  4. Zigbee Probleme
Zigbee Probleme
34 Beiträge 7 Kommentatoren 4.8k Aufrufe 6 Beobachtet
  • AsgothianA Asgothian
    @labamba sagte in Zigbee Probleme:
    Ich habe alle zum Tisch geholt und in gleicher Position versucht anzumelden.
    hast du den Adapter auf die 1.10.14 aus dem Latest aktualisiert ?
    Was wird beim starten des Adapters ins Log geschrieben ?
    LaBamba
    schrieb am zuletzt editiert von LaBamba
    @asgothian
    Adapter ist auf der aktuellsten Version
    zigbee.0
    	2025-01-03 23:24:15.705	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","pnpId":"usb-Texas_Instruments_CC2538_USB_CDC-if00","vendorId":"0451","productId":"16c8"},{"path":"/dev/ttyAMA0"}]
    admin.0
    	2025-01-03 23:24:14.971	info	==> Connected system.user.admin from 192.168.178.31
    zigbee.0
    	2025-01-03 23:24:07.700	info	Device 0x00158d0003a4aea6 "undefined" not present in statesMapping - relying on exposes for device definition.
    zigbee.0
    	2025-01-03 23:24:07.237	info	debug devices set to []
    zigbee.0
    	2025-01-03 23:24:07.175	warn	download icon Kindfenster for undefined Device not available. Check your devices.
    zigbee.0
    	2025-01-03 23:24:07.127	info	Zigbee started
    zigbee.0
    	2025-01-03 23:24:07.125	info	0x00158d0006335f56 (addr 42017): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    	2025-01-03 23:24:07.124	info	0x00158d0003a4aea6 (addr 32594): Not supported (model undefined)(Unknown)
    zigbee.0
    	2025-01-03 23:24:07.123	info	0x00158d0003f3628c (addr 52907): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    	2025-01-03 23:24:07.120	info	0x00158d0003cf38ad (addr 60239): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    	2025-01-03 23:24:07.115	info	0x00158d000633b878 (addr 47490): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    	2025-01-03 23:24:07.111	info	0x00158d0003f362a5 (addr 10909): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    	2025-01-03 23:24:07.046	info	Currently 6 devices are joined:
    zigbee.0
    	2025-01-03 23:24:07.035	info	--> transmitPower : normal
    zigbee.0
    	2025-01-03 23:24:07.011	info	Unable to disable LED, unsupported function.
    zigbee.0
    	2025-01-03 23:24:07.010	info	Disable LED
    zigbee.0
    	2025-01-03 23:24:07.009	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200327}}
    zigbee.0
    	2025-01-03 23:24:06.172	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    	2025-01-03 23:24:05.597	info	Starting Zigbee npm ...
    zigbee.0
    	2025-01-03 23:24:05.593	info	delete old Backup files. keep only last 10
    zigbee.0
    	2025-01-03 23:23:59.669	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 7.0.6
    Ein paar Sensoren sind drin! Aus Proiorität habe ich die Bewegungssensoren mal rein gemacht. Das sind genau die ich davor auch rein bekommen habe. Jedoch die anderen bekomme ich nicht rein.
    arteckA AsgothianA 2 Antworten Letzte Antwort
    • L LaBamba
      @asgothian
      zigbee.0
      admin.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      arteckA Offline
      arteckA Offline
      arteck
      0x00158d0003a4aea6
      was ist das 0x00158d0003a4aea6 für Gerät.. der verursacht die Probleme
      bei dem Stick hat sich auch in den letztn 4 Jahren nix grossartig getan.. der sollte tun ..
      aber du hast ein Backup zurückgespielt. oder... die Fehlermeldung aus dem ersten Post sieht zumindest danahc aus..
      da die settings zwischen dem adapter und dem Stick nicht mehr passen..
      deshalb auch die ""Den Start des Adapters mit inkonsistenter Konfiguration erzwingen ......"
      also WAS HAST DU GENAU GETAN ???????????????
      L 1 Antwort Letzte Antwort
      • L LaBamba
        @asgothian
        zigbee.0
        admin.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @labamba Hast du Geräte die fest am Strom hängen ? Wenn ja diese zuerst pairen, dann die Sensoren.
        A.
        • arteckA arteck
          0x00158d0003a4aea6
          LaBamba
          @arteck
          alles Geräte sind von Aquara (Bewegungsmelder, Temperatursenoren und Fensterkontakte)
          Besonders die Türsensoren und Temperatursensoren machen Probleme.
          https://www.zigbee2mqtt.io/devices/MCCGQ11LM.html
          Die Bewegungsmelder konnte ich alle wieder anmelden.
          Jedoch verstehe ich nicht warum ich manche Türsensoren der gleichen Bauart gehen und andere wiederum nicht.
          Grundsätzlich habe ich festgestellt, dass die selben 8 Geräte immer funktionieren sich anzumelden. Die anderen ca. 10 Geräte kann man stundenlang versuchen anzumelden. Jedoch es passiert nichts.
          Ich hatte vor ca. 1 - 1 1/2 Jahren mal ein Backup zurückgespielt. Seitdem ist es gelaufen. Jedoch war es schon da nicht möglich neue Geräte anzumelden.
          Das Problem fing an, dass sich ein Bewegungsmelder verabschiedet hatte (defekt) und ich einen neuen einsetzten wollte. Ich hatte es nicht geschafft ein neues Gerät anzumelden.
          Dann habe ich aus versehen den Haken bei "Den Start des Adapter mit inkonsitenter Konfiguration" rausgemacht und kein Gerät wurde mehr gefunden. Beim neuen setzen des Hackens musste ich alle Geräte wieder neu anmelden.
          Jedoch konnte ich ungefähr 8 von 18 Geräten wieder finden.
          Danach habe ich dann wie hier im Chat vorgeschlagen die Dateien in *.old umbenannt.
          Aktuell schaut es jetzt so aus!
          Jedoch sind hier auch keine Daten mehr für die einzelnen Sensoren vorhanden.
            A.
            LaBamba
            @asgothian
            Sind alle mit Batterie betrieben!
            1Topf1 1 Antwort Letzte Antwort
            • AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @labamba ich muss an dieser Stelle die Frage stellen ob du sicher bist das du die Geräte zum Anmelden erfolgreich zurück setzt. Das immer genau die gleichen 8 Geräte sich anmelden lassen deutet für mich darauf hin dass da etwas unsauber ist.
              Ansonsten würde ich empfehlen den cc3538 in Rente zu schicken und durch etwas modernes (z.Bsp einen SONOFF Zigbee 3.0 USB Dongle Plus - wichtig: den mit dem TI Chipsatz, nicht den mit dem EFR32MG21 Chipsatz) zu ersetzen.
              Auch ist denkbar das die Sensoren defekt sind oder deren Batterien am Ende sind.
              Aus der Software ist absolut nicht zu erklären warum nur bestimmte Geräte anlernbar sein sollten bzw. warum nur eine bestimmte Anzahl geht.
              A.
              L rug1024R 2 Antworten Letzte Antwort
              • L LaBamba
                @asgothian
                1Topf1 Offline
                1Topf1 Offline
                1Topf
                @labamba Für solche Problemfälle habe ich mir ein normales Zigbee-Gateway zugelegt. Wenn sich die Geräte dort auch nicht anlernen lassen, weiß man zu 99%, wo das Problem liegt.
                  A.
                  LaBamba
                  @asgothian
                  Ist dieses System dann fertig oder muss dieses dann auch geflasht werden. Damit habe ich keine Erfahrungen.
                  • L LaBamba
                    @asgothian
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @asgothian
                    welches System.. es ist ein USB stick.. und ja muss evtl geflasht werden.. wie das geht steht hier im forum als auch in zahleichen YT Videos
                    • arteckA arteck
                      @asgothian
                      LaBamba
                      @arteck @Asgothian
                      Ich habe anscheinend eine Lösung gefunden.
                      Die Geräte wurden alle nochmals entfernt. Danach habe ich dann einige Tage gewartet. Irgendwann sind sie im Adapter nicht mehr aufgetaucht. Neustart einmal Nachts!!
                      Danach habe ich die Geräte wieder hinzugefügt. ...und schaue da, es funktioniert wieder mehr als die 8 Geräte in das System aufzunehmen.
                      Danke an alle die mir geholfen haben!
                        A.
                        rug1024R Offline
                        rug1024R Offline
                        rug1024
                        @asgothian sagte in Zigbee Probleme:
                        Kannst Du kurz erläutern warum Du vom EFR32MG21 Chipsatz abrätst?
                        • rug1024R rug1024
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @rug1024 sagte in Zigbee Probleme:
                          Ich rate nicht davon ab. Ich bevorzuge einfach den TI Chipsatz, da die Unterstützung davon deutlich ausgereifter ist als die beim EFR32.
                          Ich habe damit bisher wenig Erfahrung.
                          A.
                          rug1024R mickemupM 2 Antworten Letzte Antwort
                            A.
                            rug1024R Offline
                            rug1024R Offline
                            rug1024
                            @asgothian
                            Danke für die flotte Rückmeldung. Grund meiner Frage: Ich erwarte in Kürze einen https://smlight.tech/product/slzb-06m/ vom AliExpress, erstmal zum Testen außerhalb der Produktivumgebung. Werde gerne berichten falls gewünscht.
                            • rug1024R rug1024
                              @asgothian
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @rug1024 bitte ja
                                A.
                                mickemupM Online
                                mickemupM Online
                                mickemup
                                @asgothian
                                OK ich habe mir vor kurzen den "sonoff-zigbee-3-0-usb-dongle-plus-e" geholt, da der andere bei mir gerade nicht verfügbar war.
                                Dieser ist auf der SONOFF Homepage als IO-Broker kompatibel angegeben.
                                Hat bisher auch reibungslos geklappt und kein Flash von neuer Firmware usw. nötig. :-)
                                haselchenH rug1024R 2 Antworten Letzte Antwort
                                • mickemupM mickemup
                                  @asgothian
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @mickemup
                                  Was nicht heißt , dass ein Betrieb mit alter FW in ferner Zukunft noch gegeben ist .
                                    @asgothian
                                    rug1024R Offline
                                    rug1024R Offline
                                    rug1024
                                    @mickemup
                                    Ein Vorteil beim Plus-E mit SiLabs-Chip ist wohl, das Firmware flashen nun ohne großes rumgehampel über den Browser möglich ist: https://darkxst.github.io/silabs-firmware-builder/
                                    • rug1024R rug1024
                                      @mickemup
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @mickemup
                                      ja und danach musst du alles neu anlernen da der E kein backup einspiellen kann
                                      rug1024R 1 Antwort Letzte Antwort
                                      • arteckA arteck
                                        @mickemup
                                        rug1024R Offline
                                        rug1024R Offline
                                        rug1024
                                        @arteck
                                        Koenkk-FW-Updates waren bei mir stets mit dem neu Anlernen aller Geräte verbunden, auch beim aktuellen Sonoff-P-Stick und dem den ich davor hatte.
                                        Auch habe ich es fast nie geschafft den Haken bei "Start mit inkonsister Konfiguration erzwingen" weg zu lassen weil der Adapter dann eben gar nicht startet. Wenn alles läuft dann bloß nicht anfassen. Backup zurückspielen? Hat nie funktioniert bei mir. Daher baue ich mir nun eine Testumgebung um da besser zu werden.
                                          AsgothianA Offline
                                          Asgothian
                                          Wenn du so arbeitest ist es kein Wunder das du jedes mal deine Geräte neu anmelden musstest. Der Adapter sollte IMMER ohne diesen Haken gestartet werden. Es bedarf ggf. einiges an Handarbeit das hin zu bekommen. Der Haken ist ausschliesslich für notfälle gedacht - im Produktiveinsatz sollte der nicht gesetzt sein.
                                          A.
