  4. Homematic IP Cloud Adapter lässt sich nicht installieren
36 Beiträge 3 Kommentatoren 4.5k Aufrufe 2 Beobachtet
  • L lukas8519
    @lukas8519
    jetzt kommt das
    lukas@iobroker:/opt/iobroker $ iob stop
    lukas@iobroker:/opt/iobroker $ sudo apt update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
    Get:5 https://repos.influxdata.com/debian stretch InRelease [12.9 kB]
    Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
    Err:5 https://repos.influxdata.com/debian stretch InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Err:6 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    Reading package lists... Done
    W: GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian stretch InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    lukas@iobroker:/opt/iobroker $ sudo apt full-upgrade
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
    Use 'sudo apt autoremove' to remove them.
    The following NEW packages will be installed:
      kms++-utils raspi-utils
    The following packages will be upgraded:
      adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez
      bluez-firmware bsdextrautils bsdutils chromium-browser chromium-browser-l10n
      chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client cups-common
      cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils
      cups-ppdc cups-server-common dbus dbus-user-session dbus-x11 debian-archive-keyring
      dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject exfatprogs fdisk
      ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree
      firmware-realtek ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git
      git-man gldriver-test grafana grep gstreamer1.0-alsa gstreamer1.0-plugins-bad
      gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
      gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0
      libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev
      libavahi-common3 libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7
      libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
      libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin
      libc-dev-bin libc-devtools libc-l10n libc6 libc6-dbg libc6-dev libcamera-apps
      libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
      libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0
      libexpat1 libexpat1-dev libext2fs2 libfdisk1 libflac8 libfontembed1 libgbm1
      libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common
      libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
      libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common
      libgssapi-krb5-2 libgstreamer-gl1.0-0 libgstreamer-plugins-bad1.0-0
      libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
      libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0
      libkrb5-3 libkrb5support0 libksba8 liblapack3 libmagic-mgc libmagic1 libmount-dev
      libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1 libnghttp2-14
      libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55
      libprotobuf-lite23 libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5
      libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5widgets5 libqt5xml5
      libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
      librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient
      libsqlite3-0 libss2 libssh-gcrypt-4 libssh2-1 libssl1.1 libswresample3 libswscale5
      libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1 libuuid1
      libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0
      libwebkit2gtk-4.0-37 libwebp6 libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev
      libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev locales logrotate logsave
      lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
      lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers
      mesa-vdpau-drivers mount mutter mutter-common nano ncurses-base ncurses-bin ncurses-term
      net-tools nfs-common nftables nodejs ntfs-3g openssh-client openssh-server
      openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt
      python3-cryptography python3-flask python3-idna python3-kms++ python3-libcamera
      python3-picamera2 python3-pil python3-pkg-resources python3-renderpm python3-reportlab
      python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
      python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel
      raspberrypi-sys-mods raspberrypi-ui-mods raspi-config raspinfo realvnc-vnc-server rfkill
      rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd systemd-sysv
      systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data
      vlc-l10n vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
      vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output vlc-plugin-video-splitter
      vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core xwayland
    321 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
    Need to get 212 MB/700 MB of archives.
    After this operation, 539 MB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 http://archive.raspberrypi.org/debian bullseye/main arm64 kms++-utils arm64 0~git20221104~171243+adc05b6-1 [81.4 kB]
    Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 raspinfo all 20230123-1 [2,564 B]
    Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-utils arm64 20230123-1 [41.8 kB]
    Err:4 https://packages.grafana.com/oss/deb stable/main arm64 grafana arm64 10.1.0
      404  Not Found [IP: 2a04:4e42:9::729 443]
    Fetched 126 kB in 0s (422 kB/s)
    E: Failed to fetch https://packages.grafana.com/oss/deb/pool/main/g/grafana/grafana_10.1.0_arm64.deb  404  Not Found [IP: 2a04:4e42:9::729 443]
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    @lukas8519 sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
    das ist ja Steinzeit
    wie alt ist die Installation?
      Halte deine Kiste immer auf einem aktuellen Stand...
      Die hat noch nie ein Update gesehen. Davon ab betreibt man auch keine graphische Oberfläche auf einem Server.
      Was willste mit vlc auf dem Ding?
      Richte grafana und influx neu ein:
      https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
      L 1 Antwort Letzte Antwort
        lukas8519
        ja die ist schon älter und ich habe tatsächlich nicht viel daran gemacht.
        Und Grafana benutze ich auch schon lange nicht mehr ...
        was sind denn nun die extenziell wichtigen schritte?
        sorry für meine Unwissenheit
        • L lukas8519
          Die habe ich dir schon geschrieben.
          • L Offline
            lukas8519
            @Homoran, @Thomas-Braun,
            ich bin nun wieder up to date und alles läuft, inklusive der HmIP Installation.
            Ich danke euch für euern Support und eure Geduld.
            Danke das Ihr durch euer Engagement auch Leuten wie mir helft sich ein wenig zu recht zu finden und am Iobroker teil haben zu können!
            Danke!
            • L lukas8519
              Danke!
              @lukas8519
              Dann lass jetzt mal die Langfassung von
              iob diag
              sehen.
                @lukas8519
                iob diag
                sehen.
                lukas8519
                Copy text starting here:
                                        v.2024-10-19
                   Static hostname: iobroker
                         Icon name: computer
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 5.15.61-v8+
                      Architecture: arm64
                Kernel:                 aarch64
                Userland:               64 bit
                Timezone:               Europe/Berlin (CET, +0100)
                User-ID:                1000
                Display-Server:         false
                Boot Target:            multi-user.target
                Pending OS-Updates:     0
                Pending iob updates:    28
                This system needs to be REBOOTED NOW!
                Nodejs-Installation:
                /usr/bin/nodejs         v20.18.0
                /usr/bin/node           v20.18.0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.29.3
                Recommended versions are nodejs 20.18.0 and npm 10.8.2
                nodeJS installation is correct
                MEMORY:
                Mem:            3.8G        2.4G        412M         35M        964M        1.2G
                Swap:            99M         56M         43M
                Total:          3.9G        2.5G        456M
                Active iob-Instances:   31
                Upgrade policy: none
                ioBroker Core:          js-controller           6.0.11
                                        admin                   7.1.5
                Objects type: jsonl
                States  type: jsonl
                Objects:                26089
                States:                 20688
                Size of iob-Database:
                24M     /opt/iobroker/iobroker-data/objects.jsonl
                37M     /opt/iobroker/iobroker-data/states.jsonl
                Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                === Mark text until here for copying ===
                • L lukas8519
                                          v.2024-10-19
                           Icon name: computer
                        Architecture: arm64
                  Kernel:                 aarch64
                  Userland:               64 bit
                  User-ID:                1000
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  MEMORY:
                  Swap:            99M         56M         43M
                                          admin                   7.1.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                26089
                  States:                 20688
                  @lukas8519
                  Ich wollte die Langfassung sehen, nicht die Zusammenfassung.
                  Nach einem REBOOT:
                    @lukas8519
                    Nach einem REBOOT:
                    lukas8519
                    @thomas-braun habs gemerkt, moment
                    • L lukas8519
                      @lukas8519
                      Und das bringst du auch auf 0:
                        @lukas8519
                        lukas8519
                        um die letzten 6 Updates kümmere ich mich morgen.
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                                 Icon name: computer
                                    Kernel: Linux 6.1.21-v8+
                              Architecture: arm64
                        OS is similar to:
                        Model           : Raspberry Pi 4 Model B Rev 1.1
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         00:18:01 up 4 min,  2 users,  load average: 3.97, 2.63, 1.17
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** TIME AND TIMEZONES ***
                                       Local time: Sun 2024-11-10 00:18:01 CET
                                   Universal time: Sat 2024-11-09 23:18:01 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        lukas
                        HOME=/home/lukas
                        GROUPS=lukas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        *** DISPLAY-SERVER SETUP ***
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            3.8G        2.0G        821M        1.0M        943M        1.7G
                        Swap:            99M          0B         99M
                        Total:          3.9G        2.0G        921M
                                 3794 M total memory
                                 2028 M used memory
                                 2408 M active memory
                                  415 M inactive memory
                                  821 M free memory
                                   71 M buffer memory
                                  872 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        top - 00:18:02 up 4 min,  2 users,  load average: 3.73, 2.60, 1.17
                        Tasks: 208 total,   1 running, 207 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  9.7 us,  4.2 sy,  0.0 ni, 86.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3794.3 total,    821.5 free,   2028.4 used,    944.4 buff/cache
                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1681.2 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        No critical errors detected
                        *** FILESYSTEM ***
                        /dev/root      ext4      235G   14G  212G   6% /
                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                        tmpfs          tmpfs     759M  1.2M  758M   1% /run
                        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                        tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                        [Sun Nov 10 00:13:06 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Sun Nov 10 00:13:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Sun Nov 10 00:13:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Sun Nov 10 00:13:10 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        Show mounted filesystems:
                        TARGET  SOURCE         FSTYPE OPTIONS
                        /       /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        4.8G    /var/
                        3.7G    /var/log
                        3.6G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
                        739M    /var/cache
                        Archived and active journals take up 3.5G in the file system.
                        /opt/iobroker/backups:
                        1.7G    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        548M    /opt/iobroker/iobroker-data/
                        402M    /opt/iobroker/iobroker-data/files
                        80M     /opt/iobroker/iobroker-data/backup-objects
                        67M     /opt/iobroker/iobroker-data/files/echarts.admin
                        61M     /opt/iobroker/iobroker-data/files/echarts
                        38M     /opt/iobroker/iobroker-data/states.jsonl
                        28M     /opt/iobroker/iobroker-data/objects.jsonl
                        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                        *** NodeJS-Installation ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Installed: 20.18.0-1nodesource1
                          Candidate: 20.18.0-1nodesource1
                          Version table:
                         *** 20.18.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                             20.17.0-1nodesource1 1001
                             20.16.0-1nodesource1 1001
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                             12.22.12~dfsg-1~deb11u5 500
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 289)
                        Core adapters versions
                        js-controller:  6.0.11
                        admin:          7.1.5
                        javascript:     7.8.0
                        nodejs modules from github:     1
                        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                        Adapter State
                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                          system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                        + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
                        + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                        + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled
                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                          system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
                        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                          system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                        + system.adapter.history.0                : history               : iobroker                                 -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                        + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                          system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                          system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
                        + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                          system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
                        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                          system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
                          system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 - disabled
                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 7.1.5    , installed 7.1.5
                        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                        Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
                        Adapter    "bring"        : 1.8.4    , installed 1.8.4
                        Adapter    "countdown"    : 2.3.0    , installed 2.3.0
                        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                        Adapter    "device-reminder": 3.1.2  , installed 1.2.9  [Updatable]
                        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                        Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                        Adapter    "fullybrowser" : 3.0.12   , installed 2.1.1  [Updatable]
                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                        Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
                        Adapter    "hmip"         : 1.24.3   , installed 1.24.3
                        Adapter    "hue"          : 3.12.0   , installed 3.12.0
                        Adapter    "ical"         : 1.15.0   , installed 1.15.0
                        Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
                        Controller "js-controller": 6.0.11   , installed 6.0.11
                        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                        Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                        Adapter    "rpi2"         : 2.2.1    , installed 1.3.1  [Updatable]
                        Adapter    "samsung"      : 0.6.1    , installed 0.6.1
                        Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
                        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                        Adapter    "text2command" : 3.0.3    , installed 3.0.3
                        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                        Adapter    "web"          : 6.2.5    , installed 6.2.5
                        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                        Adapter    "withings"     : 0.0.13   , installed 0.0.13
                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                        Objects and States
                        Objects:        26237
                        States:         20884
                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
                        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:6 https://repos.influxdata.com/debian stable InRelease
                        Hit:7 https://apt.grafana.com stable InRelease
                        Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        12227      623/influxd
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1818       581/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15599      914/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15605      914/iobroker.js-con
                        tcp        0      0 192.168.178.92:42011    0.0.0.0:*               LISTEN      1001       15855      1203/io.hm-rpc.1
                        tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15823      1184/io.hm-rpc.0
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14199      545/cupsd
                        tcp6       0      0 :::8086                 :::*                    LISTEN      116        16444      623/influxd
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18905      1797/io.simple-api.
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17521      1029/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18296      1731/io.web.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          1820       581/sshd: /usr/sbin
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14198      545/cupsd
                        tcp6       0      0 :::3000                 :::*                    LISTEN      117        15592      913/grafana
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14656      476/dhcpcd
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16054      1334/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16055      1334/io.tuya.0
                        udp        0      0 0.0.0.0:35422           0.0.0.0:*                           108        14136      401/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14134      401/avahi-daemon: r
                        udp6       0      0 :::41151                :::*                                108        14137      401/avahi-daemon: r
                        udp6       0      0 :::546                  :::*                                0          14697      476/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        14135      401/avahi-daemon: r
                        2024-11-10 00:19:17.540  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:17.541  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:17.542  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:17.597  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:21.597  - info: alexa2.0 (1139) Subscribing to states...
                        2024-11-10 00:19:21.608  - info: alexa2.0 (1139) Deleting the following states: ["Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7","Smart-Home-Devices.003aedb7-567e-4c34-a57c-a07ff842976c.#query","Smart-Home-Devices.012f1123-14fe-45de-b7ad-e96d7d2418f5.#query","Smart-Home-Devices.0373ad50-6d67-4d7d-8cf1-25c5ca3a8a6f.#query","Smart-Home-Devices.0558f2c7-04f3-466b-bc3d-5eeb9537fc83.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#delete","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#enabled","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.active","Smart-Home-Devices.0a175031-bd4e-467f-bcf7-a317bfc179eb.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#delete","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#enabled","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity-reason","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.powerState","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#delete","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#enabled","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#query","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-hue","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-saturation","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorRgb","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureInKelvin","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity-reason","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.powerState","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#delete","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#enabled","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#query","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity-reason","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.powerState","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#delete","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#enabled","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#query","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.active","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#delete","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#enabled","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#query","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.brightness","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity-reason","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.powerState","Smart-Home-Devices.196e2f4f-23ff-4419-9398-55823800ccae.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#delete","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#enabled","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-hue","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-saturation","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorRgb","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureInKelvin","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.powerState","Smart-Home-Devices.1eaa8074-65f2-4b2f-8aa0-18a0bd21252a.#query","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#delete","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#enabled","Smart-Home-Devices.2ad5f69c-0316-4394-b033-ea4f1d17a11a.#query","Smart-Home-Devices.2b7f4876-d82c-42d6-b302-20a0ae5d5d39.#query","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#delete","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#enabled","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#query","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-hue","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-saturation","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorRgb","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureInKelvin","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.powerState","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#delete","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#enabled","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#query","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-hue","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-saturation","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorName","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorRgb","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity-reason","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.powerState","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#delete","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#enabled","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#query","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-hue","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-saturation","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorRgb","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureInKelvin","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.powerState","Smart-Home-Devices.3ac22223-0447-4d99-b624-1ed607a5848f.#query","Smart-Home-Devices.414afebe-9a0c-4dfb-a60d-d69324daa9ba.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#delete","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#enabled","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity-reason","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.powerState","Smart-Home-Devices.41d1bfc2-f0c9-41f5-993d-7f3090c0c015.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#delete","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#enabled","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity-reason","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.powerState","Smart-Home-Devices.45734c42-2ddc-4bdb-b4fb-053417c9fb29.#query","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#delete","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#enabled","Smart-Home-Devices.4843643a-6b91-48c5-9b27-21b8f1354a6d.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#delete","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#enabled","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.active","Smart-Home-Devices.4ffbe9f1-4adc-45e2-b00c-1d5cbb171c6f.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#delete","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#enabled","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.powerState","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#delete","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#enabled","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.powerState","Smart-Home-Devices.5b3e8fe1-a2e8-47fc-ac3f-9ae3e3715a59.#query","Smart-Home-Devices.60abe88c-de46-42fb-93a6-a84fbc400e20.#query","Smart-Home-Devices.62173163-c184-4f87-9284-60cb53677d3b.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#delete","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#enabled","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity-reason","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.powerState","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#delete","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#enabled","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#query","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.powerState","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#delete","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#enabled","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#query","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity-reason","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.powerState","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#delete","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#enabled","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#query","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-hue","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-saturation","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorRgb","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureInKelvin","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity-reason","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.powerState","Smart-Home-Devices.7ccaaf08-b038-4713-b431-eeb8500c3790.#query","Smart-Home-Devices.81d78b2e-d706-4162-84cf-44c8e38310da.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#delete","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#enabled","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity-reason","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.powerState","Smart-Home-Devices.888412a0-610a-46d4-9f2b-d260c44ab80b.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#delete","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#enabled","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.active","Smart-Home-Devices.8d73aba0-1cb0-40fd-aca7-a4aae639b1eb.#query","Smart-Home-Devices.92fa9139-72ae-4950-939f-264e9edd93d6.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#delete","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#enabled","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity-reason","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.powerState","Smart-Home-Devices.97fd57e9-16e9-471c-ba20-4629356240d2.#query","Smart-Home-Devices.9a0904f8-5dbe-469e-8b8d-e90d23494a36.#query","Smart-Home-Devices.9f34de1c-8ae8-4308-8d38-c4ac8270c1ad.#query","Smart-Home-Devices.a25e4279-c22e-44ca-b75a-54a54f0b2e3d.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#delete","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#enabled","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.active","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#delete","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#enabled","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#query","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.detectionState","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#delete","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#enabled","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#query","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity-reason","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.powerState","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#delete","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#enabled","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#query","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-hue","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-saturation","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorRgb","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureInKelvin","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity-reason","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.powerState","Smart-Home-Devices.b9aa977c-7173-4465-bc76-9bb35ea78a15.#query","Smart-Home-Devices.bdc08478-6398-4a62-8104-a87e3e841e8b.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#delete","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#enabled","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.active","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#delete","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#enabled","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#query","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity-reason","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.powerState","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#delete","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#enabled","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#query","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity-reason","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.powerState","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#delete","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#enabled","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity-reason","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.powerState","Smart-Home-Devices.c6b5fe24-e2e3-43a5-9625-1f3de08a9117.#query","Smart-Home-Devices.c7767a90-9305-4ad8-a194-b8d11cf068d5.#query","Smart-Home-Devices.c911652c-82d7-47ac-9148-b693698cd15c.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#delete","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#enabled","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity-reason","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.powerState","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#delete","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#enabled","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#query","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.detectionState","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#delete","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#enabled","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#query","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-hue","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-saturation","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorName","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorRgb","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity-reason","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.powerState","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#delete","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#enabled","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#query","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity-reason","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.detectionState","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#delete","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#enabled","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#query","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-hue","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-saturation","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorName","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorRgb","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity-reason","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.powerState","Smart-Home-Devices.d31fdee0-9261-45b2-b762-7601510e5bfa.#query","Smart-Home-Devices.d4c058d6-1454-4364-8044-024fa2b9015b.#query","Smart-Home-Devices.d567e065-a853-4cdb-90fa-637e858dba16.#query","Smart-Home-Devices.d735eab4-e4d9-4e27-9422-c66a413a945d.#query","Smart-Home-Devices.da69e1db-05a1-46b4-8113-b856e832d92a.#query","Smart-Home-Devices.e150b646-c923-4c38-8cd9-2d7dab656b06.#query","Smart-Home-Devices.e198978a-397d-431e-a5c3-014ba600f4b1.#query","Smart-Home-Devices.e2af59b6-6e34-4109-80aa-72e4c9c9531c.#query","Smart-Home-Devices.e4bb56f4-7aa9-447c-8f7b-e4594561ede3.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#delete","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#enabled","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.brightness","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity-reason","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.powerState","Smart-Home-Devices.e6371aa7-760a-4134-bd48-64a0534aa373.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#delete","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#enabled","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity-reason","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.powerState","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#delete","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#enabled","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#query","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity-reason","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.powerState","Smart-Home-Devices.e7b8b085-a5bb-43c9-b058-4f2906769370.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#delete","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#enabled","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-hue","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-saturation","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorRgb","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureInKelvin","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.powerState","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#delete","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#enabled","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#query","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.active","Smart-Home-Devices.e82d4546-299a-4161-b46e-61433fe3ccca.#query","Smart-Home-Devices.e98459e4-06bb-45dd-b5c3-84a2dcba87ff.#query","Smart-Home-Devices.e9bdc49a-b74d-4a31-99fc-7685187590d9.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#delete","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#enabled","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity-reason","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.powerState","Smart-Home-Devices.ead6cf64-5555-4eeb-8861-258621a8d286.#query","Smart-Home-Devices.f0cb5405-3842-4b18-9863-5c031c74a409.#query","Smart-Home-Devices.f3dcc4b4-74eb-45b4-b677-62bd5dbcaa46.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#delete","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#enabled","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-hue","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-saturation","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorRgb","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureInKelvin","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity-reason","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.powerState","Smart-Home-Devices.f7648592-a2b4-4556-8985-53006fce51a7.#query","Smart-Home-Devices.f87eec87-46b6-4cd2-a389-b2407b1229c9.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#delete","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#enabled","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.active","Smart-Home-Devices.fb458fac-5057-47bb-a16c-0e195adfc1c0.#query","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#delete","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#enabled","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.powerState","Smart-Home-Devices.fe7d453e-663d-4092-9069-91ad6c11169e.#query","Smart-Home-Devices.ff1203b1-c4be-4892-aef1-9c7a3aa0d40e.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#includeInAllQuery","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#includeInAllQuery","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#includeInAllQuery","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#includeInAllQuery","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#includeInAllQuery","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#includeInAllQuery","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#includeInAllQuery","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#includeInAllQuery","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#includeInAllQuery","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#includeInAllQuery","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#includeInAllQuery","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#includeInAllQuery","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#includeInAllQuery","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#includeInAllQuery","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#includeInAllQuery","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#includeInAllQuery","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#includeInAllQuery","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#includeInAllQuery","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#includeInAllQuery","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#includeInAllQuery","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#includeInAllQuery","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#includeInAllQuery","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#includeInAllQuery","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#includeInAllQuery","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#includeInAllQuery","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#includeInAllQuery","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#includeInAllQuery","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#includeInAllQuery","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#includeInAllQuery","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.humanPresenceDetectionState","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#query","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#includeInAllQuery","Smart-Home-Devices.2deb04a8-7e12-4a66-b6f1-8b24bf3caa95.humanPresenceDetectionState","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity-reason","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity-reason","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity-reason","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity-reason","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity-reason","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity-reason","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#enabled","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#delete","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.powerState","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureInKelvin","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-hue","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-saturation","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorRgb","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#query","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#includeInAllQuery","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#enabled","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#delete","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.powerState","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.brightness","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity-reason","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#query","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#includeInAllQuery","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#enabled","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#delete","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.powerState","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorName","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-hue","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-saturation","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorRgb","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity-reason","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#query","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#includeInAllQuery","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#enabled","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#delete","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.powerState","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureInKelvin","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-hue","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-saturation","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorRgb","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity-reason","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#query","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#includeInAllQuery","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#enabled","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#delete","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.powerState","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorName","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-hue","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-saturation","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorRgb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity-reason","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#query","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#includeInAllQuery"]
                        2024-11-10 00:19:23.423  - info: alexa2.0 (1139) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2024-11-10 00:19:25.809  - warn: bring.0 (1451) Error on login: Cannot Login: 401 - "{\"message\":\"email password combination not existing\",\"error\":\"unauthorized\",\"error_description\":\"Not authorized to access this resource\",\"errorcode\":200}"
                        2024-11-10 00:19:25.809  - info: bring.0 (1451) [LOGIN] Reconnection in 30 seconds
                        2024-11-10 00:19:26.829  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:26.833  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:26.837  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:26.839  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:26.858  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:26.860  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:26.862  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:26.876  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:27.243  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:27.302  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:27.349  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:27.350  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:27.409  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:27.410  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:27.434  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                        2024-11-10 00:19:27.441  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                        • L Offline
                          lukas8519
                          @Homoran @Thomas-Braun
                          könnt ihr mir nochmal helfen?
                          ich habe in JS meine Blocklys angepasst und dann aus Unwissenheit irgendwas "DEBUG ...." oben über die Menüleiste gestartet.
                          Jetzt ist es so das alles läuft, ich aber nicht mehr über den Browser zum Iobroker komme...
                          danke
                          • L lukas8519
                            danke
                            iob diag
                            anschauen.
                            • L lukas8519
                              danke
                              im Javascript editor?
                              inkognito versuchen
                                iob diag
                                anschauen.
                                lukas8519
                                Script v.2024-10-19
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                 15:05:24 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                                CPU threads: 4
                                Current issues:
                                               Local time: Sun 2024-11-10 15:05:24 CET
                                           Universal time: Sun 2024-11-10 14:05:24 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                lukas
                                HOME=/home/lukas
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        2.1G        695M        1.0M        1.0G        1.6G
                                Swap:            99M          0B         99M
                                Total:          3.9G        2.1G        795M
                                Active iob-Instances:   29
                                         3794 M total memory
                                         2095 M used memory
                                         2434 M active memory
                                          483 M inactive memory
                                          695 M free memory
                                          101 M buffer memory
                                          901 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                top - 15:05:25 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                                Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  4.1 us,  4.1 sy,  0.0 ni, 91.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   3794.3 total,    695.1 free,   2096.1 used,   1003.1 buff/cache
                                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1621.6 avail Mem
                                *** FILESYSTEM ***
                                /dev/root      ext4      235G   15G  211G   7% /
                                [Sun Nov 10 14:45:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Sun Nov 10 14:45:03 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Sun Nov 10 14:45:03 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Sun Nov 10 14:45:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                /var:
                                4.8G    /var/
                                3.7G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
                                3.7G    /var/log
                                739M    /var/cache
                                Archived and active journals take up 3.6G in the file system.
                                4.0K    /opt/iobroker/backups/influxDB_2024_11_10-01_00_25_backupiobroker
                                1.1G    /opt/iobroker/iobroker-data/
                                963M    /opt/iobroker/iobroker-data/files
                                617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                33M     /opt/iobroker/iobroker-data/objects.jsonl
                                28M     /opt/iobroker/iobroker-data/states.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1200)
                                admin:          7.1.5
                                javascript:     8.8.3
                                Adapter State
                                  system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.bring.0                  : bring                 : iobroker                                 - disabled
                                + instance is alive
                                Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                                Objects and States
                                Objects:        26218
                                States:         20791
                                Reading package lists...
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        15664      622/influxd
                                tcp        0      0 192.168.178.92:42010    0.0.0.0:*               LISTEN      1001       16648      1142/io.hm-rpc.1
                                tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15188      1127/io.hm-rpc.0
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14942      885/iobroker.js-con
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14947      885/iobroker.js-con
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13826      536/cupsd
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12059      576/sshd: /usr/sbin
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18349      1729/io.web.0
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17391      1974/io.simple-api.
                                tcp6       0      0 :::8086                 :::*                    LISTEN      116        16428      622/influxd
                                tcp6       0      0 :::3000                 :::*                    LISTEN      117        16489      884/grafana
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13825      536/cupsd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          12061      576/sshd: /usr/sbin
                                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16172      1218/io.tuya.0
                                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16173      1218/io.tuya.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12001      403/avahi-daemon: r
                                udp        0      0 0.0.0.0:50606           0.0.0.0:*                           108        12003      403/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12134      467/dhcpcd
                                udp6       0      0 :::546                  :::*                                0          12212      467/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        12002      403/avahi-daemon: r
                                udp6       0      0 :::49079                :::*                                108        12004      403/avahi-daemon: r
                                2024-11-10 15:06:16.682  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:17.068  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:17.071  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:17.081  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:17.129  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:26.585  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:26.586  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:26.589  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:26.590  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:26.591  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:26.626  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:26.627  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:26.628  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:26.933  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:27.053  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:27.099  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:27.102  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:27.104  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                                2024-11-10 15:06:27.122  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  @lukas8519 sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
                                  inkognito versuchen
                                  lukas8519
                                  ja im Editor...
                                  inkogito Browser?
                                  • L lukas8519
                                    ja im Editor...
                                    inkogito Browser?
                                    @lukas8519
                                    iob start admin
                                    L 1 Antwort Letzte Antwort
                                      @lukas8519
                                      iob start admin
                                      lukas8519
                                      @thomas-braun sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
                                      @lukas8519
                                      iob start admin
                                      Danke!!!!!!!!!!!!
