  4. nodejs 22.18 update
    6.6k
nodejs 22.18 update
21 Beiträge 5 Kommentatoren 2.3k Aufrufe 6 Beobachtet
  • Thomas BraunT Online
    @mico
    nodejs ist richtig installiert.
    Da belügt dich mal wieder eine graphische Oberfläche.
    Starte die Kiste mal sauber durch (NIE einfach den Strom kappen!)
    iob stop
    sudo reboot
    • M Mico
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: raspberrypi5
             Icon name: computer
                Kernel: Linux 6.12.34+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       07:30:50 up 41 min,  4 users,  load average: 0.50, 0.52, 0.58
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      ~ Throttling has occurred
      ~ Soft temperature limit has occurred
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-08-12 07:30:50 CEST
                 Universal time: Tue 2025-08-12 05:30:50 UTC
                       RTC time: Tue 2025-08-12 05:30:50
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         true
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:                tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.5G        3.6G        3.2G         28M        1.8G        4.9G
      Swap:           209M          0B        209M
      Total:          8.7G        3.6G        3.4G
      Active iob-Instances:   37
               8063 M total memory
               3405 M used memory
               3673 M active memory
                872 M inactive memory
               3013 M free memory
                140 M buffer memory
               1618 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 07:30:51 up 41 min,  4 users,  load average: 0.50, 0.52, 0.58
      Tasks: 265 total,   1 running, 264 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8063.2 total,   3013.8 free,   3405.7 used,   1758.9 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4657.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     1.6G  6.0M  1.6G   1% /run
      /dev/mmcblk0p2 ext4       58G   41G   15G  75% /
      tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
      tmpfs          tmpfs     807M  192K  807M   1% /run/user/1000
      [Tue Aug 12 06:49:30 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:32:68:16 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=a84847a9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Tue Aug 12 06:49:32 2025] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
      [Tue Aug 12 06:49:33 2025] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w.
      Show mounted filesystems:
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/mmcblk0p2 ext4        rw,noatime
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      30G     /var/
      28G     /var/lib/influxdb/engine/data/2d344d64e0714233/autogen
      Archived and active journals take up 1.5G in the file system.
      /opt/iobroker/backups:
      84M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      536M    /opt/iobroker/iobroker-data/files
      377M    /opt/iobroker/iobroker-data/history
      165M    /opt/iobroker/iobroker-data/files/vis-2
      122M    /opt/iobroker/iobroker-data/backup-objects
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      32M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03218114-if00-port0
      *** ZigBee Settings ***
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.4
      /usr/bin/node           v20.19.4
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.32.0
      nodejs:
        Installed: 20.19.4-1nodesource1
        Candidate: 20.19.4-1nodesource1
        Version table:
       *** 20.19.4-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.19.3-1nodesource1 600
           20.19.2-1nodesource1 600
           20.19.1-1nodesource1 600
           20.19.0-1nodesource1 600
           20.18.3-1nodesource1 600
           20.18.2-1nodesource1 600
           20.18.1-1nodesource1 600
           20.18.0-1nodesource1 600
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi2        raspberrypi2 (version: 7.0.6, hostname: raspberrypi2  , alive, uptime: 1499)
      raspberrypi5        raspberrypi5 (version: 7.0.6, hostname: raspberrypi5  , alive, uptime: 1337)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     2
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi5                             -  enabled
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi5                             - disabled
      + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : raspberrypi5                             -  enabled
        system.adapter.devices.0                : devices               : raspberrypi5                             - disabled
      + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
      + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi5                             -  enabled
      + system.adapter.geofency.0               : geofency              : raspberrypi5                             -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.growatt.0                : growatt               : raspberrypi5                             -  enabled
        system.adapter.habpanel.0               : habpanel              : raspberrypi5                             - disabled
      + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
        system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi5                             - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi5                             - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi5                             - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi5                             -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi5                             -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi2                             -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : raspberrypi5                             -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.openweathermap.0         : openweathermap        : raspberrypi5                             -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi5                             -  enabled
      + system.adapter.reolink.0                : reolink               : raspberrypi5                             -  enabled
      + system.adapter.reolink.1                : reolink               : raspberrypi5                             -  enabled
      + system.adapter.samsung.0                : samsung               : raspberrypi5                             -  enabled
      + system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi5                             -  enabled, port: 8002
      + system.adapter.scenes.0                 : scenes                : raspberrypi5                             -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smartthings.0            : smartthings           : raspberrypi5                             -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi2                             -  enabled, port: 1889, bind: 0.0.0.0
      + system.adapter.statistics.0             : statistics            : raspberrypi5                             -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi5                             -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi5                             -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi5                             - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi5                             - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi5                             - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi5                             - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : raspberrypi5                             -  enabled
        system.adapter.yr.0                     : yr                    : raspberrypi5                             -  enabled
      + system.adapter.zigbee2mqtt.1            : zigbee2mqtt           : raspberrypi5                             -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "growatt"      : 3.3.1    , installed 3.3.1
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
      Objects and States
      Objects:        14179
      States:         11326
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:8 https://repo.mosquitto.org/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7316       833/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       31261      5766/iobroker.js-co
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       31266      5766/iobroker.js-co
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7356       816/cupsd
      tcp        0      0 127.0.0.1:34259         0.0.0.0:*               LISTEN      1001       48557      6489/io.yahka.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       33315      5935/node-red
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       34419      6192/io.shelly.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      113        6655       824/mosquitto
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       31683      6134/io.mqtt.1
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       31682      6134/io.mqtt.1
      tcp        0      0 0.0.0.0:35415           0.0.0.0:*               LISTEN      1001       35072      6489/io.yahka.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          7318       833/sshd: /usr/sbin
      tcp6       0      0 :::1884                 :::*                    LISTEN      113        6656       824/mosquitto
      tcp6       0      0 :::3000                 :::*                    LISTEN      112        10091      2066/grafana
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7355       816/cupsd
      tcp6       0      0 :::7999                 :::*                    LISTEN      1001       31620      6071/io.geofency.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31325      5791/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       35963      6474/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        12414      1205/influxd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        8808       651/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33525      6211/io.shelly.1
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32652      6226/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32653      6226/io.tuya.0
      udp        0      0 0.0.0.0:45274           0.0.0.0:*                           104        8810       651/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        8809       651/avahi-daemon: r
      udp6       0      0 :::56697                :::*                                104        8811       651/avahi-daemon: r
      udp6       0      0 fe80::201f:2fec:9bc:546 :::*                                0          10508      772/NetworkManager
      2025-08-12 07:31:03.771  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:04.774  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:05.775  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:06.775  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:07.776  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:08.777  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:09.779  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:10.781  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:11.784  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:12.786  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:13.788  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:14.319  - warn: shelly.0 (6192) [Mqtt.statusNotifications] 192.168.178.118 (shellyplus1pm / shellyplus1pm-cc7b5c820c00 / shellyplus1pm#cc7b5c820c00#1): "General Status Notifications" are disabled (see adapter documentation for details)
      2025-08-12 07:31:14.789  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:15.791  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:16.793  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:17.794  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:18.796  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:19.797  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:20.798  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:21.800  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:22.801  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:23.803  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:24.804  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:25.806  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      2025-08-12 07:31:26.807  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
      iob diag has finished.
      @mico
      Und schalt den Desktop-Quark aus. Der belügt dich ja ohnehin nur.
      Server immer ohne solchen Overhead.
        @mico
        Mico
        Was soll ich da genau abschalten die Übersicht?
        • M Mico
          @mico
          Geht u.a. per
          iob fix
          Da wirste gefragt, ob die graphische Oberfläche ausgeschaltet werden soll.
            @mico
            Geht u.a. per
            iob fix
            Mico
            OK das ist aber nicht dann der Browser über denn ich immer zum Iobroker gelange per PC
            Thomas BraunT M 2 Antworten Letzte Antwort
            • M Mico
              @mico
              Eine Weboberfläche hat nichts mit dem Desktop zu tun.
              Den ioBroker-Admin erreichst du natürlich weiter über den Browser.
              • M Mico
                Mico
                schrieb am zuletzt editiert von Mico
                aber er zeigt mir trotzdem bei Übersicht diesen Stand an.
                Mico
                • M Mico
                  Mico
                  @mico
                  Haste die Seite mal neugeladen?
                  Wie gesagt, GUIs sind notorische Lügner.
                    @mico
                    @thomas-braun sagte in nodejs 22.18 update:
                    @Mico
                    = Browsercache geleert/mit incognitoTab geöffnet
                      @Mico
                      wendy2702W Online
                      wendy2702W Online
                      @homoran @Thomas-Braun Vielleicht übersehe ich es am Habdy aber das was ihm der Browser anzeigt als installierte Version ist doch laut iob diag auch installiert und er würde gerne auf NodeJS 22.x
                      Ist der „runde Pfeil“ nicht nur ein refresh Button?
                      • wendy2702W wendy2702
                        @wendy2702
                        Deswegen vermute ich, das nur die Seite mal neugeladen werden muss.
                          @wendy2702
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          Hmm - vielleicht verwechsel ich was.
                          Aber der Update Button im UI aktualisisert doch nur innerhalb einer node Release.
                          Zum Update 20 -> 22 muss man doch 'iob node-update' auf der Coammndline aufrufen.
                          Oder?
                          Support Repositoryverwaltung.
                          LESEN - gute Forenbeitrage
                          • mcm1957M mcm1957
                            Oder?
                            @mcm1957 @wendy2702
                            OMG, ihr habt natürlich beide Recht...
                            Hab die 20 total überlesen...
                            @Mico
                            Ein Upgrade auf einen anderen Zweig macht man per
                            iob nodejs-update
                              @mcm1957 @wendy2702
                              @Mico
                              iob nodejs-update
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              Ich hab jetzt mal ein Issue erstellt (https://github.com/ioBroker/ioBroker.admin/issues/3152) damit admin da verbessert wird. Wenn du da Ideen zu einer Umsetzung oder sonstige Anmerkungen hast - nur rein damit.
