  5. [erledigt] Müllkalender, keine Benachrichtigung
    6.0k
26 Beiträge 6 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • David G.D David G.
    @accuface sagte in Müllkalender, keine Benachrichtigung:
    Gerade im Protokoll gesehen:
    Copy to Clipboard admin.0 954 2024-10-29 19:14:31.953 warn ical has an invalid jsonConfig: [{"instancePath":"/items/_calendars/items/calendars/items/5","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_calendars/items/calendars","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"/items/_calendars","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
    Copy to Clipboard admin.0 954 2024-10-29 18:59:19.130 warn trashschedule has an invalid jsonConfig: [{"instancePath":"/items/_advanced/items/trashtypes/items/4","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_advanced/items/trashtypes","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"/items/_advanced","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
    Evtl die Settings nochmal neu eintragen und neu Speichern? Ka.
    Accuface
    @david-g said in Müllkalender, keine Benachrichtigung:
    Auffällig ist bei beiden Protokollen: "failingKeyword":"then"
    müsste dann statt "und" ein "then" rein?
    • David G.D Online
      David G.D Online
      David G.
      @accuface
      https://forum.iobroker.net/topic/69570/logging-warnung-admin-0-ical-has-an-invalid-jsonconfig
      A 2 Antworten Letzte Antwort
        @accuface
        Accuface
        @accuface
        ach Super, Dank Dir. dann also erst mal getrost ignorieren
        • A Accuface
          @accuface
          David G.D Online
          David G.D Online
          David G.
          @accuface
          Evtl system nicht aktuell? Angeblich ist das schon lange gefixt.
            @accuface
            Accuface
            @accuface
            ich hab das ganze vor 2 oder 3 wochen erst angefangen mit iob, sollte also alles aktuell sein, zumindest die Adapter bringen keine Updates
            • A Accuface
              @accuface
              David G.D Online
              David G.D Online
              David G.
              @accuface
              Dann kannst du dich jetzt drinnen üben ein Issue auf github zu erstellen bei den beiden Adaptern^^.
              Oder @haus-automatisierung kann hier schon was sagen. Von ihm ist der trashschedule Adapter.
                @accuface
                Accuface
                @accuface
                Dann kannst du dich jetzt drinnen üben ein Issue auf github zu erstellen bei den beiden Adaptern.
                noch nie gemacht.... ich find mich auf der Seite null zurecht. aber ich schau mir das mal an
                • A Accuface
                  @accuface
                  David G.D Online
                  David G.D Online
                  David G.
                  @accuface
                  https://github.com/klein0r/ioBroker.trashschedule/issues
                  Wobei es bei mir bei beiden Adaptern rund läuft.
                  Gibt's aber schon und ist bereits geschlossen.
                  https://github.com/klein0r/ioBroker.trashschedule/issues/192
                  A 3 Antworten Letzte Antwort
                    @accuface
                    Accuface
                    @accuface
                    ich denk auch nicht dass es am Adapter liegt, gut möglich dass ich irgendwo was falsches eingetragen habe oder so. Kenn mich ja nun ned wirklich gut aus. mach aktuell alles irgendwie aus Videos und anleitungen.
                    • A Accuface
                      dass er mich am Tag der abholung erinnert, morgens um 5 uhr. Ich steh um 4 Uhr auf und bin gern mal bissl vergesslich
                      Aber was juckt dich die nächste Tonne?
                      Du willst ja die aktuelle.
                      Prüf die aktuelle Tonne um 4 Uhr auf 0 Tage verbleibend.
                      admin.0
                      954	2024-10-29 19:14:31.953	warn ical has an invalid jsonConfig: [{"instancePath":"/items/_calendars/items/calendars/items/5","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_calendars/items/calendars","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/_calendars","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                      admin.0
                      954	2024-10-29 18:59:19.130	warn   trashschedule has an invalid jsonConfig: [{"instancePath":"/items/_advanced/items/trashtypes/items/4","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_advanced/items/trashtypes","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/_advanced","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                      haus-automatisierungH Offline
                      Das sind eigentlich Infos für die Entwickler. Ich weiß nach wie vor nicht, warum die Nutzer damit konfrontiert werden. Das verwirrt nur, ... @mcm1957
                      Erstmal ignorieren.
                      📚 Meine Dokumentation
                        @accuface
                        Accuface
                        @accuface
                        hab ich vorhin auch gesehen... also irgendwo mein Fehler
                          @accuface
                          Accuface
                          schrieb am zuletzt editiert von Accuface
                          @accuface
                          Dann schau ma morgen mal.
                          Danke erst mal
                          So, nachdem wohl das Format meiner Telnummer nicht gepasst hat, hab ich das korrigiert und mit einem einfachen Zeitplan und einer Message als Whatsapp getestet.
                          Ergebniss: die Nachricht kam im Callbot an.
                          Dann hab ich einen anderen Zeitplan gefunden, den hab ich etwas angepasst und getestet.
                          Ergebniss:
                          whatsapp-cmb.0
                          86624 2024-10-29 20:59:00.283 error Cannot send message: <p>ERROR: Phone number <b>format</b> is incorrect
                          Paar Minuten vorher ging es doch. Ich verstehe es gerade nicht.
                          gerade nochmal zum Test:
                          whatsapp-cmb.0
                          86624 2024-10-29 21:13:00.030 info Send testnachricht to +49151
                            Erstmal ignorieren.
                            mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            @haus-automatisierung said in Müllkalender, keine Benachrichtigung:
                            Erstmal ignorieren.
                            Sinn der Meldung ist es analog wie bei Meldungen über nicht richtig angelegte States den Fehler am System zu registrieren. Beim Auftreten dieser Meldung kann und sollte der User ein Issue beim Adapter anlegen damit der Entwickler
                            a) informiert wird
                            b) eine Korrektur des Adaptercodes vornehmen kann
                            Daher die Frage:
                            Gibt es ein Issue beim Adapter? Wenn nicht, bitte anlegen.
                            PS: Ansonsten bin ich nicht der richtige Ansprechpartner da ich weder den Check umgesetzt habe noch diesen beeinflussen kann.
                            Support Repositoryverwaltung.
                            LESEN - gute Forenbeitrage
                            • mcm1957M mcm1957
                              Erstmal ignorieren.
                              a) informiert wird
                              Daher die Frage:
                              Accuface
                              @mcm1957 said in Müllkalender, keine Benachrichtigung:
                              Erstmal ignorieren.
                              a) informiert wird
                              Daher die Frage:
                              Guten Morgen,
                              Nein gibt es noch nicht. Da mein Englisch miserabel bis nicht vorhanden ist, hab ich keine Ahnung wo, was und wie ich genau machen muss. und bevor ich wieder eins auf die Mütze bekomme weil etwas falsch gemacht wurde....lass ich es lieber.
                              Und so wie ich das verstehe ist der Fehler doch behoben worden.....anscheinend.
                              grüße
                              • A Accuface
                                Erstmal ignorieren.
                                a) informiert wird
                                Daher die Frage:
                                Guten Morgen,
                                grüße
                                Ne, besteht immernoch. Und ist kein Fehler, sondern ein unvollständiges Schema. Das heißt es funktioniert alles, aber das Schema sagt die Konfiguration ist ungültig. Entsprechend überflüssig sind solche Infos für Nutzer. Habe mal einen Issue angelegt.
                                https://github.com/ioBroker/adapter-react-v5/issues/448
                                  Accuface
                                  Vielen Dank.
                                  Irgendwann werd ich mich schon auch noch um die Seite kümmern, aber alles auf einmal geht gerade leider ned.
                                  • A Accuface
                                    Vielen Dank.
                                    Accuface
                                    @mcm1957
                                    @David-G
                                    Problem gelöst.
                                    Auflösung: Ich hatte nach der Anleitung von @haus-automatisierung das erste Blockly erstellt. Da ich aber VIS-2 nutze, scheinen die blöcke anders zu sein. Ich hatte vorher den Baustein....erstelle Text aus.... in den 2. hacken eingerastet.
                                    Dieser ist aber wohl Empfänger (optional).
                                    So hab ich es jetzt erstellt und das funktioniert nun:
                                    Im Video ist es zwar richtig erklärt, aber bei mir sehen die Blöcke mit den Rasten anders aus, dass heisst, ich musste einen 2. "erstelle Text aus" einfügen um "morgen wird die ...Tonne Geholt" hinzubekommen.
                                    Oder denk ich zu kompliziert?
                                    • A Accuface
                                      @mcm1957
                                      @David-G
                                      Problem gelöst.
                                      klick mal auf das Zahnrad
                                        Accuface
                                        @homoran said in Müllkalender, keine Benachrichtigung:
                                        ja gut, Zahnräder werden völlig überbewertet. sowas kann ein anfänger ned wissen.
                                        aber hey, meine Variante funzt auch.
                                        Trozdem Danke an euch
