  4. Test Adapter BMW/Mini v4.x.x
    6.8k
1.1k Beiträge 103 Kommentatoren 377.6k Aufrufe 89 Beobachtet
  • P Pino72
    Hi, hab auch den aktuellsten BMW Adapter am laufen, 2.9.0:
    bmw.0
    	2025-01-17 10:47:56.340	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
    bmw.0
    	2025-01-17 10:47:56.339	error	update failed
    bmw.0
    	2025-01-17 10:12:56.299	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
    bmw.0
    	2025-01-17 10:12:56.299	error	update failed
    bmw.0
    	2025-01-17 10:05:56.295	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
    bmw.0
    	2025-01-17 10:05:56.294	error	update failed
    bmw.0
    	2025-01-17 09:58:56.390	warn	Out of call volume quota. Quota will be replenished in 00:01:02.
    bmw.0
    	2025-01-17 09:44:56.280	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
    bmw.0
    	2025-01-17 09:44:56.280	error	update failed
    bmw.0
    	2025-01-17 08:58:54.396	warn	Out of call volume quota. Quota will be replenished in 00:01:04.
    bmw.0
    	2025-01-17 08:48:54.222	info	First update of Trips and Demands in 10 minutes
    bmw.0
    	2025-01-17 08:48:33.560	info	Initial first update of the vehicles
    bmw.0
    	2025-01-17 08:48:23.548	info	Found 1 bmw vehicles
    bmw.0
    	2025-01-17 08:48:23.200	info	Start getting bmw vehicles
    bmw.0
    	2025-01-17 08:48:23.051	info	Session found. If the login fails please delete bmw.0.auth.session and restart the adapter
    bmw.0
    	2025-01-17 08:48:23.037	info	starting. Version 2.9.0 (non-npm: TA2k/ioBroker.bmw#3145a510e56ff3291b51fdfe70708c81772cb3cd) in C:/ioBroker/node_modules/iobroker.bmw, node: v20.18.1, js-controller: 7.0.6
    Hab das update intervall schon auf 8 Minuten gestellt....normales Verhalten?
    lobomauL Offline
    lobomauL Offline
    lobomau
    #627
    @pino72 ja, vermutlich zu kurz. Ich bin bei 15min gelandet. Das läuft meistens ok.
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      #628
      BMW V.2.8.3
      Instanz wird grün.
      Beim Neustart der Instanz kommt:
      bmw.0
      2025-01-23 09:57:25.676	info	Found 1 bmw vehicles
      bmw.0
      2025-01-23 09:57:25.389	info	Start getting bmw vehicles
      bmw.0
      2025-01-23 09:57:25.098	info	Session found. If the login fails please delete bmw.0.auth.session and restart the adapter
      bmw.0
      2025-01-23 09:57:25.060	info	starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.bmw, node: v20.18.1, js-controller: 7.0.6
      Beim remote "Lichthupe einschalten" kommt dann aber:
      bmw.0
      2025-01-23 09:58:01.813	error	"Forbidden"
      bmw.0
      2025-01-23 09:58:01.812	error	AxiosError: Request failed with status code 403
      bmw.0
      2025-01-23 09:58:01.812	error	Remote command failed
      Habt ihr eine Idee was da los ist ?
      Danke.
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #629
        Habe nun mal update auf 2.9.0 gemacht.
        Im log kommt nun:
        bmw.0
        2025-01-23 10:10:48.669	warn	Out of call volume quota. Quota will be replenished in 00:49:12.
        bmw.0
        2025-01-23 10:10:48.587	info	Refresh values
        bmw.0
        2025-01-23 10:10:36.585	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:49:24."}
        bmw.0
        2025-01-23 10:10:36.585	error	AxiosError: Request failed with status code 403
        bmw.0
        2025-01-23 10:10:36.585	error	Remote command failed
        bmw.0
        2025-01-23 10:10:36.580	error	3 Retries failed
        bmw.0
        2025-01-23 10:10:31.466	warn	Rate Limit exceeded, retry in 5 seconds
        bmw.0
        2025-01-23 10:10:31.466	info	"Forbidden"
        bmw.0
        2025-01-23 10:10:31.466	info	Retry 5
        bmw.0
        2025-01-23 10:10:26.351	warn	Rate Limit exceeded, retry in 5 seconds
        bmw.0
        2025-01-23 10:10:26.351	info	"Forbidden"
        bmw.0
        2025-01-23 10:10:26.350	info	Retry 4
        bmw.0
        2025-01-23 10:10:21.272	warn	Rate Limit exceeded, retry in 5 seconds
        bmw.0
        2025-01-23 10:10:21.272	info	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:49:39."}
        bmw.0
        2025-01-23 10:10:21.272	info	Retry 3
        bmw.0
        2025-01-23 10:10:16.188	warn	Rate Limit exceeded, retry in 5 seconds
        bmw.0
        2025-01-23 10:10:16.188	info	"Forbidden"
        bmw.0
        2025-01-23 10:10:16.188	info	Retry 2
        bmw.0
        2025-01-23 10:10:11.142	warn	Rate Limit exceeded, retry in 5 seconds
        bmw.0
        2025-01-23 10:10:11.142	info	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:49:49."}
        bmw.0
        2025-01-23 10:10:11.141	info	Retry 1
        Fazit:
        remote funktioniert bei mir nicht mehr.
        Danke.
        vowillV T 2 Antworten Letzte Antwort
        • bahnuhrB bahnuhr
          Im log kommt nun:
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          bmw.0
          Fazit:
          vowillV Offline
          vowillV Offline
          vowill
          #630
          @bahnuhr Hm, gleiches bei mir. Laut BMW-Doku zur API wird der Fehler 403 in der Regel bei 'No permission for the clearance ID specified' ausgegeben.
          Vielleicht kan @tombox dazu etwas sagen?
          ioBroker im lxc auf NUC / Aktive Instanzen: 38
          • bahnuhrB bahnuhr
            Im log kommt nun:
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            bmw.0
            Fazit:
            tombox
            #631
            @bahnuhr Ich schaue mir das mal an
            lemonbiterL 1 Antwort Letzte Antwort
            • T tombox
              lemonbiterL Offline
              lemonbiterL Offline
              lemonbiter
              #632
              Ich hatte das heute bei meinem auch bzw. seit ein paar Tagen. Blöd besonders bei den Temperaturen ohne Standheizung vorglühen zu lassen. Auch hatte mein i5 keine Vrebindung mehr zur BMW Connected App auf dem Handy... Also Kilometerstand änderte sich nicht, Standort bleib unverändert etc...
              LÖSUNG: Ich musste die Headunit zurücksetzen und dann funktionierte alles wieder.
              Wie?
              In meinem Fall Fahrbereitschaft herstellen (bei Verbrennern Zündung an), dann den Lautstärkeknopf (am Lenkrad oder in der Mittelkonsole) ca. 30s IN WORTEN: DREISSIG Sekunden festhalten, SOLANGE bis sich das Display komplett ausschaltet und schwarz ist. Dann loslassen, bisschen warten, dann geht das Display wieder an und ZACK: Alles geht wieder
              LG
              LEM
              bahnuhrB 2 Antworten Letzte Antwort
              • lemonbiterL lemonbiter
                Wie?
                LG
                LEM
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #633
                @lemonbiter
                Das probier ich nachher mal aus.
                Melde mich dann wieder.
                Danke.
                  Wie?
                  LG
                  LEM
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  #634
                  @lemonbiter
                  Rückinfo von mir.
                  Klappt bei mir leider nicht.
                  Es kommt weiterhin:
                  bmw.0
                  2025-01-24 11:00:48.746	error	"Forbidden"
                  bmw.0
                  2025-01-24 11:00:48.746	error	AxiosError: Request failed with status code 403
                  bmw.0
                  2025-01-24 11:00:48.746	error	Remote command failed
                  bmw.0
                  2025-01-24 11:00:48.743	error	3 Retries failed
                  bmw.0
                  2025-01-24 11:00:43.456	warn	Rate Limit exceeded, retry in 5 seconds
                  bmw.0
                  2025-01-24 11:00:43.456	info	"Forbidden"
                  bmw.0
                  2025-01-24 11:00:43.456	info	Retry 5
                  bmw.0
                  2025-01-24 11:00:38.386	warn	Rate Limit exceeded, retry in 5 seconds
                  bmw.0
                  2025-01-24 11:00:38.386	info	"Forbidden"
                  bmw.0
                  2025-01-24 11:00:38.385	info	Retry 4
                  bmw.0
                  2025-01-24 11:00:33.109	warn	Rate Limit exceeded, retry in 5 seconds
                  bmw.0
                  2025-01-24 11:00:33.109	info	"Forbidden"
                  bmw.0
                  2025-01-24 11:00:33.109	info	Retry 3
                  bmw.0
                  2025-01-24 11:00:28.028	warn	Rate Limit exceeded, retry in 5 seconds
                  bmw.0
                  2025-01-24 11:00:28.028	info	"Forbidden"
                  bmw.0
                  2025-01-24 11:00:28.028	info	Retry 2
                  bmw.0
                  2025-01-24 11:00:22.987	warn	Rate Limit exceeded, retry in 5 seconds
                  bmw.0
                  2025-01-24 11:00:22.987	info	"Forbidden"
                  bmw.0
                  2025-01-24 11:00:22.987	info	Retry 1
                  Was hat BMW da wieder geändert ?
                  Nachtrag: sowas kam eben auch noch.
                  bmw.0
                  2025-01-24 11:06:50.427	warn	Out of call volume quota. Quota will be replenished in 00:53:10.
                  Danke.
                  Marc BergM 2 Antworten Letzte Antwort
                  • bahnuhrB bahnuhr
                    @lemonbiter
                    Rückinfo von mir.
                    Es kommt weiterhin:
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    bmw.0
                    Marc BergM Online
                    Marc BergM Online
                    Marc Berg
                    #635
                    @bahnuhr sagte in Test Adapter BMW/Mini v2.0.0:
                    Ganz normales Verhalten, wenn man die Server mit zu vielen Anfragen nervt.
                    Schau, ob das Updateintervall nicht zu kurz ist, starte den Adapter nicht zu oft neu, setze nicht ständig Befehle ab und warte die Zeit ab, die in der Meldung angegeben ist. Vorher gehts sowieso nichts. Politik der ruhigen Hand.
                    Mein Log, nachdem ich den Adapter zwei mal neu gestartet habe:
                    2025-01-24 11:49:19.347 - warn: bmw.0 (122305) Out of call volume quota. Quota will be replenished in 00:10:41.
                    2025-01-24 11:51:50.935 - warn: bmw.0 (122305) Rate Limit exceeded, retry in 5 seconds
                    2025-01-24 11:51:56.137 - warn: bmw.0 (122305) Rate Limit exceeded, retry in 5 seconds
                    2025-01-24 11:52:01.327 - warn: bmw.0 (122305) Rate Limit exceeded, retry in 5 seconds
                    2025-01-24 11:52:06.462 - warn: bmw.0 (122305) Rate Limit exceeded, retry in 5 seconds
                    2025-01-24 11:52:11.616 - warn: bmw.0 (122305) Rate Limit exceeded, retry in 5 seconds
                    2025-01-24 11:52:16.778 - error: bmw.0 (122305) 3 Retries failed
                    2025-01-24 11:52:16.779 - error: bmw.0 (122305) Remote command failed
                    2025-01-24 11:52:16.780 - error: bmw.0 (122305) AxiosError: Request failed with status code 403
                    2025-01-24 11:52:16.780 - error: bmw.0 (122305) "Forbidden"
                    2025-01-24 11:52:38.679 - error: bmw.0 (122522) getvehicles v2 failed
                    2025-01-24 11:52:38.680 - error: bmw.0 (122522) AxiosError: Request failed with status code 403
                    2025-01-24 11:52:38.681 - error: bmw.0 (122522) {"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:07:22."}
                    2025-01-24 11:52:38.681 - warn: bmw.0 (122522) Rate Limit exceeded, please wait 5 minutes
                    2025-01-24 11:55:38.834 - error: bmw.0 (122522) getvehicles v2 failed
                    2025-01-24 11:55:38.835 - error: bmw.0 (122522) AxiosError: Request failed with status code 403
                    2025-01-24 11:55:38.835 - error: bmw.0 (122522) {"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:04:22."}
                    2025-01-24 11:55:38.835 - warn: bmw.0 (122522) Rate Limit exceeded, please wait 5 minutes
                    • Marc BergM Marc Berg
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #636
                      @marc-berg sagte in Test Adapter BMW/Mini v2.0.0:
                      Das trifft bei mir nicht zu !
                      Selbstverständlich ist das Thema bekannt. Und ich habe nicht zu viele Befehle abgesetzt.
                      Und die Zeit habe ich auch abgewartet.
                      Es kommt aber immer das gleiche.
                      Danke.
                      • bahnuhrB bahnuhr
                        @lemonbiter
                        Rückinfo von mir.
                        Es kommt weiterhin:
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        bmw.0
                        Marc BergM Online
                        Marc BergM Online
                        Marc Berg
                        #637
                        Da du aber hier der einzige mit dem Problem bist, wird es wohl nicht am Server liegen.
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #638
                          Dann hast du aber die Beiträge oben nicht gelesen.
                          Danke.
                          • bahnuhrB bahnuhr
                            Marc BergM Online
                            Marc BergM Online
                            Marc Berg
                            #639
                            Doch.
                            @lobomau sagte in Test Adapter BMW/Mini v2.0.0:
                              Doch.
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #640
                              Doch.
                              @vowill sagte in Test Adapter BMW/Mini v2.0.0:
                              @lemonbiter sagte in Test Adapter BMW/Mini v2.0.0:
                              Da bin ich auch. Schon seit Jahren.
                              Danke.
                              • bahnuhrB bahnuhr
                                Doch.
                                Marc BergM Online
                                Marc BergM Online
                                Marc Berg
                                #641
                                @bahnuhr
                                Das läuft aber alles darauf hinaus, dass die Abfragen in zu kurzen Abständen kommen. Da können wir uns noch zehn mal im Kreis drehen.
                                  @bahnuhr
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #642
                                  @marc-berg
                                  @tombox
                                  Eine Idee hätte ich noch.
                                  Wie oben geschrieben frage ich die Daten nicht ständig ab.
                                  Für mich stellt sich die Frage wie BMW dies prüft.
                                  Wenn BMW auf die IP abstellt dann könnte das Problem an meinem Provider liegen.
                                  Hatte das gleiche Problem mal mit dem Adapter "tankerkoenig". Hierbei wurde von tankerkönig auf die IP abgestellt.
                                  Mein Provider (Glasfaser mit ipv6) stellt auf "Carrier-Grade-Network (CGN) " ab.
                                  Die Erklärung damals von meinem Provider:
                                  Also:
                                  Wenn mein Provider mehrere Kunden hat, die iob mit BMW Adapter nutzen dann haben diese wohl die gleiche IP.
                                  Und wenn dann BMW auf die IP abstellt, dann haben wir das Problem.
                                  @tombox
                                  Kannst du prüfen (oder vielleicht weißt du es ja auch) auf was BMW abstellt.
                                  Könnte das Verhalten/Einstellungen meines Providers das Problem sein.
                                  Wenn ja,
                                  was kann ich dann tun ?
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    @marc-berg
                                    @tombox
                                    Also:
                                    @tombox
                                    Wenn ja,
                                    Marc BergM Online
                                    Marc BergM Online
                                    Marc Berg
                                    #643
                                    Das CGN wird meines Wissens ausschließlich für IPv4 Adressen genutzt. Wenn du also per IPv6 mit den BMW-Server kommunizierst hättest du dieses Problem nicht. Da stellt sich die Frage, ob dein ioBroker Host IPv6 unterstützt?
                                    Was sagt
                                    wget -6 cocoapi.bmwgroup.com
                                    auf dem Host?
                                      Was sagt
                                      auf dem Host?
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #644
                                      da kommt:
                                      dieter@iobroker:~$ wget -6 cocoapi.bmwgroup.com
                                      --2025-01-24 12:56:14--  http://cocoapi.bmwgroup.com/
                                      Auflösen des Hostnamens cocoapi.bmwgroup.com (cocoapi.bmwgroup.com)… 2620:1ec:29              :1::45
                                      Verbindungsaufbau zu cocoapi.bmwgroup.com (cocoapi.bmwgroup.com)|2620:1ec:29:1::              45|:80 … verbunden.
                                      HTTP-Anforderung gesendet, auf Antwort wird gewartet … 404 Not Found
                                      2025-01-24 12:56:14 FEHLER 404: Not Found.
                                      kann ich natürlich auch falsch verstanden haben.
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        da kommt:
                                        Marc BergM Online
                                        Marc BergM Online
                                        Marc Berg
                                        #645
                                        @bahnuhr
                                        Das sieht doch gut aus. Nochmal den Test ohne "-6", um festzustellen, ob auch primär IPv6 genutzt wird.
                                          @bahnuhr
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #646
                                          dieter@iobroker:~$ wget cocoapi.bmwgroup.com
                                          --2025-01-24 13:05:31--  http://cocoapi.bmwgroup.com/
                                          Auflösen des Hostnamens cocoapi.bmwgroup.com (cocoapi.bmwgroup.com)… 2620:1ec:bdf::45, 13.107.246.45
                                          Verbindungsaufbau zu cocoapi.bmwgroup.com (cocoapi.bmwgroup.com)|2620:1ec:bdf::45|:80 … verbunden.
                                          2025-01-24 13:05:31 FEHLER 404: Not Found.
                                          Danke.
