  4. Kann den Rpi Adapter auf meinem Raspberry nicht installieren
    apollon77A
adaptergpiohilfeinstallationraspberry
48 Beiträge 9 Kommentatoren 5.4k Aufrufe 7 Beobachtet
  • Basti97B
    Basti97B
    Basti97
    schrieb am zuletzt editiert von Basti97
    Ich bin seid dem Mittag dran den Rpi 2 Adapter auf dem Raspberry zu installieren aber es kommt immer dieser Fehler:
    raspberrypi
    Plattform: linux
    RAM: 921.9 MB
    Node.js: v20.19.1(20.19.3) NPM: 10.8.2 JS 7.0.6
    Befehl ausführen
    ERROR: Process exited with code 25
    Weniger Protokolle
    Detailliert
    $ iobroker add rpi2 --host raspberrypi
    NPM version: 10.8.2
    Installing iobroker.rpi2@2.4.0... (System call)
    host.raspberrypi Cannot install iobroker.rpi2@2.4.0: 1
    Im Log steht noch
    host.raspberrypi
    	2025-07-15 23:05:47.461	error	iobroker npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error make: Entering directory '/opt/iobroker/node_modules/opengpio/build'npm error CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error SOLINK_MODULE(target) Release/obj.target/opengpio.nodenpm error make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'npm error /usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizednpm error collect2: error: ld returned 1 exit statusnpm error make: *** [opengpio.target.mk:133: Release/obj.target/opengpio.node] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)npm error gyp ERR! System Linux 6.1.21-v7+npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v20.19.1npm error gyp ERR! node-gyp -v v10.1.0npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T21_04_48_736Z-debug-0.log```
    Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
    • Basti97B Basti97
      raspberrypi
      Plattform: linux
      RAM: 921.9 MB
      Befehl ausführen
      Weniger Protokolle
      Detailliert
      NPM version: 10.8.2
      Im Log steht noch
      host.raspberrypi
      OliverIOO
      OliverIOO
      OliverIO
      @basti97 sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
      ich habe mal das log bei chatgpt reinkopiert.
      welchen raspi hast du?
      welches betriebssystem in welcher version mit wieviel bits (32 oder 64) ist installiert?
      hier das ergebnis von chatgpt
      erst mal bitte nur die fragen beantworten.
      den hinweis mit node18 LTS nicht beachten
      ich vermute, du hast 32bit linux installiert und opengpio gibt es nur noch in 64bit
      ich habe mal die schritte zur Lösungsbehebung entfernt, da da fast nur irrelevantes drin stand
      den inhalt der erwähnten datei kannst du mal selbst bei opengpt reinkopieren und hier die ergebnisse mitteilen.
      Der Fehler, den du bekommst, deutet darauf hin, dass beim Kompilieren des Node.js-Moduls opengpio ein Linker-Fehler auftritt:
      🧭 Ursache:
      Das bedeutet meistens:
      • Die Datei /usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o ist beschädigt oder inkompatibel.
      • Du hast möglicherweise ein Mixed-Architektur-Problem (z. B. 64-bit vs 32-bit).
      • Oder dein System ist inkonsistent nach einem Update oder manuellen Eingriff.
      Wenn du mir den Inhalt der Datei zeigst:
      … kann ich dir noch gezielter helfen.
      Meine Adapter und Widgets
      Links im Profil
      Basti97B 2 Antworten Letzte Antwort
      • Basti97B
        Basti97B
        Basti97
        @oliverio Ich habe den rpi3 laufen zuvor ist bereits der rpi2 Adapter gelaufen aber in einer älteren Version. Da ich aber iobroker nochmal neu installieren wollte und auch auf dem aktuellsten Stand. Habe ich iobroker komplett gelöscht und neu gemacht.
        Ja ich glaube das ist die 32 bit von mir aus wäre ich auch mit einer älteren Version von rpi2 Adapter zufrieden wenn es funktioniert.
        2025-07-16 00:17:18.106  - error: host.raspberrypi iobroker host.raspberrypi Cannot install https://www.npmjs.com/package/iobroker.rpi2/v/2.4.0: 1
        2025-07-16 00:17:19.164  - info: host.raspberrypi iobroker exit 25
        2025-07-16 00:18:21.579  - info: host.raspberrypi iobroker add rpi2 auto --host raspberrypi --debug
        2025-07-16 00:18:27.722  - info: host.raspberrypi iobroker NPM version: 10.8.2
        2025-07-16 00:18:27.726  - info: host.raspberrypi iobroker Installing iobroker.rpi2@2.4.0... (System call)
        2025-07-16 00:18:36.550  - info: host.raspberrypi iobroker
        2025-07-16 00:18:36.552  - info: host.raspberrypi iobroker > iobroker.rpi2@2.4.0 preinstall> sudo apt-get install -y libgpiod-dev || exit 0
        2025-07-16 00:18:36.810  - info: host.raspberrypi iobroker Reading package lists...
        2025-07-16 00:18:37.616  - info: host.raspberrypi iobroker Building dependency tree...
        2025-07-16 00:18:37.627  - info: host.raspberrypi iobroker Reading state information...
        2025-07-16 00:18:39.376  - info: host.raspberrypi iobroker libgpiod-dev is already the newest version (1.6.2-1+rpi1).
        2025-07-16 00:18:39.380  - info: host.raspberrypi iobroker 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        2025-07-16 00:18:39.393  - info: host.raspberrypi iobroker > diskusage@1.2.0 install
        2025-07-16 00:18:39.395  - info: host.raspberrypi iobroker > node-gyp rebuild
        2025-07-16 00:18:39.918  - info: host.raspberrypi iobroker gyp info it worked if it ends with ok
        2025-07-16 00:18:39.919  - info: host.raspberrypi iobroker gyp info using node-gyp@10.1.0
        2025-07-16 00:18:39.924  - info: host.raspberrypi iobroker gyp info using node@20.19.1 | linux | arm
        2025-07-16 00:18:40.381  - info: host.raspberrypi iobroker gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
        2025-07-16 00:18:41.067  - info: host.raspberrypi iobroker
        2025-07-16 00:18:41.104  - info: host.raspberrypi iobroker gyp info spawn /usr/bin/python3
        2025-07-16 00:18:41.121  - info: host.raspberrypi iobroker gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
        2025-07-16 00:18:41.123  - info: host.raspberrypi iobroker gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/diskusage/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/diskusage',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
        2025-07-16 00:18:42.237  - info: host.raspberrypi iobroker gyp info spawn make
        2025-07-16 00:18:42.239  - info: host.raspberrypi iobroker gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        2025-07-16 00:18:42.246  - info: host.raspberrypi iobroker make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
        2025-07-16 00:18:42.250  - info: host.raspberrypi iobroker   CXX(target) Release/obj.target/diskusage/src/main.o
        2025-07-16 00:18:42.321  - info: host.raspberrypi iobroker <command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefined<command-line>: note: this is the location of the previous definition
        2025-07-16 00:18:47.186  - info: host.raspberrypi iobroker In file included from ../../nan/nan.h:62,                 from ../src/main.cpp:3:
        2025-07-16 00:18:47.188  - info: host.raspberrypi iobroker /home/iobroker/.cache/node-gyp/20.19.1/include/node/node.h:1226:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type] 1226 |       (node::addon_register_func) (regfunc),                          \      |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.19.1/include/node/node.h:1260:3: note: in expansion of macro 'NODE_MODULE_X' 1260 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)      |   ^~~~~~~~~~~~~../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'   42 | NODE_MODULE(diskusage, Init)      | ^~~~~~~~~~~
        2025-07-16 00:18:48.510  - info: host.raspberrypi iobroker   CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
        2025-07-16 00:18:48.575  - info: host.raspberrypi iobroker <command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefined<command-line>: note: this is the location of the previous definition
        2025-07-16 00:19:03.005  - info: host.raspberrypi iobroker   SOLINK_MODULE(target) Release/obj.target/diskusage.node
        2025-07-16 00:19:04.665  - info: host.raspberrypi iobroker /usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognized
        2025-07-16 00:19:04.671  - info: host.raspberrypi iobroker collect2: error: ld returned 1 exit status
        2025-07-16 00:19:04.678  - info: host.raspberrypi iobroker make: *** [diskusage.target.mk:135: Release/obj.target/diskusage.node] Error 1make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
        2025-07-16 00:19:04.690  - info: host.raspberrypi iobroker gyp ERR! build error
        2025-07-16 00:19:04.693  - info: host.raspberrypi iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
        2025-07-16 00:19:04.699  - info: host.raspberrypi iobroker gyp ERR! System Linux 6.1.21-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/diskusagegyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok
        2025-07-16 00:19:06.817  - info: host.raspberrypi iobroker > node-dht-sensor@0.4.5 install> node-gyp configure
        2025-07-16 00:19:07.340  - info: host.raspberrypi iobroker gyp info it worked if it ends with ok
        2025-07-16 00:19:07.343  - info: host.raspberrypi iobroker gyp info using node-gyp@10.1.0
        2025-07-16 00:19:07.347  - info: host.raspberrypi iobroker gyp info using node@20.19.1 | linux | arm
        2025-07-16 00:19:07.787  - info: host.raspberrypi iobroker gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
        2025-07-16 00:19:08.434  - info: host.raspberrypi iobroker
        2025-07-16 00:19:12.169  - info: host.raspberrypi iobroker gyp info spawn /usr/bin/python3
        2025-07-16 00:19:12.190  - info: host.raspberrypi iobroker gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
        2025-07-16 00:19:12.192  - info: host.raspberrypi iobroker gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
        2025-07-16 00:19:13.816  - info: host.raspberrypi iobroker gyp info ok
        2025-07-16 00:19:13.833  - info: host.raspberrypi iobroker > opengpio@1.0.18 install> node-gyp rebuild
        2025-07-16 00:19:13.835  - info: host.raspberrypi iobroker
        2025-07-16 00:19:14.351  - info: host.raspberrypi iobroker gyp info it worked if it ends with ok
        2025-07-16 00:19:14.356  - info: host.raspberrypi iobroker gyp info using node-gyp@10.1.0
        2025-07-16 00:19:14.358  - info: host.raspberrypi iobroker gyp info using node@20.19.1 | linux | arm
        2025-07-16 00:19:14.846  - info: host.raspberrypi iobroker gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
        2025-07-16 00:19:15.489  - info: host.raspberrypi iobroker
        2025-07-16 00:19:15.524  - info: host.raspberrypi iobroker gyp info spawn /usr/bin/python3
        2025-07-16 00:19:15.539  - info: host.raspberrypi iobroker gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
        2025-07-16 00:19:15.542  - info: host.raspberrypi iobroker gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
        2025-07-16 00:19:16.670  - info: host.raspberrypi iobroker gyp info spawn make
        2025-07-16 00:19:16.678  - info: host.raspberrypi iobroker gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        2025-07-16 00:19:16.680  - info: host.raspberrypi iobroker make: Entering directory '/opt/iobroker/node_modules/opengpio/build'
        2025-07-16 00:19:16.687  - info: host.raspberrypi iobroker   CXX(target) Release/obj.target/opengpio/cpp/opengpio.o
        2025-07-16 00:19:31.635  - info: host.raspberrypi iobroker   SOLINK_MODULE(target) Release/obj.target/opengpio.node
        2025-07-16 00:19:31.659  - info: host.raspberrypi iobroker /usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognized
        2025-07-16 00:19:31.662  - info: host.raspberrypi iobroker collect2: error: ld returned 1 exit status
        2025-07-16 00:19:31.669  - info: host.raspberrypi iobroker make: *** [opengpio.target.mk:133: Release/obj.target/opengpio.node] Error 1make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'
        2025-07-16 00:19:31.678  - info: host.raspberrypi iobroker gyp ERR! build error
        2025-07-16 00:19:31.681  - info: host.raspberrypi iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.1.21-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        2025-07-16 00:19:31.687  - info: host.raspberrypi iobroker gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok
        2025-07-16 00:19:31.836  - info: host.raspberrypi iobroker npm error code 1
        2025-07-16 00:19:31.839  - info: host.raspberrypi iobroker npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuild
        2025-07-16 00:19:31.850  - info: host.raspberrypi iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T22_18_28_400Z-debug-0.log
        2025-07-16 00:19:31.890  - error: host.raspberrypi iobroker gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.19.1 | linux | armgyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/diskusage/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/diskusage',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]<command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefined<command-line>: note: this is the location of the previous definitionIn file included from ../../nan/nan.h:62,                 from ../src/main.cpp:3:/home/iobroker/.cache/node-gyp/20.19.1/include/node/node.h:1226:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type] 1226 |       (node::addon_register_func) (regfunc),                          \      |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.19.1/include/node/node.h:1260:3: note: in expansion of macro 'NODE_MODULE_X' 1260 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)      |   ^~~~~~~~~~~~~../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'   42 | NODE_MODULE(diskusage, Init)      | ^~~~~~~~~~~<command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefined<command-line>: note: this is the location of the previous definition/usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizedcollect2: error: ld returned 1 exit statusmake: *** [diskusage.target.mk:135: Release/obj.target/diskusage.node] Error 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.1.21-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/diskusagegyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.19.1 | linux | armgyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info ok gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.19.1 | linux | armgyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]/usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizedcollect2: error: ld returned 1 exit statusmake: *** [opengpio.target.mk:133: Release/obj.target/opengpio.node] Error 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.1.21-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T22_18_28_400Z-debug-0.log
        2025-07-16 00:19:31.893  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.rpi2@2.4.0: 1
        2025-07-16 00:19:32.961  - info: host.raspberrypi iobroker exit 25
        2025-07-16 00:22:15.158  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
        2025-07-16 00:22:17.669  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
        pi@raspberrypi:~ $
        ich habe das auch per npm probiert gleicher fehler
        • OliverIOO OliverIO
          🧭 Ursache:
          Basti97B
          Basti97B
          Basti97
          @oliverio andere Adapter kann ich installieren seid heute Nachmittag sitze ich dran ich werde morgen weiter machen. Der andere Raspberry läuft da habe ich aber auch nur geupdatet und nicht neu installiert.
            🧭 Ursache:
            Basti97B
            Basti97B
            Basti97
            @oliverio hier noch eine log
            • Basti97B Basti97
              pi@raspberrypi:~ $
              Thomas BraunT
              Thomas BraunT
              das ist die 32 bit
              Und warum hast du die Gelegenheit nicht genutzt und auch das OS 'neugemacht'? Mit 32Bit wirst du zunehmend Probleme bekommen, erste Pakete werden nur noch für 64Bit angeboten.
              (Mit 1GB RAM machste auch keinen Staat mehr).
              Basti97B 1 Antwort Letzte Antwort
                das ist die 32 bit
                Basti97B
                Basti97B
                Basti97
                @thomas-braun das stimmt es ist nur ein kleines Projekt mit dem rpi Adapter und ein paar LEDs mit 10 Ausgänge und ein paar Eingänge ca wo der Rpi nicht so viel arbeiten müsste. Es soll für mein Kind etwas zum spielen sein. Ich hatte das ganze mit Mqtt getestet der Adapter lässt sich installieren ohne Fehler.
                • Basti97B Basti97
                  Thomas BraunT
                  Thomas BraunT
                  mqtt ist aber nicht opengpio. Hat also keine Aussagekraft, das andere Adapter installierbar sind.
                    Basti97B
                    Basti97B
                    Basti97
                    @thomas-braun Naja ich dachte erst das es an der Netzwerkverbindung/ DNS Server liegt
                    • Basti97B Basti97
                      Thomas BraunT
                      Thomas BraunT
                      @basti97
                      Schau mal, ob du opengpio unabhängig vom ioBroker gebaut bekommst:
                      cd
                      npm ls
                      npm i opengpio@1.0.18
                      npm ls
                      Auf meiner Kiste baut opengpio@1.0.18 nicht, dafür aber die 2.0.2.
                      Aber die wiederum funktioniert mit dem rpi2-Adapter noch nicht. Deswegen bekomme ich den Adapter nicht ohne Patch installiert.
                      Mit Patch läuft dann auch die
                      echad@chet:~ $ iob version rpi2
                      2.4.0
                      echad@chet:~ $
                      • Basti97B Basti97
                        OliverIOO
                        OliverIOO
                        OliverIO
                        hier noch eine log
                        evtl hat sich das ja jetzt auch schon erledigt und nix für ungut
                        hm, sollte ich jetzt für dich den copy paste kasper machen?
                        kopiere es doch selbst bei chatgpt rein.
                        wenn dann ergebnisse kommen kann man die hier besprechen.
                        Links im Profil
                          @basti97
                          cd
                          npm ls
                          npm ls
                          2.4.0
                          echad@chet:~ $
                          Basti97B
                          Basti97B
                          Basti97
                          @thomas-braun Danke probiere ich mal aus ich dachte opengpio wird schon mit dem Befehl
                          sudo apt install -y build-essential python3-dev git automatisch mit installiert. Wo ich das ganze damals mal getestet hatte habe ich gedacht das ich nur den Adapter installiert habe und dann wäre es gegangen.
                          Nein leider nicht da kommt auch eine Fehlermeldung wenn ich opengpio installieren möchte
                          npm error code 1
                          npm error path /home/pi/node_modules/opengpio
                          npm error make: Entering directory '/home/pi/node_modules/opengpio/build'
                          npm error make: Leaving directory '/home/pi/node_modules/opengpio/build'
                          npm error gyp info it worked if it ends with ok
                          npm error gyp info using node-gyp@10.1.0
                          npm error gyp info using node@20.19.1 | linux | arm
                          npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                          npm error gyp http GET https://nodejs.org/download/release/v20.19.1/node-v20.19.1-headers.tar.gz
                          npm error gyp http 200 https://nodejs.org/download/release/v20.19.1/node-v20.19.1-headers.tar.gz
                          npm error gyp http GET https://nodejs.org/download/release/v20.19.1/SHASUMS256.txt
                          npm error gyp http 200 https://nodejs.org/download/release/v20.19.1/SHASUMS256.txt
                          npm error gyp info spawn /usr/bin/python3
                          npm error gyp info spawn args [
                          npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
                          npm error gyp info spawn args 'binding.gyp',
                          npm error gyp info spawn args '-f',
                          npm error gyp info spawn args 'make',
                          npm error gyp info spawn args '-I',
                          npm error gyp info spawn args '/home/pi/node_modules/opengpio/build/config.gypi',
                          npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
                          npm error gyp info spawn args '/home/pi/.cache/node-gyp/20.19.1/include/node/common.gypi',
                          npm error gyp info spawn args '-Dlibrary=shared_library',
                          npm error gyp info spawn args '-Dvisibility=default',
                          npm error gyp info spawn args '-Dnode_root_dir=/home/pi/.cache/node-gyp/20.19.1',
                          npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
                          npm error gyp info spawn args '-Dnode_lib_file=/home/pi/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',
                          npm error gyp info spawn args '-Dmodule_root_dir=/home/pi/node_modules/opengpio',
                          npm error gyp info spawn args '-Dnode_engine=v8',
                          npm error gyp info spawn args '--depth=.',
                          npm error gyp info spawn args '--no-parallel',
                          npm error gyp info spawn args '--generator-output',
                          npm error gyp info spawn args 'build',
                          npm error gyp info spawn args '-Goutput_dir=.'
                          npm error gyp info spawn args ]
                          npm error gyp info spawn make
                          npm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                          npm error gyp ERR! cwd /home/pi/node_modules/opengpio
                          npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-07-15T23_12_46_875Z-debug-0.log
                          /home/pi
                          └── (empty)
                          ich werde morgen probieren so ein misst :)
                            @basti97
                            cd
                            npm ls
                            npm ls
                            2.4.0
                            echad@chet:~ $
                            Basti97B
                            Basti97B
                            Basti97
                            @thomas-braun ist vielleicht nodejs zu neu?
                            OliverIOO Thomas BraunT 2 Antworten Letzte Antwort
                            • Basti97B Basti97
                              npm error code 1
                              /home/pi
                              └── (empty)
                              Thomas BraunT
                              Thomas BraunT
                              Nein, damit werden nur Pakete installiert, die zum bauen von Paketen benötigt werden.
                              opengpio wird dann durch die Kompiler gejagt
                              Nein, eher ist dein OS zu alt/auf der falschen Architektur. Du fährst doch da nodejs@20, das ist die momentane Empfehlung.
                              deutet auf 32Bit hin, das wird eher nicht mehr mit dem aktuellen Code durchlaufen.
                              • Basti97B Basti97
                                OliverIOO
                                OliverIOO
                                OliverIO
                                @basti97
                                an dieser stelle spielt node keine rolle.
                                das kompillieren und linken eines c/c++ programms (opengpio ) schlägt fehl.
                                immer noch der gleiche fehler
                                Links im Profil
                                • Basti97B Basti97
                                  Thomas BraunT
                                  Thomas BraunT
                                  @basti97
                                  Gib mal die Ausgabe von
                                  iob diag
                                  bekannt sowie von
                                  apt policy libgpiod*
                                    @basti97
                                    iob diag
                                    bekannt sowie von
                                    Basti97B
                                    Basti97B
                                    Basti97
                                    @thomas-braun sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
                                    iob diag
                                    ```bash
                                    Script v.2025-03-08
                                    *** BASE SYSTEM ***
                                       Static hostname: raspberrypi
                                             Icon name: computer
                                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 6.1.21-v7+
                                          Architecture: arm
                                    OS is similar to: debian
                                    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : armv7l
                                    Userland        : 32 bit
                                    Systemuptime and Load:
                                     09:46:33 up 14:44,  2 users,  load average: 3.28, 2.88, 2.27
                                    CPU threads: 4
                                    *** LIFE CYCLE STATUS ***
                                    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    ~ Under-voltage has occurred
                                    ~ Arm frequency capping has occurred
                                    *** TIME AND TIMEZONES ***
                                                   Local time: Wed 2025-07-16 09:46:33 CEST
                                               Universal time: Wed 2025-07-16 07:46:33 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** Users and Groups ***
                                    User that called 'iob diag':
                                    pi
                                    HOME=/home/pi
                                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    *** DISPLAY-SERVER SETUP ***
                                    Display-Server: false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            921M        216M        209M        1.0M        496M        634M
                                    Swap:            99M         78M         21M
                                    Total:          1.0G        295M        230M
                                    Active iob-Instances:   3
                                              921 M total memory
                                              216 M used memory
                                              407 M active memory
                                              210 M inactive memory
                                              209 M free memory
                                               70 M buffer memory
                                              425 M swap cache
                                               99 M total swap
                                               78 M used swap
                                               21 M free swap
                                    top - 09:46:34 up 14:44,  2 users,  load average: 3.28, 2.88, 2.27
                                    Tasks: 158 total,   1 running, 157 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  5.5 us,  5.5 sy,  0.0 ni, 89.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :    922.0 total,    209.1 free,    216.4 used,    496.5 buff/cache
                                    MiB Swap:    100.0 total,     21.0 free,     79.0 used.    633.7 avail Mem
                                    *** FAILED SERVICES ***
                                      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                                    * bthelper@hci0.service         loaded failed failed Raspberry Pi bluetooth helper
                                    * colord.service                loaded failed failed Manage, Install and Generate Color Profiles
                                    * openvpn-client@client.service loaded failed failed OpenVPN tunnel for client
                                    * plymouth-start.service        loaded failed failed Show Plymouth Boot Screen
                                    * wg-quick@wg0.service          loaded failed failed WireGuard via wg-quick(8) for wg0
                                    5 loaded units listed.
                                    *** DMESG CRITICAL ERRORS ***
                                    144 CRITICAL ERRORS DETECTED!
                                    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       15G  6.2G  7.7G  45% /
                                    devtmpfs       devtmpfs  333M     0  333M   0% /dev
                                    tmpfs          tmpfs     461M  4.0K  461M   1% /dev/shm
                                    tmpfs          tmpfs     185M  772K  184M   1% /run
                                    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                    tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
                                    [Tue Jul 15 19:01:52 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=44a3dce6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    [Tue Jul 15 19:01:55 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Tue Jul 15 19:01:55 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Tue Jul 15 19:01:58 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    Show mounted filesystems:
                                    TARGET  SOURCE         FSTYPE OPTIONS
                                    /       /dev/mmcblk0p2 ext4   rw,noatime
                                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                    /var:
                                    2.2G    /var/
                                    1.1G    /var/cache/apt
                                    1.1G    /var/cache
                                    992M    /var/cache/apt/archives
                                    865M    /var/log
                                    Journal file /var/log/journal/17f5be65a0144b718868da827cf6bffe/system@0c9cfaba2fdb43568eb34c2594062e00-0000000000000001-0005cf905c0cadb6.journal corrupted, ignoring file.
                                    Archived and active journals take up 776.1M in the file system.
                                    /opt/iobroker/backups:
                                    4.0K    /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    103M    /opt/iobroker/iobroker-data/
                                    64M     /opt/iobroker/iobroker-data/files
                                    47M     /opt/iobroker/iobroker-data/files/admin.admin
                                    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                                    22M     /opt/iobroker/iobroker-data/objects.jsonl
                                    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
                                    3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
                                    3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
                                    3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
                                    USB-Devices by-id:
                                    No Devices found 'by-id'
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs         v20.19.1
                                    /usr/bin/node           v20.19.1
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    /usr/bin/corepack       0.31.0
                                    nodejs:
                                      Installed: 20.19.1-1nodesource1
                                      Candidate: 20.19.1-1nodesource1
                                      Version table:
                                     *** 20.19.1-1nodesource1 600
                                            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                         20.19.0-1nodesource1 600
                                         20.18.3-1nodesource1 600
                                         20.18.2-1nodesource1 600
                                         20.18.1-1nodesource1 600
                                         20.18.0-1nodesource1 600
                                         20.17.0-1nodesource1 600
                                         20.16.0-1nodesource1 600
                                         20.15.1-1nodesource1 600
                                         20.15.0-1nodesource1 600
                                         20.14.0-1nodesource1 600
                                         20.13.1-1nodesource1 600
                                         20.13.0-1nodesource1 600
                                         20.12.2-1nodesource1 600
                                         20.12.1-1nodesource1 600
                                         20.12.0-1nodesource1 600
                                         20.11.1-1nodesource1 600
                                         20.11.0-1nodesource1 600
                                         20.10.0-1nodesource1 600
                                         20.9.0-1nodesource1 600
                                         20.8.1-1nodesource1 600
                                         20.8.0-1nodesource1 600
                                         20.7.0-1nodesource1 600
                                         20.6.1-1nodesource1 600
                                         20.6.0-1nodesource1 600
                                         20.5.1-1nodesource1 600
                                         20.5.0-1nodesource1 600
                                         20.4.0-1nodesource1 600
                                         20.3.1-1nodesource1 600
                                         20.3.0-1nodesource1 600
                                         20.2.0-1nodesource1 600
                                         20.1.0-1nodesource1 600
                                         20.0.0-1nodesource1 600
                                         12.22.12~dfsg-1~deb11u7 500
                                    No problems detected
                                    Errors in npm tree: 0
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 35829)
                                    Core adapters versions
                                    js-controller:  7.0.6
                                    admin:          7.6.17
                                    javascript:     "javascript" not found
                                    nodejs modules from github:     0
                                    Adapter State
                                      system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
                                      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                    + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1884
                                    + instance is alive
                                    ioBroker-Repositories
                                    Active repo(s): stable
                                    Upgrade policy: none
                                    Installed ioBroker-Adapters
                                    Used repository: stable
                                    Adapter    "admin"        : 7.6.17   , installed 7.6.17
                                    Adapter    "backitup"     : 3.3.5    , installed 3.2.2  [Updatable]
                                    Controller "js-controller": 7.0.6    , installed 7.0.6
                                    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
                                    Objects and States
                                    Objects:        171
                                    States:         106
                                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          14657      623/lighttpd
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14552      551/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          14166      876/dnsmasq
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       285666     21933/iobroker.js-c
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       285671     21933/iobroker.js-c
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          297692     25814/cupsd
                                    tcp6       0      0 :::80                   :::*                    LISTEN      0          14658      623/lighttpd
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14554      551/sshd: /usr/sbin
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          297691     25814/cupsd
                                    tcp6       0      0 :::53                   :::*                    LISTEN      0          14168      876/dnsmasq
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       288840     21989/io.admin.0
                                    udp        0      0 0.0.0.0:59903           0.0.0.0:*                           108        12483      337/avahi-daemon: r
                                    udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          14165      876/dnsmasq
                                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14162      876/dnsmasq
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12897      857/dhcpcd
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12481      337/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          116938     857/dhcpcd
                                    udp6       0      0 :::53                   :::*                                0          14167      876/dnsmasq
                                    udp6       0      0 :::58970                :::*                                108        12484      337/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        12482      337/avahi-daemon: r
                                    2025-07-16 00:32:36.623  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
                                    2025-07-16 00:32:36.881  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
                                    2025-07-16 00:32:36.925  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
                                    2025-07-16 00:32:39.394  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
                                    2025-07-16 00:38:54.719  - info: host.raspberrypi iobroker add rpi2 --host raspberrypi
                                    2025-07-16 00:39:02.488  - info: host.raspberrypi iobroker NPM version: 10.8.2
                                    2025-07-16 00:39:02.492  - info: host.raspberrypi iobroker Installing iobroker.rpi2@2.4.0... (System call)
                                    2025-07-16 00:40:08.220  - error: host.raspberrypi iobroker npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error make: Entering directory '/opt/iobroker/node_modules/opengpio/build'npm error   CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error   SOLINK_MODULE(target) Release/obj.target/opengpio.nodenpm error make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'npm error /usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizednpm error collect2: error: ld returned 1 exit statusnpm error make: *** [opengpio.target.mk:133: Release/obj.target/opengpio.node] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)npm error gyp ERR! System Linux 6.1.21-v7+npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v20.19.1npm error gyp ERR! node-gyp -v v10.1.0npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T22_39_03_166Z-debug-0.log
                                    2025-07-16 00:40:08.225  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.rpi2@2.4.0: 1
                                    2025-07-16 00:40:09.283  - info: host.raspberrypi iobroker exit 25
                                    2025-07-16 00:45:05.391  - error: host.raspberrypi Cannot read disk size: Could not determine controller directory
                                    2025-07-16 00:51:31.884  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
                                    2025-07-16 09:44:56.397  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
                                    2025-07-16 09:48:30.566  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
                                    2025-07-16 09:49:23.357  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
                                    2025-07-16 09:49:23.955  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
                                    iob diag has finished.
                                    pi@raspberrypi:~ $ obroker fix
                                    -bash: obroker: command not found
                                    pi@raspberrypi:~ $
                                    ```pi@raspberrypi:~ $ apt policy libgpiod*
                                    libgpiod-dev:
                                      Installed: 1.6.2-1+rpi1
                                      Candidate: 1.6.2-1+rpi1
                                      Version table:
                                     *** 1.6.2-1+rpi1 500
                                    libgpiod-doc:
                                      Installed: (none)
                                      Version table:
                                         1.6.2-1+rpi1 500
                                    libgpiod2:
                                      Version table:
                                    • Basti97B Basti97
                                      iob diag
                                      ```bash
                                      Script v.2025-03-08
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm
                                      Docker          : false
                                      Kernel          : armv7l
                                      Userland        : 32 bit
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      HOME=/home/pi
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M         78M         21M
                                                921 M total memory
                                                216 M used memory
                                                407 M active memory
                                                209 M free memory
                                                 70 M buffer memory
                                                425 M swap cache
                                                 99 M total swap
                                                 78 M used swap
                                                 21 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      2.2G    /var/
                                      1.1G    /var/cache/apt
                                      1.1G    /var/cache
                                      865M    /var/log
                                      USB-Devices by-id:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      admin:          7.6.17
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        171
                                      States:         106
                                      Pending Updates: 0
                                      pi@raspberrypi:~ $
                                      libgpiod-dev:
                                        Version table:
                                      libgpiod-doc:
                                        Installed: (none)
                                        Version table:
                                           1.6.2-1+rpi1 500
                                      libgpiod2:
                                        Version table:
                                      Thomas BraunT
                                      Thomas BraunT
                                      Setz das Ding komplett neu auf, diesmal direkt als RaspberryOS 12 'Lite - 64Bit'.
                                        Basti97B
                                        Basti97B
                                        Basti97
                                        @thomas-braun Und dann funktoniert es oder?
                                        Das komische daran ist ich hatte den Rpi vorher als Slave laufen gehabt. Das hatte ich vor längeren mal so eingestellt und er wurde auch gleich wieder erkannt und ich konnte die gpios auch steuern. Ich hatte den Verbund nicht auseinander gemacht und iobroker deinstalliert und alles neu installiert. Danach konnte ich den rpi Adapter nicht mehr installieren.
                                        • Basti97B Basti97
                                          Thomas BraunT
                                          Thomas BraunT
                                          Kann ich dir nicht sagen. Aber zumindest ist dann die Ausgangslage eine stabile.
                                          83.9k
