  5. [ gelöst ] JSON aufteilen in DP
    6.5k
48 Beiträge 5 Kommentatoren 6.0k Aufrufe 2 Beobachtet
  • I ioBrokerMike
    So jetzt die Filterung von Javascript:
       2024-11-29 20:59:14.006	warn	(COMPACT) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
    javascript.0
    2024-11-29 20:59:14.006	warn	(COMPACT) at Object.<anonymous> (script.js.00_Anwesend.AnzahlAnwesend:17:3)
    javascript.0
    2024-11-29 20:59:14.005	warn	(COMPACT) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
    javascript.0
    2024-11-29 20:59:14.003	warn	(COMPACT) You are assigning a number to the state "0_userdata.0.Anwesend.Anzahl" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    javascript.0
    2024-11-29 20:59:12.010	info	(COMPACT) State value to set for "0_userdata.0.Anwesend.Anzahl" has to be type "string" but received type "number"
    javascript.0
    2024-11-29 20:59:12.005	warn	(COMPACT) at processTimers (node:internal/timers:519:7)
    javascript.0
    2024-11-29 20:59:12.005	warn	(COMPACT) at listOnTimeout (node:internal/timers:581:17)
    javascript.0
    2024-11-29 20:59:12.004	warn	(COMPACT) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
    javascript.0
    2024-11-29 20:59:12.004	warn	(COMPACT) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
    javascript.0
    2024-11-29 20:59:12.004	warn	(COMPACT) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
    javascript.0
    2024-11-29 20:59:12.004	warn	(COMPACT) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
    javascript.0
    2024-11-29 20:59:12.003	warn	(COMPACT) at Object.<anonymous> (script.js.00_Anwesend.AnzahlAnwesend:17:3)
    javascript.0
    2024-11-29 20:59:12.003	warn	(COMPACT) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
    javascript.0
    2024-11-29 20:59:12.002	warn	(COMPACT) You are assigning a number to the state "0_userdata.0.Anwesend.Anzahl" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    javascript.0
    2024-11-29 20:59:10.011	info	(COMPACT) State value to set for "0_userdata.0.Anwesend.Anzahl" has to be type "string" but received type "number"
    javascript.0
    2024-11-29 20:59:10.005	warn	(COMPACT) at processTimers (node:internal/timers:519:7)
    starte mal die Instsnz neu und mach rinen Browserrefresh (Strg-f5)
    Javascript und mqtt neugestartet sowie F5
    @iobrokermike sagte in JSON aufteilen in DP:
    und in dem Zeitbereich (4 Sekunden!) hast du das Testskript refreshed?
    läuft der Adapter bei dir im compact mode?
    warum?
    I 1 Antwort Letzte Antwort
      warum?
      I Online
      I Online
      ioBrokerMike
      schrieb am zuletzt editiert von ioBrokerMike
      @homoran sagte in JSON aufteilen in DP:
      Nein das hatte ich nicht getan.
      warum?
      Das kann ich nicht sagen.
      Habe den harken im Host raus gemacht.
      Was mir eben auffiel ist :
      Wenn ich den Javascript Adapter auf debug stelle läuft das Testscript warum auch immer.
      Mfg
      IOBrokerMike
      Achtung ! Sehkraft 25% | 60% , kein scherz
      Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
      • I ioBrokerMike
        warum?
        dann jetzt zum echten Skript!
          I Online
          I Online
          ioBrokerMike
          Vielen Dank an euch und eure Geduld . 👍
          Mfg
          IOBrokerMike
          • I ioBrokerMike
            @iobrokermike sagte in [ gelöst ] JSON aufteilen in DP:
            heisst das, dass es jetzt läuft?
              I Online
              I Online
              ioBrokerMike
              Richtig !!!
              Es läuft.
              Mfg
              IOBrokerMike
              • I ioBrokerMike
                Richtig !!!
                Es läuft.
                Richtig !!!
                Es läuft.
                Super!
                so muss es sein!
                dann kann @mickym jetzt mit @paul53 weiter über die Wandlung des json zum Objekt philosophieren
                  Richtig !!!
                  Es läuft.
                  Super!
                  so muss es sein!
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @homoran Nicht mehr nötig - ich konnte es mir ja selbst erklären.
                  • mickymM mickym
                    @mickym sagte in [ gelöst ] JSON aufteilen in DP:
                    ok, du hast wieder heimlich editiert ;-)
                    ist aber nur eine Arbeitshypothese, oder?
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @homoran Nein ich habe nichts editiert. Ich habe nur folgendes verstanden:
                      1. Wenn Du über einen JSON String ein Attribut extrahierst, wird temporär in ein Objekt gewandelt, um das Attribut zu extrahieren. Es bleibt aber ein JSON, also Text und wird nicht in ein Objekt gewandelt.
                      2. Um also den JSON als Objekt weiter zu verarbeiten musst du den JSON permanent in ein Objekt wandeln.
                      Das ganze hat also nichts mit JSONATA zu tun.
