  5. [ gelöst ] JSON aufteilen in DP
    6.5k
48 Beiträge 5 Kommentatoren 6.0k Aufrufe 2 Beobachtet
    @iobrokermike sagte in JSON aufteilen in DP:
    @homoran sagte in JSON aufteilen in DP:
    war das große log nach mqtt gefiltert?
    Ja, das war nach matt gefiltert
    dann kann man da natürlich auch keine Meldungen von javascript sehen!
    I Offline
    I Offline
    ioBrokerMike
    So jetzt die Filterung von Javascript:
       2024-11-29 20:59:14.006	warn	(COMPACT) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
    javascript.0
    2024-11-29 20:59:14.006	warn	(COMPACT) at Object.<anonymous> (script.js.00_Anwesend.AnzahlAnwesend:17:3)
    javascript.0
    2024-11-29 20:59:14.005	warn	(COMPACT) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
    javascript.0
    2024-11-29 20:59:14.003	warn	(COMPACT) You are assigning a number to the state "0_userdata.0.Anwesend.Anzahl" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    javascript.0
    2024-11-29 20:59:12.010	info	(COMPACT) State value to set for "0_userdata.0.Anwesend.Anzahl" has to be type "string" but received type "number"
    javascript.0
    2024-11-29 20:59:12.005	warn	(COMPACT) at processTimers (node:internal/timers:519:7)
    javascript.0
    2024-11-29 20:59:12.005	warn	(COMPACT) at listOnTimeout (node:internal/timers:581:17)
    javascript.0
    2024-11-29 20:59:12.004	warn	(COMPACT) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
    javascript.0
    2024-11-29 20:59:12.004	warn	(COMPACT) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
    javascript.0
    2024-11-29 20:59:12.004	warn	(COMPACT) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
    javascript.0
    2024-11-29 20:59:12.004	warn	(COMPACT) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
    javascript.0
    2024-11-29 20:59:12.003	warn	(COMPACT) at Object.<anonymous> (script.js.00_Anwesend.AnzahlAnwesend:17:3)
    javascript.0
    2024-11-29 20:59:12.003	warn	(COMPACT) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
    javascript.0
    2024-11-29 20:59:12.002	warn	(COMPACT) You are assigning a number to the state "0_userdata.0.Anwesend.Anzahl" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    javascript.0
    2024-11-29 20:59:10.011	info	(COMPACT) State value to set for "0_userdata.0.Anwesend.Anzahl" has to be type "string" but received type "number"
    javascript.0
    2024-11-29 20:59:10.005	warn	(COMPACT) at processTimers (node:internal/timers:519:7)
    starte mal die Instsnz neu und mach rinen Browserrefresh (Strg-f5)
    Javascript und mqtt neugestartet sowie F5
    Mfg
    IOBrokerMike
    Achtung ! Sehkraft 25% | 60% , kein scherz
    Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
    mickymM HomoranH 2 Antworten Letzte Antwort
    • mickymM mickym
      @paul53 sagte in JSON aufteilen in DP:
      @mickym sagte: früher ging das glaub nicht.
      Das ging mit getAttr() schon immer. Siehe Doku. Die Funktion wurde speziell für Blockly geschaffen.
      Irgendwie ist das aber anscheinend doch kein Objekt - zumindest, wenn ich es in JSONATA weiter verwenden will. Gibt es da eine Erklärung?
      Im 1. Fall ohne Konvertierung - kann ich über JSONATA nicht auf die Objekteigenschaft zugreifen. Im 2. Fall gehts.
       <variables>
         <variable id="NWR;`_N@3a:sTiBKQkne">Objekt</variable>
       </variables>
       <block type="variables_set" id="M@F*zUMa;{#yJo2.2goG" x="-1137" y="-337">
         <field name="VAR" id="NWR;`_N@3a:sTiBKQkne">Objekt</field>
         <value name="VALUE">
           <block type="text" id="fWZa-MC8^[YM-V-;#R}:">
             <field name="TEXT">{"meterId":"1KFM00000754396","deviceId":"EBSD14250567526","msgType":"EMETER_OBIS_V2","measurements":[{"timestamp":"2022-12-03T13:25:53Z","values":{"1-0:96.90.21":"7E2005D2","1-0:0.2.00":"312E3033","1-0:14.7.0255":50,"1-0:81.7.26255":359,"1-0:81.7.15255":330,"1-0:81.7.4255":337,"1-0:81.7.2255":238,"1-0:81.7.1255":118,"1-0:71.7.0255":10.119999885559082,"1-0:51.7.0255":1.7100000381469727,"1-0:31.7.0255":0.89999997615814209,"1-0:72.7.0255":235.89999389648438,"1-0:52.7.0255":234.69999694824219,"1-0:32.7.0255":237,"1-0:16.7.0255":2818,"1-0:2.8.0255":0,"1-0:1.8.0255":9071.03125,"1-0:96.1.0255":"0A014B464D0000006E24","1-0:96.50.1*1":"4B464D"}}]}</field>
           </block>
         </value>
         <next>
           <block type="debug" id="^5#in-UU}%!K~KPOKHz_">
             <field name="Severity">info</field>
             <value name="TEXT">
               <shadow type="text" id="-,TGC$b5|aHgxT-/9J]`">
               </shadow>
               <block type="variables_get" id="nRXii?=4yGGy,y7%2jY(">
               </block>
             </value>
             <next>
               <block type="debug" id="C*BY:f~|[e)Xvn8W1*s{">
                 <value name="TEXT">
                   <shadow type="text" id="michMudNxqrBOIIp?ntJ">
                   </shadow>
                   <block type="convert_jsonata" id="AS%.5T)U4NQRb~6pE|^y">
                     <value name="EXPRESSION">
                       <shadow type="text" id="]-J?Hivq,p/e0?KwDjKv">
                         <field name="TEXT">$.measurements[0].values.'1-0:96.50.1*1'</field>
                       </shadow>
                     </value>
                     <value name="TARGET">
                       <block type="variables_get" id="$:M+P`jmlylnj6q[{yF,">
                       </block>
                     </value>
                   </block>
                 </value>
                 <next>
                   <block type="variables_set" id="QRu@$s3*df8mR7r@=iO#">
                       <block type="convert_json2object" id="R.c9ffe%vYu70tFC4Wg0">
                           <block type="variables_get" id="Z^;~j8`)]MoA[fRfSluS">
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                       <block type="debug" id="yQlY]j3k2iPYr$s%:Z=c">
                         <value name="TEXT">
                           </shadow>
                           <block type="convert_jsonata" id="*P_(9@j7YL};L(Uz5~ZN">
                               <shadow type="text" id="7abV56Ncd4Eb9CA7Gy|N">
                               </shadow>
                             </value>
                               <block type="variables_get" id="^3+giB~)?btQR6/;R1~a">
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </next>
       </block>
      </xml>
      Oder heißt das, dass zum Extrahieren wird es temporär in ein Objekt gewandelt, wenn ich es aber weiterverwenden will, dann muss ich es konveritieren.
      Ja ich hab es mir selbst beantwortet. Vergiss diesen Post.
      HomoranH Offline
      HomoranH Offline
      @mickym Ist sehr interessant (vielleicht werd ich deswegen mit jsonata nicht warm), aber könnten wir das bitte aus diesem Thread erst mal herauslassen.
      ich fürchte wir verlieren @ioBrokerMike sonst.
      • I ioBrokerMike
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        mickymM Offline
        mickymM Offline
        mickym
        @iobrokermike Ja entweder konvertierst Du die Anzahl in eine Zahl oder den Datenpunkt in String/Zeichenkette.
        I 1 Antwort Letzte Antwort
          mickymM Offline
          mickymM Offline
          mickym
          @homoran Ja ist OK - ich habs selbst gecheckt - Du kannst den Post auch löschen.
          • mickymM mickym
            I Offline
            I Offline
            ioBrokerMike
            @mickym sagte in JSON aufteilen in DP:
            Schon gemacht
            Mfg
            IOBrokerMike
            • I ioBrokerMike
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              HomoranH Offline
              HomoranH Offline
              und in dem Zeitbereich (4 Sekunden!) hast du das Testskript refreshed?
              läuft der Adapter bei dir im compact mode?
              warum?
                warum?
                I Offline
                I Offline
                ioBrokerMike
                schrieb am zuletzt editiert von ioBrokerMike
                Nein das hatte ich nicht getan.
                warum?
                Das kann ich nicht sagen.
                Habe den harken im Host raus gemacht.
                Was mir eben auffiel ist :
                Wenn ich den Javascript Adapter auf debug stelle läuft das Testscript warum auch immer.
                Mfg
                IOBrokerMike
                • I ioBrokerMike
                  warum?
                  HomoranH Offline
                  HomoranH Offline
                  dann jetzt zum echten Skript!
                    I Offline
                    I Offline
                    ioBrokerMike
                    Vielen Dank an euch und eure Geduld . 👍
                    Mfg
                    IOBrokerMike
                    • I ioBrokerMike
                      HomoranH Offline
                      HomoranH Offline
                      @iobrokermike sagte in [ gelöst ] JSON aufteilen in DP:
                      heisst das, dass es jetzt läuft?
                        I Offline
                        I Offline
                        ioBrokerMike
                        Richtig !!!
                        Es läuft.
                        Mfg
                        IOBrokerMike
                        • I ioBrokerMike
                          Richtig !!!
                          Es läuft.
                          HomoranH Offline
                          HomoranH Offline
                          Richtig !!!
                          Es läuft.
                          Super!
                          so muss es sein!
                          dann kann @mickym jetzt mit @paul53 weiter über die Wandlung des json zum Objekt philosophieren
                            Richtig !!!
                            Es läuft.
                            Super!
                            so muss es sein!
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @homoran Nicht mehr nötig - ich konnte es mir ja selbst erklären.
                            • mickymM mickym
                              HomoranH Offline
                              HomoranH Offline
                              @mickym sagte in [ gelöst ] JSON aufteilen in DP:
                              ok, du hast wieder heimlich editiert ;-)
                              ist aber nur eine Arbeitshypothese, oder?
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @homoran Nein ich habe nichts editiert. Ich habe nur folgendes verstanden:
                                1. Wenn Du über einen JSON String ein Attribut extrahierst, wird temporär in ein Objekt gewandelt, um das Attribut zu extrahieren. Es bleibt aber ein JSON, also Text und wird nicht in ein Objekt gewandelt.
                                2. Um also den JSON als Objekt weiter zu verarbeiten musst du den JSON permanent in ein Objekt wandeln.
                                Das ganze hat also nichts mit JSONATA zu tun.
