  4. io Broker startet nicht mehr
    6.6k
59 Beiträge 7 Kommentatoren 8.6k Aufrufe 6 Beobachtet
  • M MrNight
    MAX11905:~ MAX$ ./iobroker update
    Used repositories: beta, stable
    Adapter    "admin"        : 7.4.10   , installed 5.4.9  [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.19.7 [Updatable]
    Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
    Adapter    "cloud"        : 5.0.1    , installed 4.2.2  [Updatable]
    Adapter    "email"        : 1.3.1    , installed 1.1.3  [Updatable]
    Adapter    "harmony"      : 1.5.0    , installed 1.2.2  [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.15 [Updatable]
    Adapter    "hmip"         : 1.25.0   , installed 1.20.0 [Updatable]
    Adapter    "hue"          : 3.13.1   , installed 3.14.1
    Adapter    "iot"          : 3.3.0    , installed 3.4.5
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
    Adapter    "owntracks"    : 1.1.0    , installed 1.0.3  [Updatable]
    Adapter    "pushover"     : 4.1.0    , installed 2.1.0  [Updatable]
    Adapter    "sayit"        : 5.0.0    , installed 1.12.6 [Updatable]
    Adapter    "scenes"       : 3.2.3    , installed 4.0.1
    Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
    Adapter    "telegram"     : 4.0.0    , installed 1.14.1 [Updatable]
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 3.4.16 [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 0.11.0 [Updatable]
    MAX11905:~ MAX$
    so sieht das dann immer noch aus.
    Wenn ich dann nur den Admin Adapter Updaten will.
    MAX11905:~ MAX$ ./iobroker upgrade admin
    This upgrade of "admin" will at least introduce the following changes:
    -> 7.4.10:
    Corrected JSON-Config tables
    Corrected translation on the update adapter dialog
    -> 7.4.8:
    Show latest/stable labels by updating/downgrading of adapters
    Corrected selection of chinese language
    -> 7.4.7:
    Corrected the rendering of custom JSON config components
    Corrected the news dialog for multi-line messages
    -> 7.4.4:
    Showed value in object edit dialog
    -> 7.4.3:
    Changed information box on the hosts tab
    Corrected some errors in JsonConfig library
    Added flag expertMode to hide JSON config controls for non-experts
    Corrected cloud icon for admin
    Added old dialog names to adapter-react-v5 again
    -> 7.4.2:
    Made improvement for JSONConfig components
    Added clear button to text area JSON config component
    -> 7.4.1:
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @5.4.9 to @7.4.10 now? [(y)es, (n)o]:
    das bestätige ich dann mit "y"
    dann erscheint das:
    host.E11905.fritz.box Adapter "system.adapter.admin.0" is stopped.
    NPM version: 10.8.2
    Installing iobroker.admin@7.4.10... (System call)
    added 81 packages, removed 6 packages, changed 11 packages, and audited 1056 packages in 21s
    98 packages are looking for funding
      run `npm fund` for details
    88 vulnerabilities (12 low, 47 moderate, 24 high, 5 critical)
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues possible (including breaking changes), run:
      npm audit fix --force
    Some issues need review, and may require choosing
    a different dependency.
    Run `npm audit` for details.
    Updating objects from io-package.json for adapter "admin" with version "7.4.10"
    Update "system.adapter.admin.0"
    upload [312] admin.admin /Users/e/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [300] admin.admin /Users/enricoklimczak/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
    upload [250] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/node_modules_mui_system_esm_useTheme_useTheme_js-_95041.7238f945.chunk.js custom/static/js/node_modules_mui_system_esm_useTheme_useTheme_js-_95041.7238f945.chunk.js application/javascript
    upload [200] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.b1e4762d.chunk.js custom/static/js/src_bootstrap_jsx.b1e4762d.chunk.js application/javascript
    upload [150] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.fcf5d44e.chunk.js custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.fcf5d44e.chunk.js application/javascript
    upload [100] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.08770d2e.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.08770d2e.chunk.js application/javascript
    upload [90] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f075e886.chunk.js custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f075e886.chunk.js application/javascript
    upload [80] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_defaultTheme_js-node_modules_mui_material_styles_ide-00a7ec.54dc30ec.chunk.js custom/static/js/vendors-node_modules_mui_material_styles_defaultTheme_js-node_modules_mui_material_styles_ide-00a7ec.54dc30ec.chunk.js application/javascript
    upload [70] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_cronstrue_locales_de_js-nod-b40f79.ee63d226.chunk.js custom/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_cronstrue_locales_de_js-nod-b40f79.ee63d226.chunk.js application/javascript
    upload [60] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_system_esm_colorManipulator_colorManipulator_js-node_modules_mui_sys-525238.332f7d66.chunk.js custom/static/js/vendors-node_modules_mui_system_esm_colorManipulator_colorManipulator_js-node_modules_mui_sys-525238.332f7d66.chunk.js application/javascript
    upload [50] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.eed2bb86.chunk.js custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.eed2bb86.chunk.js application/javascript
    upload [40] admin.admin /Users/enrico/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js.1328581e.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js.1328581e.chunk.js application/javascript
    upload [30] admin.admin /Users/enriconode_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.98467b71.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.98467b71.chunk.js application/javascript
    upload [20] admin.admin /Users/enrico/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js application/javascript
    upload [19] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js.map application/json
    upload [18] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js application/javascript
    upload [17] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js.map custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js.map application/json
    upload [16] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js application/javascript
    upload [15] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js.map custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js.map application/json
    upload [14] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js application/javascript
    upload [13] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js.map custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js.map application/json
    upload [12] admin.admin /Users/e/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [11] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [1] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] admin.admin /Users/e/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    host.Eini11905.fritz.box Adapter "system.adapter.admin.0" is started
    E11905:~ e$
    wenn man dann wieder "iobroker update macht zeigt er an das es wieder nur die 5 Version ist. Hoffe habe das einigermaßen Verständlich rüber gebracht.
    Danke Dir.....
    @mrnight sagte in io Broker startet nicht mehr:
    was ist das?
    dast du vorher nicht beta deaktiviert?
    iob repo unset beta?
    wenn es danach immer och so ausdieht, versuchen wir einen anderen Weg
      was ist das?
      MrNight
      Enricosini11905:~ enrico$ ./iobroker repo unset beta
      Repository "beta" deactivated.
      Active repo(s): stable
      Upgrade policy: none
      Esini11905:~ e$
      das habe ich vorhin gemacht.
      Da steht doch "stable"
      • M MrNight
        Esini11905:~ e$
        und danach
          und danach
          MrNight
          Auf Stable habe ich es vor dem manuellen Upgrade gesetzt.
          Ist doch auch aktuell nicht mehr in „Beta“
          Trotzdem lässt es sich nicht so manuell Updaten.
          • M MrNight
            und das iob update zeigt trotzdem noch beide Repos als aktiv an.
            Vielleicht hilft ja ein reboot, sonst weiß ich nicht weiter
              MrNight
              Wie es zeigt alle beide als Aktiv an??
              Komme ich mit was durcheinander??
              • M MrNight
                hab ich dir jetzt zweimal aus deinem outout von iob update zitiert
                hier nochmal!
                  MrNight
                  schrieb am zuletzt editiert von MrNight
                  so habe nun den Rechner mehrmals neugestartet und da war nun der „Admin“ Adapter tatsächlich endlich auf der aktuellen Version.
                  Werde nun morgen die Adapter erstmal alle manuell im Terminal upgraden und dann mal sehen ob ich es gestartet bekomme. Habe ein bisschen Hoffnung.
                  Möchte mich heute erstmal ganz herzlich für deinen ja und den Support der anderen bedanken.
                  Morgen sehe ich ja dann ob es wieder ins laufen kommt.
                  • M MrNight
                    Möglicherweise hätte auch ein iob upload admin gereicht.
                    dazu darf aber bei iob update kein beta-Repository mehr beteiligt sein.
                    Zusätzlich würde es evtl. helfen, den jeweiligen Upgrade mit der option --debug auszuführen um erweiterte logausgaben für den Support zu erhalten.
                    also z.B. iob upgrade admin --debug
                    ich noch nicht wirklich, da die Vermutung
                    @homoran sagte in io Broker startet nicht mehr:
                    Ich fürchte auch, dass du den controller von einer ebenso antiken Version direkt auf die v7 gehoben hast, was nicht vorgesehen ist, und zu Kollateralschäden führt
                    nicht entkräftet wurde.
                      MrNight
                      was soll ich sagen.....es läuft tatsächlich alles wieder. Bin dir so dankbar für den Support und deine Zeit,
                      ab nun wird der das System gepflegt. Das war mir eine Lehre.
                      Habe ein Debug gemacht wie Du geschrieben hast wenn ich den noch veröffentlichen soll kann ich das noch machen.
                      • M MrNight
                        kann sein, dass noch was schlummert.
                        Gehen wir aber erstmal vom besten aus.
                        Das ist doch mal ein Wort!
                          MrNight
                          Nun mache mir mal keine Angst 🥲……was aber wohl am Limit läuft ist der Arbeitsspeicher.
                          Da kam schon eine Meldung.
                          • M MrNight
                            das hilft ohne exakten Wortlaut nichts!
                            was sagt denn top
                              MrNight
                              Bevor ich was zerschiesse….ich habe ja einen MacMini laufen. Der Befehl „Top“ kommt doch von linux.
                              Oder wie finde ich es?
                              • M MrNight
                                und apfelware ist modifiziertes linux
                                  MrNight
                                  ommands:
                                    iobroker setup                                               Setup ioBroker
                                    iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                                    iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                                    iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                                    iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                                    iobroker info                                                Shows the host info
                                    iobroker logs [<adapter>]                                    Monitor log
                                    iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                                    iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                                    iobroker rebuild [<module>]                                  Rebuild all native modules or path
                                    iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
                                    iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                                    iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                                    iobroker update [<repositoryUrl>]                            Update repository and list adapters
                                    iobroker upgrade                                             Upgrade management
                                    iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                                    iobroker object                                              Object management  [aliases: o]
                                    iobroker state                                               State management  [aliases: s]
                                    iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                                    iobroker list <type> [<filter>]                              List all entries, like objects
                                    iobroker chmod <mode> <file>                                 Change file rights
                                    iobroker chown <user> <group> <file>                         Change file ownership
                                    iobroker touch <file>                                        Touch file
                                    iobroker rm <file>                                           Remove file
                                    iobroker file                                                File management
                                    iobroker user                                                User commands
                                    iobroker group                                               group management
                                    iobroker host <hostname>                                     Set host to given hostname
                                    iobroker set <adapter>.<instance>                            Change settings of adapter config
                                    iobroker license <license.file or license.text>              Update license by given file
                                    iobroker cert                                                Certificate management
                                    iobroker clean <yes>                                         Clears all objects and states
                                    iobroker backup                                              Create backup
                                    iobroker restore <backup name or path>                       Restore a specified backup
                                    iobroker validate <backup name or path>                      Validate a specified backup
                                    iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                                    iobroker repo                                                Show repo information
                                    iobroker uuid                                                Show uuid of the installation  [aliases: id]
                                    iobroker unsetup                                             Reset license, installation secret and language
                                    iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                                    iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
                                    iobroker multihost                                           Multihost management
                                    iobroker compact                                             compact group management
                                    iobroker plugin                                              Plugin management
                                    iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                                    iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                                  Options:
                                    --help  Show help  [boolean]
                                  • M MrNight
                                    ommands:
                                    Options:
                                    @mrnight bitte immer alles zeigen!
                                    was hast du eingegeben?
                                      MrNight
                                      ./IoBroker top habe ich eingegeben.
                                      • M MrNight
                                        @mrnight
                                        top
                                        ist ein eigenes Programm und hat mit dem iobroker nichts zu tun.
                                        Ich weiß nur nicht, ob es das bei dir gibt.
                                          @mrnight
                                          top
                                          MrNight
                                          Was ich dir so sagen kann ist…..das er in IObroker anzeigt das nur 1GB RAM zur Verfügung stehen…..wenn ich aber beim Mac so schaue hat er noch gute 5GB frei von 8GB.
