  4. Zwei instanzen vom web adapter laufen lassen?
23 Beiträge 4 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • T TRB
    @skb
    Mit Dauerschleife meine ich das der web Adapter sich immer wieder neu startet. Hier einmal ein Auszug aus dem Log:
    Zuerst habe ich beide web adapter instanzen neu gestartet und dann um ca. 21:16 dann den adpater Energiefluss erweitert gestartet. Um 21:18 dann wieder gestoppt.
    2025-01-19 21:15:48.043 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
    2025-01-19 21:15:48.050 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
    2025-01-19 21:15:48.060 - info: web.0 (79942) Got terminate signal TERMINATE_YOURSELF
    2025-01-19 21:15:48.063 - warn: web.0 (79942) setTimeout called, but adapter is shutting down
    2025-01-19 21:15:48.565 - info: web.0 (79942) terminating
    2025-01-19 21:15:48.566 - debug: web.0 (79942) Plugin sentry destroyed
    2025-01-19 21:15:48.566 - info: web.0 (79942) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-01-19 21:15:49.052 - info: host.iobroker stopInstance timeout system.adapter.web.0 killing pid 79942
    2025-01-19 21:15:49.214 - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
    2025-01-19 21:15:49.215 - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
    2025-01-19 21:15:49.728 - info: host.iobroker stopInstance system.adapter.web.1 (force=false, process=true)
    2025-01-19 21:15:49.738 - info: host.iobroker stopInstance system.adapter.web.1 send kill signal
    2025-01-19 21:15:49.738 - info: web.1 (79941) Got terminate signal TERMINATE_YOURSELF
    2025-01-19 21:15:49.741 - warn: web.1 (79941) setTimeout called, but adapter is shutting down
    2025-01-19 21:15:50.242 - info: web.1 (79941) terminating
    2025-01-19 21:15:50.244 - debug: web.1 (79941) Plugin sentry destroyed
    2025-01-19 21:15:50.244 - info: web.1 (79941) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-01-19 21:15:50.740 - info: host.iobroker stopInstance timeout system.adapter.web.1 killing pid 79941
    2025-01-19 21:15:50.919 - warn: host.iobroker instance system.adapter.web.1 terminated due to SIGKILL
    2025-01-19 21:15:50.920 - info: host.iobroker instance system.adapter.web.1 terminated with code null ()
    2025-01-19 21:15:53.310 - info: host.iobroker instance system.adapter.web.0 in version "6.2.5" started with pid 80230
    2025-01-19 21:15:55.945 - info: host.iobroker instance system.adapter.web.1 in version "6.2.5" started with pid 80237
    2025-01-19 21:15:57.506 - debug: web.0 (80230) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-01-19 21:15:57.663 - debug: web.0 (80230) Objects client ready ... initialize now
    2025-01-19 21:15:57.682 - debug: web.0 (80230) Objects create System PubSub Client
    2025-01-19 21:15:57.683 - debug: web.0 (80230) Objects create User PubSub Client
    2025-01-19 21:15:57.881 - debug: web.0 (80230) Objects client initialize lua scripts
    2025-01-19 21:15:57.921 - debug: web.0 (80230) Objects connected to redis: 127.0.0.1:9001
    2025-01-19 21:15:58.039 - debug: web.0 (80230) Redis States: Use Redis connection: iobroker_redis:6379
    2025-01-19 21:15:58.193 - debug: web.0 (80230) States create System PubSub Client
    2025-01-19 21:15:58.195 - debug: web.0 (80230) States create User PubSub Client
    2025-01-19 21:15:58.228 - debug: web.0 (80230) States connected to redis: iobroker_redis:6379
    2025-01-19 21:15:58.308 - debug: web.0 (80230) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-19 21:16:00.031 - info: web.0 (80230) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
    2025-01-19 21:16:00.567 - debug: web.1 (80237) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-01-19 21:16:00.708 - debug: web.0 (80230) Activating states & socket info
    2025-01-19 21:16:00.758 - debug: web.1 (80237) Objects client ready ... initialize now
    2025-01-19 21:16:00.760 - debug: web.1 (80237) Objects create System PubSub Client
    2025-01-19 21:16:00.770 - debug: web.1 (80237) Objects create User PubSub Client
    2025-01-19 21:16:00.927 - debug: web.1 (80237) Objects client initialize lua scripts
    2025-01-19 21:16:00.711 - debug: web.0 (80230) Secure connection not enabled - using http createServer
    2025-01-19 21:16:00.716 - debug: web.0 (80230) Activating IOSocket
    2025-01-19 21:16:00.914 - info: web.0 (80230) socket.io server listening on port 8082
    2025-01-19 21:16:00.915 - debug: web.0 (80230) Activating extensions
    2025-01-19 21:16:00.916 - debug: web.0 (80230) Activating web files from objectDB
    2025-01-19 21:16:00.949 - info: web.0 (80230) http server listening on port 8082
    2025-01-19 21:16:00.953 - debug: web.1 (80237) Objects connected to redis: 127.0.0.1:9001
    2025-01-19 21:16:01.015 - debug: web.1 (80237) Redis States: Use Redis connection: iobroker_redis:6379
    2025-01-19 21:16:01.042 - debug: web.1 (80237) States create System PubSub Client
    2025-01-19 21:16:01.044 - debug: web.1 (80237) States create User PubSub Client
    2025-01-19 21:16:01.058 - debug: web.1 (80237) States connected to redis: iobroker_redis:6379
    2025-01-19 21:16:01.114 - debug: web.1 (80237) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-19 21:16:02.229 - info: web.1 (80237) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
    2025-01-19 21:16:02.715 - debug: web.1 (80237) Activating states & socket info
    2025-01-19 21:16:02.717 - debug: web.1 (80237) Secure connection not enabled - using http createServer
    2025-01-19 21:16:02.728 - debug: web.1 (80237) Activating IOSocket
    2025-01-19 21:16:02.826 - info: web.1 (80237) socket.io server listening on port 8084
    2025-01-19 21:16:02.827 - debug: web.1 (80237) Activating extensions
    2025-01-19 21:16:02.828 - debug: web.1 (80237) Activating web files from objectDB
    2025-01-19 21:16:02.835 - info: web.1 (80237) http server listening on port 8084
    2025-01-19 21:16:05.223 - info: web.0 (80230) ==> Connected system.user.admin from ::ffff:192.168.144.110
    2025-01-19 21:16:05.259 - debug: web.0 (80230) Connection from "vis.0"
    2025-01-19 21:16:05.427 - debug: web.0 (80230) 2025-01-19T20:16:05.427Z Request authenticate [system.user.admin]
    2025-01-19 21:16:05.704 - debug: web.0 (80230) Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command
    (...gekürzt...)
    2025-01-19 21:16:05.987 - debug: web.0 (80230)
    2025-01-19 21:16:08.258 - info: web.0 (80230) ==> Connected system.user.admin from ::ffff:192.168.144.110
    2025-01-19 21:16:08.319 - info: web.0 (80230) ==> Connected system.user.admin from ::ffff:192.168.144.110
    2025-01-19 21:16:08.401 - info: web.0 (80230) ==> Connected system.user.admin from ::ffff:192.168.144.110
    2025-01-19 21:16:08.549 - debug: web.0 (80230) Connection from "flot"
    2025-01-19 21:16:08.803 - debug: web.0 (80230) Subscribes: energiefluss-erweitert.0.configuration, energiefluss-erweitert.0.data, system.adapter.energiefluss-erweitert.0.alive
    2025-01-19 21:16:08.953 - debug: web.0 (80230) Subscribes: energiefluss-erweitert.0.configuration, energiefluss-erweitert.0.data, system.adapter.energiefluss-erweitert.0.alive
    2025-01-19 21:16:29.542 - info: host.iobroker "system.adapter.energiefluss-erweitert.0" enabled
    2025-01-19 21:16:29.555 - debug: web.0 (80230) Plugin sentry destroyed
    2025-01-19 21:16:29.556 - warn: web.0 (80230) Terminated (-100): Without reason
    2025-01-19 21:16:29.576 - debug: web.1 (80237) Plugin sentry destroyed
    2025-01-19 21:16:29.577 - warn: web.1 (80237) Terminated (-100): Without reason
    2025-01-19 21:16:31.115 - warn: web.0 (80230) setTimeout called, but adapter is shutting down
    2025-01-19 21:16:31.126 - warn: web.1 (80237) setTimeout called, but adapter is shutting down
    2025-01-19 21:16:31.731 - info: host.iobroker instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2025-01-19 21:16:31.732 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
    2025-01-19 21:16:31.732 - info: host.iobroker instance system.adapter.web.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2025-01-19 21:16:31.732 - info: host.iobroker Restart adapter system.adapter.web.1 because enabled
    2025-01-19 21:16:31.856 - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 80334
    2025-01-19 21:16:36.644 - info: host.iobroker instance system.adapter.web.0 in version "6.2.5" started with pid 80347
    2025-01-19 21:16:36.688 - info: host.iobroker instance system.adapter.web.1 in version "6.2.5" started with pid 80349
    2025-01-19 21:16:43.443 - debug: web.0 (80347) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-01-19 21:16:43.573 - debug: web.0 (80347) Objects client ready ... initialize now
    2025-01-19 21:16:43.584 - debug: web.0 (80347) Objects create System PubSub Client
    2025-01-19 21:16:43.590 - debug: web.0 (80347) Objects create User PubSub Client
    2025-01-19 21:16:43.751 - debug: web.1 (80349) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-01-19 21:16:43.759 - debug: web.0 (80347) Objects client initialize lua scripts
    2025-01-19 21:16:43.776 - debug: web.0 (80347) Objects connected to redis: 127.0.0.1:9001
    2025-01-19 21:16:43.838 - debug: web.0 (80347) Redis States: Use Redis connection: iobroker_redis:6379
    2025-01-19 21:16:43.886 - debug: web.0 (80347) States create System PubSub Client
    2025-01-19 21:16:43.887 - debug: web.0 (80347) States create User PubSub Client
    2025-01-19 21:16:43.905 - debug: web.1 (80349) Objects client ready ... initialize now
    2025-01-19 21:16:43.906 - debug: web.0 (80347) States connected to redis: iobroker_redis:6379
    2025-01-19 21:16:43.907 - debug: web.1 (80349) Objects create System PubSub Client
    2025-01-19 21:16:43.908 - debug: web.1 (80349) Objects create User PubSub Client
    2025-01-19 21:16:44.026 - debug: web.1 (80349) Objects client initialize lua scripts
    2025-01-19 21:16:44.064 - debug: web.0 (80347) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-19 21:16:44.089 - debug: web.1 (80349) Objects connected to redis: 127.0.0.1:9001
    2025-01-19 21:16:44.133 - info: javascript.0 (241) script.js.Energiemanagement.Bad_prüfen_ob_badebereit: Bad ist badebereit
    2025-01-19 21:16:44.306 - debug: web.1 (80349) Redis States: Use Redis connection: iobroker_redis:6379
    2025-01-19 21:16:44.391 - debug: web.1 (80349) States create System PubSub Client
    2025-01-19 21:16:44.392 - debug: web.1 (80349) States create User PubSub Client
    2025-01-19 21:16:44.422 - debug: web.1 (80349) States connected to redis: iobroker_redis:6379
    2025-01-19 21:16:44.482 - debug: web.1 (80349) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-19 21:16:46.095 - info: web.0 (80347) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
    2025-01-19 21:16:46.870 - debug: web.0 (80347) Activating states & socket info
    2025-01-19 21:16:47.159 - info: web.1 (80349) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
    2025-01-19 21:16:47.816 - debug: web.1 (80349) Activating states & socket info
    2025-01-19 21:16:49.467 - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGILL
    2025-01-19 21:16:49.467 - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
    2025-01-19 21:16:49.468 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
    2025-01-19 21:16:50.016 - warn: host.iobroker instance system.adapter.web.1 terminated due to SIGILL
    2025-01-19 21:16:50.016 - info: host.iobroker instance system.adapter.web.1 terminated with code null ()
    2025-01-19 21:16:50.017 - info: host.iobroker Restart adapter system.adapter.web.1 because enabled
    2025-01-19 21:17:21.757 - info: host.iobroker instance system.adapter.web.0 in version "6.2.5" started with pid 80421
    2025-01-19 21:17:21.813 - info: host.iobroker instance system.adapter.web.1 in version "6.2.5" started with pid 80422
    2025-01-19 21:17:27.404 - debug: web.1 (80422) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-01-19 21:17:27.498 - debug: web.1 (80422) Objects client ready ... initialize now
    2025-01-19 21:17:27.549 - debug: web.1 (80422) Objects create System PubSub Client
    2025-01-19 21:17:27.550 - debug: web.1 (80422) Objects create User PubSub Client
    2025-01-19 21:17:27.735 - debug: web.0 (80421) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-01-19 21:17:27.769 - debug: web.1 (80422) Objects client initialize lua scripts
    2025-01-19 21:17:27.833 - debug: web.0 (80421) Objects client ready ... initialize now
    2025-01-19 21:17:27.839 - debug: web.0 (80421) Objects create System PubSub Client
    2025-01-19 21:17:27.841 - debug: web.1 (80422) Objects connected to redis: 127.0.0.1:9001
    2025-01-19 21:17:27.840 - debug: web.0 (80421) Objects create User PubSub Client
    2025-01-19 21:17:28.001 - debug: web.0 (80421) Objects client initialize lua scripts
    2025-01-19 21:17:28.015 - debug: web.0 (80421) Objects connected to redis: 127.0.0.1:9001
    2025-01-19 21:17:28.041 - debug: web.1 (80422) Redis States: Use Redis connection: iobroker_redis:6379
    2025-01-19 21:17:28.118 - debug: web.1 (80422) States create System PubSub Client
    2025-01-19 21:17:28.120 - debug: web.1 (80422) States create User PubSub Client
    2025-01-19 21:17:28.133 - debug: web.1 (80422) States connected to redis: iobroker_redis:6379
    2025-01-19 21:17:28.181 - debug: web.0 (80421) Redis States: Use Redis connection: iobroker_redis:6379
    2025-01-19 21:17:28.211 - debug: web.1 (80422) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-19 21:17:28.252 - debug: web.0 (80421) States create System PubSub Client
    2025-01-19 21:17:28.262 - debug: web.0 (80421) States create User PubSub Client
    2025-01-19 21:17:28.286 - debug: web.0 (80421) States connected to redis: iobroker_redis:6379
    2025-01-19 21:17:28.357 - debug: web.0 (80421) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-19 21:17:29.639 - info: web.0 (80421) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
    2025-01-19 21:17:30.078 - info: web.1 (80422) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
    2025-01-19 21:17:30.144 - debug: web.0 (80421) Activating states & socket info
    2025-01-19 21:17:30.659 - debug: web.1 (80422) Activating states & socket info
    2025-01-19 21:17:31.591 - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGILL
    2025-01-19 21:17:31.592 - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
    2025-01-19 21:17:31.592 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
    2025-01-19 21:17:31.870 - warn: host.iobroker instance system.adapter.web.1 terminated due to SIGILL
    2025-01-19 21:17:31.871 - info: host.iobroker instance system.adapter.web.1 terminated with code null ()
    2025-01-19 21:17:31.871 - info: host.iobroker Restart adapter system.adapter.web.1 because enabled
    2025-01-19 21:18:04.981 - info: host.iobroker instance system.adapter.web.0 in version "6.2.5" started with pid 80493
    2025-01-19 21:18:05.046 - info: host.iobroker instance system.adapter.web.1 in version "6.2.5" started with pid 80494
    2025-01-19 21:18:10.984 - debug: web.0 (80493) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-01-19 21:18:11.701 - debug: web.1 (80494) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-01-19 21:18:12.307 - debug: web.0 (80493) Objects client ready ... initialize now
    2025-01-19 21:18:12.369 - debug: web.1 (80494) Objects client ready ... initialize now
    2025-01-19 21:18:12.445 - debug: web.0 (80493) Objects create System PubSub Client
    2025-01-19 21:18:12.454 - debug: web.1 (80494) Objects create System PubSub Client
    2025-01-19 21:18:12.446 - debug: web.0 (80493) Objects create User PubSub Client
    2025-01-19 21:18:12.471 - debug: web.1 (80494) Objects create User PubSub Client
    2025-01-19 21:18:13.048 - debug: web.0 (80493) Objects client initialize lua scripts
    2025-01-19 21:18:13.050 - debug: web.1 (80494) Objects client initialize lua scripts
    2025-01-19 21:18:13.078 - debug: web.1 (80494) Objects connected to redis: 127.0.0.1:9001
    2025-01-19 21:18:13.106 - debug: web.0 (80493) Objects connected to redis: 127.0.0.1:9001
    2025-01-19 21:18:13.267 - debug: web.1 (80494) Redis States: Use Redis connection: iobroker_redis:6379
    2025-01-19 21:18:13.342 - debug: web.1 (80494) States create System PubSub Client
    2025-01-19 21:18:13.346 - debug: web.1 (80494) States create User PubSub Client
    2025-01-19 21:18:13.390 - debug: web.0 (80493) Redis States: Use Redis connection: iobroker_redis:6379
    2025-01-19 21:18:13.401 - debug: web.1 (80494) States connected to redis: iobroker_redis:6379
    2025-01-19 21:18:13.627 - debug: web.0 (80493) States create System PubSub Client
    2025-01-19 21:18:13.621 - debug: web.1 (80494) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-19 21:18:13.637 - debug: web.0 (80493) States create User PubSub Client
    2025-01-19 21:18:13.719 - debug: web.0 (80493) States connected to redis: iobroker_redis:6379
    2025-01-19 21:18:13.965 - debug: web.0 (80493) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-19 21:18:16.688 - info: web.1 (80494) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
    2025-01-19 21:18:16.845 - info: host.iobroker "system.adapter.energiefluss-erweitert.0" disabled
    2025-01-19 21:18:16.846 - info: host.iobroker stopInstance system.adapter.energiefluss-erweitert.0 (force=false, process=true)
    2025-01-19 21:18:16.878 - info: host.iobroker stopInstance system.adapter.energiefluss-erweitert.0 send kill signal
    2025-01-19 21:18:17.984 - debug: web.1 (80494) Activating states & socket info
    2025-01-19 21:18:18.882 - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-19 21:18:18.015 - debug: web.1 (80494) Secure connection not enabled - using http createServer
    2025-01-19 21:18:18.151 - debug: web.1 (80494) Activating IOSocket
    2025-01-19 21:18:19.280 - info: web.1 (80494) socket.io server listening on port 8084
    2025-01-19 21:18:19.289 - debug: web.1 (80494) Activating extensions
    2025-01-19 21:18:19.295 - debug: web.1 (80494) Activating web files from objectDB
    2025-01-19 21:18:19.348 - info: web.1 (80494) http server listening on port 8084
    2025-01-19 21:18:19.703 - info: web.0 (80493) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
    2025-01-19 21:18:20.316 - debug: web.0 (80493) Activating states & socket info
    2025-01-19 21:18:20.322 - debug: web.0 (80493) Secure connection not enabled - using http createServer
    2025-01-19 21:18:20.333 - debug: web.0 (80493) Activating IOSocket
    2025-01-19 21:18:20.683 - info: web.0 (80493) socket.io server listening on port 8082
    2025-01-19 21:18:20.696 - debug: web.0 (80493) Activating extensions
    2025-01-19 21:18:20.698 - debug: web.0 (80493) Activating web files from objectDB
    2025-01-19 21:18:20.719 - info: web.0 (80493) http server listening on port 8082
    SKBS Offline
    SKBS Offline
    SKB
    @trb Bitte die Adapter mal wieder auf Info stellen. Dann die EF Instanz starten und die Ausgabe des Log einstellen. Die Web-Instanz lädt die Web Extensions nicht.
    Screenshot der Web-Instanz noch, bitte.
    • SKBS SKB
      TRB
      schrieb am zuletzt editiert von TRB
      @skb
      Das Log:
      2025-01-19 21:47:32.571 - info: host.iobroker "system.adapter.energiefluss-erweitert.0" enabled
      2025-01-19 21:47:32.596 - warn: web.0 (82033) Terminated (-100): Without reason
      2025-01-19 21:47:34.227 - warn: web.0 (82033) setTimeout called, but adapter is shutting down
      2025-01-19 21:47:35.337 - info: host.iobroker instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2025-01-19 21:47:35.338 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
      2025-01-19 21:47:35.580 - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 82500
      2025-01-19 21:47:38.343 - info: host.iobroker instance system.adapter.web.0 in version "6.2.5" started with pid 82507
      2025-01-19 21:47:42.613 - info: energiefluss-erweitert.0 (82500) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.18.1, js-controller: 7.0.6
      2025-01-19 21:47:42.747 - info: energiefluss-erweitert.0 (82500) Adapter started. Loading config!
      2025-01-19 21:47:44.851 - info: energiefluss-erweitert.0 (82500) Configuration loaded!
      2025-01-19 21:47:44.860 - info: energiefluss-erweitert.0 (82500) Requesting the following states: energiefluss-erweitert.0.configuration,0_userdata.0.Solaredge.SE_Netzbezug,alias.0.Power.SS Waschmaschine POWER_STATUS,alias.0.Power.PV_Production,alias.0.Power.Verbrauch Haus,alias.0.Other.PV_Energy_today,0_userdata.0.Schwellwert_Ueberschussstrom,alias.0.Power.IEC_ENERGY_COUNTER,alias.0.Power.IEC_ENERGY_COUNTER_2_Einspeisung,0_userdata.0.WP_Bezug_Heizen,0_userdata.0.WP_Bezug_WW,0_userdata.0.Pseudoenergie_Herd,0_userdata.0.Pseudoenergie_Kaffeemaschine,0_userdata.0.Pseudoenergie_TV,0_userdata.0.Pseudoenergie_WM
      2025-01-19 21:47:46.689 - info: web.0 (82507) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
      2025-01-19 21:47:47.067 - info: web.0 (82507) socket.io server listening on port 8082
      2025-01-19 21:47:47.938 - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGILL
      2025-01-19 21:47:47.939 - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
      2025-01-19 21:47:47.939 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
      2025-01-19 21:48:19.268 - info: host.iobroker instance system.adapter.web.0 in version "6.2.5" started with pid 82570
      2025-01-19 21:48:22.635 - info: web.0 (82570) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
      2025-01-19 21:48:23.230 - info: web.0 (82570) socket.io server listening on port 8082
      2025-01-19 21:48:24.127 - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGILL
      2025-01-19 21:48:24.127 - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
      2025-01-19 21:48:24.127 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
      2025-01-19 21:48:55.965 - info: host.iobroker instance system.adapter.web.0 in version "6.2.5" started with pid 82612
      2025-01-19 21:48:59.984 - info: web.0 (82612) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.6
      2025-01-19 21:49:00.439 - info: web.0 (82612) socket.io server listening on port 8082
      2025-01-19 21:49:01.255 - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGILL
      2025-01-19 21:49:01.256 - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
      2025-01-19 21:49:01.256 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
      SKBS 1 Antwort Letzte Antwort
      • T TRB
        @skb
        Das Log:
        SKBS Offline
        SKBS Offline
        SKB
        @trb Tippfehler passieren - bzw. die Autokorrektur am Telefon. Sollte Log heißen.
        Hast Du den Adapter via GitHub oder über das ioBroker Repository installiert?
        Am Besten machst du mal einen Upload des Adapters.
        Adapter im Tab Adapter über die 3 Punkte anklicken und den Pfeil nach oben drücken.
        Danach den EF Adapter wieder starten und die Ausgabe des Log.
        • SKBS SKB
          TRB
          @skb Eigentlich sollte der über iobroker aktualisiert worden sein. Kann mich nicht erinnern den jemals von GitHub installiert zu haben.
          Upload habe ich durchgeführt - Verhalten ist unverändert (Siehe Log in meinem vorherigen Post)
          Hilft es den EF adapter noch einmal neu zu installieren?
          • T TRB
            SKBS Offline
            SKBS Offline
            SKB
            @trb Ich würde mal den einen Web-Adapter entfernen. Oder, wird der zwingend benötigt?
            Ich verstehe nicht, wieso der Web-Adapter die Extension nicht lädt.
            Hak mal bitte die Simple-API an und einen Screenshot des Tab "Extra" vom Web-Adapter.
            • SKBS SKB
              TRB
              @skb web.1 hatte ich schon deaktiviert. Kann die Instanz auch entfernen. Bisher lief alles über web.0 ohne Probleme.
              => Simple API ist angehakt
              => EF und web adapter neu installiert
              Screenshot:
              • T TRB
                Screenshot:
                SKBS Offline
                SKBS Offline
                SKB
                @trb Sieht laut Screenshots gut aus.
                Wie ist das Ergebnis?
                • SKBS SKB
                  TRB
                  @skb Leider unverändert. Hatte auch mal vis gestoppt und nur den EF gestartet. Das Verhalten von web.0 ist das immer dasselbe.
                  Muss jetzt leider erstmal aufhören weil ich morgen früh raus muss.
                    TRB
                    So, bin leider immer noch nicht weitergekommen.
                    @SKB: Was mich etwas wundert ist, dass die Weboberfläche von EF adapter immernoch erreichbar ist (unter http://<meine_IP>:8082/energiefluss-erweitert/) obwohl der adapter ausgeschaltet ist.
                    Er ist allerdings wie eingefroren und aktualisiert die Werte aus den Datenpunkten nicht.
                    • T TRB
                      SKBS Offline
                      SKBS Offline
                      SKB
                      @trb Inwiefern ist das verwunderlich? Die Oberfläche wird über den Web-Adapter serviert. Der EF liefert nur die Daten dazu. Daher eingefroren.
                      Hast du die Möglichkeit, ein 2. Docker zum Testen aufzusetzen?
                      Mich wundert hier viel mehr, das der Web-Adapter das Plugin nicht lädt und dieser immer wieder neu startet.
                      Ob @apollon77 hier noch etwas weiss?
                      • SKBS SKB
                        TRB
                        @skb Ok, wenn das so normal ist, alles gut. Ich bin auf diesem Gebiet tatsächlich absolut unerfahren.
                        Ein zweiter iobroker sollte möglich sein via docker. Muss schauen, dass ich dafür Zeit finde. Was wären die adapter die dort laufen müssten?
                        web, vis, EF?
                        Melde mich sobald der Testcontainer läuft
                        • T TRB
                          web, vis, EF?
                          TRB
                          Testcontainer ist aufgesetzt im Docker. Image von buanet stable, alles frisch installiert. Das Verhalten ist dasselbe. Bin etwas ratlos.
                          Kann es etwas mit den Docker Einstellungen zu tun haben? Wüsste aber nicht so richtig was da sein sollte...
                          Und lässt sich evtl. ein Downgrade von EF auf Version 0.4x durchführen? Leider geht das über iobroker direkt nicht, dort ist nur noch Version 0.5 und höher vorhanden.
                          T crunchipC 2 Antworten Letzte Antwort
                          • T TRB
                            TRB
                            Kann hier keiner weiterhelfen? Und bin ich wirklich der Einzige mit diesem Problem?
                            Leider fehlen mir die Fähigkeiten weiter selbst zu analysieren. Ich kann aber mit der Testinstanz jetzt frei Dinge ausprobieren. Hat jemand vielleicht eine Idee was die Fehlerursache sein könnte?
                            Vielleicht noch als Hintergrund: Mein Docker läuft auf dem Hostsystem Openmediavault 7 mit einigen anderen Dingen wie
                            • Nextcloud AIO
                            • TvHeadend
                            • Adguard Home
                            • Syncthing
                            Iobroker (produktiv) nutzt eine Redis Datenbank, die Testumgebung nicht.
                            Hardware ist ein HP Proliant gen7 N40, AMD Turion II, 16GB RAM
                            • T TRB
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @trb sagte in Zwei instanzen vom web adapter laufen lassen?:
                              hab zwar nicht den Adapter , jedoch geht das bei allen
                                TRB
                                @crunchip Vielen Dank! Hatte das Feld "manuell eingeben" immer übersehen. 🙈
                                Nun bin ich zurück auf Version 0.4.1 und siehe da: Es läuft wieder alles.
                                @SKB: Kannst du nachvollziehen was geändert wurde zw. 0.4.1 und 0.6.2 was mein Problem verursachen könnte?
                                SKBS 2 Antworten Letzte Antwort
                                • T TRB
                                  SKBS Offline
                                  SKBS Offline
                                  SKB
                                  @trb Das kannst auch du selbständig sehen - dafür gibt es ja die Versionshistorie bei GitHub 😉
                                  Bei dir wird die Extension nicht geladen - wieso das so ist, kann ich nicht sagen. Das ist das Problem des Web-Adapters.
                                  • T TRB
                                    SKBS Offline
                                    SKBS Offline
                                    SKB
                                    @trb Ich habe dies jetzt nochmals bei mir und bei einem Arbeitskollegen in einer Docker-Umgebung ausprobiert. Buanet installiert, EF-Adapter installiert, dieser installiert automatisch den Web-Adapter mit, Instanzlink aufgerufen -> Geht.
                                    Die Web-Adapter landen nicht in einer Startschleife. Also irgendwas ist da bei Dir strubbelig. Ist bei Dir wirklich die Erweiterungsbehandlung im Tab Extras nicht deaktiviert oder Ähnliches?
