  4. Tester Zigbee Adapter 3.x gesucht
zigbeezigbee adapter
259 Beiträge 27 Kommentatoren 66.5k Aufrufe 38 Beobachtet
  • FabioF Fabio
    @asgothian das passierte jetzt schon 2 mal nachdem ich die 3.0 nutze.
    zigbee.0
    2025-04-17 10:45:44.803	info	Starting Zigbee-Herdsman
    zigbee.0
    2025-04-17 10:45:44.802	info	Installed Version: iobroker.zigbee@3.0.0 (Converters 23.27.0 Herdsman 3.5.1)
    zigbee.0
    2025-04-17 10:45:44.790	info	Starting Adapter npm ...
    zigbee.0
    2025-04-17 10:45:44.790	info	--- creating device debug ---
    zigbee.0
    2025-04-17 10:45:44.789	info	delete old Backup files. keep only last 10
    zigbee.0
    2025-04-17 10:45:44.770	info	--> transmitPower :
    zigbee.0
    2025-04-17 10:45:44.767	info	init localConfig
    zigbee.0
    2025-04-17 10:45:44.766	info	Adapter ready - starting subsystems. Adapter is running in info mode.
    zigbee.0
    2025-04-17 10:45:44.752	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
    host.nuc
    2025-04-17 10:45:43.990	info	instance system.adapter.zigbee.0 in version "3.0.0" started with pid 2762
    host.nuc
    2025-04-17 10:45:13.538	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.nuc
    2025-04-17 10:45:13.538	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.nuc
    2025-04-17 10:45:13.538	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.nuc
    2025-04-17 10:45:13.538	error	Caught by controller[1]: at Controller.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:382:47)
    host.nuc
    2025-04-17 10:45:13.538	error	Caught by controller[1]: at ZStackAdapter.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:908:49)
    host.nuc
    2025-04-17 10:45:13.538	error	Caught by controller[1]: at AdapterBackup.createBackup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:65:48)
    host.nuc
    2025-04-17 10:45:13.538	error	Caught by controller[1]: at AdapterBackup.getAdapterVersion (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:446:48)
    host.nuc
    2025-04-17 10:45:13.538	error	Caught by controller[1]: at Znp.requestWithReply (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:224:34)
    host.nuc
    2025-04-17 10:45:13.538	error	Caught by controller[1]: at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:240:19)
    host.nuc
    2025-04-17 10:45:13.538	error	Caught by controller[1]: Error: Cannot request when znp has not been initialized yet
    host.nuc
    2025-04-17 10:45:13.537	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    2025-04-17 10:45:13.453	info	terminating
    zigbee.0
    2025-04-17 10:45:13.273	info	Closing Zigbee network, 0 seconds remaining
    zigbee.0
    2025-04-17 10:45:12.950	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2025-04-17 10:45:12.950	info	terminating
    zigbee.0
    2025-04-17 10:45:12.950	info	Saved local configuration data
    zigbee.0
    2025-04-17 10:45:12.950	info	local config saved
    zigbee.0
    2025-04-17 10:45:12.950	info	cleaned everything up...
    zigbee.0
    2025-04-17 10:45:12.943	error	Cannot request when znp has not been initialized yet
    zigbee.0
    2025-04-17 10:45:12.943	error	Error: Cannot request when znp has not been initialized yet at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:240:19) at Znp.requestWithReply (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:224:34) at AdapterBackup.getAdapterVersion (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:446:48) at AdapterBackup.createBackup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:65:48) at ZStackAdapter.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:908:49) at Controller.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:382:47) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    zigbee.0
    2025-04-17 10:45:12.933	error	unhandled promise rejection: Cannot request when znp has not been initialized yet
    zigbee.0
    2025-04-17 10:45:12.933	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Hertliche Grüße aus Köln
    Fabio
    unhandled promise rejection.txt
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @fabio sagte in Tester Zigbee Adapter 3.x gesucht:
    Müssen wir beobachten. Passiert das immer nach längerer Laufzeit oder beim Start ?
    Hintergrund: ZNP not initialized deutet darauf hin das versucht wird Kommunikation mit einem Zigbee-Gerät zu initiieren bevor der Herdsman sauber läuft.
    A.
    L 1 Antwort Letzte Antwort
    • FabioF Online
      FabioF Online
      Fabio
      @asgothian das passiert im laufenden Betrieb ohne mein dazutun zu unterschiedlichen Zeiten und auch erst seit der v 3.0.
      Herzliche Grüße
      Fabio
      Iobroker:
      • Matter over Thread Hilfe
      • AsgothianA Asgothian
        A.
        locito09
        schrieb am zuletzt editiert von locito09
        @asgothian
        Habe bei den Flower sensor gemerkt das die Geräte die einwandfrei funktionieren der Status auf configured:false steht
        und die die nicht funktionieren steht der Status auf configured:true. Auch wen ich einen neuen Sensor anlerne steht der Status auf configured:True und Funktioniert nicht. Was kann das Problem sein?
        • FabioF Fabio
          Herzliche Grüße
          Fabio
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @fabio Kannst schauen was an Log Meldungen vor dem Fehler kommt ? Anscheinend startet der Adapter anstandslos neu - trotzdem ist die frage was er macht wenn der Fehler auftritt.
          A.
          FabioF 1 Antwort Letzte Antwort
          • L locito09
            @asgothian
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @locito09 ändert sich daran etwas wenn du versuchst die nicht funktionierenden Geräte neu zu konfigurieren ?
            Auffällig ist auch das die Firmware unterschiedlich alt ist.
            A.
              A.
              locito09
              @asgothian
              ja das habe ich auch schon bemerkt, ich habe insgesammt 10 stk und nur 1 davon hat eine ältere Firmware, aber Danke für den Hinweis. Habe alle 4 stk die nicht funktionieren neu Konfiguriert, jetzt sind die wieder online, werde die weiterhin beobachten. Das erneute Konmfigurieren wurde zwar im LOG mit einen Timeout Quittiert , die Geräte sind aber jetzt wieder Online und haben einen wert gesendet.
              zigbee.0
              2025-04-17 11:47:29.424	info	Timeout trying to configure 0x00124b002260a134 DIYRuZ_Flower (starting CoM).
              zigbee.0
              2025-04-17 11:47:19.411	info	Configuring 0x00124b002260a134 DIYRuZ_Flower
              zigbee.0
              2025-04-17 11:47:10.025	info	Timeout trying to configure 0x00124b0022607918 DIYRuZ_Flower (starting CoM).
              zigbee.0
              2025-04-17 11:47:00.897	info	Closing Zigbee network, 1 seconds remaining
              zigbee.0
              2025-04-17 11:47:00.011	info	Configuring 0x00124b0022607918 DIYRuZ_Flower
              zigbee.0
              2025-04-17 11:46:40.515	info	Timeout trying to configure 0x00124b00226296fc DIYRuZ_Flower (starting CoM).
              zigbee.0
              2025-04-17 11:46:30.499	info	Configuring 0x00124b00226296fc DIYRuZ_Flower
              • L locito09
                @asgothian
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @locito09 sagte in Tester Zigbee Adapter 3.x gesucht:
                @asgothian
                ich gehe davon aus das die ein 'configure_on_message' bekommen haben und deswegen jetzt wieder gehen
                  A.
                  FabioF Online
                  FabioF Online
                  Fabio
                  @asgothian okay, ich werde beim nächsten mal drauf achten. 👍
                  Jedes Mal innerhalb vom Sekunden neu gestartet und alles verbunden.👌
                  Fabio
                  Iobroker:
                  • FabioF Fabio
                    Fabio
                    FabioF Online
                    FabioF Online
                    Fabio
                    schrieb am zuletzt editiert von Fabio
                    @Asgothian hatte gestern einen zweiten cod.m Zigbee Coordinator in Betrieb genommen plus zweiter Instanz. Diese Nacht verlor er die Verbindung.
                    Das Log sagt aber leider nichts gravierendes aus:
                    zigbee.1
                    2025-04-18 01:00:55.254	info	Zigbee started
                    zigbee.1
                    2025-04-18 01:00:55.254	info	Currently 10 devices are joined:
                    zigbee.1
                    2025-04-18 01:00:55.254	info	0x001788010949ef8b (addr 1561): 9290019758 - Philips Hue motion outdoor sensor (EndDevice)
                    zigbee.1
                    2025-04-18 01:00:55.252	info	0x8c65a3fffe52151b (addr 57896): WG001 - Aeotec Range extender Zi (Router)
                    zigbee.1
                    2025-04-18 01:00:55.251	info	0x00158d0007bcedb8 (addr 41799): WXKG01LM - Xiaomi Mi wireless switch (EndDevice)
                    zigbee.1
                    2025-04-18 01:00:55.249	info	0x54ef4410001ba4c0 (addr 14573): SSM-U01 - Aqara Single switch module T1 (with neutral) (EndDevice)
                    zigbee.1
                    2025-04-18 01:00:55.248	info	0x7cb03eaa00a9573c (addr 37514): 4058075036147 - OSRAM Smart+ gardenpole 8.7W RGBW (Router)
                    zigbee.1
                    2025-04-18 01:00:55.247	info	0xb4e3f9fffe780ea4 (addr 3314): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                    zigbee.1
                    2025-04-18 01:00:55.245	info	0xa4c138c1c3e255be (addr 41578): A1Z - Nous Smart plug (with power monitoring) (Router)
                    zigbee.1
                    2025-04-18 01:00:55.242	info	0xec1bbdfffeb4e3e0 (addr 54356): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                    zigbee.1
                    2025-04-18 01:00:55.238	info	0x84fd27fffecf684c (addr 29163): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                    zigbee.1
                    2025-04-18 01:00:55.235	info	0x804b50fffee0f03d (addr 14812): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                    zigbee.1
                    2025-04-18 01:00:55.231	info	Unable to disable LED, unsupported function.
                    zigbee.1
                    2025-04-18 01:00:55.230	info	Zigbee-Herdsman started successfully with Coordinator firmware version: zStack3x0 : 20240710 (2-1.2.7.1)
                    zigbee.1
                    2025-04-18 01:00:53.994	info	Starting Zigbee-Herdsman
                    zigbee.1
                    2025-04-18 01:00:53.993	info	Installed Version: iobroker.zigbee@3.0.0 (Converters 23.27.0 Herdsman 3.5.1)
                    zigbee.1
                    2025-04-18 01:00:53.989	info	Starting Adapter npm ...
                    zigbee.1
                    2025-04-18 01:00:53.988	info	Try to reconnect.
                    zigbee.1
                    2025-04-18 01:00:43.958	error	Adapter disconnected, stopping
                    modbus.0
                    2025-04-18 00:51:58.375	warn	On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                    modbus.0
                    2025-04-18 00:51:58.375	error	Client in error state.
                    modbus.0
                    2025-04-18 00:51:58.373	error	Socket Error
                    zigbee.0
                    2025-04-18 00:19:15.418	info	Stopping to ping 0x84fd27fffecf6a54 TS011F after 6 ping attempts
                    alexa2.0
                    2025-04-18 00:18:17.285	info	Alexa-Push-Connection (macDms = true) established. Disable Polling
                    alexa2.0
                    2025-04-18 00:18:15.980	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
                    Herzliche Grüße
                    Fabio
                    Iobroker:
                    • FabioF Fabio
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      zigbee.1
                      modbus.0
                      modbus.0
                      modbus.0
                      zigbee.0
                      alexa2.0
                      alexa2.0
                      Herzliche Grüße
                      Fabio
                      Hattest du Netzwerkprobleme?
                        FabioF Online
                        FabioF Online
                        Fabio
                        @homoran nicht das ich wüßte.
                        Herzliche Grüße
                        Fabio
                        Iobroker:
                        • FabioF Fabio
                          Herzliche Grüße
                          Fabio
                          @fabio modbus und Alexa hatten auch Probleme
                            FabioF Online
                            FabioF Online
                            Fabio
                            @homoran nein der Alexa Adapter startet immer von alleine das ist normal.
                            Der Modbus macht das so, seid ich Ihn installiert habe. Den Heizstab den er ansteuert ist immer Online und sogar im LAN, aber lass uns das gerne in einem neuen Beitarg bereden.
                            Auffällig ist nur das ich diese Probleme erts mit der 3.0 bekommen habe, kann auch Zufall sein.
                            Fabio
                            Iobroker:
                              MeisterQ 0
                              @Asgothian
                              Bei mir kommt immer Folgendes beim Starten.
                              Ich habe ja den shellygen4 Externen converter laufen.
                              Welche herdsman converter version läuft da jetzt im Adapter?
                              zigbee.0
                              	2025-04-18 18:01:38.492	info	Ignoring converter from module: /opt/iobroker/iobroker-data/zigbee_0/shellygen4.js - see warn messages for reason
                              zigbee.0
                              	2025-04-18 18:01:38.491	error	Sandbox error: Cannot find module '../zigbee-herdsman-converters/dist/dist/lib/reporting' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                              zigbee.0
                              	2025-04-18 18:01:38.491	warn	trying to add "reporting = require(../zigbee-herdsman-converters/dist/dist/lib/reporting)" to sandbox
                              zigbee.0
                              	2025-04-18 18:01:38.491	error	Sandbox error: Cannot find module '../zigbee-herdsman-converters/dist/dist/lib/exposes' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                              zigbee.0
                              	2025-04-18 18:01:38.491	warn	trying to add "exposes = require(../zigbee-herdsman-converters/dist/dist/lib/exposes)" to sandbox
                              zigbee.0
                              	2025-04-18 18:01:38.491	error	Sandbox error: Cannot find module '../zigbee-herdsman-converters/dist/dist/converters/toZigbee' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                              zigbee.0
                              	2025-04-18 18:01:38.491	warn	trying to add "tz = require(../zigbee-herdsman-converters/dist/dist/converters/toZigbee)" to sandbox
                              zigbee.0
                              	2025-04-18 18:01:38.491	error	Sandbox error: Cannot find module '../zigbee-herdsman-converters/dist/dist/converters/fromZigbee' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                              zigbee.0
                              	2025-04-18 18:01:38.490	warn	trying to add "fz = require(../zigbee-herdsman-converters/dist/dist/converters/fromZigbee)" to sandbox
                              zigbee.0
                              	2025-04-18 18:01:38.490	error	Sandbox error: Cannot find module '../zigbee-herdsman-converters/dist/dist/lib/modernExtend' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                              zigbee.0
                              	2025-04-18 18:01:38.490	warn	trying to add "m = require(../zigbee-herdsman-converters/dist/dist/lib/modernExtend)" to sandbox
                              • M MeisterQ 0
                                @Asgothian
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @meisterq-0 welche Version läuft steht im log beim Start.
                                Nimm mal das /dist aus dem Pfad heraus, das fügt der Adapter (anscheinend in deinem Fall falsch) hinzu.
                                A.
                                  A.
                                  MeisterQ 0
                                  @asgothian
                                  Das scheint geholfen zu haben. Aber ich sehe gerade, dass er den Converter von vor 2 Tagen nimmt. Greift er jetzt immer auf die aktuellste Version zu beim Start?
                                  Weil er mir sagt er läuft 23.29.0. Das wäre eine ZHC Version von vor 2 Tagen.
                                  Damit kann ich meinen Converter dann auch löschen...
                                  • M MeisterQ 0
                                    @asgothian
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @meisterq-0 sagte in Tester Zigbee Adapter 3.x gesucht:
                                    @asgothian
                                    Solange die Version im latest ist nimmt sie die latest zhc, aber immer nur bei Installation
                                      @asgothian
                                      MeisterQ 0
                                      @asgothian Interessant zu wissen.
                                      Das heißt nur beim Update bekomme ich immer die neuste ZHC Version?
                                      Kann man nicht sporadisch (täglich) ggf den Adapter die ZHC Version prüfen und aktualisieren lassen bei Bedarf? Meinetwegen auch per Button in den Instanzeinstellungen oder so.
                                      So kann man viel schneller für Gerätesupport sorgen 🙏
                                      • M MeisterQ 0
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        Nein. Kann man nicht.
                                        Und in dem Moment wo die 3.x soweit kommt das sie ins Stable soll wird sie auch auf eine bestimmte ZH/ZHC Kombination fest geschrieben. Das Risiko das eine Änderung in. ZH/ZHC plötzlich Änderungen am Adapter erfordert ist zu gross. Siehe das Problem mit deinem externen Konverter. Ich dachte ich hätte das so umgebaut das beide Versionen sauber geprüft werden - das hat aber leider nicht so funktioniert wie ich das wollte.
                                        Und das zusätzliche /dist in den ZHC ist irgendwann innerhalb der 23.x dazu gekommen.
                                        A.
                                          A.
                                          MeisterQ 0
                                          @asgothian Schade. Naja ich weiß ja jetzt, dass ich die ZHC fast 1:1 in den Adapter als Externe Konverter übernehmen kann bis sie dann beim Update vom Adapter unterstützt werden.
                                          War nur so ein Gedankengang um den Usern zu ermöglichen schneller Gerätesupport bieten zu können.
