  4. Homematic IP Cloud Adapter lässt sich nicht installieren
36 Beiträge 3 Kommentatoren 4.5k Aufrufe 2 Beobachtet
    @lukas8519
    Ich wollte die Langfassung sehen, nicht die Zusammenfassung.
    Nach einem REBOOT:
    This system needs to be REBOOTED NOW!
    lukas8519
    @thomas-braun habs gemerkt, moment
    • L lukas8519
      @lukas8519
      Und das bringst du auch auf 0:
      Pending iob updates: 28
      L 1 Antwort Letzte Antwort
        @lukas8519
        lukas8519
        um die letzten 6 Updates kümmere ich mich morgen.
        Script v.2024-10-19
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         00:18:01 up 4 min,  2 users,  load average: 3.97, 2.63, 1.17
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2024-11-10 00:18:01 CET
                   Universal time: Sat 2024-11-09 23:18:01 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        lukas
        HOME=/home/lukas
        GROUPS=lukas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        2.0G        821M        1.0M        943M        1.7G
        Swap:            99M          0B         99M
        Total:          3.9G        2.0G        921M
        Active iob-Instances:   31
                 3794 M total memory
                 2028 M used memory
                 2408 M active memory
                  415 M inactive memory
                  821 M free memory
                   71 M buffer memory
                  872 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 00:18:02 up 4 min,  2 users,  load average: 3.73, 2.60, 1.17
        Tasks: 208 total,   1 running, 207 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  9.7 us,  4.2 sy,  0.0 ni, 86.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3794.3 total,    821.5 free,   2028.4 used,    944.4 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1681.2 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4      235G   14G  212G   6% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
        [Sun Nov 10 00:13:06 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sun Nov 10 00:13:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Nov 10 00:13:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Nov 10 00:13:10 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        4.8G    /var/
        3.7G    /var/log
        3.6G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
        739M    /var/cache
        Archived and active journals take up 3.5G in the file system.
        /opt/iobroker/backups:
        1.7G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        548M    /opt/iobroker/iobroker-data/
        402M    /opt/iobroker/iobroker-data/files
        80M     /opt/iobroker/iobroker-data/backup-objects
        67M     /opt/iobroker/iobroker-data/files/echarts.admin
        61M     /opt/iobroker/iobroker-data/files/echarts
        38M     /opt/iobroker/iobroker-data/states.jsonl
        28M     /opt/iobroker/iobroker-data/objects.jsonl
        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.0
        /usr/bin/node           v20.18.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.18.0-1nodesource1
          Candidate: 20.18.0-1nodesource1
          Version table:
         *** 20.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u5 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 289)
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.5
        javascript:     7.8.0
        nodejs modules from github:     1
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        Adapter State
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
        + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
        + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
        + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
          system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
        + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
          system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 - disabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "countdown"    : 2.3.0    , installed 2.3.0
        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
        Adapter    "device-reminder": 3.1.2  , installed 1.2.9  [Updatable]
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
        Adapter    "fullybrowser" : 3.0.12   , installed 2.1.1  [Updatable]
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
        Adapter    "hmip"         : 1.24.3   , installed 1.24.3
        Adapter    "hue"          : 3.12.0   , installed 3.12.0
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
        Adapter    "rpi2"         : 2.2.1    , installed 1.3.1  [Updatable]
        Adapter    "samsung"      : 0.6.1    , installed 0.6.1
        Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "withings"     : 0.0.13   , installed 0.0.13
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        26237
        States:         20884
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:6 https://repos.influxdata.com/debian stable InRelease
        Hit:7 https://apt.grafana.com stable InRelease
        Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        12227      623/influxd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1818       581/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15599      914/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15605      914/iobroker.js-con
        tcp        0      0 192.168.178.92:42011    0.0.0.0:*               LISTEN      1001       15855      1203/io.hm-rpc.1
        tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15823      1184/io.hm-rpc.0
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14199      545/cupsd
        tcp6       0      0 :::8086                 :::*                    LISTEN      116        16444      623/influxd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18905      1797/io.simple-api.
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17521      1029/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18296      1731/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1820       581/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14198      545/cupsd
        tcp6       0      0 :::3000                 :::*                    LISTEN      117        15592      913/grafana
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14656      476/dhcpcd
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16054      1334/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16055      1334/io.tuya.0
        udp        0      0 0.0.0.0:35422           0.0.0.0:*                           108        14136      401/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14134      401/avahi-daemon: r
        udp6       0      0 :::41151                :::*                                108        14137      401/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14697      476/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14135      401/avahi-daemon: r
        2024-11-10 00:19:17.540  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:17.541  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:17.542  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:17.597  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:21.597  - info: alexa2.0 (1139) Subscribing to states...
        2024-11-10 00:19:21.608  - info: alexa2.0 (1139) Deleting the following states: ["Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7","Smart-Home-Devices.003aedb7-567e-4c34-a57c-a07ff842976c.#query","Smart-Home-Devices.012f1123-14fe-45de-b7ad-e96d7d2418f5.#query","Smart-Home-Devices.0373ad50-6d67-4d7d-8cf1-25c5ca3a8a6f.#query","Smart-Home-Devices.0558f2c7-04f3-466b-bc3d-5eeb9537fc83.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#delete","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#enabled","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.#query","Smart-Home-Devices.078c1846-3445-4e93-b22f-fb5b58efbc11.active","Smart-Home-Devices.0a175031-bd4e-467f-bcf7-a317bfc179eb.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#delete","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#enabled","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.#query","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.connectivity-reason","Smart-Home-Devices.0d88d6f3-a962-415c-bfe3-3a6da99ad7dd.powerState","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#delete","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#enabled","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#query","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-brightness","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-hue","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.color-saturation","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorRgb","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureInKelvin","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.colorTemperatureName","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.connectivity-reason","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.powerState","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#delete","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#enabled","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.#query","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.connectivity-reason","Smart-Home-Devices.1134a034-94c8-4e90-a1eb-f053c024baed.powerState","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#delete","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#enabled","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.#query","Smart-Home-Devices.1359ccf7-642e-4043-a69b-f87985a4cae5.active","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#delete","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#enabled","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#query","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.brightness","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.connectivity-reason","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.powerState","Smart-Home-Devices.196e2f4f-23ff-4419-9398-55823800ccae.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#delete","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#enabled","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#query","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-brightness","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-hue","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.color-saturation","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorRgb","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureInKelvin","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.colorTemperatureName","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.powerState","Smart-Home-Devices.1eaa8074-65f2-4b2f-8aa0-18a0bd21252a.#query","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#delete","Smart-Home-Devices.2365550c-efc4-4cc7-a229-22b065ec68ce.#enabled","Smart-Home-Devices.2ad5f69c-0316-4394-b033-ea4f1d17a11a.#query","Smart-Home-Devices.2b7f4876-d82c-42d6-b302-20a0ae5d5d39.#query","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity","Smart-Home-Devices.2c6fad19-b07d-4de8-8170-8fd8c8965410.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#delete","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#enabled","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#query","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-brightness","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-hue","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.color-saturation","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorRgb","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureInKelvin","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.colorTemperatureName","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.connectivity-reason","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.powerState","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#delete","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#enabled","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#query","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-brightness","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-hue","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.color-saturation","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorName","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.colorRgb","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.connectivity-reason","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.powerState","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#delete","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#enabled","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#query","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-brightness","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-hue","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.color-saturation","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorRgb","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureInKelvin","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.colorTemperatureName","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.powerState","Smart-Home-Devices.3ac22223-0447-4d99-b624-1ed607a5848f.#query","Smart-Home-Devices.414afebe-9a0c-4dfb-a60d-d69324daa9ba.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#delete","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#enabled","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#query","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.connectivity-reason","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.powerState","Smart-Home-Devices.41d1bfc2-f0c9-41f5-993d-7f3090c0c015.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#delete","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#enabled","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.#query","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.connectivity-reason","Smart-Home-Devices.41dba5b5-3d26-4475-b620-d6d765ec471b.powerState","Smart-Home-Devices.45734c42-2ddc-4bdb-b4fb-053417c9fb29.#query","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#delete","Smart-Home-Devices.46e74f1f-41ce-4786-ba40-c0cc90b1e807.#enabled","Smart-Home-Devices.4843643a-6b91-48c5-9b27-21b8f1354a6d.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#delete","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#enabled","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.#query","Smart-Home-Devices.48cd21bd-500a-40d4-9dd5-31addf4683a4.active","Smart-Home-Devices.4ffbe9f1-4adc-45e2-b00c-1d5cbb171c6f.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#delete","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#enabled","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#query","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.powerState","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#delete","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.#enabled","Smart-Home-Devices.575e928e-3254-43b7-ae4c-8ebc940db9ea.powerState","Smart-Home-Devices.5b3e8fe1-a2e8-47fc-ac3f-9ae3e3715a59.#query","Smart-Home-Devices.60abe88c-de46-42fb-93a6-a84fbc400e20.#query","Smart-Home-Devices.62173163-c184-4f87-9284-60cb53677d3b.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#delete","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#enabled","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#query","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.connectivity-reason","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.powerState","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#delete","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#enabled","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#query","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.powerState","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#delete","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#enabled","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#query","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.connectivity-reason","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.powerState","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#delete","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#enabled","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#query","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-brightness","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-hue","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.color-saturation","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorRgb","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureInKelvin","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.colorTemperatureName","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.connectivity-reason","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.powerState","Smart-Home-Devices.7ccaaf08-b038-4713-b431-eeb8500c3790.#query","Smart-Home-Devices.81d78b2e-d706-4162-84cf-44c8e38310da.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#delete","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#enabled","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#query","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.connectivity-reason","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.powerState","Smart-Home-Devices.888412a0-610a-46d4-9f2b-d260c44ab80b.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#delete","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#enabled","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.#query","Smart-Home-Devices.8c118437-fb68-46d4-a7e7-71a2eb6aed46.active","Smart-Home-Devices.8d73aba0-1cb0-40fd-aca7-a4aae639b1eb.#query","Smart-Home-Devices.92fa9139-72ae-4950-939f-264e9edd93d6.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#delete","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#enabled","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.#query","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.connectivity-reason","Smart-Home-Devices.93183344-98be-4b14-be52-3a61524b5106.powerState","Smart-Home-Devices.97fd57e9-16e9-471c-ba20-4629356240d2.#query","Smart-Home-Devices.9a0904f8-5dbe-469e-8b8d-e90d23494a36.#query","Smart-Home-Devices.9f34de1c-8ae8-4308-8d38-c4ac8270c1ad.#query","Smart-Home-Devices.a25e4279-c22e-44ca-b75a-54a54f0b2e3d.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#delete","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#enabled","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.#query","Smart-Home-Devices.a6bc446d-4525-46f9-bcfb-2f723d09b6cf.active","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#delete","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#enabled","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#query","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.detectionState","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#delete","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#enabled","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.#query","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.connectivity-reason","Smart-Home-Devices.a9e73c22-f2c4-4d17-bd64-dae40d3d615c.powerState","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#delete","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#enabled","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#query","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-brightness","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-hue","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.color-saturation","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorRgb","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureInKelvin","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.colorTemperatureName","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.connectivity-reason","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.powerState","Smart-Home-Devices.b9aa977c-7173-4465-bc76-9bb35ea78a15.#query","Smart-Home-Devices.bdc08478-6398-4a62-8104-a87e3e841e8b.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#delete","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#enabled","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.#query","Smart-Home-Devices.bf124d27-a9a0-4b5b-9e15-e0cab83a6f38.active","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#delete","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#enabled","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#query","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.connectivity-reason","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.powerState","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#delete","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#enabled","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#query","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.connectivity-reason","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.powerState","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#delete","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#enabled","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.connectivity-reason","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.powerState","Smart-Home-Devices.c6b5fe24-e2e3-43a5-9625-1f3de08a9117.#query","Smart-Home-Devices.c7767a90-9305-4ad8-a194-b8d11cf068d5.#query","Smart-Home-Devices.c911652c-82d7-47ac-9148-b693698cd15c.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#delete","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#enabled","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#query","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.connectivity-reason","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.powerState","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#delete","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#enabled","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#query","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.detectionState","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#delete","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#enabled","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#query","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-brightness","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-hue","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.color-saturation","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorName","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.colorRgb","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.connectivity-reason","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.powerState","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#delete","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#enabled","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#query","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.connectivity-reason","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.detectionState","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#delete","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#enabled","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#query","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-brightness","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-hue","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.color-saturation","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorName","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.colorRgb","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.connectivity-reason","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.powerState","Smart-Home-Devices.d31fdee0-9261-45b2-b762-7601510e5bfa.#query","Smart-Home-Devices.d4c058d6-1454-4364-8044-024fa2b9015b.#query","Smart-Home-Devices.d567e065-a853-4cdb-90fa-637e858dba16.#query","Smart-Home-Devices.d735eab4-e4d9-4e27-9422-c66a413a945d.#query","Smart-Home-Devices.da69e1db-05a1-46b4-8113-b856e832d92a.#query","Smart-Home-Devices.e150b646-c923-4c38-8cd9-2d7dab656b06.#query","Smart-Home-Devices.e198978a-397d-431e-a5c3-014ba600f4b1.#query","Smart-Home-Devices.e2af59b6-6e34-4109-80aa-72e4c9c9531c.#query","Smart-Home-Devices.e4bb56f4-7aa9-447c-8f7b-e4594561ede3.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#delete","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#enabled","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#query","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.brightness","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.connectivity-reason","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.powerState","Smart-Home-Devices.e6371aa7-760a-4134-bd48-64a0534aa373.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#delete","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#enabled","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#query","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.connectivity-reason","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.powerState","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#delete","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#enabled","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#query","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.connectivity-reason","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.powerState","Smart-Home-Devices.e7b8b085-a5bb-43c9-b058-4f2906769370.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#delete","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#enabled","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#query","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-brightness","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-hue","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.color-saturation","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorRgb","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureInKelvin","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.colorTemperatureName","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.powerState","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#delete","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#enabled","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.#query","Smart-Home-Devices.e820dc0d-3ebb-42b9-8e2c-57c9b72392fa.active","Smart-Home-Devices.e82d4546-299a-4161-b46e-61433fe3ccca.#query","Smart-Home-Devices.e98459e4-06bb-45dd-b5c3-84a2dcba87ff.#query","Smart-Home-Devices.e9bdc49a-b74d-4a31-99fc-7685187590d9.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#delete","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#enabled","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#query","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.connectivity-reason","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.powerState","Smart-Home-Devices.ead6cf64-5555-4eeb-8861-258621a8d286.#query","Smart-Home-Devices.f0cb5405-3842-4b18-9863-5c031c74a409.#query","Smart-Home-Devices.f3dcc4b4-74eb-45b4-b677-62bd5dbcaa46.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#delete","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#enabled","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#query","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-brightness","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-hue","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.color-saturation","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorRgb","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureInKelvin","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.colorTemperatureName","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.connectivity-reason","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.powerState","Smart-Home-Devices.f7648592-a2b4-4556-8985-53006fce51a7.#query","Smart-Home-Devices.f87eec87-46b6-4cd2-a389-b2407b1229c9.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#delete","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#enabled","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.#query","Smart-Home-Devices.fad7abe1-35f0-4e64-b8f9-19c89d30ae89.active","Smart-Home-Devices.fb458fac-5057-47bb-a16c-0e195adfc1c0.#query","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#delete","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.#enabled","Smart-Home-Devices.fc3dfae6-a698-4334-a4f5-bf5de47d6527.powerState","Smart-Home-Devices.fe7d453e-663d-4092-9069-91ad6c11169e.#query","Smart-Home-Devices.ff1203b1-c4be-4892-aef1-9c7a3aa0d40e.#query","Smart-Home-Devices.c65c50ea-cf00-414a-b199-bf412ee68233.#includeInAllQuery","Smart-Home-Devices.ccdd8361-8bb0-4697-87cb-4429b668437b.#includeInAllQuery","Smart-Home-Devices.414df6b1-bcd6-4d7d-8de1-7e1366637e81.#includeInAllQuery","Smart-Home-Devices.30b2c0fc-5b3e-498a-b431-5ffef21ad8e8.#includeInAllQuery","Smart-Home-Devices.cae8575f-a33c-441a-a456-f224fb561696.#includeInAllQuery","Smart-Home-Devices.cf723038-de41-48a5-aaf9-74aa642416b7.#includeInAllQuery","Smart-Home-Devices.d0d64377-c98f-486a-b517-3d48cb34ba52.#includeInAllQuery","Smart-Home-Devices.c563f516-a076-4869-a5ec-53d53917f4b2.#includeInAllQuery","Smart-Home-Devices.ea625b75-9f49-43b6-aa13-2b86a045c588.#includeInAllQuery","Smart-Home-Devices.e504ec51-50e1-4c3f-a2e9-00655fb46675.#includeInAllQuery","Smart-Home-Devices.64686f99-c9ed-4889-a65f-930861e15c6f.#includeInAllQuery","Smart-Home-Devices.78a85ed1-8cdc-44e5-9ac9-d91053633d9e.#includeInAllQuery","Smart-Home-Devices.f5fe36c4-5339-4945-8650-add1dd48ebaf.#includeInAllQuery","Smart-Home-Devices.85a852c2-dd3e-4b9e-b542-0d92716d1567.#includeInAllQuery","Smart-Home-Devices.c1252576-2580-421d-8664-021a4743083b.#includeInAllQuery","Smart-Home-Devices.ac623832-2372-46da-b5a3-211a63361852.#includeInAllQuery","Smart-Home-Devices.3008ef32-13c2-41cc-a916-5fef7a5ca1d4.#includeInAllQuery","Smart-Home-Devices.0f1943b9-0b6b-4c26-ac43-e4b9535ddb54.#includeInAllQuery","Smart-Home-Devices.75b635e5-2fbe-48e7-969a-561c0fa1e7c4.#includeInAllQuery","Smart-Home-Devices.e6cb700a-72cd-4cef-ae55-38f43051b3a5.#includeInAllQuery","Smart-Home-Devices.151ae531-0dce-4951-9403-e5d35fe955e7.#includeInAllQuery","Smart-Home-Devices.e68db7c6-0257-4d32-8212-6f187b104265.#includeInAllQuery","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.#includeInAllQuery","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.#includeInAllQuery","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.#includeInAllQuery","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.#includeInAllQuery","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.#includeInAllQuery","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.#includeInAllQuery","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.#includeInAllQuery","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.humanPresenceDetectionState","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#query","Smart-Home-Devices.c2e9fa25-e2c8-4b3a-be0e-e14a7029a4a8.#includeInAllQuery","Smart-Home-Devices.2deb04a8-7e12-4a66-b6f1-8b24bf3caa95.humanPresenceDetectionState","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity","Smart-Home-Devices.a9d882d5-676f-4ea8-b292-6d7498646c33.connectivity-reason","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity","Smart-Home-Devices.32cb377e-eef4-4c4c-8a05-886fe76a9358.connectivity-reason","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity","Smart-Home-Devices.51c59c00-fd8d-4c22-a5e7-9401f8f1bda8.connectivity-reason","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity","Smart-Home-Devices.cba69f5b-cd05-446a-b10c-41da8fc20924.connectivity-reason","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity","Smart-Home-Devices.6d95cbec-811e-4799-8a1f-9534b2b36e30.connectivity-reason","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity","Smart-Home-Devices.1bc366a5-0ebd-4401-81f0-449f707dd3a9.connectivity-reason","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity","Smart-Home-Devices.e7efe345-2d41-4f97-9b72-cb7465923632.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#enabled","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#delete","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.powerState","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorTemperatureInKelvin","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorName","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-hue","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-saturation","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.color-brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.colorRgb","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.brightness","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.connectivity-reason","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#query","Smart-Home-Devices.ac75b956-bf1a-4553-a2dd-839cd7504948.#includeInAllQuery","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#enabled","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#delete","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.powerState","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.brightness","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.connectivity-reason","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#query","Smart-Home-Devices.961f6073-7661-49f7-8c77-4f66f07fa6af.#includeInAllQuery","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#enabled","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#delete","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.powerState","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorName","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-hue","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-saturation","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.color-brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.colorRgb","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.brightness","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.connectivity-reason","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#query","Smart-Home-Devices.9d1cd274-c508-433b-a984-a7b026e30158.#includeInAllQuery","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#enabled","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#delete","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.powerState","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorTemperatureInKelvin","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorName","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-hue","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-saturation","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.color-brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.colorRgb","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.brightness","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.connectivity-reason","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#query","Smart-Home-Devices.87f59a8e-c338-4411-83b0-347961db4deb.#includeInAllQuery","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#enabled","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#delete","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.powerState","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorName","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-hue","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-saturation","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.color-brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.colorRgb","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.brightness","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.connectivity-reason","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#query","Smart-Home-Devices.ab5186a6-f2f7-4ff1-add2-a5fe7713b6b7.#includeInAllQuery"]
        2024-11-10 00:19:23.423  - info: alexa2.0 (1139) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2024-11-10 00:19:25.809  - warn: bring.0 (1451) Error on login: Cannot Login: 401 - "{\"message\":\"email password combination not existing\",\"error\":\"unauthorized\",\"error_description\":\"Not authorized to access this resource\",\"errorcode\":200}"
        2024-11-10 00:19:25.809  - info: bring.0 (1451) [LOGIN] Reconnection in 30 seconds
        2024-11-10 00:19:26.829  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
        2024-11-10 00:19:26.833  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
        2024-11-10 00:19:26.837  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
        2024-11-10 00:19:26.839  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
        2024-11-10 00:19:26.858  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
        2024-11-10 00:19:26.860  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
        2024-11-10 00:19:26.862  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
        2024-11-10 00:19:26.876  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
        2024-11-10 00:19:27.243  - info: smartthings.0 (1586) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:27.302  - info: smartthings.0 (1586) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:27.349  - info: smartthings.0 (1586) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:27.350  - info: smartthings.0 (1586) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:27.409  - info: smartthings.0 (1586) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:27.410  - info: smartthings.0 (1586) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:27.434  - info: smartthings.0 (1586) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
        2024-11-10 00:19:27.441  - info: smartthings.0 (1586) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
        • L Offline
          lukas8519
          @Homoran @Thomas-Braun
          könnt ihr mir nochmal helfen?
          ich habe in JS meine Blocklys angepasst und dann aus Unwissenheit irgendwas "DEBUG ...." oben über die Menüleiste gestartet.
          Jetzt ist es so das alles läuft, ich aber nicht mehr über den Browser zum Iobroker komme...
          danke
          • L lukas8519
            danke
            @lukas8519 sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
            iob diag
            anschauen.
            • L lukas8519
              danke
              im Javascript editor?
              inkognito versuchen
                iob diag
                anschauen.
                lukas8519
                Script v.2024-10-19
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 15:05:24 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                CPU threads: 4
                Current issues:
                               Local time: Sun 2024-11-10 15:05:24 CET
                           Universal time: Sun 2024-11-10 14:05:24 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                lukas
                HOME=/home/lukas
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            3.8G        2.1G        695M        1.0M        1.0G        1.6G
                Swap:            99M          0B         99M
                Total:          3.9G        2.1G        795M
                Active iob-Instances:   29
                         3794 M total memory
                         2095 M used memory
                         2434 M active memory
                          483 M inactive memory
                          695 M free memory
                          101 M buffer memory
                          901 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                top - 15:05:25 up 20 min,  2 users,  load average: 2.71, 2.11, 1.44
                Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  4.1 us,  4.1 sy,  0.0 ni, 91.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3794.3 total,    695.1 free,   2096.1 used,   1003.1 buff/cache
                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1621.6 avail Mem
                *** FILESYSTEM ***
                /dev/root      ext4      235G   15G  211G   7% /
                [Sun Nov 10 14:45:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:40:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e488c2eb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Sun Nov 10 14:45:03 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Sun Nov 10 14:45:03 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Sun Nov 10 14:45:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                /var:
                4.8G    /var/
                3.7G    /var/log/journal/7dfe713e6e0e4645ad53eacc6d30a1a8
                3.7G    /var/log
                739M    /var/cache
                Archived and active journals take up 3.6G in the file system.
                4.0K    /opt/iobroker/backups/influxDB_2024_11_10-01_00_25_backupiobroker
                1.1G    /opt/iobroker/iobroker-data/
                963M    /opt/iobroker/iobroker-data/files
                617M    /opt/iobroker/iobroker-data/files/javascript.admin
                560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                33M     /opt/iobroker/iobroker-data/objects.jsonl
                28M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1200)
                admin:          7.1.5
                javascript:     8.8.3
                Adapter State
                  system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.bring.0                  : bring                 : iobroker                                 - disabled
                + instance is alive
                Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                Objects and States
                Objects:        26218
                States:         20791
                Pending Updates: 0
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        15664      622/influxd
                tcp        0      0 192.168.178.92:42010    0.0.0.0:*               LISTEN      1001       16648      1142/io.hm-rpc.1
                tcp        0      0 192.168.178.92:42001    0.0.0.0:*               LISTEN      1001       15188      1127/io.hm-rpc.0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14942      885/iobroker.js-con
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14947      885/iobroker.js-con
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13826      536/cupsd
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12059      576/sshd: /usr/sbin
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18349      1729/io.web.0
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17391      1974/io.simple-api.
                tcp6       0      0 :::8086                 :::*                    LISTEN      116        16428      622/influxd
                tcp6       0      0 :::3000                 :::*                    LISTEN      117        16489      884/grafana
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13825      536/cupsd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          12061      576/sshd: /usr/sbin
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16172      1218/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16173      1218/io.tuya.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12001      403/avahi-daemon: r
                udp        0      0 0.0.0.0:50606           0.0.0.0:*                           108        12003      403/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12134      467/dhcpcd
                udp6       0      0 :::546                  :::*                                0          12212      467/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        12002      403/avahi-daemon: r
                udp6       0      0 :::49079                :::*                                108        12004      403/avahi-daemon: r
                2024-11-10 15:06:16.682  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                2024-11-10 15:06:17.068  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:17.071  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:17.081  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:17.082  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:17.129  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:17.131  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:26.585  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.saturation.value" has to be type "string" but received type "number"
                2024-11-10 15:06:26.586  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.saturation.value" has to be type "string" but received type "number"
                2024-11-10 15:06:26.589  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.saturation.value" has to be type "string" but received type "number"
                2024-11-10 15:06:26.590  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.saturation.value" has to be type "string" but received type "number"
                2024-11-10 15:06:26.591  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.saturation.value" has to be type "string" but received type "number"
                2024-11-10 15:06:26.626  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.saturation.value" has to be type "string" but received type "number"
                2024-11-10 15:06:26.627  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.saturation.value" has to be type "string" but received type "number"
                2024-11-10 15:06:26.628  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.saturation.value" has to be type "string" but received type "number"
                2024-11-10 15:06:26.933  - info: smartthings.0 (1456) State value to set for "smartthings.0.12b46ff9-3e0b-4423-ad99-02baa9285ea4.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:27.053  - info: smartthings.0 (1456) State value to set for "smartthings.0.03dc17d2-f53e-4a9e-a03d-00b4229cd9e5.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:27.099  - info: smartthings.0 (1456) State value to set for "smartthings.0.8b8047ba-cd25-4244-a93e-91350a760595.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.ffcc9dac-c4b6-47da-bd7a-4e81d68a981e.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:27.101  - info: smartthings.0 (1456) State value to set for "smartthings.0.012db635-dbc7-4b24-b8c0-3ecda3b8d640.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:27.102  - info: smartthings.0 (1456) State value to set for "smartthings.0.989d3a7c-8cb6-4618-adf3-4dbfe4533c96.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:27.104  - info: smartthings.0 (1456) State value to set for "smartthings.0.aad5406f-a8e5-4428-b4b4-4bc81e720b3b.status.colorControl.hue.value" has to be type "string" but received type "number"
                2024-11-10 15:06:27.122  - info: smartthings.0 (1456) State value to set for "smartthings.0.dce2c5d4-bdca-4f98-b8f6-54e646944a1f.status.colorControl.hue.value" has to be type "string" but received type "number"
                  inkognito versuchen
                  lukas8519
                  ja im Editor...
                  inkogito Browser?
                  • L lukas8519
                    ja im Editor...
                    inkogito Browser?
                    @lukas8519
                    iob start admin
                    L 1 Antwort Letzte Antwort
                      @lukas8519
                      iob start admin
                      lukas8519
                      @thomas-braun sagte in Homematic IP Cloud Adapter lässt sich nicht installieren:
                      @lukas8519
                      iob start admin
                      Danke!!!!!!!!!!!!
