  4. [gelöst]Tankerkönig Widget konfigurieren
104 Beiträge 24 Kommentatoren 33.7k Aufrufe 8 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    #74
    Wie sieht denn dein Logfile für den Adapter aus?
      AnthraX
      #75
      @wendy2702:
      Wie sieht denn dein Logfile für den Adapter aus? `
      Cloud:
      cloud.0	2018-01-07 21:37:39.062	info	Connection changed: CONNECTED1
      cloud.0	2018-01-07 21:37:28.699	info	2018-01-07T20:37:28.698Z Connected system.user.admin
      cloud.0	2018-01-07 21:37:28.225	info	Connecting with xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
      cloud.0	2018-01-07 21:37:28.180	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.3
      Vis:
      vis.0	2018-01-07 21:38:25.046	info	vis license is OK.
      vis.0	2018-01-07 21:38:19.473	info	starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.vis, node: v6.12.3
      vis.0	2018-01-07 21:38:19.396	debug	statesDB connected
      vis.0	2018-01-07 21:38:19.324	debug	objectDB connected
      Host:
      host.IOBroker	2018-01-07 21:40:07.690	info	instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
      host.IOBroker	2018-01-07 21:40:00.135	info	instance system.adapter.tankerkoenig.0 started with pid 4918
      host.IOBroker	2018-01-07 21:38:26.233	info	instance system.adapter.vis.0 terminated while should be started once
      host.IOBroker	2018-01-07 21:38:17.620	info	object change system.adapter.vis.0
      host.IOBroker	2018-01-07 21:37:38.827	info	instance system.adapter.vis.0 terminated while should be started once
      host.IOBroker	2018-01-07 21:37:30.114	info	object change system.adapter.vis.0
      host.IOBroker	2018-01-07 21:37:25.710	info	instance system.adapter.cloud.0 started with pid 4699
      host.IOBroker	2018-01-07 21:36:55.653	info	Restart adapter system.adapter.cloud.0 because enabled
      host.IOBroker	2018-01-07 21:36:55.641	error	instance system.adapter.cloud.0 terminated with code 156 ()
      host.IOBroker	2018-01-07 21:36:05.990	info	"system.adapter.vis.0" disabled
      Also nichts dramatisches
      System: IoBroker auf Pi3, CCU2, Fritz!Box 6490
      Media: Synology NAS DS212+, Alexa, VU+Solo2
      Anzeige: Samsung Galaxy Note 10.1
      Heizung / Fenster: Homematic
      Lampen: Osram Lightify, Philips Hue, Sonoff-Basic WiFi Remote
      • wendy2702W Online
        wendy2702W Online
        #76
        Sorry,
        ich meinte das Debug log vom Tankerkönig Adapter.
          AnthraX
          #77
          tankerkoenig.0	2018-01-07 21:45:02.469	debug	API Key Länge: 36 Zeichen
          tankerkoenig.0	2018-01-07 21:45:02.469	debug	Option is true
          tankerkoenig.0	2018-01-07 21:45:02.469	debug	initializing objects
          tankerkoenig.0	2018-01-07 21:45:02.469	info	starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.12.3
          tankerkoenig.0	2018-01-07 21:40:02.648	debug	API Key Länge: 36 Zeichen
          tankerkoenig.0	2018-01-07 21:40:02.648	debug	Option is true
          tankerkoenig.0	2018-01-07 21:40:02.647	debug	initializing objects
          tankerkoenig.0	2018-01-07 21:40:02.647	info	starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v6.12.3
          tankerkoenig.0	2018-01-07 21:35:02.329	debug	API Key Länge: 36 Zeichen
          • wendy2702W Online
            wendy2702W Online
            #78
            Hast du das vorher so gemacht:
            Dazu im Instanz-Reiter den Expertmodus einstellen (Männchen links oben) und dann in der tankerkoenig.0-Zeile von info auf debug stellen. Dann die Log-Ausgabe hier pasten. Du kannst sie vorher einmal durchgehen und sehen, ob du was anonymisieren willst.
            Sieht ein wenig mager aus dein Output.
            Bitte beim nächsten mal in Code tags posten.
              AnthraX
              #79
              Ja das ist alles - abgesehen davon dass sich die selben Ausgaben immer wieder wiederholen.
              • wendy2702W Online
                wendy2702W Online
                #80
                Kannst du mal einen Screenshot der Adapter Konfig posten?
                Tankstellen Keys hast du aber eingetragen, oder?
                  AnthraX
                  #81
                  Naja besonders viel ist ja dort nicht einzustellen
                  • wendy2702W Online
                    wendy2702W Online
                    #82
                    Und du hast unter Objecten nichts?
                    Sollte ungefähr so aussehen:
                    Wie sieht das denn bei dir aus?
                      AnthraX
                      #83
                      Bei Werten eben nichts
                      Ich hab es jetzt im Laufe des Abends 3x neu installiert und paar mal neu gestartet. Habe auch nen Log von Tankerkönig angefordert.
                      Ich denke da passt auch alles und bei dem Testlink auf Tankerkönig kommt ja eine neue Seite (dort soll doch aber nur eine Textausgabe erscheinen? - was sie tut)
                      • wendy2702W Online
                        wendy2702W Online
                        #84
                        Auf was für einem System läuft das?
                        Hast du auf dem Objekte Reiter mal refresh gemacht? Also nicht den Browser refresh sondern das hier:
                        Falls noch nicht probiert:
                        Adapter stoppen
                        Objekte löschen
                        Adapter starten
                        dabei das debug log vom Adapter mit laufen lassen.
                        Benutzt du auch "Redis" ?
                          AnthraX
                          #85
                          @wendy2702:
                          Adapter stoppen
                          Objekte löschen
                          Adapter starten
                          Benutzt du auch "Redis" ? `
                          Habe ich alles schon gemacht.
                          Läuft aufm RaspberryPi3
                          Redis? Sagt mir (noch) nichts….
                          Werde mir das ganze morgen nochmal anschauen und testen. Danke schonmal für deine Zeit
                          • wendy2702W Online
                            wendy2702W Online
                            #86
                            OK.
                            Bin jetzt auch gleich weg.
                            Bis dann.
                              AnthraX
                              #87
                              Guten Abend,
                              gerade wollte ich starten das Problem weiter anzugehen, stehen auf einmal Daten in den Objects…. keine Ahnung woran es lag zumindest empfängt und schreibt er jetzt die Spritpreise.
                              Nun geh das Widget Prob an...
                              • wendy2702W Online
                                wendy2702W Online
                                #88
                                Naja,
                                Das Widget kannst du dir im Prinzip bauen wie du willst.
                                Glaube es gibt im Forum auch einige Beispiele.
                                Viel Spaß und schön das es jetzt funktioniert.
                                • Raidy007R Offline
                                  Raidy007R Offline
                                  Raidy007
                                  #89
                                  Moin!
                                  Habe noch EIN Problem mit der Anzeige, ob die TS open oder closed ist!
                                  Nach dem folgenden Widget (Danke Rainer!) , wird es aber nicht mehr angezeigt, wenn die TS geschlossen ist!
                                  [{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"open","visibility-oid":"tankerkoenig.0.stations.2.status","html_prepend":"geöffnet","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"550px","top":"708px","width":"180px","height":"24px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(0, 255, 0)","padding-right":"","z-index":"5"},"widgetSet":"basic"}]
                                  Gibt es da einen neuen Ansatz? Ich würde einfach das widget immer anzeigen, aber mit geschlossen oder geöffnet und dann jeweils in rot oder grünem Hintergrund!
                                  Im readme von PIX steht:
                                  .station_open {
                                      color: blue;
                                  .station_closed {
                                      color: red !important; /* !important kann ggf. weggelassen werden */
                                  .station_notfound {
                                      color: yellow !important; /* !important kann ggf. weggelassen werden */
                                  /* € sign */
                                  .station_combined_euro {
                                      font-family: Times;
                                      font-size: 80%;
                                  Aber wo muss ich das eingeben und passt das widget überhaupt so? Wahrscheinlich nur eine Kleinigkeit , aber hat das schon jemand fehlerfrei lösen können? Wäre sehr dankbar für eine Hilfestellung!
                                  Raidy
                                  Viele Grüße
                                  Raidy
                                    #90
                                    @Raidy007:
                                    Nach dem folgenden Widget (Danke Rainer!) , wird es aber nicht mehr angezeigt, wenn die TS geschlossen ist! `
                                    Ich will mich nicht mit fremden Federn schmücken. Das Widget ist nicht von mir.
                                    Bei mir funktioniert es aber noch:
                                    • Raidy007R Offline
                                      Raidy007R Offline
                                      Raidy007
                                      #91
                                      Stimmt! Ich habe einen Fehler gemacht!
                                      Habe erst jetzt gesehen, dass "Offen" und "Geschlossen" 2 Widgets sind, die übereinander liegen!
                                      Jetzt funktioniert es bei mir auch wieder ;)
                                      Viele Grüße
                                      Raidy
                                        martin
                                        #92
                                        @Homoran:
                                        @Raidy007:
                                        Rainer `
                                        Ich bin VIS-Anfänger und leider noch nicht so fit. Könntest du mir dein View für den Tankerkönig zur Verfügung stellen, so dass ich es in meinem VIS importieren kann?
                                          So:
                                          [{"tpl":"tplImage","data":{"visibility-cond":"==","visibility-val":1,"refreshInterval":"0","refreshOnWakeUp":"false","refreshOnViewChange":"false","src":"/vis.0/bluefox_FlurTab/img/Tanken/Logo_Jet_Tanken.png","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"400px","top":"60px","width":"120px","z-index":"1"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.0.e5.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.0.e5.3rd","html_prepend":"E5","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"290px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.0.diesel.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.0.diesel.3rd","html_prepend":"Diesel","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"190px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.0.e10.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.0.diesel.3rd","html_prepend":"E10","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"240px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"visibility-oid":"","html_prepend":"Kölner Str.
                                           54","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"140px","width":"170px","height":"44px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(204, 204, 204) none repeat scroll 0% 0% / auto padding-box border-box","padding-right":"10px","padding-top":"0px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"open","visibility-oid":"tankerkoenig.0.stations.0.status","html_prepend":"geöffnet","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"340px","width":"180px","height":"24px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(0, 255, 0)","padding-right":"","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"closed","visibility-oid":"tankerkoenig.0.stations.0.status","html_prepend":"geschlossen","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"340px","width":"180px","height":"24px","color":"white","text-align":"center","font-size":"18px","background":"red","padding-right":"","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.0.diesel.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.0.diesel.3rd","html_prepend":"Diesel","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"190px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.0.e10.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.0.e10.3rd","html_prepend":"E10","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"240px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.0.e5.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.0.e5.3rd","html_prepend":"E5","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"290px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"visibility-oid":"","html_prepend":"","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"360px","top":"130px","width":"201px","height":"244px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(245, 245, 245) none repeat scroll 0% 0% / auto padding-box border-box","padding-right":"","padding-top":"0px","z-index":"","border-radius":"20px"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.1.e5.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.1.e5.3rd","html_prepend":"E5","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"580px","top":"290px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.1.diesel.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.1.diesel.3rd","html_prepend":"Diesel","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"580px","top":"190px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.1.e10.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.1.diesel.3rd","html_prepend":"E10","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"580px","top":"240px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"visibility-cond":"==","visibility-val":1,"refreshInterval":"0","refreshOnWakeUp":"false","refreshOnViewChange":"false","src":"/vis.0/bluefox_FlurTab/img/Tanken/Logo_Jet_Tanken.png","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"610px","top":"60px","width":"120px","z-index":"1"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"visibility-oid":"","html_prepend":"Strassburger Allee
                                           75","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"580px","top":"140px","width":"170px","height":"44px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(204, 204, 204) none repeat scroll 0% 0% / auto padding-box border-box","padding-right":"10px","padding-top":"0px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"open","visibility-oid":"tankerkoenig.0.stations.1.status","html_prepend":"geöffnet","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"580px","top":"340px","width":"180px","height":"24px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(0, 255, 0)","padding-right":"","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"closed","visibility-oid":"tankerkoenig.0.stations.1.status","html_prepend":"geschlossen","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"580px","top":"340px","width":"180px","height":"24px","color":"white","text-align":"center","font-size":"18px","background":"red","padding-right":"","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.1.diesel.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.1.diesel.3rd","html_prepend":"Diesel","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"580px","top":"190px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.1.e10.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.1.e10.3rd","html_prepend":"E10","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"580px","top":"240px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.1.e5.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.1.e5.3rd","html_prepend":"E5","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"580px","top":"290px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"visibility-oid":"","html_prepend":"","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"570px","top":"130px","width":"200px","height":"244px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(245, 245, 245) none repeat scroll 0% 0% / auto padding-box border-box","padding-right":"","padding-top":"0px","z-index":"","border-radius":"20px"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.2.e5.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.2.e5.3rd","html_prepend":"E5","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"790px","top":"290px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.2.diesel.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.2.diesel.3rd","html_prepend":"Diesel","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"790px","top":"190px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.2.e10.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.2.diesel.3rd","html_prepend":"E10","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"790px","top":"240px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"open","visibility-oid":"tankerkoenig.0.stations.2.status","html_prepend":"geöffnet","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"790px","top":"340px","width":"180px","height":"24px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(0, 255, 0)","padding-right":"","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"closed","visibility-oid":"tankerkoenig.0.stations.2.status","html_prepend":"geschlossen","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"790px","top":"340px","width":"180px","height":"24px","color":"white","text-align":"center","font-size":"18px","background":"red","padding-right":"","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.2.diesel.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.2.diesel.3rd","html_prepend":"Diesel","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"790px","top":"190px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.2.e10.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.2.e10.3rd","html_prepend":"E10","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"790px","top":"240px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.2.e5.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.2.e5.3rd","html_prepend":"E5","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"790px","top":"290px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"visibility-cond":"==","visibility-val":1,"refreshInterval":"0","refreshOnWakeUp":"false","refreshOnViewChange":"false","src":"/vis.0/bluefox_FlurTab/img/Tanken/Logo_Total_Tanken.jpg","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"820px","top":"60px","width":"120px","z-index":"1"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"visibility-oid":"","html_prepend":"Kölner Str.
                                           451","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"790px","top":"140px","width":"170px","height":"44px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(204, 204, 204) none repeat scroll 0% 0% / auto padding-box border-box","padding-right":"10px","padding-top":"0px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"visibility-oid":"","html_prepend":"","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"780px","top":"130px","width":"200px","height":"244px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(245, 245, 245) none repeat scroll 0% 0% / auto padding-box border-box","padding-right":"","padding-top":"0px","z-index":"","border-radius":"20px"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.3.e5.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.3.e5.3rd","html_prepend":"E5","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1000px","top":"290px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.3.diesel.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.3.diesel.3rd","html_prepend":"Diesel","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1000px","top":"190px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.3.e10.short","visibility-cond":"==","visibility-val":"9","visibility-oid":"tankerkoenig.0.stations.3.diesel.3rd","html_prepend":"E10","html_append":"<sup>9</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1000px","top":"240px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"open","visibility-oid":"tankerkoenig.0.stations.3.status","html_prepend":"geöffnet","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1000px","top":"340px","width":"180px","height":"24px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(0, 255, 0)","padding-right":"","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"closed","visibility-oid":"tankerkoenig.0.stations.3.status","html_prepend":"geschlossen","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1000px","top":"340px","width":"180px","height":"24px","color":"white","text-align":"center","font-size":"18px","background":"red","padding-right":"","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.3.diesel.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.3.diesel.3rd","html_prepend":"Diesel","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1000px","top":"190px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.3.e10.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.3.e10.3rd","html_prepend":"E10","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1000px","top":"240px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.3.e5.short","visibility-cond":"==","visibility-val":"4","visibility-oid":"tankerkoenig.0.stations.3.e5.3rd","html_prepend":"E5","html_append":"<sup>4</sup> €","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1000px","top":"290px","width":"170px","height":"40px","color":"ghostwhite","text-align":"right","font-size":"30px","background":"darkslategray","padding-right":"10px","padding-top":"4px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"visibility-cond":"==","visibility-val":1,"refreshInterval":"0","refreshOnWakeUp":"false","refreshOnViewChange":"false","src":"/vis.0/bluefox_FlurTab/img/Tanken/Logo_Star_Tanken.jpg","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1030px","top":"60px","width":"120px","z-index":"1"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"visibility-oid":"","html_prepend":"Kölner Str.
                                           69","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"1000px","top":"140px","width":"170px","height":"44px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(204, 204, 204) none repeat scroll 0% 0% / auto padding-box border-box","padding-right":"10px","padding-top":"0px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":1,"visibility-oid":"","html_prepend":"","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"990px","top":"130px","width":"200px","height":"244px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(245, 245, 245) none repeat scroll 0% 0% / auto padding-box border-box","padding-right":"","padding-top":"0px","z-index":"","border-radius":"20px"},"widgetSet":"basic"}]
                                          Der Sinn dieser Website ist es, dass man sich die Info da holen kann, indem man die Views editiert.
                                          KusselinK Offline
                                          KusselinK Offline
                                          Kusselin
                                          #93
                                          @Homoran sagte in [gelöst]Tankerkönig Widget konfigurieren:
                                          So:
                                          Hi Zusammen,
                                          wenn ich den kompletten Code kopiere und unter Widget importieren schiebe und abdrücke kommt folgende Meldung:
                                          Invalid JSON SyntaxError: JSON.parse: bad control character in string literal at line 1 column 4586 of the JSON data
                                          Kann da mal jemand drübersehen bitte.....
                                          Gruss
