  4. Backitup Fehlermeldung bei Grafana Backup
    6.8k
23 Beiträge 6 Kommentatoren 3.0k Aufrufe 6 Beobachtet
  • umbmU umbm
    @simatec
    Ja, ich nutze auch Unterordner in Grafana.
    simatecS Offline
    simatecS Offline
    simatec
    @umbm dann teste bitte auch mal die aktuelle Githubversion. Das Problem tritt aktuell nur in Verbindung mit Grafana 12.0.0 auf
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    W 1 Antwort Letzte Antwort
    • simatecS simatec
      W Offline
      W Offline
      wibear
      @simatec
      Hallo Forum,
      ich habe dasselbe Problem. Bei mir sind auch Ordner in Grafana vorhanden.
      Unten sind meine Logs.
      Soll ich eine Lösung abwarten?
      Danke und Grüße
      404","name":"AxiosError","stack":"AxiosError: Request failed with status code 404\n at settle
      (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:2031:12)\n at IncomingMessage.handleStreamEnd
      (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3148:11)\n at IncomingMessage.emit (node:events:536:35)\n at
      endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections
      (node:internal/process/task_queues:82:21)\n at Axios.request
      (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4258:41)\n at process.processTicksAndRejections
      (node:internal/process/task_queues:95:5)\n at async
      /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:93:44\n at async
      Promise.all (index 0)","config":{"transitional":{"silentJSONParsing":true,
      "forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],
      "transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN",
      "xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":
      "application/json, text/plain, */*","Authorization":"Bearer ****","User-Agent":"axios/1.8.4",
      "Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":
      "http://192.168.178.10:3000/api/dashboards/uid/ee6zqf4dq7ncwa","responseType":"json","httpsAgent":
      {"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:",
      "options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},
      "freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,
      "scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":
      {"map":{},"list":[]}},"allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":404}
      13:46:48.334INFOguiBackup gestartet ...
      13:46:58.449DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iobrokerBackup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backups"
      13:46:58.518DEBUGmountfirst mount attempt with smb option failed. try next mount attempt without smb option ...
      13:46:58.527DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iobrokerBackup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backups"
      13:46:58.744DEBUGmountmount successfully completed
      13:46:58.785DEBUGmountdone
      13:47:04.430DEBUGiobrokerhost.raspi 9580 objects saved
      13:47:05.339DEBUGiobrokerhost.raspi 8233 states saved
      13:47:05.396DEBUGiobrokerhost.raspi Validating backup ...
      13:47:05.400DEBUGiobrokerhost.raspi "config.json" is valid
      host.raspi "objects.jsonl" exists
      host.raspi "states.jsonl" exists
      13:47:06.080DEBUGiobrokerhost.raspi JSONL lines are valid
      13:47:06.085DEBUGiobrokerhost.raspi The backup is valid!
      13:47:10.982DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2025_05_15-13_46_57_backupiobroker.tar.gz
      13:47:10.993DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
      13:47:12.092DEBUGiobrokerdone
      13:47:13.476DEBUGgrafanaStart Grafana Backup ...
      13:47:13.769DEBUGgrafanaCreated grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
      13:47:14.068DEBUGgrafanaCreated dashboard directory
      13:47:14.348DEBUGgrafanaCreated dashboards_manually_restore directory
      13:47:14.637DEBUGgrafanaCreated datasource directory
      13:47:14.645DEBUGgrafanastart Grafana request ...
      13:47:14.680DEBUGgrafanaGrafana is available ... Status: 200
      13:47:15.652ERRORgrafanaError on Grafana Dashboard ee6zqf4dq7ncwa backup: AxiosError: Request failed with status code 404
      13:47:15.655DEBUGgrafanafound Dashboard: energie
      13:47:15.734ERRORgrafanaError on Grafana Dashboard ce6zq9xqztp8gd backup: AxiosError: Request failed with status code 404
      13:47:15.740DEBUGgrafanafound Dashboard: heizung
      13:47:15.768ERRORgrafanaError on Grafana Dashboard backup: TypeError: Cannot read properties of undefined (reading 'data')
      13:47:15.779DEBUGgrafanastart Grafana backup compress ...
      13:47:15.833ERRORgrafanaError on Grafana Dashboard de6zqdiu6f400c backup: AxiosError: Request failed with status code 404
      13:47:15.838DEBUGgrafanafound Dashboard: funk
      13:47:15.928DEBUGgrafanafound Dashboard: verbrauch-hz-taglich
      13:47:16.177DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
      13:47:16.311DEBUGgrafanafound Dashboard: temperatur-shelly
      13:47:16.321DEBUGgrafanafound Dashboard: verbrauch-ww-taglich
      13:47:16.339DEBUGgrafanafound Dashboard: gerateleistung
      13:47:16.370DEBUGgrafanafound Dashboard: gauges
      13:47:16.378DEBUGgrafanafound Dashboard: umwalzpumpe
      13:47:16.457DEBUGgrafanafound Dashboard: verbrauch-strom-taglich
      13:47:16.468DEBUGgrafanafound Dashboard: signalstarke
      13:47:16.488DEBUGgrafanafound Dashboard: leistung-solar
      13:47:16.517DEBUGgrafanafound Dashboard: batterie-ladeleistung
      13:47:16.523DEBUGgrafanafound Dashboard: temperaturen-ww-hz
      13:47:16.578DEBUGgrafanafound Dashboard: batterie-soc
      13:47:21.333DEBUGgrafanadone
      13:47:22.671DEBUGcifsused copy path: /fritz.box/MemoryBoard/Share/Backup/ioBroker
      13:47:22.717DEBUGcifsdone
      13:47:23.278ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
      13:47:23.280DEBUGcleandone
      13:47:23.442DEBUGhistoryHTMLnew history html values created
      13:47:23.534DEBUGhistoryHTMLdone
      13:47:23.735DEBUGhistoryJSONnew history json values created
      13:47:23.779DEBUGhistoryJSONdone
      13:47:23.897DEBUGumountmount active, umount is started ...
      13:47:29.090DEBUGumountumount successfully completed
      13:47:29.094DEBUGumountdone
      13:47:30.305DEBUGwhatsappdone
      13:47:31.463DEBUGnotificationAdmin notification will be sent
      13:47:31.505DEBUGnotificationdone
      13:47:31.621INFOguiDas Backup wurde erfolgreich erstellt!
      • W wibear
        @simatec
        Hallo Forum,
        Danke und Grüße
        @wibear sagte in Backitup Fehlermeldung bei Grafana Backup:
        vers=1.0
        Ich würde auch die SMB-Version mal in die Gegenwart holen. Das sollte auch mit 3.1.1 laufen und die Meldung
        wäre weg.
          vers=1.0
          wäre weg.
          W Offline
          W Offline
          wibear
          Hallo Thomas, wie kann ich die SMB Version auf 3.1.1 bringen?
          Werden dann nicht nur die Fehlermeldungen verschwinden, sondern auch das Grafana Backup sauber laufen?
          Danke und Gruß
          Thomas BraunT simatecS 2 Antworten Letzte Antwort
          • W wibear
            Danke und Gruß
            In den Einstellungen des Backitup-Adapters.
            Vermutlich nicht. Aber es ist ein kleiner Baustein zu einem vollfunktionierenden Backup.
            • W wibear
              Danke und Gruß
              simatecS Offline
              simatecS Offline
              simatec
              @wibear Die Fehlermeldungen in Grafana liegen an Grafana 12.0.0 und werden mit dem nächsten Update von Backitup behoben
              MichaelFM W 2 Antworten Letzte Antwort
              • simatecS simatec
                MichaelFM Online
                MichaelFM Online
                MichaelF
                @simatec Danke für die Info, aber die Github Version kann ich doch einfach weiter laufen lassen? Oder spricht hier was dagegen ?
                • MichaelFM MichaelF
                  @michaelf sagte in Backitup Fehlermeldung bei Grafana Backup:
                  Man verwendet solche Versionen aber nicht produktiv, wenn es ein stabiles Release mit den gleichen Funktionen gibt.
                  Wenn die Versionsnummer die aus dem github übersteigt wird ohnehin wieder eine Repository-gestützte Version installiert werden.
                  MichaelFM 1 Antwort Letzte Antwort
                    MichaelFM Online
                    MichaelFM Online
                    MichaelF
                    @thomas-braun Auf die Stable update ich natürlich wieder, wollte nur jetzt nicht wieder auf die Version mit der Fehlermeldung zurück.
                    • simatecS simatec
                      W Offline
                      W Offline
                      wibear
                      @simatec
                      Danke für die Info!
