  4. Multihost probleme ## Error: No configuration received! ##
28 Beiträge 9 Kommentatoren 4.8k Aufrufe 6 Beobachtet
  • D Dirk 0
    @homoran ...das wird etwas länglich...:
    Master:
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: raspi7
           Icon name: computer
              Kernel: Linux 6.6.31+rpt-rpi-2712
        Architecture: arm64
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     17:42:20 up  7:18,  5 users,  load average: 0.29, 0.14, 0.14
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-08-26 17:42:20 CEST
               Universal time: Mon 2024-08-26 15:42:20 UTC
                     RTC time: Mon 2024-08-26 15:42:20
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.4G        1.9G        1.3G         35M        5.4G        6.6G
    Swap:           209M          0B        209M
    Total:          8.7G        1.9G        1.5G
    Active iob-Instances:   17
             8052 M total memory
             1786 M used memory
             1794 M active memory
             4679 M inactive memory
             1234 M free memory
              224 M buffer memory
             4936 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 17:42:21 up  7:18,  5 users,  load average: 0.29, 0.14, 0.14
    Tasks: 231 total,   1 running, 227 sleeping,   3 stopped,   0 zombie
    %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8052.4 total,   1233.5 free,   1787.5 used,   5161.1 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6264.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     806M  6.0M  800M   1% /run
    /dev/nvme0n1p2 ext4      916G   14G  856G   2% /
    tmpfs          tmpfs     4.0G  288K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/nvme0n1p1 vfat      511M   76M  436M  15% /boot/firmware
    tmpfs          tmpfs     806M  160K  806M   1% /run/user/1000
    /dev/mmcblk0p2 ext4       29G  5.3G   22G  20% /media/pi/rootfs
    /dev/mmcblk0p1 vfat      510M   75M  436M  15% /media/pi/bootfs
    [Mon Aug 26 10:23:36 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:33:1F:89 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=da30460c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Mon Aug 26 10:23:37 2024] EXT4-fs (nvme0n1p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
    [Mon Aug 26 10:23:38 2024] EXT4-fs (nvme0n1p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
    [Mon Aug 26 10:23:42 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET                                                  SOURCE         FSTYPE          OPTIONS
    /                                                       /dev/nvme0n1p2 ext4            rw,noatime
    |-/sys                                                  sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security                                securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                                      cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore                                      pstore         pstore          rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                                         bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                                   debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing                                 tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config                                  configfs       configfs        rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections                            fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
    |-/proc                                                 proc           proc            rw,relatime
    | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5204
    |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc     rw,nosuid,nodev,noexec,relatime
    |-/dev                                                  udev           devtmpfs        rw,nosuid,relatime,size=3947856k,nr_inodes=246741,mode=755
    | |-/dev/pts                                            devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                                            tmpfs          tmpfs           rw,nosuid,nodev
    | `-/dev/mqueue                                         mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
    |-/run                                                  tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=824576k,mode=755
    | |-/run/lock                                           tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs      rw,relatime
    | `-/run/user/1000                                      tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=824560k,nr_inodes=206140,mode=700,uid=1000,gid=1000
    |   |-/run/user/1000/gvfs                               gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |   `-/run/user/1000/doc                                portal         fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot/firmware                                        /dev/nvme0n1p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    |-/media/pi/rootfs                                      /dev/mmcblk0p2 ext4            rw,nosuid,nodev,relatime,errors=remount-ro
    `-/media/pi/bootfs                                      /dev/mmcblk0p1 vfat            rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
    /var:
    1.2G    /var/
    613M    /var/cache
    606M    /var/cache/apt
    493M    /var/cache/apt/archives
    197M    /var/lib
    Archived and active journals take up 157.7M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    4.5G    /opt/iobroker/iobroker-data/
    3.7G    /opt/iobroker/iobroker-data/history
    710M    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.17.0
    /usr/bin/node           v20.17.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.17.0-1nodesource1
      Candidate: 20.17.0-1nodesource1
      Version table:
     *** 20.17.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.9
    admin:          7.0.23
    javascript:     8.7.6
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi7                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspi7                                   -  enabled
      system.adapter.denon.0                  : denon                 : raspi7                                   - disabled
    + system.adapter.discovery.0              : discovery             : raspi7                                   -  enabled
    + system.adapter.echarts.0                : echarts               : raspi7                                   -  enabled
      system.adapter.email.0                  : email                 : raspi7                                   - disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspi7                                   -  enabled
    + system.adapter.followthesun.0           : followthesun          : raspi7                                   -  enabled
    + system.adapter.history.0                : history               : raspi7                                   -  enabled
    + system.adapter.hue.0                    : hue                   : raspi7                                   -  enabled, port: 443
    + system.adapter.javascript.0             : javascript            : raspi7                                   -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : raspi7                                   -  enabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : raspi7                                   - disabled
      system.adapter.mobile.0                 : mobile                : raspi7                                   - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspi7                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : raspi7                                   -  enabled
      system.adapter.robonect.0               : robonect              : raspi7                                   - disabled
      system.adapter.rpi2.0                   : rpi2                  : raspi7                                   - disabled
      system.adapter.rpi2.1                   : rpi2                  : raspi7                                   - disabled
    + system.adapter.shelly.0                 : shelly                : raspi7                                   -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.signal-cmb.0             : signal-cmb            : raspi7                                   - disabled
      system.adapter.smartmeter.0             : smartmeter            : raspi7                                   - disabled
    + system.adapter.tibberlink.0             : tibberlink            : raspi7                                   -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspi7                                   -  enabled
    + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : raspi7                                   -  enabled
      system.adapter.vis-history.0            : vis-history           : raspi7                                   - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi7                                   - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspi7                                   - disabled
      system.adapter.vis.0                    : vis                   : raspi7                                   -  enabled
    + system.adapter.web.0                    : web                   : raspi7                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "backitup"     : 3.0.19   , installed 3.0.19
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "hue"          : 3.11.0   , installed 3.11.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
    Adapter    "mielecloudservice": 6.5.6, installed 6.5.6
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "robonect"     : 1.3.6    , installed 1.3.6
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "tibberlink"   : 3.4.8    , installed 3.4.8
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        5677
    States:         4871
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5908       839/cupsd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       61911      7189/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       61964      7249/io.mqtt.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7578       864/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       61486      6839/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       59849      6839/iobroker.js-co
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       62666      7200/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       59957      6949/io.admin.0
    tcp6       0      0 :::5900                 :::*                    LISTEN      992        4801       883/wayvnc
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5907       839/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7580       864/sshd: /usr/sbin
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       60255      7280/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       60256      7280/io.tuya.0
    udp        0      0 0.0.0.0:33123           0.0.0.0:*                           104        4617       678/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11498      1526/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4615       678/avahi-daemon: r
    udp6       0      0 :::56493                :::*                                104        4618       678/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4616       678/avahi-daemon: r
    2024-08-26 17:41:40.108  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 131 level: 0
    2024-08-26 17:41:41.987  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 140 level: 0
    2024-08-26 17:41:45.874  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 138 level: 0
    2024-08-26 17:41:50.002  - info: javascript.0 (7027) script.js.Gesamtleistung(Strom): Gesamtleistung: 292
    2024-08-26 17:41:53.206  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 137 level: 0
    2024-08-26 17:41:54.170  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 133 level: 0
    2024-08-26 17:41:57.124  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 136 level: 0
    2024-08-26 17:42:00.001  - info: javascript.0 (7027) script.js.Gesamtleistung(Strom): Gesamtleistung: 294
    2024-08-26 17:42:00.006  - info: javascript.0 (7027) script.js.Gesamtenergie(Strom): Gesamtenergie (Strom): 4895.099
    2024-08-26 17:42:00.009  - info: javascript.0 (7027) script.js.PVEigenverbrauch: PV Eigenverbrauch: 849.615
    2024-08-26 17:42:00.585  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 134 level: 0
    2024-08-26 17:42:04.376  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 133 level: 0
    2024-08-26 17:42:06.414  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 131 level: 0
    2024-08-26 17:42:09.926  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 130 level: 0
    2024-08-26 17:42:10.001  - info: javascript.0 (7027) script.js.Gesamtleistung(Strom): Gesamtleistung: 280
    2024-08-26 17:42:12.831  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 131 level: 0
    2024-08-26 17:42:15.761  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 126 level: 0
    2024-08-26 17:42:20.001  - info: javascript.0 (7027) script.js.Gesamtleistung(Strom): Gesamtleistung: 285
    2024-08-26 17:42:22.174  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 123 level: 0
    2024-08-26 17:42:28.180  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 129 level: 0
    2024-08-26 17:42:30.001  - info: javascript.0 (7027) script.js.Gesamtleistung(Strom): Gesamtleistung: 288
    2024-08-26 17:42:34.019  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 128 level: 0
    2024-08-26 17:42:37.422  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 146 level: 0
    2024-08-26 17:42:40.002  - info: javascript.0 (7027) script.js.Gesamtleistung(Strom): Gesamtleistung: 305
    2024-08-26 17:42:40.359  - info: javascript.0 (7027) script.js.Strom_0: aktuelle Leistung (W): 141 level: 0
    Slave:
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: raspi3
           Icon name: computer
              Kernel: Linux 6.6.31+rpt-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Kernel          : aarch64
    Userland        : 64 bit
     17:47:16 up  1:04,  2 users,  load average: 0.79, 0.24, 0.09
    CPU threads: 4
    Current issues:
    ~ Under-voltage detected
    ~ Arm frequency capped
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
                   Local time: Mon 2024-08-26 17:47:17 CEST
               Universal time: Mon 2024-08-26 15:47:17 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            951M        391M        309M        1.1M        308M        560M
    Swap:           209M          0B        209M
    Total:          1.2G        391M        518M
    Active iob-Instances:   4
              907 M total memory
              373 M used memory
              460 M active memory
               78 M inactive memory
              294 M free memory
               28 M buffer memory
              265 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 17:47:18 up  1:04,  2 users,  load average: 0.79, 0.24, 0.09
    Tasks: 149 total,   2 running, 147 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  6.7 us, 20.0 sy,  0.0 ni, 73.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    907.3 total,    293.1 free,    374.4 used,    294.7 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.    532.9 avail Mem
    *** FILESYSTEM ***
    udev           devtmpfs  318M     0  318M   0% /dev
    tmpfs          tmpfs      91M 1020K   90M   2% /run
    /dev/mmcblk0p2 ext4       29G  3.2G   25G  12% /
    tmpfs          tmpfs     454M     0  454M   0% /dev/shm
    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    [Mon Aug 26 16:43:03 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cda0b3af-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Mon Aug 26 16:43:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
    [Mon Aug 26 16:43:10 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
    /                                                       /dev/mmcblk0p2 ext4        rw,noatime
    | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1282
    |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=325396k,nr_inodes=81349,mode=755
    |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=92912k,mode=755
    | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=92908k,nr_inodes=23227,mode=700,uid=1000,gid=1000
    `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    669M    /var/
    205M    /var/cache
    200M    /var/cache/apt
    163M    /var/lib
    134M    /var/lib/apt/lists
    Archived and active journals take up 100.0M in the file system.
    13M     /opt/iobroker/backups/
    108M    /opt/iobroker/iobroker-data/
    57M     /opt/iobroker/iobroker-data/files
    38M     /opt/iobroker/iobroker-data/backup-objects
    31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    8.4M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.70cad8ba.js
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
    5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0049-if00-port0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    nodejs:
      Version table:
    Errors in npm tree:
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    admin:          7.0.23
    javascript:     "javascript" not found
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi3                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspi3                                   -  enabled
    + system.adapter.discovery.0              : discovery             : raspi3                                   -  enabled
    + instance is alive
    Objects and States
    Objects:        149
    States:         107
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Pending Updates: 0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4624       605/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4629       605/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1806       622/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4721       653/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1808       622/sshd: /usr/sbin
    udp        0      0 0.0.0.0:33918           0.0.0.0:*                           104        6287       452/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6285       452/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        6286       452/avahi-daemon: r
    udp6       0      0 :::36949                :::*                                104        6288       452/avahi-daemon: r
    2024-08-26 16:43:12.367  - info: host.raspi3 hostname: raspi3, node: v20.17.0
    2024-08-26 16:43:12.370  - info: host.raspi3 ip addresses: fe80::5e7a:a3b:deb7:57e9
    2024-08-26 16:43:15.497  - info: host.raspi3 connected to Objects and States
    2024-08-26 16:43:15.601  - info: host.raspi3 added notifications configuration of host
    2024-08-26 16:43:17.250  - info: host.raspi3 3 instances found
    2024-08-26 16:43:17.282  - info: host.raspi3 starting 3 instances
    2024-08-26 16:43:18.676  - info: host.raspi3 Delete state "system.host.raspi3.versions.nodeCurrent"
    2024-08-26 16:43:20.367  - info: host.raspi3 Delete state "system.host.raspi3.versions.nodeNewest"
    2024-08-26 16:43:20.391  - info: host.raspi3 Delete state "system.host.raspi3.versions.nodeNewestNext"
    2024-08-26 16:43:20.416  - info: host.raspi3 Delete state "system.host.raspi3.versions.npmCurrent"
    2024-08-26 16:43:20.440  - info: host.raspi3 Delete state "system.host.raspi3.versions.npmNewest"
    2024-08-26 16:43:20.470  - info: host.raspi3 Delete state "system.host.raspi3.versions.npmNewestNext"
    2024-08-26 16:43:20.492  - info: host.raspi3 Some obsolete host states deleted.
    2024-08-26 16:43:20.564  - info: host.raspi3 instance system.adapter.admin.0 in version "7.0.23" started with pid 653
    2024-08-26 16:43:22.761  - info: host.raspi3 instance system.adapter.backitup.0 in version "3.0.19" started with pid 660
    2024-08-26 16:43:26.874  - info: host.raspi3 instance system.adapter.discovery.0 in version "4.5.0" started with pid 667
    2024-08-26 16:43:33.491  - info: backitup.0 (660) starting. Version 3.0.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.9
    2024-08-26 16:43:33.892  - info: backitup.0 (660) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-08-26 16:43:34.273  - info: admin.0 (653) starting. Version 7.0.23 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.9
    2024-08-26 16:43:34.457  - info: admin.0 (653) requesting all objects
    2024-08-26 16:43:53.176  - info: admin.0 (653) received all objects
    2024-08-26 16:43:53.825  - info: discovery.0 (667) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.9
    2024-08-26 16:43:54.533  - info: admin.0 (653) socket.io server listening on port 8081
    2024-08-26 16:43:54.547  - info: admin.0 (653) http server listening on port 8081
    2024-08-26 16:43:54.550  - info: admin.0 (653) Use link "http://127.0.0.1:8081" to configure.
    ..das throttling von raspi3 ist bekannt - ich bekomme das leider mit diversen Netzteilen nicht gelöst - allerdings hatte das bislang außer der Meldung selbst keine Auswirkungen, auch als iob slave lief er bislang ohne Probleme.
    @dirk-0 sagte in Multihost probleme ## Error: No configuration received! ##:
    Adapter State
    auf dem slave muss keine Instanz existieren!
    und das Throttling ist dir bekannt.
    sollte aver wegen under-voltage an der Spannungsversorgung und eher nicht an over temperature liegen.
    Dann solltest du es mal über iob setup custom versuchen.
    Anfangen beim slave
      Adapter State
      Anfangen beim slave
      Dirk 0
      iob setup custom mit defaults hat leider nichts geändert.
      Hab noch alle instanzen des slave gelöscht - hat aber auch nichts gebracht.
      • D Dirk 0
        zeigen!!
        defaults werden nicht unbedingt deine Gegebenheiten widerspiegeln
          zeigen!!
          Dirk 0
          ...hmm, mir ist nicht ganz klar was es macht.
          Ich habe iob setup custom aufgerufen und bei allen Konfigurationen den default Wert bestätigt,
          ich vermute, die Konfiguration wird dadurch nicht geändert?
          pi@raspi7:~ $ iob setup custom
          Current configuration:
          - Objects database:
            - Type: jsonl
            - Host/Unix Socket: 0.0.0.0
            - Port: 9001
          - States database:
            - Type: jsonl
            - Port: 9000
          - Data Directory: ../../iobroker-data/
          Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
          Host / Unix Socket of objects DB(jsonl), default[0.0.0.0]:
          Port of objects DB(jsonl), default[9001]:
          Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [jsonl]:
          Host / Unix Socket of states DB (jsonl), default[0.0.0.0]:
          Port of states DB (jsonl), default[9000]:
          Data directory (file), default[../../iobroker-data/]:
          Host name of this machine [raspi7]:
          updating conf/iobroker.json
          pi@raspi7:~ $ iobroker restart
          pi@raspi7:~ $ iobroker multihost enable
          I HomoranH 2 Antworten Letzte Antwort
          • D Dirk 0
            - Objects database:
              - Type: jsonl
              - Port: 9001
            - States database:
              - Type: jsonl
              - Port: 9000
            I Offline
            I Offline
            innriver
            @dirk-0
            bei iob setup custom auf dem Slave muss die Host-Adresse des Masters rein nicht 0.0.0.0
            • D Dirk 0
              - Objects database:
                - Type: jsonl
                - Port: 9001
              - States database:
                - Type: jsonl
                - Port: 9000
              Hier die IP des Masters!
              bei Objects auch.
              BTW
              Hier ist der
              Master:
              Raspi7!!!
              wo bist du denn gerade?
                bei Objects auch.
                BTW
                Hier ist der
                Master:
                Raspi7!!!
                Dirk 0
                ja, das hat jetzt geklappt!! :) :) - Vielen lieben Dank!
                • D Dirk 0
                  Dirk 0
                  @dirk-0
                  statt IP geht auch der hostname:
                  pi@raspi3:~ $ iob setup custom
                  - Objects database:
                    - Type: jsonl
                    - Host/Unix Socket: raspi7
                    - Port: 9001
                  - States database:
                    - Type: jsonl
                    - Port: 9000
                  Host / Unix Socket of objects DB(jsonl), default[raspi7]:
                  Host / Unix Socket of states DB (jsonl), default[raspi7]:
                  Host name of this machine [raspi3]:
                  • D Dirk 0
                    @dirk-0
                    - Objects database:
                      - Type: jsonl
                      - Port: 9001
                    - States database:
                      - Type: jsonl
                      - Port: 9000
                    Ja, intern läuft es sowieso über den Hostnamen.
                    Deswegen ist es wichtig bei einer Neuinstallation den selnen Hostnamen zu verwenden
                    • von.cartmanV von.cartman
                      Hallo Zusammen,
                      ich versuche gerade ein Multihost aufzustellen.
                      Ich bekomme folgenden Fehlermeldung:
                       iobroker multihost connect
                      1 |         192.168.0.34 |  host |         192.168.0.34 | "authentication required"
                      Please select host [1]: 1
                      Enter secret phrase for connection: ****
                          at file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/src/lib/setup/setupMultihost.ts:339:26
                          at onFinished (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/src/lib/setup/multihostClient.ts:267:21)
                          at Timeout.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/src/lib/setup/multihostClient.ts:98:17)
                          at listOnTimeout (node:internal/timers:581:17)
                          at processTimers (node:internal/timers:519:7)
                      Beide Hosts sind von Software indentisch, Hardware ist unterschiedlich:
                      Master: Raspi5 und Slave: Raspi4
                      Für EURE Hilfe Vielen Dank im Voraus
                      mago
                      ich hänge mich hier mal dran da ich ein ähnliches Problem (mit derselben Fehlermeldung) habe.
                      Setup ist wie folgt:
                      iobroker Master als Proxmox LXC:
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                       Static hostname: iobroker
                             Icon name: computer-container
                               Chassis: container ☐
                        Virtualization: lxc
                                Kernel: Linux 6.8.12-2-pve
                          Architecture: x86-64
                      model name      : AMD Ryzen Embedded R1505G with Radeon Vega Gfx
                      Docker          : false
                      Virtualization  : lxc
                      Kernel          : x86_64
                      Userland        : 64 bit
                       08:42:55 up 1 day, 23:06,  2 users,  load average: 0.12, 0.14, 0.10
                      CPU threads: 2
                                     Local time: Wed 2024-09-25 08:42:55 CEST
                                 Universal time: Wed 2024-09-25 06:42:55 UTC
                                       RTC time: n/a
                                    NTP service: inactive
                                RTC in local TZ: no
                      root
                      HOME=/root
                      GROUPS=root
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Mem:            2.1G        1.3G        385M        114K        459M        845M
                      Swap:           536M          0B        536M
                      Total:          2.7G        1.3G        922M
                      Active iob-Instances:   16
                               2048 M total memory
                               1242 M used memory
                               1365 M active memory
                                230 M inactive memory
                                367 M free memory
                                  0 M buffer memory
                                438 M swap cache
                                512 M total swap
                                  0 M used swap
                                512 M free swap
                      top - 08:42:55 up 1 day, 23:06,  2 users,  load average: 0.12, 0.14, 0.10
                      Tasks:  41 total,   1 running,  40 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   2048.0 total,    365.9 free,   1243.8 used,    438.4 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.    804.2 avail Mem
                        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                      1 loaded units listed.
                      *** FILESYSTEM ***
                      Filesystem                       Type      Size  Used Avail Use% Mounted on
                      /dev/mapper/pve-vm--100--disk--0 ext4      7.8G  4.1G  3.4G  56% /
                      none                             tmpfs     492K  4.0K  488K   1% /dev
                      udev                             devtmpfs  2.9G     0  2.9G   0% /dev/tty
                      tmpfs                            tmpfs     2.9G     0  2.9G   0% /dev/shm
                      tmpfs                            tmpfs     1.2G  108K  1.2G   1% /run
                      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                      dmesg: read kernel buffer failed: Operation not permitted
                      /                                                       /dev/mapper/pve-vm--100--disk--0 ext4       rw,relatime,stripe=16
                      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=1196024k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                      | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                      | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                      |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                      | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
                      | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
                      | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
                      | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=2956268k,nr_inodes=739067,mode=755,inode64
                      | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=2956268k,nr_inodes=739067,mode=755,inode64
                      | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=2956268k,nr_inodes=739067,mode=755,inode64
                      | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=2956268k,nr_inodes=739067,mode=755,inode64
                      | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=2956268k,nr_inodes=739067,mode=755,inode64
                      | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=2956268k,nr_inodes=739067,mode=755,inode64
                      | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
                      | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
                      | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
                      | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
                      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
                        |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
                        |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
                        `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      /var:
                      419M    /var/
                      248M    /var/cache
                      245M    /var/cache/apt
                      169M    /var/cache/apt/archives
                      146M    /var/lib
                      Archived and active journals take up 24.0M in the file system.
                      42M     /opt/iobroker/backups/
                      816M    /opt/iobroker/iobroker-data/
                      552M    /opt/iobroker/iobroker-data/files
                      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      27M     /opt/iobroker/iobroker-data/states.jsonl
                      17M     /opt/iobroker/iobroker-data/objects.jsonl
                      14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                      USB-Devices by-id:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                              500 http://security.debian.org bookworm-security/main amd64 Packages
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      js-controller:  6.0.11
                      admin:          7.1.2
                      javascript:     8.7.6
                      Adapter State
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      + system.adapter.bshb.0                   : bshb                  : iobroker                                 -  enabled
                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                      + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
                      + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.signal-cmb.0             : signal-cmb            : iobroker                                 -  enabled
                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + instance is alive
                      Adapter    "admin"        : 7.1.2    , installed 7.1.2
                      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                      Adapter    "bshb"         : 0.2.8    , installed 0.2.8
                      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                      Controller "js-controller": 6.0.11   , installed 6.0.11
                      Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
                      Adapter    "radar2"       : 2.2.0    , installed 2.2.0
                      Adapter    "roborock"     : 0.6.4    , installed 0.6.4
                      Adapter    "socketio"     : 6.7.1    , installed 6.6.1  [Updatable]
                      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                      Adapter    "ws"           : 2.6.2    , installed 2.5.11 [Updatable]
                      Objects and States
                      Objects:        2276
                      States:         1810
                      Hit:1 http://security.debian.org bookworm-security InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8043       1/init
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       3970543    12894/iobroker.js-c
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       3969576    12894/iobroker.js-c
                      tcp        0      0 0.0.0.0:33881           0.0.0.0:*               LISTEN      104        12207      429/rpc.statd
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          12325      294/master
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       3974266    13186/io.shelly.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          8162       1/init
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          8045       1/init
                      tcp6       0      0 :::6824                 :::*                    LISTEN      1001       3974173    13130/io.roborock.0
                      tcp6       0      0 :::60975                :::*                    LISTEN      104        12213      429/rpc.statd
                      tcp6       0      0 :::7906                 :::*                    LISTEN      1001       3974174    13130/io.roborock.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3970869    13015/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3974533    13288/io.web.0
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          12326      294/master
                      udp        0      0 0.0.0.0:36378           0.0.0.0:*                           104        12204      429/rpc.statd
                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       3973433    13227/io.radar2.0
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          8044       1/init
                      udp        0      0 127.0.0.1:605           0.0.0.0:*                           0          12199      429/rpc.statd
                      udp6       0      0 :::58912                :::*                                104        12210      429/rpc.statd
                      udp6       0      0 :::111                  :::*                                0          8046       1/init
                      2024-09-25 08:41:50.551  - info: radar2.0 (13227) debug: and not here (iPhone-Patrizia)
                      2024-09-25 08:41:50.551  - info: radar2.0 (13227) debug: radar2 found uBT's: []
                      2024-09-25 08:41:50.551  - info: radar2.0 (13227) debug: radar2 found uIP's: []
                      2024-09-25 08:41:54.714  - warn: roborock.0 (13130) State "roborock.0.Devices.6OHbplLtKW1fSqmmRsscGx.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                      2024-09-25 08:41:54.853  - warn: roborock.0 (13130) Failed to map rooms. You need to name your rooms via the mobile app on your phone.
                      2024-09-25 08:42:17.304  - info: radar2.0 (13227) debug: ChangeState ack:true of Fritzbox._lastHere = 2024-09-25@08:42:17
                      2024-09-25 08:42:20.442  - info: radar2.0 (13227) debug: ChangeState ack:true of Xperia-Marco._lastHere = 2024-09-25@08:42:20
                      2024-09-25 08:42:20.450  - info: radar2.0 (13227) debug: ChangeState ack:true of Fritzbox._nHere = 1366
                      2024-09-25 08:42:20.454  - info: radar2.0 (13227) debug: ChangeState ack:true of Xperia-Marco._nHere = 272
                      2024-09-25 08:42:20.455  - info: radar2.0 (13227) debug: radar2 found here (Fritzbox, Xperia-Marco)
                      2024-09-25 08:42:20.455  - info: radar2.0 (13227) debug: and who here (Fritzbox, Xperia-Marco)
                      2024-09-25 08:42:20.455  - info: radar2.0 (13227) debug: and not here (iPhone-Patrizia)
                      2024-09-25 08:42:20.455  - info: radar2.0 (13227) debug: radar2 found uBT's: []
                      2024-09-25 08:42:20.455  - info: radar2.0 (13227) debug: radar2 found uIP's: []
                      2024-09-25 08:42:47.304  - info: radar2.0 (13227) debug: ChangeState ack:true of Fritzbox._lastHere = 2024-09-25@08:42:47
                      2024-09-25 08:42:50.441  - info: radar2.0 (13227) debug: ChangeState ack:true of Xperia-Marco._lastHere = 2024-09-25@08:42:50
                      2024-09-25 08:42:50.448  - info: radar2.0 (13227) debug: ChangeState ack:true of Fritzbox._nHere = 1367
                      2024-09-25 08:42:50.452  - info: radar2.0 (13227) debug: ChangeState ack:true of Xperia-Marco._nHere = 273
                      2024-09-25 08:42:50.453  - info: radar2.0 (13227) debug: radar2 found here (Fritzbox, Xperia-Marco)
                      2024-09-25 08:42:50.453  - info: radar2.0 (13227) debug: and who here (Fritzbox, Xperia-Marco)
                      2024-09-25 08:42:50.453  - info: radar2.0 (13227) debug: and not here (iPhone-Patrizia)
                      2024-09-25 08:42:50.454  - info: radar2.0 (13227) debug: radar2 found uBT's: []
                      2024-09-25 08:42:50.454  - info: radar2.0 (13227) debug: radar2 found uIP's: []
                      2024-09-25 08:42:54.725  - warn: roborock.0 (13130) State "roborock.0.Devices.6OHbplLtKW1fSqmmRsscGx.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                      2024-09-25 08:42:54.868  - warn: roborock.0 (13130) Failed to map rooms. You need to name your rooms via the mobile app on your phone.
                      ioBroker slave auf RPi3:
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                       Static hostname: heizpi
                             Icon name: computer
                                Kernel: Linux 6.6.47+rpt-rpi-v8
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       07:45:39 up 11:27,  2 users,  load average: 0.54, 0.20, 0.07
                      CPU threads: 4
                      Current issues:
                                     Local time: Wed 2024-09-25 07:45:39 BST
                                 Universal time: Wed 2024-09-25 06:45:39 UTC
                                       RTC time: n/a
                                      Time zone: Europe/London (BST, +0100)
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal: 	tty
                      *** MEMORY ***
                      Mem:            951M        198M        514M        1.1M        299M        752M
                      Swap:           209M          0B        209M
                      Total:          1.2G        198M        724M
                                907 M total memory
                                189 M used memory
                                268 M active memory
                                 64 M inactive memory
                                490 M free memory
                                 29 M buffer memory
                                256 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      top - 07:45:40 up 11:27,  2 users,  load average: 0.54, 0.20, 0.07
                      Tasks: 145 total,   1 running, 144 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 11.1 us,  0.0 sy,  0.0 ni, 77.8 id, 11.1 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :    907.3 total,    490.3 free,    190.0 used,    286.6 buff/cache
                      MiB Swap:    200.0 total,    200.0 free,      0.0 used.    717.3 avail Mem
                      *** FILESYSTEM ***
                      tmpfs          tmpfs      91M 1016K   90M   2% /run
                      /dev/mmcblk0p2 ext4       57G  3.5G   51G   7% /
                      [Tue Sep 24 20:17:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cb0e562e-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                      [Tue Sep 24 20:17:45 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                      [Tue Sep 24 20:17:49 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                      /                                                       /dev/mmcblk0p2 ext4        rw,noatime,commit=600
                      | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
                      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4006
                      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=325264k,nr_inodes=81316,mode=755
                      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=92904k,mode=755
                      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=92904k,nr_inodes=23226,mode=700,uid=1000,gid=1000
                      /var:
                      888M	/var/
                      470M	/var/cache
                      464M	/var/cache/apt
                      351M	/var/cache/apt/archives
                      166M	/var/lib
                      Archived and active journals take up 52.0M in the file system.
                      70M	/opt/iobroker/iobroker-data/
                      62M	/opt/iobroker/iobroker-data/files
                      31M	/opt/iobroker/iobroker-data/files/backitup.admin
                      5.0M	/opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm 		10.8.2
                      /usr/bin/npx 		10.8.2
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      At least one iobroker host is running.
                      Objects type: jsonl
                      States  type: jsonl
                      admin: 		7.1.2
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects: 	2276
                      States: 	1810
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5490       614/sshd: /usr/sbin
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          5492       614/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:42826           0.0.0.0:*                           104        5378       466/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5376       466/avahi-daemon: r
                      udp6       0      0 :::55563                :::*                                104        5379       466/avahi-daemon: r
                      udp6       0      0 fe80::275a:bd8e:c88:546 :::*                                0          10432      543/NetworkManager
                      udp6       0      0 :::5353                 :::*                                104        5377       466/avahi-daemon: r
                      2024-09-24 20:11:11.615  - info: host.heizpi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                      2024-09-24 20:11:11.618  - info: host.heizpi hostname: heizpi, node: v20.17.0
                      2024-09-24 20:11:11.621  - info: host.heizpi ip addresses: 192.168.178.42 2003:c0:5706:d400:f585:3f06:acba:beee fe80::275a:bd8e:c889:ff42
                      2024-09-24 20:11:12.699  - info: host.heizpi connected to Objects and States
                      2024-09-24 20:11:12.790  - info: host.heizpi added notifications configuration of host
                      2024-09-24 20:11:15.029  - info: host.heizpi 15 instances found
                      2024-09-24 20:11:15.057  - warn: host.heizpi does not start any instances on this host
                      2024-09-24 20:11:27.955  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                      2024-09-24 20:11:27.965  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                      2024-09-24 20:11:32.963  - info: host.heizpi Objects database successfully reconnected
                      2024-09-24 20:11:32.975  - info: host.heizpi Objects database successfully reconnected
                      2024-09-24 20:17:29.887  - info: host.heizpi received SIGTERM
                      2024-09-24 20:17:30.180  - info: host.heizpi terminated
                      2024-09-24 20:17:49.149  - info: host.heizpi iobroker.js-controller version 6.0.11 js-controller starting
                      2024-09-24 20:17:49.161  - info: host.heizpi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                      2024-09-24 20:17:49.164  - info: host.heizpi hostname: heizpi, node: v20.17.0
                      2024-09-24 20:17:49.167  - info: host.heizpi ip addresses: 192.168.178.42 2003:c0:5706:d400:f585:3f06:acba:beee fe80::275a:bd8e:c889:ff42
                      2024-09-24 20:17:49.807  - info: host.heizpi connected to Objects and States
                      2024-09-24 20:17:49.866  - info: host.heizpi added notifications configuration of host
                      2024-09-24 20:17:51.449  - info: host.heizpi 15 instances found
                      2024-09-24 20:17:51.477  - warn: host.heizpi does not start any instances on this host
                      2024-09-24 20:18:27.532  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                      2024-09-24 20:18:27.541  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                      2024-09-24 20:18:32.557  - info: host.heizpi Objects database successfully reconnected
                      2024-09-24 20:18:32.562  - info: host.heizpi Objects database successfully reconnected
                      Mir fallen da spontan folgende beiden Zeilen auf:
                      Verbindung zwischen den beiden Geräten steht prinzipiell, auch ist der Master beim Verbindungsversuch "sichtbar" und auswählbar.
                      • M mago
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 2
                                         RTC time: n/a
                                  RTC in local TZ: no
                        root
                        HOME=/root
                        GROUPS=root
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Swap:           536M          0B        536M
                                 2048 M total memory
                                 1242 M used memory
                                  367 M free memory
                                    0 M buffer memory
                                  438 M swap cache
                                  512 M total swap
                                    0 M used swap
                                  512 M free swap
                        *** FILESYSTEM ***
                        /var:
                        419M    /var/
                        248M    /var/cache
                        245M    /var/cache/apt
                        146M    /var/lib
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          7.1.2
                        javascript:     8.7.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        2276
                        States:         1810
                        Pending Updates: 0
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal: 	tty
                        *** MEMORY ***
                        Swap:           209M          0B        209M
                                  907 M total memory
                                  189 M used memory
                                  268 M active memory
                                  490 M free memory
                                   29 M buffer memory
                                  256 M swap cache
                                  199 M total swap
                                    0 M used swap
                                  199 M free swap
                        *** FILESYSTEM ***
                        /var:
                        888M	/var/
                        470M	/var/cache
                        464M	/var/cache/apt
                        166M	/var/lib
                        USB-Devices by-id:
                        /usr/bin/npm 		10.8.2
                        /usr/bin/npx 		10.8.2
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin: 		7.1.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects: 	2276
                        States: 	1810
                        Pending Updates: 0
                        @mago
                        Hampel nicht als root herum.
                        Setz das boot target auf multi-user.
                        Bring die Adapter auf einen aktuellen Stand.
                        Setz die Zeitzone auf dem Pi3 richtig.
                          @mago
                          mago
                          Danke für die schnelle Antwort!
                          Die root-Thematik ist mir grundsätzlich bekannt, hatte halt grad eine Konsole offen und dachte für iob diag ist es egal. Kann aber tatsächlich sein, dass ich iob multihost enable mit root aufgerufen habe.
                          boot target und updates sind angewandt, auch die Zeitzone ist gefixt. Wegen o.g. Fauxpas habe ich iob fix über den LXC laufen lassen. Stand jetzt:
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                           10:04:21 up 34 min,  2 users,  load average: 0.27, 0.10, 0.03
                          CPU threads: 4
                          Current issues:
                                         Local time: Wed 2024-09-25 10:04:21 CEST
                                     Universal time: Wed 2024-09-25 08:04:21 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal: 	tty
                          *** MEMORY ***
                          Mem:            951M        190M        596M        1.1M        221M        761M
                          Swap:           209M          0B        209M
                          Total:          1.2G        190M        806M
                          Active iob-Instances: 	11
                                    907 M total memory
                                    181 M used memory
                                    206 M active memory
                                     60 M inactive memory
                                    568 M free memory
                                     23 M buffer memory
                                    187 M swap cache
                                    199 M total swap
                                      0 M used swap
                                    199 M free swap
                          top - 10:04:22 up 34 min,  2 users,  load average: 0.27, 0.10, 0.03
                          Tasks: 146 total,   1 running, 145 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  0.0 us, 22.2 sy,  0.0 ni, 77.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :    907.3 total,    567.0 free,    182.9 used,    211.8 buff/cache
                          MiB Swap:    200.0 total,    200.0 free,      0.0 used.    724.4 avail Mem
                          *** FILESYSTEM ***
                          tmpfs          tmpfs      91M  1.1M   90M   2% /run
                          [Wed Sep 25 09:30:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cb0e562e-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                          [Wed Sep 25 09:30:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                          [Wed Sep 25 09:30:30 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                          | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4430
                          /var:
                          888M	/var/
                          470M	/var/cache
                          464M	/var/cache/apt
                          166M	/var/lib
                          USB-Devices by-id:
                          /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
                          /usr/bin/npm 		10.8.2
                          /usr/bin/npx 		10.8.2
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin: 		7.1.2
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects: 	2275
                          States: 	1805
                          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5014       627/sshd: /usr/sbin
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          5016       627/sshd: /usr/sbin
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3463       478/avahi-daemon: r
                          udp        0      0 0.0.0.0:55097           0.0.0.0:*                           104        3465       478/avahi-daemon: r
                          udp6       0      0 fe80::275a:bd8e:c88:546 :::*                                0          6095       542/NetworkManager
                          udp6       0      0 :::34389                :::*                                104        3466       478/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                104        3464       478/avahi-daemon: r
                          2024-09-25 08:55:04.367  - error: host.heizpi States database error: connect ETIMEDOUT
                          2024-09-25 08:55:17.488  - info: host.heizpi Objects database successfully reconnected
                          2024-09-25 08:55:17.493  - info: host.heizpi Objects database successfully reconnected
                          2024-09-25 09:00:29.933  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                          2024-09-25 09:00:29.937  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                          2024-09-25 09:00:34.953  - info: host.heizpi Objects database successfully reconnected
                          2024-09-25 09:00:34.963  - info: host.heizpi Objects database successfully reconnected
                          2024-09-25 09:01:04.540  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                          2024-09-25 09:01:04.561  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                          2024-09-25 09:01:09.560  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                          2024-09-25 09:01:09.578  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                          2024-09-25 09:01:14.570  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                          2024-09-25 09:01:14.601  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                          2024-09-25 09:01:19.588  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                          2024-09-25 09:01:19.609  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                          2024-09-25 09:01:24.599  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                          2024-09-25 09:01:24.619  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                          2024-09-25 09:01:29.616  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                          2024-09-25 09:01:29.628  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                          2024-09-25 09:01:37.201  - info: host.heizpi Objects database successfully reconnected
                          2024-09-25 09:01:37.204  - info: host.heizpi Objects database successfully reconnected
                          2024-09-25 09:02:49.236  - error: host.heizpi States database error: connect ECONNREFUSED 192.168.178.6:9000
                          2024-09-25 09:02:49.239  - error: host.heizpi Objects database error: connect ECONNREFUSED 192.168.178.6:9001
                          2024-09-25 09:02:54.248  - info: host.heizpi Objects database successfully reconnected
                          2024-09-25 09:02:54.251  - info: host.heizpi Objects database successfully reconnected
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           10:15:41 up 20 min,  2 users,  load average: 0.72, 0.35, 0.30
                          CPU threads: 2
                                         Local time: Wed 2024-09-25 10:15:41 CEST
                                     Universal time: Wed 2024-09-25 08:15:41 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          marco
                          HOME=/home/marco
                          GROUPS=marco sudo users iobroker
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal: 	tty
                          *** MEMORY ***
                          Mem:            2.1G        1.2G        411M        135K        492M        903M
                          Swap:           536M          0B        536M
                          Total:          2.7G        1.2G        948M
                                   2048 M total memory
                                   1186 M used memory
                                   1205 M active memory
                                    337 M inactive memory
                                    391 M free memory
                                      0 M buffer memory
                                    469 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          top - 10:15:41 up 20 min,  2 users,  load average: 0.72, 0.35, 0.30
                          Tasks:  45 total,   1 running,  44 sleeping,   0 stopped,   0 zombie
                          MiB Mem :   2048.0 total,    390.4 free,   1187.8 used,    470.0 buff/cache
                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.    860.2 avail Mem
                          *** FILESYSTEM ***
                          /dev/mapper/pve-vm--100--disk--0 ext4      7.8G  4.1G  3.3G  56% /
                          tmpfs                            tmpfs     1.2G  128K  1.2G   1% /run
                          tmpfs                            tmpfs     584M     0  584M   0% /run/user/1000
                          | |-/run/user/1000                                      tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=598012k,nr_inodes=149503,mode=700,uid=101000,gid=101000,inode64
                          /var:
                          419M	/var/
                          248M	/var/cache
                          245M	/var/cache/apt
                          146M	/var/lib
                          Archived and active journals take up 8.0M in the file system.
                          842M	/opt/iobroker/iobroker-data/
                          553M	/opt/iobroker/iobroker-data/files
                          61M	/opt/iobroker/iobroker-data/states.jsonl
                          8.6M	/opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm 		10.8.2
                          /usr/bin/npx 		10.8.2
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin: 		7.1.2
                          javascript: 	8.7.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects: 	2275
                          States: 	1805
                          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:3 http://security.debian.org bookworm-security InRelease
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5400599    294/master
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       5429225    2441/io.shelly.0
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5399021    1/init
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       5428303    2149/iobroker.js-co
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       5428300    2149/iobroker.js-co
                          tcp        0      0 0.0.0.0:44167           0.0.0.0:*               LISTEN      104        5401869    429/rpc.statd
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          5399023    1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          5399224    1/init
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       5432700    2543/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5429621    2270/io.admin.0
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5400600    294/master
                          tcp6       0      0 :::7906                 :::*                    LISTEN      1001       5429914    2396/io.roborock.0
                          tcp6       0      0 :::47517                :::*                    LISTEN      104        5401875    429/rpc.statd
                          tcp6       0      0 :::6824                 :::*                    LISTEN      1001       5429913    2396/io.roborock.0
                          udp        0      0 127.0.0.1:605           0.0.0.0:*                           0          5401852    429/rpc.statd
                          udp        0      0 0.0.0.0:50005           0.0.0.0:*                           1001       5429314    2149/iobroker.js-co
                          udp        0      0 0.0.0.0:42227           0.0.0.0:*                           104        5401866    429/rpc.statd
                          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       5432432    2482/io.radar2.0
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5399022    1/init
                          udp6       0      0 :::33474                :::*                                104        5401872    429/rpc.statd
                          udp6       0      0 :::111                  :::*                                0          5399024    1/init
                          2024-09-25 10:14:40.508  - info: radar2.0 (2482) debug: radar2 found here (Fritzbox, Xperia-Marco)
                          2024-09-25 10:14:40.508  - info: radar2.0 (2482) debug: and who here (Fritzbox, Xperia-Marco)
                          2024-09-25 10:14:40.508  - info: radar2.0 (2482) debug: and not here (iPhone-Patrizia)
                          2024-09-25 10:14:40.508  - info: radar2.0 (2482) debug: radar2 found uBT's: []
                          2024-09-25 10:14:40.508  - info: radar2.0 (2482) debug: radar2 found uIP's: []
                          2024-09-25 10:15:07.283  - info: radar2.0 (2482) debug: ChangeState ack:true of Fritzbox._lastHere = 2024-09-25@10:15:07
                          2024-09-25 10:15:10.598  - info: radar2.0 (2482) debug: ChangeState ack:true of Xperia-Marco._lastHere = 2024-09-25@10:15:10
                          2024-09-25 10:15:10.607  - info: radar2.0 (2482) debug: ChangeState ack:true of Fritzbox._nHere = 23
                          2024-09-25 10:15:10.610  - info: radar2.0 (2482) debug: ChangeState ack:true of Xperia-Marco._nHere = 23
                          2024-09-25 10:15:10.612  - info: radar2.0 (2482) debug: radar2 found here (Fritzbox, Xperia-Marco)
                          2024-09-25 10:15:10.612  - info: radar2.0 (2482) debug: and who here (Fritzbox, Xperia-Marco)
                          2024-09-25 10:15:10.612  - info: radar2.0 (2482) debug: and not here (iPhone-Patrizia)
                          2024-09-25 10:15:10.612  - info: radar2.0 (2482) debug: radar2 found uBT's: []
                          2024-09-25 10:15:10.612  - info: radar2.0 (2482) debug: radar2 found uIP's: []
                          2024-09-25 10:15:15.192  - warn: roborock.0 (2396) State "roborock.0.Devices.6OHbplLtKW1fSqmmRsscGx.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                          2024-09-25 10:15:15.335  - warn: roborock.0 (2396) Failed to map rooms. You need to name your rooms via the mobile app on your phone.
                          2024-09-25 10:15:37.283  - info: radar2.0 (2482) debug: ChangeState ack:true of Fritzbox._lastHere = 2024-09-25@10:15:37
                          2024-09-25 10:15:40.504  - info: radar2.0 (2482) debug: ChangeState ack:true of Xperia-Marco._lastHere = 2024-09-25@10:15:40
                          2024-09-25 10:15:40.512  - info: radar2.0 (2482) debug: ChangeState ack:true of Fritzbox._nHere = 24
                          2024-09-25 10:15:40.516  - info: radar2.0 (2482) debug: ChangeState ack:true of Xperia-Marco._nHere = 24
                          2024-09-25 10:15:40.518  - info: radar2.0 (2482) debug: radar2 found here (Fritzbox, Xperia-Marco)
                          2024-09-25 10:15:40.518  - info: radar2.0 (2482) debug: and who here (Fritzbox, Xperia-Marco)
                          2024-09-25 10:15:40.518  - info: radar2.0 (2482) debug: and not here (iPhone-Patrizia)
                          2024-09-25 10:15:40.518  - info: radar2.0 (2482) debug: radar2 found uBT's: []
                          2024-09-25 10:15:40.518  - info: radar2.0 (2482) debug: radar2 found uIP's: []
                          Problem besteht aber weiterhin.
                          • M mago
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Swap:           209M          0B        209M
                                      907 M total memory
                                      181 M used memory
                                      206 M active memory
                                      568 M free memory
                                       23 M buffer memory
                                      187 M swap cache
                                      199 M total swap
                                        0 M used swap
                                      199 M free swap
                            *** FILESYSTEM ***
                            /var:
                            888M	/var/
                            470M	/var/cache
                            464M	/var/cache/apt
                            166M	/var/lib
                            USB-Devices by-id:
                            /usr/bin/npm 		10.8.2
                            /usr/bin/npx 		10.8.2
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		7.1.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	2275
                            States: 	1805
                            Pending Updates: 0
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                              Virtualization: lxc
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 2
                                             RTC time: n/a
                                      RTC in local TZ: no
                            marco
                            HOME=/home/marco
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Swap:           536M          0B        536M
                                     2048 M total memory
                                     1186 M used memory
                                      391 M free memory
                                        0 M buffer memory
                                      469 M swap cache
                                      512 M total swap
                                        0 M used swap
                                      512 M free swap
                            *** FILESYSTEM ***
                            /var:
                            419M	/var/
                            248M	/var/cache
                            245M	/var/cache/apt
                            146M	/var/lib
                            USB-Devices by-id:
                            /usr/bin/npm 		10.8.2
                            /usr/bin/npx 		10.8.2
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		7.1.2
                            javascript: 	8.7.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	2275
                            States: 	1805
                            Pending Updates: 0
                            @mago sagte in Multihost probleme ## Error: No configuration received! ##:
                            Nein, es ist NICHT egal, weil mal GRUNDSÄTZLICH NIE als root agiert.
                            Nie wie in GAR NICHT.
                              mago
                              Hast ja Recht, kommt nicht wieder vor.
                              Was ich gerade feststelle ist dass ich auf das Webinterface von Slave/RPi3 nicht draufkomme, obwohl der admin Adapter eigentlich läuft.
                              Zusammen mit
                              sieht das irgendwie wie instabile Verbindung aus, was mit WLAN im Keller auch durchaus nachvollziehbar erscheint. Allerdings läuft SSH absolut problemlos, und das multihost Verbindungsproblem hatte ich auch gestern Abend schon als der Pi quasi noch neben der FritzBox lag.
                                mago
                                Nach einiger Recherche habe ich herausgefunden, dass manche hier den Automatismen von iob multihost enable / connect nicht so ganz trauen, daher habe ich folgendes gemacht:
                                Den Slave habe ich nochmal komplett neu aufgesetzt mit Raspi Imager und dem iobroker install Skript
                                Auf dem Master habe ich nur iob setup custom aufgerufen:
                                - Objects database:
                                  - Type: jsonl
                                  - Port: 9001
                                - States database:
                                  - Type: jsonl
                                  - Port: 9000
                                Host name of this machine [iobroker]:
                                (letztlich habe ich hier die defaults stehen lassen)
                                Auf dem Slave:
                                - Objects database:
                                  - Type: jsonl
                                  - Host/Unix Socket: 127.0.0.1
                                  - Port: 9001
                                - States database:
                                  - Type: jsonl
                                  - Port: 9000
                                Host / Unix Socket of objects DB(jsonl), default[127.0.0.1]: 192.168.178.6
                                Host / Unix Socket of states DB (jsonl), default[192.168.178.6]:
                                Host name of this machine [heizpi]:
                                (also letztlich auch nur die IP des Master gesetzt)
                                • beide Knoten mit iob restart neu gestartet
                                Und schon taucht der Slave unter 'hosts' auf dem Master auf und ist verbunden.
                                • M mago
                                  - Objects database:
                                    - Type: jsonl
                                    - Port: 9001
                                  - States database:
                                    - Type: jsonl
                                    - Port: 9000
                                  Auf dem Slave:
                                  - Objects database:
                                    - Type: jsonl
                                    - Port: 9001
                                  - States database:
                                    - Type: jsonl
                                    - Port: 9000
                                  @mago
                                  Was hast du denn zuvor gemacht?
                                  • M mago
                                    Zusammen mit
                                    Meister MopperM Online
                                    Meister Mopper
                                    Der Slave hat kein Webinterface, auch wenn da eine admin Instanz läuft, wird das System vom admin des Masters organisiert.
                                    Eine admin Instanz ist auf dem Slave nicht erforderlich.
                                    Proxmox und HA ...
