  4. Error in GUI!
    1.9k
Error in GUI!
13 Beiträge 6 Kommentatoren 1.7k Aufrufe 4 Beobachtet
    thorkillar
    schrieb am zuletzt editiert von thorkillar
    Guten Abend liebe Gemeinschaft,
    ich habe seit dem letzten Update ein paar Probleme, wo ich nicht genau weis, wie ich sie beheben soll.
    Ich bekomme seit dem 20.09. folgende Fehlermeldung im Admin:
    If in the second line you will see at :3000/static/js/main.chunk.js:36903 and not the normal file name,
    please try to reproduce an error with opened browser console. In this case the special "map" files will be loaded and the developers can see the real name of functions and files.
    Minified React error #31; visit https://reactjs.org/docs/error-decoder.html?invariant=31&args[]=%5Bobject%20Error%5D for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
    Error: Minified React error #31; visit https://reactjs.org/docs/error-decoder.html?invariant=31&args[]=%5Bobject%20Error%5D for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
        at va (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:49950)
        at e (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:54963)
        at ko (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:73156)
        at xi (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:122082)
        at bs (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:109361)
        at vs (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:109289)
        at gs (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:109152)
        at as (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:105932)
        at ls (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:104483)
        at S (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:131248)
        at MessagePort.T (http://192.168.0.34:8081/static/js/5096.3a6e8bdb.chunk.js:2:131782)
    Leider weiß ich jetzt nicht, was ich machen kann. Der Admin schmiert mir immer innerhalb von ein paar Sekunden ab.
    Das Problem tritt erst auf, seit dem ich ein paar Updates durchgeführt habe und Node-Red installiert hatte.
    Updates:
    backitup 3.0.19 →3.0.22
    daswetter 3.1.15 →3.1.16
    discovery 4.5.0 →5.0.0
    pushover 3.0.6 →4.1.0
    admin 7.0.23 => 7.1.2
    Successfully upgraded admin to version 7.1.2
    $ iobroker add node-red --host iobroker
    NPM version: 10.8.1
    Installing iobroker.node-red@5.2.1... (System call)
    In der Console wird zeitgleich folgender Fehler ausgeworfen:
    Invalid group id "g00005" in widget "w00403"
    Invalid group id "g00005" in widget "w00404"
    Invalid group id "g00005" in widget "w00405"
    Invalid group id "g00005" in widget "w00406"
    Invalid group id "g00005" in widget "w00425"
    Invalid group id "g00005" in widget "w00393"
    Invalid group id "g00005" in widget "w00394"
    Invalid group id "g00005" in widget "w00395"
    Invalid group id "g00005" in widget "w00396"
    Invalid group id "g00005" in widget "w00397"
    Invalid group id "undefined" in widget "w01131"
    Invalid group id "undefined" in widget "w01133"
    Invalid group id "undefined" in widget "w01134"
    Invalid group id "undefined" in widget "w01220"
    Invalid group id "undefined" in widget "w01221"
    Invalid group id "undefined" in widget "w01222"
    Könnt Ihr mir sagen, was ich tun kann?
    • T thorkillar
      Updates:
      NPM version: 10.8.1
      CodierknechtC Offline
      Codierknecht
      @thorkillar sagte in Error in GUI!:
      Du könntest mal die Langfassung von
      iob diag
      zeigen.
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • CodierknechtC Codierknecht
        iob diag
        zeigen.
        thorkillar
        @codierknecht
        Sorry, so langsam sollte ich das ja wissen :-)
        Skript v.2024-05-22
        *** BASE SYSTEM ***
        Hardware Vendor : Synology Inc.
        Kernel          : x86_64
        Userland        : 64 bit
        Docker          : v9.1.2
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         18:07:44 up 165 days,  9:44,  0 user,  load average: 4.85, 4.67, 5.37
        CPU threads: 4
        *** Time and Time Zones ***
        Mon Sep 23 16:07:44 UTC 2024
        Mon Sep 23 18:07:44 CEST 2024
        CEST +0200
        Etc/UTC
        *** Users and Groups ***
        User that called 'iob diag':
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/opt/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             16G        9.6G        2.3G        382M        5.6G        7.1G
        Swap:            12G        5.5G        6.7G
        Total:           28G         15G        9.0G
        Active iob-Instances:   39
                15966 M total memory
                 9159 M used memory
                 4779 M active memory
                 5447 M inactive memory
                 2200 M free memory
                   20 M buffer memory
                 5277 M swap cache
                11627 M total swap
                 5236 M used swap
                 6391 M free swap
        top - 18:07:45 up 165 days,  9:44,  0 user,  load average: 4.78, 4.66, 5.36
        Tasks:  47 total,   5 running,  42 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 66.7 us, 33.3 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  15966.7 total,   2198.9 free,   9161.8 used,   5298.1 buff/cache
        MiB Swap:  11627.9 total,   6391.7 free,   5236.2 used.   6804.9 avail Mem
        *** FILESYSTEM ***
        Filesystem             Type   Size  Used Avail Use% Mounted on
        /dev/mapper/cachedev_0 btrfs   34T   27T  6.8T  80% /
        tmpfs                  tmpfs   64M     0   64M   0% /dev
        tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
        shm                    tmpfs   64M     0   64M   0% /dev/shm
        /dev/mapper/cachedev_0 btrfs   34T   27T  6.8T  80% /opt/iobroker
        /dev/mapper/cachedev_0 btrfs   34T   27T  6.8T  80% /etc/hosts
        tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/acpi
        tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/scsi
        tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/firmware
        Show mounted filesystems:
        TARGET                           SOURCE        FSTYPE OPTIONS
        /                                /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/4a23f0115e1c1f32770ab54ec1422dff1390d4fbbd0f37c1c194a4cfc44caa54]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=57211,subvol=/@syno/@docker/btrfs/subvolumes/4a23f0115e1c1f32770ab54ec1422dff1390d4fbbd0f37c1c194a4cfc44caa54
        |-/proc                          proc        proc   rw,nosuid,nodev,noexec,relatime
        | |-/proc/bus                    proc[/bus]        proc   ro,relatime
        | |-/proc/fs                     proc[/fs]        proc   ro,relatime
        | |-/proc/irq                    proc[/irq]        proc   ro,relatime
        | |-/proc/sys                    proc[/sys]        proc   ro,relatime
        | |-/proc/sysrq-trigger          proc[/sysrq-trigger]        proc   ro,relatime
        | |-/proc/acpi                   tmpfs        tmpfs  ro,relatime
        | |-/proc/kcore                  tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
        | |-/proc/keys                   tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
        | |-/proc/timer_list             tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
        | |-/proc/sched_debug            tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
        | `-/proc/scsi                   tmpfs        tmpfs  ro,relatime
        |-/dev                           tmpfs        tmpfs  rw,nosuid,size=65536k,mode=755
        | |-/dev/pts                     devpts        devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
        | |-/dev/mqueue                  mqueue        mqueue rw,nosuid,nodev,noexec,relatime
        | `-/dev/shm                     shm        tmpfs  rw,nosuid,nodev,noexec,relatime,size=65536k
        |-/sys                           sysfs        sysfs  ro,nosuid,nodev,noexec,relatime
        | |-/sys/firmware                tmpfs        tmpfs  ro,relatime
        | `-/sys/fs/cgroup               tmpfs        tmpfs  rw,nosuid,nodev,noexec,relatime,mode=755
        |   |-/sys/fs/cgroup/systemd     cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd
        |   |-/sys/fs/cgroup/synomonitor cgroup[/system.slice/pkg-Docker-dockerd.service]        cgroup ro,nosuid,nodev,noexec,relatime,name=synomonitor
        |   |-/sys/fs/cgroup/blkio       cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,blkio
        |   |-/sys/fs/cgroup/memory      cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,memory
        |   |-/sys/fs/cgroup/devices     cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,devices
        |   |-/sys/fs/cgroup/cpuacct     cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,cpuacct
        |   |-/sys/fs/cgroup/cpuset      cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,cpuset
        |   |-/sys/fs/cgroup/cpu         cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,cpu
        |   `-/sys/fs/cgroup/freezer     cgroup[/docker/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56]                                               cgroup ro,nosuid,nodev,noexec,relatime,freezer
        |-/opt/iobroker                  /dev/mapper/cachedev_0[/@syno/docker/iob24/prod]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=1750,subvol=/@syno/docker/iob24/prod
        |-/etc/resolv.conf               /dev/mapper/cachedev_0[/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/resolv.conf
        |-/etc/hostname                  /dev/mapper/cachedev_0[/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/hostname
        `-/etc/hosts                     /dev/mapper/cachedev_0[/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/bc844b075dafe94f8fe49ada033748faa69d0c52f568c218365748102c5c3b56/hosts
        /var:
        34M     /var/
        32M     /var/lib
        19M     /var/lib/apt/lists
        19M     /var/lib/apt
        13M     /var/lib/dpkg
        /opt/iobroker/backups:
        2.9G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.5G    /opt/iobroker/iobroker-data/
        1.1G    /opt/iobroker/iobroker-data/files
        765M    /opt/iobroker/iobroker-data/history
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        123M    /opt/iobroker/iobroker-data/objects.jsonl
        116M    /opt/iobroker/iobroker-data/states.jsonl
        65M     /opt/iobroker/iobroker-data/files/admin.0/zip/2024-09-20-scripts.zip
        45M     /opt/iobroker/iobroker-data/files/admin.0/zip/2024-06-25-scripts.zip
        43M     /opt/iobroker/iobroker-data/files/admin.0/zip/2024-04-29-scripts.zip
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.3
        /usr/bin/node           v18.20.3
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        /usr/bin/corepack       0.28.0
        nodejs:
          Installed: 18.20.3-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
             18.20.4-1nodesource1 1001
               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         *** 18.20.3-1nodesource1 1001
             18.20.2-1nodesource1 1001
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.2
        javascript:     8.7.6
        nodejs modules from github:     0
        Adapter State
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
        + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
          system.adapter.emby.0                   : emby                  : iobroker                                 - disabled
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
        + system.adapter.fb-checkpresence.1       : fb-checkpresence      : iobroker                                 -  enabled
        + system.adapter.fb-checkpresence.2       : fb-checkpresence      : iobroker                                 -  enabled
        + system.adapter.fb-checkpresence.3       : fb-checkpresence      : iobroker                                 -  enabled
        + system.adapter.fb-checkpresence.4       : fb-checkpresence      : iobroker                                 -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
        + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
        + system.adapter.hue.1                    : hue                   : iobroker                                 -  enabled, port: 80
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
          system.adapter.meteoalarm.0             : meteoalarm            : iobroker                                 -  enabled
        + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
        + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
        + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
          system.adapter.odl.0                    : odl                   : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled
          system.adapter.tibberlink.1             : tibberlink            : iobroker                                 - disabled
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        + system.adapter.webuntis.0               : webuntis              : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        │ (index) │   name   │                           url                           │ auto upgrade │
        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.2    , installed 7.1.2
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
        Adapter    "backitup"     : 3.0.22   , installed 3.0.22
        Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "emby"         : 1.2.0    , installed 1.2.0
        Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
        Adapter    "fullcalendar" : 2.4.2    , installed 2.4.2
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
        Adapter    "hue"          : 3.12.0   , installed 3.12.0
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
        Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "odl"          : 3.0.1    , installed 3.0.1
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "telegram-menu": 2.0.0    , installed 2.0.0
        Adapter    "tibberlink"   : 3.4.8    , installed 3.4.8
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
        Objects and States
        Objects:        60827
        States:         51137
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 33
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3815200672 -
        tcp        0      0 192.168.0.34:12010      0.0.0.0:*               LISTEN      1001       3815218166 -
        tcp        0      0 192.168.0.34:9292       0.0.0.0:*               LISTEN      1001       3815229505 -
        tcp        0      0 192.168.0.34:18701      0.0.0.0:*               LISTEN      1001       3835159089 -
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       3880989456 -
        tcp        0      0 192.168.0.34:12001      0.0.0.0:*               LISTEN      1001       3815216805 -
        tcp        0      0 127.0.0.11:37379        0.0.0.0:*               LISTEN      0          3815190854 -
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3815207997 -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3815213131 -
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3815240144 -
        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       3815318907 -
        udp        0      0 127.0.0.11:41346        0.0.0.0:*                           0          3815190853 -
        2024-09-23 18:07:52.401  - warn: javascript.0 (251)     at Fenster_und_T_C3_BCren (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:306:3648)
        2024-09-23 18:07:52.401  - warn: javascript.0 (251)     at processTicksAndRejections (node:internal/process/task_queues:95:5)
        2024-09-23 18:07:52.401  - warn: javascript.0 (251)     at New_Start_Zeile1 (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:29:8789)
        2024-09-23 18:07:52.401  - warn: javascript.0 (251)     at Object.<anonymous> (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:514:3)
        2024-09-23 18:08:00.024  - warn: javascript.0 (251) script.js.Prozesse.BVG-Live: request blockly block is deprecated - please use "http (GET)" instead
        2024-09-23 18:08:00.098  - warn: javascript.0 (251) script.js.Prozesse.BVG-Live-new: request blockly block is deprecated - please use "http (GET)" instead
        2024-09-23 18:08:10.023  - info: javascript.0 (251) script.js.Prozesse.Display.Tablet.Kalender.Kalender-Auslesen-Live: 📅TerminENDE: Training / 0 Stunden und 37 Min. / https://www.spielerplus.de/training/view?id=54362896
        2024-09-23 18:08:43.940  - warn: javascript.0 (251) script.js.Prozesse.Skriptübergreifende_Programme.Servicemeldungen_auslesen_und_weiter_verarbeiten: Servicemeldungen: 4
        2024-09-23 18:08:43.940  - warn: javascript.0 (251) script.js.Prozesse.Skriptübergreifende_Programme.Servicemeldungen_auslesen_und_weiter_verarbeiten: Korrigierte Servicemeldungen: 4
        2024-09-23 18:08:43.944  - warn: javascript.0 (251) getState "nuki-extended.0.smartlocks.zuhause.state.batteryChargeState" not found (3)
        2024-09-23 18:08:43.945  - warn: javascript.0 (251)     at Fenster_und_T_C3_BCren (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:306:3648)
        2024-09-23 18:08:43.945  - warn: javascript.0 (251)     at processTicksAndRejections (node:internal/process/task_queues:95:5)
        2024-09-23 18:08:43.945  - warn: javascript.0 (251)     at New_Start_Zeile1 (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:29:8789)
        2024-09-23 18:08:43.946  - warn: javascript.0 (251)     at START_1_2_3_new (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:21:3)
        2024-09-23 18:08:43.946  - warn: javascript.0 (251)     at Object.<anonymous> (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:408:3)
        2024-09-23 18:08:43.968  - warn: javascript.0 (251) getState "nuki-extended.0.smartlocks.zuhause.state.batteryChargeState" not found (3)
        2024-09-23 18:08:43.969  - warn: javascript.0 (251)     at Fenster_und_T_C3_BCren (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:306:3648)
        2024-09-23 18:08:43.969  - warn: javascript.0 (251)     at New_Start_Zeile1 (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:29:8789)
        2024-09-23 18:08:43.969  - warn: javascript.0 (251)     at START_1_2_3_new (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:21:3)
        2024-09-23 18:08:43.969  - warn: javascript.0 (251)     at Object.<anonymous> (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:408:3)
        2024-09-23 18:08:43.971  - warn: javascript.0 (251) getState "nuki-extended.0.smartlocks.zuhause.state.batteryChargeState" not found (3)
        2024-09-23 18:08:43.972  - warn: javascript.0 (251)     at Fenster_und_T_C3_BCren (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:306:3648)
        2024-09-23 18:08:43.972  - warn: javascript.0 (251)     at New_Start_Zeile1 (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:29:8789)
        2024-09-23 18:08:43.972  - warn: javascript.0 (251)     at START_1_2_3_new (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:21:3)
        2024-09-23 18:08:43.972  - warn: javascript.0 (251)     at Object.<anonymous> (script.js.Prozesse.Display.Tablet.Statusanzeige.Statusanzeige_Text_Rechts:429:3)
                                v.2024-05-22
        model name      : Intel(R) Atom(TM) CPU C3538 @ 2.10GHz
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.1.2
        Installation:           Docker
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               CEST +0200
        User-ID:                0
        Pending OS-Updates:     33
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        Recommended versions are nodejs 20.17.0 and npm 10.8.2
        MEMORY:
        Mem:             16G         10G        1.6G        383M        5.6G        6.6G
        Swap:            12G        5.5G        6.7G
        Total:           28G         15G        8.4G
        ioBroker Core:          js-controller           6.0.11
                                admin                   7.1.2
        Objects type: jsonl
        States  type: jsonl
        Objects:                60827
        States:                 51137
        Size of iob-Database:
        120M    /opt/iobroker/iobroker-data/states.jsonl
        • T thorkillar
          @codierknecht
          Skript v.2024-05-22
          *** BASE SYSTEM ***
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v9.1.2
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
          CEST +0200
          Etc/UTC
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/opt/iobroker
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:            12G        5.5G        6.7G
          Total:           28G         15G        9.0G
                   9159 M used memory
                   2200 M free memory
                     20 M buffer memory
                   5277 M swap cache
                  11627 M total swap
                   5236 M used swap
                   6391 M free swap
          *** FILESYSTEM ***
          /var:
          34M     /var/
          32M     /var/lib
          19M     /var/lib/apt
          13M     /var/lib/dpkg
          USB-Devices by-id:
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.1.2
          javascript:     8.7.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        60827
          States:         51137
          Pending Updates: 33
                                  v.2024-05-22
          Kernel          : x86_64
          Userland        : amd64
          Docker          : v9.1.2
          Kernel:                 x86_64
          Userland:               64 bit
          User-ID:                0
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          MEMORY:
          Swap:            12G        5.5G        6.7G
          Total:           28G         15G        8.4G
                                  admin                   7.1.2
          Objects type: jsonl
          States  type: jsonl
          Objects:                60827
          States:                 51137
          crunchipC Abwesend
          crunchipC Abwesend
          Solltest mal deine Blockly's überarbeiten
          Docker : v9.1.2
          Gibt's mittlerweile v10 incl. Nodejs v20
          Eventuell mal zurück auf 7.1.1 gehen oder aus dem Latest die v7. 1.3 fischen
          Edit:
          Ggf hilft auch ein iob upload all
          S T YodaY 3 Antworten Letzte Antwort
            Docker : v9.1.2
            Edit:
            S Nicht stören
            S Nicht stören
            stenmic
            ich hatte diese Fehlermeldung gestern auch einmal.
            Bei mir sollte eigentlich alles auf neustem Stand sein.
              Docker : v9.1.2
              Edit:
              thorkillar
              @crunchip Danke Dir.
              Die Blocklys überarbeite ich. (leider fehlt die Zeit)
              Docker werde ich am WE auf V10 updaten.
              iob upload all => hat bei mir leider nicht geholfen.
              Zum Glück tritt der Fehler nur sporadisch auf.
              eventuell mal zurück auf 7.1.1 => Habe ich durchgeführt.
              Melde mich, ob der Fehler wieder auftritt.
              DANKE
                Docker : v9.1.2
                Edit:
                YodaY Offline
                YodaY Offline
                Yoda
                @crunchip ich habe das Problem mit der GUI ebenfalls - sporadisch.
                Rasspi update habe ich grade zuvor gemacht, Problem besteht aber immer noch
                Liegt es an der Admin Version des Adapters?
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                 Static hostname: raspberrypi
                       Icon name: computer
                          Kernel: Linux 6.6.47+rpt-rpi-v8
                    Architecture: arm64
                Model           : Raspberry Pi 4 Model B Rev 1.2
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 64 bit
                 09:34:03 up 8 min,  2 users,  load average: 1.44, 2.44, 1.42
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                               Local time: Wed 2024-09-25 09:34:04 CEST
                           Universal time: Wed 2024-09-25 07:34:04 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            4.0G        2.2G        1.3G        1.2M        581M        1.8G
                Swap:           209M          0B        209M
                Total:          4.2G        2.2G        1.5G
                Active iob-Instances:   30
                         3791 M total memory
                         2078 M used memory
                         2111 M active memory
                          320 M inactive memory
                         1234 M free memory
                           56 M buffer memory
                          498 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                top - 09:34:04 up 8 min,  2 users,  load average: 1.44, 2.44, 1.42
                Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 57.1 id,  0.0 wa,  0.0 hi, 14.3 si,  0.0 st
                MiB Mem :   3792.0 total,   1232.5 free,   2079.3 used,    554.6 buff/cache
                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   1712.7 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                udev           devtmpfs  1.6G     0  1.6G   0% /dev
                tmpfs          tmpfs     380M  1.2M  379M   1% /run
                /dev/mmcblk0p2 ext4       59G   11G   45G  19% /
                tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                [Wed Sep 25 09:25:27 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.ena                                        ble_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B2:75:50 vc_mem.mem_base=0x3ec00                                        000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a6320af0-02 rootfstype=ext4 fsck.repair=yes root                                        wait cfg80211.ieee80211_regdom=DE
                [Wed Sep 25 09:25:30 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mod                                        e. Quota mode: none.
                [Wed Sep 25 09:25:31 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,me                                        mory_recursiveprot
                | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
                |-/proc                                                 proc           proc        rw,relatime
                | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5                                        ,maxproto=5,direct,pipe_ino=644
                |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671168k,nr_inodes=41                                        7792,mode=755
                | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmx                                        mode=000
                | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
                | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
                |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388300k,                                        mode=755
                | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
                | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388296k,nr_inod                                        es=97074,mode=700,uid=1000,gid=1000
                `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=43                                        7,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                934M    /var/
                355M    /var/log/journal/9cad1102edaf418c8a35375ebd8c4778
                355M    /var/log
                209M    /var/cache
                Archived and active journals take up 354.0M in the file system.
                383M    /opt/iobroker/backups/
                1.3G    /opt/iobroker/iobroker-data/
                408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                65M     /opt/iobroker/iobroker-data/objects.jsonl
                38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2153973-if00
                /usr/bin/nodejs         v20.17.0
                /usr/bin/node           v20.17.0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.29.3
                nodejs:
                  Installed: 20.17.0-1nodesource1
                  Candidate: 20.17.0-1nodesource1
                  Version table:
                 *** 20.17.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                        500 http://deb.debian.org/debian bookworm/main arm64 Packages
                        500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          7.1.2
                javascript:     8.7.6
                nodejs modules from github:     1
                +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#9c4635239c7                                        b9321601dcf0fcdd8677a55a8b13f)
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8                                        081, bind: 0.0.0.0, run as: admin
                + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                + system.adapter.cloud.3                  : cloud                 : raspberrypi                              -  enabled
                  system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                + system.adapter.email.1                  : email                 : raspberrypi                              -  enabled
                + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 4                                        43
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
                  system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1                                        886, bind: 0.0.0.0
                + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 8                                        0, 7575, 8000, 8080, 8081, 8899
                + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
                + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1                                        882, bind: 0.0.0.0
                + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8                                        087, bind: 0.0.0.0, run as: admin
                + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8                                        443, bind: 0.0.0.0
                + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                  system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              - disabled
                  system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
                  system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              - disabled
                + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                  system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                  system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                  system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
                  system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                  system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                  system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                  system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8                                        082, bind: 0.0.0.0, run as: admin
                + system.adapter.zendure-solarflow.0      : zendure-solarflow     : raspberrypi                              -  enabled
                + instance is alive
                Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                Adapter    "email"        : 1.3.1    , installed 1.3.1
                Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                Adapter    "hmip"         : 1.23.3   , installed 1.23.3
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                Adapter    "scenes"       : 3.2.1    , installed 3.2.1
                Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                Adapter    "vis-2-widgets-energy": 1.0.0, installed 1.0.0
                Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                Adapter    "zendure-solarflow": 1.8.5, installed 1.8.5
                Objects and States
                Objects:        42738
                States:         40264
                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       8406       992/io.mqtt.0
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       8405       992/io.mqtt.0
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       7764       999/io.shelly.0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7311       674/iobroker.js-con
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5503       674/iobroker.js-con
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7264       681/sshd: /usr/sbin
                tcp6       0      0 :::8095                 :::*                    LISTEN      1001       6121       1119/io.onvif.0
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       8553       1149/io.simple-api.
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3039       808/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7788       1224/io.web.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          7266       681/sshd: /usr/sbin
                udp        0      0 192.168.178.119:5353    0.0.0.0:*                           1001       6626       1010/io.tr-064.0
                udp        0      0 192.168.178.118:5353    0.0.0.0:*                           1001       6625       1010/io.tr-064.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6170       537/avahi-daemon: r
                udp        0      0 0.0.0.0:56598           0.0.0.0:*                           1001       14582      922/io.broadlink2.0
                udp        0      0 0.0.0.0:55300           0.0.0.0:*                           1001       7524       922/io.broadlink2.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5969       1017/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5970       1017/io.tuya.0
                udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       7521       922/io.broadlink2.0
                udp        0      0 0.0.0.0:47873           0.0.0.0:*                           104        6172       537/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        6171       537/avahi-daemon: r
                udp6       0      0 :::45355                :::*                                104        6173       537/avahi-daemon: r
                udp6       0      0 fe80::a516:5605:ab6:546 :::*                                0          6320       616/NetworkManager
                udp6       0      0 fe80::359:efc:16c4::546 :::*                                0          7299       616/NetworkManager
                Gruß Yoda
                Stand 05.2025
                Raspberry5,linux,arm64,CPUs:4,Geschwindigkeit:2400 MHz,Modell:Cortex-A76,RAM:15.8 GB,Node.js:v20.19.2
                • YodaY Yoda
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           209M          0B        209M
                           3791 M total memory
                           2078 M used memory
                           1234 M free memory
                             56 M buffer memory
                            498 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  *** FILESYSTEM ***
                  /var:
                  934M    /var/
                  355M    /var/log
                  209M    /var/cache
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          7.1.2
                  javascript:     8.7.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        42738
                  States:         40264
                  Pending Updates: 0
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @yoda sagte in Error in GUI!:
                  Möglicherweise
                  M YodaY 2 Antworten Letzte Antwort
                    Möglicherweise
                    MartyBr
                    @crunchip Ich habe das Problem mit einem Update auf die 7.1.3 behoben.
                    Der Rest ist Stabile.
                    Martin
                    Homematic und Homematic IP
                    • M MartyBr
                      MartyBr
                      @martybr
                      Noch eine Erklärung zum vorlaufenden Post:
                      Das Problem betraf Safari auf meinem Mac. Mit Google Chrome auf dem Mac hatte ich das Problem nicht. Das Update vom Admin auf die 7.1.3 behob das Problem mit Safari.
                      Martin
                        Möglicherweise
                        YodaY Offline
                        YodaY Offline
                        Yoda
                        @crunchip ich habe grade das update der Admin Version auf 7.1.5 durchgeführt, mal schauen ....
                        habe nun die Seite einige male neu geladen, bisher keinen Fehler.
                        Gruß Yoda
                        Stand 05.2025
                        • YodaY Yoda
                          MartyBr
                          @yoda
                          Die 7.1.5 läuft bei mir auch in Safari und Chrome auf dem Mac. Keine Login-Probleme .
                          Martin
                          • T thorkillar
                            DANKE
                            thorkillar
                            @crunchip
                            Hi, jetzt funktioniert es.
                            Update des Admin Adapters hat geholfen.
