  4. [gelöst]Tankerkönig Widget konfigurieren
104 Beiträge 24 Kommentatoren 33.7k Aufrufe 8 Beobachtet
  • F Offline
    fuchs1978
    #66
    host.ioBroker-RasPi	2017-06-06 21:55:08.005	info	instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    tankerkoenig.0	2017-06-06 21:55:03.281	debug	redis publish io.system.adapter.tankerkoenig.0.alive {"val":false,"ack":true,"ts":1496778903281,"q":0,"from":"system.adapter.tankerkoenig.0","lc":1496778903281}
    tankerkoenig.0	2017-06-06 21:55:02.881	debug	redis mget 1 1
    tankerkoenig.0	2017-06-06 21:55:02.874	debug	redis publish io.system.adapter.tankerkoenig.0.outputCount {"val":8,"ack":true,"ts":1496778902873,"q":0,"from":"system.adapter.tankerkoenig.0","lc":1496179782508}
    tankerkoenig.0	2017-06-06 21:55:02.871	debug	redis publish io.system.adapter.tankerkoenig.0.inputCount {"val":0,"ack":true,"ts":1496778902870,"q":0,"from":"system.adapter.tankerkoenig.0","lc":1496179782506}
    tankerkoenig.0	2017-06-06 21:55:02.870	debug	redis publish io.system.adapter.tankerkoenig.0.uptime {"val":2,"ack":true,"ts":1496778902869,"q":0,"from":"system.adapter.tankerkoenig.0","lc":1496775902842}
    tankerkoenig.0	2017-06-06 21:55:02.867	debug	redis publish io.system.adapter.tankerkoenig.0.memHeapUsed {"val":12.85,"ack":true,"ts":1496778902867,"q":0,"from":"system.adapter.tankerkoenig.0","lc":1496778902867}
    tankerkoenig.0	2017-06-06 21:55:02.865	debug	redis publish io.system.adapter.tankerkoenig.0.memHeapTotal {"val":20.99,"ack":true,"ts":1496778902864,"q":0,"from":"system.adapter.tankerkoenig.0","lc":1496179782500}
    tankerkoenig.0	2017-06-06 21:55:02.862	debug	redis publish io.system.adapter.tankerkoenig.0.memRss {"val":37.43,"ack":true,"ts":1496778902862,"q":0,"from":"system.adapter.tankerkoenig.0","lc":1496778902862}
    tankerkoenig.0	2017-06-06 21:55:02.860	debug	redis publish io.system.adapter.tankerkoenig.0.connected {"val":true,"ack":true,"ts":1496778902858,"q":0,"from":"system.adapter.tankerkoenig.0","lc":1496778902858}
    tankerkoenig.0	2017-06-06 21:55:02.856	debug	redis publish io.system.adapter.tankerkoenig.0.alive {"val":true,"ack":true,"ts":1496778902856,"q":0,"from":"system.adapter.tankerkoenig.0","lc":1496778902856}
    tankerkoenig.0	2017-06-06 21:55:02.853	debug	redis keys 1 *.logging
    tankerkoenig.0	2017-06-06 21:55:02.780	debug	redis psubscribe io.tankerkoenig.0.checkLogging
    tankerkoenig.0	2017-06-06 21:55:02.753	debug	API Key Länge: 36 Zeichen
    tankerkoenig.0	2017-06-06 21:55:02.751	debug	Option is true
    tankerkoenig.0	2017-06-06 21:55:02.749	debug	initializing objects
    tankerkoenig.0	2017-06-06 21:55:02.742	info	starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.10.3
    tankerkoenig.0	2017-06-06 21:55:02.700	debug	redis get system.adapter.tankerkoenig.0.alive ok: {"val":false,"ack":true,"ts":1496778704021,"q":0,"from":"system.host.ioBroker-RasPi","lc":1496778699297}
    tankerkoenig.0	2017-06-06 21:55:02.686	info	States connected to redis 127.0.0.1:6379
    tankerkoenig.0	2017-06-06 21:55:02.675	debug	statesDB connected
    tankerkoenig.0	2017-06-06 21:55:02.626	debug	objectDB connected
    host.ioBroker-RasPi	2017-06-06 21:55:00.461	info	instance system.adapter.tankerkoenig.0 started with pid 12174
    • F Offline
      fuchs1978
      #67
      konnte jemand mit dem Log etwas anfangen? :?
      • F Offline
        fuchs1978
        #68
        Leider funktioniert es immer noch nicht. Mein Api Key funktioniert, zumindest kann ich auf der Webseite den Log laden. Dort sind einträge vorhanden, die mit einer Webanfrage gemacht wurde. Als Tankstelle habe ich 6b95334e-7674-4e0a-976e-0c15331116f0 aber leider keine Daten. Hat noch jemand eine Idee?
          AnthraX
          #69
          Ich habe genau das Gleiche Problem :(
          Ausserdem hab ich in der Vis das Problem, dass ich das Tankerkönig Widget nicht mehr löschen kann. Wenn ich es entferne bleibt die Cloud hängen - merke das aber erst wenn ich den Browser refreshe, dann sind natürlich alle danach bearbeitenden Inhalte auch weg.
          Insatlliert ist V1.0.4
          Das einzige dass im Log erscheint:
          host.IOBroker	2018-01-07 21:07:51.851	info	instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
          tankerkoenig.0	2018-01-07 21:07:46.695	debug	API Key Länge: 36 Zeichen
          tankerkoenig.0	2018-01-07 21:07:46.694	debug	Option is true
          tankerkoenig.0	2018-01-07 21:07:46.693	debug	initializing objects
          System: IoBroker auf Pi3, CCU2, Fritz!Box 6490
          Media: Synology NAS DS212+, Alexa, VU+Solo2
          Anzeige: Samsung Galaxy Note 10.1
          Heizung / Fenster: Homematic
          Lampen: Osram Lightify, Philips Hue, Sonoff-Basic WiFi Remote
          • wendy2702W Online
            wendy2702W Online
            #70
            @fuchs1978:
            Leider funktioniert es immer noch nicht. Mein Api Key funktioniert, zumindest kann ich auf der Webseite den Log laden. Dort sind einträge vorhanden, die mit einer Webanfrage gemacht wurde. Als Tankstelle habe ich 6b95334e-7674-4e0a-976e-0c15331116f0 aber leider keine Daten. Hat noch jemand eine Idee? `
            Ich habe es gerade mal mit deiner Tankstellen ID probiert und die funktioniert bei mir jedenfalls.
            Nutze allerdings kein "Redis", vielleicht liegt es daran.
            @AnthraX:
            Ausserdem hab ich in der Vis das Problem, dass ich das Tankerkönig Widget nicht mehr löschen kann. Wenn ich es entferne bleibt die Cloud hängen - merke das aber erst wenn ich den Browser refreshe, dann sind natürlich alle danach bearbeitenden Inhalte auch weg. `
            Wenn du es wie entfernst? Lokal verbunden oder über die Cloud oder meinst du der Cloud Adapter bleib hängen wenn du das Widget löschst?
              AnthraX
              #71
              @wendy2702:
              Wenn du es wie entfernst? Lokal verbunden oder über die Cloud oder meinst du der Cloud Adapter bleib hängen wenn du das Widget löschst? `
              lokal verbunden. Der Cloudadapter bleibt nicht hängen… aber im Browser wird ja ständig gespeichert wenn man was ändert... nachdem ich das Widget entferne wird nichts mehr gespeichert, ich kann auch nicht manuell speichern.
              Sieht so aus als bleibt die Seite hängen oder der Browser
              • wendy2702W Online
                wendy2702W Online
                #72
                Welchen Browser benutzt du?
                Mal anderen probiert bzw. Cache gelöscht?
                Welches Widget ist das denn, ich benutze da etwas eigenes und kenne das offizielle Widget nicht, wenn es denn eines ist.
                  AnthraX
                  #73
                  @wendy2702:
                  Welches Widget ist das denn, ich benutze da etwas eigenes und kenne das offizielle Widget nicht, wenn es denn eines ist. `
                  Benutze Chrome und das Standard Widget aus der Anleitung http://www.iobroker.net/docu/?page_id=4654&lang=de - Cache löschen brachte nichts.
                  Aber das mit der Vis finde ich nicht so schlimm… in erster Linie muss ich ja mal Daten in meine "states" bekommen.
                  • wendy2702W Online
                    wendy2702W Online
                    #74
                    Wie sieht denn dein Logfile für den Adapter aus?
                      AnthraX
                      #75
                      @wendy2702:
                      Wie sieht denn dein Logfile für den Adapter aus? `
                      Cloud:
                      cloud.0	2018-01-07 21:37:39.062	info	Connection changed: CONNECTED1
                      cloud.0	2018-01-07 21:37:28.699	info	2018-01-07T20:37:28.698Z Connected system.user.admin
                      cloud.0	2018-01-07 21:37:28.225	info	Connecting with xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                      cloud.0	2018-01-07 21:37:28.180	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.3
                      Vis:
                      vis.0	2018-01-07 21:38:25.046	info	vis license is OK.
                      vis.0	2018-01-07 21:38:19.473	info	starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.vis, node: v6.12.3
                      vis.0	2018-01-07 21:38:19.396	debug	statesDB connected
                      vis.0	2018-01-07 21:38:19.324	debug	objectDB connected
                      Host:
                      host.IOBroker	2018-01-07 21:40:07.690	info	instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                      host.IOBroker	2018-01-07 21:40:00.135	info	instance system.adapter.tankerkoenig.0 started with pid 4918
                      host.IOBroker	2018-01-07 21:38:26.233	info	instance system.adapter.vis.0 terminated while should be started once
                      host.IOBroker	2018-01-07 21:38:17.620	info	object change system.adapter.vis.0
                      host.IOBroker	2018-01-07 21:37:38.827	info	instance system.adapter.vis.0 terminated while should be started once
                      host.IOBroker	2018-01-07 21:37:30.114	info	object change system.adapter.vis.0
                      host.IOBroker	2018-01-07 21:37:25.710	info	instance system.adapter.cloud.0 started with pid 4699
                      host.IOBroker	2018-01-07 21:36:55.653	info	Restart adapter system.adapter.cloud.0 because enabled
                      host.IOBroker	2018-01-07 21:36:55.641	error	instance system.adapter.cloud.0 terminated with code 156 ()
                      host.IOBroker	2018-01-07 21:36:05.990	info	"system.adapter.vis.0" disabled
                      Also nichts dramatisches
                      • wendy2702W Online
                        wendy2702W Online
                        #76
                        Sorry,
                        ich meinte das Debug log vom Tankerkönig Adapter.
                          AnthraX
                          #77
                          tankerkoenig.0	2018-01-07 21:45:02.469	debug	API Key Länge: 36 Zeichen
                          tankerkoenig.0	2018-01-07 21:45:02.469	debug	Option is true
                          tankerkoenig.0	2018-01-07 21:45:02.469	debug	initializing objects
                          tankerkoenig.0	2018-01-07 21:45:02.469	info	starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.12.3
                          tankerkoenig.0	2018-01-07 21:40:02.648	debug	API Key Länge: 36 Zeichen
                          tankerkoenig.0	2018-01-07 21:40:02.648	debug	Option is true
                          tankerkoenig.0	2018-01-07 21:40:02.647	debug	initializing objects
                          tankerkoenig.0	2018-01-07 21:40:02.647	info	starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.12.3
                          tankerkoenig.0	2018-01-07 21:35:02.329	debug	API Key Länge: 36 Zeichen
                          • wendy2702W Online
                            wendy2702W Online
                            #78
                            Hast du das vorher so gemacht:
                            Dazu im Instanz-Reiter den Expertmodus einstellen (Männchen links oben) und dann in der tankerkoenig.0-Zeile von info auf debug stellen. Dann die Log-Ausgabe hier pasten. Du kannst sie vorher einmal durchgehen und sehen, ob du was anonymisieren willst.
                            Sieht ein wenig mager aus dein Output.
                            Bitte beim nächsten mal in Code tags posten.
                              AnthraX
                              #79
                              Ja das ist alles - abgesehen davon dass sich die selben Ausgaben immer wieder wiederholen.
                              • wendy2702W Online
                                wendy2702W Online
                                #80
                                Kannst du mal einen Screenshot der Adapter Konfig posten?
                                Tankstellen Keys hast du aber eingetragen, oder?
                                  AnthraX
                                  #81
                                  Naja besonders viel ist ja dort nicht einzustellen
                                  • wendy2702W Online
                                    wendy2702W Online
                                    #82
                                    Und du hast unter Objecten nichts?
                                    Sollte ungefähr so aussehen:
                                    Wie sieht das denn bei dir aus?
                                      AnthraX
                                      #83
                                      Bei Werten eben nichts
                                      Ich hab es jetzt im Laufe des Abends 3x neu installiert und paar mal neu gestartet. Habe auch nen Log von Tankerkönig angefordert.
                                      Ich denke da passt auch alles und bei dem Testlink auf Tankerkönig kommt ja eine neue Seite (dort soll doch aber nur eine Textausgabe erscheinen? - was sie tut)
                                      • wendy2702W Online
                                        wendy2702W Online
                                        #84
                                        Auf was für einem System läuft das?
                                        Hast du auf dem Objekte Reiter mal refresh gemacht? Also nicht den Browser refresh sondern das hier:
                                        Falls noch nicht probiert:
                                        Adapter stoppen
                                        Objekte löschen
                                        Adapter starten
                                        dabei das debug log vom Adapter mit laufen lassen.
                                        Benutzt du auch "Redis" ?
                                          AnthraX
                                          #85
                                          @wendy2702:
                                          Adapter stoppen
                                          Objekte löschen
                                          Adapter starten
                                          Benutzt du auch "Redis" ? `
                                          Habe ich alles schon gemacht.
                                          Läuft aufm RaspberryPi3
                                          Redis? Sagt mir (noch) nichts….
                                          Werde mir das ganze morgen nochmal anschauen und testen. Danke schonmal für deine Zeit
