  4. Homematic IP Cloud Adapter lässt sich nicht installieren
36 Beiträge 3 Kommentatoren 4.5k Aufrufe 2 Beobachtet
    @lukas8519 sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
    Please execute 'iobroker fix' first.
    oder hast du einen Raspi?
    lukas8519
    @homoran jaa
    • L lukas8519
      @homoran jaa
      HomoranH Offline
      HomoranH Offline
      @lukas8519 dann bitte
      curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
      chmod 744 iob_diag.sh
      ./iob_diag.sh
      ausführen
      L 1 Antwort Letzte Antwort
        ./iob_diag.sh
        ausführen
        lukas8519
        Copy text starting here:
        ```bash
                                v.2024-10-26 Raspbian
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.15.61-v8+
              Architecture: arm64
        Kernel:                 aarch64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        Display-Server:         false
        Boot Target:            multi-user.target
        Pending OS-Updates:     320
        Pending iob updates:    40
        Nodejs-Installation:
        nodejs:                 N/A
        /usr/bin/node           v16.19.0
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        /usr/bin/corepack       0.15.1
        Recommended versions are nodejs 20.18.0 and npm 10.8.2
        *** nodejs is NOT correctly installed ***
        Wrong installation path detected. This needs to be fixed.
        Please execute
        iob nodejs-update
        to fix these errors.
        MEMORY:
        Mem:            3.8G        510M        1.8G         35M        1.5G        3.3G
        Swap:            99M        1.0M         98M
        Total:          3.9G        511M        1.9G
        Active iob-Instances:   1
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.24
                                admin                   7.1.5
        ioBroker Status:        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
          system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                25596
        States:                 20358
        Size of iob-Database:
        21M     /opt/iobroker/iobroker-data/objects.jsonl
        5.9M    /opt/iobroker/iobroker-data/states.jsonl
        Unknown release codenamed 'bullseye'. Please check yourself if the Operating System is actively maintained.
        === Mark text until here for copying ===
        Thomas BraunT L 2 Antworten Letzte Antwort
        • L lukas8519
          ```bash
                   Icon name: computer
                Architecture: arm64
          Kernel:                 aarch64
          Userland:               64 bit
          User-ID:                1000
          nodejs:                 N/A
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          Please execute
          iob nodejs-update
          MEMORY:
          Swap:            99M        1.0M         98M
                                  admin                   7.1.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                25596
          States:                 20358
          Hatte ich mir schon gedacht, das da allgemeiner Update-Stau herrscht...
          iob stop
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Wenn die Kiste wieder greifbar ist:
          iob update
          iob upgrade
          iob stop
          iob upgrade self
          iob update
          iob upgrade
          iob nodejs-update
          • L lukas8519
            ```bash
                     Icon name: computer
                  Architecture: arm64
            Kernel:                 aarch64
            Userland:               64 bit
            User-ID:                1000
            nodejs:                 N/A
            /usr/bin/npm            8.19.3
            /usr/bin/npx            8.19.3
            Please execute
            iob nodejs-update
            MEMORY:
            Swap:            99M        1.0M         98M
                                    admin                   7.1.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                25596
            States:                 20358
            lukas8519
            @lukas8519
            jetzt kommt das
            lukas@iobroker:/opt/iobroker $ iob stop
            lukas@iobroker:/opt/iobroker $ sudo apt update
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
            Get:5 https://repos.influxdata.com/debian stretch InRelease [12.9 kB]
            Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
            Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
            Err:5 https://repos.influxdata.com/debian stretch InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            Err:6 https://packages.grafana.com/oss/deb stable InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
            Reading package lists... Done
            W: GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            E: The repository 'https://repos.influxdata.com/debian stretch InRelease' is not signed.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
            lukas@iobroker:/opt/iobroker $ sudo apt full-upgrade
            Calculating upgrade... Done
            The following packages were automatically installed and are no longer required:
              libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
            Use 'sudo apt autoremove' to remove them.
            The following NEW packages will be installed:
              kms++-utils raspi-utils
            The following packages will be upgraded:
              adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez
              bluez-firmware bsdextrautils bsdutils chromium-browser chromium-browser-l10n
              chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client cups-common
              cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils
              cups-ppdc cups-server-common dbus dbus-user-session dbus-x11 debian-archive-keyring
              dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject exfatprogs fdisk
              ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree
              firmware-realtek ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git
              git-man gldriver-test grafana grep gstreamer1.0-alsa gstreamer1.0-plugins-bad
              gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
              gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0
              libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev
              libavahi-common3 libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7
              libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
              libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin
              libc-dev-bin libc-devtools libc-l10n libc6 libc6-dbg libc6-dev libcamera-apps
              libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
              libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0
              libexpat1 libexpat1-dev libext2fs2 libfdisk1 libflac8 libfontembed1 libgbm1
              libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common
              libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
              libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common
              libgssapi-krb5-2 libgstreamer-gl1.0-0 libgstreamer-plugins-bad1.0-0
              libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
              libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0
              libkrb5-3 libkrb5support0 libksba8 liblapack3 libmagic-mgc libmagic1 libmount-dev
              libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1 libnghttp2-14
              libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55
              libprotobuf-lite23 libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5
              libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5widgets5 libqt5xml5
              libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
              librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient
              libsqlite3-0 libss2 libssh-gcrypt-4 libssh2-1 libssl1.1 libswresample3 libswscale5
              libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1 libuuid1
              libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0
              libwebkit2gtk-4.0-37 libwebp6 libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev
              libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev locales logrotate logsave
              lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
              lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers
              mesa-vdpau-drivers mount mutter mutter-common nano ncurses-base ncurses-bin ncurses-term
              net-tools nfs-common nftables nodejs ntfs-3g openssh-client openssh-server
              openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt
              python3-cryptography python3-flask python3-idna python3-kms++ python3-libcamera
              python3-picamera2 python3-pil python3-pkg-resources python3-renderpm python3-reportlab
              python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
              python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel
              raspberrypi-sys-mods raspberrypi-ui-mods raspi-config raspinfo realvnc-vnc-server rfkill
              rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd systemd-sysv
              systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data
              vlc-l10n vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
              vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output vlc-plugin-video-splitter
              vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core xwayland
            321 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
            Need to get 212 MB/700 MB of archives.
            After this operation, 539 MB of additional disk space will be used.
            Do you want to continue? [Y/n] y
            Get:1 http://archive.raspberrypi.org/debian bullseye/main arm64 kms++-utils arm64 0~git20221104~171243+adc05b6-1 [81.4 kB]
            Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 raspinfo all 20230123-1 [2,564 B]
            Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-utils arm64 20230123-1 [41.8 kB]
            Err:4 https://packages.grafana.com/oss/deb stable/main arm64 grafana arm64 10.1.0
              404  Not Found [IP: 2a04:4e42:9::729 443]
            Fetched 126 kB in 0s (422 kB/s)
            E: Failed to fetch https://packages.grafana.com/oss/deb/pool/main/g/grafana/grafana_10.1.0_arm64.deb  404  Not Found [IP: 2a04:4e42:9::729 443]
            E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
            • L lukas8519
              @lukas8519
              jetzt kommt das
              HomoranH Offline
              HomoranH Offline
              das ist ja Steinzeit
              wie alt ist die Installation?
                Halte deine Kiste immer auf einem aktuellen Stand...
                Die hat noch nie ein Update gesehen. Davon ab betreibt man auch keine graphische Oberfläche auf einem Server.
                Was willste mit vlc auf dem Ding?
                Richte grafana und influx neu ein:
                https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                  lukas8519
                  ja die ist schon älter und ich habe tatsächlich nicht viel daran gemacht.
                  Und Grafana benutze ich auch schon lange nicht mehr ...
                  was sind denn nun die extenziell wichtigen schritte?
                  sorry für meine Unwissenheit
                  • L lukas8519
                    Die habe ich dir schon geschrieben.
                    • L Offline
                      lukas8519
                      @Homoran, @Thomas-Braun,
                      ich bin nun wieder up to date und alles läuft, inklusive der HmIP Installation.
                      Ich danke euch für euern Support und eure Geduld.
                      Danke das Ihr durch euer Engagement auch Leuten wie mir helft sich ein wenig zu recht zu finden und am Iobroker teil haben zu können!
                      Danke!
                      • L lukas8519
                        Danke!
                        @lukas8519
                        Dann lass jetzt mal die Langfassung von
                        iob diag
                        sehen.
                          @lukas8519
                          iob diag
                          sehen.
                          lukas8519
                                                  v.2024-10-19
                                   Icon name: computer
                                Architecture: arm64
                          Kernel:                 aarch64
                          Userland:               64 bit
                          User-ID:                1000
                          Pending OS-Updates:     0
                          Pending iob updates:    28
                          This system needs to be REBOOTED NOW!
                          /usr/bin/nodejs         v20.18.0
                          /usr/bin/node           v20.18.0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          /usr/bin/corepack       0.29.3
                          nodeJS installation is correct
                          MEMORY:
                          Mem:            3.8G        2.4G        412M         35M        964M        1.2G
                          Swap:            99M         56M         43M
                          Total:          3.9G        2.5G        456M
                          Active iob-Instances:   31
                          Upgrade policy: none
                          ioBroker Core:          js-controller           6.0.11
                                                  admin                   7.1.5
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                26089
                          States:                 20688
                          24M     /opt/iobroker/iobroker-data/objects.jsonl
                          37M     /opt/iobroker/iobroker-data/states.jsonl
                          Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                          • L lukas8519
                                                    v.2024-10-19
                                     Icon name: computer
                                  Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               64 bit
                            User-ID:                1000
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            MEMORY:
                            Swap:            99M         56M         43M
                                                    admin                   7.1.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                26089
                            States:                 20688
                            @lukas8519
                            Ich wollte die Langfassung sehen, nicht die Zusammenfassung.
                            Nach einem REBOOT:
                              @lukas8519
                              Nach einem REBOOT:
                              lukas8519
                              @thomas-braun habs gemerkt, moment
                              • L lukas8519
                                @lukas8519
                                Und das bringst du auch auf 0:
                                  @lukas8519
                                  lukas8519
                                  um die letzten 6 Updates kümmere ich mich morgen.
                                  Script v.2024-10-19
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                              Kernel: Linux 6.1.21-v8+
                                        Architecture: arm64
                                  OS is similar to:
                                  Model           : Raspberry Pi 4 Model B Rev 1.1
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                  Systemuptime and Load:
                                   00:18:01 up 4 min,  2 users,  load average: 3.97, 2.63, 1.17
                                  CPU threads: 4
                                  *** LIFE CYCLE STATUS ***
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                  *** TIME AND TIMEZONES ***
                                                 Local time: Sun 2024-11-10 00:18:01 CET
                                             Universal time: Sat 2024-11-09 23:18:01 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** Users and Groups ***
                                  User that called 'iob diag':
                                  lukas
                                  HOME=/home/lukas
                                  GROUPS=lukas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  *** DISPLAY-SERVER SETUP ***
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            3.8G        2.0G        821M        1.0M        943M        1.7G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        2.0G        921M
                                           3794 M total memory
                                           2028 M used memory
                                           2408 M active memory
                                            415 M inactive memory
                                            821 M free memory
                                             71 M buffer memory
                                            872 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  top - 00:18:02 up 4 min,  2 users,  load average: 3.73, 2.60, 1.17
                                  Tasks: 208 total,   1 running, 207 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  9.7 us,  4.2 sy,  0.0 ni, 86.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   3794.3 total,    821.5 free,   2028.4 used,    944.4 buff/cache
                                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1681.2 avail Mem
                                  *** FAILED SERVICES ***
                                  0 loaded units listed.
                                  *** DMESG CRITICAL ERRORS ***
                                  No critical errors detected
                                  *** FILESYSTEM ***
                                  /dev/root      ext4      235G   14G  212G   6% /
                                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                  tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                  /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                  tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                  [Sun Nov 10 00:13:06 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                  [Sun Nov 10 00:13:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Sun Nov 10 00:13:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [Sun Nov 10 00:13:10 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  Show mounted filesystems:
                                  TARGET  SOURCE         FSTYPE OPTIONS
                                  /       /dev/mmcblk0p2 ext4   rw,noatime
                                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  4.8G    /var/
                                  3.7G    /var/log
                                  3.6G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
                                  739M    /var/cache
                                  Archived and active journals take up 3.5G in the file system.
                                  /opt/iobroker/backups:
                                  1.7G    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  548M    /opt/iobroker/iobroker-data/
                                  402M    /opt/iobroker/iobroker-data/files
                                  80M     /opt/iobroker/iobroker-data/backup-objects
                                  67M     /opt/iobroker/iobroker-data/files/echarts.admin
                                  61M     /opt/iobroker/iobroker-data/files/echarts
                                  38M     /opt/iobroker/iobroker-data/states.jsonl
                                  28M     /opt/iobroker/iobroker-data/objects.jsonl
                                  26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                                  26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                  USB-Devices by-id:
                                  /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                  Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                  *** NodeJS-Installation ***
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Installed: 20.18.0-1nodesource1
                                    Candidate: 20.18.0-1nodesource1
                                    Version table:
                                   *** 20.18.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                       20.17.0-1nodesource1 1001
                                       20.16.0-1nodesource1 1001
                                       20.15.1-1nodesource1 1001
                                       20.15.0-1nodesource1 1001
                                       20.14.0-1nodesource1 1001
                                       20.13.1-1nodesource1 1001
                                       20.13.0-1nodesource1 1001
                                       20.12.2-1nodesource1 1001
                                       20.12.1-1nodesource1 1001
                                       20.12.0-1nodesource1 1001
                                       20.11.1-1nodesource1 1001
                                       20.11.0-1nodesource1 1001
                                       20.10.0-1nodesource1 1001
                                       20.9.0-1nodesource1 1001
                                       20.8.1-1nodesource1 1001
                                       20.8.0-1nodesource1 1001
                                       20.7.0-1nodesource1 1001
                                       20.6.1-1nodesource1 1001
                                       20.6.0-1nodesource1 1001
                                       20.5.1-1nodesource1 1001
                                       20.5.0-1nodesource1 1001
                                       20.4.0-1nodesource1 1001
                                       20.3.1-1nodesource1 1001
                                       20.3.0-1nodesource1 1001
                                       20.2.0-1nodesource1 1001
                                       20.1.0-1nodesource1 1001
                                       20.0.0-1nodesource1 1001
                                       12.22.12~dfsg-1~deb11u5 500
                                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                       12.22.12~dfsg-1~deb11u4 500
                                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                  No problems detected
                                  Errors in npm tree: 0
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 289)
                                  Core adapters versions
                                  js-controller:  6.0.11
                                  admin:          7.1.5
                                  javascript:     7.8.0
                                  nodejs modules from github:     1
                                  | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                  Adapter State
                                  + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                                  + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
                                  + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                  + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                                  + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled
                                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                    system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                  + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
                                  + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                    system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                  + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                  + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                                  + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                  + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                  + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                                    system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
                                  + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                                  + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
                                  + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
                                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                  + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                    system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                    system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                    system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
                                    system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 - disabled
                                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                  + instance is alive
                                  ioBroker-Repositories
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                  Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
                                  Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                  Adapter    "countdown"    : 2.3.0    , installed 2.3.0
                                  Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                                  Adapter    "device-reminder": 3.1.2  , installed 1.2.9  [Updatable]
                                  Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                  Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                  Adapter    "fullybrowser" : 3.0.12   , installed 2.1.1  [Updatable]
                                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                  Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
                                  Adapter    "hmip"         : 1.24.3   , installed 1.24.3
                                  Adapter    "hue"          : 3.12.0   , installed 3.12.0
                                  Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                  Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
                                  Controller "js-controller": 6.0.11   , installed 6.0.11
                                  Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                  Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                                  Adapter    "rpi2"         : 2.2.1    , installed 1.3.1  [Updatable]
                                  Adapter    "samsung"      : 0.6.1    , installed 0.6.1
                                  Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
                                  Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                  Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                  Adapter    "web"          : 6.2.5    , installed 6.2.5
                                  Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                  Adapter    "withings"     : 0.0.13   , installed 0.0.13
                                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                  Objects and States
                                  Objects:        26237
                                  States:         20884
                                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                  Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
                                  Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:6 https://repos.influxdata.com/debian stable InRelease
                                  Hit:7 https://apt.grafana.com stable InRelease
                                  Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        12227      623/influxd
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1818       581/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15599      914/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15605      914/iobroker.js-con
                                  tcp        0      0 192.168.178.92:42011    0.0.0.0:*               LISTEN      1001       15855      1203/io.hm-rpc.1
                                  tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15823      1184/io.hm-rpc.0
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14199      545/cupsd
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      116        16444      623/influxd
                                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18905      1797/io.simple-api.
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17521      1029/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18296      1731/io.web.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          1820       581/sshd: /usr/sbin
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14198      545/cupsd
                                  tcp6       0      0 :::3000                 :::*                    LISTEN      117        15592      913/grafana
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14656      476/dhcpcd
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16054      1334/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16055      1334/io.tuya.0
                                  udp        0      0 0.0.0.0:35422           0.0.0.0:*                           108        14136      401/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14134      401/avahi-daemon: r
                                  udp6       0      0 :::41151                :::*                                108        14137      401/avahi-daemon: r
                                  udp6       0      0 :::546                  :::*                                0          14697      476/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        14135      401/avahi-daemon: r
                                  2024-11-10 00:19:17.540  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:17.541  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:17.542  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:17.597  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:21.597  - info: alexa2.0 (1139) Subscribing to states...
                                  2024-11-10 00:19:21.608  - info: alexa2.0 (1139) Deleting the following states: ["Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7","Smart-Home-Devices.003aedb7-567e-4c34-a57c-a07ff842976c.#query","Smart-Home-Devices.012f1123-14fe-45de-b7ad-e96d7d2418f5.#query","Smart-Home-Devices.0373ad50-6d67-4d7d-8cf1-25c5ca3a8a6f.#query","Smart-Home-Devices.0558f2c7-04f3-466b-bc3d-5eeb9537fc83.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#delete","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#enabled","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.active","Smart-Home-Devices.0a175031-bd4e-467f-bcf7-a317bfc179eb.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#delete","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#enabled","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity-reason","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.powerState","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#delete","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#enabled","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#query","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-hue","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-saturation","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorRgb","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureInKelvin","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity-reason","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.powerState","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#delete","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#enabled","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#query","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity-reason","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.powerState","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#delete","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#enabled","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#query","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.active","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#delete","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#enabled","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#query","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.brightness","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity-reason","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.powerState","Smart-Home-Devices.196e2f4f-23ff-4419-9398-55823800ccae.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#delete","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#enabled","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-hue","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-saturation","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorRgb","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureInKelvin","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.powerState","Smart-Home-Devices.1eaa8074-65f2-4b2f-8aa0-18a0bd21252a.#query","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#delete","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#enabled","Smart-Home-Devices.2ad5f69c-0316-4394-b033-ea4f1d17a11a.#query","Smart-Home-Devices.2b7f4876-d82c-42d6-b302-20a0ae5d5d39.#query","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#delete","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#enabled","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#query","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-hue","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-saturation","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorRgb","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureInKelvin","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.powerState","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#delete","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#enabled","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#query","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-hue","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-saturation","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorName","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorRgb","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity-reason","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.powerState","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#delete","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#enabled","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#query","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-hue","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-saturation","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorRgb","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureInKelvin","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.powerState","Smart-Home-Devices.3ac22223-0447-4d99-b624-1ed607a5848f.#query","Smart-Home-Devices.414afebe-9a0c-4dfb-a60d-d69324daa9ba.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#delete","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#enabled","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity-reason","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.powerState","Smart-Home-Devices.41d1bfc2-f0c9-41f5-993d-7f3090c0c015.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#delete","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#enabled","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity-reason","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.powerState","Smart-Home-Devices.45734c42-2ddc-4bdb-b4fb-053417c9fb29.#query","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#delete","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#enabled","Smart-Home-Devices.4843643a-6b91-48c5-9b27-21b8f1354a6d.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#delete","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#enabled","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.active","Smart-Home-Devices.4ffbe9f1-4adc-45e2-b00c-1d5cbb171c6f.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#delete","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#enabled","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.powerState","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#delete","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#enabled","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.powerState","Smart-Home-Devices.5b3e8fe1-a2e8-47fc-ac3f-9ae3e3715a59.#query","Smart-Home-Devices.60abe88c-de46-42fb-93a6-a84fbc400e20.#query","Smart-Home-Devices.62173163-c184-4f87-9284-60cb53677d3b.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#delete","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#enabled","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity-reason","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.powerState","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#delete","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#enabled","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#query","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.powerState","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#delete","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#enabled","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#query","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity-reason","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.powerState","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#delete","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#enabled","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#query","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-hue","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-saturation","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorRgb","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureInKelvin","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity-reason","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.powerState","Smart-Home-Devices.7ccaaf08-b038-4713-b431-eeb8500c3790.#query","Smart-Home-Devices.81d78b2e-d706-4162-84cf-44c8e38310da.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#delete","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#enabled","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity-reason","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.powerState","Smart-Home-Devices.888412a0-610a-46d4-9f2b-d260c44ab80b.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#delete","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#enabled","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.active","Smart-Home-Devices.8d73aba0-1cb0-40fd-aca7-a4aae639b1eb.#query","Smart-Home-Devices.92fa9139-72ae-4950-939f-264e9edd93d6.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#delete","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#enabled","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity-reason","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.powerState","Smart-Home-Devices.97fd57e9-16e9-471c-ba20-4629356240d2.#query","Smart-Home-Devices.9a0904f8-5dbe-469e-8b8d-e90d23494a36.#query","Smart-Home-Devices.9f34de1c-8ae8-4308-8d38-c4ac8270c1ad.#query","Smart-Home-Devices.a25e4279-c22e-44ca-b75a-54a54f0b2e3d.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#delete","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#enabled","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.active","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#delete","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#enabled","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#query","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.detectionState","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#delete","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#enabled","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#query","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity-reason","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.powerState","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#delete","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#enabled","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#query","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-hue","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-saturation","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorRgb","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureInKelvin","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity-reason","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.powerState","Smart-Home-Devices.b9aa977c-7173-4465-bc76-9bb35ea78a15.#query","Smart-Home-Devices.bdc08478-6398-4a62-8104-a87e3e841e8b.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#delete","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#enabled","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.active","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#delete","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#enabled","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#query","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity-reason","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.powerState","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#delete","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#enabled","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#query","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity-reason","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.powerState","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#delete","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#enabled","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity-reason","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.powerState","Smart-Home-Devices.c6b5fe24-e2e3-43a5-9625-1f3de08a9117.#query","Smart-Home-Devices.c7767a90-9305-4ad8-a194-b8d11cf068d5.#query","Smart-Home-Devices.c911652c-82d7-47ac-9148-b693698cd15c.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#delete","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#enabled","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity-reason","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.powerState","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#delete","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#enabled","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#query","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.detectionState","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#delete","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#enabled","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#query","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-hue","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-saturation","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorName","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorRgb","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity-reason","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.powerState","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#delete","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#enabled","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#query","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity-reason","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.detectionState","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#delete","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#enabled","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#query","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-hue","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-saturation","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorName","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorRgb","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity-reason","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.powerState","Smart-Home-Devices.d31fdee0-9261-45b2-b762-7601510e5bfa.#query","Smart-Home-Devices.d4c058d6-1454-4364-8044-024fa2b9015b.#query","Smart-Home-Devices.d567e065-a853-4cdb-90fa-637e858dba16.#query","Smart-Home-Devices.d735eab4-e4d9-4e27-9422-c66a413a945d.#query","Smart-Home-Devices.da69e1db-05a1-46b4-8113-b856e832d92a.#query","Smart-Home-Devices.e150b646-c923-4c38-8cd9-2d7dab656b06.#query","Smart-Home-Devices.e198978a-397d-431e-a5c3-014ba600f4b1.#query","Smart-Home-Devices.e2af59b6-6e34-4109-80aa-72e4c9c9531c.#query","Smart-Home-Devices.e4bb56f4-7aa9-447c-8f7b-e4594561ede3.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#delete","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#enabled","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.brightness","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity-reason","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.powerState","Smart-Home-Devices.e6371aa7-760a-4134-bd48-64a0534aa373.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#delete","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#enabled","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity-reason","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.powerState","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#delete","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#enabled","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#query","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity-reason","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.powerState","Smart-Home-Devices.e7b8b085-a5bb-43c9-b058-4f2906769370.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#delete","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#enabled","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-hue","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-saturation","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorRgb","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureInKelvin","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.powerState","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#delete","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#enabled","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#query","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.active","Smart-Home-Devices.e82d4546-299a-4161-b46e-61433fe3ccca.#query","Smart-Home-Devices.e98459e4-06bb-45dd-b5c3-84a2dcba87ff.#query","Smart-Home-Devices.e9bdc49a-b74d-4a31-99fc-7685187590d9.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#delete","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#enabled","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity-reason","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.powerState","Smart-Home-Devices.ead6cf64-5555-4eeb-8861-258621a8d286.#query","Smart-Home-Devices.f0cb5405-3842-4b18-9863-5c031c74a409.#query","Smart-Home-Devices.f3dcc4b4-74eb-45b4-b677-62bd5dbcaa46.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#delete","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#enabled","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-hue","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-saturation","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorRgb","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureInKelvin","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity-reason","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.powerState","Smart-Home-Devices.f7648592-a2b4-4556-8985-53006fce51a7.#query","Smart-Home-Devices.f87eec87-46b6-4cd2-a389-b2407b1229c9.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#delete","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#enabled","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.active","Smart-Home-Devices.fb458fac-5057-47bb-a16c-0e195adfc1c0.#query","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#delete","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#enabled","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.powerState","Smart-Home-Devices.fe7d453e-663d-4092-9069-91ad6c11169e.#query","Smart-Home-Devices.ff1203b1-c4be-4892-aef1-9c7a3aa0d40e.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#includeInAllQuery","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#includeInAllQuery","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#includeInAllQuery","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#includeInAllQuery","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#includeInAllQuery","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#includeInAllQuery","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#includeInAllQuery","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#includeInAllQuery","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#includeInAllQuery","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#includeInAllQuery","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#includeInAllQuery","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#includeInAllQuery","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#includeInAllQuery","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#includeInAllQuery","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#includeInAllQuery","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#includeInAllQuery","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#includeInAllQuery","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#includeInAllQuery","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#includeInAllQuery","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#includeInAllQuery","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#includeInAllQuery","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#includeInAllQuery","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#includeInAllQuery","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#includeInAllQuery","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#includeInAllQuery","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#includeInAllQuery","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#includeInAllQuery","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#includeInAllQuery","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#includeInAllQuery","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.humanPresenceDetectionState","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#query","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#includeInAllQuery","Smart-Home-Devices.2deb04a8-7e12-4a66-b6f1-8b24bf3caa95.humanPresenceDetectionState","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity-reason","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity-reason","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity-reason","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity-reason","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity-reason","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity-reason","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#enabled","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#delete","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.powerState","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureInKelvin","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-hue","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-saturation","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorRgb","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#query","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#includeInAllQuery","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#enabled","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#delete","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.powerState","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.brightness","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity-reason","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#query","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#includeInAllQuery","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#enabled","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#delete","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.powerState","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorName","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-hue","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-saturation","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorRgb","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity-reason","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#query","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#includeInAllQuery","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#enabled","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#delete","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.powerState","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureInKelvin","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-hue","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-saturation","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorRgb","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity-reason","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#query","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#includeInAllQuery","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#enabled","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#delete","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.powerState","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorName","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-hue","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-saturation","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorRgb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity-reason","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#query","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#includeInAllQuery"]
                                  2024-11-10 00:19:23.423  - info: alexa2.0 (1139) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                  2024-11-10 00:19:25.809  - warn: bring.0 (1451) Error on login: Cannot Login: 401 - "{\"message\":\"email password combination not existing\",\"error\":\"unauthorized\",\"error_description\":\"Not authorized to access this resource\",\"errorcode\":200}"
                                  2024-11-10 00:19:25.809  - info: bring.0 (1451) [LOGIN] Reconnection in 30 seconds
                                  2024-11-10 00:19:26.829  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:26.833  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:26.837  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:26.839  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:26.858  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:26.860  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:26.862  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:26.876  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:27.243  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:27.302  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:27.349  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:27.350  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:27.409  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:27.410  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:27.434  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  2024-11-10 00:19:27.441  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                                  • L Offline
                                    lukas8519
                                    @Homoran @Thomas-Braun
                                    könnt ihr mir nochmal helfen?
                                    ich habe in JS meine Blocklys angepasst und dann aus Unwissenheit irgendwas "DEBUG ...." oben über die Menüleiste gestartet.
                                    Jetzt ist es so das alles läuft, ich aber nicht mehr über den Browser zum Iobroker komme...
                                    danke
                                    • L lukas8519
                                      danke
                                      @lukas8519 sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
                                      iob diag
                                      anschauen.
                                      L 1 Antwort Letzte Antwort
                                      • L lukas8519
                                        danke
                                        HomoranH Offline
                                        HomoranH Offline
                                        im Javascript editor?
                                        inkognito versuchen
                                          iob diag
                                          anschauen.
                                          lukas8519
                                          Script v.2024-10-19
                                          *** BASE SYSTEM ***
                                             Static hostname: iobroker
                                                   Icon name: computer
                                            Operating System: Debian GNU/Linux 11 (bullseye)
                                                Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                           15:05:24 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                                          CPU threads: 4
                                          Current issues:
                                                         Local time: Sun 2024-11-10 15:05:24 CET
                                                     Universal time: Sun 2024-11-10 14:05:24 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          lukas
                                          HOME=/home/lukas
                                          iobroker
                                          HOME=/home/iobroker
                                          Display-Server: false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            3.8G        2.1G        695M        1.0M        1.0G        1.6G
                                          Swap:            99M          0B         99M
                                          Total:          3.9G        2.1G        795M
                                          Active iob-Instances:   29
                                                   3794 M total memory
                                                   2095 M used memory
                                                   2434 M active memory
                                                    483 M inactive memory
                                                    695 M free memory
                                                    101 M buffer memory
                                                    901 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          top - 15:05:25 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                                          Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  4.1 us,  4.1 sy,  0.0 ni, 91.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   3794.3 total,    695.1 free,   2096.1 used,   1003.1 buff/cache
                                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1621.6 avail Mem
                                          *** FILESYSTEM ***
                                          /dev/root      ext4      235G   15G  211G   7% /
                                          [Sun Nov 10 14:45:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                          [Sun Nov 10 14:45:03 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Sun Nov 10 14:45:03 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Sun Nov 10 14:45:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          /var:
                                          4.8G    /var/
                                          3.7G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
                                          3.7G    /var/log
                                          739M    /var/cache
                                          Archived and active journals take up 3.6G in the file system.
                                          4.0K    /opt/iobroker/backups/influxDB_2024_11_10-01_00_25_backupiobroker
                                          1.1G    /opt/iobroker/iobroker-data/
                                          963M    /opt/iobroker/iobroker-data/files
                                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                          33M     /opt/iobroker/iobroker-data/objects.jsonl
                                          28M     /opt/iobroker/iobroker-data/states.jsonl
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1200)
                                          admin:          7.1.5
                                          javascript:     8.8.3
                                          Adapter State
                                            system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            system.adapter.bring.0                  : bring                 : iobroker                                 - disabled
                                          + instance is alive
                                          Active repo(s): stable
                                          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                          Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                                          Objects and States
                                          Objects:        26218
                                          States:         20791
                                          Reading package lists...
                                          Pending Updates: 0
                                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        15664      622/influxd
                                          tcp        0      0 192.168.178.92:42010    0.0.0.0:*               LISTEN      1001       16648      1142/io.hm-rpc.1
                                          tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15188      1127/io.hm-rpc.0
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14942      885/iobroker.js-con
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14947      885/iobroker.js-con
                                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13826      536/cupsd
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12059      576/sshd: /usr/sbin
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18349      1729/io.web.0
                                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17391      1974/io.simple-api.
                                          tcp6       0      0 :::8086                 :::*                    LISTEN      116        16428      622/influxd
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      117        16489      884/grafana
                                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13825      536/cupsd
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          12061      576/sshd: /usr/sbin
                                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16172      1218/io.tuya.0
                                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16173      1218/io.tuya.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12001      403/avahi-daemon: r
                                          udp        0      0 0.0.0.0:50606           0.0.0.0:*                           108        12003      403/avahi-daemon: r
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12134      467/dhcpcd
                                          udp6       0      0 :::546                  :::*                                0          12212      467/dhcpcd
                                          udp6       0      0 :::5353                 :::*                                108        12002      403/avahi-daemon: r
                                          udp6       0      0 :::49079                :::*                                108        12004      403/avahi-daemon: r
                                          2024-11-10 15:06:16.682  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:17.068  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:17.071  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:17.081  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:17.129  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:26.585  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:26.586  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:26.589  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:26.590  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:26.591  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:26.626  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:26.627  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:26.628  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:26.933  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:27.053  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:27.099  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:27.102  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:27.104  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                                          2024-11-10 15:06:27.122  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
