  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Fritz-DECT-Adapter
    2.8k
    4.9k
    4.1k
Fritz-DECT-Adapter
23 Beiträge 10 Kommentatoren 4.3k Aufrufe 10 Beobachtet
  • U Offline
    U Offline
    ULBE
    Beim Anmelden bekomme ich folgende Meldungen (aus dem IO-Protokoll kopiert, neueste Meldung oben) Anmeldung mit speziellem IOBroker-User und den Rechten "SmartHome" und als Admin-User gleich. Fritzbox 7590 mit aktueller SW (8.02). Was mache ich falsch?:
    fritzdect.0
    	2025-03-23 10:42:59.213	error	login not possible, check user and permissions
    fritzdect.0
    	2025-03-23 10:42:59.212	error	API err => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.1","port":80}}}
    fritzdect.0
    	2025-03-23 10:42:59.211	error	no response part in returned error message
    fritzdect.0
    	2025-03-23 10:42:59.210	error	API funct => login_SID
    fritzdect.0
    	2025-03-23 10:42:59.210	error	API msg => error calling executeCommand
    fritzdect.0
    	2025-03-23 10:42:59.208	error	--------------- error calling the fritzbox -----------
    fritzdect.0
    	2025-03-23 10:42:56.045	info	fritzdect uses USER: iobroker
    fritzdect.0
    	2025-03-23 10:42:56.002	info	fritzdect entered ready
    fritzdect.0
    	2025-03-23 10:42:55.975	info	starting. Version 2.5.11 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v20.17.0, js-controller: 7.0.6
    host.iobroker
    	2025-03-23 10:42:53.653	info	instance system.adapter.fritzdect.0 in version "2.5.11" started with pid 155170
    host.iobroker
    	2025-03-23 10:42:52.964	info	"system.adapter.fritzdect.0" enabled
    host.iobroker
    	2025-03-23 10:42:39.991	info	instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    fritzdect.0
    	2025-03-23 10:42:39.873	info	terminating
    host.iobroker
    	2025-03-23 10:42:39.430	info	stopInstance system.adapter.fritzdect.0 send kill signal
    fritzdect.0
    	2025-03-23 10:42:39.370	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fritzdect.0
    	2025-03-23 10:42:39.369	info	terminating
    fritzdect.0
    	2025-03-23 10:42:39.367	info	cleaned everything up...
    fritzdect.0
    	2025-03-23 10:42:39.365	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    	2025-03-23 10:42:39.355	info	stopInstance system.adapter.fritzdect.0 (force=false, process=true)
    host.iobroker
    	2025-03-23 10:42:39.354	info	"system.adapter.fritzdect.0" disabled
    M haselchenH 2 Antworten Letzte Antwort
    • U ULBE
      fritzdect.0
      fritzdect.0
      fritzdect.0
      fritzdect.0
      fritzdect.0
      fritzdect.0
      fritzdect.0
      fritzdect.0
      fritzdect.0
      host.iobroker
      host.iobroker
      host.iobroker
      fritzdect.0
      host.iobroker
      fritzdect.0
      fritzdect.0
      fritzdect.0
      fritzdect.0
      host.iobroker
      host.iobroker
      M Online
      M Online
      MCU
      @ulbe IP-Adresse der FritzBox?
      Und Logs bitte in Code-Tags setzen -> 37ffc753-df7a-426e-9bdf-e3ab6fb4ee29-image.png
      nutzen
      U 1 Antwort Letzte Antwort
      • U ULBE
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        host.iobroker
        host.iobroker
        host.iobroker
        fritzdect.0
        host.iobroker
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        host.iobroker
        host.iobroker
        haselchenH Offline
        haselchenH Offline
        haselchen
        @ulbe
        Repo kurz auf Beta stellen, die 2.6.0 einspielen und dann wieder zurück auf Stable.
        Mit dem 8.0.2 Update der FB funktioniert dann FritzDect wieder.
        Edit: + natürlich @MCU ´s Hinweis
        U D 2 Antworten Letzte Antwort
        • M MCU
          nutzen
          U Offline
          U Offline
          ULBE
          @mcu 192.168.0.1
          • haselchenH haselchen
            @ulbe
            U Offline
            U Offline
            ULBE
            @haselchen said in Fritz-DECT-Adapter:
            @ulbe
            ... das verstehe ich nicht ...
            • U ULBE
              @ulbe
              haselchenH Offline
              haselchenH Offline
              haselchen
              @ulbe
              http:// davor , so wie es oben steht
              Und dann hier auf Beta
              Und dann wieder zurück auf Stable nach dem Update auf Version 2.6.0
                @ulbe
                dibide
                schrieb am zuletzt editiert von dibide
                @ulbe
                Danke für den Tip - das hat super funktioniert!
                • D dibide
                  @ulbe
                  mcm1957M Offline
                  mcm1957M Offline
                  mcm1957
                  @dibide said in Fritz-DECT-Adapter:
                  @ulbe
                  Na ja - LATEST sollte aber JETZT nicht mehr notwendig sein.
                  Die aktuelle Version 2-6.1 ist seit eca 14 Tagen bereits im STABLE Repository. Wenn du da kein Upodate angeboten bekommen hast, dann solltest du dein Sysetm überprüfen.
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • JB_SullivanJ Offline
                    JB_Sullivan
                    schrieb am zuletzt editiert von JB_Sullivan
                    Kann mir jemand sagen, was mir diese Warnmeldung mitteilen möchte und vor allen Dingen wie ich sie abgestellt bekomme?
                    Adapter Version 2.6.2
                    fritzdect.0
                    12376	2025-05-14 21:03:42.461	warn	State value to set for "fritzdect.0.DECT_087610221797.energy_stats.datatimed" has value "1747249422456" greater than max "2147483648"
                    fritzdect.0
                    12376	2025-05-14 21:03:42.321	warn	State value to set for "fritzdect.0.DECT_087610221797.energy_stats.datatimem" has value "1747249422307" greater than max "2147483648"
                    • JB_SullivanJ JB_Sullivan
                      fritzdect.0
                      fritzdect.0
                      CodierknechtC Online
                      Codierknecht
                      @jb_sullivan sagte in Fritz-DECT-Adapter:
                      Na das ist einfach: Der Wert ist zu groß für den Datenpunkt (bzw. dessen konfiguriertes Maximum).
                      Da wird wohl ein Timestamp mit Millisekunden in einen DP geschrieben der nur Sekundengenau ist.
                      Schreibst Du den DP selbst?
                      Ansonsten kann das nur der Entwickler/Maintainer des Adapters. Am besten machst Du dazu ein Issue auf GitHub auf.
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                      • CodierknechtC Codierknecht
                        JB_Sullivan
                        @codierknecht
                        OK, nein den schreibe ich nicht selbst, den holt der Adapter aus der Fritzbox von einer schaltbaren Steckdose ab.
                        Das interessante ist, das diese Warnungen seit 3-4 Tagen erst da sind, das Adapter Update aber schon deutlich länger zurück liegt
                        CodierknechtC haselchenH 2 Antworten Letzte Antwort
                          @codierknecht
                          Codierknecht
                          Und was hat sich vor 3-4 Tagen verändert? Irgendeine Einstellung?
                            @codierknecht
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @jb_sullivan
                            Adapter anhalten
                            Besagte Datenpunkte löschen
                            Adapter starten
                            Die DP werden wieder „richtig“ angelegt .
                            JB_SullivanJ W R 4 Antworten Letzte Antwort
                              @jb_sullivan
                              Adapter anhalten
                              Adapter starten
                              JB_Sullivan
                              @haselchen sagte in Fritz-DECT-Adapter:
                              @jb_sullivan
                              Adapter anhalten
                              Adapter starten
                              Vielen Dank - das hat geholfen 👍👍
                                @jb_sullivan
                                Adapter anhalten
                                Adapter starten
                                DerLockjaw
                                Ich bekomme seit einigen Wochen keine aktualisierte Werte mehr in den Objekten. Adapter: v2.6.1, Fritz!Box 8.02.
                                Im Protokoll vom ioBroker taucht z.B. nach einem Adapter-Neustart auf:
                                fritzdect.0
                                	2025-06-01 15:17:25.662	debug	{"identifier":"11657 0351352","id":"16","functionbitmask":"35712","fwversion":"04.27","manufacturer":"AVM","productname":"FRITZ!Smart Energy 210","present":"1","txbusy":"0","name":"E-HeizungWasser","switch":{"state":"1","mode":"manuell","lock":"0","devicelock":"0"},"simpleonoff":{"state":"1"},"powermeter":{"voltage":"226136","power":"1989010","energy":"3301268"},"temperature":{"celsius":"245","offset":"0"}}
                                Energy ist hier der korrekte aktuelle Wert 3301268.
                                Aber der Wert unter Objekte lautet auf 3027985 und stammt laut Zeitstempel vom 21.04.2025. Es gibt keinen Wert im ganzen fritzdect.0-Zweig der aktueller ist - außer state. Aber state setze ich mit einem Programm und das Steuern funktioniert auch.
                                Ich habe mal Testweise den nicht so wichtigen Wert "Voltage" gelöscht (vorher Adapter pausiert). Er wird beim Neustart nicht neu erstellt und fehlt jetzt.
                                Was kann ich tun?
                                • D DerLockjaw
                                  fritzdect.0
                                  Was kann ich tun?
                                  DerLockjaw
                                  @derlockjaw Hat sich erstmal erledigt. Ein Downgrade des Adapters hat das Problem beseitigt.
                                  • D DerLockjaw
                                    mcm1957M Offline
                                    mcm1957M Offline
                                    mcm1957
                                    @derlockjaw
                                    Hast du ein Issue im Adapter Repository angelegt?
                                    Ohne Issue erwarte bitte nicht dass jemand sichvdes Problems annimmt ...
                                      @jb_sullivan
                                      Adapter anhalten
                                      Adapter starten
                                      W Offline
                                      W Offline
                                      Wolf1997
                                      schrieb am zuletzt editiert von Wolf1997
                                      @haselchen Vielen Dank!
                                      Bei mir trat diese Fehlermeldung gestern plötzlich auf. Tausende Warnungen.
                                      Mit deinem Tip ist jetzt alles wieder i.O.!
                                      Copy to Clipboard
                                      fritzdect.0
                                      fritzdect.0
                                        @jb_sullivan
                                        Adapter anhalten
                                        Adapter starten
                                        W Offline
                                        W Offline
                                        Wolf1997
                                        @jb_sullivan
                                        Adapter anhalten
                                        Adapter starten
                                          @jb_sullivan
                                          Adapter anhalten
                                          Adapter starten
                                          Rico Sander
                                          @haselchen
                                          Nur zur Info:
                                          Der Fehler "größer als" betraf bei mir nur den DP "Monatsertrag".
                                          Der Tipp hat bei mir nicht geholfen.
                                          Nach Downgrade auf 2.6.1 wieder ok,
                                          wieder auf 2.6.2: gleicher Fehler.
                                          Auch hier half der Tip nicht.
                                          Jetzt läuft wieder 2.6.1 und alles ist ok.
                                          Wenns nicht geht, wie man will
                                          - muss mans tun, wie man kann.
