  4. Puppeteer Adapter
    6.5k
Puppeteer Adapter
76 Beiträge 8 Kommentatoren 13.1k Aufrufe 7 Beobachtet
  • JensenJ Jensen
    @oliverio
    Ok, dann mal mit stoppen
    c:\ioBroker>npm install iobroker.puppeteer
    npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
    npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
    npm warn deprecated npmlog@6.0.2: This package is no longer supported.
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated har-validator@5.1.5: this library is no longer supported
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
    npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
    npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
    npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (github.com/visionmedia/debug/issues/797)
    npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
    npm warn deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
    npm warn deprecated gauge@4.0.4: This package is no longer supported.
    npm warn deprecated gauge@3.0.2: This package is no longer supported.
    npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See v8.dev/blog/math-random for details.
    npm warn deprecated request@2.88.2: request has been deprecated, see github.com/request/request/issues/3142
    npm warn deprecated sinon@15.2.0: 16.1.1
    added 64 packages, removed 2 packages, changed 1295 packages, and audited 1361 packages in 3m
    170 packages are looking for funding
      run `npm fund` for details
    57 vulnerabilities (6 low, 30 moderate, 20 high, 1 critical)
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues possible (including breaking changes), run:
      npm audit fix --force
    Some issues need review, and may require choosing
    a different dependency.
    Run `npm audit` for details.
    jetzt sieht das wieder so aus
    c:\ioBroker>npm ls puppeteer
    iobroker.inst@3.0.0 c:\ioBroker
    `-- iobroker.puppeteer@0.3.0
      `-- puppeteer@22.15.0
    Bei dem Versuch, über die Adapterseite eine Instanz zu erzeugen, kommt dann das
    $ iobroker add puppeteer auto --host IpsServerWB --debug
    node:internal/modules/cjs/loader:1225 const err = new Error(message); ^ Error: Cannot find module 'C:\ioBroker\node_modules\deep-clone\index.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15) at Module._load (node:internal/modules/cjs/loader:1051:27) at cjsLoader (node:internal/modules/esm/translators:346:17) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:286:7) at ModuleJob.run (node:internal/modules/esm/module_job:234:25) at async ModuleLoader.import (node:internal/modules/esm/loader:473:24) { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v20.17.0
    ERROR: Process exited with code 1
    Ich glaube, das ist alles zwecklos.
    Eine Neuinstallation muß her.
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    @jensen
    Schon seltsam.
    Er meckert das ein bestimmtes Modul nicht gefunden worden ist.
    Neuinstallation macht Sinn. Es sind Zuviel kleinklein Probleme
    Und ob das dann später noch stabil läuft ist auch keine Garantie.
    Was für Hardware und Festplatte hast du im Einsatz?
    Meine Adapter und Widgets
    Links im Profil
    JensenJ 1 Antwort Letzte Antwort
    • OliverIOO OliverIO
      @jensen
      Schon seltsam.
      JensenJ Offline
      JensenJ Offline
      Jensen
      @oliverio
      NUC i5 mit SSD
      • JensenJ Jensen
        @oliverio
        NUC i5 mit SSD
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @jensen
        Ne dann ist es eher unwahrscheinlich das die Platte was hat
        Links im Profil
          @jensen
          JensenJ Offline
          JensenJ Offline
          Jensen
          @oliverio
          So, ich habe den Sonntag für eine Neuinstallation genutzt.
          ioBroker neu installiert, die Basics eingerichtet, dann ein Restore, dann hier und da ein wenig geradeziehen, alles halbwegs stressfrei.
          Als dann alles wieder lief und ich keine Probleme mehr sehen konnte, wieder den Puppeteer Adapter installiert, direkt von der Adapterseite, alles problemlos und ohne Fehlermeldungen.
          Insofern hat die Neuinstallation schon mal was gebracht.
          Leider kann ich aber immer noch keine Bilder erzeugen.
          Der Adapter liefert folgende Fehlermeldung:
          • bei den Flot Charts
          Could not take screenshot of "http://localhost:8082/flot/index.html?timeType=static&relativeEnd=now&range=10&aggregateType=count&aggregateSpan=300&hoverDetail=false&useComma=false&zoom=false&noedit=true&animation=0&l%5B0%5D%5Bid%5D=javascript.0.Haus.Verbrauch&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=6&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=0&l%5B0%5D%5BafterComma%5D=2&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B1%5D%5Bid%5D=javascript.0.Haus.Einspeisung&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=0&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=2&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B2%5D%5Bid%5D=javascript.0.PV.TriPower.PV-Leistung_kW&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%23ffc300&l%5B2%5D%5Bthickness%5D=1&l%5B2%5D%5Bshadowsize%5D=0&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=1&l%5B2%5D%5BafterComma%5D=2&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B3%5D%5Bid%5D=modbus.1.inputRegisters.13350_TO_TotalDemand&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%2352a0ff&l%5B3%5D%5Bthickness%5D=1&l%5B3%5D%5Bshadowsize%5D=0&l%5B3%5D%5Bname%5D=PV+Demand&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=1&l%5B3%5D%5BignoreNull%5D=&l%5B3%5D%5BafterComma%5D=2&l%5B3%5D%5Bdashes%5D=false&l%5B3%5D%5BdashLength%5D=10&l%5B3%5D%5BspaceLength%5D=10&l%5B4%5D%5Bid%5D=modbus.1.coils.12310_PV_Freigabe&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=-15&l%5B4%5D%5Bmax%5D=5&l%5B4%5D%5Bthickness%5D=1&l%5B4%5D%5Bshadowsize%5D=0&l%5B4%5D%5Bname%5D=PV+Freigabe&l%5B4%5D%5BignoreNull%5D=&l%5B4%5D%5BafterComma%5D=2&l%5B4%5D%5Bdashes%5D=false&l%5B4%5D%5BdashLength%5D=10&l%5B4%5D%5BspaceLength%5D=10&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&start=2024-09-07&start_time=06:00:00&end=2024-09-08&end_time=20:00:00&width=700&height=300&legend=nw&legColumns=5&legBgOpacity=0&timeFormat=%25H%3A%25M": net::ERR_ABORTED at http://localhost:8082/flot/index.html?timeType=static&relativeEnd=now&range=10&aggregateType=count&aggregateSpan=300&hoverDetail=false&useComma=false&zoom=false&noedit=true&animation=0&l%5B0%5D%5Bid%5D=javascript.0.Haus.Verbrauch&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=6&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=0&l%5B0%5D%5BafterComma%5D=2&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B1%5D%5Bid%5D=javascript.0.Haus.Einspeisung&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=0&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=2&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B2%5D%5Bid%5D=javascript.0.PV.TriPower.PV-Leistung_kW&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%23ffc300&l%5B2%5D%5Bthickness%5D=1&l%5B2%5D%5Bshadowsize%5D=0&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=1&l%5B2%5D%5BafterComma%5D=2&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B3%5D%5Bid%5D=modbus.1.inputRegisters.13350_TO_TotalDemand&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%2352a0ff&l%5B3%5D%5Bthickness%5D=1&l%5B3%5D%5Bshadowsize%5D=0&l%5B3%5D%5Bname%5D=PV+Demand&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=1&l%5B3%5D%5BignoreNull%5D=&l%5B3%5D%5BafterComma%5D=2&l%5B3%5D%5Bdashes%5D=false&l%5B3%5D%5BdashLength%5D=10&l%5B3%5D%5BspaceLength%5D=10&l%5B4%5D%5Bid%5D=modbus.1.coils.12310_PV_Freigabe&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=-15&l%5B4%5D%5Bmax%5D=5&l%5B4%5D%5Bthickness%5D=1&l%5B4%5D%5Bshadowsize%5D=0&l%5B4%5D%5Bname%5D=PV+Freigabe&l%5B4%5D%5BignoreNull%5D=&l%5B4%5D%5BafterComma%5D=2&l%5B4%5D%5Bdashes%5D=false&l%5B4%5D%5BdashLength%5D=10&l%5B4%5D%5BspaceLength%5D=10&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&start=2024-09-07&start_time=06:00:00&end=2024-09-08&end_time=20:00:00&width=700&height=300&legend=nw&legColumns=5&legBgOpacity=0&timeFormat=%25H%3A%25M
          und bei meiner Wetter Seite
          Could not take screenshot of "file:///C:/ioBroker/images/msnweather1.html": Navigation timeout of 30000 ms exceeded
          In beiden Fällen kann ich die URL im Browser aufrufen und bekomme angezeigt, was ich erwarte.
          Da ich nichts an meinen Scripten geändert habe, und beide Fälle für die ich den Puppeteer Adapter monatelang benutzt habe nun nicht mehr funktionieren, denke ich, das muß mit irgendeinem Update zu tun haben. Aber ich finde keinen Ansatz, wo ich nun wieder suchen könnte.
          • JensenJ Jensen
            @oliverio
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @jensen
            Kannst du mir mal komplette Beispiele geben?
            Verwendest du sendto oder die datenpunkte?
            Ich versuche das mal nachzustellen
            Links im Profil
              @jensen
              JensenJ Offline
              JensenJ Offline
              Jensen
              @oliverio
              Ich benutze sendto, im Groben sieht das bei mir so aus :
              function createImage(_output, _url) {
                  //log(_url);
                  log('try to create : ' + _output);
                  sendTo('puppeteer.0', 'screenshot', {
                      url: _url,
                      path: '../../images/' + _output,
                      viewportOptions: {
                          width: 700,
                          height: 300
                      renderTime: 20000
                  obj => {
                    if (obj.error) {
                      log('Error taking screenshot: ${obj.error.message}', 'error');
              // PV heute
              var url01 = 'http://localhost:8082/flot/ .........';
              createImage('img01.png', url01);
              Die Url müßtest du durch was Brauchbares auf deinem System ersetzen.
              Ich glaube aber, das Problem steckt tiefer, entweder in der verwendeten Puppeteer Version oder eher in der darunterliegenden chrome Version.
              Ich finde auf meinem System schon wieder so viele verschiedene Versionen von chrome, das verwirrt mich.
              Unter C:\Windows\System32\config\systemprofile.cache\puppeteer\chrome
              Im Benutzer Verzeichnis C:\Users\IpsJensen.cache\puppeteer\chrome
              Wie sind da die Zusammenhänge?
              Wer installiert was wann wo, und wo wird entschieden, was benutzt wird?
              JensenJ OliverIOO 3 Antworten Letzte Antwort
              • JensenJ Jensen
                @oliverio
                    //log(_url);
                        url: _url,
                        viewportOptions: {
                            width: 700,
                            height: 300
                        renderTime: 20000
                    obj => {
                      if (obj.error) {
                // PV heute
                JensenJ Offline
                JensenJ Offline
                Jensen
                @foxriver76
                Könntest Du vielleicht einem Ahnungslosen etwas weiter helfen?
                Ich weiß hier einfach nicht weiter.
                • JensenJ Jensen
                  @oliverio
                      //log(_url);
                          url: _url,
                          viewportOptions: {
                              width: 700,
                              height: 300
                          renderTime: 20000
                      obj => {
                        if (obj.error) {
                  // PV heute
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @jensen
                  Der Adapter nutzt eigentlich nur das folgende package.
                  Dies sorgt sich um das herunterladen und das richtige ansprechen des Browsers.
                  https://www.npmjs.com/package/puppeteer
                  Hauptanwendungszweck dieses Pakets ist automatisierter Tests von webanwendungen.
                  Dazu wird meist die applikation in einer gekapselten virtuellen Umgebung (meist sowas wie docker) installiert, die Tests ausgeführt und am Ende die komplette Umgebung wieder weggeworfen.
                  Andere anwendungsfälle sind webscraping oder sowas wie hier, was aber wahrscheinlich bei weitem nicht so oft in der Welt angewendet wird.
                  Das deinstallieren von Browsern wurde erst letztes Jahr hinzugefügt
                  https://github.com/puppeteer/puppeteer/pull/10179
                  Ob das im Adapter berücksichtigt ist weiß ich nicht.
                  Die Ursache deiner Fehler kann vielfältig sein.
                  Bei flot stand im Ergebnis ein net_err drin. Das deutet darauf hin, das irgendwas mit der netzverbindung nicht passt. Aber auch hier kann es vielfältig sein. Am wahrscheinlichsten sind timeouts, aber daher wollte ich das mal für mich selbst probieren um das einzugrenzen.
                  Bei deinem msnwetter kann es sein, das der Anbieter Begrenzungen eingebaut hat, die ein automatisiertes Abrufen verhindert. Ich selbst bin im Zusammenhang einer nieten Fragestellung letztens auch auf sowas gestoßen, das der Abruf im Browser funktioniert, mit puppeteer aber nicht. Wie die verhinderungsstrategie funktioniert weiß ich aktuell nicht.
                  Also ichdenke nicht das der Fehler aktuell noch an puppeteer liegt
                  Links im Profil
                  • JensenJ Jensen
                    @oliverio
                        //log(_url);
                            url: _url,
                            viewportOptions: {
                                width: 700,
                                height: 300
                            renderTime: 20000
                        obj => {
                          if (obj.error) {
                    // PV heute
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @jensen sagte in Puppeteer Adapter:
                    also flot funktioniert bei mir
                    msn weather eigentlich auch, allerdings erhalte ich mit puppeteer nur die folgende seite
                    link ist
                    https://www.msn.com/en-us/weather/forecast/in-Frankfurt,Hesse
                    aufgrund des net_err vermute ich, das irgendwas mit dem abruf der daten von deinem nuc nicht passt.
                    probiere es mal direkt von dort mit curl
                    um im script eine bessere fehlermeldung zu erhalten ändere mal die zeile zu.
                    da waren die falschen anfürhungszeichen drin und message ist da auch nicht vorhanden.
                    ich frage mich wie du die fehlermeldung weiter oben produzieren konntest?
                            log(`Error taking screenshot: ${obj.error}`, 'error');
                    wenn der timeout von puppeteer nicht reicht, dann solltest du die folgende option einbauen
                    waitForTimeout
                            url: _url,
                            viewportOptions: {
                                width: 700,
                                height: 300
                          renderTime: 20000,
                          waitOption: {
                            waitForTimeout: 20000,
                    der generelle timeout ist auf 5 sekunden eingestellt, was eigentlich reichen sollte.
                    überprüfe auch mal noch deinen bilderpfad, ob der existiert.
                    evtl mal ohne pfad nur mit img.png eintragen, dann findest du das bild unter /opt/iobroker/ioberoker-data
                    Links im Profil
                    • JensenJ Offline
                      JensenJ Offline
                      Jensen
                      schrieb am zuletzt editiert von Jensen
                      @oliverio
                      Für msnweather brauchst du die von mir geparste Datei.
                      msnweather1.html
                      (Bitte nicht an den komischen Zeichen vor dem °C stören, das ist ein anderes Thema.
                      Was ist der Unterschied bei diesen verschiedenen Apostrophen?
                      Ich habe meine Log Zeile geändert.
                      Die waitOption habe ich auch dazu gebaut.
                      Ergebnis:
                      javascript.0
                         2024-09-09 15:48:27.524	error	script.js.test.PuppeteerSample3: Error taking screenshot: timeout
                      javascript.0
                         2024-09-09 15:48:07.516	info	script.js.test.PuppeteerSample3: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                      javascript.0
                         2024-09-09 15:48:07.516	info	script.js.test.PuppeteerSample3: try to create : msnweather1.png
                      javascript.0
                         2024-09-09 15:48:07.516	info	script.js.test.PuppeteerSample3: file:///C:/ioBroker/images/msnweather1.html
                      javascript.0
                         2024-09-09 15:48:07.495	info	Start JavaScript script.js.test.PuppeteerSample3 (Javascript/js)
                      Interessant ist, ich habe waitOption auf 60000, renderTime auf 30000, aber der timeout kommt nach 20000.
                      • JensenJ Jensen
                        @oliverio
                        msnweather1.html
                        Ergebnis:
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        JensenJ Offline
                        JensenJ Offline
                        Jensen
                        Ohne Pfad bringt auch keine Änderung.
                        • JensenJ Jensen
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @jensen
                          Was sagt curl?
                          Links im Profil
                            @jensen
                            Was sagt curl?
                            JensenJ Offline
                            JensenJ Offline
                            Jensen
                            @oliverio
                            curl ?
                            Was muß ich tun?
                            • JensenJ Jensen
                              @oliverio
                              curl ?
                              Was muß ich tun?
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @jensen
                              curl müsste seit windows 10 installiert sein.
                              du gehst auf die komandozeile deines nucs
                              am besten mit der gleichen berechtigung wie iobroker
                              und führst bspw das aus
                              in anführungszeichen steht der link.
                              curl ruft dann die daten ab, ungefähr so wie es puppeteer macht und gibt sie aus.
                              wenn irgendwelche fehler dabei angezeigt werden könnte das interessant sein
                              curl "https://www.msn.com/en-us/weather/forecast/in-Frankfurt,Hesse?loc=eyJsIjoiRnJhbmtmdXJ0IiwiciI6Ikhlc3NlIiwicjIiOiJGcmFua2Z1cnQgYW0gTWFpbiIsImMiOiJHZXJtYW55IiwiaSI6IkRFIiwidCI6MTAyLCJnIjoiZW4tdXMiLCJ4IjoiOC42Nzk0OTk2MjYxNTk2NjgiLCJ5IjoiNTAuMTEwOTAwODc4OTA2MjUiLCJvIjp0cnVlfQ%3D%3D&weadegreetype=C"
                              hier die anleitung für curl
                              https://curl.se/docs/manpage.html
                              Links im Profil
                                @jensen
                                JensenJ Offline
                                JensenJ Offline
                                Jensen
                                @oliverio
                                Wir müssen das verschieben.
                                Ich bin jetzt erst mal 2 Wochen auf Montage und hier ist die Internetverbindung momentan sehr schlecht, komme nicht per VPN auf den Rechner.
                                • JensenJ Jensen
                                  @oliverio
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  @jensen
                                  alles gut. du schreibst am besten wieder in diesen thread wenns weitere fragen gibt
                                  Links im Profil
                                  • E Offline
                                    e_a_s_y
                                    hallo,
                                    ich versuche gerade vergeblich einen screenshot meiner vis zu erstellen.
                                    nach updates funktioniert der phantomJS nicht mehr der das seit 2 jahren gut erledigt hatte.
                                    daher bin ich nun zu puppeteer gewechselt.
                                    mittels send-to wird hier auch ein screeshot erstellt. leider aber zu früh so das nicht alles mit drauf ist.
                                    laut der docu von puppetier gibt es hier den rendertime parameter, leider ist dieser aber im beispiel nicht mit drin.
                                    ich habe einiges versucht und dann versucht im netz etwas zu finden.
                                    lande aber immer wieder hier.
                                    kann mir evtl. jemand erklären was ich falsch mache. ich bräuchte nur eine verzögerung von 8-10 sekunden erhalte aber immer nach 5s das bild. (oder teile davon)
                                    hier mein test-script:
                                    sendTo('puppeteer.1', 'screenshot', {
                                            url: 'http://192.168.5.153:8082/vis/?main#Heizung',
                                            ioBrokerOptions: { storagePath: 'tempt.png'  },
                                            path: 'c://iobroker//test-screenshot-heizung.png',
                                            fullPage: false,
                                            omitBackground: true,
                                            encoding: 'binary',
                                            captureBeyondViewport: false,
                                            renderTime: 8000,
                                    E liv-in-skyL 2 Antworten Letzte Antwort
                                    • E e_a_s_y
                                      hallo,
                                              fullPage: false,
                                              encoding: 'binary',
                                              renderTime: 8000,
                                      e_a_s_y
                                      @e_a_s_y
                                      nach 2 abenden testen ohne erfolg hier eine notlösung.
                                      nur für mich wenn ich wieder hier lande:
                                      in datei: ...node_modules\iobroker.puppeteer\build\main.js
                                      await this.delay(7000);
                                      hinter die wait condition einfügen (ca. zeile 105 & ca. zeile 170)
                                      • E e_a_s_y
                                        @e_a_s_y
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        @e_a_s_y
                                        Hast du ein Issue im Adapter repository eröffnet und dein problem (und deinen9 Workaround dort abgelegt?
                                        Ohne issue wird da siher nichts gendert / gefixed / verbessert.
                                        https://github.com/foxriver76/ioBroker.puppeteer/issues
                                        Support Repositoryverwaltung.
                                        LESEN - gute Forenbeitrage
                                        • E e_a_s_y
                                          hallo,
                                                  fullPage: false,
                                                  encoding: 'binary',
                                                  renderTime: 8000,
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #66
                                          @e_a_s_y
                                          hast du mal waitForTimeout oder waitForSelector probiert - siehe: https://github.com/foxriver76/ioBroker.puppeteer
                                          E 1 Antwort Letzte Antwort
