  4. Test Adapter drops-weather 1.2.x
    6.7k
drops-weathermcm1957
196 Beiträge 21 Kommentatoren 44.3k Aufrufe 24 Beobachtet
  • mcm1957M mcm1957
    @winni
    Kannst du bitte mal mit debug Level starten und das log posten?
    Ist aber nicht prior - muss dann weg und kann erst nachher in Code schaun.
    WinniW Offline
    WinniW Offline
    Winni
    @mcm1957, ok
    drops-weather.0
    2025-03-20 08:50:23.836	error	Cannot read properties of null (reading 'pages')
    drops-weather.0
    2025-03-20 08:50:23.836	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
    drops-weather.0
    2025-03-20 08:50:23.834	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
    drops-weather.0
    2025-03-20 08:50:23.834	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    drops-weather.0
    2025-03-20 08:50:23.832	info	terminating
    drops-weather.0
    2025-03-20 08:50:23.830	info	Got terminate signal TERMINATE_YOURSELF
    drops-weather.0
    2025-03-20 08:50:23.803	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    drops-weather.0
    2025-03-20 08:50:23.801	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
    drops-weather.0
    2025-03-20 08:50:23.775	info	browserPath set to puppeteer default
    drops-weather.0
    2025-03-20 08:50:23.772	info	browserMode set to automatic
    drops-weather.0
    2025-03-20 08:50:23.760	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
    • arteckA Offline
      arteckA Offline
      arteck
      so für alle..
      das wird nix.. wir müssen den auf cron umstellen..
      ich bitte um Geduld
      mcm1957M ? 2 Antworten Letzte Antwort
      • arteckA arteck
        so für alle..
        ich bitte um Geduld
        mcm1957M Offline
        mcm1957M Offline
        mcm1957
        @arteck said in Test Adapter drops-weather 1.1.x:
        so für alle..
        ich bitte um Geduld
        @arteck
        Ich nehm an du meinst damit umstellen auf scheduled adapter.
        Machst du das? Oder brauchts du Support? (wobei ich nicht bös bin wenn du das machst, bin eh ausgelastet).
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • WinniW Winni
          @mcm1957, ok
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          mcm1957M Offline
          mcm1957M Offline
          mcm1957
          #66
          @winni said in Test Adapter drops-weather 1.1.x:
          @mcm1957, ok
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          drops-weather.0
          Hmm - das ist aber nicht DEBUG Level log :-)
          WinniW 1 Antwort Letzte Antwort
          • arteckA arteck
            so für alle..
            ich bitte um Geduld
            #67
            @arteck
            um's Choas kompletty zu machen, es gibt auch noch Fetch... :)
            https://www.zenrows.com/blog/axios-vs-got-vs-fetch#which-is-best
            Ihr seit schon hartnaeckig, das muss man sagen! geht nicht - gibts net.. 👍 👍 👍 👍
            • mcm1957M mcm1957
              @mcm1957, ok
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              WinniW Offline
              WinniW Offline
              Winni
              #68
              @mcm1957 meinst du so?
              Zeit
              info
              Nachricht
              host.raspberrypi
              2025-03-20 15:03:02.764	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.raspberrypi
              2025-03-20 15:03:02.233	info	stopInstance system.adapter.drops-weather.0 send kill signal
              drops-weather.0
              2025-03-20 15:03:02.229	error	Cannot read properties of null (reading 'pages')
              drops-weather.0
              2025-03-20 15:03:02.228	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
              drops-weather.0
              2025-03-20 15:03:02.226	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
              drops-weather.0
              2025-03-20 15:03:02.222	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              host.raspberrypi
              2025-03-20 15:03:02.211	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
              host.raspberrypi
              2025-03-20 15:03:02.209	info	"system.adapter.drops-weather.0" disabled
              drops-weather.0
              2025-03-20 15:03:02.167	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
              host.raspberrypi
              2025-03-20 15:03:00.760	info	instance system.adapter.drops-weather.0 in version "1.1.0" (non-npm: iobroker-community-adapters/ioBroker.drops-weather) started with pid 125172
              host.raspberrypi
              2025-03-20 15:03:00.092	info	"system.adapter.drops-weather.0" enabled
              • WinniW Winni
                Zeit
                info
                Nachricht
                host.raspberrypi
                host.raspberrypi
                drops-weather.0
                drops-weather.0
                drops-weather.0
                drops-weather.0
                host.raspberrypi
                host.raspberrypi
                drops-weather.0
                host.raspberrypi
                host.raspberrypi
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                #69
                @winni
                Hmmm - eigentlich sollten da DEBUG Meldungen stehen. Hast du den LOG Level in der Instanz auf debug gestellt?
                Aber da @arteck sowieso plant auch scheduled umzustellen (damit hoffentlich dann die Zombieprozesse / Speicherfresser bereinigt werden) können wir diese Analyse auch mal nach hinten schieben.
                Den Fehler bei manuelle Auswahl (chromkum-browser) hab ich schon gefunden, war ein Typo in jsonConfig.json. Hab dafür aber keine neue Release erstell da zuerst die Änderung von arteck stabilisiert sein sollten. Danke für das Rückmelden
                • mcm1957M mcm1957
                  @winni
                  WinniW Offline
                  WinniW Offline
                  Winni
                  #70
                  @mcm1957 so hatte ich das eingestellt.
                  • WinniW Winni
                    #71
                    @winni sagte in Test Adapter drops-weather 1.1.x:
                    dann zeigt das log nur Errors
                    bitte auf debug umstellen
                      WinniW Offline
                      WinniW Offline
                      Winni
                      #72
                      @homoran jetzt so:
                      host.raspberrypi
                      2025-03-20 15:49:41.016	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      host.raspberrypi
                      2025-03-20 15:49:40.497	info	stopInstance system.adapter.drops-weather.0 send kill signal
                      drops-weather.0
                      2025-03-20 15:49:40.494	error	Cannot read properties of null (reading 'pages')
                      drops-weather.0
                      2025-03-20 15:49:40.494	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
                      drops-weather.0
                      2025-03-20 15:49:40.492	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                      drops-weather.0
                      2025-03-20 15:49:40.492	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      drops-weather.0
                      2025-03-20 15:49:40.491	info	terminating
                      drops-weather.0
                      2025-03-20 15:49:40.490	debug	destroy browser
                      drops-weather.0
                      2025-03-20 15:49:40.489	info	Got terminate signal TERMINATE_YOURSELF
                      host.raspberrypi
                      2025-03-20 15:49:40.486	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
                      host.raspberrypi
                      2025-03-20 15:49:40.486	info	"system.adapter.drops-weather.0" disabled
                      drops-weather.0
                      2025-03-20 15:49:40.442	debug	de
                      drops-weather.0
                      2025-03-20 15:49:40.434	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      drops-weather.0
                      2025-03-20 15:49:40.433	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                      drops-weather.0
                      2025-03-20 15:49:40.413	debug	getting system language
                      drops-weather.0
                      2025-03-20 15:49:40.412	info	browserPath set to puppeteer default
                      drops-weather.0
                      2025-03-20 15:49:40.412	info	browserMode set to automatic
                      drops-weather.0
                      2025-03-20 15:49:40.401	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                      • WinniW Winni
                        @homoran jetzt so:
                        host.raspberrypi
                        host.raspberrypi
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        host.raspberrypi
                        host.raspberrypi
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        drops-weather.0
                        #73
                        jetzt so:
                        wie geht das denn 😱 ??
                        debug und error?
                        WinniW NegaleinN 2 Antworten Letzte Antwort
                          jetzt so:
                          debug und error?
                          WinniW Offline
                          WinniW Offline
                          Winni
                          #74
                          @homoran keine Ahnung, aber jetzt steht da nur noch debug, vielleicht war ich zu schnell..
                          • WinniW Winni
                            #75
                            @winni das log passt auf jeden Fall.
                            Da sollte jetzt alles für @mcm1957 drin sein
                              jetzt so:
                              debug und error?
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              #76
                              @homoran sagte in Test Adapter drops-weather 1.1.x:
                              wie geht das denn ??
                              Screenshot gleich nach speichern gemacht.
                              Sobald der Adapter gestartet ist, steht da nur eins von denen.
                              ° Fixer ---> iob fix
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                #77
                                so hab da mal was
                                https://github.com/iobroker-community-adapters/ioBroker.drops-weather
                                der adapter muss aber zuvor gelöscht werden (die id aus den einstellungen merken)
                                dann installieren
                                dann instanz hinzufügen
                                dann starten
                                es kann aber sein dass es paar zombie prozesse gibt .. also am besten den iobroker neu starten oder die prozesse killen
                                dann erst den adapter starten
                                sollte dann so aussehen
                                kommt so eine meldung im LOG
                                drops-weather.0
                                2025-03-20 20:12:31.879	error	drops-weather.0 already running
                                drops-weather.0
                                2025-03-20 20:12:31.882	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                host.iobroker
                                2025-03-20 20:12:32.436	error	instance system.adapter.drops-weather.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                dann sind da noch prozesse am laufen die gekillt werden müssen.. oder iob neu starten
                                • arteckA arteck
                                  so hab da mal was
                                  dann installieren
                                  dann starten
                                  drops-weather.0
                                  drops-weather.0
                                  host.iobroker
                                  WinniW Offline
                                  WinniW Offline
                                  Winni
                                  #78
                                  @arteck Hallo, funktioniert bei mir leider nicht. Habe den Adapter erst deinstalliert, iob gestoppt und neu gestartet. Dann den Adapter neu installiert. Hier der Log:
                                  host.raspberrypi
                                  2025-03-20 20:42:18.103	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypi
                                  2025-03-20 20:42:17.538	info	stopInstance canceled schedule system.adapter.drops-weather.0
                                  host.raspberrypi
                                  2025-03-20 20:42:17.538	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
                                  host.raspberrypi
                                  2025-03-20 20:42:17.537	info	"system.adapter.drops-weather.0" disabled
                                  drops-weather.0
                                  2025-03-20 20:42:17.494	debug	de
                                  drops-weather.0
                                  2025-03-20 20:42:17.486	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  drops-weather.0
                                  2025-03-20 20:42:17.485	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                                  drops-weather.0
                                  2025-03-20 20:42:17.466	debug	getting system language
                                  drops-weather.0
                                  2025-03-20 20:42:17.466	info	browserPath set to puppeteer default
                                  drops-weather.0
                                  2025-03-20 20:42:17.465	info	browserMode set to automatic
                                  drops-weather.0
                                  2025-03-20 20:42:17.453	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather#df8b0a7231e71f2a89672d780c44b03675ed4dfe) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                  • WinniW Winni
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    mcm1957M Offline
                                    mcm1957M Offline
                                    mcm1957
                                    #79
                                    @arteck hat den Adapter dankenswerter Weise nochmals überarbeitet und auf schedule Betrieb umgestellt. Er startet jetzt alle 5 Minuten als neuer Prozess. Das Problem der Zobieprozesse sollte dadurch gelöst sein.
                                    Der Adapter steht in dieser Version nun als 1.2.0 nun zurVerfügung (ab morgen im LATEST).
                                    Bei Tests auf meine Pi4 in den letzen Tagen hat dieser "halbwegs" funktioniert. Das halbwegs bezieht sich darauf, dass der Adapter in nicht vorhersehbarere Weise updates durch ein Timeout verweigert - mal gehen die Update stundenlang gut, dann kommen wieder timeouts ohne unterbrechung... Die Ursache dafür ist zumindest mir derzeit nicht klar. Eine Vergrößerung des Timeouts von 10 auf 15s hat keine Verbesserung gebracht.
                                    Ich stellen den Adapter trotzdem mal zum Testen bereit - viulleicht zeigt sich ja da dann ein klareres Bild. Oder @arteck hat noch eine Idee wie / wo "man" suchen könnte.
                                    mcm1957
                                    EDIT:
                                    mcm1957 about a minute ago
                                    ACHTUNG:
                                    Bitte vor der Installation der 1.2.0 den Adapter DEINSTALLIEREN. Vorher bitte die locationID notieren.
                                    Siehe: https://forum.iobroker.net/topic/80335/test-adapter-drops-weather-1-1-x/77
                                    Chris76eC S 3 Antworten Letzte Antwort
                                    • mcm1957M mcm1957
                                      mcm1957
                                      EDIT:
                                      ACHTUNG:
                                      Chris76eC Online
                                      Chris76eC Online
                                      Chris76e
                                      #80
                                      @mcm1957
                                      Auf meinem System Startet der immer wieder neu....
                                      01
                                      Log-Größe: 19.1 KB
                                      Zeit
                                      drops-weather.0
                                      	2025-03-24 18:58:47.388	info	terminating
                                      drops-weather.0
                                      	2025-03-24 18:58:47.075	debug	Rain (data_1h): [{"label":"Mo 21:00","value":"0"},{"label":"Mo 22:00","value":"0"},{"label":"Mo 23:00","value":"0"},{"label":"Di 00:00","value":"0"},{"label":"Di 01:00","value":"0"},{"label":"Di 02:00","value":"0"},{"label":"Di 03:00","value":"0"},{"label":"Di 04:00","value":"0"},{"label":"Di 05:00","value":"0"},{"label":"Di 06:00","value":"0"},{"label":"Di 07:00","value":"0"},{"label":"Di 08:00","value":"0"},{"label":"Di 09:00","value":"0"},{"label":"Di 10:00","value":"0"},{"label":"Di 11:00","value":"0"},{"label":"Di 12:00","value":"0"},{"label":"Di 13:00","value":"0"},{"label":"Di 14:00","value":"0"},{"label":"Di 15:00","value":"0"},{"label":"Di 16:00","value":"0"},{"label":"Di 17:00","value":"0"},{"label":"Di 18:00","value":"0"},{"label":"Di 19:00","value":"0"},{"label":"Di 20:00","value":"0.1"}]
                                      drops-weather.0
                                      	2025-03-24 18:58:47.015	debug	Rain (data_5min): [{"label":"18:55","value":"0"},{"label":"19:00","value":"0"},{"label":"19:05","value":"0"},{"label":"19:10","value":"0"},{"label":"19:15","value":"0"},{"label":"19:20","value":"0"},{"label":"19:25","value":"0"},{"label":"19:30","value":"0"},{"label":"19:35","value":"0"},{"label":"19:40","value":"0"},{"label":"19:45","value":"0"},{"label":"19:50","value":"0"},{"label":"19:55","value":"0"},{"label":"20:00","value":"0"},{"label":"20:05","value":"0"},{"label":"20:10","value":"0"},{"label":"20:15","value":"0"},{"label":"20:20","value":"0"},{"label":"20:25","value":"0"},{"label":"20:30","value":"0"},{"label":"20:35","value":"0"},{"label":"20:40","value":"0"},{"label":"20:45","value":"0"},{"label":"20:50","value":"0"},{"label":"20:55","value":"0"},{"label":"21:00","value":"0"},{"label":"21:05","value":"0"},{"label":"21:10","value":"0"},{"label":"21:15","value":"0"},{"label":"21:20","value":"0"},{"label":"21:25","value":"0"},{"label":"21:30","value":"0"},{"label":"21:35","value":"0"},{"label":"21:40","value":"0"},{"label":"21:45","value":"0"},{"label":"21:50","value":"0"},{"label":"21:55","value":"0"},{"label":"22:00","value":"0"}]
                                      drops-weather.0
                                      	2025-03-24 18:58:46.902	info	Terminated (NO_ERROR): Without reason
                                      drops-weather.0
                                      	2025-03-24 18:58:46.900	info	terminating
                                      drops-weather.0
                                      	2025-03-24 18:58:46.883	debug	destroy browser
                                      drops-weather.0
                                      	2025-03-24 18:58:46.882	debug	creating 1 hour states
                                      drops-weather.0
                                      	2025-03-24 18:58:46.881	debug	creating 5 min states
                                      drops-weather.0
                                      	2025-03-24 18:58:46.881	debug	weatherData found
                                      drops-weather.0
                                      	2025-03-24 18:58:46.877	debug	got labeltext "It will stay dry for now"
                                      drops-weather.0
                                      	2025-03-24 18:58:46.873	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T17:55:00Z\",\"timestamp\":1742838900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:05:00Z\",\"timestamp\":1742839500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:10:00Z\",\"timestamp\":1742839800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:15:00Z\",\"timestamp\":1742840100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:20:00Z\",\"timestamp\":1742840400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:25:00Z\",\"timestamp\":1742840700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:30:00Z\",\"timestamp\":1742841000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:35:00Z\",\"timestamp\":1742841300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:40:00Z\",\"timestamp\":1742841600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:45:00Z\",\"timestamp\":1742841900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:50:00Z\",\"timestamp\":1742842200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:55:00Z\",\"timestamp\":1742842500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:05:00Z\",\"timestamp\":1742843100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:10:00Z\",\"timestamp\":1742843400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:15:00Z\",\"timestamp\":1742843700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:20:00Z\",\"timestamp\":1742844000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:25:00Z\",\"timestamp\":1742844300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:30:00Z\",\"timestamp\":1742844600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:35:00Z\",\"timestamp\":1742844900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:40:00Z\",\"timestamp\":1742845200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:45:00Z\",\"timestamp\":1742845500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:50:00Z\",\"timestamp\":1742845800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:55:00Z\",\"timestamp\":1742846100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:05:00Z\",\"timestamp\":1742846700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:10:00Z\",\"timestamp\":1742847000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:15:00Z\",\"timestamp\":1742847300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:20:00Z\",\"timestamp\":1742847600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:25:00Z\",\"timestamp\":1742847900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:30:00Z\",\"timestamp\":1742848200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:35:00Z\",\"timestamp\":1742848500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:40:00Z\",\"timestamp\":1742848800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:45:00Z\",\"timestamp\":1742849100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:50:00Z\",\"timestamp\":1742849400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:55:00Z\",\"timestamp\":1742849700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000}],\"daypart\":[{\"precipitationrate\":0.0,\"time\":\"2025-03-24T17:00:00Z\",\"timestamp\":1742835600,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.12,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADBBB\",\"source\":\"radar-nl\",\"timestamp\":1742838300}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T22:00:00Z\",\"timestamp\":1742853600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T23:00:00Z\",\"timestamp\":1742857200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T00:00:00Z\",\"timestamp\":1742860800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T01:00:00Z\",\"timestamp\":1742864400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T02:00:00Z\",\"timestamp\":1742868000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T03:00:00Z\",\"timestamp\":1742871600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T04:00:00Z\",\"timestamp\":1742875200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T05:00:00Z\",\"timestamp\":1742878800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T06:00:00Z\",\"timestamp\":1742882400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T07:00:00Z\",\"timestamp\":1742886000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T08:00:00Z\",\"timestamp\":1742889600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T09:00:00Z\",\"timestamp\":1742893200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T10:00:00Z\",\"timestamp\":1742896800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T11:00:00Z\",\"timestamp\":1742900400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T12:00:00Z\",\"timestamp\":1742904000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T13:00:00Z\",\"timestamp\":1742907600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T14:00:00Z\",\"timestamp\":1742911200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T15:00:00Z\",\"timestamp\":1742914800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T16:00:00Z\",\"timestamp\":1742918400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T17:00:00Z\",\"timestamp\":1742922000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T18:00:00Z\",\"timestamp\":1742925600},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T19:00:00Z\",\"timestamp\":1742929200}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.115,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADB\",\"source\":\"weathercomputer\",\"timestamp\":1742838984}}},"," timezoneOffset: 60,"," locals: {\"labels\":[[0,\"dry\"],[0.1,\"drizzle\"],[1,\"light rain\"],[2,\"heavy rain\"]],\"language\":\"en\",\"strings\":{\"unavailable\":\"Something went wrong\",\"mmph\":\"mm per hour\",\"now\":\"now\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
                                      drops-weather.0
                                      	2025-03-24 18:58:46.865	debug	domcontent loaded, evaluate page
                                      drops-weather.0
                                      	2025-03-24 18:58:44.910	debug	creating new page ...
                                      drops-weather.0
                                      	2025-03-24 18:58:44.909	debug	Reading data from : https://www.meteox.com/en-gb/city/2937543
                                      drops-weather.0
                                      	2025-03-24 18:58:44.569	debug	de
                                      drops-weather.0
                                      	2025-03-24 18:58:44.532	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors"]}
                                      drops-weather.0
                                      	2025-03-24 18:58:44.531	debug	getting system language
                                      drops-weather.0
                                      	2025-03-24 18:58:44.530	debug	browserPath set to puppeteer default
                                      drops-weather.0
                                      	2025-03-24 18:58:44.530	debug	browserMode set to automatic, running on linux / x64
                                      drops-weather.0
                                      	2025-03-24 18:58:44.511	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                      drops-weather.0
                                      	2025-03-24 18:58:05.945	info	terminating
                                      drops-weather.0
                                      	2025-03-24 18:58:05.565	debug	Rain (data_1h): [{"label":"Mo 21:00","value":"0"},{"label":"Mo 22:00","value":"0"},{"label":"Mo 23:00","value":"0"},{"label":"Di 00:00","value":"0"},{"label":"Di 01:00","value":"0"},{"label":"Di 02:00","value":"0"},{"label":"Di 03:00","value":"0"},{"label":"Di 04:00","value":"0"},{"label":"Di 05:00","value":"0"},{"label":"Di 06:00","value":"0"},{"label":"Di 07:00","value":"0"},{"label":"Di 08:00","value":"0"},{"label":"Di 09:00","value":"0"},{"label":"Di 10:00","value":"0"},{"label":"Di 11:00","value":"0"},{"label":"Di 12:00","value":"0"},{"label":"Di 13:00","value":"0"},{"label":"Di 14:00","value":"0"},{"label":"Di 15:00","value":"0"},{"label":"Di 16:00","value":"0"},{"label":"Di 17:00","value":"0"},{"label":"Di 18:00","value":"0"},{"label":"Di 19:00","value":"0"},{"label":"Di 20:00","value":"0.1"}]
                                      drops-weather.0
                                      	2025-03-24 18:58:05.555	debug	Rain (data_5min): [{"label":"18:55","value":"0"},{"label":"19:00","value":"0"},{"label":"19:05","value":"0"},{"label":"19:10","value":"0"},{"label":"19:15","value":"0"},{"label":"19:20","value":"0"},{"label":"19:25","value":"0"},{"label":"19:30","value":"0"},{"label":"19:35","value":"0"},{"label":"19:40","value":"0"},{"label":"19:45","value":"0"},{"label":"19:50","value":"0"},{"label":"19:55","value":"0"},{"label":"20:00","value":"0"},{"label":"20:05","value":"0"},{"label":"20:10","value":"0"},{"label":"20:15","value":"0"},{"label":"20:20","value":"0"},{"label":"20:25","value":"0"},{"label":"20:30","value":"0"},{"label":"20:35","value":"0"},{"label":"20:40","value":"0"},{"label":"20:45","value":"0"},{"label":"20:50","value":"0"},{"label":"20:55","value":"0"},{"label":"21:00","value":"0"},{"label":"21:05","value":"0"},{"label":"21:10","value":"0"},{"label":"21:15","value":"0"},{"label":"21:20","value":"0"},{"label":"21:25","value":"0"},{"label":"21:30","value":"0"},{"label":"21:35","value":"0"},{"label":"21:40","value":"0"},{"label":"21:45","value":"0"},{"label":"21:50","value":"0"},{"label":"21:55","value":"0"},{"label":"22:00","value":"0"}]
                                      drops-weather.0
                                      	2025-03-24 18:58:05.491	info	Terminated (NO_ERROR): Without reason
                                      drops-weather.0
                                      	2025-03-24 18:58:05.489	info	terminating
                                      drops-weather.0
                                      	2025-03-24 18:58:05.439	debug	destroy browser
                                      drops-weather.0
                                      	2025-03-24 18:58:05.438	debug	creating 1 hour states
                                      drops-weather.0
                                      	2025-03-24 18:58:05.435	debug	creating 5 min states
                                      drops-weather.0
                                      	2025-03-24 18:58:05.435	debug	weatherData found
                                      drops-weather.0
                                      	2025-03-24 18:58:05.431	debug	got labeltext "It will stay dry for now"
                                      drops-weather.0
                                      	2025-03-24 18:58:05.429	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T17:55:00Z\",\"timestamp\":1742838900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:05:00Z\",\"timestamp\":1742839500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:10:00Z\",\"timestamp\":1742839800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:15:00Z\",\"timestamp\":1742840100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:20:00Z\",\"timestamp\":1742840400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:25:00Z\",\"timestamp\":1742840700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:30:00Z\",\"timestamp\":1742841000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:35:00Z\",\"timestamp\":1742841300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:40:00Z\",\"timestamp\":1742841600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:45:00Z\",\"timestamp\":1742841900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:50:00Z\",\"timestamp\":1742842200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:55:00Z\",\"timestamp\":1742842500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:05:00Z\",\"timestamp\":1742843100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:10:00Z\",\"timestamp\":1742843400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:15:00Z\",\"timestamp\":1742843700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:20:00Z\",\"timestamp\":1742844000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:25:00Z\",\"timestamp\":1742844300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:30:00Z\",\"timestamp\":1742844600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:35:00Z\",\"timestamp\":1742844900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:40:00Z\",\"timestamp\":1742845200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:45:00Z\",\"timestamp\":1742845500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:50:00Z\",\"timestamp\":1742845800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:55:00Z\",\"timestamp\":1742846100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:05:00Z\",\"timestamp\":1742846700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:10:00Z\",\"timestamp\":1742847000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:15:00Z\",\"timestamp\":1742847300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:20:00Z\",\"timestamp\":1742847600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:25:00Z\",\"timestamp\":1742847900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:30:00Z\",\"timestamp\":1742848200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:35:00Z\",\"timestamp\":1742848500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:40:00Z\",\"timestamp\":1742848800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:45:00Z\",\"timestamp\":1742849100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:50:00Z\",\"timestamp\":1742849400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:55:00Z\",\"timestamp\":1742849700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000}],\"daypart\":[{\"precipitationrate\":0.0,\"time\":\"2025-03-24T17:00:00Z\",\"timestamp\":1742835600,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.12,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADBBB\",\"source\":\"radar-nl\",\"timestamp\":1742838300}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T22:00:00Z\",\"timestamp\":1742853600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T23:00:00Z\",\"timestamp\":1742857200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T00:00:00Z\",\"timestamp\":1742860800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T01:00:00Z\",\"timestamp\":1742864400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T02:00:00Z\",\"timestamp\":1742868000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T03:00:00Z\",\"timestamp\":1742871600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T04:00:00Z\",\"timestamp\":1742875200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T05:00:00Z\",\"timestamp\":1742878800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T06:00:00Z\",\"timestamp\":1742882400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T07:00:00Z\",\"timestamp\":1742886000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T08:00:00Z\",\"timestamp\":1742889600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T09:00:00Z\",\"timestamp\":1742893200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T10:00:00Z\",\"timestamp\":1742896800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T11:00:00Z\",\"timestamp\":1742900400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T12:00:00Z\",\"timestamp\":1742904000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T13:00:00Z\",\"timestamp\":1742907600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T14:00:00Z\",\"timestamp\":1742911200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T15:00:00Z\",\"timestamp\":1742914800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T16:00:00Z\",\"timestamp\":1742918400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T17:00:00Z\",\"timestamp\":1742922000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T18:00:00Z\",\"timestamp\":1742925600},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T19:00:00Z\",\"timestamp\":1742929200}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.115,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADB\",\"source\":\"weathercomputer\",\"timestamp\":1742838984}}},"," timezoneOffset: 60,"," locals: {\"labels\":[[0,\"dry\"],[0.1,\"drizzle\"],[1,\"light rain\"],[2,\"heavy rain\"]],\"language\":\"en\",\"strings\":{\"unavailable\":\"Something went wrong\",\"mmph\":\"mm per hour\",\"now\":\"now\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
                                      drops-weather.0
                                      	2025-03-24 18:58:05.427	debug	domcontent loaded, evaluate page
                                      drops-weather.0
                                      	2025-03-24 18:58:02.955	debug	creating new page ...
                                      drops-weather.0
                                      	2025-03-24 18:58:02.955	debug	Reading data from : https://www.meteox.com/en-gb/city/2937543
                                      drops-weather.0
                                      	2025-03-24 18:58:02.621	debug	de
                                      drops-weather.0
                                      	2025-03-24 18:58:02.561	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors"]}
                                      drops-weather.0
                                      	2025-03-24 18:58:02.561	debug	getting system language
                                      drops-weather.0
                                      	2025-03-24 18:58:02.560	debug	browserPath set to puppeteer default
                                      drops-weather.0
                                      	2025-03-24 18:58:02.560	debug	browserMode set to automatic, running on linux / x64
                                      drops-weather.0
                                      	2025-03-24 18:58:02.525	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                      drops-weather.0
                                      	2025-03-24 18:57:48.137	info	terminating
                                      drops-weather.0
                                      	2025-03-24 18:57:47.641	info	Terminated (NO_ERROR): Without reason
                                      • mcm1957M mcm1957
                                        mcm1957
                                        EDIT:
                                        ACHTUNG:
                                        Sleepwalker
                                        #81
                                        @mcm1957
                                        Moin!
                                        [OT]
                                        Da demnächst die Gartensaison wieder startet und ich unseren Rasimir entstauben will, fiel mein Blick die Tage Richtung Drops-Adapter, den ich seit vielen Monden wegen eines Axios-Fehlers deaktiviert hatte.
                                        Nun sehe ich, dass sich dem Adapter schon angenommen wurde und wollte ein herzliches "Danke" hierlassen! Ich freue mich drauf, den Adapter ab morgen "offiziell" im Latest-Repo begrüßen zu dürfen.
                                        Bei mir läuft ioBroker auch noch im Container auf einem Pi4 mit Bullseye. Habe mich noch nicht getraut auf Bookworm zu aktualisieren :D
                                        Ich stelle mich gerne als Tester zur Verfügung, für mehr reicht meine (Frei-)Zeit aktuell leider nicht, auch wenn ich selbst Software entwickele. Echt stark, dass sich jemand dem Adapter annimmt. Er hat sich zu meinem Liebling unter den Regenwarnern gemausert.
                                        Vielen Dank nochmal an euch!
                                        [/OT]
                                        • Chris76eC Chris76e
                                          @mcm1957
                                          01
                                          Log-Größe: 19.1 KB
                                          Zeit
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          drops-weather.0
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          #82
                                          @chris76e
                                          Das ist das normale Verhalten für einen SCHEDULED Adapter. Dieser startet gemäß cron einstellungen, erledigt seine Aufgabe und beendet sich dann wieder.
