  3. Off Topic
  4. Grafana
  5. JSON in Grafana einbinden
    6.6k
Geplant Angeheftet Gesperrt Verschoben Grafana
39 Beiträge 2 Kommentatoren 5.4k Aufrufe 2 Beobachtet
  • CodierknechtC Codierknecht
    @stefu87_ch
    Also bei mir sieht das so aus:
    Per Script ermittle ich z.B. die Signalstärke meiner Tasmota-Geräte und schreibe das Ganze in einen eigenen DP.
    const sonoff_ids = Array.prototype.slice.apply($('sonoff.0.*.Wifi_RSSI'));
    var sonoffStates = {};
    function refreshSonoffValues(elementList) {
        for (const element of elementList) {
            let objAlive = getState(element.replace('.Wifi_RSSI', '.alive')).val;
            let objName = getObject(element.replace('.Wifi_RSSI', '')).common.name;
            sonoffStates[objName] = (objAlive ? getState(element).val : 0);
        setState('0_userdata.0.Monitoring.Sonoff.RSSI', JSON.stringify(sonoffStates), true);
    schedule('* * * * *', function() {
        refreshSonoffValues(sonoff_ids);
    In Grafana lese ich den DP per SimpleApi.
    Das sieht dann so aus:
     "id": 4,
     "type": "bargauge",
     "title": "Sonoff",
     "gridPos": {
       "x": 0,
       "y": 1,
       "h": 17,
       "w": 11
     "fieldConfig": {
       "defaults": {
         "mappings": [],
         "thresholds": {
           "mode": "absolute",
           "steps": [
               "color": "orange",
               "value": null
               "color": "yellow",
               "value": 20
               "color": "green",
               "value": 50
         "color": {
           "mode": "thresholds"
         "decimals": 0,
         "max": 100,
         "min": 0,
         "unit": "percent"
       "overrides": []
     "transformations": [
         "id": "extractFields",
         "options": {
           "replace": true,
           "source": "A"
         "id": "transpose",
         "options": {}
         "id": "sortBy",
         "options": {
           "fields": {},
           "sort": [
               "field": "Field"
     "pluginVersion": "11.4.0",
     "targets": [
         "columns": [],
         "datasource": {
           "type": "yesoreyeram-infinity-datasource",
           "uid": "adut1o422tpfkf"
         "filters": [],
         "format": "table",
         "global_query_id": "",
         "parser": "backend",
         "refId": "A",
         "root_selector": "",
         "source": "url",
         "type": "json",
         "uql": "parse-json\r\n| jsonata \"$.result[0].value\"\r\n\r\n",
         "url": "http://192.168.178.9:8083/getPlainValue/0_userdata.0.Monitoring.Sonoff.RSSI",
         "url_options": {
           "body_content_type": "text/plain",
           "body_type": "none",
           "data": "",
           "headers": [],
           "method": "GET"
     "datasource": {
     "options": {
       "reduceOptions": {
         "values": true,
         "calcs": [
           "min"
         "fields": "/^1$/"
       "orientation": "horizontal",
       "legend": {
         "showLegend": false,
         "displayMode": "list",
         "placement": "bottom",
         "calcs": []
       "displayMode": "gradient",
       "valueMode": "color",
       "namePlacement": "left",
       "showUnfilled": true,
       "sizing": "manual",
       "minVizWidth": 8,
       "minVizHeight": 0,
       "maxVizHeight": 20
    stefu87_CHS Offline
    stefu87_CHS Offline
    stefu87_CH
    @codierknecht ok sowas würde ich gerne haben, aber kann man das auch machen, wenn in der Tabelle für jeden Tag ein Wert drin steht?
    Also z.B so:
    01.01.2025 5.64kW
    02.01.2025 6.52kW
    03.01.2025 4.58kW
    usw…
    Cores: 1 × 8 = 8 cores
    Threads: 16
    mit Proxmox
    LXC Container mit Iobroker
    • stefu87_CHS stefu87_CH
      Also z.B so:
      01.01.2025 5.64kW
      02.01.2025 6.52kW
      03.01.2025 4.58kW
      usw…
      CodierknechtC Offline
      Codierknecht
      @stefu87_ch
      Kein Problem. Das JSON muss dann aber etwas anders aussehen. Der Wert darf keine Einheit haben. Die wird in Grafana eingestellt.
      "{"01.01.2025":5.64,"02.01.2025":6.25,"03.01.2025":5.89,"04.01.2025":5.4}"
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      stefu87_CHS 2 Antworten Letzte Antwort
        @stefu87_ch
        stefu87_CHS Offline
        stefu87_CHS Offline
        stefu87_CH
        @codierknecht ok danke für den Tipp.
        Werde mir morgen mal den Java Code anschauen wo das definiert wird im Code
        Threads: 16
        mit Proxmox
          @stefu87_ch
          stefu87_CHS Offline
          stefu87_CHS Offline
          stefu87_CH
          @codierknecht Also wenn ich die Json Tabelle anpasse, erscheint nur das bei mir:
          Die Tabelle sieht so aus:
          Threads: 16
          mit Proxmox
            Codierknecht
            @stefu87_ch
            Dein JSON sieht ja auch völlig anders aus. Du hast ein Array von Objekten mit jeweils 2 Properties.
            Mein JSON ist ein Objekt mit X Properties.
            Da gibt's in Grafana jede Menge Manipulationsmöglichkeiten über die "Transformations". Da muss man mal kreativ werden und rumspielen 😁
            Oder Du postest hier mal Dein JSON (in Code-Tags </>).
              @stefu87_ch
              stefu87_CHS Offline
              stefu87_CHS Offline
              stefu87_CH
              @codierknecht
              Also habe diesen Code so von einer Internetseite kopiert gehabt vor längere Zeit.
              const idVerbrauch = '0_userdata.0.Wohnungsverbrauch.Tagesverbrauch_kwh'; // ID zuweisen!
              const idTable = '0_userdata.0.Wohnungsverbrauch.TagesverbrauchTest'; // ID anpassen!
               schedule('59 23 * * *', function() {
                  var arr = [];
                  if(getState(idTable).val) arr = JSON.parse(getState(idTable).val);
                  const obj = {
                      Datum: formatDate(new Date(), 'W, DD.MM.YYYY'),
                      Verbrauch: getState(idVerbrauch).val.toFixed(3)
                  arr.push(obj);
                  if(arr.length > 23) arr.shift(); // max. 23 Zeilen
                  setState(idTable, JSON.stringify(arr), true);
              Threads: 16
              mit Proxmox
                @codierknecht
                    var arr = [];
                    const obj = {
                    arr.push(obj);
                Codierknecht
                @stefu87_ch
                Der schreibt Dir jeden Abend einen neuen Eintrag in ein JSON-Array.
                Über die Sinnhaftigkeit von sowas mag man streiten. Dafür gibt's diverse History-Adapter (SQL, Influx, History).
                Das JS umzuschreiben könnte auch schwierig werden, da der Aufbau ja komplett anders aussehen muss und die Werte der Vergangenheit dann erstmal weg sind (es sei denn, man treibt da noch Zusatzaufwand).
                Versuch's mal hiermit. Ist allerdings nur so dahingeschrieben und ungetestet.
                const idGrafana = '0_userdata.0.Wohnungsverbrauch.TagesverbrauchGrafana';
                    var arr = [];
                    if (getState(idTable).val) arr = JSON.parse(getState(idTable).val);
                    const obj = {
                    arr.push(obj);
                    let values = {};
                    for (const item of arr) {
                      values[item.Datum] = parseFloat(item.Verbrauch);
                    setState(idGrafana, JSON.stringify(values), true);
                  @stefu87_ch
                      var arr = [];
                      const obj = {
                      arr.push(obj);
                      let values = {};
                  stefu87_CHS Offline
                  stefu87_CHS Offline
                  stefu87_CH
                  @codierknecht sagte in JSON in Grafana einbinden:
                  Muss ich diesen noch selber anlegen, oder passiert das dann automatisch?
                  Threads: 16
                  mit Proxmox
                    Codierknecht
                    @stefu87_ch sagte in JSON in Grafana einbinden:
                    Den musst Du selbst anlegen. Typ "Text/String".
                      stefu87_CHS Offline
                      stefu87_CHS Offline
                      stefu87_CH
                      @codierknecht Ok werde es mal testen und schauen ob heute Nacht etwas passiert.
                      Wie würdest du den das umsetzen ohne die JSON Tabelle, sondern eben mit z.B. Influx das er immer um 23:59 den Wert speichert samt Datum?
                      Threads: 16
                      mit Proxmox
                        Codierknecht
                        Ich habe dafür einen eigenen DP für den Tagesverbrauch. Der wird per SQL historisiert.
                        In den DP wird per Script um 23:59:45 Uhr der Wert reingeschrieben. So habe ich die Werte mit passendem Datum in der DB. Damit lassen sich dann ohne viel Aufwand auch Monats- oder Jahresverbräuche bestimmen.
                          stefu87_CHS Offline
                          stefu87_CHS Offline
                          stefu87_CH
                          @codierknecht
                          Also für den Tagesverbauch habe ich auch einen Datenpunkt der alle 15min aktualisiert wird. Und um 23:59 schreibt eben der gezeigte Code dann dies in die JSON Tabelle.
                          Könnte ich den mit dem bestehen Datenpunkt sowas weiter verarbeiten so wie du das machst?
                          Threads: 16
                          mit Proxmox
                            @codierknecht
                            Codierknecht
                            Eben nicht, weil der ja alle 15 Minuten aktualisier wird.
                            Lege Dir einen neuen an (Typ: Zahl) und historisiere den. Da schreibst Du einfach um 23:59 Uhr den aktuellen Wert aus dem über Tag hochgezählten DP rein.
                              stefu87_CHS Offline
                              stefu87_CHS Offline
                              stefu87_CH
                              @codierknecht Also müsste ich diesen Code hier ganz am Schluss anpassen statt alle 15min das es 23:59 ist?
                               * @copyright 2021 Stephan Kreyenborg <stephan@kreyenborg.koeln>
                               * @author 2021 Stephan Kreyenborg <stephan@kreyenborg.koeln>
                               * Dieses Skript dient zur freien Verwendung in ioBroker zur Verbrauchserfassung der Shelly Geräte.
                               * Jegliche Verantwortung liegt beim Benutzer. Das Skript wurde unter Berücksichtigung der bestmöglichen Nutzung
                               * und Performance entwickelt.
                               * Der Entwickler versichert, das keine böswilligen Systemeingriffe im originalen Skript vorhanden sind.
                               * Sollte das Skript wider Erwarten nicht korrekt funktionieren, so hast Du jederzeit die Möglichkeit, Dich auf
                               * https://www.kreyenborg.koeln
                               * für Unterstützung zu melden. Jedes Skript besitzt seine eigene Kommentarseite, auf der,
                               * nach zeitlicher Möglichkeit des Autors, Hilfe angeboten wird. Ein Anrecht hierauf besteht nicht!
                               * Ansprüche gegenüber Dritten bestehen nicht.
                               * Skript Name:      Shelly-Verbrauch
                               * Skript Version:   1.60
                               * Erstell-Datum:    08. Oktober 2021 | Update: 20. Juli 2022
                              // Datenpunkte neu erstellen
                              var ueberschreiben = false;
                              // Hauptdatenpunkt unterhalb javascript
                              var datenpunkt = "ShellyVerbrauch."; // Abschließender Punkt !!! WICHTIG !!!
                              // Verbrauchs Objekte der einzelnen Shelly
                              var objekt = ["gesamt", "dieses_jahr", "letztes_jahr", "letzter_monat", "dieser_monat", "letzte_woche",
                                  "diese_woche", "gestern", "heute", "alter_wert", "aktueller_wert"
                              // Beschreibung der Objekte
                              var beschreibung = ["Gesamter Vebrauch des Shelly", "Verbrauch aktuelles Jahr", "Verbrauch letztes Jahr",
                                  "Verbrauch letzten Monat", "Verbrauch aktueller Monat", "Verbrauch letzte Woche", "Verbrauch diese Woche",
                                  "Verbrauch gestern", "Verbrauch heute", "Messwert alt", "Messwert neu"
                              // Datenpunkt der Shelly (Standard: shelly.0)
                              var shelly_dp = "shelly.1";
                              // Datenpunkte der Shelly (!!! Bitte nicht ändern !!!)
                              var shellyDps = $('state[id=' + shelly_dp + '.*.*.Energy]');
                              // Datenpunkte der Shelly 3EM DP
                              var shelly3EMDps = $('state[id=' + shelly_dp + '.*.*.TotalActiveEnergy]');
                              // Datenpunkte der Shelly 3EM DP - Total
                              var shelly3EMTotalDps = $('state[id=' + shelly_dp + '.*.*.ConsumedPower]');
                              var shelly3EMTotalReturned = $('state[id=' + shelly_dp + '.*.*.Total_Returned]');
                              // Datenpunkte der Shelly Namen (!!! Bitte nicht ändern !!!)
                              var shellyDpsName = $('state[id=' + shelly_dp + '.*.name]');
                              // Shelly Verbrauch aktualisieren - nachts um 00:00 Uhr
                              function shelly_vebrauch_tag() {
                                  // Nochmals das Tagesupdate durchlaufen, damit die restlichen Werte gelesen werden
                                  shelly_verbrauch_update();
                                  // Datumsvariable
                                  var heute = new Date();
                                  // Heute zu Gestern verschieben. Täglich um 00:00 Uhr
                                  verschiebe_verbrauch_objekt("heute", "gestern");
                                  log("Shelly Verbrauch: Werte für gestern und heute aktualisiert!");
                                  // aktuelle Woche in letzte Woche verschieben. Am Montag um 00:00 Uhr
                                  if (heute.getDay() === 1) {
                                      verschiebe_verbrauch_objekt("diese_woche", "letzte_woche");
                                      log("Shelly Verbrauch: Werte für diese und letzte Woche aktualisiert!");
                                  // aktueller Monat in letzten Monat verschieben. Am 1. des Monats um 00:00 Uhr
                                  if (heute.getDate() === 1) {
                                      verschiebe_verbrauch_objekt("dieser_monat", "letzter_monat");
                                      log("Shelly Verbrauch: Werte für diesen und letzten Monat aktualisiert!");
                                  // aktuelles Jahr in letztes Jahr verschieben. Am 1. des Monats am 1. Monat um 00:00 Uhr
                                  if (heute.getDate() === 1 && heute.getMonth() === 0) {
                                      verschiebe_verbrauch_objekt("dieses_jahr", "letztes_jahr");
                                      log("Shelly Verbrauch: Werte für dieses und letztes Jahr aktualisiert!");
                              // Tagesverbrauch alle 15 Min von der Original Variable des Shelly in eigene Variable kopieren
                              function shelly_verbrauch_update() {
                                  var anzahl_updates = 0;
                                  var anzahl_reboots = 0;
                                  var anzahl_gleich = 0;
                                  shellyDps.each(function (id, i) {
                                      var shelly_verbrauch = getState(id).val;
                                      // Einige Shelly haben keine Verbrauchswerte (noch nicht)
                                      if (shelly_verbrauch != null) {
                                          // Hole aktuellen Wert, um zu kontrollieren, ob ein Reboot stattgefunden hat
                                          var aktueller_wert = getState(shelly_DP(id) + "aktueller_wert").val;
                                          var alter_wert = 0;
                                          // Prüfe alten und neuen Wert
                                          if (shelly_verbrauch > aktueller_wert) {
                                              // Verbrauchswert ist größer als alter Wert -> es wurde kein Reboot durchgeführt
                                              setState(shelly_DP(id) + "alter_wert", aktueller_wert, true);
                                              alter_wert = aktueller_wert;
                                              anzahl_updates++;
                                          if (aktueller_wert > shelly_verbrauch) {
                                              // Verbrauchswert ist kleiner als alter Wert -> es wurde ein Reboot durchgeführt
                                              setState(shelly_DP(id) + "alter_wert", 0, true);
                                              alter_wert = 0;
                                              anzahl_reboots++;
                                          if (shelly_verbrauch == aktueller_wert) {
                                              // Verbrauchswert ist gleich wie alter Wert -> kein Update notwendig
                                              anzahl_gleich++;
                                          setState(shelly_DP(id) + "aktueller_wert", shelly_verbrauch, true);
                                          // Alter und neuer Wert -> aktuelle Differenz
                                          var verbrauch = parseFloat(shelly_verbrauch) - alter_wert;
                                          // Tagesverbrauch aktualisieren
                                          aktualisiere_vebrauch_objekt(shelly_DP(id), "heute", verbrauch);
                                          // Wochenverbrauch aktualisieren
                                          aktualisiere_vebrauch_objekt(shelly_DP(id), "diese_woche", verbrauch);
                                          // Monatsverbrauch aktualisieren
                                          aktualisiere_vebrauch_objekt(shelly_DP(id), "dieser_monat", verbrauch);
                                          // Jahresverbrauch aktualisieren
                                          aktualisiere_vebrauch_objekt(shelly_DP(id), "dieses_jahr", verbrauch);
                                          // Gesamten Vebrauch aktualisieren
                                          aktualisiere_vebrauch_objekt(shelly_DP(id), "gesamt", verbrauch);
                                  shelly3EMDps.each(function (id, i) {
                                          var alter_wert = 0;
                                              anzahl_updates++;
                                              alter_wert = 0;
                                              anzahl_reboots++;
                                              anzahl_gleich++;
                                  shelly3EMTotalDps.each(function (id, i) {
                                          var alter_wert = 0;
                                              anzahl_updates++;
                                              alter_wert = 0;
                                              anzahl_reboots++;
                                              anzahl_gleich++;
                                  shelly3EMTotalReturned.each(function (id, i) {
                                          var aktueller_wert = getState(shelly_DP(id, true) + "aktueller_wert").val;
                                          var alter_wert = 0;
                                              setState(shelly_DP(id, true) + "alter_wert", aktueller_wert, true);
                                              anzahl_updates++;
                                              setState(shelly_DP(id, true) + "alter_wert", 0, true);
                                              alter_wert = 0;
                                              anzahl_reboots++;
                                              anzahl_gleich++;
                                          setState(shelly_DP(id, true) + "aktueller_wert", shelly_verbrauch, true);
                                          aktualisiere_vebrauch_objekt(shelly_DP(id, true), "heute", verbrauch);
                                          aktualisiere_vebrauch_objekt(shelly_DP(id, true), "diese_woche", verbrauch);
                                          aktualisiere_vebrauch_objekt(shelly_DP(id, true), "dieser_monat", verbrauch);
                                          aktualisiere_vebrauch_objekt(shelly_DP(id, true), "dieses_jahr", verbrauch);
                                          aktualisiere_vebrauch_objekt(shelly_DP(id, true), "gesamt", verbrauch);
                                  aktualisiere_namen();
                                  log("Shelly Verbrauch: Verbrauchswerte aktualisiert: " + anzahl_updates + " | Reboots korrigiert: " + anzahl_reboots + " | Unveränderte Werte: " + anzahl_gleich);
                              // aktualisiert das jeweilige Verbrauchs-Objekt und addiert den Verbrauch dazu
                              function aktualisiere_vebrauch_objekt(dp, objekt, wert) {
                                  // Hole alten Verbrauch
                                  let alter_verbrauch = getState(dp + objekt).val;
                                  let verbrauch = 0;
                                  // Kein Wert vorhanden - nutze den übermittelten Wert
                                  if (alter_verbrauch < 1 || alter_verbrauch == null) {
                                      verbrauch = parseFloat(wert)
                                  } else {
                                      verbrauch = parseFloat(alter_verbrauch) + parseFloat(wert);
                                  setState(dp + objekt, parseFloat(verbrauch.toFixed(2)), true);
                              // Verschiebt das jeweilige Verbrauchs-Objekt und nullt den Ursprung (Tag, Woche, Monat, Jahr)
                              function verschiebe_verbrauch_objekt(von, nach) {
                                  $('state[id=*.' + datenpunkt + '*.*.' + von + ']').each(function (id, i) {
                                      // Temporärer Gruppen-Datenpunkt
                                      var tmp_dp = id.slice(0, -(von.length));
                                      var verbrauch = getState(id).val;
                                      if (verbrauch != null) {
                                          setState(tmp_dp + nach, verbrauch, true);
                                      // Setze "von" zurück
                                      setState(id, 0, true);
                              // Funktion um die aktuellen Namen des Shelly abzuholen
                              function aktualisiere_namen() {
                                  if (typeof extendObject === "function") {
                                      shellyDpsName.each(function (id, i) {
                                          if (existsState(id)) {
                                              setState(shelly_DP_Name(id), String(getState(id).val), true);
                                              extendObject("javascript.0." + shelly_DP_Name_Main(id), {
                                                  common: {
                                                      desc: String(getState(id).val)
                                                  type: "channel"
                              // Erstelle die benötigten Datenpunkte
                              function datenpunkte_erstellen() {
                                  // Anzahl der gefundenen Shelly
                                  var anzahl = shellyDps.length;
                                  shellyDps.each(function (id, j) {
                                      var initial_wert = 0.0;
                                      for (var i = 0; i < objekt.length; i++) {
                                          // Startwerte werden nur bei alter_wert und aktueller_wert eingetragen
                                          if (i > 8) {
                                              initial_wert = getState(id).val;
                                          createState(shelly_DP(id) + objekt[i], initial_wert, ueberschreiben, {
                                              desc: beschreibung[i],
                                              type: "number",
                                              role: "value.power",
                                              unit: "Wh"
                                  // Anzahl der gefundenen Shelly 3EM
                                  var anzahl_3em = shelly3EMDps.length;
                                  shelly3EMDps.each(function (id, j) {
                                          if (i > 8) {
                                              type: "number",
                                              unit: "Wh"
                                  // Anzahl der gefundenen Shelly 3EM - Total
                                  var anzahl_3em_total = shelly3EMTotalDps.length;
                                  shelly3EMTotalDps.each(function (id, j) {
                                          if (i > 8) {
                                              type: "number",
                                              unit: "Wh"
                                  var anzahl_3em_total_returned = shelly3EMTotalReturned.length;
                                  shelly3EMTotalReturned.each(function (id, j) {
                                          if (i > 8) {
                                          createState(shelly_DP(id, true) + objekt[i], initial_wert, ueberschreiben, {
                                              type: "number",
                                              unit: "Wh"
                                  // Alle Datenpunkte erstellt. Frage ersten Verbrauch ab!
                                  log("Shelly Verbrauch: Datenpunkte erstellt! Erster Verbrauch steht nach 30 Sekunden zur Verfügung! Anzahl gefundener Shelly Datenpunkte: " + (anzahl_3em + anzahl + anzahl_3em_total + anzahl_3em_total_returned));
                                  setTimeout(shelly_verbrauch_update, 30000);
                                  // Datenpunkte für die Namen der Shelly erstellen
                                  shellyDpsName.each(function (id, j) {
                                      createState(shelly_DP_Name(id), "", ueberschreiben, {
                                          name: "Name des Shelly",
                                          desc: "Name des Shelly",
                                          type: "string",
                                          role: "value",
                                          unit: ""
                               * Wenn 3EM DP, dann anderen Wert zurückgeben
                               * @param {any} dp
                               * @param {boolean} extended
                              function shelly_DP(dp, extended = false) {
                                  dp = dp.split(".");
                                  dp = datenpunkt + dp[2] + "." + dp[3];
                                  if (extended) {
                                      dp = dp + "_Returned.";
                                  } else {
                                      dp = dp + ".";
                                  return dp;
                              function shelly_DP_Name(dp) {
                                  dp = dp.split(".");
                                  return dp;
                              function shelly_DP_Name_Main(dp) {
                                  dp = dp.split(".");
                                  dp = datenpunkt + dp[2];
                                  return dp;
                              function shelly_verbrauch_erster_start() {
                                  log("Shelly Verbrauch: Erster Start des Skriptes! Datenpunkte werden erstellt!");
                                  // Datenpunkte werden erstellt
                                  datenpunkte_erstellen();
                              // Erster Start und Initialisierung
                              shelly_verbrauch_erster_start();
                              // Alle 15 Minuten das Skript für den Tagesverbrauch ausführen
                              schedule('*/15 * * * *', shelly_verbrauch_update);
                              // Nachts um 24 Uhr werden die Werte in andere Variablen gespeichert, um den Verlauf zu erstellen
                              schedule('0 0 * * *', shelly_vebrauch_tag);
                              Threads: 16
                              mit Proxmox
                                stefu87_CHS Offline
                                stefu87_CHS Offline
                                stefu87_CH
                                @codierknecht Versuche es mal auf eine einfache Weise, das ich den Wert per CRON in den DP schreibe.
                                Threads: 16
                                mit Proxmox
                                      // Datumsvariable
                                              var alter_wert = 0;
                                                  anzahl_updates++;
                                                  alter_wert = 0;
                                                  anzahl_reboots++;
                                                  anzahl_gleich++;
                                              var alter_wert = 0;
                                                  anzahl_updates++;
                                                  alter_wert = 0;
                                                  anzahl_reboots++;
                                                  anzahl_gleich++;
                                              var alter_wert = 0;
                                                  anzahl_updates++;
                                                  alter_wert = 0;
                                                  anzahl_reboots++;
                                                  anzahl_gleich++;
                                              var alter_wert = 0;
                                                  anzahl_updates++;
                                                  alter_wert = 0;
                                                  anzahl_reboots++;
                                                  anzahl_gleich++;
                                      let verbrauch = 0;
                                      } else {
                                                      common: {
                                                      type: "channel"
                                              if (i > 8) {
                                                  type: "number",
                                                  unit: "Wh"
                                              if (i > 8) {
                                                  type: "number",
                                                  unit: "Wh"
                                              if (i > 8) {
                                                  type: "number",
                                                  unit: "Wh"
                                              if (i > 8) {
                                                  type: "number",
                                                  unit: "Wh"
                                              type: "string",
                                              role: "value",
                                              unit: ""
                                   * @param {any} dp
                                      dp = dp.split(".");
                                      if (extended) {
                                      } else {
                                          dp = dp + ".";
                                      return dp;
                                      dp = dp.split(".");
                                      return dp;
                                      dp = dp.split(".");
                                      return dp;
                                  Codierknecht
                                  @stefu87_ch
                                  Hier stand Quatsch :-(
                                    @stefu87_ch
                                    stefu87_CHS Offline
                                    stefu87_CHS Offline
                                    stefu87_CH
                                    @codierknecht Versuche es mal so:
                                    Threads: 16
                                    mit Proxmox
                                      Codierknecht
                                      @stefu87_ch
                                      Ich würde für den Zeitplan ein CRON verwenden und nicht den Wizard.
                                      Ist besser lesbar und funktioniert nach meiner Erfahrung zuverlässiger.
                                        @stefu87_ch
                                        stefu87_CHS Offline
                                        stefu87_CHS Offline
                                        stefu87_CH
                                        @codierknecht das heisst, wenn die Werte dann in der History sind, für jeden Tag, können dann in Grafana als Graphische Balken dargestellt werden?
                                        Threads: 16
                                        mit Proxmox
                                          Codierknecht
                                          @stefu87_ch
                                          Ja!
                                          Frag mich aber bei Influx nicht, wie da die Abfrage aussehen müsste.
                                          Ich bleibe berufsbedingt beim guten alten SQL.
                                          stefu87_CHS 3 Antworten Letzte Antwort
