  4. [Vorlage] Denon Skript
    5.8k
141 Beiträge 35 Kommentatoren 40.5k Aufrufe
    akamia
    #97
    Widget jqui - icon http get
    Status Abfragen
    http://192.168.1.12/goform/formMainZone_MainZoneXml.xml
    http://192.168.1.12/goform/formMainZone_MainZoneXmlStatus.xml
    http://192.168.1.12/goform/formMainZone_MainZoneXmlStatusLite.xml
    http://192.168.1.12/goform/formNetAudio_StatusXml.xml
    http://192.168.1.12/goform/formNetAudio_StatusXml.xml?ZoneName=MAIN+ZONE
    http://192.168.1.12/goform/formZone2_Zone2XmlStatus.xml
    http://192.168.1.12/goform/formZone2_Zone2XmlStatusLite.xml
    !!! geht nicht !!! http://192.168.1.12/goform/formZone2_Zone2Xml.xml
    http://192.168.1.12/goform/Deviceinfo.xml
    Lautstärke
    Main Zone
    http://192.168.1.12/goform/formiPhoneAppMute.xml?1+MuteOn
    http://192.168.1.12/goform/formiPhoneAppMute.xml?1+MuteOff
    http://192.168.1.12/goform/formiPhoneAppVolume.xml?1+ <db wert/meist/negativ/z.b./-30="">Zone 2
    http://192.168.1.12/goform/formiPhoneAppMute.xml?2+MuteOn
    http://192.168.1.12/goform/formiPhoneAppMute.xml?2+MuteOff
    http://192.168.1.12/goform/formiPhoneAppVolume.xml?2+- <db wert/meist/negativ/z.b./-30="">http://192.168.1.12/goform/formiPhoneAppVolume.xml?2+-10
    Power zustand
    Main Zone
    http://192.168.1.12/goform/formiPhoneAppPower.xml?1+PowerOn
    http://192.168.1.12/goform/formiPhoneAppPower.xml?1+PowerStandby
    Zone 2
    http://192.168.1.12/goform/formiPhoneAppPower.xml?2+PowerOn
    http://192.168.1.12/goform/formiPhoneAppPower.xml?2+PowerStandby
    Netzwerk
    http://192.168.1.12/goform/formiPhoneAppNetAudioCommand.xml?CurLeft
    http://192.168.1.12/goform/formiPhoneAppNetAudioCommand.xml?CurRight
    http://192.168.1.12/goform/formiPhoneAppNetAudioCommand.xml?CurDown
    http://192.168.1.12/goform/formiPhoneAppNetAudioCommand.xml?CurUp
    http://openremote.org/display/docs/OpenRemote+2.0+How+To+-+Denon+AV+Receivers
    Cover Bilder beim Abspielen
    http://192.168.1.12/NetAudio/art.asp-jpg
    http://192.168.1.12/img/album%20art_S.png
    Allgemein Befehle laut Telnet Dokumentation
    http://assets.denoneu.com/DocumentMaster/DE/AVRX4000_PROTOCOL(10.3.0)_V01.pdf
    http://192.168.1.12/goform/formiPhoneAppDirect.xml?MVUP
    http://192.168.1.12/goform/formiPhoneAppDirect.xml?MVDOWN
    http://192.168.1.12/goform/formiPhoneAppDirect.xml?SITV
    http://192.168.1.12/goform/formiPhoneAppDirect.xml?SIGAME
    http://192.168.1.12/goform/formiPhoneAppDirect.xml?SIIRADIO
    http://192.168.1.12/goform/formiPhoneAppDirect.xml?SIFAVORITES
    http://192.168.1.12/goform/formiPhoneAppDirect.xml?ZMFAVORITE1</db></db>
    NUC6i3 / ProxMox / HM/FHEM/WifiLight/HUE/Tradfri/KM200/InfluxDB/RFlink/Plex/Smartmeter
    piVCCU, Arduinos, X4000, Z2000, Solo4K, SAMSUNG C & H, NAS OMV4/Win10Pro (JRMC/JRemote), 4x4 HDMImatrix, ...
      Brati
      #98
      @divepython
      Wenn du nur aus vis steuern willst, ist das Widget von akamia am einfachsten. Willst du den Denon aber vielleicht automatisch bedienen klappt es nur über ein JavaScript oder in der CCU.
      In der CCU mit CuxD geht es über den Befehl:
      dom.GetObject("CUxD.CUX2801001:1.CMD_EXEC").State("LD_LIBRARY_PATH=/usr/local/addons/cuxd /usr/local/addons/cuxd/curl http://192.168.178.25/goform/formiPhoneAppDirect.xml?{Z2FAVORITES}");
      Als JS würde ich dir das hier empfehlen (meins :lol:) http://forum.iobroker.net/viewtopic.php … 327#p17186 die Volume Werte werden direkt aus dem State übernommen. Die Kommandos werden per Widget gesetzt. Wenn Alexa also Lautstärke auf 45 setzen kann, würde die 45 an den AVR gesendet werden. Ich denke mal die Kommandos als Text String wird nicht klappen, da müsste man etwas umschreiben.
      Brati
      • hg6806H Offline
        hg6806H Offline
        hg6806
        #99
        Moin!
        Leider hatte ich auch nach dem Aufpsielen eines Backups wieder das Problem, dass die IP Adresse ungültig ist.
        Also habe ich
        CreateState('javascript.0.Denon.System.IP_Adresse', '192.168.178.20',{type: "string", role: "AVR IP Adresse"});
        auskommentiert und die IP Adresse im Datenpunkt eingetragen.
        Jetzt gibt es die Fehlermeldung "Error: connect ECONNREFUSED 192.168.178.20:23"
        Kann jemand helfen?
        Danke und Grüße
        • dslraserD Offline
          dslraserD Offline
          dslraser
          #100
          @divepython:
          bin ganz neu hier und möchte mich erst einmal bei allen bedanken, die sich hier so viel Mühe machen und auch Newbies es möglich machen, mit iobroker zu arbeiten.
          Habe das Denon-Skript zum laufen gebracht und selbst über Alexa ging die Steuerung (An/Aus; Lautstärke etc.) meines Denon 4520.
          Ich nutze die DeRemote-App auf dem Iphone und da mehrere Telnet-Verbindungen nicht funktionieren, ich aber auf die App nicht verzichten möchte (u.a. wegen Audyssey-Einstellungen) möchte ich Fragen, ob ihr eine Lösung habt, wie ich den AVR über iobroker an- und ausschalten kann (ggf. noch Lautstärke regeln), aber weiterhin mit der App alles weitere steuern kann. Ginge das, über einen http-Befehl, so dass iobroker nicht über Telnet die Verbindung aufbaut?
          Die Denon-App funzt ja auch zusammen mit iobroker, aber hat nicht die komfortablen Steuerungsmöglichkeiten wie die DeRemote-App. Deshalb mein gedanke, das alles umzudrehen, d.h. iobroker steuert über http und DeRemote über Telnet.
          Viele Grüße
          Marco `
          also Lautstärke regeln habe ich bei meinem 4520 so. (über Alexa)
          Ich stelle hier mal noch einen Link mit rein (ich hoffe das ist okay, sonst bitte löschen), da gibt es einiges an http Befehlen.
          http://blue-pc.net/2013/12/28/denon-av- … p-steuern/
          ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201801 ... 9e77ec.jpg">https://uploads.tapatalk-cdn.com/20180111/090351703fe16faf29b8072a9c9e77ec.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201801 ... 98816b.jpg">https://uploads.tapatalk-cdn.com/20180111/c30da281d675040dfc2812789698816b.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201801 ... 32ef32.jpg">https://uploads.tapatalk-cdn.com/20180111/ae36d464d48d3452ea83fc9e8732ef32.jpg</link_text>" />~~~~
            divepython
            #101
            Hallo dslraser und brati,
            erst einmal vielen Dank für die schnellen Antworten.
            Ich bin in Java absoluter Newbie und völlig blank (bin gerade einmal auf "Hallo Welt"-Niveau :roll: )
            Schaffe es nicht mit Euren Vorgaben ein einfaches Power-on/Power-off-Script, das über http den befehl sendet, zu erstellen.
            Könnt ihr das für Dummies so erklären, dass ich damit erst einmal anfangen kann? Denn bei den Lautstärke-Skripten wird es mit den Werten ja schon wieder komplizierter, als bei schlichtem An/Aus.
            Mein Versuch ein solches Skript zu erstellen endete damit, dass das Skript in einer Endlosschleife durchlief und ich den raspy rebooten musste ….
            Über vis klappt es, wenn ich die Schalter betätige, aber ich will ja das ganze nicht über vis steuern, sondern lediglich über Alexa mit dem Kommando "Verstärker an" und "Verstärker aus" den AVR steuern, um dann mit DeRemote die weitere Bedienung vorzunehmen. Die Befehle sollen dann in meinen Szenen" Kino an" (Beamer springt an, Leinwand fährt hinunter, Licht wird gedimmt bzw. ausgeschaltet, etc.) integriert werden, so dass auch der AVR anspringt.
            Die Kür ist danach sicherlich noch weitere Sprachbefehle (wie z. B. Lautstärke) hinzuzufügen. Aber so weit bin ich noch lange nicht, zumal ich mit iobroker erst angefangen habe. Java ist zur Zeit noch zu weit weg, zumal ich kein Techniker bin.
            Die für Euch wohl sehr einfachen Skripte für die Lautstärke überfordern mich bereits, da ich bisher nur mit an/aus hantiert habe.
            Mein Vorgehen war bisher:
            1. Skript erstellen.
            2. Dann in über icloud das Objekt mit "Smart-Name" versehen.
            3. Dann mit Kommando "An" oder "Aus" steuern
            @ dslraiser: Das Bild mit dem Script lässt sich leider nicht vergrößern, so dass ich es nicht lesen kann. Sonst hätte och es einmal abgetippt und selbst versucht bzw. nochmal versucht anhand dieses Beispiels ein An/Aus-Skript zu erstellen. Bitte stell es doch noch mals so ins Forum, dass man es vergrößert betrachten kann. Danke vorab.
            Sorry, dass ich als absoluter Anfänger mit Eurer Hilfe versuche die ersten Erfolge zu erzielen. Aber viele Foren-Diskussionen verstehe ich schon vom Grunde her nicht, da viele Fachbegriffe fallen, die als Newbie noch unverständlich sind.
            Viele Grüße
            • dslraserD Offline
              dslraserD Offline
              dslraser
              #102
              ich war heute morgen nur am Handy, hier das Script für die Lautstärke
              ! ` > createState('Denon.Denon_Lautstärke', {
              type: 'number',
              min: 0,
              max: 100,
              def: 50,
              read: true,
              write: true,
              role: 'level.volume'});
              var http = "http://192.168.180.6/goform/formiPhoneAppDirect.xml?";
              on({id: "javascript.0.Denon.Denon_Lautstärke", change: "any"},
              function (obj) {
              var x = obj.state.val;
              if (x === 0) {
              require("request")(http + 'MUON'); // Bei Befehl "aus" wird Vol. auf Mute gesetzt.
              console.log("Lautstärke AVR-4520 auf -MUTE- gesetzt.");
              } else {
              require("request")(http + 'MV' + x);
              console.log("Lautstärke AVR-4520 auf " + x + " gesetzt.");
                divepython
                #103
                @dslraiser: DANKE !!!!
                Es klappt mit der Lautstärke!! :D :D und ich kann noch weiter über DeRemote steuern!
                Wie muss ich das Skript verändern um jetzt noch ein- und ausschalten zu können?
                Viele Grüße
                • dslraserD Offline
                  dslraserD Offline
                  dslraser
                  #104
                  kann ich jetzt aus dem Kopf leider nicht sagen (bin arbeiten) Leider komme ich auch heute Abend und morgen nicht dazu (unterwegs…)
                  • dslraserD Offline
                    dslraserD Offline
                    dslraser
                    #105
                    Versuch doch mal mit Blockly.
                    Main Zone http://<av ip-adresse="">/goform/formiPhoneAppPower.xml?
                    1+PowerOn http://<av ip-adresse="">/goform/formiPhoneAppPower.xml?1+PowerStandby
                    Zone 2 http://<av ip-adresse="">/goform/formiPhoneAppPower.xml?
                    2+PowerOn http://<av ip-adresse="">/goform/formiPhoneAppPower.xml?2+PowerStandby
                    ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201801 ... ff494f.jpg">https://uploads.tapatalk-cdn.com/20180111/4bb1b6aea9e7f3cd0fddba685eff494f.jpg</link_text>" /></av></av></av></av>
                      divepython
                      #106
                      No Problem …
                      Nochmals 1000 Dank vorab
                      • dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #107
                        @divepython:
                        No Problem …
                        Nochmals 1000 Dank vorab `
                        Blockly Export
                        einschalten Mainzone
                        <block xmlns="http://www.w3.org/1999/xhtml" type="request" id="w8WF/@tE%Efnc4`8#{=V" x="-687" y="88"><mutation with_statement="false"></mutation>
                        <field name="WITH_STATEMENT">FALSE</field>
                        <value name="URL"><shadow type="text" id="!P`R0]P%}]#3dInn=]?4"><field name="TEXT">http://192.168.180.6/goform/formiPhoneAppPower.xml?1+PowerOn</field></shadow></value></block>
                        • dslraserD Offline
                          dslraserD Offline
                          dslraser
                          #108
                          Blockly Export Main Zone Standby
                          <value name="URL"><shadow type="text" id="!P`R0]P%}]#3dInn=]?4"><field name="TEXT">http://192.168.180.6/goform/formiPhoneAppPower.xml?1+PowerStandby</field></shadow></value></block>
                          hier der "normale Code" brauchst Du nur die Befehle von hier abändern
                          try {
                            require("request")('http://192.168.180.6/goform/formiPhoneAppPower.xml?1+PowerStandby').on("error", function (e) {console.error(e);});
                          } catch (e) { console.error(e); }
                          Die Befehle findest Du hier
                          Unten noch ein Beispiel für Alexa mit A.V.R. an (die Punkte im Namen sind wichtig)
                            divepython
                            #109
                            Habe es hinbekommen. Mein Skript sieht jetzt wie folgt aus (geht wahrscheinlich eleganter, aber es funktioniert):
                            createState('Denon.Denon_Power', {
                            type: 'boolean',
                            read: true,
                            write: true,
                            role: 'switch.active'
                            var http = "http://192.1XX.XXX.XX/goform/formiPhoneAppPower.xml?";
                            on({id: "javascript.0.Denon.Denon_Power", change: "ne"},
                            function (obj) {
                            if (getState("javascript.0.Denon.Denon_Power").val === true) {
                            require("request")(http + '1+PowerOn');
                            } else {
                            require("request")(http + '1+PowerStandby');
                            Nochmals Danke für die Unterstützung … wahrscheinlich komme ich demnächst wieder angedackelt, weil ich weitere Funktionen hinzufügen möchte :lol: :lol:
                            • dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #110
                              @divepython:
                              type: 'boolean',
                              read: true,
                              write: true,
                              function (obj) {
                              } else {
                              Nochmals Danke für die Unterstützung … wahrscheinlich komme ich demnächst wieder angedackelt, weil ich weitere Funktionen hinzufügen möchte :lol: :lol: `
                              Ja, habe es in meiner Mittagspause mal schnell eingebaut, funktioniert..
                              • smileS Offline
                                smileS Offline
                                smile
                                #111
                                Auch hier sieht man mal wieder was für eine tolle Arbeit durch die Communitiy entsteht - danke an alle beteiligten!
                                Ich habe gerade zwei neue Vorstufen hier zum Testen. Yamaha CX-A5100 und Maratz AV-7704
                                Habe im Rahmen des Tests natürlich bei beiden auch gleich die Verbindungsmöglichkeiten zu io.broker getestet ;-)
                                Bei Yamaha lief das über den entsprechenden Adapter hervorragend. Aber der hat einfach den schlechteren Klang ;)
                                Bei dem Maratz war mein Gedanke das Denon Script zu nutzen, da Denon und Marantz ja bekanntermaßen unter eine Decke stecken und dieselbe Software verwenden.
                                Ich habe das Script ausgeführt und anschließend die IP Adresse unter "Objekte" eingetragen.
                                Leider kann ich den Marantz nicht steuern.
                                Ich dachte erst dass es dann wohl doch nicht funktioniert, jedoch eine Sache ist interessant: Ich bekomme den Namen des Maratz in io.broker angezeigt, ohne dass ich diesen selber eingegeben habe:
                                Das sagt mir dass die Verbindung eigentlich doch funktionieren sollte?
                                Hat jemand eine Idee was eventuell noch geändert werden sollte damit die Steuerung klappt?
                                Hier kommt einmal der Log dazu:
                                Vielen Dank für eure Hilfe!! :)
                                io.broker @ debian @ virtualbox @ Windows 10 Pro / Node 18.17.1, npm 9.6.7 / CCU3 / IR.Trans Server / Daslight 4 / Mobotix IP Cams / Qnap NAS / Sonos /
                                Mein Rolladen - Blockly: https://forum.iobroker.net/topic/6442/das-ultimative-markisen-rolladen-blockly-script
                                • smileS Offline
                                  smileS Offline
                                  smile
                                  #112
                                  Ich habe bei weiteren Recherchen noch folgendes gefunden:
                                  Eine Excel Tabelle mit Marantz IP Commandos.
                                  Vom ersten drüberschauen sind die Befehle wie erwartet analog zu Denon (z.B. "PWON" oder "PWOFF" für Power oder "MVUP" und "MVDOWN" für Master Volume up/down)
                                  Es gibt wohl ein paar unterschiedliche Befehle, klar zum Teil gibts ja auch verschiedene Funktionen, aber das grundlegende sollte doch funktionieren?
                                  Im IP Symcon Forum habe ich noch ein Script gefunden welches Maratz-spezifisch sein soll. Das kann man sicher nicht so einfach 1:1 verwenden, aber lässt sich eventuell daraus ableiten was vielleicht der Knackpunkt sein könnte?
                                  https://www.symcon.de/forum/threads/295 … et-steuern
                                  Laut Fhem Forum ist das Modul für Denon ja ebenfalls für Maratz gebräuchlich.
                                  Wäre ja ziemlich cool wenn das Denon Script auch für alle Marantz User lauffähig wird :D
                                  3472_marantz_av_sr_nr_protocol_v02.xls
                                  • smileS Offline
                                    smileS Offline
                                    smile
                                    #113
                                    <size size="150">Vergesst was ich geschrieben habe - es läuft!!!!</size>
                                    Das Script ist Marantz kompatibel. So super.
                                    Ich hab ein bisschen an der IP Adresse hin und her gestellt und den Marantz mal aus und wieder angeschaltet und irgendwann gings dann :D :D
                                    Einzig die "Master_Volume" funktioniert nur wenn man die Lautstärke nicht im negativen Bereich ( - 70 bis + 10 ) regelt, sondern im positiven Bereich ( 0 bis + 80 ). Schade, die negative Regelung ist ja eigentlich die Studiotechnisch korrekte :P ;)
                                    Aber ansonsten: ich bin mega begeistert. Danke für die Arbeit!
                                    • hg6806H Offline
                                      hg6806H Offline
                                      hg6806
                                      #114
                                      Leider bleibt bei mir wohl das Script alle paar Tage einfach stehen. AVR3311
                                      Ich kann dann nichts bedienen und bekomme auch keine Rückmeldung wie z.B. OSD Info.
                                      Keine Fehlermeldung im Log. Script sieht aus als würde es laufen.
                                      Wenn ich das Script dann einfach neu starte geht wieder alles.
                                      Ist das was bekannt?
                                      • uweklattU Offline
                                        uweklattU Offline
                                        uweklatt
                                        #115
                                        Hallo hg6806,@hg6806:
                                        Wenn ich das Script dann einfach neu starte geht wieder alles. `
                                        Den Neustart kann das Script ja auch selbst erledigen ;-)
                                        Ich habe bei mir folgendes am Ende hinzugefügt:
                                        // Nachts um 4:40 neu verbinden...
                                        schedule("40 4 * * *", function() {
                                                    if(getState('javascript.0.Denon.System.Verbunden').val===true)
                                                        killClient(client);
                                                    checkIP(getState('javascript.0.Denon.System.IP_Adresse').val);
                                        Tschau
                                        Uwe
                                        Intel i5/Proxmox/LXC/Docker/ioBroker
                                          Ati
                                          #116
                                          Hallo, ich oute mich mal gleich vorweg, damit keine Missverständnisse entstehen und schließ mich dem Autor divepython oben an. (hallo Welt und so)
                                          io.Broker ist neu für mich. Habe ja auch noch nicht all zulange piVCCU im Einsatz. Aber immerhin, io.Broker läuft und ich habe auch ein paar Testversuche bereits absolviert.
                                          Interessanterweise bin ich mehr durch Zufall auf die Denon Steuerung gestoßen, was mich sofort magisch in den Bann gezogen hat. Natürlich gibt es für den AVR (in meinem Fall ein 4300) auch eine Remotesoftware von Denon für das iPad bzw. Android. Aber die Steuerung auch in eine Visualisierung zu bringen erscheint reizvoll.
                                          Also ich habe kurzerhand mal das Scrip nach io.Broker kopiert. Unter Objekte/Javascript.0 erscheint auch das Denon-Script. Aber, das Script hat keinen Connect.
                                          Log
                                          15:37:29.793 [info] javascript.0 Stop script script.js.Denon
                                          15:37:33.601 [info] javascript.0 Start javascript script.js.Denon
                                          15:37:33.602 [error] javascript.0 script.js.Denon: ungültige IP Adresse
                                          15:37:33.603 [info] javascript.0 script.js.Denon: registered 40 subscriptions and 0 schedules
                                          im Script steht dazu folgendes, was mir richtig erscheint.
                                          //Kontakt: s-nolte@htp-tel.de
                                          //ioBroker Forum: Lucky
                                          var net = require('net');
                                          // System
                                          createState('javascript.0.Denon.System.UPDATE', false,{type: "boolean", role: "button"});
                                          createState('javascript.0.Denon.System.Power_System', false,{type: "boolean", role: "Power System"});
                                          createState('javascript.0.Denon.System.System_Ready', false,{type: "boolean", role: "System Ready",write:false});
                                          createState('javascript.0.Denon.System.IP_Adresse', '192.168.0.10',{type: "string", role: "AVR IP Adresse"});
                                          Der Denon hat die IP 192.168.0.10. Netzwerksteuerung ist eingeschaltet im Denon. Ein Aufruf der Webseite des Denon ergibt
                                          Error 403: Forbidden
                                          Access Forbidden
                                          Aber dazu habe ich folgende Info:
                                          ` > Folgende Antwort habe ich vom Denon Support zu meiner Frage erhalten:
                                          Sehr geehrter Herr xxx,
                                          vielen Dank für Ihre Anfrage.
                                          Unsere neuen AV-Receiver mit der Bezeichnung AVR-X..00H unterstützen kein Web-Interface mehr.
                                          Eine Steuerung des Receivers ist via IR, App (Android/IOS) und IP-Steuerung bzw. RS232-Steuerung möglich.
                                          Also ein Test ob die Webseite des AVR erreichbar ist, kann nur fehlschlagen. `
                                          Es wäre also Super, wenn mir hier mal auf die Sprünge geholfen werden könnte.
                                          Dank im Voraus
                                          Andreas
