  4. [gelöst] Objekte werden nicht mehr komplett angezeigt
23 Beiträge 7 Kommentatoren 3.5k Aufrufe 6 Beobachtet
  • Ro75R Ro75
    @hanss bitte mal
    iob diag
    Die Langfassung hier posten.
    Ro75.
    hanssH Offline
    hanssH Offline
    hanss
    @ro75
    bitte sehr:
    Skript v.2024-08-12
    *** BASE SYSTEM ***
       Static hostname: raspi4
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 4.19.97-v7l+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     17:42:58 up 108 days, 13:11,  3 users,  load average: 0.97, 0.89, 0.63
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2024-10-08 17:42:59 CEST
               Universal time: Tue 2024-10-08 15:42:59 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.9G        1.6G        642M        220M        1.7G        2.0G
    Swap:            0B          0B          0B
    Total:         3.9G        1.6G        642M
    Active iob-Instances:   12
             3906 M total memory
             1552 M used memory
             1890 M active memory
             1114 M inactive memory
              642 M free memory
              225 M buffer memory
             1485 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 17:42:59 up 108 days, 13:11,  3 users,  load average: 0.97, 0.89, 0.63
    Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.6 us,  3.8 sy,  0.0 ni, 93.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3906.0 total,    642.8 free,   1552.3 used,   1710.9 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1984.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   15G   14G  51% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     2.0G  189M  1.8G  10% /run
    tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   53M  200M  21% /boot
    /dev/sda1      fuseblk   932G   74G  858G   8% /media/exthd1
    tmpfs          tmpfs     391M  4.0K  391M   1% /run/user/1000
    tmpfs          tmpfs     391M     0  391M   0% /run/user/0
    [Sat Jun 22 04:31:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M video=HDMI-A-1:1280x1024M@60,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 smsc95xx.macaddr=DC:A6:32:22:D6:DF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e98175b2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): 8 orphan inodes deleted
    [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Jun 22 04:31:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Jun 22 04:31:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET                SOURCE         FSTYPE          OPTIONS
    /                     /dev/mmcblk0p2 ext4            rw,noatime
    |-/sys/fs/bpf         bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/exthd1       /dev/sda1      fuseblk         rw,noatime,user_id=0,group_id=0,allow_other,blksize=4096
    /var:
    2.7G    /var/
    1.2G    /var/lib
    894M    /var/log
    801M    /var/lib/mongodb
    769M    /var/lib/mongodb/journal
    Archived and active journals take up 186.8M in the file system.
    /opt/iobroker/backups:
    280M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    946M    /opt/iobroker/iobroker-data/
    781M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1e2c0fb9a112ec119d1720c7bd930c07-if00-port0
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
         18.20.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.3-1nodesource1 1001
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
     *** 18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi4                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspi4                                   -  enabled
    + system.adapter.email.0                  : email                 : raspi4                                   -  enabled
      system.adapter.flot.0                   : flot                  : raspi4                                   -  enabled
      system.adapter.ical.0                   : ical                  : raspi4                                   -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi4                                   -  enabled
    + system.adapter.iot.0                    : iot                   : raspi4                                   -  enabled
    + system.adapter.javascript.0             : javascript            : raspi4                                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspi4                                   -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shelly.0                 : shelly                : raspi4                                   -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : raspi4                                   -  enabled, port: 3306
    + system.adapter.tr-064.0                 : tr-064                : raspi4                                   -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspi4                                   -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspi4                                   -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi4                                   -  enabled
      system.adapter.vis-history.0            : vis-history           : raspi4                                   -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi4                                   -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi4                                   -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspi4                                   -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspi4                                   -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi4                                   -  enabled
      system.adapter.vis.0                    : vis                   : raspi4                                   -  enabled
    + system.adapter.web.0                    : web                   : raspi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspi4                                   -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        2521
    States:         2358
    E: Repository 'https://dl.ui.com/unifi/debian stable InRelease' changed its 'Codename' value from 'unifi-8.0' to 'unifi-8.4'
    Pending Updates: 87
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          16710      525/dnsmasq
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17596      523/sshd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       550045522  28427/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       550048124  28402/io.mqtt.0
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          20300      1044/smbd
    tcp        0      0 0.0.0.0:8800            0.0.0.0:*               LISTEN      0          188350090  12270/perl
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       550046775  28230/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       550046768  28230/iobroker.js-c
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          20301      1044/smbd
    tcp6       0      0 :::53                   :::*                    LISTEN      0          16712      525/dnsmasq
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17598      523/sshd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          15764      489/xrdp-sesman
    tcp6       0      0 :::3389                 :::*                    LISTEN      112        16862      527/xrdp
    tcp6       0      0 :::445                  :::*                    LISTEN      0          20298      1044/smbd
    tcp6       0      0 :::3306                 :::*                    LISTEN      113        539078977  29231/mysqld
    tcp6       0      0 :::139                  :::*                    LISTEN      0          20299      1044/smbd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       550046261  28253/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       550051163  28545/io.web.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          16709      525/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16706      525/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19573      412/dhcpcd
    udp        0      0 192.111.250.114:123     0.0.0.0:*                           105        21766      488/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          17569      488/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          17565      488/ntpd
    udp        0      0 192.111.250.255:137     0.0.0.0:*                           0          20655      443/nmbd
    udp        0      0 192.111.250.114:137     0.0.0.0:*                           0          20654      443/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          17686      443/nmbd
    udp        0      0 192.111.250.255:138     0.0.0.0:*                           0          20657      443/nmbd
    udp        0      0 192.111.250.114:138     0.0.0.0:*                           0          20656      443/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          17687      443/nmbd
    udp        0      0 192.111.250.114:5353    0.0.0.0:*                           1002       550049336  28478/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        14551      386/avahi-daemon: r
    udp        0      0 0.0.0.0:53053           0.0.0.0:*                           109        14553      386/avahi-daemon: r
    udp6       0      0 :::53                   :::*                                0          16711      525/dnsmasq
    udp6       0      0 2003:f2:e74d:9600:d:123 :::*                                105        550464595  488/ntpd
    udp6       0      0 fe80::dea6:32ff:fe2:123 :::*                                105        21570      488/ntpd
    udp6       0      0 ::1:123                 :::*                                0          17573      488/ntpd
    udp6       0      0 :::123                  :::*                                0          17562      488/ntpd
    udp6       0      0 :::5353                 :::*                                109        14552      386/avahi-daemon: r
    udp6       0      0 :::48575                :::*                                109        14554      386/avahi-daemon: r
    2024-10-08 17:32:11.217  - info: host.raspi4 instance system.adapter.ical.0 having pid 26355 terminated with code 0 (NO_ERROR)
    2024-10-08 17:33:00.024  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26440
    2024-10-08 17:33:11.192  - info: host.raspi4 instance system.adapter.ical.0 having pid 26440 terminated with code 0 (NO_ERROR)
    2024-10-08 17:34:00.043  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26526
    2024-10-08 17:34:11.225  - info: host.raspi4 instance system.adapter.ical.0 having pid 26526 terminated with code 0 (NO_ERROR)
    2024-10-08 17:35:00.044  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26625
    2024-10-08 17:35:11.464  - info: host.raspi4 instance system.adapter.ical.0 having pid 26625 terminated with code 0 (NO_ERROR)
    2024-10-08 17:36:00.039  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26715
    2024-10-08 17:36:11.118  - info: host.raspi4 instance system.adapter.ical.0 having pid 26715 terminated with code 0 (NO_ERROR)
    2024-10-08 17:37:00.043  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26793
    2024-10-08 17:37:11.459  - info: host.raspi4 instance system.adapter.ical.0 having pid 26793 terminated with code 0 (NO_ERROR)
    2024-10-08 17:38:00.046  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26877
    2024-10-08 17:38:11.153  - info: host.raspi4 instance system.adapter.ical.0 having pid 26877 terminated with code 0 (NO_ERROR)
    2024-10-08 17:39:00.032  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 27064
    2024-10-08 17:39:11.987  - info: host.raspi4 instance system.adapter.ical.0 having pid 27064 terminated with code 0 (NO_ERROR)
    2024-10-08 17:40:00.021  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 27474
    2024-10-08 17:40:15.259  - info: host.raspi4 instance system.adapter.ical.0 having pid 27474 terminated with code 0 (NO_ERROR)
    2024-10-08 17:40:16.180  - debug: host.raspi4 Incoming Host message getRepository
    2024-10-08 17:40:18.971  - debug: host.raspi4 Incoming Host message getInstalled
    2024-10-08 17:41:00.031  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 27964
    2024-10-08 17:41:11.357  - info: host.raspi4 instance system.adapter.ical.0 having pid 27964 terminated with code 0 (NO_ERROR)
    2024-10-08 17:42:00.066  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 28273
    2024-10-08 17:42:11.306  - info: host.raspi4 instance system.adapter.ical.0 having pid 28273 terminated with code 0 (NO_ERROR)
    2024-10-08 17:43:00.026  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 28631
    2024-10-08 17:43:12.092  - info: host.raspi4 instance system.adapter.ical.0 having pid 28631 terminated with code 0 (NO_ERROR)
    iob diag has finished.
    Ro75R 1 Antwort Letzte Antwort
    • hanssH hanss
      @ro75
      bitte sehr:
      Skript v.2024-08-12
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                RTC in local TZ: no
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            0B          0B          0B
               3906 M total memory
               1552 M used memory
                642 M free memory
                225 M buffer memory
               1485 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      2.7G    /var/
      1.2G    /var/lib
      894M    /var/log
      USB-Devices by-id:
      HINT:
      /dev/ttyUSB0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.1.5
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        2521
      States:         2358
      Pending Updates: 87
      Ro75R Online
      Ro75R Online
      Ro75
      schrieb am zuletzt editiert von Ro75
      @hanss sagte in Objekte werden nicht mehr komplett angezeigt:
      Dafür gibt es keine OS-Update mehr. Neuinstallation mit Debian 12 (Bookworm) 64Bit lite ohne Desktop
      [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): 8 orphan inodes deleted [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): recovery complete
      Dateisystem und / oder Datenträger defekt. Für Neuinstallation eine neuen Datenträger verwenden.
      Ro75
      EDIT: Backup hast du? Regelmäßig gesichert und extern aufbewahrt?
      hanssH 1 Antwort Letzte Antwort
      • Ro75R Ro75
        Ro75
        hanssH Offline
        hanssH Offline
        hanss
        @ro75
        Danke für den Tipp, aber das ist mir für den Bug zu viel Aufwand.
        • hanssH hanss
          @ro75
          Ro75R Online
          Ro75R Online
          Ro75
          @hanss DAS IST KEIN BUG. Dein Datenträger ist schrott! Damit sind Daten verschwunden, aufgrund einer defekten Hardware.
          Ro75.
          • Ro75R Ro75
            Ro75.
            hanssH Offline
            hanssH Offline
            hanss
            @ro75
            Warum sehe ich dann die Objekt z.B. im IOT Adapter, die ich im Admin nicht sehe?
            Ro75R Samson71S Jey CeeJ 3 Antworten Letzte Antwort
            • hanssH hanss
              @ro75
              Ro75R Online
              Ro75R Online
              Ro75
              @hanss Du hast um Hilfe gebeten. Ich habe dir gesagt, was nicht korrekt läuft und wo es Probleme gibt.
              Ro75.
              • hanssH hanss
                @ro75
                Samson71S Offline
                Samson71S Offline
                Samson71
                @hanss
                Unabhängig von den Ausführungen von @Ro75 ist Debian 10 tot. Das kann auch nicht auf Nodejs 20 upgedatet werden. Um eine Neuinstallation mit Debian 12 kommst Du daher so oder so nicht herum.
                Markus
                Bitte beachten:
                • Samson71S Samson71
                  @hanss
                  hanssH Offline
                  hanssH Offline
                  hanss
                  @samson71
                  in meinem ioBroker System stecken 4 Jahre Entwicklungsarbeit.
                  Da ist eine Neuinstallation schon eine Zumutung.
                  Samson71S CodierknechtC 2 Antworten Letzte Antwort
                  • hanssH hanss
                    @samson71
                    Samson71S Offline
                    Samson71S Offline
                    Samson71
                    @hanss
                    Glaube ich, verstehe ich, kann ich aber nicht ändern und ist eigentlich auch nicht weiter schlimm. Das haben alle mit Debian 10 als Basis entweder durch oder aber noch zwingend vor sich. Punkt.
                    Bei mir stecken mittlerweile knapp 10 Jahre drin. Dafür gibt es ja das Backup. Alles unter "alt" soweit aktualisieren wie möglich und dann eine Neuinstallation unter Debian 12 und das Backup einspielen.
                    Markus
                    Bitte beachten:
                    • hanssH hanss
                      @samson71
                      CodierknechtC Offline
                      Codierknecht
                      Eine Zumutung wäre, weiterhin ein totes Pferd zu reiten.
                      Du hast aktuelle Backups? Dann ist das Neuaufsetzen in max. 1-2 Stunden erledigt.
                      An Deiner Kiste ist so einiges im Argen:
                      1. Dein Datenträger ist Schrott
                      2. Dein OS ist tot
                      3. man fummelt nicht als root rum
                      4. auf einem Server betreibt man keinen Desktop
                      Und mit einem neuen OS hättest Du auch ein 64Bit-System.
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                      • CodierknechtC Codierknecht
                        2. Dein OS ist tot
                        hanssH Offline
                        hanssH Offline
                        hanss
                        @codierknecht
                        Wieso ist mein Datenträger "Schrott"?
                        • hanssH hanss
                          @codierknecht
                          Codierknecht
                          @hanss
                          Entweder hat das Dateisystem 'nen Schuss abgekriegt oder der Datenträger.
                          Dem Raspi mal plötzlich den Strom abgeknipst?
                          Ich würde dem der SD-Karte nicht mehr trauen und für die Neuinstallation einen neuen eine neue Karte nehmen.
                          Dann kann man im allergrößten Notfall auch nochmal an den alten die alte Karte ran.
                          • hanssH hanss
                            @ro75
                            Jey CeeJ Offline
                            Jey CeeJ Offline
                            Jey Cee
                            Spätestens hier hätte auch mal der Hinweis kommen können das womöglich ein Filter im Tab Objekte gesetzt sein könnte.
                            Check das mal.
                            Ansonsten haben die anderen schon recht, ein Update auf die Aktuelle Version des Betriebssystems solltest du machen.
                            Persönlicher Support
                            Spenden -> paypal.me/J3YC33
                            • Jey CeeJ Jey Cee
                              Check das mal.
                              hanssH Offline
                              hanssH Offline
                              hanss
                              @jey-cee
                              Danke, kein Filter gesetzt.
                              Inzwischen ist klar, die SD Karte ist defekt. Bei einem Neustart ist nicht einmal mehr
                              das OS hochgelaufen.
                              Dumm ist nur, dass bei einem 7 Tage altem Linux Backup ioBroker nicht mehr komplett hochfährt.
                              z.B. ist "Admin" permanent deaktiviert. Admin manuell aktivieren hilft nicht.
                              Ich bin jetzt 14Tage im Urlaub.
                              Danach werde ich mit neuem Raspbi4 8GB, neuer microSD Karte, Debian 12 64Bit neu aufsetzen.
                              Vielen Dank.
                              • hanssH hanss
                                @jey-cee
                                Vielen Dank.
                                Codierknecht
                                Es muss kein neuer Raspi sein. Neue SD-Karte reicht.
                                Ich habe meinen Post mal dahingehend korrigiert.
                                Aber 8 GB RAM sind auf jeden Fall besser als 4 und Du bist da für die Zukunft besser aufgestellt.
                                • hanssH hanss
                                  nachdem ich ein Script bearbeitet habe, kontrollierte ich ein Objekt,
                                  das ich vorher manuell angelegt hatte: 'javascript.0.Global.System.CPUTemp'
                                  Es war nicht mehr da, auch andere Objekte nicht mehr, z.B. zigbee.0 ist komplett leer,
                                  auch noch viele andere.
                                  System ist ein Raspi4 mit allen ioBroker Updates.
                                  Bitte um Hilfe, vielen Dank.
                                  ecki-noname
                                  Ich hatte ein Ähnliches Problem.
                                  Bei mir war in den Objekten ein Filter gesetzt.
                                  In den Spaltenüberschriften war ganz rechts ein X.
                                  Dieses habe ich betätigt und alles war wieder da.
                                  Mit freundlichen Grüßen
                                  Ro75R Samson71S 2 Antworten Letzte Antwort
                                  • E ecki-noname
                                    Ro75R Online
                                    Ro75R Online
                                    Ro75
                                    @ecki-noname lies doch bitte mal alles. Bei dir war es so (ODER AUCH ÄHNLICH UND NICHT GLEICH). Hier liegt es etwas anders.
                                    Ro75.
                                    • E ecki-noname
                                      Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      @ecki-noname
                                      Mann, Mann, Mann. 2 Beiträge über Deinem ist das gerade geklärt.
                                      Markus
                                      Bitte beachten:
                                        @ecki-noname
                                        hanssH Offline
                                        hanssH Offline
                                        hanss
                                        @samson71
                                        Problem gelöst:
                                        Nachdem auch noch der Admin nicht mehr aufzurufen war, neue MicroSD Karte besorgt
                                        und die Linux Datensicherung vom September aufgespielt.
                                        Objekte wurden noch immer nicht angezeigt:
                                        Cache vom Firefox gelöscht - Objekte werden wieder angezeigt!!!!
                                        Das war die Lösung.
                                        Ich habe mir damit wochenlange Arbeit erspart - funktioniert auch mit Debian 10!
                                        Thomas BraunT Samson71S 2 Antworten Letzte Antwort
                                        • hanssH hanss
                                          @samson71
                                          Problem gelöst:
                                          Das war die Lösung.
                                          @hanss sagte in [gelöst] Objekte werden nicht mehr komplett angezeigt:
                                          Debian 10 ist tot. Muss durch Debian 12 ersetzt werden.
