  3. Off Topic
  4. Grafana
  5. "Unauthorized" Meldung beim Sign in in Grafana
    6.7k
Geplant Angeheftet Gesperrt Verschoben Grafana
123 Beiträge 9 Kommentatoren 16.6k Aufrufe 6 Beobachtet
  • W wibear
    @ro75
    Ro75R Offline
    Ro75R Offline
    Ro75
    #67
    @wibear Das sind ja nur die "Diagramme" drin, aber doch nicht Grafana selbst. Keine Ahnung. Hattest du schon einmal
    iob diag
    gemacht und die Langfassung gepostet?
    Ro75.
    W 2 Antworten Letzte Antwort
    • Ro75R Ro75
      iob diag
      Ro75.
      W Offline
      W Offline
      wibear
      #68
      @ro75
      Summary:
      ```bash
                              v.2024-08-12
         Static hostname: iobroker-pi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7l+
            Architecture: arm
      Kernel:                 armv7l
      Userland:               32 bit
      User-ID:                1000
      Display-Server:         true
      Boot Target:            multi-user.target
      Pending OS-Updates:     1
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      Recommended versions are nodejs 20.18.0 and npm 10.8.2
      MEMORY:
      Mem:            3.9G        1.3G        728M        0.0K        1.8G        2.5G
      Swap:            99M        5.0M         94M
      Total:          4.0G        1.3G        823M
      Active iob-Instances:   24
      Upgrade policy: patch
      ioBroker Core:          js-controller           6.0.11
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                7086
      States:                 5970
      Size of iob-Database:
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      8.5M    /opt/iobroker/iobroker-data/states.jsonl
      ```bash
      Skript v.2024-08-12
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      OS is similar to: debian
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       12:15:40 up 38 min,  1 user,  load average: 0.92, 0.85, 0.61
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-10-19 12:15:40 CEST
                 Universal time: Sat 2024-10-19 10:15:40 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      wibear
      HOME=/home/wibear
      GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.9G        1.3G        727M        0.0K        1.9G        2.5G
      Swap:            99M        5.0M         94M
      Total:          4.0G        1.3G        822M
               3887 M total memory
               1308 M used memory
                302 M active memory
               2729 M inactive memory
                727 M free memory
                 86 M buffer memory
               1764 M swap cache
                 99 M total swap
                  5 M used swap
                 94 M free swap
      top - 12:15:41 up 38 min,  1 user,  load average: 0.92, 0.85, 0.61
      Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  6.1 us,  0.0 sy,  0.0 ni, 93.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3887.9 total,    727.9 free,   1308.5 used,   1851.5 buff/cache
      MiB Swap:    100.0 total,     95.0 free,      5.0 used.   2470.9 avail Mem
      *** FAILED SERVICES ***
        UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
      * grafana-server.service loaded failed failed Grafana instance
      1 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       55G   11G   42G  21% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     778M  1.1M  777M   1% /run
      /dev/sda1      vfat      255M   60M  196M  24% /boot
      tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
      [Sat Oct 19 11:37:16 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): write access will be enabled during recovery
      [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): recovery complete
      [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Oct 19 11:37:17 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat Oct 19 11:37:18 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
      3.8G    /var/
      2.0G    /var/log
      1.5G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
      943M    /var/cache
      Archived and active journals take up 1.4G in the file system.
      /opt/iobroker/backups:
      82M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      909M    /opt/iobroker/iobroker-data/
      754M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      8.8M    /opt/iobroker/iobroker-data/states.jsonl
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u5 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     1
      +-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
      + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-pi                              - disabled
        system.adapter.energiefluss.0           : energiefluss          : iobroker-pi                              - disabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
        system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
      + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
      + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
        system.adapter.tuya.0                   : tuya                  : iobroker-pi                              - disabled
      + system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
      Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
      Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Objects and States
      Objects:        7086
      States:         5970
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 https://packages.grafana.com/oss/deb stable InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
      Hit:6 https://repos.influxdata.com/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       20835      2442/io.mqtt.0
      tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       17102      2163/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11850      831/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11838      784/influxd
      tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       19800      2386/io.hm-rpc.1
      tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       17232      2426/io.hm-rpc.2
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          11881      878/dnsmasq
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21089      2543/io.shelly.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16138      1621/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16726      1621/iobroker.js-co
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11852      831/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21177      2638/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16824      1828/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21153      2621/io.simple-api.
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        16087      784/influxd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12690      368/avahi-daemon: r
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          11880      878/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          11877      878/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14528      611/dhclient
      udp        0      0 0.0.0.0:40577           0.0.0.0:*                           108        12692      368/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12691      368/avahi-daemon: r
      udp6       0      0 :::60456                :::*                                108        12693      368/avahi-daemon: r
      2024-10-19 12:00:07.986  - info: netatmo-crawler.0 (4265) Getting data for stationid:70:ee:50:33:0f:3e
      2024-10-19 12:00:11.082  - info: netatmo-crawler.0 (4265) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2024-10-19 12:00:11.615  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4265 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-10-19 12:01:40.325  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
      2024-10-19 12:03:10.939  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
      2024-10-19 12:05:05.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 4608
      2024-10-19 12:05:07.958  - info: netatmo-crawler.0 (4608) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
      2024-10-19 12:05:08.027  - info: netatmo-crawler.0 (4608) Getting data for stationid:70:ee:50:33:0f:3e
      2024-10-19 12:05:09.323  - info: netatmo-crawler.0 (4608) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2024-10-19 12:05:09.856  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4608 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-10-19 12:08:33.508  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.178.33
      2024-10-19 12:10:05.025  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 4939
      2024-10-19 12:10:07.943  - info: netatmo-crawler.0 (4939) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
      2024-10-19 12:10:08.008  - info: netatmo-crawler.0 (4939) Getting data for stationid:70:ee:50:33:0f:3e
      2024-10-19 12:10:09.580  - info: netatmo-crawler.0 (4939) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2024-10-19 12:10:10.111  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4939 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-10-19 12:10:25.733  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
      2024-10-19 12:11:10.407  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.8
      2024-10-19 12:14:10.520  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
      2024-10-19 12:14:55.567  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.6
      2024-10-19 12:15:05.024  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 6289
      2024-10-19 12:15:08.067  - info: netatmo-crawler.0 (6289) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
      2024-10-19 12:15:08.134  - info: netatmo-crawler.0 (6289) Getting data for stationid:70:ee:50:33:0f:3e
      2024-10-19 12:15:11.479  - info: netatmo-crawler.0 (6289) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2024-10-19 12:15:12.015  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 6289 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Ro75R 1 Antwort Letzte Antwort
      • Ro75R Ro75
        iob diag
        Ro75.
        W Offline
        W Offline
        wibear
        #69
        @ro75 sagte in "Unauthorized" Meldung beim Sign in in Grafana:
        Ich habe auch diesen Backup vor ein paar Tagen gemacht:
        Ro75R Thomas BraunT 2 Antworten Letzte Antwort
        • W wibear
          @ro75
          Summary:
          ```bash
                                  v.2024-08-12
                   Icon name: computer
                Architecture: arm
          Kernel:                 armv7l
          Userland:               32 bit
          User-ID:                1000
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Swap:            99M        5.0M         94M
                                  admin                   7.1.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                7086
          States:                 5970
          ```bash
          Skript v.2024-08-12
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : 32 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          wibear
          HOME=/home/wibear
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M        5.0M         94M
                   3887 M total memory
                   1308 M used memory
                    302 M active memory
                    727 M free memory
                     86 M buffer memory
                   1764 M swap cache
                     99 M total swap
                      5 M used swap
                     94 M free swap
          *** FILESYSTEM ***
          /var:
          3.8G    /var/
          2.0G    /var/log
          943M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.1.5
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        7086
          States:         5970
          Pending Updates: 1
          Ro75R Offline
          Ro75R Offline
          Ro75
          #70
          @wibear tja, möglicherweise ist das die Folge von
          Das Dateisystem hat(te) einen Treffer. Da kann u.U. noch einiges "defekt" sein. Grafana könnte auch davon betroffen sein.
          Ro75.
          • W wibear
            Ro75R Offline
            Ro75R Offline
            Ro75
            #71
            @wibear sagte in "Unauthorized" Meldung beim Sign in in Grafana:
            nix anderes.
            Ro75.
            • W wibear
              #72
              @wibear
              Da über kurz oder lang ohnehin eine komplette Neuinstallation des Betriebssystems ins Haus steht kannst du es auch jetzt in Angriff nehmen.
              W 1 Antwort Letzte Antwort
                @wibear
                W Offline
                W Offline
                wibear
                #73
                Was meinst Du unter Neuinstallation??
                • W wibear
                  #74
                  Damit meine ich eine Neuinstallation.
                  Dein Raspberry 11 'Bullseye' (32Bit) kann ohnehin nicht auf das aktuelle Release 12 'Bookworm' (64Bit) gebracht werden. Musst du also neuinstallieren. Ganz unabhängig von Grafana.
                    W Offline
                    W Offline
                    wibear
                    #75
                    Würdest Du das bitte etwas genauer erläutern? Heißt es, dass meine jetzige Installation, in die ich wie etliche andere Nutzer jede Menge Zeit investiert habe, unbrauchbar geworden ist und wir wieder von vorne anfangen müssen?
                    • W wibear
                      #76
                      Das heißt, das du wie üblich Backups anlegst und mit diesen Backups auf ein neuinstalliertes System umziehst.
                      Wie etliche andere Nutzer auch schon. Da muss auch nix 'von vorne' angefangen werden, weil du ja die Daten im Backup hast.
                        W Offline
                        W Offline
                        wibear
                        #77
                        @thomas-braun sagte in "Unauthorized" Meldung beim Sign in in Grafana:
                        Wird es dafür irgendeine Anleitung o.ä. geben, da diese Neuinstallation (Umstieg von 32- auf 64-bit ?) etwas komplexer ausfallen dürfte?
                        Gibt's eine Möglichkeit, grafana.ini runterzuladen und/oder durch eine andere zu ersetzen? Bei mir begann der Ärger mit deren Änderung.
                        • W wibear
                          Ro75R Offline
                          Ro75R Offline
                          Ro75
                          #78
                          Die ini nicht runterziehen. Nach der Neuinstalltion schauen ob es gleich geht. Wenn nicht, dann die Datei modifizieren. Im übrigen, begannen die Probleme wohl nicht damit. Wie ich schon geschrieben habe, das Dateisystem hat einen Treffer.
                          Ro75.
                          • W wibear
                            #79
                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                              W Offline
                              W Offline
                              wibear
                              #80
                              Muss mein 32-bit System auf 64-bit ungestellt werden?
                              Kann ich es jetzt ohne Bedenken über arm_64bit=1 machen?
                              Muss meine SSD gelöscht werden und IOBroker danach neu istalliert werden?
                              Was geschieht dann mit Raspberrymatic?
                              • W wibear
                                #81
                                Irgendwann ganz sicher.
                                Nein, das ist nur Schminke und kein richtiger Wechsel der Architektur.
                                Ja, so funktioniert das mit dem Umzug.
                                Backups einspielen. Muss es ja auch dort geben.
                                Bei Raspberry OS Bookworm kommt noch dazu, das beim Bootvorgang etwas umgestellt wurde. Und auch das geht man am besten mit einer Neuinstallation an. Das ist im Übrigen auch die offizielle Vorgehensweise, in-line-Dist-Upgrades waren noch nie vorgesehen.
                                  W Offline
                                  W Offline
                                  wibear
                                  #82
                                  Gibt's einen Grund, warum ich mit FileZilla grafana.ini nicht runterladen kann bzw. gibt's eine andere Möglichkeit zum Runterladen?
                                  Könnte mir bitte jemand für eine Analyse eine Beispiel grafana.ini zur Verfügung stellen?
                                  Danke.
                                  • W wibear
                                    Danke.
                                    Ro75R Offline
                                    Ro75R Offline
                                    Ro75
                                    #83
                                    @wibear Die eine Seite sollte der eigene und die andere Seite der "entfernte" Rechner sein. Normalerweise kann man die doch per Drag and Drop rüberziehen?
                                    Ro75.
                                    • W wibear
                                      Danke.
                                      #84
                                      Bestimmt. Aber ohne die Rechte des Users zu kennen kann ich dazu nix sagen.
                                      Aber warum willst du die Datei überhaupt runter und wieder raufladen?
                                      Viel zu umständlich. Du kommst doch per nano dran.
                                      • Ro75R Ro75
                                        Ro75.
                                        W Offline
                                        W Offline
                                        wibear
                                        #85
                                        @ro75
                                        Es funktioniert bei anderen Dateien, nicht aber bei grafana.ini, obwohl sie gleiche Berechtigungen haben.
                                        HomoranH Ro75R 2 Antworten Letzte Antwort
                                        • W wibear
                                          @ro75
                                          #86
                                          und welche?
