  3. Off Topic
  4. Grafana
  5. "Unauthorized" Meldung beim Sign in in Grafana
    6.7k
Geplant Angeheftet Gesperrt Verschoben Grafana
123 Beiträge 9 Kommentatoren 16.6k Aufrufe 6 Beobachtet
  • W wibear
    @ro75
     systemctl status grafana-server
    ● grafana-server.service - Grafana instance
         Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
         Active: failed (Result: exit-code) since Sat 2024-10-19 16:17:44 CEST; 7mi>
           Docs: http://docs.grafana.org
        Process: 9362 ExecStart=/usr/share/grafana/bin/grafana server --config=${CO>
       Main PID: 9362 (code=exited, status=1/FAILURE)
            CPU: 412ms
    Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Scheduled resta>
    Oct 19 16:17:44 iobroker-pi systemd[1]: Stopped Grafana instance.
    Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Start request r>
    Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Failed with res>
    Oct 19 16:17:44 iobroker-pi systemd[1]: Failed to start Grafana instance.
    lines 1-13/13 (END)
         Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Sat 2024-10-19 16:17:44 CEST; 7min ago
        Process: 9362 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packagi>
            CPU: 412ms
    Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
    Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Start request repeated too quickly.
    Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
    #100
    @wibear warum ist da alles abgeschnitten?
    W 1 Antwort Letzte Antwort
      W Offline
      W Offline
      wibear
      #101
      Ist es besser?
      wibear@iobroker-pi:~ $ systemctl status grafana-server
           Active: failed (Result: exit-code) since Sat 2024-10-19 16:17:44 CEST; 10min ago
          Process: 9362 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.data=${DATA_DIR} cfg:default.paths.>
              CPU: 412ms
      • Ro75R Offline
        Ro75R Offline
        Ro75
        #102
        @wibear sagte in "Unauthorized" Meldung beim Sign in in Grafana:
        schaue mal hier. Da wurde das Problem schon einmal besprochen.
        Ro75.
        • Ro75R Ro75
          Ro75.
          W Offline
          W Offline
          wibear
          #103
          @ro75 sagte in "Unauthorized" Meldung beim Sign in in Grafana:
          Ich habe die Datei /lib/systemd/system/grafana-server.service mit meiner verglichen: identisch.
          Mehr konnte ich dem Beitrag nicht entnehmen.
          Ro75R 1 Antwort Letzte Antwort
          • W wibear
            Ro75R Offline
            Ro75R Offline
            Ro75
            #104
            @wibear dann hätte ich außer einem kompletten Neuanfang (Installation Debian12) - wäre auch die beste Option, nur noch eine Idee.
            1. sichere die Datei "/var/lib/grafana/grafana.db"
            2. Entferne Grafana von deinem System
            3. Installiere Grafana komplett neu
            4. Starte Grafana und schaue ob du wieder zur Anmeldung kommst
            Wenn ja dann ab hier weiter
            1. Stoppe Grafana
            2. Kopiere die Datei unter Punkt 1 zurück und gib dieser Datei die Rechte von der existierenden
            3. Starte Grafana neu.
            Ro75.
            • Ro75R Ro75
              1. Stoppe Grafana
              Ro75.
              W Offline
              W Offline
              wibear
              #105
              @ro75
              Es kommt ein Fehler beim Versuch runterzuladen:
              • W wibear
                @ro75
                Ro75R Offline
                Ro75R Offline
                Ro75
                #106
                @wibear was hast du denn immer mit dem "Berechtigungsfenster"? Mit welchen Account loggst du dich den via Filezilla ein?
                Ro75.
                • Ro75R Ro75
                  Ro75.
                  W Offline
                  W Offline
                  wibear
                  #107
                  Mit dem Account, mit dem ich mich über die Console anmelde.
                  • W wibear
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    #108
                    Alles klar, damit kann ich nichts anfangen? Root? pi? iobroker? klaus?
                    Ro75.
                    • Ro75R Ro75
                      Ro75.
                      W Offline
                      W Offline
                      wibear
                      #109
                      es ist der einzige User, den ich bei der Installation angelegt habe. Müsste eigentlich root sein.
                      • W wibear
                        Ro75R Offline
                        Ro75R Offline
                        Ro75
                        #110
                        @wibear genau. Die Rechte, Eigentümer, Gruppe stimmen nicht.
                        Bei dir ist es root/grafana und 0640. Da passt was überhaupt nicht. Hast du von Grafana via Backitup eine Sicherung die OK ist? Wenn ja, setze neu auf.
                        Und nix mir Root in Zukunft.
                        Ro75.
                        • Ro75R Ro75
                          Ro75.
                          W Offline
                          W Offline
                          wibear
                          #111
                          Die Sicherung wurde mit OK geladen, hat aber nichts gebracht.
                          Ich versuche Grafana neu zu installieren, wie Du zuvor vorgeschlagen hast.
                          • W wibear
                            Ro75R Offline
                            Ro75R Offline
                            Ro75
                            #112
                            Das ist gut. Mir ging es nur darum, ob in gepackten Datei auch was drin ist.
                            Ro75.
                              Heißt es, dass meine jetzige Installation, in die ich wie etliche andere Nutzer jede Menge Zeit investiert habe, unbrauchbar geworden ist und wir wieder von vorne anfangen müssen?
                              Das heißt, das du wie üblich Backups anlegst und mit diesen Backups auf ein neuinstalliertes System umziehst.
                              Wie etliche andere Nutzer auch schon. Da muss auch nix 'von vorne' angefangen werden, weil du ja die Daten im Backup hast.
                              W Offline
                              W Offline
                              wibear
                              #113
                              Hallo Thomas, ich benutze momentan eine SSD und versuche jetzt auf einer SD dieses Update auf 64-bit auf einem Raspi 4B mit einem Image für Bookworm Lite mittels Raspberry Pi Imager durchzuspielen. Dafür klemme ich die SSD ab und versuche es mit der SD zu booten. Der Raspi bootet aber nicht und die beiden LEDs vorne rot und grün leuchten permanent. Woran könnte es bitte liegen. Danke und Grüße
                              • W wibear
                                #114
                                An der Boot-Reihenfolge. Kann man z. B. in
                                sudo raspi-config
                                einstellen.
                                  sudo raspi-config
                                  einstellen.
                                  W Offline
                                  W Offline
                                  wibear
                                  #115
                                  @thomas-braun sagte in "Unauthorized" Meldung beim Sign in in Grafana:
                                  Die Boot-Reihenfolge wurde noch mit der SSD so eingestellt: zuerst SD, danach SSD. Ich komme aber jetzt überhaupt nicht an Raspi ran??
                                  • W wibear
                                    #116
                                    @wibear Dann klemm die SSD an und kontrollier es.
                                    W 2 Antworten Letzte Antwort
                                      W Offline
                                      W Offline
                                      wibear
                                      #117
                                      Die Reihenfolge scheint richtig zu sein...
                                      • W wibear
                                        Ro75R Offline
                                        Ro75R Offline
                                        Ro75
                                        #118
                                        @wibear SSD an USB2 oder USB3 angeschlossen? Manche Controller laufen nur sauber über USB2-Anschluss
                                        Ro75.
                                        • Ro75R Ro75
                                          Ro75.
                                          W Offline
                                          W Offline
                                          wibear
                                          #119
                                          @ro75
                                          Es ist an USB3 angeschlossen. Die SSD läuft aber über USB3 ohne Probleme. Das Problem ist kein Booten von der SD Karte.
