  4. [Gelöst] Flot installations Probleme
    1.9k
12 Beiträge 3 Kommentatoren 2.1k Aufrufe
  • E Offline
    eXplOiD
    Guten Tag,
    mein Flot funktioniert nicht,
    ich bekomme bei der installation eine reihe an fehlern, eventuell kann jemand von euch ja damit was anfangen.
    $ ./iobroker add flot
    npm install iobroker.flot –production --prefix "/mnt/iobroker" (System call)
    node-pre-gyp ERR! Tried to download(404): https://github.com/tessel/node-usb/rele ... x64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for usb@1.3.1 and node@8.8.0 (node-v57 ABI) (falling back to source compile with node-gyp)
    ../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefundencompilation terminated.
    make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Fehler 1
    gyp
    ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/mnt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
    gyp ERR! stack at emitTwo (events.js:125:13)
    gyp ERR! stack at ChildProcess.emit (events.js:213:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
    gyp ERR! System Linux 4.4.0-104-generic
    gyp ERR! command "/usr/local/bin/node" "/mnt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "–fallback-to-build" "--module=/mnt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/mnt/iobroker/node_modules/usb/src/binding"
    gyp ERR! cwd /mnt/iobroker/node_modules/usb
    gyp ERR! node -v v8.8.0
    gyp ERR! node-gyp -v v3.6.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /mnt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/mnt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/mnt/iobroker/node_modules/usb/src/binding' (1)
    node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/mnt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack at emitTwo (events.js:125:13)
    node-pre-gyp ERR! stack at ChildProcess.emit (events.js:213:7)
    node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:927:16)
    node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
    node-pre-gyp ERR! System Linux 4.4.0-104-generic
    node-pre-gyp ERR! command "/usr/local/bin/node" "/mnt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /mnt/iobroker/node_modules/usb
    node-pre-gyp ERR! node -v v8.8.0
    node-pre-gyp ERR! node-pre-gyp -v v0.6.36
    node-pre-gyp ERR! not ok
    npm
    WARN
    optional
    SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
    npm
    WARN
    notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN notsup
    SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 (node_modules/usb):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: node-pre-gyp install --fallback-to-build
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    host.homeserver install adapter flot
    npm install --production (System call) in "/mnt/iobroker/node_modules/iobroker.flot"
    got /mnt/iobroker/node_modules/iobroker.flot/admin
    upload [0] flot.admin /mnt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
    got /mnt/iobroker/node_modules/iobroker.flot/www
    upload [30] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.hiddengraphs.js lib/js/jquery.flot.hiddengraphs.js application/javascript
    upload [20] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/preview-opacity.png lib/css/images/preview-opacity.png image/png
    upload [19] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/map.png lib/css/images/map.png image/png
    upload [18] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/map-pointer.png lib/css/images/map-pointer.png image/png
    upload [17] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/map-opacity.png lib/css/images/map-opacity.png image/png
    upload [16] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar.png lib/css/images/bar.png image/png
    upload [15] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar-pointer.png lib/css/images/bar-pointer.png image/png
    upload [14] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar-opacity.png lib/css/images/bar-opacity.png image/png
    upload [13] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar-alpha.png lib/css/images/bar-alpha.png image/png
    upload [12] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/128/map.png lib/css/images/128/map.png image/png
    upload [11] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/128/bar.png lib/css/images/128/bar.png image/png
    upload [10] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/128/bar-alpha.png lib/css/images/128/bar-alpha.png image/png
    upload [9] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/words.js js/words.js application/javascript
    upload [8] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/settings.js js/settings.js application/javascript
    upload [7] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
    upload [6] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/data.js js/data.js application/javascript
    upload [5] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/chart.js js/chart.js application/javascript
    upload [4] flot /mnt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
    upload [3] flot /mnt/iobroker/node_modules/iobroker.flot/www/img/resetZoom.png img/resetZoom.png image/png
    upload [2] flot /mnt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
    upload [1] flot /mnt/iobroker/node_modules/iobroker.flot/www/img/edit.svg img/edit.svg image/svg+xml
    upload [0] flot /mnt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
    host.homeserver object system.adapter.flot created
    host.homeserver object _design/chart created
    host.homeserver create instance flot
    host.homeserver object system.adapter.flot.upload created
    host.homeserver object system.adapter.flot.0 created
    process exited with code 0</anonymous>
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Die Fehler von gyp sind normal und nicht schlimm, desweiteren sehe ich das die mit upload endet also erfolgreich war.
      Hat du mal unter Instanzen geschaut ob er jetzt dabei steht?
      Send from mobile device
      Das schöne ios hat Auto Korrektur zum k****
      Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
      • E Offline
        eXplOiD
        @Dutchman:
        Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community `
        ja die Instanz ist da aber wie schon beschrieben funktioniert da nichts ich sehe unten ein dauerhaften ladebalken und objekte auswählen kann ich auch nicht.
        • E Offline
          eXplOiD
          @Dutchman:
          ich sehe aber das er versucht usb bindings zu installieren das aber nicht geht weil die angegebene adresse nicht mehr existiert.
          • apollon77A Online
            apollon77A Online
            Das hat aber mal nichts mit den Fehlern zu tun. Starte mal die Web Instanz neu
            • E Offline
              eXplOiD
              @apollon77:
              Das hat aber mal nichts mit den Fehlern zu tun. Starte mal die Web Instanz neu `
              erledigt, aber keine veränderung.
              die browser konsole zeigt mir dort aber auch nix an
              • E Offline
                eXplOiD
                ~~![](</s><URL url=)https://www2.pic-upload.de/img/34602628/Unbenannt-1.png" />
                ![](</s><URL url=)https://www2.pic-upload.de/img/34602625/Unbenannt-2.png" />~~
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  Hat du überhaupt history oder einen anderen datenlogger (zB MySQL Adapter) installiert und zeichnest Daten auf ?
                  Die selber geht ja wie ich aus dem Screenshot erkenne sehr nur keine Datenpunkte
                  • E Offline
                    eXplOiD
                    @Dutchman:
                    ja ich habe history installiert
                    • E Offline
                      eXplOiD
                      @Dutchman:
                      richtig weil mir flot keine Datenpunkte anzeigt warum auch immer
                      • DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        Und auch logging für Datenpunkte aktiviert?
                        Schau Mal bei den objecten ob überhaupt was aufgezeichnet ist.
                        Zudem in flot links anstatt Default Mal history selektieren
                        • E Offline
                          eXplOiD
                          geht jetzt danke habe im admin_beta nicht gesehen das man den harken noch setzen muss im alten admin war er zu sehen und hatte anschließend auch datenpunkte.
                          Dankeschön
