  3. Off Topic
  4. InfluxDB
  5. InfluxDB installieren wie
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
48 Beiträge 3 Kommentatoren 7.6k Aufrufe 3 Beobachtet
  • L Laser
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: neuheizung
           Icon name: computer
              Kernel: Linux 6.6.62+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     17:24:25 up  1:41,  2 users,  load average: 0.80, 0.78, 0.84
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-01-01 17:24:25 CET
               Universal time: Wed 2025-01-01 16:24:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    otto
    HOME=/home/otto
    GROUPS=otto adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.2G        2.2G        4.9G        1.3M        1.2G        6.0G
    Swap:           209M          0B        209M
    Total:          8.4G        2.2G        5.1G
    Active iob-Instances:   32
             7808 M total memory
             2118 M used memory
             2338 M active memory
              687 M inactive memory
             4638 M free memory
               69 M buffer memory
             1105 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 17:24:26 up  1:41,  2 users,  load average: 0.80, 0.78, 0.84
    Tasks: 206 total,   1 running, 205 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7808.9 total,   4637.0 free,   2119.7 used,   1175.3 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5689.2 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     781M  1.2M  780M   1% /run
    /dev/sda2      ext4      110G   16G   89G  15% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   65M  446M  13% /boot/firmware
    tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
    [Wed Jan  1 15:42:54 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:0D:3B:C5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=522926e5-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Jan  1 15:42:58 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
    [Wed Jan  1 15:43:00 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.5G    /var/
    2.6G    /var/log/journal/dd88a5e009d84a8992e10dbb99d7e583
    2.6G    /var/log
    473M    /var/cache
    Archived and active journals take up 2.5G in the file system.
    /opt/iobroker/backups:
    8.0K    /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker
    /opt/iobroker/iobroker-data:
    5.9G    /opt/iobroker/iobroker-data/
    4.7G    /opt/iobroker/iobroker-data/history
    1.1G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    30M     /opt/iobroker/iobroker-data/objects.jsonl
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CCDE649-if00
    /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE82E1IJ-if00-port0
    /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    debian11            debian11 (version: 4.0.24, hostname: debian11      , dead, uptime: 198)
    neuheizung          neuheizung (version: 7.0.6, hostname: neuheizung    , alive, uptime: 6072)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     1
    +-- iobroker.vedirect@0.3.3 (git+ssh://git@github.com/DrozmotiX/ioBroker.vedirect.git#0a83b8b987ee94d0c49f2ee7299bbb8d5d329dde)
    Adapter State
    + system.adapter.admin.1                  : admin                 : neuheizung                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : neuheizung                               - disabled
    + system.adapter.backitup.0               : backitup              : neuheizung                               -  enabled
    + system.adapter.discovery.0              : discovery             : neuheizung                               -  enabled
    + system.adapter.echarts.0                : echarts               : neuheizung                               -  enabled
    + system.adapter.email.0                  : email                 : neuheizung                               -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : neuheizung                               -  enabled
      system.adapter.flot.0                   : flot                  : neuheizung                               - disabled
    + system.adapter.history.0                : history               : neuheizung                               -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : neuheizung                               -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : neuheizung                               -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : neuheizung                               -  enabled, port: 0
      system.adapter.i2c.0                    : i2c                   : neuheizung                               - disabled
    + system.adapter.influxdb.0               : influxdb              : neuheizung                               -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : neuheizung                               -  enabled
    + system.adapter.logparser.0              : logparser             : neuheizung                               -  enabled
    + system.adapter.modbus.0                 : modbus                : neuheizung                               -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : neuheizung                               -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : neuheizung                               -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : neuheizung                               -  enabled, port: 1888, bind: 0.0.0.0
    + system.adapter.mqtt.3                   : mqtt                  : neuheizung                               -  enabled, port: 1890, bind: 0.0.0.0
    + system.adapter.opendtu.0                : opendtu               : neuheizung                               -  enabled
    + system.adapter.opendtu.1                : opendtu               : neuheizung                               -  enabled
    + system.adapter.opendtu.2                : opendtu               : neuheizung                               -  enabled
    + system.adapter.owfs.0                   : owfs                  : neuheizung                               -  enabled, port: 4304
    + system.adapter.rpi2.0                   : rpi2                  : neuheizung                               -  enabled
    + system.adapter.shelly.0                 : shelly                : neuheizung                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : neuheizung                               -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : neuheizung                               -  enabled
    + system.adapter.simple-api.0             : simple-api            : neuheizung                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.sourceanalytix.0         : sourceanalytix        : neuheizung                               - disabled
    + system.adapter.vedirect.0               : vedirect              : neuheizung                               -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : neuheizung                               -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : neuheizung                               -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : neuheizung                               - disabled
      system.adapter.vis-material.0           : vis-material          : neuheizung                               - disabled
      system.adapter.vis-metro.0              : vis-metro             : neuheizung                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : neuheizung                               - disabled
      system.adapter.vis.0                    : vis                   : neuheizung                               -  enabled
    + system.adapter.web.0                    : web                   : neuheizung                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : neuheizung                               -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "i2c"          : 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "rpi2"         : 2.2.1    , installed 2.2.2
    Adapter    "shelly"       : 8.2.1    , installed 8.3.0
    Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "web"          : 6.2.5    , installed 6.3.1
    Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
    Objects and States
    Objects:        4489
    States:         3667
    W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://packages.grafana.com/enterprise/deb stable InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.2.54:2001       0.0.0.0:*               LISTEN      1001       8299       1072/io.hm-rpc.1
    tcp        0      0 192.168.2.54:2010       0.0.0.0:*               LISTEN      1001       6882       1057/io.hm-rpc.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       923        787/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       918        787/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4572       722/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       7529       1213/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7570       1250/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       8574       1270/io.mqtt.1
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       7627       1300/io.shelly.1
    tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       7677       1315/io.mqtt.3
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       9226       1289/io.mqtt.2
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        6135       786/grafana
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9500       1424/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6745       876/io.admin.1
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       8696       1394/io.simple-api.
    tcp6       0      0 :::22                   :::*                    LISTEN      0          4574       722/sshd: /usr/sbin
    udp        0      0 0.0.0.0:56980           0.0.0.0:*                           104        625        588/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        623        588/avahi-daemon: r
    udp6       0      0 fe80::75d1:70aa:4ea:546 :::*                                0          6578       665/NetworkManager
    udp6       0      0 :::42177                :::*                                104        626        588/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        624        588/avahi-daemon: r
    2025-01-01 17:23:21.360  - error: modbus.0 (8223) Request timed out.
    2025-01-01 17:23:21.361  - warn: modbus.0 (8223) [DevID_1] Poll error count: 6 code: {"err":"timeout","timeout":5000}
    2025-01-01 17:23:25.886  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
    2025-01-01 17:23:27.016  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:23:37.021  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:23:41.186  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
    2025-01-01 17:23:47.026  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:23:56.423  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
    2025-01-01 17:23:57.030  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:24:07.033  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:24:11.720  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
    2025-01-01 17:24:17.039  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:24:27.045  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:24:27.046  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
    2025-01-01 17:24:27.370  - warn: modbus.0 (8223) Error: undefined
    2025-01-01 17:24:27.371  - error: modbus.0 (8223) Request timed out.
    2025-01-01 17:24:27.372  - warn: modbus.0 (8223) [DevID_1] Poll error count: 7 code: {"err":"timeout","timeout":5000}
    2025-01-01 17:24:37.050  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:24:42.327  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
    2025-01-01 17:24:47.055  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:24:57.065  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:25:01.026  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
    2025-01-01 17:25:07.075  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:25:17.081  - error: influxdb.0 (7260) AggregateError
    2025-01-01 17:25:17.910  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
    iob diag has finished.
    PS: ich habe influxdb mit "autoremove" gelöscht und die 5 Befehlszeilen nochmal ausgeführt. Jetzt:
    otto@neuheizung:~ $ apt policy influxdb2
    influxdb2:
    Installed: (none)
    Candidate: (none)
    Version table:
    2.7.11-1 -1
    otto@neuheizung:~ $ sudo apt-get update && sudo apt-get install influxdb2
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://packages.grafana.com/enterprise/deb stable InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Package influxdb2 is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    E: Package 'influxdb2' has no installation candidate
    otto@neuheizung:~ $
    @laser sagte in InfluxDB installieren wie:
    Stell im zigbee-Adapter den richtigen 'by-id'-Link ein, nicht /dev/ttyACM0
    HINT:
    /dev/ttyACM0
    Der Host 'debian11' muss mal auf Vordermann gebracht werden.
    Ich breche hier ab. Kannst du mal aufhören die Ausgabe ständig zu verändern?
    L 1 Antwort Letzte Antwort
      HINT:
      /dev/ttyACM0
      Laser
      @thomas-braun der Host Debian 11 war nur ein Versuchsobjekt. Den gibt es erst mal nicht mehr.
      Die Ausgabe habe ich ergänzt, weil ich glaube das es wichtig sein könnte.
      • L Laser
        @laser
        Ist mir eigentlich jetzt auch egal. Du hast dir jetzt irgendwie das Repo gelöscht.
        Also NOCHMAL die 5 Zeilen, mit denen man das richtig anlegt...
          @laser
          Laser
          schrieb am zuletzt editiert von Laser
          @thomas-braun Ich will Dir jetzt auch nicht endlos auf den Nerv gehen. Vermutlich habe ich bei den 5 Zeilen (habe ich mir in ein xx.txt-File kopiert) einen Fehler gemacht. Ich mache das jetzt Alles noch mal, bis es klappt.
          die Installation geht doch so: sudo apt-get update && sudo apt-get install influxdb2
          die läuft jetzt auch durch. Auch der Status wird ohne Fehler angezeigt.
          Es funktioniert jetzt. Kann die GUI port: 8086 öffenen.
          Ich hoffe, durch die Neuinstallation ist das Chaos mit den Tokens beseitigt. Deshalb wollte ich das neu haben.
          Danke für die Hilfe!
          • L Laser
            Laser
            @Thomas-Braun Influx funktioniert, wie es soll. Jetzt versuche ich, von einem anderen PC darauf zu zugreifen. Die GUI öffnet sich, aber meine Anmeldedaten werden nicht akzeptiert. Ist das ein Sicherheitsfeature? Die Konfigurationsdatei(en) zu finden, ist auch ein Abenteuer für sich.
            • L Laser
              @laser
              Zum Umgang mit influxdb kann ich nix sagen, verwende ich nicht.
                @laser
                Laser
                Evtl. weiß hierüber jemand etwas:
                • L Laser
                  Liegen die nicht wie üblich in /etc ?
                  Lt. debian-Package ist es
                  /etc/influxdb/influxdb.conf
                  Also gar kein Abenteuer, total langweilger Standard.
                    Laser
                    @thomas-braun Danke. Ja, da liegen die Konfig- Dateien. Abenteuer war etwas übertrieben. Nur mit dem Inhalt kann ich erst mal nichts anfangen. Das unterscheidet die Version 1 total von der Version 2. Ich möchte meine mühsam zum Laufen gebrachte DB nicht zerschießen.
                    Das steht drin- soll das Alles sein?
                    bolt-path = "/var/lib/influxdb/influxd.bolt"
                    engine-path = "/var/lib/influxdb/engine"
                    In den influxdb Pfad komme ich nicht rein - "Permission denied"
                    • L Laser
                      Laser
                      Einloggen geht jetzt auch. Mein notiertes Passwort stimmte nicht (Wieso- keine Ahnung- 1 Buchstabe falsch). Über "Einstellungen" in der Edge Seite rausgefunden.
                      Die Hilfe für Influx ist umfangreich, aber ebenso unverständlich... Kaum Beispiele, wie man wo etwas eingeben soll.
                      • L Laser
                        Die richtet sich vermutlich auch an Anwender mit gewissen Vorkenntnissen.
                          Laser
                          @thomas-braun Das ist richtig, um sich von Null darin einzuarbeiten, ist das kaum geeignet.
                          • L Laser
                            @laser
                            Grundkenntnisse im Umgang mit dem Betriebssystem und/oder Datenbanken zu erwerben ist auch mit Sicherheit nicht das Ziel der influxdb-Dokumentation.
                            Und deswegen ist es auch so schwierig, gute Doku zu schreiben. Und wird daher dann auch gerne vernachlässigt.
                              @laser
                              Laser
                              @thomas-braun hier mal ein Beispiel (aus der Influx- Hilfe-Datei):
                              Change your password
                              Use influx command line interface (CLI) to update your password.
                              User passwords cannot be updated in the InfluxDB UI.
                              Change your password using the influx CLI
                              Use the influx user password command to update a password for a user. Provide the following:
                              An operator token using your influx CLI connection configuration, INFLUX_TOKEN environment variable, or the --token, -t flag.
                              The username (with the --name, -n flag) or the user ID (with the --id, -i flag). View usernames and IDs in the output of influx user list.
                              Optional: the --password, -p flag and the new password. If you don’t provide a password flag, enter the new password when prompted.
                              Update a password
                              influx user password \
                                --name USERNAME \
                                --password PASSWORD
                              Replace the following:
                              USERNAME: The username to change the password for
                              PASSWORD: The new password
                              Was this page helpful?
                              Das Passwort konnte ich aber mit diesem Befehl ändern (user = username):
                              influx user password -n admin --password 12345678 -t <der notierte Token>
                              Mit der Influx Hilfe kam ich niemals auf diese Befehlseingabe. Man braucht schon sehr viel Phantasie...
