  4. Diskussion zum HowTo nodejs-Installation und upgrade
    1.0k
    6.1k
nodejs
844 Beiträge 91 Kommentatoren 309.8k Aufrufe 63 Beobachtet
  • Michael ÜBM Michael ÜB
    ich habe leider auch Probleme node-js etc upzudaten.
    Ich hab schon alles mögliche versucht.
    Folgende Fehlermeldung erhalte ich:
    Recommended versions are nodejs 20.17.0 and npm 10.8.2
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please execute
    iobroker nodejs-update
    to fix these errors.
    komplettes iob diag siehe unten.
    iobroker nodejs-update funktioniert dann auch nicht:
    ioBroker nodejs fixer 2024-05-23
    Recommended nodejs-version is: 20.17.0
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/node 		v16.18.1
    /usr/bin/npm 		8.19.2
    /usr/bin/npx 		8.19.2
    /usr/bin/corepack 	0.14.1
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 16.18.1-deb-1nodesource1
      Candidate: 20.17.0-1nodesource1
      Version table:
         20.17.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
     *** 16.18.1-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u4 500
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v16.18.1. Do you want to install recommended version 20.17.0?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Get:3 https://packages.grafana.com/oss/deb stable InRelease [7660 B]
    Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
    Err:3 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    Fetched 13.3 MB in 7s (1782 kB/s)
    Reading package lists... Done
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Installing nodejs now!
    /home/iobroker/.nodejs-update.sh: line 370: [: : integer expression expected
    /home/iobroker/.nodejs-update.sh: line 387: [: : integer expression expected
    Installing the nodejs!
    E: Failed to fetch https://packages.grafana.com/oss/deb/pool/main/g/grafana/grafana-rpi_10.1.0_arm.deb  404  Not Found [IP: 2a04:4e42:8e::729 443]
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    komplettes iob diag:
    			v.2024-05-22
       Static hostname: michisraspi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.61-v7l+
          Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		32 bit
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    Display-Server: 	true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	311
    Pending iob updates: 	14
    Nodejs-Installation:
    nodejs: 		N/A
    /usr/bin/npm 		8.19.2
    /usr/bin/npx 		8.19.2
    Please execute
    MEMORY:
    Mem:            1.9G        822M         99M         21M        950M        1.1G
    Swap:            99M        1.0M         98M
    Total:          2.0G        824M        197M
    Active iob-Instances: 	14
    Active repo(s): stable
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			7.0.23
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : michisraspi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : michisraspi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		2107
    States: 		1864
    Size of iob-Database:
    11M	/opt/iobroker/iobroker-data/objects.jsonl
    748K	/opt/iobroker/iobroker-data/states.jsonl
    #813
    @michael-üb
    Du musst deine Paketquellen aufräumen. Bei Grafana klemmt es.
    Super...
    Bring das erstmal überhaupt auf einen konsistenten Stand, danach kannste dann über nodejs nachdenken.
    Und ein Desktop rumpelt da auch umher.
    Michael ÜBM 1 Antwort Letzte Antwort
      Please execute
      /usr/bin/npm 		8.19.2
      /usr/bin/npx 		8.19.2
      nodejs:
        Version table:
      Package: nodejs
      Pin-Priority: 1001
      			v.2024-05-22
               Icon name: computer
            Architecture: arm
      Kernel: 		armv7l
      Userland: 		32 bit
      User-ID: 		1000
      nodejs: 		N/A
      /usr/bin/npm 		8.19.2
      /usr/bin/npx 		8.19.2
      Please execute
      MEMORY:
      Swap:            99M        1.0M         98M
      			admin 			7.0.23
      Objects type: jsonl
      States  type: jsonl
      Objects: 		2107
      States: 		1864
      #814
      @michael-üb sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
      alt
      veraltet
      weitere Schreckensnachrichten wird wohl die Langfassung ans Tageslicht bringen
        @michael-üb
        Super...
        Michael ÜBM Offline
        Michael ÜBM Offline
        Michael ÜB
        #815
        OK, ist halt jetzt schon sehr lang, sehr stabil gelaufen, warum also was ändern...
        Bis man neue Funktionen benutzen möchte. Na gut ich mach mich mal an die Arbeit..
        Michael
          #816
          Weil man die Kiste GRUNSDÄTZLICH IMMER AKTUELL HÄLT!!
            #817
            Kannste gleich neuinstallieren. Dann in der aktuellen 64Bit-Lite-Version.
              #818
              @thomas-braun ob sich aber ein Backup mit controller v4 in eine Neuinstallation mit v6 einlesen lässt ???
              @michael-üb
              je größer due Sprünge, desto schwieriger bis unmöglich wird ein Update
                @michael-üb
                #819
                @homoran sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                Nö. Den ganzen Summs natürlich zuvor auf Stand bringen. Und dann damit in den Neubau umziehen.
                  Michael ÜBM Offline
                  Michael ÜBM Offline
                  Michael ÜB
                  #820
                  Besten Dank schon mal.
                  Hab erstmal das "alte" Bullseye auf Stand gebracht.
                  Bis auf Grafana, da kümmern ich mich später, sehe da keinen direkten Zusammenhang zum iobroker.
                  iobroker läuft soweit, mit aktuellem npm und node.
                  Aber was muss ich denn tun, damit ich meine iobroker Backups dann in der Controller Version 6 nutzen kann.
                  Wenn ich es richtig verstehe, besteht die Gefahr das ich nach update auf js-controller 6.0.xx meine backups nicht mehr lesen kann.
                  Michael
                  • Thomas BraunT Online
                    #821
                    Nee, du sieht ja offenbar eh keine Zusammenhänge was wichtige Updates angeht...
                    Bring das ganze Konstrukt auf einen konsistenten Stand, das gilt auch für Grafana.
                    Mach einen separaten Thread auf und poste da die Langfassung von
                    iob diag
                    rein.
                      iob diag
                      rein.
                      Michael ÜBM Offline
                      Michael ÜBM Offline
                      Michael ÜB
                      #822
                      Oh doch, die Zusammenhänge sehe ich, sonst hätte ich ja keine Backups....
                      Ich kümmer mich dann mal um grafana.....
                      ...und bitte nicht böse sein, es gibt halt Menschen die fahren lieber Motorrad und machen sich in der Werkstatt die Finger an Drehbank und alten Motoren schmutzig, wenn du mal was in die Richtung brauchst helfe ich auch gerne.
                      Michael
                        #823
                        Dann hättest du aber keine 311 Updates beim OS und 14 beim ioBroker verpennt. Das Mopped hat also akuten Wartungsstau.
                          Michael ÜBM Offline
                          Michael ÜBM Offline
                          Michael ÜB
                          #824
                          So, alles wieder im Lot.
                          Danke hier und an chatgpt ;-)
                          Michael
                            #825
                            chatgpt
                            Was hat dir das denn geflüstert?
                            iob diag
                            flüstert dir?
                              chatgpt
                              iob diag
                              flüstert dir?
                              Michael ÜBM Offline
                              Michael ÜBM Offline
                              Michael ÜB
                              #826
                              @thomas-braun said in Diskussion zum HowTo nodejs-Installation und upgrade:
                              chatgpt
                              iob diag
                              flüstert dir?
                              chatgpt hat mir verraten, wie ich die Grafen Installation sauber ziehe.
                              Ich habs erstmal bei bullseye belassen, hochziehen mit allem Gedöns ist wohl etwas aufwändiger.
                              			v.2024-05-22
                                       Icon name: computer
                                          Kernel: Linux 6.1.21-v8+
                                    Architecture: arm64
                              Kernel: 		aarch64
                              Userland: 		32 bit
                              User-ID: 		1000
                              Display-Server: 	false
                              Boot Target: 		multi-user.target
                              Pending OS-Updates: 	0
                              Pending iob updates: 	5
                              /usr/bin/nodejs 	v20.17.0
                              /usr/bin/node 		v20.17.0
                              /usr/bin/npm 		10.8.2
                              /usr/bin/npx 		10.8.2
                              /usr/bin/corepack 	0.29.3
                              MEMORY:
                              Mem:            1.8G        1.0G        184M        0.0K        657M        843M
                              Swap:            99M        6.0M         93M
                              Total:          1.9G        1.0G        278M
                              Active iob-Instances: 	13
                              Upgrade policy: none
                              ioBroker Core: 		js-controller 		6.0.11
                              			admin 			7.0.23
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		2111
                              States: 		1842
                              17M	/opt/iobroker/iobroker-data/objects.jsonl
                              1.2M	/opt/iobroker/iobroker-data/states.jsonl
                              Michael
                                chatgpt
                                iob diag
                                flüstert dir?
                                			v.2024-05-22
                                         Icon name: computer
                                      Architecture: arm64
                                Kernel: 		aarch64
                                Userland: 		32 bit
                                User-ID: 		1000
                                /usr/bin/npm 		10.8.2
                                /usr/bin/npx 		10.8.2
                                MEMORY:
                                Swap:            99M        6.0M         93M
                                			admin 			7.0.23
                                Objects type: jsonl
                                States  type: jsonl
                                Objects: 		2111
                                States: 		1842
                                #827
                                Hochziehen von Bullseye auf Bookworm funktioniert für Raspberry OS auch nicht. Also ist das nicht aufwändiger als eine komplette Neuinstallation. Mit Backup ist das in kurzer Zeit erledigt.
                                F 1 Antwort Letzte Antwort
                                  final
                                  schrieb am zuletzt editiert von final
                                  #828
                                  Moin.
                                  Ich habe in der Weboberfläche das node.js Update angeklickt. Was auch immer mich geritten hat ...?
                                  Jetzt dreht sich im Dialogfenster dazu dauerhaft ein blauer Kreis seit geraumer Zeit. Muss ich mir Sorgen machen?
                                  EDIT: läuft immer noch. Kann ich das irgendwie abbrechen?
                                  EDIT 2: so, ich hab grad mal die Website reloaded. Danach war das Dialogfenster weg. node.js und npm sind aktuell nun - gehangen hat es anscheindend, weil iob source analytix installieren wollte, was nicht funktioniert hat (ich hatte SA auf dem alten RPi drauf, es aber nach dem Umstieg auf den Rpi5 (noch) nicht wieder installiert)
                                  Von daher scheint erstmal alles wieder ok zu sein.
                                  • F final
                                    Moin.
                                    #829
                                    @final sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                    Schau mittels
                                    iob nodejs-update
                                    über die Kommandozeile nach. Das ist ohnehin robuster als GUI-Geraffel.
                                    • C Offline
                                      ChefkochTS
                                      #830
                                      Re: Diskussion zum HowTo nodejs-Installation und upgrade
                                      Ich habe das update mit iob nodejs-update probiert und bekomme folgende Meldung:
                                      chefkochts@iobroker:~$ iob nodejs-update
                                      bash: /home/iobroker/.nodejs-update.sh: Permission denied
                                      Ich wollte von 18.20.4 auf 20.18.0 kommen.
                                      Was muss ich tun das es funktioniert?
                                      Thorsten
                                      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
                                      Hier gehts zur Hilfe.
                                      • C ChefkochTS
                                        Thorsten
                                        #831
                                        @chefkochts
                                        sudo chmod 750 /home/iobroker
                                        Dann nochmal versuchen
                                        C 1 Antwort Letzte Antwort
                                        • C ChefkochTS
                                          Thorsten
                                          #832
                                          @chefkochts bitte aussagekräftigen Threadtitel und code-tags verwenden.
