  4. Test Adapter drops-weather 1.2.x
    6.7k
drops-weathermcm1957
196 Beiträge 21 Kommentatoren 44.3k Aufrufe 24 Beobachtet
    @winni sagte in Test Adapter drops-weather 1.1.x:
    so hatte ich das eingestellt.
    dann zeigt das log nur Errors
    bitte auf debug umstellen
    WinniW Offline
    WinniW Offline
    Winni
    #72
    @homoran jetzt so:
    host.raspberrypi
    2025-03-20 15:49:41.016	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    2025-03-20 15:49:40.497	info	stopInstance system.adapter.drops-weather.0 send kill signal
    drops-weather.0
    2025-03-20 15:49:40.494	error	Cannot read properties of null (reading 'pages')
    drops-weather.0
    2025-03-20 15:49:40.494	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
    drops-weather.0
    2025-03-20 15:49:40.492	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
    drops-weather.0
    2025-03-20 15:49:40.492	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    drops-weather.0
    2025-03-20 15:49:40.491	info	terminating
    drops-weather.0
    2025-03-20 15:49:40.490	debug	destroy browser
    drops-weather.0
    2025-03-20 15:49:40.489	info	Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi
    2025-03-20 15:49:40.486	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
    host.raspberrypi
    2025-03-20 15:49:40.486	info	"system.adapter.drops-weather.0" disabled
    drops-weather.0
    2025-03-20 15:49:40.442	debug	de
    drops-weather.0
    2025-03-20 15:49:40.434	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    drops-weather.0
    2025-03-20 15:49:40.433	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
    drops-weather.0
    2025-03-20 15:49:40.413	debug	getting system language
    drops-weather.0
    2025-03-20 15:49:40.412	info	browserPath set to puppeteer default
    drops-weather.0
    2025-03-20 15:49:40.412	info	browserMode set to automatic
    drops-weather.0
    2025-03-20 15:49:40.401	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
    • WinniW Winni
      @homoran jetzt so:
      host.raspberrypi
      host.raspberrypi
      drops-weather.0
      drops-weather.0
      drops-weather.0
      drops-weather.0
      drops-weather.0
      drops-weather.0
      drops-weather.0
      host.raspberrypi
      host.raspberrypi
      drops-weather.0
      drops-weather.0
      drops-weather.0
      drops-weather.0
      drops-weather.0
      drops-weather.0
      drops-weather.0
      #73
      jetzt so:
      wie geht das denn 😱 ??
      debug und error?
      WinniW NegaleinN 2 Antworten Letzte Antwort
        jetzt so:
        debug und error?
        WinniW Offline
        WinniW Offline
        Winni
        #74
        @homoran keine Ahnung, aber jetzt steht da nur noch debug, vielleicht war ich zu schnell..
        • WinniW Winni
          #75
          @winni das log passt auf jeden Fall.
          Da sollte jetzt alles für @mcm1957 drin sein
            jetzt so:
            debug und error?
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #76
            @homoran sagte in Test Adapter drops-weather 1.1.x:
            wie geht das denn ??
            Screenshot gleich nach speichern gemacht.
            Sobald der Adapter gestartet ist, steht da nur eins von denen.
            ° Fixer ---> iob fix
            • arteckA Offline
              arteckA Offline
              arteck
              #77
              so hab da mal was
              https://github.com/iobroker-community-adapters/ioBroker.drops-weather
              der adapter muss aber zuvor gelöscht werden (die id aus den einstellungen merken)
              dann installieren
              dann instanz hinzufügen
              dann starten
              es kann aber sein dass es paar zombie prozesse gibt .. also am besten den iobroker neu starten oder die prozesse killen
              dann erst den adapter starten
              sollte dann so aussehen
              kommt so eine meldung im LOG
              drops-weather.0
              2025-03-20 20:12:31.879	error	drops-weather.0 already running
              drops-weather.0
              2025-03-20 20:12:31.882	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              host.iobroker
              2025-03-20 20:12:32.436	error	instance system.adapter.drops-weather.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              dann sind da noch prozesse am laufen die gekillt werden müssen.. oder iob neu starten
              WinniW 1 Antwort Letzte Antwort
              • arteckA arteck
                so hab da mal was
                dann installieren
                dann starten
                drops-weather.0
                drops-weather.0
                host.iobroker
                WinniW Offline
                WinniW Offline
                Winni
                #78
                @arteck Hallo, funktioniert bei mir leider nicht. Habe den Adapter erst deinstalliert, iob gestoppt und neu gestartet. Dann den Adapter neu installiert. Hier der Log:
                host.raspberrypi
                2025-03-20 20:42:18.103	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                host.raspberrypi
                2025-03-20 20:42:17.538	info	stopInstance canceled schedule system.adapter.drops-weather.0
                host.raspberrypi
                2025-03-20 20:42:17.538	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
                host.raspberrypi
                2025-03-20 20:42:17.537	info	"system.adapter.drops-weather.0" disabled
                drops-weather.0
                2025-03-20 20:42:17.494	debug	de
                drops-weather.0
                2025-03-20 20:42:17.486	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                drops-weather.0
                2025-03-20 20:42:17.485	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                drops-weather.0
                2025-03-20 20:42:17.466	debug	getting system language
                drops-weather.0
                2025-03-20 20:42:17.466	info	browserPath set to puppeteer default
                drops-weather.0
                2025-03-20 20:42:17.465	info	browserMode set to automatic
                drops-weather.0
                2025-03-20 20:42:17.453	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather#df8b0a7231e71f2a89672d780c44b03675ed4dfe) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                • WinniW Winni
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  drops-weather.0
                  drops-weather.0
                  drops-weather.0
                  drops-weather.0
                  drops-weather.0
                  drops-weather.0
                  drops-weather.0
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  #79
                  @arteck hat den Adapter dankenswerter Weise nochmals überarbeitet und auf schedule Betrieb umgestellt. Er startet jetzt alle 5 Minuten als neuer Prozess. Das Problem der Zobieprozesse sollte dadurch gelöst sein.
                  Der Adapter steht in dieser Version nun als 1.2.0 nun zurVerfügung (ab morgen im LATEST).
                  Bei Tests auf meine Pi4 in den letzen Tagen hat dieser "halbwegs" funktioniert. Das halbwegs bezieht sich darauf, dass der Adapter in nicht vorhersehbarere Weise updates durch ein Timeout verweigert - mal gehen die Update stundenlang gut, dann kommen wieder timeouts ohne unterbrechung... Die Ursache dafür ist zumindest mir derzeit nicht klar. Eine Vergrößerung des Timeouts von 10 auf 15s hat keine Verbesserung gebracht.
                  Ich stellen den Adapter trotzdem mal zum Testen bereit - viulleicht zeigt sich ja da dann ein klareres Bild. Oder @arteck hat noch eine Idee wie / wo "man" suchen könnte.
                  mcm1957
                  EDIT:
                  mcm1957 about a minute ago
                  ACHTUNG:
                  Bitte vor der Installation der 1.2.0 den Adapter DEINSTALLIEREN. Vorher bitte die locationID notieren.
                  Siehe: https://forum.iobroker.net/topic/80335/test-adapter-drops-weather-1-1-x/77
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  Chris76eC S 3 Antworten Letzte Antwort
                  • mcm1957M mcm1957
                    mcm1957
                    EDIT:
                    ACHTUNG:
                    Chris76eC Offline
                    Chris76eC Offline
                    Chris76e
                    #80
                    @mcm1957
                    Auf meinem System Startet der immer wieder neu....
                    01
                    Log-Größe: 19.1 KB
                    Zeit
                    drops-weather.0
                    	2025-03-24 18:58:47.388	info	terminating
                    drops-weather.0
                    	2025-03-24 18:58:47.075	debug	Rain (data_1h): [{"label":"Mo 21:00","value":"0"},{"label":"Mo 22:00","value":"0"},{"label":"Mo 23:00","value":"0"},{"label":"Di 00:00","value":"0"},{"label":"Di 01:00","value":"0"},{"label":"Di 02:00","value":"0"},{"label":"Di 03:00","value":"0"},{"label":"Di 04:00","value":"0"},{"label":"Di 05:00","value":"0"},{"label":"Di 06:00","value":"0"},{"label":"Di 07:00","value":"0"},{"label":"Di 08:00","value":"0"},{"label":"Di 09:00","value":"0"},{"label":"Di 10:00","value":"0"},{"label":"Di 11:00","value":"0"},{"label":"Di 12:00","value":"0"},{"label":"Di 13:00","value":"0"},{"label":"Di 14:00","value":"0"},{"label":"Di 15:00","value":"0"},{"label":"Di 16:00","value":"0"},{"label":"Di 17:00","value":"0"},{"label":"Di 18:00","value":"0"},{"label":"Di 19:00","value":"0"},{"label":"Di 20:00","value":"0.1"}]
                    drops-weather.0
                    	2025-03-24 18:58:47.015	debug	Rain (data_5min): [{"label":"18:55","value":"0"},{"label":"19:00","value":"0"},{"label":"19:05","value":"0"},{"label":"19:10","value":"0"},{"label":"19:15","value":"0"},{"label":"19:20","value":"0"},{"label":"19:25","value":"0"},{"label":"19:30","value":"0"},{"label":"19:35","value":"0"},{"label":"19:40","value":"0"},{"label":"19:45","value":"0"},{"label":"19:50","value":"0"},{"label":"19:55","value":"0"},{"label":"20:00","value":"0"},{"label":"20:05","value":"0"},{"label":"20:10","value":"0"},{"label":"20:15","value":"0"},{"label":"20:20","value":"0"},{"label":"20:25","value":"0"},{"label":"20:30","value":"0"},{"label":"20:35","value":"0"},{"label":"20:40","value":"0"},{"label":"20:45","value":"0"},{"label":"20:50","value":"0"},{"label":"20:55","value":"0"},{"label":"21:00","value":"0"},{"label":"21:05","value":"0"},{"label":"21:10","value":"0"},{"label":"21:15","value":"0"},{"label":"21:20","value":"0"},{"label":"21:25","value":"0"},{"label":"21:30","value":"0"},{"label":"21:35","value":"0"},{"label":"21:40","value":"0"},{"label":"21:45","value":"0"},{"label":"21:50","value":"0"},{"label":"21:55","value":"0"},{"label":"22:00","value":"0"}]
                    drops-weather.0
                    	2025-03-24 18:58:46.902	info	Terminated (NO_ERROR): Without reason
                    drops-weather.0
                    	2025-03-24 18:58:46.900	info	terminating
                    drops-weather.0
                    	2025-03-24 18:58:46.883	debug	destroy browser
                    drops-weather.0
                    	2025-03-24 18:58:46.882	debug	creating 1 hour states
                    drops-weather.0
                    	2025-03-24 18:58:46.881	debug	creating 5 min states
                    drops-weather.0
                    	2025-03-24 18:58:46.881	debug	weatherData found
                    drops-weather.0
                    	2025-03-24 18:58:46.877	debug	got labeltext "It will stay dry for now"
                    drops-weather.0
                    	2025-03-24 18:58:46.873	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T17:55:00Z\",\"timestamp\":1742838900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:05:00Z\",\"timestamp\":1742839500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:10:00Z\",\"timestamp\":1742839800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:15:00Z\",\"timestamp\":1742840100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:20:00Z\",\"timestamp\":1742840400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:25:00Z\",\"timestamp\":1742840700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:30:00Z\",\"timestamp\":1742841000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:35:00Z\",\"timestamp\":1742841300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:40:00Z\",\"timestamp\":1742841600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:45:00Z\",\"timestamp\":1742841900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:50:00Z\",\"timestamp\":1742842200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:55:00Z\",\"timestamp\":1742842500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:05:00Z\",\"timestamp\":1742843100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:10:00Z\",\"timestamp\":1742843400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:15:00Z\",\"timestamp\":1742843700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:20:00Z\",\"timestamp\":1742844000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:25:00Z\",\"timestamp\":1742844300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:30:00Z\",\"timestamp\":1742844600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:35:00Z\",\"timestamp\":1742844900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:40:00Z\",\"timestamp\":1742845200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:45:00Z\",\"timestamp\":1742845500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:50:00Z\",\"timestamp\":1742845800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:55:00Z\",\"timestamp\":1742846100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:05:00Z\",\"timestamp\":1742846700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:10:00Z\",\"timestamp\":1742847000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:15:00Z\",\"timestamp\":1742847300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:20:00Z\",\"timestamp\":1742847600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:25:00Z\",\"timestamp\":1742847900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:30:00Z\",\"timestamp\":1742848200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:35:00Z\",\"timestamp\":1742848500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:40:00Z\",\"timestamp\":1742848800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:45:00Z\",\"timestamp\":1742849100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:50:00Z\",\"timestamp\":1742849400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:55:00Z\",\"timestamp\":1742849700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000}],\"daypart\":[{\"precipitationrate\":0.0,\"time\":\"2025-03-24T17:00:00Z\",\"timestamp\":1742835600,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.12,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADBBB\",\"source\":\"radar-nl\",\"timestamp\":1742838300}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T22:00:00Z\",\"timestamp\":1742853600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T23:00:00Z\",\"timestamp\":1742857200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T00:00:00Z\",\"timestamp\":1742860800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T01:00:00Z\",\"timestamp\":1742864400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T02:00:00Z\",\"timestamp\":1742868000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T03:00:00Z\",\"timestamp\":1742871600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T04:00:00Z\",\"timestamp\":1742875200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T05:00:00Z\",\"timestamp\":1742878800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T06:00:00Z\",\"timestamp\":1742882400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T07:00:00Z\",\"timestamp\":1742886000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T08:00:00Z\",\"timestamp\":1742889600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T09:00:00Z\",\"timestamp\":1742893200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T10:00:00Z\",\"timestamp\":1742896800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T11:00:00Z\",\"timestamp\":1742900400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T12:00:00Z\",\"timestamp\":1742904000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T13:00:00Z\",\"timestamp\":1742907600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T14:00:00Z\",\"timestamp\":1742911200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T15:00:00Z\",\"timestamp\":1742914800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T16:00:00Z\",\"timestamp\":1742918400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T17:00:00Z\",\"timestamp\":1742922000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T18:00:00Z\",\"timestamp\":1742925600},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T19:00:00Z\",\"timestamp\":1742929200}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.115,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADB\",\"source\":\"weathercomputer\",\"timestamp\":1742838984}}},"," timezoneOffset: 60,"," locals: {\"labels\":[[0,\"dry\"],[0.1,\"drizzle\"],[1,\"light rain\"],[2,\"heavy rain\"]],\"language\":\"en\",\"strings\":{\"unavailable\":\"Something went wrong\",\"mmph\":\"mm per hour\",\"now\":\"now\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
                    drops-weather.0
                    	2025-03-24 18:58:46.865	debug	domcontent loaded, evaluate page
                    drops-weather.0
                    	2025-03-24 18:58:44.910	debug	creating new page ...
                    drops-weather.0
                    	2025-03-24 18:58:44.909	debug	Reading data from : https://www.meteox.com/en-gb/city/2937543
                    drops-weather.0
                    	2025-03-24 18:58:44.569	debug	de
                    drops-weather.0
                    	2025-03-24 18:58:44.532	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors"]}
                    drops-weather.0
                    	2025-03-24 18:58:44.531	debug	getting system language
                    drops-weather.0
                    	2025-03-24 18:58:44.530	debug	browserPath set to puppeteer default
                    drops-weather.0
                    	2025-03-24 18:58:44.530	debug	browserMode set to automatic, running on linux / x64
                    drops-weather.0
                    	2025-03-24 18:58:44.511	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                    drops-weather.0
                    	2025-03-24 18:58:05.945	info	terminating
                    drops-weather.0
                    	2025-03-24 18:58:05.565	debug	Rain (data_1h): [{"label":"Mo 21:00","value":"0"},{"label":"Mo 22:00","value":"0"},{"label":"Mo 23:00","value":"0"},{"label":"Di 00:00","value":"0"},{"label":"Di 01:00","value":"0"},{"label":"Di 02:00","value":"0"},{"label":"Di 03:00","value":"0"},{"label":"Di 04:00","value":"0"},{"label":"Di 05:00","value":"0"},{"label":"Di 06:00","value":"0"},{"label":"Di 07:00","value":"0"},{"label":"Di 08:00","value":"0"},{"label":"Di 09:00","value":"0"},{"label":"Di 10:00","value":"0"},{"label":"Di 11:00","value":"0"},{"label":"Di 12:00","value":"0"},{"label":"Di 13:00","value":"0"},{"label":"Di 14:00","value":"0"},{"label":"Di 15:00","value":"0"},{"label":"Di 16:00","value":"0"},{"label":"Di 17:00","value":"0"},{"label":"Di 18:00","value":"0"},{"label":"Di 19:00","value":"0"},{"label":"Di 20:00","value":"0.1"}]
                    drops-weather.0
                    	2025-03-24 18:58:05.555	debug	Rain (data_5min): [{"label":"18:55","value":"0"},{"label":"19:00","value":"0"},{"label":"19:05","value":"0"},{"label":"19:10","value":"0"},{"label":"19:15","value":"0"},{"label":"19:20","value":"0"},{"label":"19:25","value":"0"},{"label":"19:30","value":"0"},{"label":"19:35","value":"0"},{"label":"19:40","value":"0"},{"label":"19:45","value":"0"},{"label":"19:50","value":"0"},{"label":"19:55","value":"0"},{"label":"20:00","value":"0"},{"label":"20:05","value":"0"},{"label":"20:10","value":"0"},{"label":"20:15","value":"0"},{"label":"20:20","value":"0"},{"label":"20:25","value":"0"},{"label":"20:30","value":"0"},{"label":"20:35","value":"0"},{"label":"20:40","value":"0"},{"label":"20:45","value":"0"},{"label":"20:50","value":"0"},{"label":"20:55","value":"0"},{"label":"21:00","value":"0"},{"label":"21:05","value":"0"},{"label":"21:10","value":"0"},{"label":"21:15","value":"0"},{"label":"21:20","value":"0"},{"label":"21:25","value":"0"},{"label":"21:30","value":"0"},{"label":"21:35","value":"0"},{"label":"21:40","value":"0"},{"label":"21:45","value":"0"},{"label":"21:50","value":"0"},{"label":"21:55","value":"0"},{"label":"22:00","value":"0"}]
                    drops-weather.0
                    	2025-03-24 18:58:05.491	info	Terminated (NO_ERROR): Without reason
                    drops-weather.0
                    	2025-03-24 18:58:05.489	info	terminating
                    drops-weather.0
                    	2025-03-24 18:58:05.439	debug	destroy browser
                    drops-weather.0
                    	2025-03-24 18:58:05.438	debug	creating 1 hour states
                    drops-weather.0
                    	2025-03-24 18:58:05.435	debug	creating 5 min states
                    drops-weather.0
                    	2025-03-24 18:58:05.435	debug	weatherData found
                    drops-weather.0
                    	2025-03-24 18:58:05.431	debug	got labeltext "It will stay dry for now"
                    drops-weather.0
                    	2025-03-24 18:58:05.429	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T17:55:00Z\",\"timestamp\":1742838900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:05:00Z\",\"timestamp\":1742839500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:10:00Z\",\"timestamp\":1742839800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:15:00Z\",\"timestamp\":1742840100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:20:00Z\",\"timestamp\":1742840400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:25:00Z\",\"timestamp\":1742840700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:30:00Z\",\"timestamp\":1742841000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:35:00Z\",\"timestamp\":1742841300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:40:00Z\",\"timestamp\":1742841600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:45:00Z\",\"timestamp\":1742841900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:50:00Z\",\"timestamp\":1742842200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:55:00Z\",\"timestamp\":1742842500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:05:00Z\",\"timestamp\":1742843100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:10:00Z\",\"timestamp\":1742843400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:15:00Z\",\"timestamp\":1742843700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:20:00Z\",\"timestamp\":1742844000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:25:00Z\",\"timestamp\":1742844300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:30:00Z\",\"timestamp\":1742844600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:35:00Z\",\"timestamp\":1742844900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:40:00Z\",\"timestamp\":1742845200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:45:00Z\",\"timestamp\":1742845500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:50:00Z\",\"timestamp\":1742845800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:55:00Z\",\"timestamp\":1742846100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:05:00Z\",\"timestamp\":1742846700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:10:00Z\",\"timestamp\":1742847000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:15:00Z\",\"timestamp\":1742847300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:20:00Z\",\"timestamp\":1742847600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:25:00Z\",\"timestamp\":1742847900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:30:00Z\",\"timestamp\":1742848200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:35:00Z\",\"timestamp\":1742848500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:40:00Z\",\"timestamp\":1742848800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:45:00Z\",\"timestamp\":1742849100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:50:00Z\",\"timestamp\":1742849400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:55:00Z\",\"timestamp\":1742849700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000}],\"daypart\":[{\"precipitationrate\":0.0,\"time\":\"2025-03-24T17:00:00Z\",\"timestamp\":1742835600,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.12,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADBBB\",\"source\":\"radar-nl\",\"timestamp\":1742838300}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T22:00:00Z\",\"timestamp\":1742853600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T23:00:00Z\",\"timestamp\":1742857200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T00:00:00Z\",\"timestamp\":1742860800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T01:00:00Z\",\"timestamp\":1742864400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T02:00:00Z\",\"timestamp\":1742868000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T03:00:00Z\",\"timestamp\":1742871600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T04:00:00Z\",\"timestamp\":1742875200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T05:00:00Z\",\"timestamp\":1742878800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T06:00:00Z\",\"timestamp\":1742882400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T07:00:00Z\",\"timestamp\":1742886000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T08:00:00Z\",\"timestamp\":1742889600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T09:00:00Z\",\"timestamp\":1742893200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T10:00:00Z\",\"timestamp\":1742896800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T11:00:00Z\",\"timestamp\":1742900400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T12:00:00Z\",\"timestamp\":1742904000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T13:00:00Z\",\"timestamp\":1742907600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T14:00:00Z\",\"timestamp\":1742911200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T15:00:00Z\",\"timestamp\":1742914800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T16:00:00Z\",\"timestamp\":1742918400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T17:00:00Z\",\"timestamp\":1742922000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T18:00:00Z\",\"timestamp\":1742925600},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T19:00:00Z\",\"timestamp\":1742929200}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.115,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADB\",\"source\":\"weathercomputer\",\"timestamp\":1742838984}}},"," timezoneOffset: 60,"," locals: {\"labels\":[[0,\"dry\"],[0.1,\"drizzle\"],[1,\"light rain\"],[2,\"heavy rain\"]],\"language\":\"en\",\"strings\":{\"unavailable\":\"Something went wrong\",\"mmph\":\"mm per hour\",\"now\":\"now\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
                    drops-weather.0
                    	2025-03-24 18:58:05.427	debug	domcontent loaded, evaluate page
                    drops-weather.0
                    	2025-03-24 18:58:02.955	debug	creating new page ...
                    drops-weather.0
                    	2025-03-24 18:58:02.955	debug	Reading data from : https://www.meteox.com/en-gb/city/2937543
                    drops-weather.0
                    	2025-03-24 18:58:02.621	debug	de
                    drops-weather.0
                    	2025-03-24 18:58:02.561	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors"]}
                    drops-weather.0
                    	2025-03-24 18:58:02.561	debug	getting system language
                    drops-weather.0
                    	2025-03-24 18:58:02.560	debug	browserPath set to puppeteer default
                    drops-weather.0
                    	2025-03-24 18:58:02.560	debug	browserMode set to automatic, running on linux / x64
                    drops-weather.0
                    	2025-03-24 18:58:02.525	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                    drops-weather.0
                    	2025-03-24 18:57:48.137	info	terminating
                    drops-weather.0
                    	2025-03-24 18:57:47.641	info	Terminated (NO_ERROR): Without reason
                    • mcm1957M mcm1957
                      mcm1957
                      EDIT:
                      ACHTUNG:
                      Sleepwalker
                      #81
                      @mcm1957
                      Moin!
                      [OT]
                      Da demnächst die Gartensaison wieder startet und ich unseren Rasimir entstauben will, fiel mein Blick die Tage Richtung Drops-Adapter, den ich seit vielen Monden wegen eines Axios-Fehlers deaktiviert hatte.
                      Nun sehe ich, dass sich dem Adapter schon angenommen wurde und wollte ein herzliches "Danke" hierlassen! Ich freue mich drauf, den Adapter ab morgen "offiziell" im Latest-Repo begrüßen zu dürfen.
                      Bei mir läuft ioBroker auch noch im Container auf einem Pi4 mit Bullseye. Habe mich noch nicht getraut auf Bookworm zu aktualisieren :D
                      Ich stelle mich gerne als Tester zur Verfügung, für mehr reicht meine (Frei-)Zeit aktuell leider nicht, auch wenn ich selbst Software entwickele. Echt stark, dass sich jemand dem Adapter annimmt. Er hat sich zu meinem Liebling unter den Regenwarnern gemausert.
                      Vielen Dank nochmal an euch!
                      [/OT]
                      • Chris76eC Chris76e
                        @mcm1957
                        01
                        Log-Größe: 19.1 KB
                        Zeit
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        #82
                        @chris76e
                        Das ist das normale Verhalten für einen SCHEDULED Adapter. Dieser startet gemäß cron einstellungen, erledigt seine Aufgabe und beendet sich dann wieder.
                        • mcm1957M mcm1957
                          mcm1957
                          EDIT:
                          ACHTUNG:
                          Chris76eC Offline
                          Chris76eC Offline
                          Chris76e
                          #83
                          @mcm1957 sagte in Test Adapter drops-weather 1.1.x:
                          Habe das so verstanden das er das alle 5 Minuten macht und nicht ständig.
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #84
                            @chris76e
                            Ok, ja sollte er nur alle 5 Minuten machen, genauer (derzeit) immer wenn die Minutenanzahl durch 5 teilbar ist (5, 10, 15, ...)
                            ABER auch direkt nach der Installation oder nach dem Ändern von Parametern zusätzlich einmal.
                            Chris76eC mcm1957M 2 Antworten Letzte Antwort
                            • mcm1957M mcm1957
                              @chris76e
                              Chris76eC Offline
                              Chris76eC Offline
                              Chris76e
                              #85
                              @mcm1957
                              so sieht es bei mir aus:
                              drops-weather.0
                              	2025-03-24 19:16:44.345	info	terminating
                              drops-weather.0
                              	2025-03-24 19:16:43.849	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:16:43.848	info	terminating
                              drops-weather.0
                              	2025-03-24 19:16:41.245	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:16:33.864	info	terminating
                              drops-weather.0
                              	2025-03-24 19:16:33.389	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:16:33.387	info	terminating
                              drops-weather.0
                              	2025-03-24 19:16:30.720	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:16:23.445	info	terminating
                              drops-weather.0
                              	2025-03-24 19:16:22.952	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:16:22.951	info	terminating
                              drops-weather.0
                              	2025-03-24 19:16:20.205	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:16:12.670	info	terminating
                              drops-weather.0
                              	2025-03-24 19:16:12.171	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:16:12.170	info	terminating
                              drops-weather.0
                              	2025-03-24 19:16:09.570	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:16:02.063	info	terminating
                              drops-weather.0
                              	2025-03-24 19:16:01.564	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:16:01.563	info	terminating
                              drops-weather.0
                              	2025-03-24 19:15:58.740	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:15:47.979	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:15:47.979	info	terminating
                              drops-weather.0
                              	2025-03-24 19:15:45.209	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:15:37.552	info	terminating
                              drops-weather.0
                              	2025-03-24 19:15:37.061	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:15:37.060	info	terminating
                              drops-weather.0
                              	2025-03-24 19:15:28.333	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:15:20.443	info	terminating
                              drops-weather.0
                              	2025-03-24 19:15:19.947	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:15:19.947	info	terminating
                              drops-weather.0
                              	2025-03-24 19:15:17.148	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:15:08.618	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:15:08.618	info	terminating
                              drops-weather.0
                              	2025-03-24 19:15:05.650	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:14:54.896	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:54.401	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:14:54.400	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:51.649	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:14:44.832	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:44.338	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:14:44.338	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:41.840	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:14:34.264	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:33.838	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:14:33.837	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:30.789	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:14:23.180	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:14:23.180	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:20.282	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:14:13.210	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:12.719	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:14:12.718	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:10.193	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:14:03.230	info	terminating
                              drops-weather.0
                              	2025-03-24 19:14:02.740	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:14:02.739	info	terminating
                              drops-weather.0
                              	2025-03-24 19:13:59.884	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:13:51.804	info	terminating
                              drops-weather.0
                              	2025-03-24 19:13:51.311	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0
                              	2025-03-24 19:13:51.310	info	terminating
                              drops-weather.0
                              	2025-03-24 19:13:48.751	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              drops-weather.0
                              	2025-03-24 19:13:39.050	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              drops-weather.0
                              	2025-03-24 19:13:39.050	info	terminating
                              • mcm1957M mcm1957
                                @chris76e
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #86
                                ACHTUNG:
                                @Chris76e - vermute mal dass ist das Problem bei dir.
                                Chris76eC 1 Antwort Letzte Antwort
                                • mcm1957M mcm1957
                                  ACHTUNG:
                                  Chris76eC Offline
                                  Chris76eC Offline
                                  Chris76e
                                  #87
                                  @mcm1957
                                  das war es, nach neuinstallation läuft es richtig.
                                  Der DP
                                  drops-weather.0.data_1h.labeltext
                                  ist jetzt jetzt nicht mehr deutsch....
                                    @mcm1957
                                    Der DP
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #88
                                    @chris76e said in Test Adapter drops-weather 1.1.x:
                                    Der DP
                                    Copy to Clipboarddrops-weather.0.data_1h.labeltext
                                    Copy to ClipboardIt will stay dry for now
                                    Habs mal erfasst: https://github.com/iobroker-community-adapters/ioBroker.drops-weather/issues/117
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #89
                                      guck ich mir an
                                      • arteckA arteck
                                        guck ich mir an
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        #90
                                        Sprachsupport wurde von @arteck implementiert und ist nun (bzw. ab morgen im latest) in V1.2.1 verfügbar.
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #91
                                          ich hab gerade noch was hochgeladen auf GIT
                                          alle die den adapter schon laufen hatten bitte einmal ausfürhre
                                          find /tmp -type d -name "puppeteer_dev*" -exec rm -rf {} +
                                          hab gerade festgestellt dass puppeteer die platte voll müllt..es werden temp dateien angelegt halt im tmp ordner...
