  4. Keinen Zugriff mehr auf ADMIN, VIS Oberfläche erreichbar
24 Beiträge 3 Kommentatoren 2.9k Aufrufe 3 Beobachtet
  • H haubada
    Es kam öfters die Fehlermeldung, dass JS-controller upgedated werden muss.
    Das geschieht ja wohl erst beim Befehle "iob upgrade self"
    Ist das ein Problem?
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade influxdb from @3.2.0 to @4.0.2 now? [(y)es, (n)o]: y
    Update influxdb from @3.2.0 to @4.0.2
    NPM version: 10.8.2
    Installing iobroker.influxdb@4.0.2... (System call)
    removed 1 package, and changed 1 package in 9s
    107 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.influxdb.0"
    upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/influxdb.png influxdb.png image/png
    upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonCustom.json jsonCustom.json application/json
    upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/javascript
    Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.17", required ">=5.0.19
    pi@raspberrypi:~ $ iob stop
    iob pi@raspberrypi:~ $ iob upgrade self
    Update js-controller from @5.0.17 to @6.0.11
    Stopped Objects DB
    Stopped States DB
    NPM version: 10.8.2
    Installing iobroker.js-controller@6.0.11... (System call)
    removed 32 packages, and changed 24 packages in 38s
    @haubada
    Deswegen solltest du ja nun auch nochmal
    iob diag
    anschauen.
    Was da noch nicht auf aktuellem Stand ist muss dann auch noch hochgezogen werden.
    H 1 Antwort Letzte Antwort
      @haubada
      iob diag
      anschauen.
      haubada
      schrieb am zuletzt editiert von haubada
      es scheint alles zu funktionieren außer beim Adapter rpi2.0 gibt es ein Problem mit GPIO 22.
      Diesen benutze ich als Eingang für meinen Gaszähler.
      Für mich sieht es aus als wäre er richtig eingestellt im Adapter aber es kommt immer die Fehlermeldung:
      rpi2.0	2024-09-25 07:29:15.776	error	Cannot setup port 22 as input: Error: EINVAL: invalid argument, write
      Woran könnte das liegen?
      Hier nochmal was passiert wenn ich den Adapter neu starte:
      rpi2.0	2024-09-25 07:35:01.209	error	Cannot setup port 22 as input: Error: EINVAL: invalid argument, write
      rpi2.0	2024-09-25 07:35:00.047	info	starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.17.0, js-controller: 6.0.1host.raspberrypi
      	2024-09-25 07:34:58.155	info	instance system.adapter.rpi2.0 in version "1.3.2" started with pid 37337
      host.raspberrypi
      	2024-09-25 07:34:57.200	info	"system.adapter.rpi2.0" enabled
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.47+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       07:37:32 up 14:40,  2 users,  load average: 0.64, 0.37, 0.28
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2024-09-25 07:37:32 CEST
                 Universal time: Wed 2024-09-25 05:37:32 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        1.4G        320M        1.2M        2.4G        2.6G
      Swap:           209M          0B        209M
      Total:          4.2G        1.4G        530M
      Active iob-Instances:   14
               3791 M total memory
               1299 M used memory
               1637 M active memory
               1612 M inactive memory
                305 M free memory
                133 M buffer memory
               2131 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 07:37:32 up 14:40,  2 users,  load average: 0.64, 0.37, 0.28
      Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.0 total,    303.8 free,   1300.8 used,   2264.5 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2491.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       29G  9.8G   18G  36% /
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Tue Sep 24 16:57:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:83:5A:17 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=194987c9-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GB
      [Tue Sep 24 16:57:30 2024] EXT4-fs (mmcblk0p2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
      [Tue Sep 24 16:57:32 2024] EXT4-fs (mmcblk0p2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE         FSTYPE      OPTIONS
      /                                                       /dev/mmcblk0p2 ext4        rw,noatime
      |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc           proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2384
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671168k,nr_inodes=417792,mode=755
      | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388300k,mode=755
      | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388296k,nr_inodes=97074,mode=700,uid=1000,gid=1000
      `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.8G    /var/
      2.2G    /var/log/journal/b656039fa4ae4234b58673c86559ff52
      2.2G    /var/log
      233M    /var/cache
      Archived and active journals take up 2.1G in the file system.
      /opt/iobroker/backups:
      71M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.8G    /opt/iobroker/iobroker-data/
      2.0G    /opt/iobroker/iobroker-data/history
      770M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.17.0-1nodesource1
        Version table:
       *** 20.17.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.2
      javascript:     8.7.6
      nodejs modules from github:     0
      Adapter State
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
        system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
        system.adapter.info.0                   : info                  : raspberrypi                              - disabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.2    , installed 7.1.2
      Adapter    "backitup"     : 3.0.22   , installed 2.8.1  [Updatable]
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "growatt"      : 3.2.5    , installed 3.2.5
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Objects and States
      Objects:        9924
      States:         7738
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       29734      5457/io.shelly.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2975       707/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27300      5303/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27295      5303/iobroker.js-co
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       25566      5321/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28145      5610/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       28973      5551/io.socketio.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          2977       707/sshd: /usr/sbin
      udp        0      0 0.0.0.0:51467           0.0.0.0:*                           104        2791       490/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2789       490/avahi-daemon: r
      udp6       0      0 :::40876                :::*                                104        2792       490/avahi-daemon: r
      udp6       0      0 fe80::526c:410f:553:546 :::*                                0          630        640/NetworkManager
      udp6       0      0 fe80::c80a:1d5b:320:546 :::*                                0          6180       640/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        2790       490/avahi-daemon: r
      2024-09-25 07:34:52.409  - info: rpi2.0 (37111) terminating
      2024-09-25 07:34:52.505  - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-09-25 07:34:55.887  - info: smartmeter.0 (5473) Received 22 values, 15 updated
      2024-09-25 07:34:57.200  - info: host.raspberrypi "system.adapter.rpi2.0" enabled
      2024-09-25 07:34:58.155  - info: host.raspberrypi instance system.adapter.rpi2.0 in version "1.3.2" started with pid 37337
      2024-09-25 07:35:00.047  - info: rpi2.0 (37337) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.17.0, js-controller: 6.0.11
      2024-09-25 07:35:01.209  - error: rpi2.0 (37337) Cannot setup port 22 as input: Error: EINVAL: invalid argument, write
      2024-09-25 07:35:06.871  - info: smartmeter.0 (5473) Received 22 values, 15 updated
      2024-09-25 07:35:17.848  - info: smartmeter.0 (5473) Received 22 values, 14 updated
      2024-09-25 07:35:28.835  - info: smartmeter.0 (5473) Received 22 values, 10 updated
      2024-09-25 07:35:39.828  - info: smartmeter.0 (5473) Received 22 values, 13 updated
      2024-09-25 07:35:50.863  - info: smartmeter.0 (5473) Received 22 values, 10 updated
      2024-09-25 07:36:01.839  - info: smartmeter.0 (5473) Received 22 values, 13 updated
      2024-09-25 07:36:12.851  - info: smartmeter.0 (5473) Received 22 values, 12 updated
      2024-09-25 07:36:23.845  - info: smartmeter.0 (5473) Received 22 values, 10 updated
      2024-09-25 07:36:34.850  - info: smartmeter.0 (5473) Received 22 values, 14 updated
      2024-09-25 07:36:45.854  - info: smartmeter.0 (5473) Received 22 values, 14 updated
      2024-09-25 07:36:56.869  - info: smartmeter.0 (5473) Received 22 values, 14 updated
      2024-09-25 07:37:07.873  - info: smartmeter.0 (5473) Received 22 values, 13 updated
      2024-09-25 07:37:18.883  - info: smartmeter.0 (5473) Received 22 values, 13 updated
      2024-09-25 07:37:29.820  - info: smartmeter.0 (5473) Received 22 values, 11 updated
      2024-09-25 07:37:40.835  - info: smartmeter.0 (5473) Received 22 values, 11 updated
      2024-09-25 07:37:51.875  - info: smartmeter.0 (5473) Received 22 values, 14 updated
      2024-09-25 07:38:02.881  - info: smartmeter.0 (5473) Received 22 values, 11 updated
      2024-09-25 07:38:13.857  - info: smartmeter.0 (5473) Received 22 values, 14 updated
      • H haubada
        host.raspberrypi
        Skript v.2024-05-22
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 3791 M total memory
                 1299 M used memory
                  305 M free memory
                  133 M buffer memory
                 2131 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        2.8G    /var/
        2.2G    /var/log
        233M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          7.1.2
        javascript:     8.7.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        9924
        States:         7738
        Pending Updates: 0
        @haubada
        Versuch mal den rpi2-Adapter in der Beta-Version 2.0.0.
        Und bring den backitup-Adapter auf Stand.
        Setzt den smartmeter-Adapter auf ein weniger gesprächiges LogLevel.
          @haubada
          haubada
          Ich hatte zwischenzeitlich probiert den rpi2 Adapter neu zu installieren.
          Jetzt kommen folgende Zeilen:
          rpi2.0
          	2024-09-25 15:39:45.027	info	terminating
          rpi2.0
          	2024-09-25 15:39:44.544	warn	Got terminate signal. Checking desired PID: 58268 vs own PID 58216
          host.raspberrypi
          	2024-09-25 15:39:44.537	info	instance system.adapter.rpi2.0 in version "1.3.2" started with pid 58268
          rpi2.0
          	2024-09-25 15:39:44.525	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          rpi2.0
          	2024-09-25 15:39:44.524	info	terminating
          rpi2.0
          	2024-09-25 15:39:44.521	warn	Got terminate signal. Checking desired PID: 0 vs own PID 58216
          rpi2.0
          	2024-09-25 15:39:16.508	error	Cannot setup port 22 as input: Error: EINVAL: invalid argument, write
          rpi2.0
          	2024-09-25 15:39:15.784	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30106780 10264812 18293656 36% / /1024
          rpi2.0
          	2024-09-25 15:39:15.782	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30106780 10264812 18293656 36% / /1024
          rpi2.0
          	2024-09-25 15:39:15.438	info	starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.17.0, js-controller: 6.0.11
          Ich probiert jetzt den Beta 2.0.0
          • H haubada
            rpi2.0
            rpi2.0
            host.raspberrypi
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            haubada
            Ich habe auf 2.0.0 upgedated.
            Nun kommen noch folgende Meldungen:
            rpi2.0
            	2024-09-25 16:01:26.740	error	Cannot initialize/setMode GPIO: Error: Cannot find module 'opengpio' Require stack: - /opt/iobroker/node_modules/iobroker.rpi2/lib/gpioControl.js - /opt/iobroker/node_modules/iobroker.rpi2/main.js
            rpi2.0
            	2024-09-25 16:01:25.325	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.17.0, js-controller: 6.0.11
            Ich habe nur den Befehl für Alpha 10 gefunden:
            iob upgrade rpi2@2.0.0-alpha.10
            Was muss ich für Beta eingeben?
            iob upgrade rpi2@2.0.0-beta
            • H haubada
              rpi2.0
              rpi2.0
              @haubada
              Nix, die 2.0.0 IST im Moment im Beta-Stage.
              Du musst den Adapter nur aus dem Beta-Repo oder den npm-Reiter installieren.
              Zuvor muss aber die libgpiod-dev installiert sein, damit opengpio gebaut werden kann.
              sudo apt update
              sudo apt install libgpiod-dev
              Und dann rpi2 nochmal installieren.
                @haubada
                sudo apt update
                haubada
                Hallo nochmal,
                ich habe alles so gemacht wie beschrieben.
                Bei der Instanz rpi2.0 steht v.2.0.0 dabei.
                Es kommt leider noch immer ein Error:
                rpi2.0	2024-09-25 20:33:33.686	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
                rpi2.0	2024-09-25 20:33:32.214	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.17.0, js-controller: 6.0.11
                • H haubada
                  Hallo nochmal,
                  @haubada
                  Ich meine das Thema sei bekannt. Hast du mal in die Issues zum Adapter geschaut?
                  Edit:
                  https://forum.iobroker.net/topic/75290/test-adapter-rpi2-2-x/126?_=1727290340474
                    @haubada
                    Edit:
                    haubada
                    Das es dieses Problem gibt habe ich mittlerweile auch schon heraus gefunden.
                    Ich habe diesen Post gefunden mit 159 Beiträgen:
                    https://forum.iobroker.net/topic/75290/test-adapter-rpi2-2-x/154
                    Ich bin ein Linux Leihe. Viele dieser Diskussionen verstehe ich einfach nicht und
                    ich konnte bisher keine Lösung darin erkennen.
                    Das ist leider auch der Grund warum so ungerne Updates mache.
                    Bisher was er jedes mal so, dass etwas danach nicht funktionert hat und ich letztendlich oft
                    eine komplett neue Installation aufsetzen musste.
                    Ich möchte hat nur ein System mit mein Homeassist, dass einfach nur läuft.
                    Ist nun die Antwort, dass es noch nicht gelöst wurde oder habe ich nur die Antwort bisher nicht gefunden.
                    Falls es eine einfache Antwort gäbe, wären bestimmt auch andere froh diese hier nach wenigen Posts zu finden.
                    Danke jedenfalls für den Support bisher.
                    Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                    • H haubada
                      @haubada
                      Wenn du den Thread zu Ende liest siehst du, das @searcher57 erst vor wenigen Stunden die von @Garfonso angefragten Informationen liefern konnte. Es wird daher wohl noch keinen Fix geben.
                      Das erfordert halt permanente Anpassungen und Updates.
                      • H haubada
                        CodierknechtC Offline
                        Codierknecht
                        @haubada sagte in Keinen Zugriff mehr auf ADMIN, VIS Oberfläche erreichbar:
                        Wie immer gilt auch hier:
                        Auch Deinen Mac/Windows-Rechner musst Du ständig mit Updates versorgen. Genau wie Dein Handy, Dein Tablet und heutzutage sogar Dein Auto.
                        Das sind in der Regel Sicherheitsupdates, weil irgend ein Fuchs wieder eine Schwachstelle gefunden hat, über die sich Schadcode einschleusen lässt o.ä.
                        In der Regel erwartet ein Anwender ja auch ein zeitgemäßes System. Darum gehen die Entwickler auch hin und verwenden an diversen Stellen ggf. neuere Funktionen, um das zu realisieren.
                        Diese neueren Funktionen muss der Unterbau (Linux, Node) anbieten. Auch dazu muss das Ganze regelmäßig auf aktuellem Stand gehalten werden.
                        Mit 'nem Windows-XP, iOS 12 oder Android 6 kommst Du heute auch nicht mehr weit.
                        HmIP|ZigBee|Tasmota|Unifi
                        Zabbix Certified Specialist
                        • CodierknechtC Codierknecht
                          haubada
                          @codierknecht
                          Es war nicht meine Absicht jemanden zu beleidigen.
                          Viele Leute stecken einiges an Aufwand rein, damit dieses Projekt läuft.
                          Mir ist klar, dass Updates notwendig sind um die Sicherheit zu gewährleisten.
                          Dennoch ist es aus Sicht eines Leihen oft schwierig die Programmierprobleme nachzuvollziehen und
                          aus den oft sehr langen Threads die Lösung herauszufinden.
                          • H haubada
                            @codierknecht
                            Codierknecht
                            Beleidigt dürfte sich auch niemand fühlen.
                            Der unschlagbare Vorteil von ioBroker ist auch gleichzeitig ein großer Nachteil: Es gibt Adapter für jeden Furz und Feuerstein. Teilweise mit nur 'ner handvoll Anwender. Die haben dann aber zwangsläufig nur wenige Tests durchlaufen und können demnach auch noch Fehler enthalten und die Stabilität des Gesamtsystems beeinträchtigen.
                            Das kann aber auch bei Adaptern mit großer Anwenderbasis der Fall sein. Der handelsübliche Anwender möchte einen Adapter einfach nur einsetzen. Zum Testen hat er wenig bis gar keine Lust.
                            Und ein Entwickler ist der denkbar schlechteste Tester - er weiß nämlich, was er wo einzustellen hat, welche Bedingungen einzuhalten sind und kommt gar nicht auf die Idee, die wildesten Kombinationen zu testen.
                            Dennoch ist es aus Sicht eines Laien oft schwierig die Programmierprobleme nachzuvollziehen
                            ioBroker ist ein kostenloses System und OpenSource. Genau wie das meist als Basis verwendete Linux.
                            Es liegt in der Natur der Sache, dass sowas häufigeren Änderungen unterliegt
                            Das liegt u.a. an den oben beschriebenen unterbliebenen Tests.
                            Es wird aber in der Regel auch sehr schnell auf Anwenderwünsche oder Sicherheitslücken reagiert.
                            Ein OpenSource-Projekt kann sich halt keine Testabteilung leisten. Das machen die Anwender.
                            Es steht jedem frei, auf ein anderes System zu wechseln und ggf. dafür zu bezahlen. Dann darf man auch mehr Qualität und eine bessere Dokumentation erwarten. Sonst nicht.
                            Es steht aber auch jedem frei, sich an der Entwicklung, den Tests oder der Doku zu beteiligen.
                            Und weil sich mein innerer Monk gerade meldet:
                            Ein Nicht-Profi ist ein "Laie". Mehrere davon sind "Laien".
                            "Leihen" kann man Bücher ;-)
                              haubada
                              @codierknecht
                              Vielleicht sollte ich mir wirklich mal ein Paar Linux Bücher ausleihen 😊
                              Wenn ich das Topic über den RPI2 Adpater so verfolge, scheint es nicht so,
                              als ob es da bald eine Lösung gäbe.
                              Wenn ist es bisher richtig verstanden habe, ist nicht die PI Verson 3, 4 oder 5 das Problem,
                              sondern das Update auf 12 Bookworm.
                              Kann ich mein System irgendwie wieder auf 11 Bullseye downgraden, damit es wieder funktioniert?
                              • H haubada
                                @codierknecht
                                @haubada
                                Da eigentliche Problem ist, das es für nodejs keine vollständig funktionierende Brücke zur libgpiod gibt.
                                Für andere Sprachen gibt es da wohl was.
                                Bullseye dürfte dir auch nichts nutzen, soweit ich weiß wird auch dort mittlerweile die libgpiod verwendet. Man hat den alten Zugang direkt in das System unterbunden. Deswegen funktioniert der rpi2-Adapter nicht mehr, da der diesen 'Schleichweg' halt verwendet hat.
                                  @haubada
                                  haubada
                                  Ich möchte meinen Gaszähler schon ganz gerne wieder auslesen.
                                  Vor dem Upgrade wie im 2. Post beschrieben habe eine SD Karten Sicherung gemacht.
                                  Ich könnte diese Version wieder zurück spielen.
                                  Welche Upgrades (bzw. Befehle) könnte ich ausführen um mein ursprüngliches Performance Problem
                                  (Zugriff auf ADMIN) evtl. zu verbesseren, aber nicht auf Bookworm bzw. neueste Nodejs upzudaten?
                                  Wäre das denkbar, oder macht das keinen Sinn?
                                  Mein Homeassists ist vorher auch gut gelaufen, es gab nur das Problem mit dem manchmal langsamen Adminzugriff.
                                  Thomas BraunT H 2 Antworten Letzte Antwort
                                  • H haubada
                                    Macht keinen Sinn mit abgekündigten Versionen zu hantieren.
                                    • H haubada
                                      haubada
                                      Ich habe heute den neue Adapter Version Rpi 2.2.1 installiert und nun funktioniert der GPIO 22 wieder.
                                      Jetzt wollte ich mein Javascript wieder aktivieren, doch leider erkennt er im Blockly den GPIO 22 nicht?
                                      Normal müsste ja über diesen Debug Code etwas ins Log file geschrieben werden, was jedoch nicht passiert.
                                      Wenn ich mir das Objekt GPIO 22 ansehen, welchselt es jedoch zwischen FALSE und TRUE hin und her.
                                      An was könnte das liegen?
                                      • H haubada
                                        haubada
                                        @haubada
                                        Ich glaube ich habs gefunden 😊
                                        Nach dem Update sind in meinen Blockly alle Debug von "Info" auf "Debug" gewechselt.
                                        Ich probiert jetzt auch wieder auf "INFO" umzustellen.
                                        • H haubada
                                          @haubada
                                          haubada
                                          Bei mir funktioniert jetzt wieder alles!!!
                                          Besten Dank an alle und dem Programmierer vom RPI2 Adatper Garfonso 👍
