  4. Test Adapter mytime
    1.0k
    6.1k
Test Adapter mytime
adaptermytimetestwidget
600 Beiträge 52 Kommentatoren 185.6k Aufrufe 63 Beobachtet
  • wendy2702W wendy2702
    gerade mal den Adapter installiert und versucht einen Countdown Timer anzulegen:
    dabei koimmt dann das im log: (sorry, kann gerade nur aus dem Browser Fenster kopieren)
    host.iobroker
    2025-06-05 17:12:16.343	info	Restart adapter system.adapter.mytime.0 because enabled
    host.iobroker
    2025-06-05 17:12:16.343	error	instance system.adapter.mytime.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    mytime.0
    2025-06-05 17:12:15.642	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    mytime.0
    2025-06-05 17:12:15.641	info	terminating
    mytime.0
    2025-06-05 17:12:15.641	info	cleaned everything up...
    mytime.0
    2025-06-05 17:12:15.638	error	Cannot set properties of undefined (setting 'config')
    mytime.0
    2025-06-05 17:12:15.637	error	TypeError: Cannot set properties of undefined (setting 'config') at mytimeCountdown.setCountdownConfigMsg (/opt/iobroker/node_modules/iobroker.mytime/lib/mytimeCountdown.js:587:46) at mytimeCountdown.processMessages (/opt/iobroker/node_modules/iobroker.mytime/lib/mytimeCountdown.js:566:18) at mytimeclassNew.processMessages (/opt/iobroker/node_modules/iobroker.mytime/lib/mytimeserver.js:60:48) at Mytime.onMessage (/opt/iobroker/node_modules/iobroker.mytime/main.js:102:22) at Mytime.emit (node:events:524:28) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7309:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:286:37) at process.processImmediate (node:internal/timers:483:21)
    mytime.0
    2025-06-05 17:12:15.635	error	unhandled promise rejection: Cannot set properties of undefined (setting 'config')
    mytime.0
    2025-06-05 17:12:15.635	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Was mache ich denn falsch?
    JS-Controller 7.0.7
    Node v20.19.1
    Admin v7.6.18
    myTime 1.4.2
    Edit: debug log
    mirko@iobroker:~$ tail -f /opt/iobroker/log/iobroker.current.log |grep mytime
    2025-06-05 17:24:47.535  - debug: mytime.0 (90064) processMessages mytime
    2025-06-05 17:24:47.535  - debug: mytime.0 (90064) processMessages countdown{"command":"setCountdownConfig","message":{"behavior":"timer","days":"0","hours":"0","minutes":"30","name":"30min","seconds":"0"},"from":"system.adapter.admin.0","callback":{"message":{"behavior":"timer","days":"0","hours":"0","minutes":"30","name":"30min","seconds":"0"},"id":491,"ack":false,"time":1749137087530},"_id":12576096}
    2025-06-05 17:24:47.536  - debug: mytime.0 (90064) send setCountdownConfig
    2025-06-05 17:24:47.536  - debug: mytime.0 (90064) setCountdownConfigMsg
    2025-06-05 17:24:47.540  - error: mytime.0 (90064) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-06-05 17:24:47.540  - error: mytime.0 (90064) unhandled promise rejection: Cannot set properties of undefined (setting 'config')
    2025-06-05 17:24:47.542  - error: mytime.0 (90064) TypeError: Cannot set properties of undefined (setting 'config')
    2025-06-05 17:24:47.543  - error: mytime.0 (90064) Cannot set properties of undefined (setting 'config')
    2025-06-05 17:24:47.554  - debug: mytime.0 (90064) main onUnload try
    2025-06-05 17:24:47.555  - debug: mytime.0 (90064) closeConnections
    2025-06-05 17:24:47.555  - debug: mytime.0 (90064) deleteObservers
    2025-06-05 17:24:47.555  - info: mytime.0 (90064) cleaned everything up...
    2025-06-05 17:24:47.555  - info: mytime.0 (90064) terminating
    2025-06-05 17:24:47.556  - warn: mytime.0 (90064) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-06-05 17:24:48.057  - info: mytime.0 (90064) terminating
    2025-06-05 17:24:48.333  - error: host.iobroker instance system.adapter.mytime.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-06-05 17:24:48.333  - info: host.iobroker Restart adapter system.adapter.mytime.0 because enabled
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    #472
    @wendy2702
    Kannst du bitte den log level auf debug stellen und dann nochmal versuchen anzulegen. Da kommen ein paar mehr Zeilen mit um zu sehen wo das genau passiert ist.
    Meine Adapter und Widgets
    Links im Profil
    • OliverIOO OliverIO
      @wendy2702
      wendy2702W Online
      wendy2702W Online
      #473
      @oliverio gerade meinen Beitrag vorher editiert.
      Edit: Melde dich wenn du noch etwas benötigst! Danke für die schnelle Antwort!
      Edit 2: Mit V1.4.0 sieht es genauso aus:
      2025-06-05 17:31:06.188  - info: mytime.0 (90356) starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.mytime, node: v20.19.1, js-controller: 7.0.7
      2025-06-05 17:31:06.206  - debug: mytime.0 (90356) main onReady start
      2025-06-05 17:31:06.207  - debug: mytime.0 (90356) main onReady open mytime
      2025-06-05 17:31:06.207  - debug: mytime.0 (90356) mytime init
      2025-06-05 17:31:06.208  - debug: mytime.0 (90356) setState connection: true
      2025-06-05 17:31:06.210  - debug: mytime.0 (90356) mytimeCountdown init
      2025-06-05 17:31:06.211  - debug: mytime.0 (90356) setCountdownInfo {}
      2025-06-05 17:31:06.213  - debug: mytime.0 (90356) mytimeTimeserie init
      2025-06-05 17:31:06.213  - debug: mytime.0 (90356) setTimeseriesInfo []
      2025-06-05 17:31:06.722  - debug: mytime.0 (90356) getStates * Countdowns
      2025-06-05 17:31:06.724  - debug: mytime.0 (90356) getStates * Timeseries
      2025-06-05 17:31:06.865  - debug: mytime.0 (90356) state mytime.0.info.connection changed: true (ack = true)
      2025-06-05 17:31:31.087  - debug: mytime.0 (90356) processMessages mytime
      2025-06-05 17:31:31.088  - debug: mytime.0 (90356) processMessages countdown{"command":"setCountdownConfig","message":{"behavior":"timer","days":"0","hours":"0","minutes":"30","name":"30min","seconds":"0"},"from":"system.adapter.admin.0","callback":{"message":{"behavior":"timer","days":"0","hours":"0","minutes":"30","name":"30min","seconds":"0"},"id":498,"ack":false,"time":1749137491062},"_id":12576105}
      2025-06-05 17:31:31.088  - debug: mytime.0 (90356) send setCountdownConfig
      2025-06-05 17:31:31.088  - debug: mytime.0 (90356) setCountdownConfigMsg
      2025-06-05 17:31:31.090  - error: mytime.0 (90356) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-06-05 17:31:31.091  - error: mytime.0 (90356) unhandled promise rejection: Cannot set properties of undefined (setting 'config')
      2025-06-05 17:31:31.094  - error: mytime.0 (90356) TypeError: Cannot set properties of undefined (setting 'config')
          at mytimeCountdown.setCountdownConfigMsg (/opt/iobroker/node_modules/iobroker.mytime/lib/mytimeCountdown.js:588:46)
      2025-06-05 17:31:31.094  - error: mytime.0 (90356) Cannot set properties of undefined (setting 'config')
      2025-06-05 17:31:31.108  - debug: mytime.0 (90356) main onUnload try
      2025-06-05 17:31:31.109  - debug: mytime.0 (90356) closeConnections
      2025-06-05 17:31:31.109  - debug: mytime.0 (90356) deleteObservers
      2025-06-05 17:31:31.109  - info: mytime.0 (90356) cleaned everything up...
      2025-06-05 17:31:31.110  - info: mytime.0 (90356) terminating
      2025-06-05 17:31:31.112  - warn: mytime.0 (90356) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-06-05 17:31:31.614  - info: mytime.0 (90356) terminating
      2025-06-05 17:31:31.936  - error: host.iobroker instance system.adapter.mytime.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-06-05 17:31:31.937  - info: host.iobroker Restart adapter system.adapter.mytime.0 because enabled
      2025-06-05 17:31:31.937  - warn: host.iobroker Do not restart adapter system.adapter.mytime.0 because restart loop detected
      • wendy2702W Online
        wendy2702W Online
        #474
        @OliverIO : sag Bescheid wenn du ein Issue auf Github benötigst.
        • wendy2702W Online
          wendy2702W Online
          #475
          @OliverIO guten Morgen.
          Hattest du schon Gelegenheit dir das log anzuschauen und vielleicht eine Idee was die Ursache sein kann?
          Gibt es noch etwas das ich testen kann um den Adapter zum laufen zu bekommen falls es an meiner Installation liegt?
          • OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #476
            @wendy2702
            Eine Idee habe ich.
            Wahrscheinlich hab ich irgendwas bei der Grund Initialisierung vergessen.
            Muss das aber noch mal testen
            Links im Profil
              @wendy2702
              Eine Idee habe ich.
              wendy2702W Online
              wendy2702W Online
              #477
              @oliverio OK. Wenn ich was Testen soll, geb Bescheid.
              Danke für deinen Einsatz
              • OliverIOO Offline
                OliverIOO Offline
                OliverIO
                #478
                @wendy2702
                ok, fehler ist identifiziert.
                der neu hinzugekommene Knopf "setDP" dient eigentlich dazu, die Zeit eines bereits vorhandenen Countdown timers erneut oder gemäß Eingabe zu setzen.
                Wenn du aber den Eintrag erst frisch hinzugefügt hast, dann existiert der Datenpunkt noch nicht und die Funktion geht schief.
                Meine Vorstellung wäre, das dieser Knopf nur aktiv ist, wenn der Datenpunkt existiert und wenn tatsächlich was geändert wurde.
                Das muss ich erst austüfteln, wie ich das im admin gestalten muss.
                Für dich reicht es einfach, den speichern Knopf unten zu drücken.
                Dann ist der Countdown auch angelegt.
                Links im Profil
                  @wendy2702
                  wendy2702W Online
                  wendy2702W Online
                  #479
                  @oliverio top.
                  Gleich mal testen wenn ich wieder am Rechner bin .
                    Neue Version 1.4.2
                    • Das Problem bei der Berechnung der Zeitdifferenz zwischen Server und Client konnte behoben werden.
                    Wer das für sich genauer testen möchte, habe ich hier meine Testview mit zusätzlichen Informationen aufbereitet. Hier zum importieren
                    Es wird noch der Adapter timeandweather benötigt für das Uhrzeit widget
                       "settings": {
                           "style": {
                               "background_class": ""
                           "theme": "redmond",
                           "sizex": "",
                           "sizey": "",
                           "gridSize": "",
                           "snapType": null,
                           "useBackground": false
                       "widgets": {
                           "e00001": {
                               "tpl": "tplMyTimeCountdownPlain",
                               "data": {
                                   "g_fixed": false,
                                   "g_visibility": false,
                                   "g_css_font_text": false,
                                   "g_css_background": false,
                                   "g_css_shadow_padding": false,
                                   "g_css_border": false,
                                   "g_gestures": false,
                                   "g_signals": false,
                                   "g_last_change": false,
                                   "visibility-cond": "==",
                                   "visibility-val": 1,
                                   "visibility-groups-action": "hide",
                                   "countdown_format": "dd\\d HH\\h mm\\m ss\\s",
                                   "signals-cond-0": "==",
                                   "signals-val-0": true,
                                   "signals-icon-0": "/vis/signals/lowbattery.png",
                                   "signals-icon-size-0": 0,
                                   "signals-blink-0": false,
                                   "signals-horz-0": 0,
                                   "signals-vert-0": 0,
                                   "signals-hide-edit-0": false,
                                   "signals-cond-1": "==",
                                   "signals-val-1": true,
                                   "signals-icon-1": "/vis/signals/lowbattery.png",
                                   "signals-icon-size-1": 0,
                                   "signals-blink-1": false,
                                   "signals-horz-1": 0,
                                   "signals-vert-1": 0,
                                   "signals-hide-edit-1": false,
                                   "signals-cond-2": "==",
                                   "signals-val-2": true,
                                   "signals-icon-2": "/vis/signals/lowbattery.png",
                                   "signals-icon-size-2": 0,
                                   "signals-blink-2": false,
                                   "signals-horz-2": 0,
                                   "signals-vert-2": 0,
                                   "signals-hide-edit-2": false,
                                   "lc-type": "last-change",
                                   "lc-is-interval": true,
                                   "lc-is-moment": false,
                                   "lc-format": "",
                                   "lc-position-vert": "top",
                                   "lc-position-horz": "right",
                                   "lc-offset-vert": 0,
                                   "lc-offset-horz": 0,
                                   "lc-font-size": "12px",
                                   "lc-font-family": "",
                                   "lc-font-style": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-border-width": "0",
                                   "lc-border-style": "",
                                   "lc-border-color": "",
                                   "lc-border-radius": 10,
                                   "lc-zindex": 0,
                                   "countdown_oid": "mytime.0.Countdowns.test.action"
                               "style": {
                                   "left": "11px",
                                   "top": "9px"
                               "widgetSet": "mytime"
                           "e00002": {
                               "tpl": "tplJquiButtonState",
                               "data": {
                                   "oid": "mytime.0.Countdowns.test.cmd",
                                   "g_fixed": true,
                                   "g_css_font_text": true,
                                   "g_css_background": true,
                                   "g_css_shadow_padding": true,
                                   "g_css_border": true,
                                   "g_signals": false,
                                   "buttontext": "stop",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "value": "stop",
                                   "class": "mytime"
                               "style": {
                                   "left": "774px",
                                   "top": "90px",
                                   "color": "white",
                                   "font-weight": "lighter",
                                   "font-size": "x-small",
                                   "background": "",
                                   "border-width": "2px",
                                   "border-style": "solid",
                                   "border-color": "white",
                                   "border-radius": "10px",
                                   "background-color": "#303030 !important",
                                   "box-shadow": "2px 2px 3px rgba(20, 20, 20, 50)",
                                   "width": "55px"
                               "widgetSet": "jqui"
                           "e00003": {
                               "data": {
                                   "g_fixed": true,
                                   "g_signals": false,
                                   "buttontext": "pause",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "value": "pause",
                                   "class": "mytime"
                               "style": {
                                   "left": "711px",
                                   "top": "90px",
                                   "color": "white",
                                   "background": "",
                                   "width": "55px"
                               "widgetSet": "jqui"
                           "e00004": {
                               "data": {
                                   "g_fixed": true,
                                   "g_signals": false,
                                   "buttontext": "start",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "value": "start",
                                   "class": "mytime"
                               "style": {
                                   "left": "652px",
                                   "top": "90px",
                                   "color": "white",
                                   "background": "",
                                   "width": "55px"
                               "widgetSet": "jqui"
                           "e00005": {
                               "data": {
                                   "g_fixed": true,
                                   "g_signals": false,
                                   "buttontext": "=10",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "value": "=10",
                                   "class": "mytime"
                               "style": {
                                   "left": "774px",
                                   "top": "38px",
                                   "color": "white",
                                   "background": "",
                                   "width": "55px"
                               "widgetSet": "jqui"
                           "e00006": {
                               "data": {
                                   "g_fixed": true,
                                   "g_signals": false,
                                   "buttontext": "-10s",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "value": "-10",
                                   "class": "mytime"
                               "style": {
                                   "left": "711px",
                                   "top": "38px",
                                   "color": "white",
                                   "background": "",
                                   "width": "55px"
                               "widgetSet": "jqui"
                           "e00007": {
                               "data": {
                                   "g_fixed": true,
                                   "g_signals": false,
                                   "buttontext": "+10s",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "value": "+10",
                                   "class": "mytime"
                               "style": {
                                   "left": "653px",
                                   "top": "39px",
                                   "color": "white",
                                   "background": "",
                                   "width": "55px"
                               "widgetSet": "jqui"
                           "e00008": {
                               "data": {
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "countdown_oid": "mytime.0.Countdowns.test.timer",
                                   "format": "d H m s",
                               "style": {
                                   "left": "682px",
                                   "top": "71px",
                                   "width": "151px",
                                   "height": "16px"
                           "e00009": {
                               "tpl": "tplMyTimeCountdownCircle",
                               "data": {
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "countdown_format": "mm:ss",
                                   "countdown_width": "20",
                                   "countdown_caps": "straight",
                                   "countdown_showsec": "true",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                               "style": {
                                   "left": "15px",
                                   "top": "37px",
                                   "width": "114px",
                                   "height": "76px"
                           "e00010": {
                               "tpl": "tplMyTimeCountdownFlip",
                               "data": {
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "countdown_oid": "mytime.0.Countdowns.test.action",
                                   "countdown_showmin": true
                               "style": {
                                   "left": "19px",
                                   "top": "131px",
                                   "width": "320px",
                                   "height": "120px"
                           "e00011": {
                               "tpl": "tplMyTimeCountdownNixie",
                               "data": {
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "countdown_color_active": "#FFE548",
                                   "countdown_color_inactive": "#323232",
                                   "countdown_opacity_inactive": "0.35",
                                   "countdown_glowcolor": "#F58732",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "countdown_showmin": true,
                                   "countdown_showhrs": true,
                                   "countdown_showday": true
                               "style": {
                                   "left": "378px",
                                   "top": "132px",
                                   "width": "723px",
                                   "height": "120px"
                           "e00012": {
                               "tpl": "tplMyTimeClockWord",
                               "data": {
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "language": "english",
                                   "minuteSize": "5",
                                   "secondSize": "5",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0
                               "style": {
                                   "left": "37px",
                                   "top": "284px"
                           "e00013": {
                               "tpl": "tplValueString",
                               "data": {
                                   "oid": "mytime.0.Countdowns.test.action",
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0
                               "style": {
                                   "left": "142px",
                                   "top": "35px",
                                   "border-color": "red",
                                   "padding": "5px",
                                   "width": "47px",
                                   "height": "30px"
                               "widgetSet": "basic"
                           "e00014": {
                               "tpl": "tplTwSimpleClock",
                               "data": {
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "blink": false,
                                   "noClass": true
                               "style": {
                                   "left": "273px",
                                   "top": "24px",
                                   "font-size": "medium",
                                   "letter-spacing": "0px",
                                   "width": "75px",
                                   "height": "20px"
                               "widgetSet": "timeandweather"
                           "e00015": {
                               "data": {
                                   "oid": "0_userdata.0.zeit",
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0
                               "style": {
                                   "left": "272px",
                                   "top": "45px",
                                   "width": "75px",
                                   "height": "20px"
                           "e00016": {
                               "tpl": "tplHtml",
                               "data": {
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "refreshInterval": "0",
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "html": "<p id=\"diff\" style=\"margin:0px\"></p>\n<script>\n    function updatediff(){\n        $(\"#diff\").html(vis.binds['mytime'].serversync.serverTimeDiff)\n        setTimeout(() => {\n            updatediff();\n        }, \"100\");\n    }\n    updatediff();\n</script>"
                               "style": {
                                   "left": "272px",
                                   "top": "69px",
                                   "width": "75px",
                                   "height": "20px"
                           "e00017": {
                               "data": {
                                   "oid": "nothing_selected",
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "html_append": "lokal"
                               "style": {
                                   "left": "369px",
                                   "top": "24px",
                                   "width": "55px",
                                   "height": "20px"
                           "e00018": {
                               "data": {
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "html_append": "server"
                               "style": {
                                   "left": "368px",
                                   "top": "45px",
                                   "width": "55px"
                           "e00019": {
                               "data": {
                                   "g_fixed": false,
                                   "g_signals": false,
                                   "lc-format": "",
                                   "lc-bkg-color": "",
                                   "lc-color": "",
                                   "lc-zindex": 0,
                                   "html_append": "diff ms"
                               "style": {
                                   "left": "368px",
                                   "top": "69px",
                                   "width": "55px"
                       "name": "mytime",
                       "filterList": []
                    Zusätzlich wird noch das folgende Blockly-Skript und der Datenpunkt 0_userdata.0.zeit vom Typ string benötigt, welches die Serverzeit als String sekündlich in den Datenpunkt schreibt
                     <block type="schedule" id="0:yPn3}/}U+V/OwAv52U" x="38" y="37">
                       <field name="SCHEDULE">* * * * * *</field>
                       <statement name="STATEMENT">
                         <block type="update" id="9TI6c)ZFUk@u*TO/pNB}">
                           <field name="OID">0_userdata.0.zeit</field>
                           <value name="VALUE">
                             <block type="time_get" id="0d0N.[rGF%upi^NYu2YQ">
                               <field name="OPTION">hh:mm:ss</field>
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                    </xml>
                    So sieht der view dann aus.
                    S Abwesend
                    S Abwesend
                    Shadowhunter23
                    schrieb am zuletzt editiert von Shadowhunter23
                    #480
                    @oliverio sagte in Test Adapter mytime:
                    Neue Version 1.4.2
                    Getestet und funktioniert, trotz Zeitversatz wird der Timer richtig beendet. Vielen Dank für die Anpassung!
                    Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                    ioBroker Backup Analyzer
                    • wendy2702W Online
                      wendy2702W Online
                      #481
                      Ich teste gerade mal die Widgets, mache ich bei dem "Circle" etwas falsch das sich der Sekunden Wert nicht ändert und auch der Kreis nicht?
                      Wie man am anderen Widget sieht läuft der Timer.
                      OliverIOO 2 Antworten Letzte Antwort
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        #482
                        @wendy2702 welche version hast du?
                        wenn server uhr und client uhr nicht genau läuft, gab es bis v1.4.2 ein problem. also hier mal aus dem beta channel laden.
                        Links im Profil
                        • OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #483
                          Neue Version 1.4.3
                          Die Validator Regel für den SetDP Knopf in der Konfiguration wurde verbessert, so das der Knopf nur gedrückt werden kann, wenn der Datenpunkt bereits existiert.
                          Links im Profil
                            wendy2702W Online
                            wendy2702W Online
                            #484
                            1.4.2
                            Ich teste nachher mit 1.4.3
                              Neue Version 1.4.3
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #485
                              @oliverio ich hab da noch einen für die VIS
                              beide countdown widgets sind defect
                              1fc34233-336f-4434-9e02-5f64aa1c1d2b-grafik.png mytime.0.Countdowns.sprinkler.timer
                              OliverIOO wendy2702W 2 Antworten Letzte Antwort
                              • arteckA arteck
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                #486
                                @arteck
                                Bist du sicher das sich sonst nix bei dir verändert hat?
                                Im vergleich zu 1.4.2 hat sich bei den Widgets nix verändert. Es betraf nur admin und aktualisierte Pakete
                                https://github.com/oweitman/ioBroker.mytime/commit/f36793612b3220420eba97e1efbf2686481b507e
                                Links im Profil
                                  @arteck
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #487
                                  @oliverio ich weiss nicht wie lange das schon so ist.. ist mir erst jetzt aufgefallen
                                  der FlipClock geht
                                  wobei der wird erst "auf Timer gesetzt" wenn er anfängt zu ticken.. sonst steht der auch auf 0 obwohl ich den "auf Timer gesetzt" gesepeichert habe
                                  • OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    #488
                                    @arteck
                                    Kannst du bitte noch nach Fehlern in der Web Developer Konsole schauen?
                                    Links im Profil
                                    arteckA wendy2702W 2 Antworten Letzte Antwort
                                    • arteckA arteck
                                      wendy2702W Online
                                      wendy2702W Online
                                      #489
                                      @arteck Bei mir laufen beide, wobei ich beim "reverse" auch kein Objekt hinterlegt habe. Da das vom Format her nicht passt.
                                        @arteck
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #490
                                        @oliverio
                                        sind keine.... auf der console..
                                        in der vis.2 gehts auch nicht
                                        ich hab jetzt alles datenpunkte durch..
                                        keiner liefer das gewollte ergebniss.. nach dem ablauf soll der wieder auf Timer gestellt werden..also 5 min
                                          @arteck
                                          wendy2702W Online
                                          wendy2702W Online
                                          #491
                                          @oliverio Ist es ein Bug das ich im Datenpunkt Namen keinen Unterstrich verwenden kann oder warum kann ich hier nicht speichern?
                                          Interessant ist das es ausrecht die Unterstriche im ersten Timer mit Unterstrichen im Namen zu entfernen damit der Speicher Button aktiv wird:
                                          Version 1.4.3
