  4. Shelly Adapter - genereller Support
    6.7k
mcm1957shelly
525 Beiträge 72 Kommentatoren 73.7k Aufrufe 53 Beobachtet
  • W wotan2005
    2025-08-14 07:09:31.312 - info: mqtt.0 (1516) Client [shellyplus1-ventil-02] connection closed: closed
    2025-08-14 07:09:36.274 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
    2025-08-14 07:09:36.274 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
    2025-08-14 07:09:36.292 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
    2025-08-14 07:09:40.424 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
    2025-08-14 07:09:40.424 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
    2025-08-14 07:09:40.442 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
    2025-08-14 07:09:57.750 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
    2025-08-14 07:09:57.750 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
    2025-08-14 07:09:57.769 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
    2025-08-14 07:10:56.123 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
    2025-08-14 07:10:56.123 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
    2025-08-14 07:10:56.141 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
    2025-08-14 07:11:55.734 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
    2025-08-14 07:11:55.734 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
    2025-08-14 07:11:55.752 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
    2025-08-14 07:12:51.245 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
    2025-08-14 07:12:51.246 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
    2025-08-14 07:12:51.264 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
    Da habe ich nichts daran geändert, deshalb verstehe ich es ja auch nicht.
    micklafisch
    #66
    @wotan2005
    im Shelly Webinterface unter "use custom prefix" bei MQTT auch nichts geändert? Das Ding kommt mit einem anderen Namen, das Log ist ja eindeutig.
    Ansonsten restet das Ding 1x und fang von vorne an. Parallel den Shelly Adapter und wie im Nachbarthread den MQTT Adapter sollte auch nicht gemacht werden.
    • W wotan2005
      Samson71S Offline
      Samson71S Offline
      Samson71
      #67
      @wotan2005 sagte in Shelly Adapter - genereller Support:
      Dann zeig die Einstellungen vom Shelly.
      Der heißt bestimmt nicht von vornherein so
      Markus
      Bitte beachten:
      • W wotan2005
        micklafisch
        #68
        @wotan2005
        uns hier die im Log angesprochene Doku (sollte eindeutig sein):
        • W Offline
          W Offline
          wotan2005
          #69
          Die Client-ID ist immer die MAC, richtig? -> "shellplus1-30c9224dxxxx"
          Aber den Part habe ich bei all meinen Shelly's bis jetzt geändert, immer ohne Probleme.
          Samson71S mcm1957M 2 Antworten Letzte Antwort
          • W wotan2005
            Samson71S Offline
            Samson71S Offline
            Samson71
            #70
            Dann nutzt Du aber nicht den Shelly-Adapter. Lt. Protokoll ist der aber (auch) im Einsatz.
            Deswegen auch der Hinweis:
            @micklafisch sagte in Shelly Adapter - genereller Support:
            Markus
            Bitte beachten:
            • W Offline
              W Offline
              wotan2005
              #71
              Okay, verstanden.
              Den Fehler habe ich jetzt auch gefixt, da war einfach ein "-" für den Shelly-Adapter zuviel drin, das möchte er nicht.
              • W wotan2005
                mcm1957M Online
                mcm1957M Online
                mcm1957
                #72
                @wotan2005 said in Shelly Adapter - genereller Support:
                In der Doku steht eindeutig dass die CLIENT-ID nicht geändert werden darf.
                Wenn du das trotzdem tust, dann rechne bitte mit beliebigen Problemen und minimalem bis keinem Support.
                Der Adapter verwendet die ClientId zur Identifikation des Devicetyps und zur eindeutigen Identifikation des Devices.
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • W Offline
                  W Offline
                  wotan2005
                  #73
                  Na dann werde ich die wohl alle wieder ändern müssen.
                  • W wotan2005
                    micklafisch
                    #74
                    @wotan2005
                    wenn dir die Bezeichnung der Client-IDs zu kryptisch ist, verwende einfach Aliase. Das macht dann auch den Austausch einfacher wenn mal ein Gerät hopps geht.
                    • W Offline
                      W Offline
                      wotan2005
                      #75
                      Wenn ich den jetzt aus der ferne auf Werkseinstellung setzte, muss ich mich wieder an dem Shelly WLan anmelden um den einzustellen, richtig?
                      M mcm1957M 2 Antworten Letzte Antwort
                      • W wotan2005
                        micklafisch
                        #76
                        @wotan2005
                        korrekt
                        • W wotan2005
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #77
                          @wotan2005
                          Mach das vor Ort - Reset auf Werkseinstellungen löscht ziemlich sicher auch das WLAN. Und damit ist der Shelly aus der Ferne nicht erreichbar ...
                          • W Offline
                            W Offline
                            wotan2005
                            #78
                            @micklafisch & @mcm1957 & @Samson71
                            Danke euch drei.
                              @horst-böttcher sagte in einiege shellys nicht da:
                              firmwareUpdate] Auto-Update enabled
                              Haben die eventuell ne neu Firmware bekommen, hast du die mal neu gestartet?
                              Horst BöttcherH Offline
                              Horst Böttcher
                              #79
                              @crunchip ja genau das war der fehler danke jetzt geht wieder alles
                              ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                              • W wotan2005
                                Ja und Nein, ich habe ja auch ein Shelly 1PM Gen4, mit dem ich das schon mal vorbereiten könnte. Im Nachgang den Datenpunkt ändern, ist glaube ich das geringste.
                                Doch fehlt mir für das Blockly jeglicher Ansatzpunkt, wie ich das angehen kann und lösen kan.
                                Deshalb ja hier miene Frage zu der Hilfstellung.
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #80
                                @wotan2005 sorry, ich frag mich immer wieder, warum man sich das leben schwer macht.
                                warum nicht den shelly-adapter und smart-control adapter?
                                • Horst BöttcherH Horst Böttcher
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #81
                                  @crunchip
                                  Das Firmware Update kanns nicht gewesen sein.
                                  Der Shelly startet danach selber automatisch.
                                  Anpingen ging ja anscheinend auch.
                                  Da wird wieder irgendwas im Hintergrund , nebenbei, gemacht worden sein, was nicht wir nicht wissen.
                                  • W Offline
                                    W Offline
                                    wotan2005
                                    #82
                                    weil über die shelly-App bespielsweise keine Voltmeter vom Shelly Plus Uni angezeigt werden, diese bekommt man leider nur über mqtt.
                                    • haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #83
                                      @wotan2005
                                      Welche Version des Shelly Adapters hast Du installiert?
                                      @mcm1957
                                      Auf Github hast Du für dieses Problem ein Isssue eröffnet. Wie ist der Stand heute?
                                      • W Offline
                                        W Offline
                                        wotan2005
                                        #84
                                        @haselchen
                                        Shelly App 10.1.0
                                        • W wotan2005
                                          @haselchen
                                          Shelly App 10.1.0
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #85
                                          @wotan2005
                                          Adapter NICHT App
                                          Und da haste den Shelly schonmal drin gehabt, im Adapter mit MQTT?
                                          @haus-automatisierung
