  4. Puppeteer Adapter
    6.5k
Puppeteer Adapter
76 Beiträge 8 Kommentatoren 13.1k Aufrufe 7 Beobachtet
  • JensenJ Jensen
    iob fix
    c:\ioBroker>iob fix
    Need to install the following packages:
    @iobroker/fix@6.0.1
    Ok to proceed? (y) y
    Windows installation starting... (fixing = true)
    NPM version: 10.8.3
    No path given, using c:\ioBroker\iobroker-data
    Compressing c:\ioBroker\iobroker-data\states.jsonl
    Cannot compress states.jsonl: Error: Failed to lock DB file "c:\ioBroker\iobroker-data\states.jsonl"!
        at JsonlDB.open (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@alcalzone\jsonl-db\build\lib\db.js:185:19)
        at async compressDB (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:37:9)
        at async main (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:78:17)
    Compressing c:\ioBroker\iobroker-data\objects.jsonl
    Cannot compress objects.jsonl: Error: Failed to lock DB file "c:\ioBroker\iobroker-data\objects.jsonl"!
        at async main (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:93:17)
    No relevant JSONL files found to compress, skip
    NPM version: 10.8.3
    Write "iobroker start" to start the ioBroker
    npm install dotenv@^16.4.5 --force --loglevel error --production --save --prefix "c:/ioBroker"
    npm error code EBUSY
    npm error syscall rename
    npm error path c:\ioBroker\node_modules\iobroker.admin
    npm error dest c:\ioBroker\node_modules\.iobroker.admin-FjHuUvU7
    npm error errno -4082
    npm error EBUSY: resource busy or locked, rename 'c:\ioBroker\node_modules\iobroker.admin' -> 'c:\ioBroker\node_modules\.iobroker.admin-FjHuUvU7'
    npm error A complete log of this run can be found in: C:\Users\IpsJensen\AppData\Local\npm-cache\_logs\2024-09-07T06_21_00_662Z-debug-0.log
    Error when installing dotenv Library: Error: Command failed: npm install dotenv@^16.4.5 --force --loglevel error --production --save --prefix "c:/ioBroker"
    sieht auch nicht berauschend aus
    JensenJ Offline
    JensenJ Offline
    Jensen
    Und was mir noch auffällt, ich habe kein admin.0, sondern nur ein admin.1
    Das ist doch auch nicht normal, oder?
    JensenJ 1 Antwort Letzte Antwort
    • JensenJ Jensen
      JensenJ Offline
      JensenJ Offline
      Jensen
      Nach Einrichten der Istanz admin.0 und Löschen von admin.1 kann ich die Skripte jetzt wieder problemlos exportieren.
      • JensenJ Jensen
        @oliverio
        Ok, dann mal mit stoppen
        c:\ioBroker>npm install iobroker.puppeteer
        npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
        npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
        npm warn deprecated npmlog@5.0.1: This package is no longer supported.
        npm warn deprecated npmlog@6.0.2: This package is no longer supported.
        npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
        npm warn deprecated har-validator@5.1.5: this library is no longer supported
        npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
        npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
        npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
        npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
        npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
        npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (github.com/visionmedia/debug/issues/797)
        npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
        npm warn deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
        npm warn deprecated gauge@4.0.4: This package is no longer supported.
        npm warn deprecated gauge@3.0.2: This package is no longer supported.
        npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See v8.dev/blog/math-random for details.
        npm warn deprecated request@2.88.2: request has been deprecated, see github.com/request/request/issues/3142
        npm warn deprecated sinon@15.2.0: 16.1.1
        added 64 packages, removed 2 packages, changed 1295 packages, and audited 1361 packages in 3m
        170 packages are looking for funding
          run `npm fund` for details
        57 vulnerabilities (6 low, 30 moderate, 20 high, 1 critical)
        To address issues that do not require attention, run:
          npm audit fix
        To address all issues possible (including breaking changes), run:
          npm audit fix --force
        Some issues need review, and may require choosing
        a different dependency.
        Run `npm audit` for details.
        jetzt sieht das wieder so aus
        c:\ioBroker>npm ls puppeteer
        iobroker.inst@3.0.0 c:\ioBroker
        `-- iobroker.puppeteer@0.3.0
          `-- puppeteer@22.15.0
        Bei dem Versuch, über die Adapterseite eine Instanz zu erzeugen, kommt dann das
        $ iobroker add puppeteer auto --host IpsServerWB --debug
        node:internal/modules/cjs/loader:1225 const err = new Error(message); ^ Error: Cannot find module 'C:\ioBroker\node_modules\deep-clone\index.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15) at Module._load (node:internal/modules/cjs/loader:1051:27) at cjsLoader (node:internal/modules/esm/translators:346:17) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:286:7) at ModuleJob.run (node:internal/modules/esm/module_job:234:25) at async ModuleLoader.import (node:internal/modules/esm/loader:473:24) { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v20.17.0
        ERROR: Process exited with code 1
        Ich glaube, das ist alles zwecklos.
        Eine Neuinstallation muß her.
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @jensen
        Schon seltsam.
        Er meckert das ein bestimmtes Modul nicht gefunden worden ist.
        Neuinstallation macht Sinn. Es sind Zuviel kleinklein Probleme
        Und ob das dann später noch stabil läuft ist auch keine Garantie.
        Was für Hardware und Festplatte hast du im Einsatz?
        Meine Adapter und Widgets
        Links im Profil
        • OliverIOO OliverIO
          @jensen
          Schon seltsam.
          JensenJ Offline
          JensenJ Offline
          Jensen
          @oliverio
          NUC i5 mit SSD
          • JensenJ Jensen
            @oliverio
            NUC i5 mit SSD
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @jensen
            Ne dann ist es eher unwahrscheinlich das die Platte was hat
            Links im Profil
              @jensen
              JensenJ Offline
              JensenJ Offline
              Jensen
              @oliverio
              So, ich habe den Sonntag für eine Neuinstallation genutzt.
              ioBroker neu installiert, die Basics eingerichtet, dann ein Restore, dann hier und da ein wenig geradeziehen, alles halbwegs stressfrei.
              Als dann alles wieder lief und ich keine Probleme mehr sehen konnte, wieder den Puppeteer Adapter installiert, direkt von der Adapterseite, alles problemlos und ohne Fehlermeldungen.
              Insofern hat die Neuinstallation schon mal was gebracht.
              Leider kann ich aber immer noch keine Bilder erzeugen.
              Der Adapter liefert folgende Fehlermeldung:
              • bei den Flot Charts
              Could not take screenshot of "http://localhost:8082/flot/index.html?timeType=static&relativeEnd=now&range=10&aggregateType=count&aggregateSpan=300&hoverDetail=false&useComma=false&zoom=false&noedit=true&animation=0&l%5B0%5D%5Bid%5D=javascript.0.Haus.Verbrauch&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=6&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=0&l%5B0%5D%5BafterComma%5D=2&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B1%5D%5Bid%5D=javascript.0.Haus.Einspeisung&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=0&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=2&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B2%5D%5Bid%5D=javascript.0.PV.TriPower.PV-Leistung_kW&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%23ffc300&l%5B2%5D%5Bthickness%5D=1&l%5B2%5D%5Bshadowsize%5D=0&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=1&l%5B2%5D%5BafterComma%5D=2&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B3%5D%5Bid%5D=modbus.1.inputRegisters.13350_TO_TotalDemand&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%2352a0ff&l%5B3%5D%5Bthickness%5D=1&l%5B3%5D%5Bshadowsize%5D=0&l%5B3%5D%5Bname%5D=PV+Demand&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=1&l%5B3%5D%5BignoreNull%5D=&l%5B3%5D%5BafterComma%5D=2&l%5B3%5D%5Bdashes%5D=false&l%5B3%5D%5BdashLength%5D=10&l%5B3%5D%5BspaceLength%5D=10&l%5B4%5D%5Bid%5D=modbus.1.coils.12310_PV_Freigabe&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=-15&l%5B4%5D%5Bmax%5D=5&l%5B4%5D%5Bthickness%5D=1&l%5B4%5D%5Bshadowsize%5D=0&l%5B4%5D%5Bname%5D=PV+Freigabe&l%5B4%5D%5BignoreNull%5D=&l%5B4%5D%5BafterComma%5D=2&l%5B4%5D%5Bdashes%5D=false&l%5B4%5D%5BdashLength%5D=10&l%5B4%5D%5BspaceLength%5D=10&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&start=2024-09-07&start_time=06:00:00&end=2024-09-08&end_time=20:00:00&width=700&height=300&legend=nw&legColumns=5&legBgOpacity=0&timeFormat=%25H%3A%25M": net::ERR_ABORTED at http://localhost:8082/flot/index.html?timeType=static&relativeEnd=now&range=10&aggregateType=count&aggregateSpan=300&hoverDetail=false&useComma=false&zoom=false&noedit=true&animation=0&l%5B0%5D%5Bid%5D=javascript.0.Haus.Verbrauch&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=6&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=0&l%5B0%5D%5BafterComma%5D=2&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B1%5D%5Bid%5D=javascript.0.Haus.Einspeisung&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=0&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=2&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B2%5D%5Bid%5D=javascript.0.PV.TriPower.PV-Leistung_kW&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%23ffc300&l%5B2%5D%5Bthickness%5D=1&l%5B2%5D%5Bshadowsize%5D=0&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=1&l%5B2%5D%5BafterComma%5D=2&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B3%5D%5Bid%5D=modbus.1.inputRegisters.13350_TO_TotalDemand&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%2352a0ff&l%5B3%5D%5Bthickness%5D=1&l%5B3%5D%5Bshadowsize%5D=0&l%5B3%5D%5Bname%5D=PV+Demand&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=1&l%5B3%5D%5BignoreNull%5D=&l%5B3%5D%5BafterComma%5D=2&l%5B3%5D%5Bdashes%5D=false&l%5B3%5D%5BdashLength%5D=10&l%5B3%5D%5BspaceLength%5D=10&l%5B4%5D%5Bid%5D=modbus.1.coils.12310_PV_Freigabe&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=-15&l%5B4%5D%5Bmax%5D=5&l%5B4%5D%5Bthickness%5D=1&l%5B4%5D%5Bshadowsize%5D=0&l%5B4%5D%5Bname%5D=PV+Freigabe&l%5B4%5D%5BignoreNull%5D=&l%5B4%5D%5BafterComma%5D=2&l%5B4%5D%5Bdashes%5D=false&l%5B4%5D%5BdashLength%5D=10&l%5B4%5D%5BspaceLength%5D=10&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&start=2024-09-07&start_time=06:00:00&end=2024-09-08&end_time=20:00:00&width=700&height=300&legend=nw&legColumns=5&legBgOpacity=0&timeFormat=%25H%3A%25M
              und bei meiner Wetter Seite
              Could not take screenshot of "file:///C:/ioBroker/images/msnweather1.html": Navigation timeout of 30000 ms exceeded
              In beiden Fällen kann ich die URL im Browser aufrufen und bekomme angezeigt, was ich erwarte.
              Da ich nichts an meinen Scripten geändert habe, und beide Fälle für die ich den Puppeteer Adapter monatelang benutzt habe nun nicht mehr funktionieren, denke ich, das muß mit irgendeinem Update zu tun haben. Aber ich finde keinen Ansatz, wo ich nun wieder suchen könnte.
              • JensenJ Jensen
                @oliverio
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @jensen
                Kannst du mir mal komplette Beispiele geben?
                Verwendest du sendto oder die datenpunkte?
                Ich versuche das mal nachzustellen
                Links im Profil
                  @jensen
                  JensenJ Offline
                  JensenJ Offline
                  Jensen
                  @oliverio
                  Ich benutze sendto, im Groben sieht das bei mir so aus :
                  function createImage(_output, _url) {
                      //log(_url);
                      log('try to create : ' + _output);
                      sendTo('puppeteer.0', 'screenshot', {
                          url: _url,
                          path: '../../images/' + _output,
                          viewportOptions: {
                              width: 700,
                              height: 300
                          renderTime: 20000
                      obj => {
                        if (obj.error) {
                          log('Error taking screenshot: ${obj.error.message}', 'error');
                  // PV heute
                  var url01 = 'http://localhost:8082/flot/ .........';
                  createImage('img01.png', url01);
                  Die Url müßtest du durch was Brauchbares auf deinem System ersetzen.
                  Ich glaube aber, das Problem steckt tiefer, entweder in der verwendeten Puppeteer Version oder eher in der darunterliegenden chrome Version.
                  Ich finde auf meinem System schon wieder so viele verschiedene Versionen von chrome, das verwirrt mich.
                  Unter C:\Windows\System32\config\systemprofile.cache\puppeteer\chrome
                  Im Benutzer Verzeichnis C:\Users\IpsJensen.cache\puppeteer\chrome
                  Wie sind da die Zusammenhänge?
                  Wer installiert was wann wo, und wo wird entschieden, was benutzt wird?
                  JensenJ OliverIOO 3 Antworten Letzte Antwort
                  • JensenJ Jensen
                    @oliverio
                        //log(_url);
                            url: _url,
                            viewportOptions: {
                                width: 700,
                                height: 300
                            renderTime: 20000
                        obj => {
                          if (obj.error) {
                    // PV heute
                    JensenJ Offline
                    JensenJ Offline
                    Jensen
                    @foxriver76
                    Könntest Du vielleicht einem Ahnungslosen etwas weiter helfen?
                    Ich weiß hier einfach nicht weiter.
                    • JensenJ Jensen
                      @oliverio
                          //log(_url);
                              url: _url,
                              viewportOptions: {
                                  width: 700,
                                  height: 300
                              renderTime: 20000
                          obj => {
                            if (obj.error) {
                      // PV heute
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @jensen
                      Der Adapter nutzt eigentlich nur das folgende package.
                      Dies sorgt sich um das herunterladen und das richtige ansprechen des Browsers.
                      https://www.npmjs.com/package/puppeteer
                      Hauptanwendungszweck dieses Pakets ist automatisierter Tests von webanwendungen.
                      Dazu wird meist die applikation in einer gekapselten virtuellen Umgebung (meist sowas wie docker) installiert, die Tests ausgeführt und am Ende die komplette Umgebung wieder weggeworfen.
                      Andere anwendungsfälle sind webscraping oder sowas wie hier, was aber wahrscheinlich bei weitem nicht so oft in der Welt angewendet wird.
                      Das deinstallieren von Browsern wurde erst letztes Jahr hinzugefügt
                      https://github.com/puppeteer/puppeteer/pull/10179
                      Ob das im Adapter berücksichtigt ist weiß ich nicht.
                      Die Ursache deiner Fehler kann vielfältig sein.
                      Bei flot stand im Ergebnis ein net_err drin. Das deutet darauf hin, das irgendwas mit der netzverbindung nicht passt. Aber auch hier kann es vielfältig sein. Am wahrscheinlichsten sind timeouts, aber daher wollte ich das mal für mich selbst probieren um das einzugrenzen.
                      Bei deinem msnwetter kann es sein, das der Anbieter Begrenzungen eingebaut hat, die ein automatisiertes Abrufen verhindert. Ich selbst bin im Zusammenhang einer nieten Fragestellung letztens auch auf sowas gestoßen, das der Abruf im Browser funktioniert, mit puppeteer aber nicht. Wie die verhinderungsstrategie funktioniert weiß ich aktuell nicht.
                      Also ichdenke nicht das der Fehler aktuell noch an puppeteer liegt
                      Links im Profil
                      • JensenJ Jensen
                        @oliverio
                            //log(_url);
                                url: _url,
                                viewportOptions: {
                                    width: 700,
                                    height: 300
                                renderTime: 20000
                            obj => {
                              if (obj.error) {
                        // PV heute
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @jensen sagte in Puppeteer Adapter:
                        also flot funktioniert bei mir
                        msn weather eigentlich auch, allerdings erhalte ich mit puppeteer nur die folgende seite
                        link ist
                        https://www.msn.com/en-us/weather/forecast/in-Frankfurt,Hesse
                        aufgrund des net_err vermute ich, das irgendwas mit dem abruf der daten von deinem nuc nicht passt.
                        probiere es mal direkt von dort mit curl
                        um im script eine bessere fehlermeldung zu erhalten ändere mal die zeile zu.
                        da waren die falschen anfürhungszeichen drin und message ist da auch nicht vorhanden.
                        ich frage mich wie du die fehlermeldung weiter oben produzieren konntest?
                                log(`Error taking screenshot: ${obj.error}`, 'error');
                        wenn der timeout von puppeteer nicht reicht, dann solltest du die folgende option einbauen
                        waitForTimeout
                                url: _url,
                                viewportOptions: {
                                    width: 700,
                                    height: 300
                              renderTime: 20000,
                              waitOption: {
                                waitForTimeout: 20000,
                        der generelle timeout ist auf 5 sekunden eingestellt, was eigentlich reichen sollte.
                        überprüfe auch mal noch deinen bilderpfad, ob der existiert.
                        evtl mal ohne pfad nur mit img.png eintragen, dann findest du das bild unter /opt/iobroker/ioberoker-data
                        Links im Profil
                        • JensenJ Offline
                          JensenJ Offline
                          Jensen
                          schrieb am zuletzt editiert von Jensen
                          @oliverio
                          Für msnweather brauchst du die von mir geparste Datei.
                          msnweather1.html
                          (Bitte nicht an den komischen Zeichen vor dem °C stören, das ist ein anderes Thema.
                          Was ist der Unterschied bei diesen verschiedenen Apostrophen?
                          Ich habe meine Log Zeile geändert.
                          Die waitOption habe ich auch dazu gebaut.
                          Ergebnis:
                          javascript.0
                             2024-09-09 15:48:27.524	error	script.js.test.PuppeteerSample3: Error taking screenshot: timeout
                          javascript.0
                             2024-09-09 15:48:07.516	info	script.js.test.PuppeteerSample3: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          javascript.0
                             2024-09-09 15:48:07.516	info	script.js.test.PuppeteerSample3: try to create : msnweather1.png
                          javascript.0
                             2024-09-09 15:48:07.516	info	script.js.test.PuppeteerSample3: file:///C:/ioBroker/images/msnweather1.html
                          javascript.0
                             2024-09-09 15:48:07.495	info	Start JavaScript script.js.test.PuppeteerSample3 (Javascript/js)
                          Interessant ist, ich habe waitOption auf 60000, renderTime auf 30000, aber der timeout kommt nach 20000.
                          • JensenJ Jensen
                            @oliverio
                            msnweather1.html
                            Ergebnis:
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            javascript.0
                            JensenJ Offline
                            JensenJ Offline
                            Jensen
                            Ohne Pfad bringt auch keine Änderung.
                            • JensenJ Jensen
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @jensen
                              Was sagt curl?
                              Links im Profil
                                @jensen
                                Was sagt curl?
                                JensenJ Offline
                                JensenJ Offline
                                Jensen
                                @oliverio
                                curl ?
                                Was muß ich tun?
                                • JensenJ Jensen
                                  @oliverio
                                  curl ?
                                  Was muß ich tun?
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  @jensen
                                  curl müsste seit windows 10 installiert sein.
                                  du gehst auf die komandozeile deines nucs
                                  am besten mit der gleichen berechtigung wie iobroker
                                  und führst bspw das aus
                                  in anführungszeichen steht der link.
                                  curl ruft dann die daten ab, ungefähr so wie es puppeteer macht und gibt sie aus.
                                  wenn irgendwelche fehler dabei angezeigt werden könnte das interessant sein
                                  curl "https://www.msn.com/en-us/weather/forecast/in-Frankfurt,Hesse?loc=eyJsIjoiRnJhbmtmdXJ0IiwiciI6Ikhlc3NlIiwicjIiOiJGcmFua2Z1cnQgYW0gTWFpbiIsImMiOiJHZXJtYW55IiwiaSI6IkRFIiwidCI6MTAyLCJnIjoiZW4tdXMiLCJ4IjoiOC42Nzk0OTk2MjYxNTk2NjgiLCJ5IjoiNTAuMTEwOTAwODc4OTA2MjUiLCJvIjp0cnVlfQ%3D%3D&weadegreetype=C"
                                  hier die anleitung für curl
                                  https://curl.se/docs/manpage.html
                                  Links im Profil
                                    @jensen
                                    JensenJ Offline
                                    JensenJ Offline
                                    Jensen
                                    @oliverio
                                    Wir müssen das verschieben.
                                    Ich bin jetzt erst mal 2 Wochen auf Montage und hier ist die Internetverbindung momentan sehr schlecht, komme nicht per VPN auf den Rechner.
                                    • JensenJ Jensen
                                      @oliverio
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      @jensen
                                      alles gut. du schreibst am besten wieder in diesen thread wenns weitere fragen gibt
                                      Links im Profil
                                      • E Offline
                                        e_a_s_y
                                        hallo,
                                        ich versuche gerade vergeblich einen screenshot meiner vis zu erstellen.
                                        nach updates funktioniert der phantomJS nicht mehr der das seit 2 jahren gut erledigt hatte.
                                        daher bin ich nun zu puppeteer gewechselt.
                                        mittels send-to wird hier auch ein screeshot erstellt. leider aber zu früh so das nicht alles mit drauf ist.
                                        laut der docu von puppetier gibt es hier den rendertime parameter, leider ist dieser aber im beispiel nicht mit drin.
                                        ich habe einiges versucht und dann versucht im netz etwas zu finden.
                                        lande aber immer wieder hier.
                                        kann mir evtl. jemand erklären was ich falsch mache. ich bräuchte nur eine verzögerung von 8-10 sekunden erhalte aber immer nach 5s das bild. (oder teile davon)
                                        hier mein test-script:
                                        sendTo('puppeteer.1', 'screenshot', {
                                                url: 'http://192.168.5.153:8082/vis/?main#Heizung',
                                                ioBrokerOptions: { storagePath: 'tempt.png'  },
                                                path: 'c://iobroker//test-screenshot-heizung.png',
                                                fullPage: false,
                                                omitBackground: true,
                                                encoding: 'binary',
                                                captureBeyondViewport: false,
                                                renderTime: 8000,
                                        E liv-in-skyL 2 Antworten Letzte Antwort
                                        • E e_a_s_y
                                          hallo,
                                                  fullPage: false,
                                                  encoding: 'binary',
                                                  renderTime: 8000,
                                          e_a_s_y
                                          @e_a_s_y
                                          nach 2 abenden testen ohne erfolg hier eine notlösung.
                                          nur für mich wenn ich wieder hier lande:
                                          in datei: ...node_modules\iobroker.puppeteer\build\main.js
                                          await this.delay(7000);
                                          hinter die wait condition einfügen (ca. zeile 105 & ca. zeile 170)
