  4. Neuer Robonect HX Adapter
    6.0k
robonectgardenahusqvarnamährobotergarten
467 Beiträge 58 Kommentatoren 166.1k Aufrufe 42 Beobachtet
  • BoronsbruderB Boronsbruder
    Ich habe jetzt mal tiefer reingeschaut, das scheint an der API zu liegen, weil die die Sonderzeichen sendet:
          "gps": {
                "satellites": 12,
                "latitude": "48�24.1068 N",
                "longitude": "10�8.9852 E"
          "successful": true
    Ich hab mal im Robonect-Forum ein Bugreport angemeldet
    I Offline
    I Offline
    ioBrokerMike
    #455
    Moin
    Ich bekomme immer wieder vom Robonect HX Modul 1.4.2 Fehlermeldungen die aber die Funktion nicht beeinträchtigen, nur der Reiter Protokolle im IOBroker füllt sich.
    robonect.0
    2025-07-11 10:19:02.681	debug	currentStatus: 2
    robonect.0
    2025-07-11 10:19:02.681	debug	isRestTime: false
    robonect.0
    2025-07-11 10:19:02.681	debug	pollType: Status
    robonect.0
    2025-07-11 10:19:02.680	warn	Error returned from Robonect device: {"message":"connect ETIMEDOUT 192.168.178.20:80","name":"Error","stack":"Error: connect ETIMEDOUT 192.168.178.20:80\n at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:92:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:620:25)\n at RedirectableRequest.emit (node:events:524:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)\n at ClientRequest.emit (node:events:536:35)\n at ClientRequest.emit (node:domain:489:12)\n at emitErrorEvent (node:_http_client:101:11)\n at Socket.socketErrorListener (node:_http_client:504:5)\n at Socket.emit (node:events:524:28)\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n at processTicksAndRejections (node:internal/process/task_queues:95:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/1.10.0","Accept-Encoding":"gzip, compress, deflate, br"},"auth":{"username":"xxxxx","password":"yyyyy"},"params":{"cmd":"status"},"method":"get","url":"http://192.168.178.20/api/json","allowAbsoluteUrls":true},"code":"ETIMEDOUT"}
    robonect.0
    2025-07-11 10:19:02.680	error	connect ETIMEDOUT 192.168.178.20:80
    robonect.0
    2025-07-11 10:19:02.680	debug	Data received for error handling: {"message":"connect ETIMEDOUT 192.168.178.20:80","name":"Error","stack":"Error: connect ETIMEDOUT 192.168.178.20:80\n at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:92:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:620:25)\n at RedirectableRequest.emit (node:events:524:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)\n at ClientRequest.emit (node:events:536:35)\n at ClientRequest.emit (node:domain:489:12)\n at emitErrorEvent (node:_http_client:101:11)\n at Socket.socketErrorListener (node:_http_client:504:5)\n at Socket.emit (node:events:524:28)\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n at processTicksAndRejections (node:internal/process/task_queues:95:5)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/1.10.0","Accept-Encoding":"gzip, compress, deflate, br"},"auth":{"username":"xxxxx","password":"yyyyy"},"params":{"cmd":"status"},"method":"get","url":"http://192.168.178.20/api/json","allowAbsoluteUrls":true},"code":"ETIMEDOUT"}
    robonect.0
    2025-07-11 10:18:23.383	debug	Polling API for data [{"cmd":"status"}] started
    Habe ein Update der Application von 1.3b auf 1.5 gemacht.
    Bei beiden Version war es dasselbe.
    Mfg
    IOBrokerMike
    Achtung ! Sehkraft 25% | 60% , kein scherz
    Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
    BoronsbruderB 1 Antwort Letzte Antwort
    • I ioBrokerMike
      Moin
      robonect.0
      robonect.0
      robonect.0
      robonect.0
      robonect.0
      robonect.0
      robonect.0
      BoronsbruderB Online
      Boronsbruder
      #456
      @iobrokermike
      Hast du den Robonect-Adapter auf "DEBUG" laufen?
      Bei mir kommen nur hin und wieder mal Warnungen, dass kein Ping möglich war:
      2025-07-11 07:29:26.818 - warn: robonect.0 (1998307) No connection to lawn mower (Not able to ping it). Check network connection.
      I 1 Antwort Letzte Antwort
        @iobrokermike
        I Offline
        I Offline
        ioBrokerMike
        schrieb am zuletzt editiert von ioBrokerMike
        #457
        @boronsbruder
        Moin
        Entschuldige erst ein mal.
        Dieser Beitrag sollte an @braindead gehen.
        ... Hast du den Robonect-Adapter auf "DEBUG" laufen?
        Nur während der Ursachenfindung, ansonsten auf Error.
        PS. Habe den WLAN Teil vom Rebonect HX auch nochmal von 1.7.5 auf 1.7.6 Upgedatet.
        Mal sehen was Montag geschied wenn der Robi wieder ran muss.
        Mfg
        IOBrokerMike
        • mcm1957M Offline
          mcm1957M Offline
          mcm1957
          #458
          @iobrokermike said in Neuer Robonect HX Adapter:
          Das wird eher aussichtslos :-). Er war zuletzt 2022 hier online...
          https://forum.iobroker.net/user/braindead
          Du wirst wohl den Support der User hier oder von @grizzlebee, der den Adapter übernommen hat (https://github.com/Grizzelbee/ioBroker.robonect) annehmen müssen.
          In jedem Fall wäre es auch sinnvoll, wenn du die im Einsatz befindliche ADAPTER Version angibst
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          LatziL 1 Antwort Letzte Antwort
          • mcm1957M mcm1957
            LatziL Online
            LatziL Online
            Latzi
            #459
            @mcm1957 sagte in Neuer Robonect HX Adapter:
            @grizzlebee
            du meintest wohl @Grizzelbee ;-)
            • LatziL Latzi
              @grizzlebee
              mcm1957M Offline
              mcm1957M Offline
              mcm1957
              #460
              @latzi said in Neuer Robonect HX Adapter:
              @grizzlebee
              Ja
              Ich wars nicht - meine Tastatur hat den Fehler gemacht :-)
              • mcm1957M mcm1957
                @grizzlebee
                Ja
                I Offline
                I Offline
                ioBrokerMike
                #461
                @mcm1957
                Vielen Danke für die Info
                Auch damit habe ich kein Problem.
                Es ist super das Grizzelbee sich den Adapter an nimmt.
                Mfg
                IOBrokerMike
                • I Offline
                  I Offline
                  ioBrokerMike
                  #462
                  @grizzlebee
                  Moin
                  Kannst du dir mal mein Beitrag (https://forum.iobroker.net/topic/11834/neuer-robonect-hx-adapter/455?_=1755705519869) an sehen.
                  Mfg
                  IOBrokerMike
                  • I ioBrokerMike
                    @grizzlebee
                    Moin
                    Boronsbruder
                    schrieb am zuletzt editiert von Boronsbruder
                    #463
                    @iobrokermike
                    kannst du mal die Einstellungen deiner Instanz posten?
                    Ich habe zum Beispiel
                    aktiviert.
                    Evtl. verhindert das Timeouts?
                    Achja, führt bei mir aber immer mal wieder zu
                    	warn	No connection to lawn mower (Not able to ping it). Check network connection.
                    Einträgen, was aber wahrscheinlich an meinem Setup mit einer WLAN-Brücke liegt
                    I V 2 Antworten Letzte Antwort
                      @iobrokermike
                      aktiviert.
                      I Offline
                      I Offline
                      ioBrokerMike
                      #464
                      @boronsbruder sagte in Neuer Robonect HX Adapter:
                      Bitte sehr.
                      Werde mal den Ping reinnehmen.
                      Mfg
                      IOBrokerMike
                      • I ioBrokerMike
                        Bitte sehr.
                        Boronsbruder
                        #465
                        @iobrokermike
                        Hmm, ich seh da auch nichts, was die Timeouts auslösen könnte...
                          @iobrokermike
                          I Offline
                          I Offline
                          ioBrokerMike
                          #466
                          @boronsbruder
                          Was ich noch habe, wäre :
                          a7aaa37a-e551-416c-b283-c0d0abc99b54-image.png von dieser Woche.
                          Mfg
                          IOBrokerMike
                            @iobrokermike
                            aktiviert.
                            V Offline
                            V Offline
                            valbuz
                            #467
                            Diese Einträge habe ich auch....😑
                            2xProxmox auf NUC
                            E3DC 13kWh Speicher via RCSP an ioBroker
