  4. Test Adapter BMW/Mini v4.x.x
    6.8k
1.1k Beiträge 103 Kommentatoren 377.6k Aufrufe 89 Beobachtet
  • bahnuhrB bahnuhr
    @wierer-sigi
    Langfassung bitte
    wierer-sigiW Offline
    wierer-sigi
    #612
    @bahnuhr
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: WBH-RasPi4
           Icon name: computer
              Kernel: Linux 6.6.51+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model        : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     14:53:54 up 42 min,  3 users,  load average: 1.87, 2.04, 1.82
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2024-11-22 14:53:54 CET
               Universal time: Fri 2024-11-22 13:53:54 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    Sigi71
    HOME=/home/Sigi71
    GROUPS=Sigi71 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker adm tty dialout audio video plugdev bluetooth gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:     tty
    *** MEMORY ***
                   total        used        free      shared  buff/cache   available
    Mem:            4.0G        2.5G        248M        3.1M        1.3G        1.5G
    Swap:           209M          0B        209M
    Total:          4.2G        2.5G        458M
    Active iob-Instances:     25
             3791 M total memory
             2353 M used memory
              363 M active memory
             2918 M inactive memory
              236 M free memory
               92 M buffer memory
             1187 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    *** top - Table Of Processes  ***
    top - 14:53:54 up 42 min,  3 users,  load average: 1.87, 2.04, 1.82
    Tasks: 219 total,   1 running, 218 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 42.9 us, 14.3 sy,  0.0 ni, 42.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3792.0 total,    234.9 free,   2355.1 used,   1280.7 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   1436.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem     Type      Size  Used Avail Use% Mounted on
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  2.9M  377M   1% /run
    /dev/mmcblk0p2 ext4       57G   18G   37G  32% /
    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   77M  434M  15% /boot/firmware
    tmpfs          tmpfs     380M   44K  380M   1% /run/user/1000
    [Fri Nov 22 14:11:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:6D:D4:B7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=efb2ccb3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=GE
    [Fri Nov 22 14:11:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
    [Fri Nov 22 14:11:24 2024] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.4G    /var/
    1.1G    /var/lib
    854M    /var/cache
    846M    /var/cache/apt
    648M    /var/cache/apt/archives
    Archived and active journals take up 265.4M in the file system.
    /opt/iobroker/backups:
    1.2G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.6G    /opt/iobroker/iobroker-data/
    2.7G    /opt/iobroker/iobroker-data/history
    825M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    24M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    21M    /opt/iobroker/iobroker-data/objects.jsonl
    12M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs     v20.18.1
    /usr/bin/node         v20.18.1
    /usr/bin/npm         10.8.2
    /usr/bin/npx         10.8.2
    /usr/bin/corepack     0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
         20.18.1+dfsg-1 100
            100 http://deb.debian.org/debian unstable/main arm64 Packages
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    ^[[B^[[B^[[B^[[Biobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    WBH-RasPi4          WBH-RasPi4 (version: 6.0.11, hostname: WBH-RasPi4    , alive, uptime: 2544)
    Core adapters versions
    js-controller:     6.0.11
    admin:         7.1.5
    javascript:     8.8.3
    nodejs modules from github:     2
    +-- iobroker.bmw@2.8.4 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#85c1894e04feb8ce2d404fb358a924e65aff8ab1)
    +-- iobroker.vw-connect@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#e023bb9ed5865c6cf19bb9c004bed9b7cf83825d)
    Adapter State
    + system.adapter.admin.0                  : admin                 : WBH-RasPi4                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : WBH-RasPi4                               -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : WBH-RasPi4                               -  enabled
    + system.adapter.discovery.0              : discovery             : WBH-RasPi4                               -  enabled
    + system.adapter.doorbird.0               : doorbird              : WBH-RasPi4                               -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : WBH-RasPi4                               -  enabled
      system.adapter.flot.0                   : flot                  : WBH-RasPi4                               - disabled
    + system.adapter.fritzdect.0              : fritzdect             : WBH-RasPi4                               -  enabled
      system.adapter.go-e.0                   : go-e                  : WBH-RasPi4                               - disabled
      system.adapter.go-e.2                   : go-e                  : WBH-RasPi4                               - disabled
      system.adapter.habpanel.0               : habpanel              : WBH-RasPi4                               - disabled
    + system.adapter.history.0                : history               : WBH-RasPi4                               -  enabled
    + system.adapter.hmip.0                   : hmip                  : WBH-RasPi4                               -  enabled
    + system.adapter.javascript.0             : javascript            : WBH-RasPi4                               -  enabled
    + system.adapter.modbus.0                 : modbus                : WBH-RasPi4                               -  enabled
    + system.adapter.modbus.1                 : modbus                : WBH-RasPi4                               -  enabled
      system.adapter.modbus.2                 : modbus                : WBH-RasPi4                               - disabled
      system.adapter.openweathermap.0         : openweathermap        : WBH-RasPi4                               -  enabled
      system.adapter.parser.0                 : parser                : WBH-RasPi4                               - disabled
      system.adapter.ping.0                   : ping                  : WBH-RasPi4                               - disabled
    + system.adapter.pvforecast.0             : pvforecast            : WBH-RasPi4                               -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : WBH-RasPi4                               -  enabled
    + system.adapter.shelly.0                 : shelly                : WBH-RasPi4                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.2                 : shelly                : WBH-RasPi4                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.snmp.0                   : snmp                  : WBH-RasPi4                               -  enabled
    + system.adapter.telegram.0               : telegram              : WBH-RasPi4                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tronity.0                : tronity               : WBH-RasPi4                               -  enabled
    + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : WBH-RasPi4                               -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : WBH-RasPi4                               - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : WBH-RasPi4                               - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : WBH-RasPi4                               - disabled
      system.adapter.vis.0                    : vis                   : WBH-RasPi4                               -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : WBH-RasPi4                               -  enabled
    + system.adapter.web.0                    : web                   : WBH-RasPi4                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : WBH-RasPi4                               -  enabled
    + system.adapter.yahka.0                  : yahka                 : WBH-RasPi4                               -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                                     │ auto upgrade │
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "discovery"    : 5.0.0    , installed 5.0.0
    Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
    Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
    Adapter    "flot"         : 1.12.0   , installed 1.12.0
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "go-e"         : 1.0.41   , installed 1.0.41
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 3.0.1    , installed 3.0.1
    Adapter    "hmip"         : 1.24.3   , installed 1.24.3
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "ping"         : 1.6.2    , installed 1.6.2
    Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
    Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "tronity"      : 1.1.1    , installed 1.1.1
    Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
    Adapter    "vis"          : 1.5.6    , installed 1.5.6
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.5.1
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.9
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects:     10218
    States:     9096
    ^[[B^[[B^[[B^[[BHit:1 http://deb.debian.org/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 http://deb.debian.org/debian unstable InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:7 https://repo.homebridge.io stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6639       1009/smbd
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6640       1009/smbd
    tcp        0      0 192.168.178.155:8100    0.0.0.0:*               LISTEN      1001       9907       2743/io.doorbird.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6508       751/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2859       711/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8420       711/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8278       710/cupsd
    tcp        0      0 127.0.0.1:39629         0.0.0.0:*               LISTEN      1001       12649      3473/io.yahka.0
    tcp        0      0 127.0.0.1:36341         0.0.0.0:*               LISTEN      112        10037      1706/homebridge
    tcp        0      0 127.0.0.1:39939         0.0.0.0:*               LISTEN      112        9092       2666/homebridge: ho
    tcp        0      0 127.0.0.1:42909         0.0.0.0:*               LISTEN      1001       14607      3473/io.yahka.0
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          2812       741/vncserver-x11-c
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       10250      2441/io.shelly.2
    tcp6       0      0 :::445                  :::*                    LISTEN      0          6637       1009/smbd
    tcp6       0      0 :::8581                 :::*                    LISTEN      112        6877       1251/hb-service
    tcp6       0      0 :::139                  :::*                    LISTEN      0          6638       1009/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6510       751/sshd: /usr/sbin
    tcp6       0      0 :::51828                :::*                    LISTEN      112        11331      1706/homebridge
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8277       710/cupsd
    tcp6       0      0 :::32100                :::*                    LISTEN      112        10358      2666/homebridge: ho
    tcp6       0      0 :::36163                :::*                    LISTEN      1001       12046      3473/io.yahka.0
    tcp6       0      0 :::51132                :::*                    LISTEN      112        9976       1706/homebridge
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7914       1065/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10705      3389/io.web.0
    tcp6       0      0 :::8089                 :::*                    LISTEN      1001       7968       1230/io.admin.1
    tcp6       0      0 :::8181                 :::*                    LISTEN      112        9798       1706/homebridge
    tcp6       0      0 :::36615                :::*                    LISTEN      112        8945       2668/homebridge: ho
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          2811       741/vncserver-x11-c
    tcp6       0      0 :::38529                :::*                    LISTEN      1001       12044      3473/io.yahka.0
    udp        0      0 0.0.0.0:45682           0.0.0.0:*                           1001       106862     2303/io.shelly.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        9977       1706/homebridge
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        10359      2666/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        8946       2668/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        11382      1706/homebridge
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        9419       1251/hb-service
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4090       533/avahi-daemon: r
    udp        0      0 0.0.0.0:34140           0.0.0.0:*                           104        4092       533/avahi-daemon: r
    udp        0      0 0.0.0.0:38327           0.0.0.0:*                           1001       9864       2534/io.snmp.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           112        11377      1706/homebridge
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11265      2303/io.shelly.0
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          7669       999/nmbd
    udp        0      0 192.168.178.155:137     0.0.0.0:*                           0          7668       999/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          7656       999/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          7671       999/nmbd
    udp        0      0 192.168.178.155:138     0.0.0.0:*                           0          7670       999/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          7657       999/nmbd
    udp6       0      0 fe80::9ad7:fe58:e65:546 :::*                                0          7916       651/NetworkManager
    udp6       0      0 :::33788                :::*                                104        4093       533/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4091       533/avahi-daemon: r
    2024-11-22 14:55:01.328  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.longpushDurationMsMax:{"val":3000,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726773}
    2024-11-22 14:55:01.333  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.multipushTimeBetweenPushesMsMax:{"val":500,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726776}
    2024-11-22 14:55:01.342  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay0.ButtonType:{"val":"toggle","ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726781}
    2024-11-22 14:55:01.344  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay0.ButtonReverse:{"val":0,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
    2024-11-22 14:55:01.349  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay1.ButtonType:{"val":"momentary","ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
    2024-11-22 14:55:01.356  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay1.ButtonReverse:{"val":0,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
    2024-11-22 14:55:01.359  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay2.ButtonType:{"val":"momentary","ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
    2024-11-22 14:55:01.364  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay2.ButtonReverse:{"val":0,"ack":true,"ts":1732283701312,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
    2024-11-22 14:55:01.389  - silly: javascript.0 (1452) States user redis pmessage */modbus.0.holdingRegisters.40079_PV_U3U1:{"val":391.2,"ack":true,"ts":1732283701375,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1732283701375}
    2024-11-22 14:55:01.394  - silly: javascript.0 (1452) States user redis pmessage */modbus.0.holdingRegisters.40080_PV_U1:{"val":226,"ack":true,"ts":1732283701375,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1732283701375}
    2024-11-22 14:55:01.399  - silly: javascript.0 (1452) States user redis pmessage */modbus.0.holdingRegisters.40082_PV_U3:{"val":225.7,"ack":true,"ts":1732283701376,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1732283701376}
    2024-11-22 14:55:01.425  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay0.ChannelName:{"val":"Shelly i3 Bad","ack":true,"ts":1732283701423,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1675353639727}
    2024-11-22 14:55:01.429  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay1.ChannelName:{"val":null,"ack":true,"ts":1732283701424,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1675353639767}
    2024-11-22 14:55:01.517  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay2.ChannelName:{"val":null,"ack":true,"ts":1732283701515,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1675353639815}
    2024-11-22 14:55:01.520  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.alive:{"val":true,"ack":true,"ts":1732283701518,"q":0,"from":"system.adapter.rpi2.0","lc":1732281151426,"expire":true}
    2024-11-22 14:55:01.523  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.connected:{"val":true,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732281151426,"expire":true}
    2024-11-22 14:55:01.527  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.memRss:{"val":71.18,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283686531,"expire":true}
    2024-11-22 14:55:01.529  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.memHeapTotal:{"val":21.46,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283506514,"expire":true}
    2024-11-22 14:55:01.531  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.memHeapUsed:{"val":20.12,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
    2024-11-22 14:55:01.533  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.eventLoopLag:{"val":2,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283581513,"expire":true}
    2024-11-22 14:55:01.535  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.uptime:{"val":2555,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
    2024-11-22 14:55:01.537  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.inputCount:{"val":0,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
    2024-11-22 14:55:01.539  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.outputCount:{"val":11,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
    2024-11-22 14:55:01.540  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.cpu:{"val":0.07,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
    2024-11-22 14:55:01.543  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.cputime:{"val":12.92,"ack":true,"ts":1732283701520,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701520,"expire":true}
    • T tombox
      @wierer-sigi Wie in Beitrag #1 auf latest repo umstellen oder via GitHub installieren
      oder benutzerdefiniert
      https://github.com/TA2k/ioBroker.bmw
      wierer-sigi
      schrieb am zuletzt editiert von wierer-sigi
      #613
      @tombox
      Danke, konnte nach dem ändern in den Basiseinstellungen - Repositories - 2 Beta. Den BMW Adapter unter NPM sehen und installieren.
      Konnte dann auch die Version 2.8.3 auswählen.
      Wieder PW und Captcha eingegeben
      Kommt leider aber im noch die selbe Fehlermeldung im Protokoll
      Adrian BeutlerA 1 Antwort Letzte Antwort
      • wierer-sigiW wierer-sigi
        @tombox
        Adrian BeutlerA Offline
        Adrian Beutler
        #614
        scheint bei BMW zu hapern. Erhalte auf dem Portal einen Systemfehler beim Login
        wierer-sigiW 1 Antwort Letzte Antwort
        • Adrian BeutlerA Adrian Beutler
          wierer-sigi
          #615
          @adrian-beutler
          Komme nach 3 Stunden zurück, uns siehe da der Adapter ist grün. Vermute auch stark das es da bei BWM / Mini Probleme gab.
          Danke Euch trotzdem
            @adrian-beutler
            Danke Euch trotzdem
            mike1429
            #616
            Bitte um kurze Anleitung wie 2.8.3 installiert wird. Hab im Moment 2.8.4 (geht nicht) und kenn mich mit Github und NPM nicht gut aus. Danke!! Oder lieber noch warten?
            vowillV wierer-sigiW 2 Antworten Letzte Antwort
            • M mike1429
              vowillV Offline
              vowillV Offline
              vowill
              #617
              @mike1429 siehe z. B. hier: Adapter-Installation
              ioBroker im lxc auf NUC / Aktive Instanzen: 38
              • M mike1429
                wierer-sigi
                #618
                @mike1429
                Überprüfen ob Beta aktiviert : Systemeinstellungen ( Gabelschlüssel ) - REPOSITORY hacken bei 2 Beta
                Experten-Modus ( Gesicht zwei neben Gabelschlüssel ) aktivieren
                GitHubkatze - NPM - BMW TA2k Adapter auswählen
                Unter Adapter erscheint jetzt der BMW Adapter und kann installiert werden, mit dem + Symobl in dem schwarzen Quatrad kann die Version ausgewählt werden.
                Bei mir hat es aber nach Eingabe der Daten und auswählen des Captcha gute 3 Stunden gedauert bis der Adapter wieder live ging, ist aber wahrscheinlich eher an der Serverlandschaft von BMW gelegen
                • Steffe.S.S Online
                  Steffe.S.S Online
                  Steffe.S.
                  schrieb am zuletzt editiert von Steffe.S.
                  #619
                  Hallo gibt es nur bei mir Probleme mit dem Login? Bei mir hat sich nach einener Neuinstallation die Version 2.9.0 installiert und ich kann auch nicht zurück auf 2.8.3.
                  2024-12-01 09:41:29.019 - error: bmw.0 (1305) getvehicles v2 failed
                  2024-12-01 09:41:29.020 - error: bmw.0 (1305) AxiosError: Request failed with status code 401
                  2024-12-01 09:41:29.021 - error: bmw.0 (1305) ""
                  Gruß S.
                  • Steffe.S.S Steffe.S.
                    Gruß S.
                    tombox
                    #620
                    @steffe-s auch nach dem löschen von bmw.0.auth.session
                    M Steffe.S.S 2 Antworten Letzte Antwort
                    • T tombox
                      McLane
                      schrieb am zuletzt editiert von McLane
                      #621
                      Mein Adapter hat heute seit 15 Uhr Auszeit (v2.9.0). Scheint aber ein Server Problem zu sein.
                      Adapter ist aber Grün!
                      Meine BMW App funktioniert seit Wochen nicht richtig, zeigt veraltete Daten.
                      Ist ein F31, bisher funktionierte alles relativ gut. Hat jemand von euch auch diese Probleme?
                      Edit: Nach Neustart vom Host bezw. Docker ging es wieder.
                      • T tombox
                        Steffe.S.S Online
                        Steffe.S.S Online
                        Steffe.S.
                        #622
                        @tombox sagte in Test Adapter BMW/Mini v2.0.0:
                        Ja, der Adapter läuft jetzt wieder. Sorry für die späte Rückmeldung.
                        P 1 Antwort Letzte Antwort
                          Pino72
                          #623
                          Hi, hab auch den aktuellsten BMW Adapter am laufen, 2.9.0:
                          bmw.0
                          	2025-01-17 10:47:56.340	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                          bmw.0
                          	2025-01-17 10:47:56.339	error	update failed
                          bmw.0
                          	2025-01-17 10:12:56.299	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                          bmw.0
                          	2025-01-17 10:12:56.299	error	update failed
                          bmw.0
                          	2025-01-17 10:05:56.295	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                          bmw.0
                          	2025-01-17 10:05:56.294	error	update failed
                          bmw.0
                          	2025-01-17 09:58:56.390	warn	Out of call volume quota. Quota will be replenished in 00:01:02.
                          bmw.0
                          	2025-01-17 09:44:56.280	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                          bmw.0
                          	2025-01-17 09:44:56.280	error	update failed
                          bmw.0
                          	2025-01-17 08:58:54.396	warn	Out of call volume quota. Quota will be replenished in 00:01:04.
                          bmw.0
                          	2025-01-17 08:48:54.222	info	First update of Trips and Demands in 10 minutes
                          bmw.0
                          	2025-01-17 08:48:33.560	info	Initial first update of the vehicles
                          bmw.0
                          	2025-01-17 08:48:23.548	info	Found 1 bmw vehicles
                          bmw.0
                          	2025-01-17 08:48:23.200	info	Start getting bmw vehicles
                          bmw.0
                          	2025-01-17 08:48:23.051	info	Session found. If the login fails please delete bmw.0.auth.session and restart the adapter
                          bmw.0
                          	2025-01-17 08:48:23.037	info	starting. Version 2.9.0 (non-npm: TA2k/ioBroker.bmw#3145a510e56ff3291b51fdfe70708c81772cb3cd) in C:/ioBroker/node_modules/iobroker.bmw, node: v20.18.1, js-controller: 7.0.6
                          Hab das update intervall schon auf 8 Minuten gestellt....normales Verhalten?
                          P lobomauL 2 Antworten Letzte Antwort
                          • P Pino72
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            bmw.0
                            Pino72
                            #624
                            Sehe ich das übrigens richtig, dass der Adapter zu 100% nur lesende Werte erlaubt und nichts geschrieben werden kann?
                            vowillV 1 Antwort Letzte Antwort
                            • P Pino72
                              vowillV Offline
                              vowillV Offline
                              vowill
                              #625
                              @pino72 Nein, die Datenpunkte in 'remotev2' können beschrieben werden. Aber nicht zu oft, sonst blockiert dich der BMW-Server.
                              • vowillV vowill
                                Pino72
                                #626
                                @vowill Danke, hatte es eben auch über das Protokoll gelesen, dass man dort Befehle absetzen kann. Lock/Unlock zb.
                                • P Pino72
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  #627
                                  @pino72 ja, vermutlich zu kurz. Ich bin bei 15min gelandet. Das läuft meistens ok.
                                  Host: NUC8i3 mit Proxmox:
                                  • Slave: Pi4
                                  • bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #628
                                    BMW V.2.8.3
                                    Instanz wird grün.
                                    Beim Neustart der Instanz kommt:
                                    bmw.0
                                    2025-01-23 09:57:25.676	info	Found 1 bmw vehicles
                                    bmw.0
                                    2025-01-23 09:57:25.389	info	Start getting bmw vehicles
                                    bmw.0
                                    2025-01-23 09:57:25.098	info	Session found. If the login fails please delete bmw.0.auth.session and restart the adapter
                                    bmw.0
                                    2025-01-23 09:57:25.060	info	starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.bmw, node: v20.18.1, js-controller: 7.0.6
                                    Beim remote "Lichthupe einschalten" kommt dann aber:
                                    bmw.0
                                    2025-01-23 09:58:01.813	error	"Forbidden"
                                    bmw.0
                                    2025-01-23 09:58:01.812	error	AxiosError: Request failed with status code 403
                                    bmw.0
                                    2025-01-23 09:58:01.812	error	Remote command failed
                                    Habt ihr eine Idee was da los ist ?
                                    Danke.
                                    • bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #629
                                      Habe nun mal update auf 2.9.0 gemacht.
                                      Im log kommt nun:
                                      bmw.0
                                      2025-01-23 10:10:48.669	warn	Out of call volume quota. Quota will be replenished in 00:49:12.
                                      bmw.0
                                      2025-01-23 10:10:48.587	info	Refresh values
                                      bmw.0
                                      2025-01-23 10:10:36.585	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:49:24."}
                                      bmw.0
                                      2025-01-23 10:10:36.585	error	AxiosError: Request failed with status code 403
                                      bmw.0
                                      2025-01-23 10:10:36.585	error	Remote command failed
                                      bmw.0
                                      2025-01-23 10:10:36.580	error	3 Retries failed
                                      bmw.0
                                      2025-01-23 10:10:31.466	warn	Rate Limit exceeded, retry in 5 seconds
                                      bmw.0
                                      2025-01-23 10:10:31.466	info	"Forbidden"
                                      bmw.0
                                      2025-01-23 10:10:31.466	info	Retry 5
                                      bmw.0
                                      2025-01-23 10:10:26.351	warn	Rate Limit exceeded, retry in 5 seconds
                                      bmw.0
                                      2025-01-23 10:10:26.351	info	"Forbidden"
                                      bmw.0
                                      2025-01-23 10:10:26.350	info	Retry 4
                                      bmw.0
                                      2025-01-23 10:10:21.272	warn	Rate Limit exceeded, retry in 5 seconds
                                      bmw.0
                                      2025-01-23 10:10:21.272	info	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:49:39."}
                                      bmw.0
                                      2025-01-23 10:10:21.272	info	Retry 3
                                      bmw.0
                                      2025-01-23 10:10:16.188	warn	Rate Limit exceeded, retry in 5 seconds
                                      bmw.0
                                      2025-01-23 10:10:16.188	info	"Forbidden"
                                      bmw.0
                                      2025-01-23 10:10:16.188	info	Retry 2
                                      bmw.0
                                      2025-01-23 10:10:11.142	warn	Rate Limit exceeded, retry in 5 seconds
                                      bmw.0
                                      2025-01-23 10:10:11.142	info	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:49:49."}
                                      bmw.0
                                      2025-01-23 10:10:11.141	info	Retry 1
                                      Fazit:
                                      remote funktioniert bei mir nicht mehr.
                                      Danke.
                                      vowillV T 2 Antworten Letzte Antwort
                                      • bahnuhrB bahnuhr
                                        Im log kommt nun:
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        Fazit:
                                        vowillV Offline
                                        vowillV Offline
                                        vowill
                                        #630
                                        @bahnuhr Hm, gleiches bei mir. Laut BMW-Doku zur API wird der Fehler 403 in der Regel bei 'No permission for the clearance ID specified' ausgegeben.
                                        Vielleicht kan @tombox dazu etwas sagen?
                                        • bahnuhrB bahnuhr
                                          Im log kommt nun:
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          bmw.0
                                          Fazit:
                                          tombox
                                          #631
                                          @bahnuhr Ich schaue mir das mal an
                                          lemonbiterL 1 Antwort Letzte Antwort
