  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Modbus: Solax Hybrid X3 Gen4 schreiben
    2.8k
    4.9k
    4.1k
51 Beiträge 4 Kommentatoren 5.2k Aufrufe 3 Beobachtet
  • CodierknechtC Codierknecht
    @homoran sagte in Modbus: Solax Hybrid X3 Gen4 schreiben:
    was zeigt denn der debug log wenn du den Wert unbestätigt änderst?
    2025-06-16 18:54:53.989	info	Disconnected from slave 192.168.179.39
    2025-06-16 18:54:53.989	debug	Closing client on purpose.
    2025-06-16 18:54:52.989	debug	Cleaning up request fifo.
    2025-06-16 18:54:52.989	debug	Clearing timeout of the current request.
    2025-06-16 18:54:52.989	debug	Socket closed with error
    2025-06-16 18:54:52.989	error	Cannot write single register [31]: {"err":"timeout","timeout":5000}
    2025-06-16 18:54:52.988	error	Client in error state.
    2025-06-16 18:54:52.988	error	Request timed out.
    2025-06-16 18:54:52.988	warn	Error: undefined
    2025-06-16 18:54:52.175	debug	[DevID_1/inputRegs] Poll address 0 - 36 registers
    2025-06-16 18:54:52.175	debug	[DevID_1] Poll start ---------------------
    2025-06-16 18:54:47.987	debug	state Changed ack=false: modbus.0.holdingRegisters._0x001F_SolarChargerUseMode: {"val":1,"ack":false,"ts":1750092887986,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1750092887986}
    2025-06-16 18:54:47.104	debug	[DevID_1/holdingRegs] Poll address 186 DONE
    2025-06-16 18:54:47.102	debug	[DevID_1/holdingRegs] Poll address 186 - 1 registers
    2025-06-16 18:54:47.093	debug	[DevID_1/holdingRegs] Poll address 170 DONE
    2025-06-16 18:54:47.091	debug	[DevID_1/holdingRegs] Poll address 170 - 5 registers
    2025-06-16 18:54:47.080	debug	[DevID_1/holdingRegs] Poll address 133 DONE
    2025-06-16 18:54:47.079	debug	[DevID_1/holdingRegs] Poll address 133 - 12 registers
    2025-06-16 18:54:47.069	debug	[DevID_1/holdingRegs] Poll address 31 DONE
    2025-06-16 18:54:47.067	debug	[DevID_1/holdingRegs] Poll address 31 - 2 registers
    2025-06-16 18:54:47.057	debug	[DevID_1/holdingRegs] Poll address 0 DONE
    2025-06-16 18:54:47.056	debug	[DevID_1/holdingRegs] Poll address 0 - 14 registers
    versuch da mal nur einzelne Register schreiben.
    @codierknecht sagte in Modbus: Solax Hybrid X3 Gen4 schreiben:
    puuuh, doch der tcp2rtu konverter schuld?
      CodierknechtC Online
      Codierknecht
      Ausschließen möchte ich das nicht.
      Viel einstellen lässt sich da aber auch nicht:
      Bei Änderung der Baudrate oder des Protokolls steigt der Adapter aus.
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
        @codierknecht da kenn ich mich nicht mit aus
        vielleicht @wendy2702
        du kannst nicht zufällig testweise einen rtu2usb einbauen?
        wendy2702W CodierknechtC 2 Antworten Letzte Antwort
          wendy2702W Offline
          wendy2702W Offline
          @homoran ich habe zwar noch nen Konverter liegen aber gerade kein Gerät zum beschreiben.
          Bin jetzt nur am Handy aber FC06 ist eigentlich Holding Register. Ist das da eingetragen?
          Zufälligerweise mal mit einem Offset +1 probiert?
            Codierknecht
            Ich befürchte, ich habe beim Versuch die Firmware upzudaten, den Konverter zerlegt :-(
              wendy2702W Offline
              wendy2702W Offline
              @codierknecht das ist ärgerlich.
              • wendy2702W wendy2702
                Codierknecht
                @wendy2702
                Kommt morgen neu.
                Gibt's bessere Alternativen zu Waveshare?
                DIN-Montage mit PoE?
                wendy2702W HomoranH 2 Antworten Letzte Antwort
                  @wendy2702
                  Kommt morgen neu.
                  wendy2702W Offline
                  wendy2702W Offline
                  @codierknecht ich bin mit den Waveshare bisher super zufrieden.
                  Habe allerdings am Waveshare nur ein Gerät was ich beschreiben könnte… steht aber erst im Winter an das umzusetzen.
                    @wendy2702
                    Kommt morgen neu.
                    USB am iob-Slave
                    :duckundwech:
                      USB am iob-Slave
                      :duckundwech:
                      wendy2702W Offline
                      wendy2702W Offline
                      @homoran damit könnte man zumindest mal testen und wenn es geht weiter mit Waveshare forschen
                        USB am iob-Slave
                        :duckundwech:
                        Codierknecht
                        USB am iob-Slave
                        Muss das ein ioB-Slave sein?
                        Ich gehe mal davon aus, dass man erstmal einen USB-RS485-Konverter benötigt (den ich nicht besitze).
                        Könnte man den dann nicht auch an einen ESP mit Tasmota klemmen?
                          USB am iob-Slave
                          da hab ich dich anders eingeschätzt ;-)
                          wasndas? 😂
                          damit hättest du jegliche weiteren Fehlerquellen ausgeschaltet.
                          Die Modbus Instanz auf dem Slave wäre dann direkt via RTU mit dem WR verbunden.
                          aber ohne RTU Stick geht's nicht "mal eben"
                          • wendy2702W Offline
                            wendy2702W Offline
                            So ein USB-RS485 Teil kostet 10-15€, dann könntest du mit irgendeinem Rechner auch erstmal mit Modbus Tool testen.
                            Oder auf einem alten PI oder so einfach erstmal IOB Installieren.
                              @wendy2702 sagte in Modbus: Solax Hybrid X3 Gen4 schreiben:
                              dafür bekommst du sogar schon gute, ggf. mit galvanischer Trennung.
                              https://www.welectron.com/Waveshare-17286-USB-TO-RS485
                              Billige kosten einstellige Euros
                              https://www.berrybase.de/usb-rs485-konverter
                              (den kenn ich nicht!)
                                wendy2702W Offline
                                wendy2702W Offline
                                @homoran Ich bin mit denen hier bisher immer gut gefahren:
                                https://amzn.eu/d/0gFPUyH
                                  wasndas? 😂
                                  Codierknecht
                                  Werd' mir mal einen besorgen. Schadet ja nicht.
                                  wasndas?
                                  Da hätte ich Dich anders eingeschätzt 😀
                                  Microcontroller. ESP32 o.ä.
                                  Sowas in der Art:
                                  Dem verpasst man Tasmota als Firmware: https://tasmota.github.io/docs/Modbus-Bridge/
                                  Davon hab' ich immer welche rumliegen. 5V Spannung krieg ich problemlos zum WR.
                                  Da einen Slave hinzustellen, gestaltet sich schon schwieriger. Erstmal müsste ich meinen NUC aus dem Schaltschrank holen und dann noch für die Stromversorgung sorgen.
                                  Vielleicht besorg' ich mir ja doch mal 'nen Pi ... als Bastelbüchse.
                                  Morgen werde ich erstmal den Konverter tauschen, damit ich wieder Daten bekomme.
                                  Laut diese Info https://github.com/alienatedsec/solis-ha-modbus-cloud/discussions/17 bereitet wohl die veraltete Standard-FW Probleme. Beim Update hat's mir den Konverter zerschossen. Ist nicht mehr über Netz erreichbar und damit allem Anschein nach Elektroschrott.
                                  Weitere Versuche werde ich dann wohl erst mit dem USB/RS485 unternehmen.
                                  Danke euch für's Erste!
                                    wasndas?
                                    Sowas in der Art:
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    @codierknecht hast du mal mit „Vircom“ geschaut? Nicht der nur ne default IP bekommen hat.
                                      Codierknecht
                                      VirCom findet den nicht mehr. Zeigt auch keinen Link an ... es leuchtet nur die Power-LED.
                                      Und ja - den habe ich auch schon mal stromlos gemacht.
                                        wendy2702W Offline
                                        wendy2702W Offline
                                        @codierknecht ok.
                                        Dann wäre das die Gelegenheit das Gehäuse mal zu öffnen um zu gucken was da so drin ist 😚🫣
                                          @codierknecht ok.
                                          Codierknecht
                                          So mein Plan 😀
                                          Ich warte aber noch auf die Antwort auf meine Supportanfrage an Waveshare.
                                          Vielleicht zeigen die sich ja kulant ;-)
