:524:28)\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n at processTicksAndRejections (node:internal/process/task_queues:95:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/1.10.0","Accept-Encoding":"gzip, compress, deflate, br"},"auth":{"username":"xxxxx","password":"yyyyy"},"params":{"cmd":"status"},"method":"get","url":"http://192.168.178.20/api/json","allowAbsoluteUrls":true},"code":"ETIMEDOUT"}
    robonect.0
    2025-07-11 10:19:02.680	error	connect ETIMEDOUT 192.168.178.20:80
    robonect.0
    2025-07-11 10:19:02.680	debug	Data received for error handling: {"message":"connect ETIMEDOUT 192.168.178.20:80","name":"Error","stack":"Error: connect ETIMEDOUT 192.168.178.20:80\n at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:92:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:620:25)\n at RedirectableRequest.emit (node:events:524:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)\n at ClientRequest.emit (node:events:536:35)\n at ClientRequest.emit (node:domain:489:12)\n at emitErrorEvent (node:_http_client:101:11)\n at Socket.socketErrorListener (node:_http_client:504:5)\n at Socket.emit (node:events:524:28)\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n at processTicksAndRejections (node:internal/process/task_queues:95:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/1.10.0","Accept-Encoding":"gzip, compress, deflate, br"},"auth":{"username":"xxxxx","password":"yyyyy"},"params":{"cmd":"status"},"method":"get","url":"http://192.168.178.20/api/json","allowAbsoluteUrls":true},"code":"ETIMEDOUT"}
    robonect.0
    2025-07-11 10:18:23.383	debug	Polling API for data [{"cmd":"status"}] started
    Habe ein Update der Application von 1.3b auf 1.5 gemacht.
    Bei beiden Version war es dasselbe.
    BoronsbruderB Online
    Boronsbruder
    #456
    @iobrokermike
    Hast du den Robonect-Adapter auf "DEBUG" laufen?
    Bei mir kommen nur hin und wieder mal Warnungen, dass kein Ping möglich war:
    2025-07-11 07:29:26.818 - warn: robonect.0 (1998307) No connection to lawn mower (Not able to ping it). Check network connection.
    I 1 Antwort Letzte Antwort
    • BoronsbruderB Boronsbruder
      @iobrokermike
      I Offline
      I Offline
      ioBrokerMike
      schrieb am zuletzt editiert von ioBrokerMike
      #457
      @boronsbruder
      Moin
      Entschuldige erst ein mal.
      Dieser Beitrag sollte an @braindead gehen.
      ... Hast du den Robonect-Adapter auf "DEBUG" laufen?
      Nur während der Ursachenfindung, ansonsten auf Error.
      PS. Habe den WLAN Teil vom Rebonect HX auch nochmal von 1.7.5 auf 1.7.6 Upgedatet.
      Mal sehen was Montag geschied wenn der Robi wieder ran muss.
      Mfg
      IOBrokerMike
      Achtung ! Sehkraft 25% | 60% , kein scherz
      Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
      • mcm1957M Online
        mcm1957M Online
        mcm1957
        #458
        @iobrokermike said in Neuer Robonect HX Adapter:
        Das wird eher aussichtslos :-). Er war zuletzt 2022 hier online...
        https://forum.iobroker.net/user/braindead
        Du wirst wohl den Support der User hier oder von @grizzlebee, der den Adapter übernommen hat (https://github.com/Grizzelbee/ioBroker.robonect) annehmen müssen.
        In jedem Fall wäre es auch sinnvoll, wenn du die im Einsatz befindliche ADAPTER Version angibst
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        LatziL 1 Antwort Letzte Antwort
        • mcm1957M mcm1957
          LatziL Offline
          LatziL Offline
          Latzi
          #459
          @mcm1957 sagte in Neuer Robonect HX Adapter:
          @grizzlebee
          du meintest wohl @Grizzelbee ;-)
          • LatziL Latzi
            @grizzlebee
            mcm1957M Online
            mcm1957M Online
            mcm1957
            #460
            @latzi said in Neuer Robonect HX Adapter:
            @grizzlebee
            Ja
            Ich wars nicht - meine Tastatur hat den Fehler gemacht :-)
            • mcm1957M mcm1957
              @grizzlebee
              Ja
              I Offline
              I Offline
              ioBrokerMike
              #461
              @mcm1957
              Vielen Danke für die Info
              Auch damit habe ich kein Problem.
              Es ist super das Grizzelbee sich den Adapter an nimmt.
              Mfg
              IOBrokerMike
              • I Offline
                I Offline
                ioBrokerMike
                #462
                @grizzlebee
                Moin
                Kannst du dir mal mein Beitrag (https://forum.iobroker.net/topic/11834/neuer-robonect-hx-adapter/455?_=1755705519869) an sehen.
                Mfg
                IOBrokerMike
                BoronsbruderB 1 Antwort Letzte Antwort
                • I ioBrokerMike
                  @grizzlebee
                  Moin
                  Boronsbruder
                  schrieb am zuletzt editiert von Boronsbruder
                  #463
                  @iobrokermike
                  kannst du mal die Einstellungen deiner Instanz posten?
                  Ich habe zum Beispiel
                  aktiviert.
                  Evtl. verhindert das Timeouts?
                  Achja, führt bei mir aber immer mal wieder zu
                  	warn	No connection to lawn mower (Not able to ping it). Check network connection.
                  Einträgen, was aber wahrscheinlich an meinem Setup mit einer WLAN-Brücke liegt
                  I V 2 Antworten Letzte Antwort
                    @iobrokermike
                    aktiviert.
                    I Offline
                    I Offline
                    ioBrokerMike
                    #464
                    @boronsbruder sagte in Neuer Robonect HX Adapter:
                    Bitte sehr.
                    Werde mal den Ping reinnehmen.
                    Mfg
                    IOBrokerMike
                    • I ioBrokerMike
                      Bitte sehr.
                      Boronsbruder
                      #465
                      @iobrokermike
                      Hmm, ich seh da auch nichts, was die Timeouts auslösen könnte...
                        @iobrokermike
                        I Offline
                        I Offline
                        ioBrokerMike
                        #466
                        @boronsbruder
                        Was ich noch habe, wäre :
                        a7aaa37a-e551-416c-b283-c0d0abc99b54-image.png von dieser Woche.
                        Mfg
                        IOBrokerMike
                          @iobrokermike
                          aktiviert.
                          V Offline
                          V Offline
                          valbuz
                          #467
                          Diese Einträge habe ich auch....😑
                          2xProxmox auf NUC
                          E3DC 13kWh Speicher via RCSP an ioBroker
