  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. [gelöst] Weatherman 2.1 mit wiffi-wz Adapter
    2.8k
    4.9k
    4.1k
18 Beiträge 3 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • B best57
    hier ein Log-Auszug beim Start von wiffi-wz:
    2024-10-23 16:31:09.837 - info: wiffi-wz.0 (221359) Got terminate signal TERMINATE_YOURSELF
    2024-10-23 16:31:09.845 - info: wiffi-wz.0 (221359) Stopping adapter ...
    2024-10-23 16:31:09.848 - debug: wiffi-wz.0 (221359) Server closed
    2024-10-23 16:31:09.850 - info: wiffi-wz.0 (221359) Adapter stopped.
    2024-10-23 16:31:09.853 - info: wiffi-wz.0 (221359) terminating
    2024-10-23 16:31:09.855 - info: wiffi-wz.0 (221359) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-10-23 16:31:09.955 - warn: wiffi-wz.0 (221359) Read-only state "wiffi-wz.0.info.connection" has been written without ack-flag with value "false"
    2024-10-23 16:31:10.002 - warn: wiffi-wz.0 (221359) Read-only state "wiffi-wz.0.info.connection" has been written without ack-flag with value "false"
    2024-10-23 16:31:18.290 - debug: wiffi-wz.0 (221510) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-10-23 16:31:18.328 - debug: wiffi-wz.0 (221510) Objects client ready ... initialize now
    2024-10-23 16:31:18.331 - debug: wiffi-wz.0 (221510) Objects create System PubSub Client
    2024-10-23 16:31:18.332 - debug: wiffi-wz.0 (221510) Objects create User PubSub Client
    2024-10-23 16:31:18.378 - debug: wiffi-wz.0 (221510) Objects client initialize lua scripts
    2024-10-23 16:31:18.387 - debug: wiffi-wz.0 (221510) Objects connected to redis: 127.0.0.1:9001
    2024-10-23 16:31:18.390 - silly: wiffi-wz.0 (221510) redis psubscribe cfg.o.system.user.*
    2024-10-23 16:31:18.418 - silly: wiffi-wz.0 (221510) redis psubscribe cfg.o.enum.*
    2024-10-23 16:31:18.422 - silly: wiffi-wz.0 (221510) objectDB connected
    2024-10-23 16:31:18.426 - debug: wiffi-wz.0 (221510) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-10-23 16:31:18.442 - debug: wiffi-wz.0 (221510) States create System PubSub Client
    2024-10-23 16:31:18.443 - debug: wiffi-wz.0 (221510) States create User PubSub Client
    2024-10-23 16:31:18.533 - debug: wiffi-wz.0 (221510) States connected to redis: 127.0.0.1:9000
    2024-10-23 16:31:18.536 - silly: wiffi-wz.0 (221510) statesDB connected
    2024-10-23 16:31:18.749 - info: wiffi-wz.0 (221510) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.wiffi-wz, node: v18.20.4, js-controller: 6.0.11
    2024-10-23 16:31:18.794 - silly: wiffi-wz.0 (221510) States system redis pmessage system.adapter.wiffi-wz.0.logLevel/system.adapter.wiffi-wz.0.logLevel:{"val":"silly","ack":true,"ts":1729693878772,"q":0,"from":"system.adapter.wiffi-wz.0","lc":1729693394545}
    2024-10-23 16:31:18.854 - info: wiffi-wz.0 (221510) Opening local server on 0.0.0.0:8181
    2024-10-23 16:31:18.859 - info: wiffi-wz.0 (221510) Server listening on 0.0.0.0:8181
    2024-10-23 16:31:18.883 - warn: wiffi-wz.0 (221510) Read-only state "wiffi-wz.0.info.connection" has been written without ack-flag with value "true"
    2024-10-23 16:31:18.956 - debug: wiffi-wz.0 (221510) Create basic states for Wiffi with ip 192.168.72.25
    2024-10-23 16:31:18.958 - info: wiffi-wz.0 (221510) Method "createChannel" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
    der WM2.1 wurde gleich konfiguriert wie der WM2.
    Wenn ich so nicht weiter komme, werde ich wohl den Weg über den HomeMatic-Adpater wählen müssen.
    crunchipC Abwesend
    crunchipC Abwesend
    @best57 sagte in Weatherman 2.1 mit wiffi-wz Adapter:
    192.168.72.25
    Und das ist dein neuer wiffi? Oder der alte?
    Vllt Schreibfehler in den Einstellungen beim Neuen
    @homoran sagte in Weatherman 2.1 mit wiffi-wz Adapter:
    0.0.0.0
    Ist doch der instanzeintrag
    @Homoran das war der gemeigte Fehler, nicht wie oben geschrieben... Number/string
      192.168.72.25
      0.0.0.0
      @crunchip sagte in Weatherman 2.1 mit wiffi-wz Adapter:
      ja, aber auch die IP in Form 192.168.xxx.yyy kann da ausgewählt werden.
      Mein Gedanke mangels Wissen war:
      Bei hm-rpc wird diese IP der CCU mitgeteilt damit die CCU dorthin antwortet.
      Sollte das beim wiffi Adapter identisch sein hilft 0.0.0.0 nichts
        crunchipC Abwesend
        crunchipC Abwesend
        @homoran ich habe keine ccu, daher hört meine Instanz auf alle und funktioniert. Im wiffi Gerät(pulscounter) hab ich die IP des iobroker hinterlegt.
        • B best57
          ich habe meinen Weatherman 2.0 von stall.biz, durch den Weatherman 2.1 ersetzt. Nun bekomme ich, über den wiffi-wz Adapter, keine Daten mehr in den iobroker. Das heißt, es werden unterhalb vom Verzeichnis 192_168_xx_xx keine Objekte angelegt. Die Konfiguration habe ich einfach übernommen.
          Ich sehe, dass der Adapter schon lange nicht mehr aktualisiert wurde. Hat da jemand von euch aktuelle Infos. Bin für jeden Tipp dankbar.
          Gruß, Stefan
          crunchipC Abwesend
          crunchipC Abwesend
          bin mir nicht genau sicher, ist schon Jahre her, aber ich meine, ich hatte setvar damals abgesetzt, damit die Datenpunkte erschienen
          ansonsten steht bei ccu-ip die des iobrokers und my ip habe ich fest vergeben
            @crunchip Ich weiss wirklich nicht mehr was ich eingestellt habe.
            ich meine aber dass sowohl die CCU als auch iobroker die Daten bekommen, auch wenn sich die IP des iob mittlerweile geändert hat ohne dass ich am Wiffi was verändert habe
            Diese Einstellung zeigt die verschiedenen Möglichkeiten
            Allerdings kann man auch mit <IP>?:json: die Werte pullen
            ich weiss jetzt gar nicht was der Adapter macht.
            EDIT:
            in dem json ist die neue IP des ioBrokers als CCU-IP angegeben.
            Da ich mir ziemlich sicher bin diese nicht über kryptische Befehle via Adresse des Wiffis eingegeben, sondern nur in der Konfiguration desr Instanz geändert zu haben. vermute ich, dass der Adapter diese Konfiguration durchführt.
            Dazu braucht der Adapter aber eine IP mit der der Wiffi dann ioBroker erreichn kann.
            Also nicht 0.0.0.0, sondern 192.168.xxx.yyy
              EDIT:
              crunchipC Abwesend
              crunchipC Abwesend
              weils bei dir über die ccu läuft, ist ja der parameter darüber, so wie ich das verstehe
              ich sende direkt an den iobroker
                nein tut es nicht, hab gerade im debug log nachgesehen (siehe edit)
                die beiden Zeilen der Beschreibung gilt für Parameter 27. Der Wert kann 0,1, oder in meinem Fall die 8181 als port sein.
                wie kommst du auf die Seite mit der IP?
                expert 0 bis 3 ist es nicht.
                  crunchipC Abwesend
                  crunchipC Abwesend
                  ist die startseite, wenn ich die ip aufrufe
                  wenn ich hin und her blättere, steht
                  http://10.1.30.10/?xpert:0:
                    @crunchip Danke!
                    ich bin blind gewesen.
                    Hab nur den unteren Block gesehen 🤦
                    Da steht die aktuelle IP des ioBrokers
                    wäre jetzt interessant was dort bei @best57 im neuen Weatherman steht
                      @crunchip Danke!
                      best57
                      sorry, konnte mich erst jetzt wieder damit beschäftigen. Es war tatsächlich die falsche IP beim Parameter "CCU IP-Adresse". Mit der IP des iobroker funktioniert es nun. Wegen der Bezeichnung hatte ich das wohl übersehen.
                      Danke für eure Unterstützung.
