  4. nodejs 22.18 update
    6.6k
nodejs 22.18 update
21 Beiträge 5 Kommentatoren 2.3k Aufrufe 6 Beobachtet
  • M Mico
    @thomas-braun ich drücke immer diesen kreis neben dem nodejs der im uhrzeigersinn angezeigt wird.
    @mico
    Gib mal die Ausgabe von
    iob diag
    zum Besten.
      Mico
      Ist das beim Protokoll oder wo finde ich das
      • M Mico
        @mico
        In deinem Terminal...
        Da klickt nix, nur die Tastatur.
          @mico
          Mico
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
           Static hostname: raspberrypi5
                 Icon name: computer
                    Kernel: Linux 6.12.34+rpt-rpi-2712
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           07:30:50 up 41 min,  4 users,  load average: 0.50, 0.52, 0.58
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          ~ Arm frequency capping has occurred
          ~ Throttling has occurred
          ~ Soft temperature limit has occurred
          *** TIME AND TIMEZONES ***
                         Local time: Tue 2025-08-12 07:30:50 CEST
                     Universal time: Tue 2025-08-12 05:30:50 UTC
                           RTC time: Tue 2025-08-12 05:30:50
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          *** DISPLAY-SERVER SETUP ***
          Display-Server:         true
          Display-Manager:        * lightdm.service - Light Display Manager
          Desktop:
          Session:                tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:            8.5G        3.6G        3.2G         28M        1.8G        4.9G
          Swap:           209M          0B        209M
          Total:          8.7G        3.6G        3.4G
          Active iob-Instances:   37
                   8063 M total memory
                   3405 M used memory
                   3673 M active memory
                    872 M inactive memory
                   3013 M free memory
                    140 M buffer memory
                   1618 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 07:30:51 up 41 min,  4 users,  load average: 0.50, 0.52, 0.58
          Tasks: 265 total,   1 running, 264 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8063.2 total,   3013.8 free,   3405.7 used,   1758.9 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4657.5 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs          tmpfs     1.6G  6.0M  1.6G   1% /run
          /dev/mmcblk0p2 ext4       58G   41G   15G  75% /
          tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
          tmpfs          tmpfs     807M  192K  807M   1% /run/user/1000
          [Tue Aug 12 06:49:30 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:32:68:16 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=a84847a9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Tue Aug 12 06:49:32 2025] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
          [Tue Aug 12 06:49:33 2025] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w.
          Show mounted filesystems:
          TARGET               SOURCE         FSTYPE      OPTIONS
          /                    /dev/mmcblk0p2 ext4        rw,noatime
          |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          30G     /var/
          28G     /var/lib/influxdb/engine/data/2d344d64e0714233/autogen
          Archived and active journals take up 1.5G in the file system.
          /opt/iobroker/backups:
          84M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          536M    /opt/iobroker/iobroker-data/files
          377M    /opt/iobroker/iobroker-data/history
          165M    /opt/iobroker/iobroker-data/files/vis-2
          122M    /opt/iobroker/iobroker-data/backup-objects
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          32M     /opt/iobroker/iobroker-data/objects.jsonl
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03218114-if00-port0
          *** ZigBee Settings ***
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.19.4
          /usr/bin/node           v20.19.4
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.32.0
          nodejs:
            Installed: 20.19.4-1nodesource1
            Candidate: 20.19.4-1nodesource1
            Version table:
           *** 20.19.4-1nodesource1 600
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
               20.19.3-1nodesource1 600
               20.19.2-1nodesource1 600
               20.19.1-1nodesource1 600
               20.19.0-1nodesource1 600
               20.18.3-1nodesource1 600
               20.18.2-1nodesource1 600
               20.18.1-1nodesource1 600
               20.18.0-1nodesource1 600
               20.17.0-1nodesource1 600
               20.16.0-1nodesource1 600
               20.15.1-1nodesource1 600
               20.15.0-1nodesource1 600
               20.14.0-1nodesource1 600
               20.13.1-1nodesource1 600
               20.13.0-1nodesource1 600
               20.12.2-1nodesource1 600
               20.12.1-1nodesource1 600
               20.12.0-1nodesource1 600
               20.11.1-1nodesource1 600
               20.11.0-1nodesource1 600
               20.10.0-1nodesource1 600
               20.9.0-1nodesource1 600
               20.8.1-1nodesource1 600
               20.8.0-1nodesource1 600
               20.7.0-1nodesource1 600
               20.6.1-1nodesource1 600
               20.6.0-1nodesource1 600
               20.5.1-1nodesource1 600
               20.5.0-1nodesource1 600
               20.4.0-1nodesource1 600
               20.3.1-1nodesource1 600
               20.3.0-1nodesource1 600
               20.2.0-1nodesource1 600
               20.1.0-1nodesource1 600
               20.0.0-1nodesource1 600
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main arm64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          raspberrypi2        raspberrypi2 (version: 7.0.6, hostname: raspberrypi2  , alive, uptime: 1499)
          raspberrypi5        raspberrypi5 (version: 7.0.6, hostname: raspberrypi5  , alive, uptime: 1337)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.6.17
          javascript:     8.9.2
          nodejs modules from github:     2
          | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
          +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi5                             -  enabled
            system.adapter.alias-manager.0          : alias-manager         : raspberrypi5                             - disabled
          + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : raspberrypi5                             -  enabled
            system.adapter.devices.0                : devices               : raspberrypi5                             - disabled
          + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
          + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi5                             -  enabled
          + system.adapter.geofency.0               : geofency              : raspberrypi5                             -  enabled, port: 7999, bind: 0.0.0.0
          + system.adapter.growatt.0                : growatt               : raspberrypi5                             -  enabled
            system.adapter.habpanel.0               : habpanel              : raspberrypi5                             - disabled
          + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
            system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
            system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi5                             - disabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi5                             - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi5                             - disabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi5                             -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
          + system.adapter.meross.0                 : meross                : raspberrypi5                             -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi2                             -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.node-red.0               : node-red              : raspberrypi5                             -  enabled, port: 1880, bind: 0.0.0.0
            system.adapter.openweathermap.0         : openweathermap        : raspberrypi5                             -  enabled
          + system.adapter.pushover.0               : pushover              : raspberrypi5                             -  enabled
          + system.adapter.reolink.0                : reolink               : raspberrypi5                             -  enabled
          + system.adapter.reolink.1                : reolink               : raspberrypi5                             -  enabled
          + system.adapter.samsung.0                : samsung               : raspberrypi5                             -  enabled
          + system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi5                             -  enabled, port: 8002
          + system.adapter.scenes.0                 : scenes                : raspberrypi5                             -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.smartthings.0            : smartthings           : raspberrypi5                             -  enabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi2                             -  enabled, port: 1889, bind: 0.0.0.0
          + system.adapter.statistics.0             : statistics            : raspberrypi5                             -  enabled
          + system.adapter.telegram.0               : telegram              : raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : raspberrypi5                             -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi5                             -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi5                             - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi5                             - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi5                             - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi5                             - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.yahka.0                  : yahka                 : raspberrypi5                             -  enabled
            system.adapter.yr.0                     : yr                    : raspberrypi5                             -  enabled
          + system.adapter.zigbee2mqtt.1            : zigbee2mqtt           : raspberrypi5                             -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.6.17   , installed 7.6.17
          Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 3.3.5    , installed 3.3.5
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "devices"      : 1.1.5    , installed 1.1.5
          Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
          Adapter    "geofency"     : 1.2.4    , installed 1.2.4
          Adapter    "growatt"      : 3.3.1    , installed 3.3.1
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "ical"         : 1.16.2   , installed 1.16.2
          Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.9.2    , installed 8.9.2
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "reolink"      : 1.2.3    , installed 1.2.3
          Adapter    "samsung"      : 0.6.1    , installed 0.6.1
          Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shelly"       : 10.1.0   , installed 10.1.0
          Adapter    "socketio"     : 6.7.1    , installed 7.0.8
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
          Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "ws"           : 2.6.2    , installed 3.0.19
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
          Objects and States
          Objects:        14179
          States:         11326
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:8 https://repo.mosquitto.org/debian bookworm InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7316       833/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       31261      5766/iobroker.js-co
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       31266      5766/iobroker.js-co
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7356       816/cupsd
          tcp        0      0 127.0.0.1:34259         0.0.0.0:*               LISTEN      1001       48557      6489/io.yahka.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       33315      5935/node-red
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       34419      6192/io.shelly.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      113        6655       824/mosquitto
          tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       31683      6134/io.mqtt.1
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       31682      6134/io.mqtt.1
          tcp        0      0 0.0.0.0:35415           0.0.0.0:*               LISTEN      1001       35072      6489/io.yahka.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          7318       833/sshd: /usr/sbin
          tcp6       0      0 :::1884                 :::*                    LISTEN      113        6656       824/mosquitto
          tcp6       0      0 :::3000                 :::*                    LISTEN      112        10091      2066/grafana
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7355       816/cupsd
          tcp6       0      0 :::7999                 :::*                    LISTEN      1001       31620      6071/io.geofency.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31325      5791/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       35963      6474/io.web.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        12414      1205/influxd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        8808       651/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33525      6211/io.shelly.1
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32652      6226/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32653      6226/io.tuya.0
          udp        0      0 0.0.0.0:45274           0.0.0.0:*                           104        8810       651/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        8809       651/avahi-daemon: r
          udp6       0      0 :::56697                :::*                                104        8811       651/avahi-daemon: r
          udp6       0      0 fe80::201f:2fec:9bc:546 :::*                                0          10508      772/NetworkManager
          2025-08-12 07:31:03.771  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:04.774  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:05.775  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:06.775  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:07.776  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:08.777  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:09.779  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:10.781  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:11.784  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:12.786  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:13.788  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:14.319  - warn: shelly.0 (6192) [Mqtt.statusNotifications] 192.168.178.118 (shellyplus1pm / shellyplus1pm-cc7b5c820c00 / shellyplus1pm#cc7b5c820c00#1): "General Status Notifications" are disabled (see adapter documentation for details)
          2025-08-12 07:31:14.789  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:15.791  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:16.793  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:17.794  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:18.796  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:19.797  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:20.798  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:21.800  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:22.801  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:23.803  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:24.804  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:25.806  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          2025-08-12 07:31:26.807  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
          iob diag has finished.
          • Thomas BraunT Online
            @mico
            nodejs ist richtig installiert.
            Da belügt dich mal wieder eine graphische Oberfläche.
            Starte die Kiste mal sauber durch (NIE einfach den Strom kappen!)
            iob stop
            sudo reboot
            • M Mico
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Session:                tty
              *** MEMORY ***
              Swap:           209M          0B        209M
                       8063 M total memory
                       3405 M used memory
                       3013 M free memory
                        140 M buffer memory
                       1618 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              *** FILESYSTEM ***
              /var:
              30G     /var/
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.6.17
              javascript:     8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        14179
              States:         11326
              Pending Updates: 0
              @mico
              Und schalt den Desktop-Quark aus. Der belügt dich ja ohnehin nur.
              Server immer ohne solchen Overhead.
                @mico
                Mico
                Was soll ich da genau abschalten die Übersicht?
                • M Mico
                  @mico
                  Geht u.a. per
                  iob fix
                  Da wirste gefragt, ob die graphische Oberfläche ausgeschaltet werden soll.
                    @mico
                    Geht u.a. per
                    iob fix
                    Mico
                    OK das ist aber nicht dann der Browser über denn ich immer zum Iobroker gelange per PC
                    Thomas BraunT M 2 Antworten Letzte Antwort
                    • M Mico
                      @mico
                      Eine Weboberfläche hat nichts mit dem Desktop zu tun.
                      Den ioBroker-Admin erreichst du natürlich weiter über den Browser.
                      • M Mico
                        Mico
                        schrieb am zuletzt editiert von Mico
                        aber er zeigt mir trotzdem bei Übersicht diesen Stand an.
                        Mico
                        • M Mico
                          Mico
                          @mico
                          Haste die Seite mal neugeladen?
                          Wie gesagt, GUIs sind notorische Lügner.
                            @mico
                            @thomas-braun sagte in nodejs 22.18 update:
                            @Mico
                            = Browsercache geleert/mit incognitoTab geöffnet
                              @Mico
                              wendy2702W Online
                              wendy2702W Online
                              @homoran @Thomas-Braun Vielleicht übersehe ich es am Habdy aber das was ihm der Browser anzeigt als installierte Version ist doch laut iob diag auch installiert und er würde gerne auf NodeJS 22.x
                              Ist der „runde Pfeil“ nicht nur ein refresh Button?
                              • wendy2702W wendy2702
                                @wendy2702
                                Deswegen vermute ich, das nur die Seite mal neugeladen werden muss.
                                  @wendy2702
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  Hmm - vielleicht verwechsel ich was.
                                  Aber der Update Button im UI aktualisisert doch nur innerhalb einer node Release.
                                  Zum Update 20 -> 22 muss man doch 'iob node-update' auf der Coammndline aufrufen.
                                  Oder?
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                  • mcm1957M mcm1957
                                    Oder?
                                    @mcm1957 @wendy2702
                                    OMG, ihr habt natürlich beide Recht...
                                    Hab die 20 total überlesen...
                                    @Mico
                                    Ein Upgrade auf einen anderen Zweig macht man per
                                    iob nodejs-update
                                      @mcm1957 @wendy2702
                                      @Mico
                                      iob nodejs-update
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      Ich hab jetzt mal ein Issue erstellt (https://github.com/ioBroker/ioBroker.admin/issues/3152) damit admin da verbessert wird. Wenn du da Ideen zu einer Umsetzung oder sonstige Anmerkungen hast - nur rein damit.
