SONOFF NSPanel mit Lovelace UI (TypeScript Version)
NAch dem ich jetzt alles upgedatet habe, bekomme ich auch den Fehler nicht mehr.
Sollte jetzt eigentlich nicht standard mässig eine Konfig an das Panel geschickt werden? Ich weiß das man es noch konfiguren sollte, aber dei Doku gibt darüber keine Auskunft.
Bei mir steht immer noch "waiting for content"
Hier die log
javascript.0 11:57:20.327 info Compiling TypeScript source script.js.NSPanel.NSPanel1
javascript.0 11:57:22.515 info script.js.NSPanel.NSPanel1: source code did not change, using cached compilation result...
javascript.0 11:57:22.729 info script.js.NSPanel.NSPanel1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
javascript.0 11:57:22.750 info script.js.NSPanel.NSPanel1: setObjects enabled - create Alias Channels possible
javascript.0 11:57:22.770 info script.js.NSPanel.NSPanel1: weather alias for accuweather.0. already exists
javascript.0 11:57:22.942 info script.js.NSPanel.NSPanel1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
javascript.0 11:57:22.966 info script.js.NSPanel.NSPanel1: No Updates for NSPanel available
javascript.0 11:57:23.243 info script.js.NSPanel.NSPanel1: Desired TFT Firmware: 55 / v4.6.2
javascript.0 11:57:23.373 info script.js.NSPanel.NSPanel1: Debug mode disabled
javascript.0 11:57:24.269 info script.js.NSPanel.NSPanel1: hidden Cards disabled
javascript.0 11:57:27.447 info script.js.NSPanel.NSPanel1: Start MQTT-Port-Check -------------------------------------
javascript.0 11:57:27.448 info script.js.NSPanel.NSPanel1: -- admin.0 - 8081
javascript.0 11:57:27.448 info script.js.NSPanel.NSPanel1: -- mqtt.0 - 1883
javascript.0 11:57:27.449 info script.js.NSPanel.NSPanel1: -- mqtt.1 - 1884
javascript.0 11:57:27.449 info script.js.NSPanel.NSPanel1: -- node-red.0 - 1880
javascript.0 11:57:27.450 info script.js.NSPanel.NSPanel1: - MQTT-Port-Check OK: Instance of Adapter: mqtt.1 is running on Port:1884
javascript.0 11:57:27.450 info script.js.NSPanel.NSPanel1: End MQTT-Port-Check ---------------------------------------Mein Panel läuft separate im mqtt.1
@matthesjimte sagte in SONOFF NSPanel mit Lovelace UI:
Wird wahrscheinlich auch.
Sieh mal in den CustomSend vom mqtt.1
Wenn da etwas drin steht, dann bitte die Konfiguration der MQTT.1 Instanz nochmals überprüfen oder posten...
Kleiner Tipp... Der MQTT-Broker nutzt immer 2 Ports. Daher würde ich den Port vom MQTT sowohl im Panel, als auch in der MQTT.1 Instanz auf 1885 setzen.
Wahrscheinlich ist es nur eine Konfigurations-Kleinigkeit im MQTT.1-Adapter, die verhindert, dass der CustomSend abboniert wird.
Hier die log
Habe jetzt auf Port 1885 geändert,
Es tut sich auf jeden Fall schon mal mehr (danke für den Port Tipp) aber das Display bleibt immer noch bei "waiting for content"
mqtt.1 2025-04-06 12:55:58.556 info Client [DVES_987A78] publishOnSubscribe send all known states
mqtt.1 2025-04-06 12:55:58.553 info Client [DVES_987A78] publishOnSubscribe send all known states
mqtt.1 2025-04-06 12:55:58.549 info Client [DVES_987A78] publishOnSubscribe send all known states
mqtt.1 2025-04-06 12:55:58.354 info Client [DVES_987A78] subscribes on "cmnd/DVES_987A78_fb/#" with regex /^mqtt.1.cmnd.DVES_987A78_fb../
mqtt.1 2025-04-06 12:55:58.353 info Client [DVES_987A78] subscribes on "cmnd/DVES_987A78_fb/#" with regex /^cmnd.DVES_987A78_fb../
mqtt.1 2025-04-06 12:55:58.352 info Client [DVES_987A78] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt.1.SmartHome.tasmotas.cmnd../
mqtt.1 2025-04-06 12:55:58.351 info Client [DVES_987A78] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome.tasmotas.cmnd../
mqtt.1 2025-04-06 12:55:58.348 info Client [DVES_987A78] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt.1.SmartHome.NSPanel_1.cmnd../
mqtt.1 2025-04-06 12:55:58.346 info Client [DVES_987A78] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome.NSPanel_1.cmnd../
mqtt.1 2025-04-06 12:55:58.232 info Client [DVES_987A78] connected with secret 1743936958223_4108
mqtt.1 2025-04-06 12:55:53.055 info Starting MQTT authenticated server on 0.0.0.0:1885
mqtt.1 2025-04-06 12:55:52.889 info starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.18.3, js-controller: 7.0.6In CommandSend steht nur "time~13:02" drin, jetzt time~13:03
Sieht das so aus, als wenn das System was schickt, aber das Panel es nicht auf die Kette bekommt, es umzusetzen?
Habe jetzt nochnal neugestartet und bekommen folgende Warnung
script.js.NSPanel.NSPanel1: Object "system.adapter.undefined" does not exist
Hier die Log nach dem Starten
Sagen wir es mal so... Ich denke das NSPanel wird es auf die Kette bekommen, aber der MQTT.1 sendet die Nachrichten noch nicht wirklich an den das Panel...
Mit dem MQTT-Explorer funktioniert es in der Regel, den CustomSend zu abbonieren:
https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation#7-customsend-anlegenDer Austausch lässt sich auch im Tasmota beobachten, wenn man in der Konsole "weblog 4" einstellt.
Endlich es klappt.
Irgendwas hat mit dem CustomsSend nicht gestimmt, obwohl ich es über die Console angelegt hatte
Vielen, vielen Dank für den super (schnellen👍) Support
Endlich es klappt.
Prima - die Hürden sind überwunden und der eigentliche Spaßfaktor kann beginnen
Warum es ab und an zu diesen Problemchen mit dem CustomSend bei der Erstkonfiguration kommt, kann ich auch nicht sagen... Wenn er ihn erst einmal abonniert hat, dann gibt es auf Lebenszeit des Panels auch keine Probleme mehr...
zunächst mal Gratulation zu der tollen Arbeit die hier schon mit dem NSPanel geliefert wurden. Ist wirklich ein tolles Werkzeug.
Eine bitte hätte ich für meinen Gebrauch. Ich verwende einen MPD-Musikserver und auch den MPD-Adapter und würde gerne das NSPanel so wie es auch beim Sonos bzw Spotify Möglich ist hier die Bedienung über den MPD Adapter steuern. Wäre es auch möglich hier den MPD-Adapter zu unterstützen?
vG Etze
vG Etze
Was für Datenpunkte zur Steuerung werden vom Adapter angelegt.
Kannst du da ein paar Informationen liefern.
Zeige auch mal eine Übersicht der Datenpunkte.
Lege dazu bitte ein issues an auf Github. -
Hi Tom, danke für das rasche Feedback. Ich habe den issue wie gewünscht angelegt. Lass mich wissen, sollte ich mit weiteren Details unterstützen können.
https://github.com/joBr99/nspanel-lovelace-ui/issues/1321
vg
EtzeKannst das bitte auch hier eröffnen per c&p https://github.com/ticaki/ioBroker.nspanel-lovelace-ui
@ticaki
Hallo, habe ich gemacht....https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/issues/238
vG
Kannst die cardMedia für den Media Player Daemon (MPD) gerne testen
Ist aktuell noch im DEV v4.7.0.3 NSPanelTs.ts :
https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/DEV/NSPanelTs.ts
Folgende Funktionen sind aktuell implementiert:
- Standardelemente: Play, Pause, Stop (Power-Button), Next, Previous, Volume
- Shuffle über random (on/off)
- Repeat mit Single (Repeat Queue, Repeat Track, Repeat off)
- Wahlweise Seek (%) oder Crossfade (Sekunden) mit Klick auf das Player-Logo
- Playlist (gespeicherte Playlists werden in Queue geladen --> clear/load/play)
- Tracklist (Auswahl eines Titels in der aktuellen Queue)
- AOD (Always On Display)
- Automatische Erstellung des erforderlichen Media-Alias-Channels
// Variable for "Music Player Daemon (MDP) Adapter Instance" // Please do not use "const" as the arrays are actively used let MPD: PageType = { 'type': 'cardMedia', 'heading': 'MPD Client', 'hiddenByTrigger': true, 'items': [{ id: AliasPath + 'Media.PlayerMPD', // Path of the Media-Alias-Channel in alias.0. adapterPlayerInstance: 'mpd.0.', // Instance of the MDP-Server / MDP-Player speakerList: [], // Do not Delete or Change playList: [], // Do not Delete or Change colorMediaIcon: White, // Color of the Player-Icon colorMediaTitle: Yellow, // Color of Text-Row for Title (Row 1) colorMediaArtist: Yellow, // Color of Text-Row for Artist (Row 2) crossfade: true, // false = Seek; true = Crossfade in Logo of Player alwaysOnDisplay: true, // true = Always On Display (AOD); false = Dimmode and Screensaver-Timeout autoCreateALias : true // Create automatically required Media-Alias-Channel }] };
Viel Spaß beim Test
EDIT: Wenn der Test erfolgreich ist, schiebe ich das gerne ins Stable...
Viel Spaß beim Test
hallo, vielen Dank für die wirklich rasche Umsetzung. Ich komme erst morgen zum Player damit ich sehen kann wie die Musikausgabe funktioniert, aber die Datenpunkte reagieren und das Display auch!! Bin sehr zuversichtlich!!
Echt tolle Sache!!! Werden morgen noch mehr berichten!
vG
Etze -
vG
EtzeSag bescheid, wenn etwas fehlt ;-)
Update v4.6.0.1
Das Lights Update...
https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.tsHierfür bitte den unteren Teil austauschen:
Konfigurationsbeispiele aus den Abbildungen
let Test_Color_Lights_1: PageType = { type: 'cardEntities', useColor: true, heading: 'Test Color Lights 1', 'items': [ { id: 'alias.0.Haus.Obergeschoss.Bad.Licht.Emu_GU10_1', name: 'HUE (CT=Kelvin)', // HUE Channel - Philips WiZ GU10 über matter.0 - Color-Temperature in Kelvin icon: 'lightbulb-on', icon2: 'lightbulb-outline', offColor: Off, minValueColorTemp: 2203, // Kelvin = Warmweiß maxValueColorTemp: 6536, // Kelvin = Kaltweiß interpolateColor: true, modeList: ["Color", "Ocean", "Romantik", "Sonnenuntergang", "Party", "Kamin", "Gemütlich", "Wald", "Pastellfarben", "Aufwachen", "Schlafenszeit", "Warmweiß", "Tageslicht", "Kaltweiß", "Nachtlicht", "Fokus", "Entspannen", "Echte Farben", "Fernsehzeit", "Pflanzenwachstum", "Frühling", "Sommer", "Herbst", "Tieftauchgang", "Dschungel", "Mojito", "Club", "Weihnachten", "Halloween", "Kerzenlicht", "Goldenes Weiß", "Impuls", "Steampunk"], inSel_ChoiceState: true }, { id: 'alias.0.Haus.Obergeschoss.Schlafzimmer_2.Licht.Tradfri_GU10_3', name: 'RGB Hex (CT=Mired)', // RGBsingle Channel - IKEA Tradfri GU10 über zigbee.0 - Color-Temperature in Mired icon: 'lightbulb-on', icon2: 'lightbulb-outline', offColor: Off, minValueColorTemp: 500, // Mired = Warmweiß = 1.000.000 / 2000 K = 500 Mired maxValueColorTemp: 153, // Mired = Kaltweiß = 1.000.000 / 6536 K = 153 Mired interpolateColor: true, modeList: ["blink","breathe","okay","channel_change","finish_effect","stop_effect","colorloop","stop_colorloop"], inSel_ChoiceState: true }, { id: 'alias.0.Haus.Erdgeschoss.Wohnzimmer.Licht.E14_Fenster_Mitte_RGB', name: 'RGB (CT=Mired)', // RGB Channel - E14 Livarno Home Color über zigbee.0 - Color-Temperature in Mired icon: 'lightbulb-on', icon2: 'lightbulb-outline', offColor: Off, minValueColorTemp: 500, // Mired = Warmweiß = 1.000.000 / 2000 K = 500 Mired maxValueColorTemp: 153, // Mired = Kaltweiß = 1.000.000 / 6536 K = 153 Mired interpolateColor: true, modeList: ["blink","breathe","okay","channel_change","finish_effect","stop_effect","colorloop","stop_colorloop"], inSel_ChoiceState: true }, { //Übersetzungsdatenpunkt für XY in 0_useedata schreibt in X, Y von zigbee.0 id: 'alias.0.Haus.Erdgeschoss.Wohnzimmer.Licht.E14_Fenster_Rechts_CIE', name: 'CIE (CT=Mired)', // RGB Channel - E14 Livarno Home Color über zigbee.0 - Color-Temperature in Mired icon: 'lightbulb-on', icon2: 'lightbulb-outline', offColor: Off, minValueColorTemp: 500, // Mired = Warmweiß = 1.000.000 / 2000 K = 500 Mired maxValueColorTemp: 153, // Mired = Kaltweiß = 1.000.000 / 6536 K = 153 Mired interpolateColor: true, modeList: ["blink","breathe","okay","channel_change","finish_effect","stop_effect","colorloop","stop_colorloop"], inSel_ChoiceState: true }, ] }; let Test_CT_Lights_1: PageType = { type: 'cardEntities', useColor: true, heading: 'Test CT Lights 1', 'items': [ { id: 'alias.0.Haus.Erdgeschoss.Buero.Aktoren.Airbowl', name: 'Socket', // Socket Channel - Smart-Plug über sonoff.0 onColor: MSGreen, offColor: HMIOff, icon: 'power-plug', icon2: 'power-plug-outline' }, { id: 'alias.0.Haus.Erdgeschoss.Gaeste_WC.Licht.Deckenstrahler', name: 'Light', // Light Channel - Shelly 1L über shelly.0 onColor: On, offColor: Off, icon: 'lightbulb-on', icon2: 'lightbulb-outline', }, { id: 'alias.0.Haus.Erdgeschoss.Buero.Licht.Schreibtisch_GU10_mitte', name: 'Dimmer', // Dimmer Channel - IKEA Tradfri GU10 über zigbee.0 icon: 'lightbulb-on', icon2: 'lightbulb-outline', interpolateColor: true }, { id: 'alias.0.Haus.Erdgeschoss.Buero.Licht.Wand_GU10_mitte', name: 'CT (CT=Mired)', // CT Channel - Livarno Home GU10 über zigbee.0 icon: 'lightbulb-on', icon2: 'lightbulb-outline', offColor: Off, minValueColorTemp: 500, // Mired = Warmweiß = 1.000.000 / 2000 K = 500 Mired maxValueColorTemp: 153, // Mired = Kaltweiß = 1.000.000 / 6536 K = 153 Mired interpolateColor: true }, ] };NSPanelTS.ts
- Der Alias-Channel CIE (XY) kann ebenfalls verwendet werden
- Die Icons interpolieren jetzt Color mit Brightness und Color-Temperature mit Brightness
- Alle Lampen verfügen jetzt über 2 Icons (icon, icon2)
- Warmweiß ist default minValueColorTemp bei Kelvin (Achtung: bei Mired (insbesondere im Zigbee.0 vertreten), ist
Warmweiß500 undKaltweiß153) - diverse kleinere Bugs eliminiert
- popupLightNew (Alternative Slider sind im Script entfernt)
TFT
Es gab bei den TFT-Pictures Zuordnungsfehler die dazu geführt haben, dass Teile des
popupLightNewzu sehen waren, wenn die HintergrundfarbeBlackanstelle vonHMIDarkgewählt wurde.Blacksollte jetzt wieder normal funktionieren.FlashNextion http://nspanel.de/nspanel-v4.6.0.tft
cardQR
Im unteren Teil der cardQR lässt sich mit einem neuen Parameter im pageItem die Entity2 (Passwort oder der Schalter) ausblenden.
let WLAN: PageType = { type: 'cardQR', heading: 'Gäste WLAN', subPage: true, parent: Subpages_1, items: [ { id: 'alias.0.NSPanel.GuestWifi', hidePassword: true, // true = Switch; false = Password hideEntity2: true // true = Switch or Password is hide } ] };
Und jetzt viel Spaß mit der Überarbeitung
Hi, kann es sein das diese beiden links zum TFT Update für die US Version (noch) nicht funktionieren?
TFT US-L STABLE Version: http://nspanel.de/nspanel-us-l-v4.6.0.tft
TFT US-P STABLE Version: http://nspanel.de/nspanel-us-p-v4.6.0.tft -
TFT US-P STABLE Version: http://nspanel.de/nspanel-us-p-v4.6.0.tftStimmt... habs nochmal geprüft... ich muss die beiden US-Versionen noch nachziehen. Wird dann die v4.7.1 werden. Hatte mich bei den Erweiterungen für den Adapter zunächst auf die eu-Versionen konzentriert...
Welche Version setzt du ein? us-p oder us-l? Dann weiß ich womit ich beginnen kann ;-)
Update v4.7.1.2
PanelTs.ts v4.7.1.2
Unteren Teil ersetzen:
TFT 56 / v4.7.1
TFT EU STABLE Version:
FlashNextion http://nspanel.de/nspanel-v4.7.1.tftTFT US-L STABLE Version:
FlashNextion http://nspanel.de/nspanel-us-l-v4.7.1.tftTFT US-P STABLE Version:
FlashNextion http://nspanel.de/nspanel-us-p-v4.7.1.tft
Das Update beinhaltet:
den MPD-Player
// Variable for "Music Player Daemon (MDP) Adapter Instance" // Please do not use "const" as the arrays are actively used let MPD: PageType = { 'type': 'cardMedia', 'heading': 'MPD Client', 'hiddenByTrigger': true, 'items': [{ id: AliasPath + 'Media.PlayerMPD', // Path of the Media-Alias-Channel in alias.0. adapterPlayerInstance: 'mpd.0.', // Instance of the MDP-Server / MDP-Player speakerList: [], // Do not Delete or Change playList: [], // Do not Delete or Change playerMediaIcon: 'logo-mpd', // "logo-mpd" (Picture-Logo) or a Icon-Logo like "alpha-m-circle" (default) colorMediaIcon: White, // Color of the Player-Icon colorMediaTitle: Yellow, // Color of Text-Row for Title (Row 1) colorMediaArtist: Yellow, // Color of Text-Row for Artist (Row 2) crossfade: true, // false = Seek; true = Crossfade in Logo of Player alwaysOnDisplay: true, // true = Always On Display (AOD); false = Dimmode and Screensaver-Timeout autoCreateALias : true // Create automatically required Media-Alias-Channel }] };
Media Player mit Adapter-Logo (der Variable einfach unter items z.B. die Zeile
playerMediaIcon: 'logo-alexa',hinzufügen)folgende Logos sind möglich
- logo-alexa
- logo-bose
- logo-dlna (z.B. Squeezebox; Logitech)
- logo-mpd
- logo-sonos
- logo-spotify
- logo-volumio
- logo-alexa
Media Player mit Icon eigener Wahl (der Variable einfach unter items z.B. die Zeile
playerMediaIcon: "alpha-a-circle",hinzufügen)weitere Icons wie immer unter: https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/master/cheatsheet.html
Update v4.7.1.2
PanelTs.ts v4.7.1.2
TFT 56 / v4.7.1
den MPD-Player
- logo-alexa
- logo-bose
- logo-mpd
- logo-sonos
- logo-spotify
- logo-volumio
- logo-alexa
erst einmal ein großes Dankeschön für dieses tolle Forum und all die hilfreichen Beiträge – ich konnte mir schon sehr viel Wissen aneignen!
Aktuell habe ich jedoch ein Problem mit meinen beiden NSPanel-Skripten. Sie stürzen regelmäßig ab, sobald bestimmte Datenpunkte verwendet werden. Nach längerer Fehlersuche konnte ich das Problem scheinbar auf den Bereich mrIcon2ScreensaverEntity eingrenzen.
Solange ich z. B. folgenden Eintrag verwende, funktioniert alles stabil:
mrIcon2ScreensaverEntity: { ScreensaverEntity: NSPanel_Path + 'Relay.2', ScreensaverEntityIconOn: 'ceiling-light-multiple', ScreensaverEntityIconOff: null, ScreensaverEntityValue: null, ScreensaverEntityValueDecimalPlace: 0, ScreensaverEntityValueUnit: null, ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff }Sobald ich aber ScreensaverEntity durch z. B. mqtt.0.wled.All.state oder mqtt.0.zigbee2mqtt.AllWindows.state ersetze, crasht das Skript sofort, sobald sich der Status des Datenpunkts ändert.
Kurios: Beide Datenpunkte funktionieren einwandfrei unter mrIcon1ScreensaverEntity, aber eben nicht unter mrIcon2ScreensaverEntity.
Fehlerbild:
Nach Änderung des Status bricht das gesamte Skript (und alle weiteren) ab. Im ioBroker-Log erscheinen dann Meldungen wie:State "0_userdata.0.NSPanel.2.Relay." not foundEs sieht so aus, als ob das Skript weiterhin versucht, auf Relay. zuzugreifen, obwohl dieser gar nicht mehr verwendet wird – oder durch die neue Quelle ein Wert erwartet wird, der nicht im erwarteten Format vorliegt?
Logauszug (gekürzt):
Caught by controller[1]: State "0_userdata.0.NSPanel.2.Relay." not found Terminated (UNCAUGHT_EXCEPTION) Unhandled promise rejectionIch vermute, dass entweder ein Fehler beim Wechsel der Datenquelle auftritt. Ich bin aber leider nicht fit genug in JS um den Fehler selber zurückzuverfolgen.
Hat jemand eine Idee, woran das liegen könnte? Muss ich ggf. zusätzliche Abfragen einbauen oder das Format prüfen, bevor ich die Datenquelle eintrage?
Bin für jeden Hinweis dankbar!
Logs aus dem Skript sind jeweils identisch:
14.4.2025, 11:30:52.930 [warn ]: javascript.0 (2143) at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2924:47) 14.4.2025, 11:30:52.931 [warn ]: javascript.0 (2143) at step (script.js.NSPanel.nspanel_705674_PC:33:23) 14.4.2025, 11:30:52.931 [warn ]: javascript.0 (2143) at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53) 14.4.2025, 11:30:52.931 [warn ]: javascript.0 (2143) at script.js.NSPanel.nspanel_705674_PC:8:71 14.4.2025, 11:30:52.931 [warn ]: javascript.0 (2143) at __awaiter (script.js.NSPanel.nspanel_705674_PC:4:12) 14.4.2025, 11:30:52.931 [warn ]: javascript.0 (2143) at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2917:32) 14.4.2025, 11:30:52.933 [warn ]: javascript.0 (2143) at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2925:62) 14.4.2025, 11:30:52.933 [warn ]: javascript.0 (2143) at step (script.js.NSPanel.nspanel_705674_PC:33:23) 14.4.2025, 11:30:52.933 [warn ]: javascript.0 (2143) at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53) 14.4.2025, 11:30:52.934 [warn ]: javascript.0 (2143) at script.js.NSPanel.nspanel_705674_PC:8:71 14.4.2025, 11:30:53.040 [info ]: javascript.0 (2143) Stopping script script.js.NSPanel.nspanel_705674_PCIOBROKER Logs sind:
host.2b4bdf4ea464 2025-04-14 11:30:53.730 warn Do not restart adapter system.adapter.javascript.0 because restart loop detected host.2b4bdf4ea464 2025-04-14 11:30:53.730 info Restart adapter system.adapter.javascript.0 because enabled host.2b4bdf4ea464 2025-04-14 11:30:53.729 error instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.2b4bdf4ea464 2025-04-14 11:30:53.729 error Caught by controller[3]: State "0_userdata.0.NSPanel.1.Relay." not found host.2b4bdf4ea464 2025-04-14 11:30:53.728 error Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.2b4bdf4ea464 2025-04-14 11:30:53.728 error Caught by controller[1]: State "0_userdata.0.NSPanel.2.Relay." not found host.2b4bdf4ea464 2025-04-14 11:30:53.725 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: javascript.0 2025-04-14 11:30:53.538 info terminating mqtt.0 2025-04-14 11:30:53.094 info send2Server mqtt.0.TasmotaDevices.nspanel_0DBF90.cmnd.CustomSend[TasmotaDevices/nspanel_0DBF90/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.093 info send2Server mqtt.0.TasmotaDevices.nspanel_0DBF90.cmnd.CustomSend[TasmotaDevices/nspanel_0DBF90/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.090 info send2Server mqtt.0.TasmotaDevices.nspanel_0DBF90.cmnd.CustomSend[TasmotaDevices/nspanel_0DBF90/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.088 info send2Server mqtt.0.TasmotaDevices.nspanel_705674.cmnd.CustomSend[TasmotaDevices/nspanel_705674/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.086 info send2Server mqtt.0.TasmotaDevices.nspanel_705674.cmnd.CustomSend[TasmotaDevices/nspanel_705674/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.081 info send2Server mqtt.0.TasmotaDevices.nspanel_705674.cmnd.CustomSend[TasmotaDevices/nspanel_705674/cmnd/CustomSend] javascript.0 2025-04-14 11:30:53.059 warn Terminated (UNCAUGHT_EXCEPTION): Without reason javascript.0 2025-04-14 11:30:53.058 info terminating javascript.0 2025-04-14 11:30:53.047 error undefined javascript.0 2025-04-14 11:30:53.046 error unhandled promise rejection: undefined javascript.0 2025-04-14 11:30:53.046 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). javascript.0 2025-04-14 11:30:53.042 info Stopping script script.js.NSPanel.nspanel_0DBF90_Door javascript.0 2025-04-14 11:30:53.040 info Stopping script script.js.NSPanel.nspanel_705674_PC javascript.0 2025-04-14 11:30:53.038 info Stopping script script.js.common.Weather.CheckRain javascript.0 2025-04-14 11:30:52.952 error undefined javascript.0 2025-04-14 11:30:52.952 error unhandled promise rejection: undefined javascript.0 2025-04-14 11:30:52.951 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). javascript.0 2025-04-14 11:30:52.944 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.944 warn at script.js.NSPanel.nspanel_0DBF90_Door:8:71 javascript.0 2025-04-14 11:30:52.944 warn at Object.next (script.js.NSPanel.nspanel_0DBF90_Door:14:53) javascript.0 2025-04-14 11:30:52.944 warn at step (script.js.NSPanel.nspanel_0DBF90_Door:33:23) javascript.0 2025-04-14 11:30:52.944 warn at Object.<anonymous> (script.js.NSPanel.nspanel_0DBF90_Door:2925:62) javascript.0 2025-04-14 11:30:52.944 warn at setStateAsync (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2276:20) javascript.0 2025-04-14 11:30:52.944 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.943 warn at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2277:17 javascript.0 2025-04-14 11:30:52.943 warn State "0_userdata.0.NSPanel.1.Relay." not found javascript.0 2025-04-14 11:30:52.943 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38) javascript.0 2025-04-14 11:30:52.943 warn at Object.<anonymous> (script.js.NSPanel.nspanel_0DBF90_Door:2917:32) javascript.0 2025-04-14 11:30:52.943 warn at __awaiter (script.js.NSPanel.nspanel_0DBF90_Door:4:12) javascript.0 2025-04-14 11:30:52.943 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.943 warn at script.js.NSPanel.nspanel_0DBF90_Door:8:71 javascript.0 2025-04-14 11:30:52.942 warn at Object.next (script.js.NSPanel.nspanel_0DBF90_Door:14:53) javascript.0 2025-04-14 11:30:52.942 warn at step (script.js.NSPanel.nspanel_0DBF90_Door:33:23) javascript.0 2025-04-14 11:30:52.942 warn at Object.<anonymous> (script.js.NSPanel.nspanel_0DBF90_Door:2924:47) javascript.0 2025-04-14 11:30:52.937 warn getState "0_userdata.0.NSPanel.1.Relay." not found (3) javascript.0 2025-04-14 11:30:52.934 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.934 warn at script.js.NSPanel.nspanel_705674_PC:8:71 javascript.0 2025-04-14 11:30:52.933 warn at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53) javascript.0 2025-04-14 11:30:52.933 warn at step (script.js.NSPanel.nspanel_705674_PC:33:23) javascript.0 2025-04-14 11:30:52.933 warn at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2925:62) javascript.0 2025-04-14 11:30:52.933 warn at setStateAsync (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2276:20) javascript.0 2025-04-14 11:30:52.933 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.933 warn at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2277:17 javascript.0 2025-04-14 11:30:52.931 warn State "0_userdata.0.NSPanel.2.Relay." not found javascript.0 2025-04-14 11:30:52.931 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38) javascript.0 2025-04-14 11:30:52.931 warn at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2917:32) javascript.0 2025-04-14 11:30:52.931 warn at __awaiter (script.js.NSPanel.nspanel_705674_PC:4:12) javascript.0 2025-04-14 11:30:52.931 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.931 warn at script.js.NSPanel.nspanel_705674_PC:8:71 javascript.0 2025-04-14 11:30:52.931 warn at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53) javascript.0 2025-04-14 11:30:52.931 warn at step (script.js.NSPanel.nspanel_705674_PC:33:23) javascript.0 2025-04-14 11:30:52.930 warn at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2924:47) javascript.0 2025-04-14 11:30:52.916 warn getState "0_userdata.0.NSPanel.2.Relay." not found (3) -
Fehlerbild:
host.2b4bdf4ea464 2025-04-14 11:30:53.730 warn Do not restart adapter system.adapter.javascript.0 because restart loop detected host.2b4bdf4ea464 2025-04-14 11:30:53.730 info Restart adapter system.adapter.javascript.0 because enabled host.2b4bdf4ea464 2025-04-14 11:30:53.729 error instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.2b4bdf4ea464 2025-04-14 11:30:53.729 error Caught by controller[3]: State "0_userdata.0.NSPanel.1.Relay." not found host.2b4bdf4ea464 2025-04-14 11:30:53.728 error Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.2b4bdf4ea464 2025-04-14 11:30:53.728 error Caught by controller[1]: State "0_userdata.0.NSPanel.2.Relay." not found host.2b4bdf4ea464 2025-04-14 11:30:53.725 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: javascript.0 2025-04-14 11:30:53.538 info terminating mqtt.0 2025-04-14 11:30:53.094 info send2Server mqtt.0.TasmotaDevices.nspanel_0DBF90.cmnd.CustomSend[TasmotaDevices/nspanel_0DBF90/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.093 info send2Server mqtt.0.TasmotaDevices.nspanel_0DBF90.cmnd.CustomSend[TasmotaDevices/nspanel_0DBF90/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.090 info send2Server mqtt.0.TasmotaDevices.nspanel_0DBF90.cmnd.CustomSend[TasmotaDevices/nspanel_0DBF90/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.088 info send2Server mqtt.0.TasmotaDevices.nspanel_705674.cmnd.CustomSend[TasmotaDevices/nspanel_705674/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.086 info send2Server mqtt.0.TasmotaDevices.nspanel_705674.cmnd.CustomSend[TasmotaDevices/nspanel_705674/cmnd/CustomSend] mqtt.0 2025-04-14 11:30:53.081 info send2Server mqtt.0.TasmotaDevices.nspanel_705674.cmnd.CustomSend[TasmotaDevices/nspanel_705674/cmnd/CustomSend] javascript.0 2025-04-14 11:30:53.059 warn Terminated (UNCAUGHT_EXCEPTION): Without reason javascript.0 2025-04-14 11:30:53.058 info terminating javascript.0 2025-04-14 11:30:53.047 error undefined javascript.0 2025-04-14 11:30:53.046 error unhandled promise rejection: undefined javascript.0 2025-04-14 11:30:53.046 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). javascript.0 2025-04-14 11:30:53.042 info Stopping script script.js.NSPanel.nspanel_0DBF90_Door javascript.0 2025-04-14 11:30:53.040 info Stopping script script.js.NSPanel.nspanel_705674_PC javascript.0 2025-04-14 11:30:53.038 info Stopping script script.js.common.Weather.CheckRain javascript.0 2025-04-14 11:30:52.952 error undefined javascript.0 2025-04-14 11:30:52.952 error unhandled promise rejection: undefined javascript.0 2025-04-14 11:30:52.951 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). javascript.0 2025-04-14 11:30:52.944 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.944 warn at script.js.NSPanel.nspanel_0DBF90_Door:8:71 javascript.0 2025-04-14 11:30:52.944 warn at Object.next (script.js.NSPanel.nspanel_0DBF90_Door:14:53) javascript.0 2025-04-14 11:30:52.944 warn at step (script.js.NSPanel.nspanel_0DBF90_Door:33:23) javascript.0 2025-04-14 11:30:52.944 warn at Object.<anonymous> (script.js.NSPanel.nspanel_0DBF90_Door:2925:62) javascript.0 2025-04-14 11:30:52.944 warn at setStateAsync (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2276:20) javascript.0 2025-04-14 11:30:52.944 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.943 warn at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2277:17 javascript.0 2025-04-14 11:30:52.943 warn State "0_userdata.0.NSPanel.1.Relay." not found javascript.0 2025-04-14 11:30:52.943 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38) javascript.0 2025-04-14 11:30:52.943 warn at Object.<anonymous> (script.js.NSPanel.nspanel_0DBF90_Door:2917:32) javascript.0 2025-04-14 11:30:52.943 warn at __awaiter (script.js.NSPanel.nspanel_0DBF90_Door:4:12) javascript.0 2025-04-14 11:30:52.943 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.943 warn at script.js.NSPanel.nspanel_0DBF90_Door:8:71 javascript.0 2025-04-14 11:30:52.942 warn at Object.next (script.js.NSPanel.nspanel_0DBF90_Door:14:53) javascript.0 2025-04-14 11:30:52.942 warn at step (script.js.NSPanel.nspanel_0DBF90_Door:33:23) javascript.0 2025-04-14 11:30:52.942 warn at Object.<anonymous> (script.js.NSPanel.nspanel_0DBF90_Door:2924:47) javascript.0 2025-04-14 11:30:52.937 warn getState "0_userdata.0.NSPanel.1.Relay." not found (3) javascript.0 2025-04-14 11:30:52.934 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.934 warn at script.js.NSPanel.nspanel_705674_PC:8:71 javascript.0 2025-04-14 11:30:52.933 warn at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53) javascript.0 2025-04-14 11:30:52.933 warn at step (script.js.NSPanel.nspanel_705674_PC:33:23) javascript.0 2025-04-14 11:30:52.933 warn at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2925:62) javascript.0 2025-04-14 11:30:52.933 warn at setStateAsync (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2276:20) javascript.0 2025-04-14 11:30:52.933 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.933 warn at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2277:17 javascript.0 2025-04-14 11:30:52.931 warn State "0_userdata.0.NSPanel.2.Relay." not found javascript.0 2025-04-14 11:30:52.931 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38) javascript.0 2025-04-14 11:30:52.931 warn at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2917:32) javascript.0 2025-04-14 11:30:52.931 warn at __awaiter (script.js.NSPanel.nspanel_705674_PC:4:12) javascript.0 2025-04-14 11:30:52.931 warn at new Promise (<anonymous>) javascript.0 2025-04-14 11:30:52.931 warn at script.js.NSPanel.nspanel_705674_PC:8:71 javascript.0 2025-04-14 11:30:52.931 warn at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53) javascript.0 2025-04-14 11:30:52.931 warn at step (script.js.NSPanel.nspanel_705674_PC:33:23) javascript.0 2025-04-14 11:30:52.930 warn at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2924:47) javascript.0 2025-04-14 11:30:52.916 warn getState "0_userdata.0.NSPanel.2.Relay." not found (3)@sarlochin
Bitte benutze für die Lesbarkeit Code-Tags.
Ich habe das bereits für die meisten Logs nachgeholt (was ich beim Überfliegen sehen konnte), mag aber nicht den ganzen Post zeilenweise durchsuchen.
