  4. Fehlermeldungen bei Adapter Update
    1.9k
5 Beiträge 2 Kommentatoren 1.1k Aufrufe
  • N Offline
    N Offline
    Newmiraculix
    ich bekomme in der letzten Zeit immer Fehlermeldungen beim installieren oder updaten von Adaptern.
    Kann jemand von euch mir sagen, was das genaue Problem ist und wie ich es beseitigen kann? Am Ende funktioniert die Installation dann übrigens doch.
    $ ./iobroker upgrade ical
    Update ical from @1.3.2 to @1.4.0
    npm install iobroker.ical@1.4.0 --production --prefix "/opt/iobroker" (System call)
    node-pre-gyp ERR! Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.3.1/usb_bindings-v1.3.1-node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for usb@1.3.1 and node@6.12.2 (node-v48 ABI) (falling back to source compile with node-gyp)
    ../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefunden #include <libudev.h>^
    compilation terminated.make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Fehler 1
    gyp
    ERR! build error
    gyp
     ERR! stack Error: `make` failed with exit code: 2gyp
     ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)gyp ERR!
    stack     at emitTwo (events.js:106:13)gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp
    ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.9.59-v7+gyp
     ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding"gyp ERR! cwd
     /opt/iobroker/node_modules/usbgyp ERR! node -v v6.12.2
    gyp ERR! node-gyp -v v3.6.0
    gyp ERR! not ok
    node-pre-gyp
     ERR! build error
    node-pre-gyp
     ERR! stack Error: Failed to execute '/usr/bin/node /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at emitTwo (events.js:106:13)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:920:16)
    node-pre-gyp ERR!
     stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)node-pre-gyp ERR!
     System Linux 4.9.59-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
    node-pre-gyp ERR! node -v v6.12.2node-pre-gyp ERR!
     node-pre-gyp -v v0.6.32
    node-pre-gyp ERR! not ok</anonymous></libudev.h>
    CCU2 mit noch nicht ganz so vielen Aktoren :D
    RaspberryPi2 für SmartHome mit ioBroker
    RaspberryPi3 für SmartHome Mit iobroker (Multihost)
    Logitech Harmony Hub
    RaspberryPi3 mit openELEC
    Amazon Echo, Echo Dot und Echo…
    • N Offline
      N Offline
      Newmiraculix
      Ist ein Linux Spezialist da? :)
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        welche node und NPM version hast du drauf ?
        node -v
        npm -v
        • N Offline
          N Offline
          Newmiraculix
          node v6.12.2 und NPM 3.10.10
          • DutchmanD Offline
            DutchmanD Offline
            Dutchman
            @Newmiraculix:
            node v6.12.2 und NPM 3.10.10 `
            ok, habe de adapter auch geupdated gerade die gyp error kan man verwarlosen hatte ich auch laeuft aber durch.
            Steht bei dir am ende:
            got /opt/iobroker/node_modules/iobroker.ical/admin
            upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
            Update "system.adapter.ical.0"
            upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index.html index.html text/html
            upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
            Adapter "ical" updated
            dan ist alles ok
